    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер ioBroker MySensors
    • V
      Vlad_k last edited by
      вроде нашел где глючит, залил , пробуй
        Maxtox last edited by
        ok.. отпишусь!
          Haba last edited by
          Подскажите пожалуйста, из-за чего криво может ставится этот драйвер?
          саму ioBroker поставил и запустил раза с пятого 🙂
          Железо Raspberry Pi B, шлюз Arduino Serial. Подключаю на GPIO, т.е. будет использоваться ttyAMA0
          Установку делаю с админ панели
          вот лог установки драйвера:
          $ ./iobroker add mysensors
          npm install iobroker.mysensors --production --prefix "/opt/iobroker" (System call)
          In file included from ../src/serialport.h:5:0, from ../src/serialport.cpp:3:
          ../node_modules/nan/nan.h:316:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
          static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
          ! make: *** [Release/obj.target/serialport/src/serialport.o] Ошибка 1
          gyp
          ERR! build error
          gyp
          ERR!
          stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
          gyp ERR! stack at ChildProcess.emit (events.js:98:17)
          gyp ERR! stack
          at Process.ChildProcess._handle.onexit (child_process.js:809:12)
          gyp
          ERR! System Linux 4.1.19+gyp ERR! command "nodejs" "/usr/bin/node-gyp" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm"
          ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialportgyp ERR! node -v v0.10.29
          gyp ERR! node-gyp -v v0.12.2
          ! gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp
          ERR! stack Error: Failed to execute 'node-gyp build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm' (1)node-pre-gyp
          ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:98:17)
          node-pre-gyp ERR! stack at maybeClose (child_process.js:755:16)
          node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:822:5)
          ! node-pre-gyp
          ERR! System Linux 4.1.19+node-pre-gyp ERR! command "node" "/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
          node-pre-gyp ERR! node -v v0.10.29
          node-pre-gyp ERR! node-pre-gyp -v v0.6.18
          node-pre-gyp
          ERR! not ok
          npm
          WARN This failure might be due to the use of legacy binary "node"
          npm WARN For further explanations, please read/usr/share/doc/nodejs/README.Debian
          ! npm
          WARN optional dep failed, continuing serialport@2.0.6</anonymous>
            Ты мой видео на YouTube смотрел? Там всё показано
            • Bluefox
              Bluefox last edited by
              @Haba:
              gyp
              ERR! build error
              gyp
              ERR!
              gyp ERR! stack
              gyp
              ! gyp ERR! not ok
              node-pre-gyp
              ! node-pre-gyp
              node-pre-gyp
              ERR! not ok
              npm
              ! npm
              Не хватает питона и build-essential
                Haba last edited by
                Maxtox видео смотрел, но посмотрел еще раз 🙂 действитвельно упустил один момент. У меня почему то даже на качестве 720р текст плохо был виден. только при втором просмотре увидел версию nodejs 12.6.
                Все переустановил еще разок, заработало! Через USB шлюз уже подключил, через GPIO пока еще не успел. Ругается Serial error: Error: Serialport not open, буду настройки проверять.
                Bluefox , в последнем образе Raspbian уже последние версии стоят, проверял.
                Кстати, подскажите еще такой момент. При установке уже самого ioBroker вылазит следующее (хотя ставил под рутом):
                ! Write "./iobroker start" to start the ioBroker
                ! Cannot create file /usr/bin/iobroker!. Non critical
                ! You can manually copy file into /usr/bin/. Just write:
                ! sudo cp /opt/iobroker/node_modules/iobroker/install/iobroker /usr/bin/
                ! sudo chmod 777 /usr/bin/iobroker
                ! Cannot copy file to /etc/init.d/iobroker.sh: Error: EACCES: permission denied, open '/etc/init.d/iobroker.sh'
                ! You can manually copy file and install autostart:
                ! sudo cp /opt/iobroker/node_modules/iobroker/install/linux/iobroker.sh /etc/init.d/
                ! sudo chmod 777 /etc/init.d/iobroker.sh
                ! sudo bash /opt/iobroker/node_modules/iobroker/install/linux/install.sh
                ! or just start "sudo bash /opt/iobroker/install.sh"
                Как и написано, ручками эти команды выполняю и запускаю брокера.
