    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Onkyo
    Onkyo
    • I
      instalator last edited by
      С power разобрался, пулреквест отправил.
      А вот с громкостью что то чудеса творятся.
      Почему в логе сообщения от mqtt??? :?:
      ! onkyo.0 2016-02-25 21:58:08 debug inMem message onkyo.0.* onkyo.0.master-volume
      ! onkyo.0 2016-02-25 21:57:45 info onkyo.0 stateChange onkyo.0.command {"val":"MVL28","ack":true,"ts":1456415865,"q":0,"from":"system.adapter.onkyo.0","lc":1456415865}
      ! onkyo.0 2016-02-25 21:57:45 debug inMem message onkyo.0.* onkyo.0.command
      ! onkyo.0 2016-02-25 21:57:45 info onkyo.0 stateChange onkyo.0.volume {"val":40,"ack":true,"ts":1456415865,"q":0,"from":"system.adapter.onkyo.0","lc":1456415865}
      ! onkyo.0 2016-02-25 21:57:45 debug inMem message onkyo.0.* onkyo.0.volume
      ! onkyo.0 2016-02-25 21:57:45 info onkyo.0 stateChange onkyo.0.master-volume {"val":40,"ack":true,"ts":1456415865,"q":0,"from":"system.adapter.onkyo.0","lc":1456415865}
      ! onkyo.0 2016-02-25 21:57:45 debug inMem message onkyo.0.* onkyo.0.master-volume
      ! onkyo.0 2016-02-25 21:57:45 debug onkyo.0 Received: command[MVL28]
      ! onkyo.0 2016-02-25 21:57:45 debug onkyo.0 Received: volume[40]
      ! onkyo.0 2016-02-25 21:57:45 debug onkyo.0 Received: master-volume[40]
      ! onkyo.0 2016-02-25 21:57:45 info onkyo.0 Got message: {"command":["master-volume","volume"],"argument":40,"iscp_command":"MVL28","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
      ! onkyo.0 2016-02-25 21:57:45 debug onkyo.0 DEBUG (received_data) Received data from 192.168.1.210:60128 - {"command":["master-volume","volume"],"argument":40,"iscp_command":"MVL28","host":"192.168.1.210","port":"60128","model":"TX-NR81
      ! mqtt.0 2016-02-25 21:57:44 warn mqtt.0 Cannot resolve topic name for ID: onkyo.0.volume (object not found)
      ! onkyo.0 2016-02-25 21:57:44 debug onkyo.0 DEBUG (sent_command) Sent command to 192.168.1.210:60128 - MVL2D
      ! onkyo.0 2016-02-25 21:57:44 debug onkyo.0 DEBUG (command_to_iscp) raw command "MVL2D"
      ! onkyo.0 2016-02-25 21:57:44 debug onkyo.0 DEBUG (command_to_iscp) Zone: main | Command: volume | Argument: 45
      ! onkyo.0 2016-02-25 21:57:44 info onkyo.0 stateChange onkyo.0.volume {"val":45,"ack":false,"ts":1456415864,"q":0,"from":"system.adapter.admin.0","lc":1456415864}
      ! onkyo.0 2016-02-25 21:57:44 debug inMem message onkyo.0.* onkyo.0.volume
      • I
        @instalator:
        Перестала работать команда power, работает только system-power. Раньше работало, вроде ничего не делал. В принципе не принципиально, подвязал на другую переменную (Правда пришлось в onkyo.js заменить power на system-power), но сам факт не понятен. Может фильтр по моделям какой сработал из-за добавленных новых переменных. Надо поковырять список команд "высокого уровня".
        var newVal = state.val;
                        if (newVal === true || newVal === 'true' || newVal === '1' || newVal === 1) {
                            newVal = "on";
                        } else if (newVal === false || newVal === 'false' || newVal === '0' || newVal === 0) {
                        	if (ids == 'system-power') {
        				newVal = "standby";
        			} else {
        		    	newVal = "off";
        Я не понимаю что ломает логику.
        Сейчас system-power не создается, а в нативных объектах
        ! "_id": "power",
        ! "type": "state",
        ! "common": {
        ! "name": "Power state",
        ! "type": "boolean",
        ! "role": "button",
        ! "read": true,
        ! "write": true,
        ! "def": null
        ! "native": {
        ! "command": "system-power",
        ! "values": ["standby","on","query"]
        Заменил снова строчку на````
        if (ids == 'power') {
        newVal = "standby";
        • I
          BlueFox а может из-за этих пакетов глюки ловить драйвер?
          https://github.com/caolan/async
          https://github.com/nodeca/js-yaml
          • I
            После всех обновления ошибка с громкостью остается.
