    4. Test Adapter Material Design Widgets v0.2.x
      liv-in-sky @Scrounger last edited by
      @Scrounger mit .2.28
      restart und neu angelegt
      [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
      DevTools failed to parse SourceMap: http://192.168.178.59:8072/lib/js/socket.io.js.map
      index.html?galaxy:4059 Version vis-colorpicker: 1.0.1
      index.html?galaxy:4907 Version coronavirus-statistics: 0.1.0
      index.html?galaxy:5638 fritzdect widget version: "0.0.1"
      index.html?galaxy:6098 Version vis-history: 1.0.0
      jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/template/words.js 404 (Not Found)
      send @ jquery-1.11.2.min.js:4
      ajax @ jquery-1.11.2.min.js:4
      m.<computed> @ jquery-1.11.2.min.js:4
      (anonymous) @ calendar.js:11
      info.js:22 Version Info-Adapter-Widget: 0.0.9
      index.html?galaxy:7156 Version vis-jqui-mfd: 1.0.12
      justgage.js:115 Version justgage: 1.0.2
      materialdesign.js:25 Version vis-materialdesign: 0.2.78
      DevTools failed to parse SourceMap: http://192.168.178.59:8072/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
      index.html?galaxy:13443 Metro version: "1.1.2"
      lib.min.js:22 Download the Vue Devtools extension for a better development experience:
      https://github.com/vuejs/vue-devtools
      lib.min.js:22 You are running Vue in development mode.
      Make sure to turn on production mode when deploying for production.
      See more tips at https://vuejs.org/guide/deployment.html
      players.js:58 Version players: 0.1.0
      rssfeed.js:22 Version rssfeed: 0.0.1
      jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/rssfeed/words.js 404 (Not Found)
      (anonymous) @ rssfeed.js:11
      trashschedule.js:22 Version trashschedule: 0.0.4
      index.html?galaxy:19713 Version vis-weather: 2.4.1
      jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/trashschedule/words.js 404 (Not Found)
      (anonymous) @ trashschedule.js:11
      conn.js:273 2020-04-05T11:45:50.743Z Connected => authenticate
      DevTools failed to parse SourceMap: chrome-extension://dafgdjggglmmknipkhngniifhplpcldb/browser-polyfill.min.js.map
      conn.js:293 2020-04-05T11:45:50.857Z Authenticated: true
      vis.js:3167 Create inner vis object controll-own.0._MenuRaspi
      vis.js:3167 Create inner vis object controll-own.0._MenuVisView8
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestString2
      vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.sortMode
      vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.filterMode
      vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.jsonList
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMaterialWidget
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.test.html
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.EnergyMaterialWidget
      vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkDevicesStatus.filterMode
      vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeBatt
      vis.js:3167 Create inner vis object controll-own.0.HANDY.odysBatt
      vis.js:3167 Create inner vis object iot.0.services.custom__batt_s7
      vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstorebatt2
      vis.js:3167 Create inner vis object controll-own.0.HANDY.t113batt
      vis.js:3167 Create inner vis object controll-own.0.WHATSAPPtext
      vis.js:3167 Create inner vis object controll-own.0.WHATSAPPCheck
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodosText
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLToDos
      vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLArmin
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ToDoListLoeschen
      vis.js:3167 Create inner vis object controll-own.0.AlexaSprichMirNach
      vis.js:3167 Create inner vis object controll-own.0.Banane
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL2
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL3
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL4
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL5
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL6
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL7
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_26
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_49
      vis.js:3167 Create inner vis object controll-own.0.statusDLNAReload
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_124
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_113
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpDaten
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpReserve
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpSync
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpmSata
      vis.js:3167 Create inner vis object plex.0.libraries.1-serien.itemsCount
      vis.js:3167 Create inner vis object controll-own.0.statusDLNARestart
      vis.js:3167 Create inner vis object controll-own.0.statusRefresh
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_29
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRoot
      vis.js:3167 Create inner vis object controll-own.0.statusMiniDLNA
      vis.js:3167 Create inner vis object controll-own.0.statusDLNAfind
      vis.js:3167 Create inner vis object mpd.0.state
      vis.js:3167 Create inner vis object controll-own.0.statusFilm
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.checkDaten
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.DatenCheckBackup
      vis.js:3167 Create inner vis object controll-own.0.mounthelpReserve
      vis.js:3167 Create inner vis object controll-own.0.mounthelpSync
      vis.js:3167 Create inner vis object controll-own.0.mounthelpDaten
      vis.js:3167 Create inner vis object controll-own.0.mounthelpmSata
      vis.js:3167 Create inner vis object controll-own.0.HANDY.odysload
      vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeload
      vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreLoad
      vis.js:3167 Create inner vis object controll-own.0.HANDY.stromTrekstore
      vis.js:3167 Create inner vis object controll-own.0.HANDY.stromEdge
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskSpace
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.WWWCopy
      vis.js:3167 Create inner vis object controll-own.0.HANDY.stromOdys
      vis.js:3167 Create inner vis object controll-own.0.iobrokerbackup
      vis.js:3167 Create inner vis object controll-own.0.iobrokerbackupstatus
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.SQLConnections
      vis.js:3167 Create inner vis object mclighting.0.fx_mode
      vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID
      vis.js:3167 Create inner vis object mclighting.0.color_R
      vis.js:3167 Create inner vis object mclighting.0.color_G
      vis.js:3167 Create inner vis object mclighting.0.color_B
      vis.js:3167 Create inner vis object mclighting.0.fx_mode_name
      vis.js:3167 Create inner vis object mclighting.1.fx_mode
      vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID2
      vis.js:3167 Create inner vis object mclighting.1.color_R
      vis.js:3167 Create inner vis object mclighting.1.color_G
      vis.js:3167 Create inner vis object mclighting.1.color_B
      vis.js:3167 Create inner vis object mclighting.1.fx_mode_name
      vis.js:3167 Create inner vis object mclighting.0.power
      vis.js:3167 Create inner vis object mclighting.1.power
      vis.js:3167 Create inner vis object mclighting.1.brightness
      vis.js:3167 Create inner vis object mclighting.0.brightness
      vis.js:3167 Create inner vis object controll-own.0.SonoffsRestart
      vis.js:3167 Create inner vis object controll-own.0.SonoffsOff
      vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov2.POWER
      vis.js:3167 Create inner vis object sonoff.0.Sonoff11.POWER2
      vis.js:3167 Create inner vis object sonoff.0.Sonoff13.POWER2
      vis.js:3167 Create inner vis object sonoff.0.Sonoff4.POWER2
      vis.js:3167 Create inner vis object sonoff.0.Sonoff5.POWER2
      vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov1.POWER
      vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodayDelete
      vis.js:3167 Create inner vis object sonoff.0.Sonoff15.AM2301_Temperature
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryFree
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapSize
      vis.js:3167 Create inner vis object controll-own.0.mount.SQLSizeioBrokerData
      vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.screenOff
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoad
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadTx
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeVAR
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeIOBroker
      vis.js:3167 Create inner vis object pi-hole.0.summary.domains_being_blocked
      vis.js:3167 Create inner vis object pi-hole.0.summary.dns_queries_today
      vis.js:3167 Create inner vis object pi-hole.0.summary.ads_blocked_today
      vis.js:3167 Create inner vis object pi-hole.0.summary.ads_percentage_today
      vis.js:3167 Create inner vis object pi-hole.0.summary.status
      vis.js:3167 Create inner vis object controll-own.0.PI-HOLE.IPv6
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Bruttopreis 100l
      vis.js:3167 Create inner vis object admin.0.info.updatesNumber
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadZaehler
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadMIN
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.First
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondtLink
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondLink
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.ThirdLink
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstLink
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstText
      vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.4bfd6fec-5b3d-45e2-ae7a-a38bb9075ac0.powerState
      vis.js:3167 Create inner vis object javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.TimerResetVIS
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Minuten
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Minuten
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.SummeMinuten2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Finished
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Sekunden
      vis.js:3167 Create inner vis object 60
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Name2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Gerät2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Gerät1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.SummeMinuten1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Finished
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Name1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Sekunden
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Ende1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Ende2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Start1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Start2
      vis.js:3167 Create inner vis object controll-own.0.Luefter3
      vis.js:3167 Create inner vis object controll-own.0.Luefter1
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_1
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_36
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_27
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_127
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_88
      vis.js:3167 Create inner vis object controll-own.0.ACER5630Cyber
      vis.js:3167 Create inner vis object controll-own.0.AMD5300
      vis.js:3167 Create inner vis object controll-own.0.fx6300
      vis.js:3167 Create inner vis object controll-own.0.FARBBand
      vis.js:3167 Create inner vis object controll-own.0.HeizungZimmerCounter
      vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer30
      vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer90
      vis.js:3167 Create inner vis object controll-own.0.SchreibtischHAUPT
      vis.js:3167 Create inner vis object controll-own.0.Wechsel
      vis.js:3167 Create inner vis object controll-own.0.WechselHalb
      vis.js:3167 Create inner vis object controll-own.0.fx6300energie
      vis.js:3167 Create inner vis object controll-own.0.AMDM5300Monitor
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.targettemp
      vis.js:3167 Create inner vis object controll-own.0.fx63000monitore
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEED
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERION
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSWING
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERCOOL
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERHUM
      vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEEDHELP
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-EIN
      vis.js:3167 Create inner vis object controll-own.0.TV
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EIN
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_23
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.REVOLT3EIN
      vis.js:3167 Create inner vis object controll-own.0.LG-TV.ChannelWahl
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrProMain
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrStu
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrMin
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrTVEin
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro1
      vis.js:3167 Create inner vis object controll-own.0.AlexaTriggerSnc
      vis.js:3167 Create inner vis object controll-own.0.HeizungKuecheCounter
      vis.js:3167 Create inner vis object controll-own.0.HeizungKueche30
      vis.js:3167 Create inner vis object controll-own.0.HeizungKueche90
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.targettemp
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.targettemp
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.targettemp
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.temp
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.temp
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.temp
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.temp
      vis.js:3167 Create inner vis object controll-own.0.FX6300alt
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_136
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Total
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer30
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer90
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmerCounter
      vis.js:3167 Create inner vis object controll-own.0.MATRIX.ScahlterMatrix
      vis.js:3167 Create inner vis object controll-own.0.schlafen
      vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreScreen
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.UnifiController
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioCarPort
      vis.js:3167 Create inner vis object controll-own.0.Atesten
      vis.js:3167 Create inner vis object controll-own.0.PLEX.PlexStart
      vis.js:3167 Create inner vis object controll-own.0.PLEX.PLEXAll
      vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckTautulla
      vis.js:3167 Create inner vis object system.adapter.plex.0.alive
      vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_14
      vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckPlexService
      vis.js:3167 Create inner vis object controll-own.0.PLEX.MountVideoFiles
      vis.js:3167 Create inner vis object controll-own.0.MATRIX2.ScahlterMatrix
      vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixMode
      vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixRefreshTime
      vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixMode
      vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixRefreshTime
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.endDate
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv1
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV2.endDate
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv2
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel1
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel2
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltReset
      vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro2
      vis.js:3167 Create inner vis object system.adapter.admin.0.uptime
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahl2
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.battery
      vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.battery
      vis.js:3167 Create inner vis object lgtv.0.states.youtube
      vis.js:3167 Create inner vis object lgtv.0.states.channel
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestLogic2
      vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.loadStartURL
      vis.js:3167 Create inner vis object controll-own.0.LEDLampe
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_124
      vis.js:3167 Create inner vis object controll-own.0.MOTION.SchalterFlurLicht
      vis.js:3167 Create inner vis object controll-own.0.KuechenLicht
      vis.js:3167 Create inner vis object controll-own.0.KuechenLichLight
      vis.js:3167 Create inner vis object controll-own.0.KuehlschrankTuer