                • fishka18rus
                  fishka18rus last edited by
                  @Vlad_k:
                  Драйвер предназначен для работы с беспроводными устройствами (arduino+nrf24), использующими библиотеку с http://www.mysensors.org/…
                  драйвер в обкатке, предложения(пожелания) не игнорируются 😄 `
                  Привет!
                  Адаптер для mysensors это действительно круто. Я давно лелеял надежду что кто-нибудь напишет подобную штуку, так как сам совсем не программист. Но, как я понял, данный адаптер в режиме tcp или udp выступает в качестве шлюза для устрйств mysensensors, т.е. работает как сервер и ждет подключений на порт 5003? Разве не логичнее ему получать данные от mysensors gateway запущенном на какой-нибудь esp8266? И есть ли в планах такой режим?
                    Haba last edited by
                    fishka18rus Не совсем так. Данный драйвер принимает данные (посылает команды) через физический шлюз, выполненный на одном из вариантов Serial, MQTT или Ethernet. Соответственно на чем сделан шлюз (ардуина + usb или esp8266 или сетевой модуль) не важно для ioBroker, будет работать с любой железкой либо через uart, либо через сеть
                      Haba last edited by
                      Возможность автоматической раздачи id, новым подключаемым узлам и возможность обновления прошивки по воздуху (на основе загрузчика MYSBootloader планируется?
                        da… v planax est
                          Haba last edited by
                          Кто может подказать по такой штуке…
                          в скетче описал датчики, они появились в Объектах в таком виде:
                          ~~![](</s><URL url=)http://s019.radikal.ru/i634/1604/fe/567a3f1240f8.png" />
                          В скетче датчики описаны так:
                          MyMessage AlmStatus(MyAlm, V_VAR1);
                          MyMessage BatStatus(MyBat, V_WATT);
                          MyMessage NetStatus(MyNet, V_VAR2);
                           gw.present(MyAlm, S_CUSTOM, "123", false);
                           gw.present(MyBat, S_POWER, "123", false);
                           gw.present(MyNet, S_CUSTOM, "123", false);
                          По картинке видно, что V_VAR1 и V_VAR2 показываются пустыми полями, и по началу не подтягивались и данные.
                          А для S_POWER добавилась лишняя переменная, которая не была описана.
                          Чтобы данные с переменных V_VAR1 и V_VAR2 тоже было видно, прописал ручками так:
                          ~~![](</s><URL url=)http://s017.radikal.ru/i409/1604/d3/89954a1243f8.png" />
                          Но по идее этот подход не соответсвуют идее разработчика. Как вообще правильно надо описывать датчики в MySensors?
                          Я предполагал, что драйвер брокера из gw.present вытягивает переменные S_…, а потом уже из сообщений тянет типы переменных V_…. При таком подходе в Объектах было бы только то, что описанно в скетче и ничего лишнего.~~~~
                            @Haba:
                            Я предполагал, что драйвер брокера из gw.present вытягивает переменные S_…, а потом уже из сообщений тянет типы переменных V_…. При таком подходе в Объектах было бы только то, что описанно в скетче и ничего лишнего. `
                            а как вытащить тип переменной из V… ?
                            пример S_Custom 😄
                              Haba last edited by
                              По идее все просто…
                              gw.present(2, S_CUSTOM, "text", false);
                              в шлюз придет:
                              30;2;0;0;23;text
                              где:
                              __30 - адрес узла
                              2 - child-sensor-id - адрес датчика
                              0 - message-type "presentation"
                              0 - ack
                              23 - sub-type "S_CUSTOM"__
                              т.е. переменную S_… получили из презентации
                              теперь будем получать код переменной V…
                              __MyMessage AlmStatus(2, V_VAR2);
                              gw.send(AlmStatus.set(-84));__
                              в шлюз получим:
                              2016-04-05 11:43:04 warn Serial data received: 30;2;1;0;25;-84
                              где:
                              __30 - адрес узла
                              1 - message-type "set"
                              0 - ack__
                              25 - sub-type "V_VAR2"
                              -84 - значение
                              В результате дерево объектов можно построить следующим образом:
                              1. с узла при презентации получаем: арес узла, адреса датчиков, их тип S_… и комментарий, название скетча, версия скетча
                              2. При отправке сообщений gw.send(MyMessage.set(x)); добавляем в дерево объектов подобъекты типов V_…, к каким добавить объектам S_… определяем по адресу датчика.
