    4. gelöst - IOT Adapter - Fehler
      Hicki last edited by Hicki
      ich kann mein IOT-Adapter nicht updatet, mit dieser Fehlermeldung:
      $ ./iobroker upgrade iot
      Update iot from @1.1.8 to @1.4.0
      host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
      NPM version: 6.13.4
      npm install iobroker.iot@1.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp
       ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.97-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
      node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-03T19_42_54_922Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.iot@1.4.0: 1
      ERROR: process exited with code 25
      Was ist der Fehler?
      Gruß Hicki
        Semenchkare last edited by Semenchkare
        Habe ebenso den Fehler...
        Update iot from @1.3.4 to @1.4.0
        host.Raspi4-Iobroker Adapter "system.adapter.iot.0" is stopped.
        NPM version: 6.13.4npm install iobroker.iot@1.4.0 --loglevel error --prefix "/opt/iobroker" (System call)
        Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:311:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v12.16.1gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:311:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.16.1node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
        npm ERR! code ELIFECYCLEnpm ERR! errno 1
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-04T07_37_23_188Z-debug.log
        ERROR: host.Raspi4-Iobroker Cannot install iobroker.iot@1.4.0: 1
        • Mauflo
          Mauflo last edited by
          Systemdata Bitte Ausfüllen
          Hardwaresystem: Raspberry 4 ARMv7 Processor rev 3 (v7l)
          Arbeitsspeicher: 4GB
          Festplattenart: SD-Karte
          Betriebssystem: Linux
          Node-Version: 10.19.0
          Nodejs-Version: 10.19.0
          NPM-Version: 6.14.2
          Installationsart: Skript
          Image genutzt: Ja
          Ort/Name der Imagedatei: ioBroker Image für Raspberry Pi2/3/4 Buster 20191127
          Wenn ich versuche IoT Assistants mit dem Link in Info update bekomme ich folgende Fehlermeldung:
          host.iobrokerP4 Adapter "system.adapter.iot.0" is stopped.
          NPM version: 6.14.2
          gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.93-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)node-pre-gyp ERR! System Linux 4.19.93-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
          npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-04T07_33_36_000Z-debug.log
          ERROR: host.iobrokerP4 Cannot install iobroker.iot@1.4.0: 1
          Was läuft da schief? Kenne mich nicht aus!
          • haselchen
            haselchen Most Active last edited by haselchen
            This post is deleted!
            Mauflo Negalein 2 Replies Last reply Reply Quote 0
              SaiBot1981 last edited by SaiBot1981
              Schließe mich an. Hab auch div. Tricks prpbiert. Sogar den InstallerFix. Keine Besserung.
              Hier meine Log 2020-04-04T08_42_54_905Z-debug.log
              • Mauflo
                • Mauflo
                  Mauflo @haselchen last edited by
                  • haselchen
                    haselchen Most Active @Mauflo last edited by
                    • khg
                      khg last edited by khg
                      gleiches Problem. Benötige von Alexa keine Zuckerwerte, habe aber gerne alle Adapter aktuell.
                        sigi234 Forum Testing Most Active @khg last edited by
                        @khg sagte in IOT Adapter - Fehler:
                        Kann mir wer erklären was das ist?
                          Hey Leute es gibt ein neues Update, jetzt funktioniert alles wieder.
                          Vielen Dank für das Update.
                          Was war nun eigentlich das Problem?
                          Gruß Hicki
                          • Negalein
                            Negalein Global Moderator @haselchen last edited by Negalein
                            @haselchen sagte in IOT Adapter - Fehler:
                            Kannst du die beiden Threads bitte zusammenlegen.
                            Mod-Edit: Erledigt
                            iot adapter
                            830