      vis.js:3167 Create inner vis object controll-own.0.NACHTLAMPE
      vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiMain
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_151
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_73
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_29
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBT
      vis.js:3167 Create inner vis object controll-own.0.NACHTKASTENLAMPE
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBTonly
      vis.js:3167 Create inner vis object controll-own.0.LEDLangWLED
      vis.js:3167 Create inner vis object controll-own.0.KuehlschrankLicht
      vis.js:3167 Create inner vis object controll-own.0.MOTION.Standort
      vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiRefreshChrome
      vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerName
      vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.inbound.caller
      vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVorwahl
      vis.js:3167 Create inner vis object controll-own.0.SAT
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_99
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_82
      vis.js:3167 Create inner vis object mpd.0.title
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_34
      vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananePiPro
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_53
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FlurAnwesenheit
      vis.js:3167 Create inner vis object dwd.0.warning.description
      vis.js:3167 Create inner vis object dwd.0.warning.headline
      vis.js:3167 Create inner vis object controll-own.0.TemperaturWidget
      vis.js:3167 Create inner vis object controll-own.0.MOTION.BADRein
      vis.js:3167 Create inner vis object controll-own.0.GastZugang
      vis.js:3167 Create inner vis object controll-own.0.HANDY.FritzCallHelpVis
      vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLAUTER
      vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLEISER
      vis.js:3167 Create inner vis object ical.1.data.html
      vis.js:3167 Create inner vis object openweathermap.0.forecast.current.temperature
      vis.js:3167 Create inner vis object openweathermap.0.forecast.day1.temperatureMax
      vis.js:3167 Create inner vis object sonoff.0.Sonoff16.BH1750_Illuminance
      vis.js:3167 Create inner vis object controll-own.0.HILDE.HildeDaheim
      vis.js:3167 Create inner vis object controll-own.0.Heizung30
      vis.js:3167 Create inner vis object controll-own.0.Heizung90
      vis.js:3167 Create inner vis object ical.0.data.html
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Datum
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.TotalText
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Alarm
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Name
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayAuswahl
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayList
      vis.js:3167 Create inner vis object mpd.0.pause
      vis.js:3167 Create inner vis object javascript.0.scriptEnabled.common.ExecuteLinuxMPDVolLauter
      vis.js:3167 Create inner vis object mpd.0.next
      vis.js:3167 Create inner vis object mpd.0.previous
      vis.js:3167 Create inner vis object tr-064.0.states.wlan24
      vis.js:3167 Create inner vis object iot.0.services.custom_hildeloc
      vis.js:3167 Create inner vis object openweathermap.0.forecast.current.icon
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Tage
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Stunden
      vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Minuten
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Sekunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Minuten
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Stunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Tage
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Sekunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Minuten
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Stunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Tage
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Start
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Start
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Start
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Stopp
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Reset
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Ausgabehilfe
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Stopp
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Reset
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Ausgabehilfe
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Reset
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ende
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Stopp
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ausgabehilfe
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Sekunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Minuten
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Stunden
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Tage
      vis.js:3167 Create inner vis object controll-own.0.mount.CPULuefter
      vis.js:3167 Create inner vis object controll-own.0.HeizungCounter
      vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.TimerZaehler
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.reached
      vis.js:3167 Create inner vis object countdown.0.setup.TV1
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.days
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.hours
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.minutes
      vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.months
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Fehler
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Orginal2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Orginal1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.MitStunden2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.MitStunden1
      vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerPicture
      vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVisSichtbarkeit
      vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerGeraet
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.battery
      vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_73.Commands.screenOff
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.title
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.event
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.file.name
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.thumb
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.datetime
      vis.js:3167 Create inner vis object plex.0._playing.players
      vis.js:3167 Create inner vis object contact.0.photo
      vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.summary
      vis.js:3167 Create inner vis object view
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADLicht
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefter
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RM-MINI.L.HEIZLuefterEIN
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADAnwesenheit
      vis.js:3167 Create inner vis object arning.headline
      vis.js:3167 Create inner vis object controll-own.0.MOTION.BADaktiv
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefterSTEPs
      vis.js:3167 Create inner vis object mihome.0.devices.magnet_158d0001fa8b82.state
      vis.js:3167 Create inner vis object controll-own.0.MOTION.BADTuerHELP
      vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_42
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHAUPTSCHALTER
      vis.js:3167 Create inner vis object controll-own.0.HANDY.t113load
      vis.js:3167 Create inner vis object controll-own.0.Lüfter4
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.POWER
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.volume
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioEcho
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentArtist
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RockAntenneTitle
      vis.js:3167 Create inner vis object sonoff.0.ShellyWC.POWER
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.targettemp
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.temp
      vis.js:3167 Create inner vis object openweathermap.0.forecast.current.precipitationSnow
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad30
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad90
      vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBadCounter
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizungCounter
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung30
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung90
      vis.js:3167 Create inner vis object controll-own.0.BAD.BADVisNeu
      vis.js:3167 Create inner vis object controll-own.0.HANDYKLINGELT
      vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.ringing
      vis.js:3167 Create inner vis object trashschedule.0.type.BIOMÜLL.daysleft
      vis.js:3167 Create inner vis object trashschedule.0.type.PAPIER TONNE.daysleft
      vis.js:3167 Create inner vis object trashschedule.0.type.GELBER SACK.daysleft
      vis.js:3167 Create inner vis object trashschedule.0.type.RESTMÜLL.daysleft
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.ENERGY_Total
      vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.battery
      vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.a67645b2-910f-4dae-9c3c-6f606a98c95f.powerState
      vis.js:3167 Create inner vis object system.adapter.coronavirus-statistics.0.connected
      vis.js:3167 Create inner vis object coronavirus-statistics.0._Last_Update
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.critical
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.critical
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.critical
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.critical
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.deaths
      vis.js:3167 Create inner vis object rssfeed.0.IOBROKER
      vis.js:3167 Create inner vis object rssfeed.0.Formel1
      vis.js:3167 Create inner vis object rssfeed.0.Tagesschau
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.active
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.country
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.flag
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.country
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.flag
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.country
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.flag
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.country
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.flag
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.country
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.flag
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.active
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.active
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.active
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.cases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.active
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.deaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.critical
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayCases
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.recovered
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayDeaths
      vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.deaths
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFeedZwitesFensterVIS
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RSSan
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelleFeed
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle2VIS
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFormelEINS2
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Power
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Current
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Voltage
      vis.js:3167 Create inner vis object nut.0.ups.load
      vis.js:3167 Create inner vis object nut.0.status.overload
      vis.js:3167 Create inner vis object nut.0.status.charging
      vis.js:3167 Create inner vis object nut.0.status.online
      vis.js:3167 Create inner vis object nut.0.ups.status
      vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Minuten
      vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Stunden
      vis.js:3167 Create inner vis object nut.0.battery.charge
      vis.js:3167 Create inner vis object nut.0.battery.voltage
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunScript
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
      vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
      vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_Table
      vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_List
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMaterialWidgetTable
      vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.missedFritzbox
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.EnergyMaterialWidgetTable
      vis.js:3167 Create inner vis object lgtv.0.states.volume
      vis.js:3167 Create inner vis object lgtv.0.remote.enter
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Player.controlPause
      vis.js:3167 Create inner vis object lgtv.0.states.channelDown
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Commands.deviceStop
      vis.js:3167 Create inner vis object lgtv.0.states.channelUp
      vis.js:3167 Create inner vis object lgtv.0.remote.cc
      vis.js:3167 Create inner vis object lgtv.0.remote.home
      vis.js:3167 Create inner vis object lgtv.0.remote.menu
      vis.js:3167 Create inner vis object lgtv.0.remote.left
      vis.js:3167 Create inner vis object lgtv.0.remote.right
      vis.js:3167 Create inner vis object lgtv.0.remote.exit
      vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.back
      vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.down
      vis.js:3167 Create inner vis object lgtv.0.remote.1
      vis.js:3167 Create inner vis object lgtv.0.remote.2
      vis.js:3167 Create inner vis object lgtv.0.remote.3
      vis.js:3167 Create inner vis object lgtv.0.remote.4
      vis.js:3167 Create inner vis object lgtv.0.remote.5
      vis.js:3167 Create inner vis object lgtv.0.remote.6
      vis.js:3167 Create inner vis object lgtv.0.remote.7
      vis.js:3167 Create inner vis object lgtv.0.remote.8
      vis.js:3167 Create inner vis object lgtv.0.remote.9
      vis.js:3167 Create inner vis object lgtv.0.remote.0
      vis.js:3167 Create inner vis object lgtv.0.remote.green
      vis.js:3167 Create inner vis object lgtv.0.remote.dash
      vis.js:3167 Create inner vis object lgtv.0.remote.blue
      vis.js:3167 Create inner vis object lgtv.0.remote.yellow
      vis.js:3167 Create inner vis object lgtv.0.remote.red
      vis.js:3167 Create inner vis object lgtv.0.states.mute
      vis.js:3167 Create inner vis object lgtv.0.states.popup
      vis.js:3167 Create inner vis object lgtv.0.states.turnOff
      vis.js:3167 Create inner vis object lgtv.0.states.input
      vis.js:3167 Create inner vis object lgtv.0.states.currentApp
      vis.js:3167 Create inner vis object lgtv.0.states.soundOutput
      vis.js:3167 Create inner vis object lgtv.0.states.3Dmode
      vis.js:3167 Create inner vis object lgtv.0.states.model
      vis.js:3167 Create inner vis object lgtv.0.info.connection
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVall
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVFlexAnzeige
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVjetzt
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVgleich
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2015
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2200
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.ALEXAToDo
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.Meisterschaft
      vis.js:3167 Create inner vis object 0_userdata.0.testmailvis
      vis.js:3167 Create inner vis object javascript.0.Tabellen.Web-Speedy-Test.VISAnzeige
      vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.PingAdapter
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTML
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-INFO
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-WEITER
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-ZURUECK
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-OK
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-OBEN
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-HDMI
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-SOURCE
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-RECHTS
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-LINKS
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PLAY
      vis.js:3167 Create inner vis object controll-own.0.TVLeiser
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-STOP
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PAUSE
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EXIT
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MENU
