    4. JavaScript
    5. Sonoff Geräte als HTML Tabelle - Vis
    • Meister Mopper
      Meister Mopper @liv-in-sky last edited by
      @liv-in-sky hab die Zeilen getauscht, allerdings bekomme ich das:
      avascript.0	2020-04-01 15:50:48.552	error	(10408) at Script.runInContext (vm.js:133:20)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at script.js.java.sonstige.Sonoff_Test:2733:2
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
      javascript.0	2020-04-01 15:50:48.552	error	(10408) at script.js.java.sonstige.Sonoff_Test:473:70
      javascript.0	2020-04-01 15:50:48.552	error	(10408) TypeError: Cannot read property 'toString' of null
      javascript.0	2020-04-01 15:50:48.552	error	(10408) ^
      javascript.0	2020-04-01 15:50:48.552	error	(10408) val6=getState(id.replace("INFO.Module","ENERGY_Today")).val.toString();
      javascript.0	2020-04-01 15:50:48.552	error	(10408) script.js.java.sonstige.Sonoff_Test: script.js.java.sonstige.Sonoff_Test:473
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at script.js.java.sonstige.Sonoff_Test:2733:2
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
      javascript.0	2020-04-01 15:50:48.552	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
      javascript.0	2020-04-01 15:50:48.551	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
      javascript.0	2020-04-01 15:50:48.551	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
      • Meister Mopper
        @liv-in-sky bzw. das:
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timer.processTimers (timers.js:223:10)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at listOnTimeout (timers.js:263:5)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at tryOnTimeout (timers.js:300:5)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at ontimeout (timers.js:436:11)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Test:2727:2)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at writeHTML (script.js.java.sonstige.Sonoff_Test:448:30)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
        javascript.0	2020-04-01 15:51:00.006	warn	(10408) at script.js.java.sonstige.Sonoff_Test:473:16
        javascript.0	2020-04-01 15:51:00.005	warn	(10408) getState "sonoff.0.kvm-switch.ENERGY_Today" not found (3)
          liv-in-sky @Meister Mopper last edited by
          @Meister-Mopper hbe es auch gerade gesehen - die haben keinen energy wert
          da müssen wir uns etwas anderes überlegen - vielleicht doch eine eigene kategorie
            liv-in-sky @Meister Mopper last edited by liv-in-sky
            @Meister-Mopper
            was würdest du dann als anzeige gerne sehen - energy fällt aus - was sind den die wichtigen werte - temperatur oder so
            aber bedenke bitte - die tabelle wird nur getriggert beim umschalten des POWER dp's - daher werden die werte nicht immer aktuell sein, da diese vom schedule abhängen
              @Meister-Mopper
              ich meine das hier
              • Meister Mopper
                @liv-in-sky Das passt schon, die aktuelle Temperatur ist nicht kriegsentscheidend.
                  @Meister-Mopper
                  der erste wert der beiden könnte die uptime sein (ist bei anderen auch so) und der zweite - den darfst du entscheiden - die ANALOG-Temperature ?
                    @Meister-Mopper
                    so ?
                    • Meister Mopper
                      @liv-in-sky 1.000 °C - wie geil, dann kann ich ja einen Hochofen anmelden 😉😊
                        @Meister-Mopper mir ist nix besseres eingefallen - muss ja die states zum test schreiben , damit keine fehler kommen 🙂
                        das neue script ist im ersten post - du mußt dann twoNice=true setzen oder
                        du kannst die ganzen settings (von zeile 3 bis bis zeile 113) wieder reinkopieren aber musst dann in zeile 37 das einsetzen - sonst fehlt eine variablen definition
                        Meister Mopper 2 Replies Last reply Reply Quote 0
                        • Meister Mopper
                          @liv-in-sky Super, das ist echt ein Wahnsinn, was Du so umsetzt.
                          Recht herzlichen Dank!
                          • Meister Mopper
                            @liv-in-sky Irgendetwas stimmt nicht, habe das Script wie beschrieben angepasst, bekomme aber Fehler:
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) at Script.runInContext (vm.js:133:20)
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) at script.js.java.sonstige.Sonoff:2797:2
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) at writeHTML (script.js.java.sonstige.Sonoff:1301:3)
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) ReferenceError: mini is not defined
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) ^
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) if (mini){
                            javascript.0	2020-04-01 17:05:24.192	error	(1081) script.js.java.sonstige.Sonoff: script.js.java.sonstige.Sonoff:1301
                              @Meister-Mopper normalerweise ist diese mini abfrage an einer anderen stelle - irgendwie hast du beim kopieren einen "wurm" drin
                              falls du lauter leerzeilen im script hast - nutze den chrome browser und nicht firefox beim kopieren des scriptes aus dem forum
                              • Stephan Schleich
                                Stephan Schleich last edited by Stephan Schleich
                                Ich bekomm folgenden Fehler, weiß jemand was dazu?
                                  liv-in-sky @Stephan Schleich last edited by
                                  @Stephan-Schleich könnte evtl ein fehler im generic teil sein - kannst du mal den generic auf false setzen und das script wieder laufen lassen ?
                                  Stephan Schleich 1 Reply Last reply Reply Quote 0
                                  • Stephan Schleich
                                    Stephan Schleich @liv-in-sky last edited by
                                    @liv-in-sky du hattest recht, dann läuft's, ist das ein Fehler bei mir oder im Script?
                                      @Stephan-Schleich weiß ich nicht - wir könnten anydesk machen und direkt bei dir schauen oder du sendest mir einen json-export deines sonoff.0 ordners - was dir lieber ist
                                      • Stephan Schleich
                                        @liv-in-sky sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                        anydesk
                                        hast pm 🙂
                                          @Stephan-Schleich ich schreib dir im chat
                                            MyMeyer last edited by
                                            @liv-in-sky Hi habe folgenden Gosund hinzugefügt. In Info steht: SP111 v1.1
                                            Tasmota Version 8.1.0.2
                                            javascript monitoring template
                                            34
                                            632
                                            131019