            • I
              Вчера появился system-power)
              Видимо с версиями глюк, а вот громкость так и работает криво, регулировать невозможно. Похоже что после изменения уровня не правильно отрабатывает запрос на текущее значение.
              • I
                system-power появился и теперь на power ругается
                onkyo-0 2016-03-11 18:19:13 error Error: ERROR (cmd_not_exist) Command power does not exist in zone main
                • I
                  BlueFox давай разберемся с драйвером, уже поднадоел он, громкостью управлять невозможно.
                  Может попробуем его подключить к тебе? я порты проброшу у себя.
                  ДОБАВЛЕНО!
                  Вспомнил, что я когда то вроде правил файл eiscp-commands.json и добавлял туда свой ресивер. Но так как у меня полетел бекап и пришлось IoB ставить с нуля я соответственно файлик не подложил.
                  В итоге сейчас добавил корректно свою модель в данный файл и вроде как все заработало. Все файлы с командами добавил в первый пост данного топика
                  • Eisbaeeer
                    Eisbaeeer Developer last edited by
                    Hi Guys
                    I can not speak russian. So I don´t know about your discuss here. I have added some code to the onkyo adapter to control with VIS. Eventually you have the same thematic!?
                    After installing the "new test version" through npm you can use buttons to power on|off zone1 and zone2, muting and other things.
                    If you will thest this and report to me (I will do a pull request and need feedback from you) you can do the following:
                    1. Delete onkyo instance
                    2. Delete onkyo adapter
                    3. Delete all onkyo objects
                    4. Connect wiht SSH in the folder /opt/iobroker
                    5. npm install https://github.com/Eisbaeeer/ioBroker.o … ll/master/
                    The adapter appears in admin.
                    6. Install instance
                    7. configure (check box!)
                    8. Start adapter
                    Your feedback is welcome!
                    • I
                      @Eisbaeeer:
                      Hi Guys
                      6. Install instance
                      8. Start adapter
                      Your feedback is welcome! `
                      A strange development, why do we need a new driver for the VIS widget?
                      [{"tpl":"tplMetroTileToggle","data":{"visibility-cond":"==","visibility-val":1,"hover":"true","transform":"true",
                      "bg_class_false":"bg-gray","bg_class_true":"bg-teal","icon_class_false":"icon-arrow-up-2","icon_class_true":"icon-arrow-up-2",
                      "icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"",
                      "brand_bg_class_true":"","visibility-oid":"","oid":"","label_false":"Закрыто","label_true":"Закрыто","icon_false":"","icon_true":"",
                      "oidTrue":"onkyo.0.command","oidFalse":"onkyo.0.command","select_on_true":false,"oidTrueValue":"ZMT00",
                      "oidFalseValue":"ZMT01","badge_top":"0","badge_left":"0","gestures-offsetX":0,"gestures-offsetY":0,
                      "gestures-swiping-value":"","gestures-rotating-value":"","gestures-pinching-value":"","gestures-swipeRight-value":"",
                      "gestures-swipeLeft-value":"","gestures-swipeUp-value":"","gestures-swipeDown-value":"","gestures-rotateLeft-value":"",
                      "gestures-rotateRight-value":"","gestures-pinchIn-value":"","gestures-pinchOut-value":""},
                      "style":{"left":"246px","top":"30px","width":"88px","height":"91px","z-index":"9999","opacity":"1"},"widgetSet":"metro"}]
                      • Eisbaeeer
                        @instalator:
                        A strange development, why do we need a new driver for the VIS widget? `
                        Hi Instalator
                        We asked some times in forum, how to use the onkyo with VIS. Nobody tell us, how to use the onkyo adapter.
                        Can you explain us how to use the adapter in VIS. Perhaps you realized a much better surface.
                        There are some more users who want to use the adapter with VIS. It would be great if you tell us how we can put on/off the zones and the other tools.
                        Perhaps you can provide some screenshots?
                        I used this strange way for 2nd driver because I don´t know how we should use it and I don´t want to change anything of your code. If the adapter works with VIS, let me say, hey, I learned verry much by programming in this adapter. There is no reaoson to use the code, if the adapter works with VIS. 😉
                        Greetings Eisbaeeer
                        • I
                          @Eisbaeeer:
                          @instalator:
                          Hi Instalator
                          Greetings Eisbaeeer `
                          All objects in IoB work with VIS.