                              • Bluefox
                                @Haba:
                                По идее все просто…
                                в шлюз придет:
                                30;2;0;0;23;text
                                где:
                                __30 - адрес узла
                                0 - ack
                                в шлюз получим:
                                где:
                                __30 - адрес узла
                                0 - ack__
                                -84 - значение
                                2. При отправке сообщений gw.send(MyMessage.set(x)); добавляем в дерево объектов подобъекты типов V_…, к каким добавить объектам S_… определяем по адресу датчика. `
                                Это означает, что пока сенсоры не пошлют данные, объекты не создадутся. А если это output? И данные никогда не придут? Или температура, которая каждые 30 мин обновляется?
                                  Haba last edited by
                                  если output, то правильно использовать вот эту штуку:
                                  The ack parameter has the following meaning:
                                  Outgoing: 0 = unacknowledged message, 1 = request ack from destination node
                                  Incoming: 0 = normal message, 1 = this is an ack message
                                  что логично, если мы посылаем команду на узел надо ведь получить подтверждение, что команда принята, а не потерялась?
                                  Можно проверять есть ли в дереве объектов уже такая переменная у датчика №х, если нет, то добавляем в дерево. Если есть просто обновляем значение у нее.
                                  И потом, можно сделать гибрид :roll:
                                  т.е. оставить все как сейчас + добавить это:
                                  > Можно проверять есть ли уже в дереве объектов такая переменная у датчика, если нет, то добавляем в дерево. Если есть просто обновляем значение у нее.
                                    Haba last edited by
                                    По идее что-то типа такого должно выходить для сенсоров S_CUSTOM
                                    ~~![](</s><URL url=)http://s020.radikal.ru/i710/1604/3f/3fb04f1da99b.png" />
                                    1-й адрес уже работает, данные видны
                                    2-й еще скетч не додлелал, поэтому пока false~~
                                      Haba last edited by
                                      как отправить команду на узел mySensors?
                                      скриптом так sendTo ('mysensors.0', 'send', '30;1;1;0;24;3\n');
                                      кнопкой из vis можно как то послать команду не используя скрипты?
                                        Haba last edited by
                                        Bluefox переделал немного библиотеку, чтобы как и говорил ранее, добавлялись новые датчики, которые по умолчанию не входят в список.
                                        файл main.js
                                        /* jshint -W097 */// jshint strict:false /*jslint node: true */ "use strict"; ! // you have to require the utils module and call adapter function var utils = require(__dirname + '/lib/utils'); // Get common adapter utils var serialport; var Parses = require('sensors'); var MySensors = require(__dirname + '/lib/mysensors'); var getMeta = require(__dirname + '/lib/getmeta').getMetaInfo; var getMeta2 = require(__dirname + '/lib/getmeta').getMetaInfo2; ! var adapter = utils.adapter('mysensors'); var devices = {}; var mySensorsInterface; var floatRegEx = /^[+-]?\d+(\.\d*)$/; var inclusionOn = false; var inclusionTimeout = false; ! var config = {}; ! try { serialport = require('serialport');//.SerialPort; } catch (e) { console.warn('Serial port is not available'); } ! //принимаем и обрабатываем сообщения adapter.on('message', function (obj) { if (obj) { switch (obj.command) { case 'listUart': if (obj.callback) { if (serialport) { // read all found serial ports serialport.list(function (err, ports) { adapter.log.info('List of port: ' + JSON.stringify(ports)); adapter.sendTo(obj.from, obj.command, ports, obj.callback); }); } else { adapter.log.warn('Module serialport is not available'); adapter.sendTo(obj.from, obj.command, [{comName: 'Not available'}], obj.callback); } } ! break; } } }); ! // is called when adapter shuts down - callback has to be called under any circumstances! adapter.on('unload', function (callback) { adapter.setState('info.connection', false, true); try { if (mySensorsInterface) mySensorsInterface.destroy(); mySensorsInterface = null; callback(); } catch (e) { callback(); } }); ! // is called if a subscribed state changes adapter.on('stateChange', function (id, state) { if (!state || state.ack || !mySensorsInterface) return; ! // Warning, state can be null if it was deleted adapter.log.debug('stateChange ' + id + ' ' + JSON.stringify(state)); ! if (id === adapter.namespace + '.inclusionOn') { setInclusionState(state.val); } else // output to mysensors if (devices[id] && devices[id].type == 'state') { if (typeof state.val === 'boolean') state.val = state.val ? 