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RETURN
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-2
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-1
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-3
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-4
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-5
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-6
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-7
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-8
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-9
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-10
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-14
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-15
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-16
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-18
      vis.js:3167 Create inner vis object scene.AVIRA1-PRO-13
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MUTE
      vis.js:3167 Create inner vis object controll-own.0.TVLauter
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-UNTEN
      vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLauter
      vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLeiser
      vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVBack
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-MUTE
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-ON
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX1
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX2
      vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-BLUET
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.connected
      vis.js:3167 Create inner vis object system.adapter.web.0.connected
      vis.js:3167 Create inner vis object system.adapter.upnp.0.connected
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.connected
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.connected
      vis.js:3167 Create inner vis object system.adapter.socketio.0.alive
      vis.js:3167 Create inner vis object system.adapter.socketio.0.connected
      vis.js:3167 Create inner vis object system.adapter.snmp.0.connected
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.connected
      vis.js:3167 Create inner vis object system.adapter.scenes.0.connected
      vis.js:3167 Create inner vis object system.adapter.ping.0.connected
      vis.js:3167 Create inner vis object system.adapter.node-red.0.connected
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.connected
      vis.js:3167 Create inner vis object system.adapter.meross.0.connected
      vis.js:3167 Create inner vis object kodi.0.info.connection
      vis.js:3167 Create inner vis object system.adapter.javascript.0.alive
      vis.js:3167 Create inner vis object system.adapter.javascript.0.connected
      vis.js:3167 Create inner vis object system.adapter.iot.0.connected
      vis.js:3167 Create inner vis object system.adapter.info.0.connected
      vis.js:3167 Create inner vis object system.adapter.ical.2.alive
      vis.js:3167 Create inner vis object system.adapter.ical.1.alive
      vis.js:3167 Create inner vis object system.adapter.ical.0.alive
      vis.js:3167 Create inner vis object system.adapter.hs100.0.connected
      vis.js:3167 Create inner vis object hm-rpc.1.info.connection
      vis.js:3167 Create inner vis object hm-rpc.0.info.connection
      vis.js:3167 Create inner vis object hm-rega.0.info.connection
      vis.js:3167 Create inner vis object system.adapter.history.0.connected
      vis.js:3167 Create inner vis object system.adapter.firetv.0.connected
      vis.js:3167 Create inner vis object system.adapter.email.0.connected
      vis.js:3167 Create inner vis object system.adapter.daswetter.0.alive
      vis.js:3167 Create inner vis object cloud.0.info.connection
      vis.js:3167 Create inner vis object system.adapter.backitup.0.connected
      vis.js:3167 Create inner vis object alexa2.0.info.connection
      vis.js:3167 Create inner vis object system.adapter.admin.0.alive
      vis.js:3167 Create inner vis object system.adapter.admin.0.connected
      vis.js:3167 Create inner vis object admin.0.info.lastUpdateCheck
      vis.js:3167 Create inner vis object system.adapter.iogo.0.connected
      vis.js:3167 Create inner vis object system.host.Medion(Test).alive
      vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.admin.0.memRss
      vis.js:3167 Create inner vis object system.adapter.javascript.0.memRss
      vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.javascript.0.uptime
      vis.js:3167 Create inner vis object system.adapter.socketio.0.memRss
      vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.socketio.0.uptime
      vis.js:3167 Create inner vis object system.adapter.web.0.alive
      vis.js:3167 Create inner vis object system.adapter.web.0.memRss
      vis.js:3167 Create inner vis object system.adapter.web.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.web.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.web.0.uptime
      vis.js:3167 Create inner vis object system.adapter.history.0.alive
      vis.js:3167 Create inner vis object system.adapter.history.0.memRss
      vis.js:3167 Create inner vis object system.adapter.history.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.history.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.history.0.uptime
      vis.js:3167 Create inner vis object system.adapter.backitup.0.alive
      vis.js:3167 Create inner vis object system.adapter.backitup.0.memRss
      vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.backitup.0.uptime
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.alive
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.alive
      vis.js:3167 Create inner vis object system.adapter.hm-rega.0.alive
      vis.js:3167 Create inner vis object system.adapter.hm-rega.0.uptime
      vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memRss
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memRss
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.uptime
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memRss
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.uptime
      vis.js:3167 Create inner vis object system.adapter.ical.0.memRss
      vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.ical.0.uptime
      vis.js:3167 Create inner vis object system.adapter.ical.1.memRss
      vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.ical.1.uptime
      vis.js:3167 Create inner vis object system.adapter.ical.2.memRss
      vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.ical.2.uptime
      vis.js:3167 Create inner vis object system.adapter.iot.0.alive
      vis.js:3167 Create inner vis object system.adapter.cloud.0.alive
      vis.js:3167 Create inner vis object system.adapter.alexa2.0.alive
      vis.js:3167 Create inner vis object system.adapter.alexa2.0.uptime
      vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.alexa2.0.memRss
      vis.js:3167 Create inner vis object system.adapter.cloud.0.memRss
      vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.cloud.0.uptime
      vis.js:3167 Create inner vis object system.adapter.iot.0.memRss
      vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.iot.0.uptime
      vis.js:3167 Create inner vis object system.adapter.ping.0.alive
      vis.js:3167 Create inner vis object system.adapter.ping.0.memRss
      vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.ping.0.uptime
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.alive
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.memRss
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.simple-api.0.uptime
      vis.js:3167 Create inner vis object system.host.Medion(Test).memRss
      vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapUsed
      vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapTotal
      vis.js:3167 Create inner vis object system.host.Medion(Test).uptime
      vis.js:3167 Create inner vis object system.adapter.iogo.0.alive
      vis.js:3167 Create inner vis object system.adapter.email.0.alive
      vis.js:3167 Create inner vis object system.adapter.info.0.alive
      vis.js:3167 Create inner vis object system.adapter.info.0.uptime
      vis.js:3167 Create inner vis object system.adapter.info.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.info.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.info.0.memRss
      vis.js:3167 Create inner vis object system.adapter.email.0.memRss
      vis.js:3167 Create inner vis object system.adapter.email.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.email.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.email.0.uptime
      vis.js:3167 Create inner vis object system.adapter.iogo.0.memRss
      vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.iogo.0.uptime
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.alive
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.memRss
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.yamaha.0.uptime
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.alive
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.memRss
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.musiccast.0.uptime
      vis.js:3167 Create inner vis object system.adapter.upnp.0.alive
      vis.js:3167 Create inner vis object system.adapter.upnp.0.memRss
      vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.upnp.0.uptime
      vis.js:3167 Create inner vis object system.adapter.firetv.0.alive
      vis.js:3167 Create inner vis object system.adapter.kodi.0.alive
      vis.js:3167 Create inner vis object system.adapter.kodi.0.uptime
      vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.kodi.0.memRss
      vis.js:3167 Create inner vis object system.adapter.firetv.1.memRss
      vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.firetv.1.uptime
      vis.js:3167 Create inner vis object system.adapter.daswetter.0.memRss
      vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.daswetter.0.uptime
      vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.alive
      vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memRss
      vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.uptime
      vis.js:3167 Create inner vis object system.adapter.snmp.0.alive
      vis.js:3167 Create inner vis object system.adapter.snmp.0.memRss
      vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.snmp.0.uptime
      vis.js:3167 Create inner vis object system.adapter.scenes.0.alive
      vis.js:3167 Create inner vis object system.adapter.scenes.0.memRss
      vis.js:3167 Create inner vis object system.adapter.scenes.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.scenes.0.uptime
      vis.js:3167 Create inner vis object system.adapter.hs100.0.alive
      vis.js:3167 Create inner vis object system.adapter.meross.0.alive
      vis.js:3167 Create inner vis object system.adapter.node-red.0.alive
      vis.js:3167 Create inner vis object system.adapter.node-red.0.uptime
      vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.node-red.0.memRss
      vis.js:3167 Create inner vis object system.adapter.meross.0.memRss
      vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.meross.0.uptime
      vis.js:3167 Create inner vis object system.adapter.hs100.0.memRss
      vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.hs100.0.uptime
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.alive
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memRss
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.uptime
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.alive
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memRss
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.uptime
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.alive
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memRss
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapUsed
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapTotal
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.uptime
      vis.js:3167 Create inner vis object system.adapter.iqontrol.0.connected
      vis.js:3167 Create inner vis object controll-own.0._MenuVisView8-BACK
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTMLAuswahlDelete
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuAlarm
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anlegen
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDelete
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteWerte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteTexte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anlegen
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anzahl
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anzahl
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.DeleteALL
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.DeleteALL
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.SONOFF
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AKKU
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.ENERGY
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMeessage
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TabellenFlexible
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.BackItUp
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AlexaSmartDevices
      vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AnzahlSonoff
      vis.js:3167 Create inner vis object 0_userdata.0.Akkuskript.VISTabelle
      vis.js:3167 Create inner vis object sonoff.0.SonoffPow1.ENERGY_Total
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.TVProgramm
      vis.js:3167 Create inner vis object system.adapter.systeminfo.0.connected
      vis.js:3167 Create inner vis object javascript.0.Park.StringHTML
      vis.js:3167 Create inner vis object javascript.0.Netzwerk.StringHTML
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Title
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Event
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.FileName
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Summary
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Thumb
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Change
      vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Player
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyWLAN
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Pause
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Anzahl
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSController
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_DeleteVIS
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CodeList2
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRootGuest
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_Delete_Voucher.Delete
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Info
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateStandard
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateListStandard
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Create
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRoot1
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Dauer
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Anzahl
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.MultiUse
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Mb_Begrenzung
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Download
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Upload
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Notiz
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.SiteLED
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm_Anzahl
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Log
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.xxxScriptVersionxxx
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Missing_Name
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.ZyklusZaehler
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Client_WhiteList
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyDISC
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_RX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_TX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_RX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_TX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_RX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_TX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.Galaxy-S9
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.GalaxyTabS2
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.GalaxyTabS2
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.Galaxy-S9
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.MediaTabT5
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.FireTablet7
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.FireTablet7
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.TrekStor13
      vis.js:3167 Create inner vis object javascript.0.VoucherKinder.LastSend
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Satisfaction
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Model
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Adopted
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.IP_Adresse
