    4. Test Adapter Worx v0.4.x
      LJSven last edited by
      Ich bekomme den Adapter nicht gestartet - habe immer folgende Meldung ->
      host.tinkerboardmaster	2019-10-23 11:19:41.528	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
      host.tinkerboardmaster	2019-10-23 11:19:41.528	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
      host.tinkerboardmaster	2019-10-23 11:19:41.528	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
      host.tinkerboardmaster	2019-10-23 11:19:41.527	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
      host.tinkerboardmaster	2019-10-23 11:19:41.527	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.worx/main.js:107:30)
      host.tinkerboardmaster	2019-10-23 11:19:41.527	error	Caught by controller[0]: at Worx.setStates (/opt/iobroker/node_modules/iobroker.worx/main.js:174:32)
      host.tinkerboardmaster	2019-10-23 11:19:41.525	error	Caught by controller[0]: TypeError: Cannot read property 'st' of undefined
      Meistertr 1 Reply Last reply Reply Quote 0
      • Meistertr
        Meistertr Developer @LJSven last edited by
        @LJSven bitte einmal einen Debug logauszug
          LJSven @Meistertr last edited by
          @Meistertr
          host.tinkerboardmaster	2019-10-23 13:15:08.271	info	Restart adapter system.adapter.worx.0 because enabled
          host.tinkerboardmaster	2019-10-23 13:15:08.271	info	instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
          host.tinkerboardmaster	2019-10-23 13:15:08.270	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
          host.tinkerboardmaster	2019-10-23 13:15:08.270	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
          host.tinkerboardmaster	2019-10-23 13:15:08.269	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
          host.tinkerboardmaster	2019-10-23 13:15:08.269	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
          host.tinkerboardmaster	2019-10-23 13:15:08.269	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.worx/main.js:107:30)
          host.tinkerboardmaster	2019-10-23 13:15:08.268	error	Caught by controller[0]: at Worx.setStates (/opt/iobroker/node_modules/iobroker.worx/main.js:174:32)
          host.tinkerboardmaster	2019-10-23 13:15:08.267	error	Caught by controller[0]: TypeError: Cannot read property 'st' of undefined
          worx.0	2019-10-23 13:15:08.217	info	(6787) terminating
          worx.0	2019-10-23 13:15:07.730	info	(6787) Terminated (NO_ERROR): Without reason
          worx.0	2019-10-23 13:15:07.728	info	(6787) terminating
          worx.0	2019-10-23 13:15:07.708	info	(6787) cleaned everything up...
          worx.0	2019-10-23 13:15:07.705	error	(6787) TypeError: Cannot read property 'st' of undefined at Worx.setStates (/opt/iobroker/node_modules/iobroker.worx/main.js:174:32) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.
          worx.0	2019-10-23 13:15:07.704	error	(6787) uncaught exception: Cannot read property 'st' of undefined
          worx.0	2019-10-23 13:15:07.686	debug	(6787) GET MQTT DATA from API: {}
          worx.0	2019-10-23 13:15:06.611	debug	(6787) Weather_d Wed Oct 23 2019 12:37:25 GMT+0200 (Central European Summer Time)
          worx.0	2019-10-23 13:15:06.609	debug	(6787) Weather_ {"coord":{"lon":7,"lat":52.07},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04d"}],"base":"stations","main":{"temp":13.55,"pressure":1017,"humidity":72,"t
          worx.0	2019-10-23 13:15:06.524	debug	(6787) Worxcloud MQTT subscribe to DB510/F0FE6BB19EC2/commandOut
          worx.0	2019-10-23 13:15:06.523	debug	(6787) Worxcloud MQTT connected to: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
          worx.0	2019-10-23 13:15:06.203	debug	(6787) Weather_ {"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"20183019090500503387","online":false,"raw":{"id":254482,"product_id":37,"user_id":151780,"serial_number":"20183019090500503
          worx.0	2019-10-23 13:15:06.192	debug	(6787) 2 Recieve User Devices: [{"id":254482,"product_id":37,"user_id":151780,"serial_number":"20183019090500503387","mac_address":"F0FE6BB19EC2","name":"Ernst Ullrich","setup_location":{"latitude":52
          worx.0	2019-10-23 13:15:05.935	debug	(6787) 1 Recieve User Certificate
          worx.0	2019-10-23 13:15:05.586	debug	(6787) 0 Recieve MqttServer Endpoint: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
          worx.0	2019-10-23 13:15:05.337	debug	(6787) Sucess connect to Worx Server!
          worx.0	2019-10-23 13:15:05.330	debug	(6787) Connect to worx ok : {"token_type":"Bearer","expires_in":31535999,"access_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsImp0aSI6IjgxYzI2YzkxYjBmMDk3M2I4Mzk2NTVmMzdlYWRkZTljMjkyNDI2YTQ0NDc0MjlmMzM
          worx.0	2019-10-23 13:15:04.556	debug	(6787) Connect to worx....