1 : 0; if (state.val === 'true') state.val = 1; if (state.val === 'false') state.val = 0; ! mySensorsInterface.write( devices[id].native.id + ';' + devices[id].native.childId + ';1;0;' + devices[id].native.varTypeNum + ';' + state.val, devices[id].native.ip); } }); ! adapter.on('objectChange', function (id, obj) { if (!obj) { if (devices[id]) delete devices[id]; } else { if (obj.native.id !== undefined && obj.native.childId !== undefined && obj.native.subType !== undefined) { devices[id] = obj; } } }); ! // is called when databases are connected and adapter received configuration. // start here! adapter.on('ready', function () { main(); }); ! // start here! adapter.on('unload', function () { adapter.setState('inclusionOn', false, true); }); ! var presentationDone = false; ! function setInclusionState(val) { val = val === 'true' || val === true || val === 1 || val === '1'; inclusionOn = val; ! if (inclusionTimeout) clearTimeout(inclusionTimeout); inclusionTimeout = null; ! if (inclusionOn && adapter.config.inclusionTimeout) { inclusionTimeout = setTimeout(function () { inclusionOn = false; adapter.setState('inclusionOn', false, true); }, adapter.config.inclusionTimeout); } } ! function processPresentation(data, ip, port) { var result = Parses.parse(data.toString()); ! //var result = [{ // id: lineParts[0], // childId: lineParts[1], // type: Values.types[lineParts[2]], // ack: lineParts[3] === '1', // payload: lineParts[5] // subType: Values.subTypes[result.type][lineParts[4]]; //}]; ! if (!result || !result.length) { adapter.log.warn('Cannot parse data: ' + data); return null; } ! for (var i = 0; i < result.length; i++) { adapter.log.debug('Got: ' + JSON.stringify(result[i])); if (result[i].type === 'presentation' && result[i].subType) { adapter.log.debug('Сообщение Презетация'); presentationDone = true; var found = false; for (var id in devices) { adapter.log.debug('id = ' + id); if ((!ip || ip === devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.subType == result[i].subType) { found = true; adapter.log.debug('Найден id = ' + id); break; } } ! // Add new node if (!found) { adapter.log.debug('Не найден id. Добавляем новый узел'); var objs = getMeta(result[i], ip, port, config[ip || 'serial']); for (var j = 0; j < objs.length; j++) { adapter.log.debug('Проверка ' + devices[adapter.namespace + '.' + objs[j]._id]); if (!devices[adapter.namespace + '.' + objs[j]._id]) { devices[adapter.namespace + '.' + objs[j]._id] = objs[j]; adapter.log.info('Add new object: ' + objs[j]._id + ' - ' + objs[j].common.name); adapter.setObject(objs[j]._id, objs[j], function (err) { if (err) adapter.log.error(err); }); } } } // проверяем, есть ли принятая переменная в объектах } else if (result[i].type === 'set' && result[i].subType) { adapter.log.debug('Тип "set". Ищем переменную в базе...'); var found = false; var id_found; // сюда сохраним id совпавший по параметрам id и childId for (var id in devices) { if ((!ip || ip === devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { found = true; adapter.log.debug('Найден id = ' + id); break; } if (devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId){ id_found = id; adapter.log.debug('Сохранили id_found с совпавшими id и childId'); adapter.log.debug('devices[id_found].native.id = ' + devices[id_found].native.id); adapter.log.debug('devices[id_found].native.childId = ' + devices[id_found].native.childId); } adapter.log.debug('Объект не найден!!!'); } // Добавляем новую переменную в существующий узел if (!found) { adapter.log.debug('Не найден id. Добавляем новую переменную'); var common_name = devices[id_found].common.name.split('.'); var objs = getMeta2(result[i], ip, port, config[ip || 'serial'],devices[id_found].native.subType,common_name[0]); if (!devices[adapter.namespace + '.' + objs[0]._id]) { devices[adapter.namespace + '.' + objs[0]._id] = objs[0]; adapter.log.info('Add new object: ' + objs[0]._id + ' - ' + objs[0].common.name); adapter.setObject(objs[0]._id, objs[0], function (err) { if (err) adapter.log.error(err); }); } } } else { // try to convert value var val = result[i].payload; if (floatRegEx.test(val)) val = parseFloat(val); if (val === 'true') val = true; if (val === 'false') val = false; result[i].payload = val; } } return result; } /* function syncObjects(index, cb) { if (typeof index === 'function') { cb = index; index = 0; } ! index = index || 0; ! if (!adapter.config.devices || index >= adapter.config.devices.length) { cb && cb(); return; } ! var id = adapter.config.devices[index].name.replace(/[.