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.ToController
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Satisfaction
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Model
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Adopted
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.IP_Adresse
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.ToController
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.AliasName
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSAdapter
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUIdleALL
      vis.js:3167 Create inner vis object system.adapter.enigma2.0.connected
      vis.js:3167 Create inner vis object system.adapter.lgtv.0.connected
      vis.js:3167 Create inner vis object system.adapter.amazon-dash.0.connected
      vis.js:3167 Create inner vis object system.adapter.plex.0.connected
      vis.js:3167 Create inner vis object system.adapter.pi-hole.0.connected
      vis.js:3167 Create inner vis object system.adapter.mpd.0.connected
      vis.js:3167 Create inner vis object system.adapter.mihome.0.connected
      vis.js:3167 Create inner vis object system.adapter.sayit.0.connected
      vis.js:3167 Create inner vis object system.adapter.fritzdect.0.connected
      vis.js:3167 Create inner vis object system.adapter.fritzdect.1.connected
      vis.js:3167 Create inner vis object system.adapter.proxmox.0.connected
      vis.js:3167 Create inner vis object system.adapter.unifi.0.connected
      vis.js:3167 Create inner vis object system.adapter.fullybrowser.0.connected
      vis.js:3167 Create inner vis object system.adapter.mclighting.0.connected
      vis.js:3167 Create inner vis object system.adapter.sonoff.0.connected
      vis.js:3167 Create inner vis object system.adapter.pushbullet.0.connected
      vis.js:3167 Create inner vis object system.adapter.sql.0.connected
      vis.js:3167 Create inner vis object system.adapter.pushbullet.1.connected
      vis.js:3167 Create inner vis object javascript.0.Ereignisliste.heute.eventlistHTML
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapTable
      vis.js:3167 Create inner vis object controll-own.0.FUTRO.DevicesIP
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskTable
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.HightCpuProcess
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.NFSExports
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapAlarm
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryAlarm
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessJetzt
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessFilter
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.ProcessTable
      vis.js:3167 Create inner vis object javascript.0.GETPROCESS.AlarmCPURunLevel
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootSQLTulla
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootProxmox
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPlexServer
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPiHole
      vis.js:3167 Create inner vis object controll-own.0.mount.DiskHelpRootFileserver
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Update
      vis.js:3167 Create inner vis object hm-rpc.0.IEQ0007259.1.STATE
      vis.js:3167 Create inner vis object hm-rpc.0.KEQ0193137.1.STATE
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur_Farbe
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.aktiv_parse
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Load
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Speicher
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.aktiv_parse
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Speicher
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Interface
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.FTL
      vis.js:3167 Create inner vis object javascript.2.scriptEnabled.common.VIS.VIS_Pihole_Info
      vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Pihole
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.TimerResetVIS
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Minuten
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Minuten
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.SummeMinuten2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Sekunden
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Name2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Finished
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Gerät2
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Gerät1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.SummeMinuten1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Finished
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Name1
      vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Sekunden
      vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahlPx
      vis.js:3167 Create inner vis object javascript.0.logik.gästebadLicht.bewegungGästebad
      vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_Anzahl
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_RX
      vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_TX
      vis.js:3167 Create inner vis object system.adapter.tr-064.1.connected
      vis.js:3167 Create inner vis object system.adapter.tr-064.0.connected
      vis.js:3167 Create inner vis object snmp.1.info.connection
      vis.js:3167 Create inner vis object system.adapter.snmp.1.alive
      vis.js:3167 Create inner vis object snmp.0.info.connection
      vis.js:3167 Create inner vis object system.adapter.rpi2.0.connected
      vis.js:3167 Create inner vis object system.adapter.radar.0.connected
      vis.js:3167 Create inner vis object system.adapter.pushover.0.connected
      vis.js:3167 Create inner vis object system.adapter.paw.0.connected
      vis.js:3167 Create inner vis object system.adapter.paw.0.alive
      vis.js:3167 Create inner vis object mihome-vacuum.0.info.connection
      vis.js:3167 Create inner vis object mihome.0.devices.gateway_7c49eb88c200.connected
      vis.js:3167 Create inner vis object system.adapter.pushbullet.1.alive
      vis.js:3167 Create inner vis object fritzbox.0.system.deltaTimeOK
      vis.js:3167 Create inner vis object javascript.0.Log-Script.logProtokol.logJSON
      vis.js:3167 Create inner vis object javascript.0.Log-Script.logAlexaueberwachung.clearJSON
      vis.js:3167 Create inner vis object javascript.1.mylog.logAllJSON
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.volume
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentArtist
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.volume
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.ALLradioALL
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.7dbdc61535fd4214b45ee26d40f00370.Player.currentArtist
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentArtist
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.volume
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioKueche
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentArtist
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioEchoPlus
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.volume
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentArtist
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.providerId
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentTitle
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.volume
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioFlur
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentArtist
      vis.js:3167 Create inner vis object controll-own.0.RADIOs.EchoShow5Radio
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.volume
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentArtist
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentState
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentTitle
      vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.providerId
      vis.js:3167 Create inner vis object trashschedule.0.type.KrankSchreibung.daysleft
      vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT
      vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT2
      vis.js:3167 Create inner vis object ping.0.iobroker59.www_google_com
      vis.js:3167 Create inner vis object ping.0.raspberry3.www_google_com
      vis.js:3167 Create inner vis object controll-own.0.mount.CPUTemp
      vis.js:3167 Create inner vis object javascript.0.CountdownPapierTonne.Termin.Rest.Tage
      vis.js:3167 Create inner vis object javascript.0.Speed-Test.data.speeds.download
      vis.js:3167 Create inner vis object tcontroll-own.0.Banane
      vis.js:3167 Create inner vis object trashschedule.1.type.Gelber Sack.daysleft
      vis.js:3167 Create inner vis object trashschedule.1.type.Biomüll.daysleft
      vis.js:3167 Create inner vis object trashschedule.1.type.Restmüll.daysleft
      vis.js:3167 Create inner vis object trashschedule.1.type.Papiertonne.daysleft
      vis.js:3167 Create inner vis object javascript.0.Log-Script.Loganzeige
      vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.download_Mb
      vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.upload_Mb
      vis.js:3167 Create inner vis object trashschedule.0.type.json
      vis.js:3167 Create inner vis object javascript.0.wled.farbe
      vis.js:3167 Create inner vis object javascript.0.wled.effekt
      vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.sx
      vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.ix
      vis.js:3167 Create inner vis object javascript.0.wled.brightness
      vis.js:3167 Create inner vis object javascript.0.wled.toggle
      vis.js:3167 Create inner vis object javascript.0.wled.palette
      vis.js:3167 Create inner vis object javascript.0.wled.preset
      vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.Alarm
      vis.js:3167 Create inner vis object calendar.0.YXJtaW4uc2xpdmluc2t5QGdtYWlsLm
      vis.js:3167 Create inner vis object calendar.0.YWRkcmVzc2Jvb2sjY29udGFjdHNAZ3
      vis.js:3167 Create inner vis object calendar.0.ZGUuZ2VybWFuI2hvbGlkYXlAZ3JvdX
      vis.js:3167 Create inner vis object calendar.0.cCN3ZWF0aGVyQGdyb3VwLnYuY2FsZW
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.DeleteALL
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anzahl
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDelete
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteWerte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteTexte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anlegen
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.ALEXAEinkauf
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.targettemp
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.targettemp
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.targettemp
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.actualtemp
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.actualtemp
      vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.actualtemp
      vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLHilde
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.ALEXAToDo
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anlegen
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDelete
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteWerte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteTexte
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.DeleteALL
      vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anzahl
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Mail
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Fax
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Telefon
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Adresse
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Name
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Datum
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Änderung zum Vortag
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Trend zum Vortag
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettopreis Gesamt
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettozuschlag Gesamt
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.MwSt Gesamt
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Bruttopreis Gesamt
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettopreis 100l
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettozuschlag 100l
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.MwSt 100l
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Entladestellen
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Heizölsorte ID
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Zahlungsart ID
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Lieferort
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Liefermenge
      vis.js:3167 Create inner vis object javascript.0.Heizoel.Skriptstart
      DevTools failed to parse SourceMap: chrome-extension://dafgdjggglmmknipkhngniifhplpcldb/browser-polyfill.min.js.map
      hqwidgets.js:902 Version vis-hqwidgets: 1.1.4
      bars.js:55 Version vis-bars:0.1.4
      undefined:1 GET http://192.168.178.59:8072/vis/undefined 404 (Not Found)
      Image (async)
      l @ can.custom.min.js:20
      e.buildFragment @ can.custom.min.js:20
      n.frag @ can.custom.min.js:14
      fragment @ can.custom.min.js:58
      frag @ can.custom.min.js:58
      r @ can.custom.min.js:58
      renderTo @ can.custom.min.js:58
      renderAs @ can.custom.min.js:58
      e.view.e.template @ can.custom.min.js:58
      renderWidget @ vis.js:1610
      (anonymous) @ vis.js:887
      (anonymous) @ vis.js:2742
      (anonymous) @ conn.js:730
      r.onack @ index.js:83
      r.onpacket @ index.js:83
      (anonymous) @ index.js:83
      r.emit @ index.js:83
      r.ondecoded @ index.js:83
      a.add @ index.js:83
      r.ondata @ index.js:83
      r.onPacket @ index.js:83
      r.onData @ index.js:83
      ws.onmessage @ index.js:83
      VM32087:1 Uncaught SyntaxError: Unexpected token u in JSON at position 0
         at JSON.parse (<anonymous>)
         at Object.redraw (trashschedule.js:170)
         at Object.createWidget (trashschedule.js:36)
         at trashschedule.js:31
      redraw @ trashschedule.js:170
      createWidget @ trashschedule.js:36
      (anonymous) @ trashschedule.js:31
      setTimeout (async)
      createWidget @ trashschedule.js:30
      eval @ tplTrashscheduleHelper.js:24
      n.render @ can.custom.min.js:76
      t.template.fn @ can.custom.min.js:76
      subscribeStates @ vis.js:2745
      renderView @ vis.js:799
      renderViews @ vis.js:761
      (anonymous) @ vis.js:917
      a.add @ index.js:83
      Show 6 more frames
      lib.min.js:1 Uncaught 1586086553413 and 1586086952413 are too far apart with stepSize of 1 millisecond
      Ve @ lib.min.js:1
      buildTicks @ lib.min.js:6
      update @ lib.min.js:5
      lt @ lib.min.js:1
      update @ lib.min.js:4
      updateLayout @ lib.min.js:4
      resize @ lib.min.js:4
      n @ lib.min.js:4
      (anonymous) @ lib.min.js:1
      requestAnimationFrame (async)
      o @ lib.min.js:1
      scroll (async)
      n._reset @ lib.min.js:1
      n.renderProxy @ lib.min.js:1
      lib.min.js:1 Uncaught (in promise) TypeError: Cannot read property 'time' of undefined
         at Te (lib.min.js:1)
         at n.getPixelForOffset (lib.min.js:6)
         at n.getPixelForValue (lib.min.js:6)
         at n.updateElement (lib.min.js:3)
         at n.addElementAndReset (lib.min.js:3)
         at n.insertElements (lib.min.js:3)
         at n.resyncElements (lib.min.js:3)
         at n.buildOrUpdateElements (lib.min.js:3)
         at rr.update (lib.min.js:4)
         at widgets.min.js:3
      Te @ lib.min.js:1
      getPixelForOffset @ lib.min.js:6
      getPixelForValue @ lib.min.js:6
      updateElement @ lib.min.js:3
      addElementAndReset @ lib.min.js:3
      insertElements @ lib.min.js:3
      resyncElements @ lib.min.js:3
      buildOrUpdateElements @ lib.min.js:3
      (anonymous) @ widgets.min.js:3
      Promise.then (async)
      o @ widgets.min.js:3
      t.dispatch @ can.custom.min.js:18
      stop @ can.custom.min.js:44
      _setAttrs @ can.custom.min.js:48
      attr @ can.custom.min.js:48
      updateState @ vis.js:2800
      (anonymous) @ vis.js:3347
      (anonymous) @ vis.js:3559
      setTimeout (async)
      _setTimeout @ vis.js:3558
      onUpdate @ vis.js:3346
      (anonymous) @ conn.js:420
      r.onevent @ index.js:83
      a.add @ index.js:83
        liv-in-sky @Scrounger last edited by
        @Scrounger sorry sory sorry - ich glaube, ich bin einen schritt weiter
        ich hatte das problem mit chrome und deiner version .2.26
        gestern oder vorgestern habe ich aber meinen brwoser gewechselt (von chrome auf brave) - nun habe ich das bemerkt und habe wieder mit chrome ein widget angelegt und siehe da
        deine neuen versionen scheinen eine besserung gebracht zu haben - ich werd noch ein wenig die settings ändern
          sigi234 Forum Testing Most Active @Scrounger last edited by
          @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
          Du hast mir nicht das consloen log angehänt, sondern den Code von der *.min.js des Adapters
          Bitte log zur verfügung stellen, vollständig!!!