          worx.0	2019-10-23 13:15:04.526	info	(6787) starting. Version 0.4.0 in /opt/iobroker/node_modules/iobroker.worx, node: v10.16.3
          worx.0	2019-10-23 13:15:03.090	debug	2
          worx.0	2019-10-23 13:15:03.090	debug	(6787) objectDB connected
          worx.0	2019-10-23 13:15:02.982	debug	(6787) Redis Objects: Use Redis connection: 0.0.0.0:9001
          host.tinkerboardmaster	2019-10-23 13:15:01.508	info	instance system.adapter.worx.0 started with pid 6787
          host.tinkerboardmaster	2019-10-23 13:15:01.438	info	"system.adapter.worx.0" enabled
          • Meistertr
            lade mal die version von git. dann stürzt er nihct mehr ab. dann sollte es wieder gehen
              @Meistertr sagte in [Aufruf] Worx Adapter Version 0.4.0 testen:
              Lässt sich starten!
              • Meistertr
                @LJSven lass in nochmal im debug laufen und zeig nochmal den log (etwas länger)
                  Ich habe den Roboter abgebaut - macht es dann Sinn? PS. Wie lange brauchst du?
                    radierer last edited by
                    @Meistertr
                    Gibt es evtl. eine Möglichkeit, vor dem Start des Mähvorgangs das Laden auf 100% anzustoßen?
                    Danke & Gruß
                    • Meistertr
                      Meistertr Developer @radierer last edited by
                      @radierer nein das geht nicht, das macht aber auch keinen großen unterschied
                        @Meistertr Hmm .. wenn ich mal von der Spannung ausgehe, ist der Mäher bei 100%, wenn 20,5V anliegen oder? Laut Daten im Adapter habe ich aktuell eine Spannung von unter 19V (18,94V). Ist das wirklich bei der ersten Ausfahrt so zu vernachlässigen in Bezug auf die Mähdauer?
                          steimi last edited by
                          Ich habe vor einiger Zeit den Adapter (Version 1.0) installiert in Vorbeitung des kommenden Worx-Mähers. Die Installation und Konfiguration hat geklappt. Seit einigen Tagen kann ich die Konfiguration der Adapter-Instanz nicht mehr durchführen. Es wird nur eine weisse Seite angezeigt. Im Log kommt nachfolgende Meldung.
                          Mein Mäh-Roboter ist leider noch nicht da, kann also weiter nix testen. Ich habe das gleiche Verhalten auf meiner Test-ioBroker-Installation.
                          Jemand eine Ahnung woran es liegen kann?
                          2020-04-13 17:58:36.395 - debug: worx.0 (3180) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2020-04-13 17:58:36.415 - debug: worx.0 (3180) Objects client ready ... initialize now
                          2020-04-13 17:58:36.416 - debug: worx.0 (3180) Objects create System PubSub Client
                          2020-04-13 17:58:36.417 - debug: worx.0 (3180) Objects create User PubSub Client
                          2020-04-13 17:58:36.422 - debug: worx.0 (3180) Objects client initialize lua scripts
                          2020-04-13 17:58:36.430 - debug: worx.0 (3180) Objects connected to redis: 127.0.0.1:9001
                          2020-04-13 17:58:36.432 - debug: worx.0 (3180) objectDB connected
                          2020-04-13 17:58:36.433 - debug: worx.0 (3180) Redis States: Use Redis connection: 127.0.0.1:9000
                          2020-04-13 17:58:36.438 - debug: worx.0 (3180) States create User PubSub Client
                          2020-04-13 17:58:36.438 - debug: worx.0 (3180) States create System PubSub Client
                          2020-04-13 17:58:36.444 - debug: worx.0 (3180) States connected to redis: 127.0.0.1:9000
                          2020-04-13 17:58:36.444 - debug: worx.0 (3180) statesDB connected
                          2020-04-13 17:58:37.162 - info: worx.0 (3180) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.worx, node: v12.16.2
                          2020-04-13 17:58:37.173 - debug: worx.0 (3180) Connect to worx....
                          2020-04-13 17:58:37.924 - debug: worx.0 (3180) system.adapter.admin.0: logging false
                          2020-04-13 17:58:38.251 - debug: worx.0 (3180) Connect to worx ok : {"token_type":"Bearer","expires_in":31536000,"access_token":"xxxxx","refresh_token":"xxxxx"}
                          2020-04-13 17:58:38.252 - debug: worx.0 (3180) Sucess connect to Worx Server!
                          2020-04-13 17:58:38.481 - debug: worx.0 (3180) 0 Recieve MqttServer Endpoint: a1optpg91s0ydf-ats.iot.eu-west-1.amazonaws.com
                          2020-04-13 17:58:38.771 - error: worx.0 (3180) StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}
                          2020-04-13 17:58:40.218 - debug: worx.0 (3180) system.adapter.admin.0: logging true
                            Habe den Adapter von GitHub über die Katze drüber installiert. Nun funktioniert es wieder; komisch.