                          I looked at your driver and understand your idea. Make better pullreqest the https://github.com/ioBroker/ioBroker.onkyo drivers and will test together. I think that BlueFox would not mind.
                          • I
                            BlueFox! объкты для второй, третьей зоны не создаются по причине отсутствия имени команды в файле команд?
                            Получается для основной зоны имена прописаны:
                            "PWR":{
                            "name":"system-power","description":"System Power Command","values":{
                            "00":{
                            "name":"standby","description":"sets System Standby","models":"set1"},
                            "01":{
                            "name":"on","description":"sets System On","models":"set1"},
                            "QSTN":{
                            "name":"query","description":"gets the System Power Status","models":"set1"}}},
                            А для остальных зон нет:
                            "zone2":{
                            "ZPW":{
                            "standby":{
                            "value":"00","models":"set139"},
                            "on":{
                            "value":"01","models":"set139"},
                            "query":{
                            "value":"QSTN","models":"set139"}},
                            Если переименовать так? они создадутся? или почему тогда создаются не все объекты для команд?
                            "ZPW":{
                            "name":"zone2-power","description":"System Power Command","values":{
                            "00":{
                            "name":"standby","description":"sets System Standby","models":"set139"},
                            "01":{
                            "name":"on","description":"sets System On","models":"set139"},
                            "QSTN":{
                            "name":"query","description":"gets the System Power Status","models":"set139"}}},
                            • I
                              Нашел косячек в файле команд.
                              Там для PWZ имя стоит power как и для основной зоны.
                              исправил на
                              "zone2":{
                              "Zone2.power":"ZPW",
                              И Zone2.power появился в списке объектов.
                              Так что не русско говорящий товарищь зря пилил свой код)
                              Добавлено! Создал пулреквест, получается мы создаем объекты только для зоны main и имена в разных зонах пересекаются.
                              • Eisbaeeer
                                ` > All objects in IoB work with VIS.
                                I looked at your driver and understand your idea. . `
                                OK, can you shortly explain, wich button do you use to power on/off and the corrosponding objekt?
                                I don't get running it with only one button.
                                Eisbaeeer
                                Gesendet von meinem SM-G920F mit Tapatalk
                                • Eisbaeeer
                                  Eisbaeeer
                                  • Bluefox
                                    Bluefox last edited by
                                    Hello Installator,
                                    i am on vacation till next week, so only then I can help you.
                                    greetings,
                                    bluefox
                                    • I
                                      @Eisbaeeer:
                                      Eisbaeeer `
                                      You wrote a little wrong code.
                                      I have made changes that allow you to automatically create objects, but check when BlueFox will return from vacation.
                                      https://github.com/GermanBluefox/node-e … 9fac6dca4d
                                      https://github.com/ioBroker/ioBroker.on ... 1532dd5799
                                      https://github.com/ioBroker/ioBroker.on ... ca6105cb19
                                      Change at these files, delete all the objects in Onkio driver and restart the IOB.
                                      • I
                                        @Eisbaeeer:
                                        Eisbaeeer `
                                        I changed the driver. Objects are created automatically. Replace folder with the drivers, and delete all the objects in Onkio driver and restart the IOB.
                                        266_iobroker.onkyo.rar
                                        • I
                                          @instalator:
                                          filename="iobroker.onkyo.rar" index="0">~~ `
                                          What result?
                                          • Eisbaeeer
                                            @instalator:
                                            @instalator:
                                            filename="iobroker.onkyo.rar" index="0">~~ What result?
                                            I tested with the main power button. Result is, that the button doesn´t change the colour, because the status in iobroker is NOT "true" or "false" or "1" or "0". And this can not be working. Only this 4 states are allowed in iobroker. The object get´s the state (value) "standby".
                                            I have attached a screenshot of my test. The buttons left of the marked are my working buttons who changes the logo by selecting a picture for the value "false" and an other for the value "true".
                                            I tested the "Mute" button, too. This is working how it should !!!
                                            So it seems, that only the feedback of power button is wrong. Can you change that from "standby" to "false" and if the receiver is on to "true"?
                                            At the moment we get:
                                            Receiver off = "standby"
                                            Receiver on = "1"
                                            Correct feedbacks will be:
                                            Receiver off = "false"
                                            Receiver on = "true"
                                            Eisbaeeer
                                            21948
