    4. Test Adapter fb-checkpresence v0.2.x
      sigi234 Forum Testing Most Active @afuerhoff last edited by
      @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
      Wenn Du magst, kannst Du einmal von Github installieren und die neue Version testen.
      fb-checkpresence.0	2020-03-31 23:40:18.571	error	(26964) getActive: TypeError: Converting circular structure to JSON
      • Negalein
        Negalein Global Moderator @afuerhoff last edited by
        Ich hoffe , das sie jetzt läuft.
        Adapter wechselt regelmäßig von Grün auf Gelb
        fb-checkpresence.0	2020-03-31 23:57:09.219	error	(23525) getActive: TypeError: Converting circular structure to JSON
        fb-checkpresence.0	2020-03-31 23:56:09.403	error	(23525) getActive: TypeError: Converting circular structure to JSON
        fb-checkpresence.0	2020-03-31 23:55:08.474	error	(23525) getActive: TypeError: Converting circular structure to JSON
        fb-checkpresence.0	2020-03-31 23:55:05.805	info	(23525) service GetSecurityPort is supported
        fb-checkpresence.0	2020-03-31 23:55:05.794	info	(23525) service X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2020-03-31 23:55:05.786	info	(23525) service GetSpecificHostEntry is supported
        fb-checkpresence.0	2020-03-31 23:55:05.769	info	(23525) service X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2020-03-31 23:55:05.651	info	(23525) start fb-checkpresence: ip-address: 10.0.1.1 polling interval: 1 Min.
        fb-checkpresence.0	2020-03-31 23:55:05.502	info	(23525) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.17.0
        fb-checkpresence.0	2020-03-31 23:55:02.327	warn	(23525) no connection to states DB
        fb-checkpresence.0	2020-03-31 23:54:53.431	info	(1747) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        fb-checkpresence.0	2020-03-31 23:54:53.430	info	(1747) terminating
        fb-checkpresence.0	2020-03-31 23:54:53.428	info	(1747) cleaned everything up...
        fb-checkpresence.0	2020-03-31 23:54:53.419	info	(1747) Got terminate signal TERMINATE_YOURSELF
        Speed wurde abgeholt 🙂
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Negalein last edited by
          @Negalein @sigi234 @e-s
          Könnt ihr mal das Passwort neu eingeben und wenn noch nicht geschehen in den Konfigurationsdialog der Familienmitglieder den Add-Dialog öffnen und einfach auf hinzufügen. Dann sollten die Ip-Adressen in der Tabelle auftauchen. Mal sehen ob das hilft.
            mameier1234 @afuerhoff last edited by
            @afuerhoff Temporär alle paar Minuten (teilweise Sekunden...)
            Ich habe sogar eine neue FB (6591) und der Fehler ist genau gleich wie vorher... Oder meinst Du , dass der Windows Server, auf dem IO-Broker läuft ein Problem hat (aber sonst nicht meckert ?)
            afuerhoff 2 Replies Last reply Reply Quote 0
            • afuerhoff
              afuerhoff Developer @mameier1234 last edited by
              @mameier1234
              Ich meinte die Fritzbox.
                e-s @afuerhoff last edited by e-s
                @afuerhoff
                hatte nach update auch den json Fehler, bei der Instanz 1 reichte es das PW neu eingeben, in der anderen musste ich die Familienmitlieder neu hinzufügen, dann waren beide Instanzen grün und ohne Fehlermeldung im log
                Ich habe influx.db am laufen, in den Einstellungen kann ich nur zwischen history und disabled wechseln, auch wenn ich auf history wechsle, dann steht im log aber deaktiviert.
                Influx ist in den iobroker Haupteinstellungen als History aktiviert.
                presentMembers als Dp finde ich gut, würde mich aber auch noch über notPresentMembers freuen
                Negalein afuerhoff 2 Replies Last reply Reply Quote 0
                • Negalein
                  Danke, das wars.
                  • Negalein
                    Negalein Global Moderator @e-s last edited by
                    @e-s sagte in Test Adapter fb-checkpresence v0.2.x:
                    Ist vorhanden (oder meinst du was anderes?).
                      e-s @Negalein last edited by
                      @Negalein
                      Wer lesen kann ist klar im Vorteil
                      • afuerhoff
                        afuerhoff Developer @e-s last edited by
                        @e-s
                        Danke an Alle für die Rückmeldungen. Dann hängt das irgendwie mit den neuen Konfigurationsobjekten zusammen. Ich hatte da schon etwas eingebaut. Scheint nicht ausreichend zu sein.
                        • afuerhoff
                          afuerhoff Developer @afuerhoff last edited by
                          @sigi234 @Negalein @mameier1234
                          @e-s
                          Hallo, ich habe gerade noch einen Bugfix auf Github eingespielt. Falls die neuen Konfigurationsobjekte fehlen, kommt ein Hinweis im Log. Bitte einmal testen.
                          sigi234 Negalein 2 Replies Last reply Reply Quote 0
                            Was meinst du da?
                            • Negalein
                              Negalein Global Moderator @afuerhoff last edited by Negalein
                              Ich bekomme das im Log (1x Warn-Meldung zwecks IP).
                              Hab aber eine MAC vergeben.