                              Letty last edited by Letty
                              ich habe seit heuer das Problem das ich sofort wenn ich den Adapter Starte die Fehlermeldung über die blockierte Verbindung bekomme.
                              worx.0	2020-04-17 10:32:58.689	warn	(13077) Connection blocked from Worx, please try again in 24h
                              worx.0	2020-04-17 10:32:57.095	info	(13077) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.worx, node: v10.16.0
                              Ich habe natürlich schon versucht den Adapter 24h Stunden und länger zu stoppen und dann wieder starten, auch den Adapter entfernt für ein paar Tage und wieder aufgespielt aber immer das gleiche Bild.
                              Nach einem Neustart des Adapters updaten sich die States einmal oder zweimal aber Bedienen lässt er sich nicht.
                              Über die App funktionert alles ganz normal.
                              Gibts hier noch einen Lösungsansatz?
                              Bastelritius 1 Reply Last reply Reply Quote 0
                              • Bastelritius
                                Bastelritius @Letty last edited by Bastelritius
                                @Letty Ich habe das gleiche Problem. Auch nach 24h warten kam direkt wieder die Meldung das die Verbingung für 24h geblockt ist. Ich konnte das Problem allerdings lösen als ich den Mäher per WebLogin unpaired habe und dann neu Verbunden habe. Danach hat sich zumindest der Adapter wieder anmelden können. Statusmedlungen kommen auch, aber bedienen lässt sich der Mäher nicht. Wenn ich Werte ändere, erscheinen sie rot und nicht grün.
                                ich bekomme folgenden Log:
                                worx.0	2020-04-18 20:51:43.315	debug	(24032) test cfg: 1 valID: 2 val: false sval: 0
                                worx.0	2020-04-18 20:51:43.314	debug	(24032) Worxcloud MQTT sendMessage to "MOWER_ID" Message: {"sc":{"d":[["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,1],["00:00",0,0],["00:00",0,0]]}}
                                worx.0	2020-04-18 20:51:43.313	debug	(24032) Mow time change to: [["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,0],["00:00",0,1],["00:00",0,0],["00:00",0,0]]
                                worx.0	2020-04-18 20:51:43.312	debug	(24032) state change: id_____ worx.0."MOWER_ID".calendar.monday.borderCut Mower "MOWER_ID"_____borderCut______{"_events":{},"_eventsCount":0,"_maxListeners":100,"serial":"30173805
                                worx.0	2020-04-18 20:51:41.165	debug	(24032) Mower S ("MOWER_ID") online status = true
                                worx.0	2020-04-18 20:50:41.234	debug	(24032) Mower S ("MOWER_ID") online status = true
                                • Meistertr
                                  Meistertr Developer @Bastelritius last edited by
                                  @Bastelritius funktioniert denn die app?
                                  • cvidal
                                    Bei mir kommt der selbe Fehler, öffne ich die App steht da direkt "Dieses Konto wurde nicht aktiviert"
                                    Bestätige ich die Meldung mit "OK" und versuche den Landroid dann zu Starten, bekomme ich die Meldung das er nicht Verbunden ist.
                                    Komisch ist aber wenn ich den Landroid Manuell Starte bekomme ich eine Pushmeldung das er gestartet wurde. Also Pushmeldungen bekomme ich immer noch, mehr geht aber nicht.
                                    Ich hatte die Tage mit Worx Telefoniert, leider konnte man mir dort nicht weiterhelfen.
                                    Jetzt habe ich mal eine E-mail hingeschickt warte noch auf Antwort.
                                    Werde berichten wenn ich was erfahre.
                                      Habs heute mit neu anlernen vom Mäher probiert klappt auch nicht.
                                      Es funktioniert die App ohne Einschränkungen (Steueren und Status).
                                      Auch die App für Windows funktioniert und lässt sich auch darüber steuern.
                                      Eine Mail an den Support habe ich auch geschrieben das sie das mal Checken sollen.
                                      Sobald ich eine Antwort habe melde ich mich.
                                      • Bastelritius
                                        Es scheint wohl jeder ein anderes Fehlerbild zu haben. Sehr seltsam. Ich habe mich auch schon an den Support gewendet. Mal sehen wann man da eine Antwort bekommt. Wäre gut wenn man zumindest die App nutzen könnte. Aber die geht inzwischen bei mir auch nicht mehr.
                                        • Bastelritius
                                          Bastelritius @Meistertr last edited by
                                          @Meistertr Hallo, nach dem Neuanlernen des Rasenmähers hatte die App für 2h funktioniert. Nun wieder nicht mehr.
                                          • lobomau
                                            lobomau last edited by
                                            ich hatte nur einmal letzte Woche erlebt, dass der Mäher nicht erreichbar war per App. Sonst alles in Ordnung.
                                            Bei mir laufen:
                                            Firmware: 3.51
                                            App Version: 1.7
                                            landroid worx
                                            36
                                            198
                                            26242