          wd.txt
          • Scrounger
            Scrounger Developer @liv-in-sky last edited by
            @liv-in-sky sagte in Test Adapter Material Design Widgets v0.2.x:
            @Scrounger mit .2.28
            restart und neu angelegt
            Hattest aber den debug mode nicht aktiv 😉
            Ok, poste aber trotzdem noch mal nen log.
            @sigi234 sagte in Test Adapter Material Design Widgets v0.2.x:
            wd.txt
            Also das log sieht gut aus. Was hast du denn noch für fehler?
              @Scrounger
              danke - das war es - beschriftung wieder da - da gibt es echt viel zum einstellen 🙂
              und noch ein log - mit funktionierendem widget
              [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
              DevTools failed to parse SourceMap: chrome-extension://iemadiahhbebdklepanmkjenfdebfpfe/static/js/main.6e6198ed.js.map
              DevTools failed to parse SourceMap: http://192.168.178.59:8072/lib/js/socket.io.js.map
              index.html?galaxy:4059 Version vis-colorpicker: 1.0.1
              index.html?galaxy:4907 Version coronavirus-statistics: 0.1.0
              index.html?galaxy:5638 fritzdect widget version: "0.0.1"
              index.html?galaxy:6098 Version vis-history: 1.0.0
              jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/template/words.js 404 (Not Found)
              send @ jquery-1.11.2.min.js:4
              ajax @ jquery-1.11.2.min.js:4
              m.<computed> @ jquery-1.11.2.min.js:4
              (anonymous) @ calendar.js:11
              info.js:22 Version Info-Adapter-Widget: 0.0.9
              index.html?galaxy:7156 Version vis-jqui-mfd: 1.0.12
              justgage.js:115 Version justgage: 1.0.2
              materialdesign.js:25 Version vis-materialdesign: 0.2.78
              index.html?galaxy:13443 Metro version: "1.1.2"
              DevTools failed to parse SourceMap: http://192.168.178.59:8072/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
              lib.min.js:22 Download the Vue Devtools extension for a better development experience:
              https://github.com/vuejs/vue-devtools
              lib.min.js:22 You are running Vue in development mode.
              Make sure to turn on production mode when deploying for production.
              See more tips at https://vuejs.org/guide/deployment.html
              players.js:58 Version players: 0.1.0
              rssfeed.js:22 Version rssfeed: 0.0.1
              jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/rssfeed/words.js 404 (Not Found)
              (anonymous) @ rssfeed.js:11
              trashschedule.js:22 Version trashschedule: 0.0.4
              index.html?galaxy:19713 Version vis-weather: 2.4.1
              jquery-1.11.2.min.js:4 GET http://192.168.178.59:8072/vis/adapter/trashschedule/words.js 404 (Not Found)
              (anonymous) @ trashschedule.js:11
              conn.js:273 2020-04-05T12:48:12.773Z Connected => authenticate
              conn.js:293 2020-04-05T12:48:12.936Z Authenticated: true
              vis.js:3167 Create inner vis object controll-own.0._MenuRaspi
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestString2
              vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.sortMode
              vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.filterMode
              vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkStatus.jsonList
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.test.html
              vis.js:3167 Create inner vis object 0_userdata.0.vis.NetzwerkDevicesStatus.filterMode
              vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeBatt
              vis.js:3167 Create inner vis object controll-own.0.HANDY.odysBatt
              vis.js:3167 Create inner vis object iot.0.services.custom__batt_s7
              vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstorebatt2
              vis.js:3167 Create inner vis object controll-own.0.HANDY.t113batt
              vis.js:3167 Create inner vis object controll-own.0.WHATSAPPtext
              vis.js:3167 Create inner vis object controll-own.0.WHATSAPPCheck
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodosText
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLToDos
              vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLArmin
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ToDoListLoeschen
              vis.js:3167 Create inner vis object controll-own.0.AlexaSprichMirNach
              vis.js:3167 Create inner vis object controll-own.0.Banane
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL2
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL3
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL4
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL5
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL6
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SeenSQL7
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_26
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_49
              vis.js:3167 Create inner vis object controll-own.0.statusDLNAReload
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_124
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_113
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpDaten
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpReserve
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpSync
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpmSata
              vis.js:3167 Create inner vis object plex.0.libraries.1-serien.itemsCount
              vis.js:3167 Create inner vis object controll-own.0.statusDLNARestart
              vis.js:3167 Create inner vis object controll-own.0.statusRefresh
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_29
              vis.js:3167 Create inner vis object controll-own.0.statusMiniDLNA
              vis.js:3167 Create inner vis object controll-own.0.statusDLNAfind
              vis.js:3167 Create inner vis object mpd.0.state
              vis.js:3167 Create inner vis object controll-own.0.statusFilm
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.checkDaten
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.DatenCheckBackup
              vis.js:3167 Create inner vis object controll-own.0.mounthelpReserve
              vis.js:3167 Create inner vis object controll-own.0.mounthelpSync
              vis.js:3167 Create inner vis object controll-own.0.mounthelpDaten
              vis.js:3167 Create inner vis object controll-own.0.mounthelpmSata
              vis.js:3167 Create inner vis object controll-own.0.HANDY.odysload
              vis.js:3167 Create inner vis object controll-own.0.HANDY.edgeload
              vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreLoad
              vis.js:3167 Create inner vis object controll-own.0.HANDY.stromTrekstore
              vis.js:3167 Create inner vis object controll-own.0.HANDY.stromEdge
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskSpace
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.WWWCopy
              vis.js:3167 Create inner vis object controll-own.0.HANDY.stromOdys
              vis.js:3167 Create inner vis object controll-own.0.iobrokerbackup
              vis.js:3167 Create inner vis object controll-own.0.iobrokerbackupstatus
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.SQLConnections
              vis.js:3167 Create inner vis object mclighting.0.fx_mode
              vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID
              vis.js:3167 Create inner vis object mclighting.0.color_R
              vis.js:3167 Create inner vis object mclighting.0.color_G
              vis.js:3167 Create inner vis object mclighting.0.color_B
              vis.js:3167 Create inner vis object mclighting.0.fx_mode_name
              vis.js:3167 Create inner vis object mclighting.1.fx_mode
              vis.js:3167 Create inner vis object controll-own.0.NeRGB-ID2
              vis.js:3167 Create inner vis object mclighting.1.color_R
              vis.js:3167 Create inner vis object mclighting.1.color_G
              vis.js:3167 Create inner vis object mclighting.1.color_B
              vis.js:3167 Create inner vis object mclighting.1.fx_mode_name
              vis.js:3167 Create inner vis object mclighting.0.power
              vis.js:3167 Create inner vis object mclighting.1.power
              vis.js:3167 Create inner vis object mclighting.1.brightness
              vis.js:3167 Create inner vis object mclighting.0.brightness
              vis.js:3167 Create inner vis object controll-own.0.SonoffsRestart
              vis.js:3167 Create inner vis object controll-own.0.SonoffsOff
              vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov2.POWER
              vis.js:3167 Create inner vis object sonoff.0.Sonoff11.POWER2
              vis.js:3167 Create inner vis object sonoff.0.Sonoff13.POWER2
              vis.js:3167 Create inner vis object sonoff.0.Sonoff4.POWER2
              vis.js:3167 Create inner vis object sonoff.0.Sonoff5.POWER2
              vis.js:3167 Create inner vis object sonoff.0.MCUTasmotaMov1.POWER
              vis.js:3167 Create inner vis object controll-own.0.HANDY.SQLTodayDelete
              vis.js:3167 Create inner vis object sonoff.0.Sonoff15.AM2301_Temperature
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryFree
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapSize
              vis.js:3167 Create inner vis object controll-own.0.mount.SQLSizeioBrokerData
              vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.screenOff
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoad
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadTx
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeVAR
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.LOGSizeIOBroker
              vis.js:3167 Create inner vis object pi-hole.0.summary.domains_being_blocked
              vis.js:3167 Create inner vis object pi-hole.0.summary.dns_queries_today
              vis.js:3167 Create inner vis object pi-hole.0.summary.ads_blocked_today
              vis.js:3167 Create inner vis object pi-hole.0.summary.ads_percentage_today
              vis.js:3167 Create inner vis object pi-hole.0.summary.status
              vis.js:3167 Create inner vis object controll-own.0.PI-HOLE.IPv6
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Bruttopreis 100l
              vis.js:3167 Create inner vis object admin.0.info.updatesNumber
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadZaehler
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FTPDownLoadMIN
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.First
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondtLink
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.SecondLink
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.ThirdLink
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstLink
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.FirstText
              vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.4bfd6fec-5b3d-45e2-ae7a-a38bb9075ac0.powerState
              vis.js:3167 Create inner vis object javascript.0.VIS-Steuerung.Aktuelle_VIS_Seite
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.TimerResetVIS
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Minuten
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Minuten
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.SummeMinuten2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Finished
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Sekunden
              vis.js:3167 Create inner vis object 60
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Name2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Gerät2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Gerät1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.SummeMinuten1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Finished
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Name1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Sekunden
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Ende1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Ende2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Start1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Start2
              vis.js:3167 Create inner vis object controll-own.0.Luefter3
              vis.js:3167 Create inner vis object controll-own.0.Luefter1
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_1
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_36
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_27
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_127
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_88
              vis.js:3167 Create inner vis object controll-own.0.ACER5630Cyber
              vis.js:3167 Create inner vis object controll-own.0.AMD5300
              vis.js:3167 Create inner vis object controll-own.0.fx6300
              vis.js:3167 Create inner vis object controll-own.0.FARBBand
              vis.js:3167 Create inner vis object controll-own.0.HeizungZimmerCounter
              vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer30
              vis.js:3167 Create inner vis object controll-own.0.HeizungZimmer90
              vis.js:3167 Create inner vis object controll-own.0.SchreibtischHAUPT
              vis.js:3167 Create inner vis object controll-own.0.Wechsel
              vis.js:3167 Create inner vis object controll-own.0.WechselHalb
              vis.js:3167 Create inner vis object controll-own.0.fx6300energie
              vis.js:3167 Create inner vis object controll-own.0.AMDM5300Monitor
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.targettemp
              vis.js:3167 Create inner vis object controll-own.0.fx63000monitore
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEED
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERION
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSWING
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERCOOL
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERHUM
              vis.js:3167 Create inner vis object controll-own.0.COOLER.COOLERSPEEDHELP
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-EIN
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EIN
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_23
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.REVOLT3EIN
              vis.js:3167 Create inner vis object controll-own.0.LG-TV.ChannelWahl
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrProMain
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrStu
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITSchaltUhrMin
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScahltUhrTVEin
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro1
              vis.js:3167 Create inner vis object controll-own.0.AlexaTriggerSnc
              vis.js:3167 Create inner vis object controll-own.0.HeizungKuecheCounter
              vis.js:3167 Create inner vis object controll-own.0.HeizungKueche30
              vis.js:3167 Create inner vis object controll-own.0.HeizungKueche90
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.targettemp
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.targettemp
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.targettemp
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.temp
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.temp
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.temp
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119590537608.temp
              vis.js:3167 Create inner vis object controll-own.0.FX6300alt
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_136
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Total
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer30
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmer90
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotZimmerCounter
              vis.js:3167 Create inner vis object controll-own.0.MATRIX.ScahlterMatrix
              vis.js:3167 Create inner vis object controll-own.0.schlafen
              vis.js:3167 Create inner vis object controll-own.0.HANDY.trekstoreScreen
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.UnifiController
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioCarPort
              vis.js:3167 Create inner vis object controll-own.0.Atesten
              vis.js:3167 Create inner vis object controll-own.0.PLEX.PlexStart
              vis.js:3167 Create inner vis object controll-own.0.PLEX.PLEXAll
              vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckTautulla
              vis.js:3167 Create inner vis object system.adapter.plex.0.alive
              vis.js:3167 Create inner vis object ping.0.raspberry3.192_168_178_14
              vis.js:3167 Create inner vis object controll-own.0.PLEX.CheckPlexService
              vis.js:3167 Create inner vis object controll-own.0.PLEX.MountVideoFiles
              vis.js:3167 Create inner vis object controll-own.0.MATRIX2.ScahlterMatrix
              vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixMode
              vis.js:3167 Create inner vis object controll-own.0.MATRIX2.MatrixRefreshTime
              vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixMode
              vis.js:3167 Create inner vis object controll-own.0.MATRIX.MatrixRefreshTime
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.endDate
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv1
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV2.endDate
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZEITScalterActiv2
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel1
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrDel2
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltReset
              vis.js:3167 Create inner vis object controll-own.0.HANDY.ZeitScaltUhrPro2
              vis.js:3167 Create inner vis object system.adapter.admin.0.uptime
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahl2
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590404152.battery
              vis.js:3167 Create inner vis object fritzdect.0.Comet_119590311304.battery
              vis.js:3167 Create inner vis object lgtv.0.states.youtube
              vis.js:3167 Create inner vis object lgtv.0.states.channel
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestLogic2
              vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_29.Commands.loadStartURL
              vis.js:3167 Create inner vis object controll-own.0.LEDLampe
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_124
              vis.js:3167 Create inner vis object controll-own.0.MOTION.SchalterFlurLicht
              vis.js:3167 Create inner vis object controll-own.0.KuechenLicht
              vis.js:3167 Create inner vis object controll-own.0.KuechenLichLight
              vis.js:3167 Create inner vis object controll-own.0.KuehlschrankTuer
              vis.js:3167 Create inner vis object controll-own.0.NACHTLAMPE
              vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiMain
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_151
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_73
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_29
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBT
              vis.js:3167 Create inner vis object controll-own.0.NACHTKASTENLAMPE
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioZimmerBTonly
              vis.js:3167 Create inner vis object controll-own.0.LEDLangWLED
              vis.js:3167 Create inner vis object controll-own.0.KuehlschrankLicht
              vis.js:3167 Create inner vis object controll-own.0.RaspBerry-Helper.RaspiRefreshChrome
              vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerName
              vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.inbound.caller
              vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVorwahl
              vis.js:3167 Create inner vis object controll-own.0.SAT
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_99
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_82
              vis.js:3167 Create inner vis object mpd.0.title
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_34
              vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananePiPro
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_53
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FlurAnwesenheit
              vis.js:3167 Create inner vis object dwd.0.warning.description
              vis.js:3167 Create inner vis object dwd.0.warning.headline
              vis.js:3167 Create inner vis object controll-own.0.TemperaturWidget
              vis.js:3167 Create inner vis object controll-own.0.MOTION.BADRein
              vis.js:3167 Create inner vis object controll-own.0.GastZugang
              vis.js:3167 Create inner vis object controll-own.0.HANDY.FritzCallHelpVis
              vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLAUTER
              vis.js:3167 Create inner vis object controll-own.0.BANANAMPD.BananeLEISER
              vis.js:3167 Create inner vis object ical.1.data.html
              vis.js:3167 Create inner vis object openweathermap.0.forecast.current.temperature
              vis.js:3167 Create inner vis object openweathermap.0.forecast.day1.temperatureMax
              vis.js:3167 Create inner vis object sonoff.0.Sonoff16.BH1750_Illuminance
              vis.js:3167 Create inner vis object controll-own.0.HILDE.HildeDaheim
              vis.js:3167 Create inner vis object controll-own.0.Heizung30
              vis.js:3167 Create inner vis object controll-own.0.Heizung90
              vis.js:3167 Create inner vis object ical.0.data.html
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Datum
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.TotalText
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Alarm
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Name
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayAuswahl
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.MPDPlayList
              vis.js:3167 Create inner vis object mpd.0.pause
              vis.js:3167 Create inner vis object javascript.0.scriptEnabled.common.ExecuteLinuxMPDVolLauter
              vis.js:3167 Create inner vis object mpd.0.next
              vis.js:3167 Create inner vis object mpd.0.previous
              vis.js:3167 Create inner vis object tr-064.0.states.wlan24
              vis.js:3167 Create inner vis object iot.0.services.custom_hildeloc
              vis.js:3167 Create inner vis object openweathermap.0.forecast.current.icon
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Tage
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Stunden
              vis.js:3167 Create inner vis object javascript.0.Countdown.Termin.Rest.Minuten
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Sekunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Minuten
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Stunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Werte.Tage
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Sekunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Minuten
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Stunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Werte.Tage
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Start
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Start
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Start
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Stopp
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Steuerung.Reset
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Ausgabehilfe
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Stopp
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Steuerung.Reset
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR2.Ausgabehilfe
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Reset
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ende
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Steuerung.Stopp
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR1.Ausgabehilfe
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Sekunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Minuten
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Stunden
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.Werte.Tage
              vis.js:3167 Create inner vis object controll-own.0.mount.CPULuefter
              vis.js:3167 Create inner vis object controll-own.0.HeizungCounter
              vis.js:3167 Create inner vis object javascript.0.STOPPUHR3.TimerZaehler
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.reached
              vis.js:3167 Create inner vis object countdown.0.setup.TV1
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.days
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.hours
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.minutes
              vis.js:3167 Create inner vis object countdown.0.countdowns.TV1.months
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Fehler
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.Orginal2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.Orginal1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer2.MitStunden2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer.Timer1.MitStunden1
              vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerPicture
              vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerVisSichtbarkeit
              vis.js:3167 Create inner vis object controll-own.0.HANDY.CallerGeraet
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610651024.battery
              vis.js:3167 Create inner vis object fullybrowser.0.192_168_178_73.Commands.screenOff
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.title
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.event
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.file.name
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.thumb
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.datetime
              vis.js:3167 Create inner vis object plex.0._playing.players
              vis.js:3167 Create inner vis object contact.0.photo
              vis.js:3167 Create inner vis object plex.0._playing._recent-player.Metadata.summary
              vis.js:3167 Create inner vis object view
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADLicht
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefter
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RM-MINI.L.HEIZLuefterEIN
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADAnwesenheit
              vis.js:3167 Create inner vis object arning.headline
              vis.js:3167 Create inner vis object controll-own.0.MOTION.BADaktiv
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizluefterSTEPs
              vis.js:3167 Create inner vis object mihome.0.devices.magnet_158d0001fa8b82.state
              vis.js:3167 Create inner vis object controll-own.0.MOTION.BADTuerHELP
              vis.js:3167 Create inner vis object ping.0.iobroker59.192_168_178_42
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHAUPTSCHALTER
              vis.js:3167 Create inner vis object controll-own.0.HANDY.t113load
              vis.js:3167 Create inner vis object controll-own.0.Lüfter4
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.POWER
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.volume
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentArtist
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RockAntenneTitle
              vis.js:3167 Create inner vis object sonoff.0.ShellyWC.POWER
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.targettemp
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.temp
              vis.js:3167 Create inner vis object openweathermap.0.forecast.current.precipitationSnow
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad30
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBad90
              vis.js:3167 Create inner vis object controll-own.0.INFRAROT.InfrarotBadCounter
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizungCounter
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung30
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADHeizung90
              vis.js:3167 Create inner vis object controll-own.0.BAD.BADVisNeu
              vis.js:3167 Create inner vis object controll-own.0.HANDYKLINGELT
              vis.js:3167 Create inner vis object tr-064-community.0.callmonitor.ringing
              vis.js:3167 Create inner vis object trashschedule.0.type.BIOMÜLL.daysleft
              vis.js:3167 Create inner vis object trashschedule.0.type.PAPIER TONNE.daysleft
              vis.js:3167 Create inner vis object trashschedule.0.type.GELBER SACK.daysleft
              vis.js:3167 Create inner vis object trashschedule.0.type.RESTMÜLL.daysleft
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow3.ENERGY_Total
              vis.js:3167 Create inner vis object fritzdect.1.Comet_119610737080.battery
              vis.js:3167 Create inner vis object alexa2.0.Smart-Home-Devices.a67645b2-910f-4dae-9c3c-6f606a98c95f.powerState
              vis.js:3167 Create inner vis object system.adapter.coronavirus-statistics.0.connected
              vis.js:3167 Create inner vis object coronavirus-statistics.0._Last_Update
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.critical
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Germany.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.critical
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.Europe.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.critical
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_continents.America.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.critical
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Italy.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.global_totals.deaths
              vis.js:3167 Create inner vis object rssfeed.0.IOBROKER
              vis.js:3167 Create inner vis object rssfeed.0.Formel1
              vis.js:3167 Create inner vis object rssfeed.0.Tagesschau
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.active
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.country
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.1.flag
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.country
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.flag
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.country
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.flag
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.country
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.flag
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.country
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.flag
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.active
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.2.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.active
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.3.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.active
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.4.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.cases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.active
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.country_Top_5.5.deaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.critical
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayCases
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.recovered
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.todayDeaths
              vis.js:3167 Create inner vis object coronavirus-statistics.0.Austria.deaths
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFeedZwitesFensterVIS
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RSSan
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelleFeed
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSQuelle2VIS
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.RSSFormelEINS2
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Power
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Current
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow2.ENERGY_Voltage
              vis.js:3167 Create inner vis object nut.0.ups.load
              vis.js:3167 Create inner vis object nut.0.status.overload
              vis.js:3167 Create inner vis object nut.0.status.charging
              vis.js:3167 Create inner vis object nut.0.status.online
              vis.js:3167 Create inner vis object nut.0.ups.status
              vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Minuten
              vis.js:3167 Create inner vis object javascript.0.Datenpunkt.USV_laufzeit_in_Stunden
              vis.js:3167 Create inner vis object nut.0.battery.charge
              vis.js:3167 Create inner vis object nut.0.battery.voltage
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunSuccessful
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.OrdnerCheck
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.RunScript
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.LatestChangeDP_Factor
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HTMLTable
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.HistoryAnalyse
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.SmartHomeAnalyse
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.MonsterSearch
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.WertAnalyse
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.TypeAnalyse
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ObjectAnzahlCheck
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.ohneInstanzAnzeige
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.JavaInstanzCheck
              vis.js:3167 Create inner vis object javascript.0.ProofingDatapoints.CheckAliase
              vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_Table
              vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.IPDevices_MD_List
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMaterialWidgetTable
              vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.missedFritzbox
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.EnergyMaterialWidgetTable
              vis.js:3167 Create inner vis object lgtv.0.states.volume
              vis.js:3167 Create inner vis object lgtv.0.remote.enter
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Player.controlPause
              vis.js:3167 Create inner vis object lgtv.0.states.channelDown
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0913L0592570PHD.Commands.deviceStop
              vis.js:3167 Create inner vis object lgtv.0.states.channelUp
              vis.js:3167 Create inner vis object lgtv.0.remote.cc
              vis.js:3167 Create inner vis object lgtv.0.remote.home
              vis.js:3167 Create inner vis object lgtv.0.remote.menu
              vis.js:3167 Create inner vis object lgtv.0.remote.left
              vis.js:3167 Create inner vis object lgtv.0.remote.right
              vis.js:3167 Create inner vis object lgtv.0.remote.exit
              vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.back
              vis.js:3167 Create inner vis object firetv.0.192_168_178_57.keys.down
              vis.js:3167 Create inner vis object lgtv.0.remote.1
              vis.js:3167 Create inner vis object lgtv.0.remote.2
              vis.js:3167 Create inner vis object lgtv.0.remote.3
              vis.js:3167 Create inner vis object lgtv.0.remote.4
              vis.js:3167 Create inner vis object lgtv.0.remote.5
              vis.js:3167 Create inner vis object lgtv.0.remote.6
              vis.js:3167 Create inner vis object lgtv.0.remote.7
              vis.js:3167 Create inner vis object lgtv.0.remote.8
              vis.js:3167 Create inner vis object lgtv.0.remote.9
              vis.js:3167 Create inner vis object lgtv.0.remote.0
              vis.js:3167 Create inner vis object lgtv.0.remote.green
              vis.js:3167 Create inner vis object lgtv.0.remote.dash
              vis.js:3167 Create inner vis object lgtv.0.remote.blue
              vis.js:3167 Create inner vis object lgtv.0.remote.yellow
              vis.js:3167 Create inner vis object lgtv.0.remote.red
              vis.js:3167 Create inner vis object lgtv.0.states.mute
              vis.js:3167 Create inner vis object lgtv.0.states.popup
              vis.js:3167 Create inner vis object lgtv.0.states.turnOff
              vis.js:3167 Create inner vis object lgtv.0.states.input
              vis.js:3167 Create inner vis object lgtv.0.states.currentApp
              vis.js:3167 Create inner vis object lgtv.0.states.soundOutput
              vis.js:3167 Create inner vis object lgtv.0.states.3Dmode
              vis.js:3167 Create inner vis object lgtv.0.states.model
              vis.js:3167 Create inner vis object lgtv.0.info.connection
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVall
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVFlexAnzeige
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVjetzt
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TVgleich
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2015
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TV2200
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.ALEXAToDo
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.Meisterschaft
              vis.js:3167 Create inner vis object 0_userdata.0.testmailvis
              vis.js:3167 Create inner vis object javascript.0.Tabellen.Web-Speedy-Test.VISAnzeige
              vis.js:3167 Create inner vis object 0_userdata.0.Tabellen.PingAdapter
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTML
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-INFO
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.ARIVA1-WEITER
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-ZURUECK
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-OK
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-OBEN
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-HDMI
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-SOURCE
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-RECHTS
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-LINKS
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PLAY
              vis.js:3167 Create inner vis object controll-own.0.TVLeiser
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-STOP
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-PAUSE
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-EXIT
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MENU
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RETURN
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-2
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-1
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-3
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-4
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-5
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-6
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-7
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-8
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-PRO-9
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-10
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-14
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-15
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-16
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-18
              vis.js:3167 Create inner vis object scene.AVIRA1-PRO-13
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-MUTE
              vis.js:3167 Create inner vis object controll-own.0.TVLauter
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-NACH-UNTEN
              vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLauter
              vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVLeiser
              vis.js:3167 Create inner vis object controll-own.0.AVIRAPROG.AVBack
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.AVIRA1-MUTE
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-ON
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX1
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-AUX2
              vis.js:3167 Create inner vis object broadlink2.0.RM:Broadlink-RMPROPLUS-e7-eb-47.L.TV-RENKFORCEBOX-BLUET
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.connected
              vis.js:3167 Create inner vis object system.adapter.web.0.connected
              vis.js:3167 Create inner vis object system.adapter.upnp.0.connected
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.connected
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.connected
              vis.js:3167 Create inner vis object system.adapter.socketio.0.alive
              vis.js:3167 Create inner vis object system.adapter.socketio.0.connected
              vis.js:3167 Create inner vis object system.adapter.snmp.0.connected
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.connected
              vis.js:3167 Create inner vis object system.adapter.scenes.0.connected
              vis.js:3167 Create inner vis object system.adapter.ping.0.connected
              vis.js:3167 Create inner vis object system.adapter.node-red.0.connected
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.connected
              vis.js:3167 Create inner vis object system.adapter.meross.0.connected
              vis.js:3167 Create inner vis object kodi.0.info.connection
              vis.js:3167 Create inner vis object system.adapter.javascript.0.alive
              vis.js:3167 Create inner vis object system.adapter.javascript.0.connected
              vis.js:3167 Create inner vis object system.adapter.iot.0.connected
              vis.js:3167 Create inner vis object system.adapter.info.0.connected
              vis.js:3167 Create inner vis object system.adapter.ical.2.alive
              vis.js:3167 Create inner vis object system.adapter.ical.1.alive
              vis.js:3167 Create inner vis object system.adapter.ical.0.alive
              vis.js:3167 Create inner vis object system.adapter.hs100.0.connected
              vis.js:3167 Create inner vis object hm-rpc.1.info.connection
              vis.js:3167 Create inner vis object hm-rpc.0.info.connection
              vis.js:3167 Create inner vis object hm-rega.0.info.connection
              vis.js:3167 Create inner vis object system.adapter.history.0.connected
              vis.js:3167 Create inner vis object system.adapter.firetv.0.connected
              vis.js:3167 Create inner vis object system.adapter.email.0.connected
              vis.js:3167 Create inner vis object system.adapter.daswetter.0.alive
              vis.js:3167 Create inner vis object cloud.0.info.connection
              vis.js:3167 Create inner vis object system.adapter.backitup.0.connected
              vis.js:3167 Create inner vis object alexa2.0.info.connection
              vis.js:3167 Create inner vis object system.adapter.admin.0.alive
              vis.js:3167 Create inner vis object system.adapter.admin.0.connected
              vis.js:3167 Create inner vis object admin.0.info.lastUpdateCheck
              vis.js:3167 Create inner vis object system.adapter.iogo.0.connected
              vis.js:3167 Create inner vis object system.host.Medion(Test).alive
              vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.admin.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.admin.0.memRss
              vis.js:3167 Create inner vis object system.adapter.javascript.0.memRss
              vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.javascript.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.javascript.0.uptime
              vis.js:3167 Create inner vis object system.adapter.socketio.0.memRss
              vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.socketio.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.socketio.0.uptime
              vis.js:3167 Create inner vis object system.adapter.web.0.alive
              vis.js:3167 Create inner vis object system.adapter.web.0.memRss
              vis.js:3167 Create inner vis object system.adapter.web.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.web.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.web.0.uptime
              vis.js:3167 Create inner vis object system.adapter.history.0.alive
              vis.js:3167 Create inner vis object system.adapter.history.0.memRss
              vis.js:3167 Create inner vis object system.adapter.history.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.history.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.history.0.uptime
              vis.js:3167 Create inner vis object system.adapter.backitup.0.alive
              vis.js:3167 Create inner vis object system.adapter.backitup.0.memRss
              vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.backitup.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.backitup.0.uptime
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.alive
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.alive
              vis.js:3167 Create inner vis object system.adapter.hm-rega.0.alive
              vis.js:3167 Create inner vis object system.adapter.hm-rega.0.uptime
              vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.hm-rega.0.memRss
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memRss
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.0.uptime
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memRss
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.hm-rpc.1.uptime
              vis.js:3167 Create inner vis object system.adapter.ical.0.memRss
              vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.ical.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.ical.0.uptime
              vis.js:3167 Create inner vis object system.adapter.ical.1.memRss
              vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.ical.1.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.ical.1.uptime
              vis.js:3167 Create inner vis object system.adapter.ical.2.memRss
              vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.ical.2.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.ical.2.uptime
              vis.js:3167 Create inner vis object system.adapter.iot.0.alive
              vis.js:3167 Create inner vis object system.adapter.cloud.0.alive
              vis.js:3167 Create inner vis object system.adapter.alexa2.0.alive
              vis.js:3167 Create inner vis object system.adapter.alexa2.0.uptime
              vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.alexa2.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.alexa2.0.memRss
              vis.js:3167 Create inner vis object system.adapter.cloud.0.memRss
              vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.cloud.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.cloud.0.uptime
              vis.js:3167 Create inner vis object system.adapter.iot.0.memRss
              vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.iot.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.iot.0.uptime
              vis.js:3167 Create inner vis object system.adapter.ping.0.alive
              vis.js:3167 Create inner vis object system.adapter.ping.0.memRss
              vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.ping.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.ping.0.uptime
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.alive
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.memRss
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.simple-api.0.uptime
              vis.js:3167 Create inner vis object system.host.Medion(Test).memRss
              vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapUsed
              vis.js:3167 Create inner vis object system.host.Medion(Test).memHeapTotal