                              fb-checkpresence.0	2020-04-01 19:41:52.080	debug	(9751) enableHistory.2 Handy-Mausi true
                              fb-checkpresence.0	2020-04-01 19:41:52.079	debug	(9751) enableHistory.2 Handy-Nega true
                              fb-checkpresence.0	2020-04-01 19:41:52.075	debug	(9751) enableHistory.2 Handy-Lisi true
                              fb-checkpresence.0	2020-04-01 19:41:50.047	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:50.045	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:50.043	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:49.859	debug	(9751) checkPresence first run
                              fb-checkpresence.0	2020-04-01 19:41:49.859	warn	(9751) The configured ip-address for Handy-Lisi is empty. Please insert a valid ip-address
                              fb-checkpresence.0	2020-04-01 19:41:49.857	debug	(9751) getDeviceInfo blCnt: 25
                              fb-checkpresence.0	2020-04-01 19:41:49.856	debug	(9751) getDeviceInfo activeCnt: 48
                              fb-checkpresence.0	2020-04-01 19:41:49.723	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
                              fb-checkpresence.0	2020-04-01 19:41:49.459	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
                              fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) createMemberObjects Handy-Mausi
                              fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) createMemberObjects Handy-Nega
                              fb-checkpresence.0	2020-04-01 19:41:49.317	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                              fb-checkpresence.0	2020-04-01 19:41:49.316	debug	(9751) createMemberObjects Handy-Lisi
                              fb-checkpresence.0	2020-04-01 19:41:49.314	debug	(9751) Fritzbox device objects succesfully created
                              fb-checkpresence.0	2020-04-01 19:41:49.299	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
                              fb-checkpresence.0	2020-04-01 19:41:48.962	debug	(9751) response: 1 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
                              fb-checkpresence.0	2020-04-01 19:41:48.800	debug	(9751) chCount 0
                              fb-checkpresence.0	2020-04-01 19:41:48.797	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:Challenge
                              fb-checkpresence.0	2020-04-01 19:41:48.783	debug	(9751) createGlobalObjects
                              fb-checkpresence.0	2020-04-01 19:41:48.781	debug	(9751) sslPort 49443
                              fb-checkpresence.0	2020-04-01 19:41:48.764	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecurityP
                              fb-checkpresence.0	2020-04-01 19:41:48.740	info	(9751) service GetSecurityPort is supported
                              fb-checkpresence.0	2020-04-01 19:41:48.730	info	(9751) service X_AVM-DE_GetSpecificHostEntryByIP is supported
                              fb-checkpresence.0	2020-04-01 19:41:48.718	info	(9751) service GetSpecificHostEntry is supported
                              fb-checkpresence.0	2020-04-01 19:41:48.699	info	(9751) service X_AVM-DE_GetHostListPath is supported
                              fb-checkpresence.0	2020-04-01 19:41:48.636	debug	(9751) configuration familymembers: [{"familymember":"Handy-Lisi","macaddress":"D0:16:B4:79:48:7E","ipaddress":"","useip":false,"comment":"","enabled":true},{"familymember":"Handy-Nega","macaddress":"
                              fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration dateformat: dd.mm.yyyy HH:MM:ss
                              fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration history: history.0
                              fb-checkpresence.0	2020-04-01 19:41:48.634	debug	(9751) configuration user: Christian
                              fb-checkpresence.0	2020-04-01 19:41:48.632	info	(9751) start fb-checkpresence: ip-address: 10.0.1.1 polling interval: 1 Min.
                              fb-checkpresence.0	2020-04-01 19:41:48.573	info	(9751) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.17.0
                              fb-checkpresence.0	2020-04-01 19:41:44.126	info	(8050) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              fb-checkpresence.0	2020-04-01 19:41:44.119	info	(8050) terminating
                              fb-checkpresence.0	2020-04-01 19:41:44.118	info	(8050) cleaned everything up...
                              fb-checkpresence.0	2020-04-01 19:41:44.117	info	(8050) Got terminate signal TERMINATE_YOURSELF
                              fb-checkpresence.0	2020-04-01 19:41:28.427	debug	(8050) sendTo "discovery" to system.adapter.admin.0 from system.adapter.fb-checkpresence.0: [{"name":"Amazon-Echo-Kinderzimmer","ip":"10.0.1.88","mac":"08:84:9D:8E:B9:A6","active":"1"},{"name":"Amazo
                                @Negalein
                                Geh mal in deine familieneinstellung und füge die neu hinzu.
                                  In den FB-Devices habe ich die speed noch als State aufgenommen
                                  Was ist das genau? Welche Einheit?
                                  • Negalein
                                    Negalein Global Moderator @sigi234 last edited by
                                    @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
                                    Danke, geht
                                    • Negalein
                                      Der Anschluss vom Gerät 1000/100/10
                                      Leider werden WLAN Geräte zB auch mit 1000 angezeigt
                                      afuerhoff sigi234 3 Replies Last reply Reply Quote 0
                                      • afuerhoff
                                        @Negalein
                                        Kommt so aus der Fritzbox
                                          sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                                          @Negalein sagte in Test Adapter fb-checkpresence v0.2.x:
                                          Ok, Mbit/s
                                          @afuerhoff
                                          Kannst du es als unit hinzufügen?
                                          • afuerhoff
                                            @mameier1234 sagte in Test Adapter fb-checkpresence v0.2.x:
                                            Hallo, ist der Fehler mit der eben eingespielten Version immer noch so häufig?
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27629