\s]+/g, '_'); ! adapter.getObject(id, function (err, obj) { if (err) adapter.log.error(err); ! // if new or changed if (!obj || JSON.stringify(obj.native) !== JSON.stringify(adapter.config.devices[index])) { adapter.setObject(id, { common: { name: adapter.config.devices[index].name, def: false, type: 'boolean', // нужный тип надо подставить read: 'true', write: 'true', // нужный режим надо подставить role: 'state', desc: obj ? obj.common.desc : 'Variable from mySensors' }, type: 'state', native: adapter.config.devices[index] }, function (err) { // Sync Rooms adapter.deleteStateFromEnum('rooms', '', '', id, function () { if (adapter.config.devices[index].room) { adapter.addStateToEnum('rooms', adapter.config.devices[index].room, '', '', id); } }); ! if (err) adapter.log.error(err); if (!obj) { adapter.log.debug('Create state ' + id); ! // if new object => create state adapter.setState(id, null, true, function () { setTimeout(function () { syncObjects(index + 1, cb); }, 0); }); } else { adapter.log.debug('Update state ' + id); setTimeout(function () { syncObjects(index + 1, cb); }, 0); } }); } else { setTimeout(function () { syncObjects(index + 1, cb); }, 0); } }); } ! function deleteStates(states, cb) { if (!states || !states.length) { cb && cb(); return; } var id = states.pop(); adapter.log.debug('Delete state ' + id); adapter.delForeignObject(id, function (err) { adapter.deleteStateFromEnum('rooms', '', '', id); ! if (err) adapter.log.error(err); ! adapter.delForeignState(id, function (err) { if (err) adapter.log.error(err); ! setTimeout(function () { deleteStates(states, cb); }, 0); }) }); } */ function main() { adapter.getState('inclusionOn', function (err, state) { setInclusionState(state ? state.val : false); }); ! // read current existing objects (прочитать текущие существующие объекты) adapter.getForeignObjects(adapter.namespace + '.*', 'state', function (err, states) { // subscribe on changes adapter.subscribeStates('*'); adapter.subscribeObjects('*'); devices = states; ! if (!devices[adapter.namespace + '.info.connection'] || !devices[adapter.namespace + '.info.connection'].common || (devices[adapter.namespace + '.info.connection'].common.type === 'boolean' && adapter.config.type !== 'serial') || (devices[adapter.namespace + '.info.connection'].common.type !== 'boolean' && adapter.config.type === 'serial')) { adapter.setForeignObject(adapter.namespace + '.info.connection', { "_id": "info.connection", "type": "state", "common": { "role": "indicator.connected", "name": adapter.config.type === 'serial' ? 'If connected to my sensors' : 'List of connected gateways', "type": adapter.config.type === 'serial' ? 'boolean' : 'string', "read": true, "write": false, "def": false }, "native": { ! } }, function (err) { if (err) adapter.log.error(err); }); } ! mySensorsInterface = new MySensors(adapter.config, adapter.log, function (error) { // if object created mySensorsInterface.write('0;0;3;0;14;Gateway startup complete'); ! // process received data mySensorsInterface.on('data', function (data, ip, port) { var result = processPresentation(data, ip, port); // update configuration if presentation received ! if (!result) return; ! for (var i = 0; i < result.length; i++) { if (result[i].type === 'set') { adapter.log.debug('Тип сообщения: set'); // If set quality if (result[i].subType == 77) { adapter.log.debug('subType = 77'); for (var id in devices) { if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId) { adapter.log.debug('Set quality of ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, {q: typeof result[i].payload}, true); } } } else { if (result[i].subType === 'V_LIGHT') result[i].subType = 'V_STATUS'; if (result[i].subType === 'V_DIMMER') result[i].subType = 'V_PERCENTAGE'; ! for (var id in devices) { adapter.log.debug(devices[id].native.varType + ' /// ' + result[i].subType); if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { ! if (devices[id].common.type == 'boolean') { result[i].payload = result[i].payload === 'true' || result[i].payload === true || result[i].payload === '1' || result[i].payload === 1; } adapter.log.debug('Set value ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, result[i].payload, true); break; } } } } else if(result[i].type === 'internal') { var saveValue = false; adapter.log.debug('Внутреннее сообщение'); switch (result[i].subType) { case 'I_BATTERY_LEVEL': // 0 Use this to report the battery level (in percent 0-100). adapter.log.info('Battery level ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; break; ! case 'I_TIME': // 1 Sensors can request the current time from the Controller using this message. The time will be reported as the seconds since 1970 adapter.log.info('Time ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); if (!result[i].ack) { // send response: internal, ack=1 mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;1;' + result[i].subType + ';' + Math.round(new Date().getTime() / 1000), ip); } break; ! case 'I_VERSION': // 2 Used to request gateway version from controller. adapter.log.info('Version ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; if (!result[i].ack) { // send response: internal, ack=1 mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;1;' + result[i].subType + ';' + (adapter.version || 0), ip); } break; ! case 'I_SKETCH_NAME': // 2 Used to request gateway version from controller. adapter.log.info('Name ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); saveValue = true; break; ! case 'I_INCLUSION_MODE': // 5 Start/stop inclusion mode of the Controller (1=start, 0=stop). adapter.log.info('inclusion mode ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload ? 'STARTED' : 'STOPPED'); break; ! case 'I_CONFIG': // 6 Config request from node. Reply with (M)etric or (I)mperal back to sensor. result[i].payload = (result[i].payload == 'I') ? 'Imperial' : 'Metric'; adapter.log.info('Config ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); config[ip || 'serial'] = config[ip || 'serial'] || {}; config[ip || 'serial'].metric = result[i].payload; saveValue = true; break; ! case 'I_LOG_MESSAGE': // 9 Sent by the gateway to the Controller to trace-log a message adapter.log.info('Log ' + (ip ? ' from ' + ip + ' ': '') + ':' + result[i].payload); break; ! case 'I_ID_REQUEST': if (inclusionOn) { // find maximal index var maxId = 0; for (var id in devices) { if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id > maxId) { maxId = devices[id].native.id; } } maxId++; if (!result[i].ack) { // send response: internal, ack=0, I_ID_RESPONSE mySensorsInterface.write(result[i].id + ';' + result[i].childId + ';3;0;4;' + maxId, ip); } } else { adapter.log.warn('Received I_ID_REQUEST, but inclusion mode is disabled'); } break; ! default: adapter.log.info('Received INTERNAL message: ' + result[i].subType + ': ' + result[i].payload); } ! if (saveValue) { for (var id in devices) { adapter.log.debug('2 ' + devices[id].native.varType + ' /// ' + result[i].subType); if (devices[id].native && (!ip || ip == devices[id].native.ip) && devices[id].native.id == result[i].id && devices[id].native.childId == result[i].childId && devices[id].native.varType == result[i].subType) { ! if (devices[id].common.type == 'boolean') result[i].payload = !!result[i].payload; if (devices[id].common.type == 'number') result[i].payload = parseFloat(result[i].payload); ! adapter.log.info('Set value ' + (devices[id].common.name || id) + ' ' + result[i].childId + ': ' + result[i].payload + ' ' + typeof result[i].payload); adapter.setState(id, result[i].payload, true); break; } } } ! } } }); ! mySensorsInterface.on('connectionChange', function (isConn, ip, port) { adapter.setState('info.connection', isConn, true); // try soft request if (!presentationDone && isConn) { // request metric system mySensorsInterface.write('0;0;3;0;6;get metric', ip, port); mySensorsInterface.write('0;0;3;0;19;force presentation', ip, port); setTimeout(function () { // send reboot command if still no presentation if (!presentationDone) { mySensorsInterface.write('0;0;3;0;13;force restart', ip, port); } }, 1500); } }); }); }); }
                                        файл getmeta.js (добавил функцию)
                                        ! >! [spoiler]`~~[code]~~function getMetaInfo2(packet, ip, port, config, subType, common_name) {
                                        ! config = config || {};
                                        var type = presentation[subType];
                                        if (!type) {
                                        type = {
