    4. Test Adapter fb-checkpresence v0.2.x
      sigi234 Forum Testing Most Active @afuerhoff last edited by
      @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
      Falls die neuen Konfigurationsobjekte fehlen
      Was meinst du da?
      • Negalein
        Negalein Global Moderator @afuerhoff last edited by Negalein
        Hallo, ich habe gerade noch einen Bugfix auf Github eingespielt.
        Ich bekomme das im Log (1x Warn-Meldung zwecks IP).
        Hab aber eine MAC vergeben.
        fb-checkpresence.0	2020-04-01 19:41:52.080	debug	(9751) enableHistory.2 Handy-Mausi true
        fb-checkpresence.0	2020-04-01 19:41:52.079	debug	(9751) enableHistory.2 Handy-Nega true
        fb-checkpresence.0	2020-04-01 19:41:52.075	debug	(9751) enableHistory.2 Handy-Lisi true
        fb-checkpresence.0	2020-04-01 19:41:50.047	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:50.045	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:50.043	debug	(9751) sendTo "enableHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:49.859	debug	(9751) checkPresence first run
        fb-checkpresence.0	2020-04-01 19:41:49.859	warn	(9751) The configured ip-address for Handy-Lisi is empty. Please insert a valid ip-address
        fb-checkpresence.0	2020-04-01 19:41:49.857	debug	(9751) getDeviceInfo blCnt: 25
        fb-checkpresence.0	2020-04-01 19:41:49.856	debug	(9751) getDeviceInfo activeCnt: 48
        fb-checkpresence.0	2020-04-01 19:41:49.723	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
        fb-checkpresence.0	2020-04-01 19:41:49.459	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
        fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:49.321	debug	(9751) createMemberObjects Handy-Mausi
        fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:49.319	debug	(9751) createMemberObjects Handy-Nega
        fb-checkpresence.0	2020-04-01 19:41:49.317	debug	(9751) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2020-04-01 19:41:49.316	debug	(9751) createMemberObjects Handy-Lisi
        fb-checkpresence.0	2020-04-01 19:41:49.314	debug	(9751) Fritzbox device objects succesfully created
        fb-checkpresence.0	2020-04-01 19:41:49.299	debug	(9751) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE
        fb-checkpresence.0	2020-04-01 19:41:48.962	debug	(9751) response: 1 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
        fb-checkpresence.0	2020-04-01 19:41:48.800	debug	(9751) chCount 0
        fb-checkpresence.0	2020-04-01 19:41:48.797	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:Challenge
        fb-checkpresence.0	2020-04-01 19:41:48.783	debug	(9751) createGlobalObjects
        fb-checkpresence.0	2020-04-01 19:41:48.781	debug	(9751) sslPort 49443
        fb-checkpresence.0	2020-04-01 19:41:48.764	debug	(9751) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n<u:GetSecurityP
        fb-checkpresence.0	2020-04-01 19:41:48.740	info	(9751) service GetSecurityPort is supported
        fb-checkpresence.0	2020-04-01 19:41:48.730	info	(9751) service X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2020-04-01 19:41:48.718	info	(9751) service GetSpecificHostEntry is supported
        fb-checkpresence.0	2020-04-01 19:41:48.699	info	(9751) service X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2020-04-01 19:41:48.636	debug	(9751) configuration familymembers: [{"familymember":"Handy-Lisi","macaddress":"D0:16:B4:79:48:7E","ipaddress":"","useip":false,"comment":"","enabled":true},{"familymember":"Handy-Nega","macaddress":"
        fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration dateformat: dd.mm.yyyy HH:MM:ss
        fb-checkpresence.0	2020-04-01 19:41:48.635	debug	(9751) configuration history: history.0
        fb-checkpresence.0	2020-04-01 19:41:48.634	debug	(9751) configuration user: Christian
        fb-checkpresence.0	2020-04-01 19:41:48.632	info	(9751) start fb-checkpresence: ip-address: 10.0.1.1 polling interval: 1 Min.
        fb-checkpresence.0	2020-04-01 19:41:48.573	info	(9751) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.17.0
        fb-checkpresence.0	2020-04-01 19:41:44.126	info	(8050) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        fb-checkpresence.0	2020-04-01 19:41:44.119	info	(8050) terminating
        fb-checkpresence.0	2020-04-01 19:41:44.118	info	(8050) cleaned everything up...
        fb-checkpresence.0	2020-04-01 19:41:44.117	info	(8050) Got terminate signal TERMINATE_YOURSELF
        fb-checkpresence.0	2020-04-01 19:41:28.427	debug	(8050) sendTo "discovery" to system.adapter.admin.0 from system.adapter.fb-checkpresence.0: [{"name":"Amazon-Echo-Kinderzimmer","ip":"10.0.1.88","mac":"08:84:9D:8E:B9:A6","active":"1"},{"name":"Amazo
          e-s @Negalein last edited by
          @Negalein
          Geh mal in deine familieneinstellung und füge die neu hinzu.
            In den FB-Devices habe ich die speed noch als State aufgenommen
            Was ist das genau? Welche Einheit?