                                        type: 'string',
                                        role: 'state',
                                        vars: ['V_VAR1', 'V_VAR2', 'V_VAR3', 'V_VAR4', 'V_VAR5'],
                                        index: packet.subType
                                        var varType = packet.subType;
                                        var variable = vars[varType];
                                        var id = (ip ? ip.replace(/./g, '') + '.' : '') + packet.id + '.' + packet.childId + '' + subType.replace('S_', '') + /*'.' + packet.subType + */ '.' + varType;
                                        var result = [
                                                    _id:            (ip ? ip.replace(/\./g, '_') + '.'  : '') + packet.id + '.' + packet.childId + '_' + subType.replace('S_', '') + '.' + varType,
                                                    common: {
                                                        name:       common_name ? (common_name + '.' + varType) : id,
                                                        type:       variable.type,
                                                        role:       variable.role + (type.role ? '.' + type.role : ''),
                                                        min:        variable.min,
                                                        max:        variable.max,
                                                        unit:       variable.unit,
                                                        def:        variable.def,
                                                        read:       variable.read,
                                                        write:      variable.write
                                                    native: {
                                                        ip:         ip,
                                                        childId:    packet.childId,
                                                        subType:    packet.subType,
                                                        subTypeNum: type.index,
                                                        varType:    varType,
                                                        varTypeNum: variable.index
                                                    type: 'state'
                                        ! return result;
                                        ! module.exports.getMetaInfo = getMetaInfo;
                                        module.exports.getMetaInfo2 = getMetaInfo2;[/code]`[/spoiler][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
                                          sanich2908 last edited by
                                          Почему не видит сом порт на Raspi ???
                                          evice converter now attached to ttyUSB0
                                          root@raspberrypi:~# dmesg
                                          Нажмите Ctrl+A и Ctrl+C, что бы скопировать в буфер обмена и после этого нажмите мышкой в любом месте.
                                          mysensors-0 2016-09-24 21:32:56.957 warn Module serialport is not available
                                          mysensors-0 2016-09-24 21:32:55.643 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.mysensors
                                          host-raspberrypi 2016-09-24 21:32:53.436 info instance system.adapter.mysensors.0 started with pid 2654
                                          host-raspberrypi 2016-09-24 21:32:51.029 info instance system.adapter.mysensors.0 terminated with code 0 (OK)
                                          mysensors-0 2016-09-24 21:32:51.000 info terminating
                                          host-raspberrypi 2016-09-24 21:32:50.916 info stopInstance system.adapter.mysensors.0 killing pid 2648
                                          host-raspberrypi 2016-09-24 21:32:50.915 info stopInstance system.adapter.mysensors.0
                                            Haus last edited by
                                            @sanich2908:
                                            host-raspberrypi 2016-09-24 21:32:50.915 info stopInstance system.adapter.mysensors.0 `
                                            sudo apt-get update
                                            sudo apt-get install build-essential
                                            sudo apt-get install python2.7
                                            106
                                            31415