            Negalein 2 Replies Last reply Reply Quote 0
            • Negalein
              Negalein Global Moderator @sigi234 last edited by
              @sigi234 sagte in Test Adapter fb-checkpresence v0.2.x:
              Danke, geht
              • Negalein
                Der Anschluss vom Gerät 1000/100/10
                Leider werden WLAN Geräte zB auch mit 1000 angezeigt
                afuerhoff sigi234 3 Replies Last reply Reply Quote 0
                • afuerhoff
                  afuerhoff Developer @Negalein last edited by
                  @Negalein
                  Kommt so aus der Fritzbox
                    sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                    @Negalein sagte in Test Adapter fb-checkpresence v0.2.x:
                    Ok, Mbit/s
                    @afuerhoff
                    Kannst du es als unit hinzufügen?
                    • afuerhoff
                      afuerhoff Developer @mameier1234 last edited by
                      @mameier1234 sagte in Test Adapter fb-checkpresence v0.2.x:
                      @afuerhoff Temporär alle paar Minuten (teilweise Sekunden...)
                      Ich habe sogar eine neue FB (6591) und der Fehler ist genau gleich wie vorher... Oder meinst Du , dass der Windows Server, auf dem IO-Broker läuft ein Problem hat (aber sonst nicht meckert ?)
                      Hallo, ist der Fehler mit der eben eingespielten Version immer noch so häufig?
                      • Negalein
                        Ja, leider
                        • afuerhoff
                          Hab das bei mir gerade kontrolliert. Mein Handy wird gerade mit 351 angezeigt.
                          E Negalein 2 Replies Last reply Reply Quote 0
                            e-s @afuerhoff last edited by
                            @afuerhoff
                            bei mir werden da auch andere geschwindigkeiten angezeigt, unschön finde ich nur, das man dies nu unter fb-devices findet und nicht bei den Familienmitglieder direkt
                            afuerhoff 1 Reply Last reply Reply Quote 0
                            • afuerhoff
                              afuerhoff Developer @e-s last edited by
                              @e-s
                              Da kann ich das auch noch mit aufnehmen.
                              • Negalein
                                Ok, bei mir nicht.
                                Liegt eventuell daran, dass ich mit WLAN nicht direkt an der Fritz bin, sondern APs benutze die mit LAN an der Fritz hängen.
                                Aber die Werte sind trotzdem komisch.
                                Ich hab 1000 und meine Frau 0
                                afuerhoff E 2 Replies Last reply Reply Quote 0
                                • afuerhoff
                                  @Negalein
                                  Bei mir steht der Interfacetype auf 802.11. Das Handy ist über AVM Repeater über Mesh eingebunden.
                                    e-s @Negalein last edited by e-s
                                    @Negalein
                                    Also bei mir klappt es auch mit einem AP. Benutze aber einen Fritzrepeater 1750 mit LAN Modus, aber trotzdem im MESH Modus. Ich denke an dem Mesh wird es liegen ob da was kommt.
                                    @afuerhoff
                                    um meine whitelists und blacklists besser im Überblick zu haben, habe ich in meiner Fritz mal ordentlich aufgeräumt und alle unbekannten gelöscht.
                                    Im Adapter bleiben diese Leichen aber teilweise noch länger drin, habe eben mal radikal den objektbaum gelöscht.
                                    Dies hat auch noch einen weiteren Fehler beseitigt, History ist jetzt in den objekten nicht mehr als disabled sonder zumindestens mal leer. Mal sehen ob sich das füllt.
                                    Im log ist aber immernoch disabled zu sehen pbwohl es aktiv sein sollte
                                    • Negalein
                                      bekomm erst die Mesh-Teile.
                                      Dann fliegen alle APs raus.
                                      @e-s sagte in Test Adapter fb-checkpresence v0.2.x:
                                      Bei mir gehts von der Fritz in ein 19" Patchpanel und an dem hängen alle anderen Geräte inkl. APs und noch mehr Switches.
                                        @Negalein @afuerhoff
                                        Apropos switch, habe einen managed switch von tplink oder so im Netzwerk, dieser ist aber nur über ein Tool steuerbar, nicht über ein WebIF, somit hat das Ding eine IP ist aber ansonsten nicht sehr gesprächig.
                                        Hatte das ding versehentlich einer Familie hinzugefügt(da eine Instanz meine shellys überwacht), dabei hat sich mit der beta von heute morgen der Adapter komplett abgeschossen.
                                        • afuerhoff
                                          @Negalein
                                          @afuerhoff
                                          Das mit den Objekten ist noch ein offener Punkt. Was auch noch ein Problem sein könnte, wenn mehrere devices in der Fritzbox den gleichen Namen haben. Dann fehlen Objekte und werden mit dem Inhalt vom letzten gefüllt. Ich müsste hier eigentlich die Mac-Adresse als eindeutigen Kennzeichner verwenden.
                                          Ist denn in der Konfiguration der richtige History Adapter ausgewählt?
                                          • afuerhoff
                                            Hallo, heute morgen war ja noch ein Fehler enthalten. Was heißt kpl. abgeschossen?
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27637