              vis.js:3167 Create inner vis object system.host.Medion(Test).uptime
              vis.js:3167 Create inner vis object system.adapter.iogo.0.alive
              vis.js:3167 Create inner vis object system.adapter.email.0.alive
              vis.js:3167 Create inner vis object system.adapter.info.0.alive
              vis.js:3167 Create inner vis object system.adapter.info.0.uptime
              vis.js:3167 Create inner vis object system.adapter.info.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.info.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.info.0.memRss
              vis.js:3167 Create inner vis object system.adapter.email.0.memRss
              vis.js:3167 Create inner vis object system.adapter.email.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.email.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.email.0.uptime
              vis.js:3167 Create inner vis object system.adapter.iogo.0.memRss
              vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.iogo.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.iogo.0.uptime
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.alive
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.memRss
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.yamaha.0.uptime
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.alive
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.memRss
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.musiccast.0.uptime
              vis.js:3167 Create inner vis object system.adapter.upnp.0.alive
              vis.js:3167 Create inner vis object system.adapter.upnp.0.memRss
              vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.upnp.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.upnp.0.uptime
              vis.js:3167 Create inner vis object system.adapter.firetv.0.alive
              vis.js:3167 Create inner vis object system.adapter.kodi.0.alive
              vis.js:3167 Create inner vis object system.adapter.kodi.0.uptime
              vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.kodi.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.kodi.0.memRss
              vis.js:3167 Create inner vis object system.adapter.firetv.1.memRss
              vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.firetv.1.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.firetv.1.uptime
              vis.js:3167 Create inner vis object system.adapter.daswetter.0.memRss
              vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.daswetter.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.daswetter.0.uptime
              vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.alive
              vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memRss
              vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.weatherunderground.0.uptime
              vis.js:3167 Create inner vis object system.adapter.snmp.0.alive
              vis.js:3167 Create inner vis object system.adapter.snmp.0.memRss
              vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.snmp.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.snmp.0.uptime
              vis.js:3167 Create inner vis object system.adapter.scenes.0.alive
              vis.js:3167 Create inner vis object system.adapter.scenes.0.memRss
              vis.js:3167 Create inner vis object system.adapter.scenes.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.scenes.0.uptime
              vis.js:3167 Create inner vis object system.adapter.hs100.0.alive
              vis.js:3167 Create inner vis object system.adapter.meross.0.alive
              vis.js:3167 Create inner vis object system.adapter.node-red.0.alive
              vis.js:3167 Create inner vis object system.adapter.node-red.0.uptime
              vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.node-red.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.node-red.0.memRss
              vis.js:3167 Create inner vis object system.adapter.meross.0.memRss
              vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.meross.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.meross.0.uptime
              vis.js:3167 Create inner vis object system.adapter.hs100.0.memRss
              vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.hs100.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.hs100.0.uptime
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.alive
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memRss
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.sourceanalytix.1.uptime
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.alive
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memRss
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.tr-064-community.0.uptime
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.alive
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memRss
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapUsed
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.memHeapTotal
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.uptime
              vis.js:3167 Create inner vis object system.adapter.iqontrol.0.connected
              vis.js:3167 Create inner vis object controll-own.0._MenuVisView8-BACK
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestHTMLAuswahlDelete
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuAlarm
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anlegen
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDelete
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteWerte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.AuswahlDeleteTexte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.ALEXAEinkauf
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anlegen
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDelete
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteWerte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.AuswahlDeleteTexte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.Anzahl
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.Anzahl
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.Einkauf.DeleteALL
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.ALEXALists.ToDo.DeleteALL
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.SONOFF
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AKKU
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.ENERGY
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AkkuMeessage
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.TabellenFlexible
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.BackItUp
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AlexaSmartDevices
              vis.js:3167 Create inner vis object controll-own.0.TABELLEN.AnzahlSonoff
              vis.js:3167 Create inner vis object 0_userdata.0.Akkuskript.VISTabelle
              vis.js:3167 Create inner vis object sonoff.0.SonoffPow1.ENERGY_Total
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.TVProgramm
              vis.js:3167 Create inner vis object system.adapter.systeminfo.0.connected
              vis.js:3167 Create inner vis object javascript.0.Park.StringHTML
              vis.js:3167 Create inner vis object javascript.0.Netzwerk.StringHTML
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Title
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Event
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.FileName
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Summary
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Thumb
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Change
              vis.js:3167 Create inner vis object javascript.0.PlexMonitor.PlexVis.Player
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyWLAN
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Pause
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Anzahl
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSController
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_DeleteVIS
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CodeList2
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRootGuest
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_Delete_Voucher.Delete
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Info
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateStandard
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_CreateListStandard
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Create
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.WLAN_DragonRoot1
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Dauer
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Anzahl
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.MultiUse
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Mb_Begrenzung
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Download
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Upload
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers-CODES.A_New_Voucher.Notiz
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.SiteLED
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Alarm.Alarm_Anzahl
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Clients_Log
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.xxxScriptVersionxxx
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Missing_Name
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.ZyklusZaehler
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Client_WhiteList
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_ClientsOnlyDISC
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_RX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferBefore.Before_Uplink_TX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_RX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferMonth.Month_Uplink_TX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_RX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.WAN1TransferDaily.Uplink_TX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.Galaxy-S9
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.GalaxyTabS2
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.GalaxyTabS2
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.Galaxy-S9
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.MediaTabT5
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_States.FireTablet7
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.FireTablet7
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Client_Network.TrekStor13
              vis.js:3167 Create inner vis object javascript.0.VoucherKinder.LastSend
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Satisfaction
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Model
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.Adopted
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.IP_Adresse
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-LongR.ToController
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Satisfaction
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Model
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.Adopted
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.IP_Adresse
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.APInfo.AP-Light.ToController
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.AliasName
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUbyJSAdapter
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.CPUIdleALL
              vis.js:3167 Create inner vis object system.adapter.enigma2.0.connected
              vis.js:3167 Create inner vis object system.adapter.lgtv.0.connected
              vis.js:3167 Create inner vis object system.adapter.amazon-dash.0.connected
              vis.js:3167 Create inner vis object system.adapter.plex.0.connected
              vis.js:3167 Create inner vis object system.adapter.pi-hole.0.connected
              vis.js:3167 Create inner vis object system.adapter.mpd.0.connected
              vis.js:3167 Create inner vis object system.adapter.mihome.0.connected
              vis.js:3167 Create inner vis object system.adapter.sayit.0.connected
              vis.js:3167 Create inner vis object system.adapter.fritzdect.0.connected
              vis.js:3167 Create inner vis object system.adapter.fritzdect.1.connected
              vis.js:3167 Create inner vis object system.adapter.proxmox.0.connected
              vis.js:3167 Create inner vis object system.adapter.unifi.0.connected
              vis.js:3167 Create inner vis object system.adapter.fullybrowser.0.connected
              vis.js:3167 Create inner vis object system.adapter.mclighting.0.connected
              vis.js:3167 Create inner vis object system.adapter.sonoff.0.connected
              vis.js:3167 Create inner vis object system.adapter.pushbullet.0.connected
              vis.js:3167 Create inner vis object system.adapter.sql.0.connected
              vis.js:3167 Create inner vis object system.adapter.pushbullet.1.connected
              vis.js:3167 Create inner vis object javascript.0.Ereignisliste.heute.eventlistHTML
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapTable
              vis.js:3167 Create inner vis object controll-own.0.FUTRO.DevicesIP
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.DiskTable
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.HightCpuProcess
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.NFSExports
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.SwapAlarm
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.MemoryAlarm
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessJetzt
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.GetProcessFilter
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.ProcessTable
              vis.js:3167 Create inner vis object javascript.0.GETPROCESS.AlarmCPURunLevel
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootSQLTulla
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootProxmox
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPlexServer
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskhelpRootPiHole
              vis.js:3167 Create inner vis object controll-own.0.mount.DiskHelpRootFileserver
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Update
              vis.js:3167 Create inner vis object hm-rpc.0.IEQ0007259.1.STATE
              vis.js:3167 Create inner vis object hm-rpc.0.KEQ0193137.1.STATE
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Temperatur_Farbe
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.aktiv_parse
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Load
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Farbe.Speicher
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.aktiv_parse
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Speicher
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Interface
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.FTL
              vis.js:3167 Create inner vis object javascript.2.scriptEnabled.common.VIS.VIS_Pihole_Info
              vis.js:3167 Create inner vis object javascript.2.Pi-hole.Version.Pihole
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.TimerResetVIS
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Minuten
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Minuten
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.SummeMinuten2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Sekunden
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Name2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Finished
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer2.Gerät2
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Gerät1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.SummeMinuten1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Finished
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Name1
              vis.js:3167 Create inner vis object javascript.0.ALEXATimer2.Timer1.Sekunden
              vis.js:3167 Create inner vis object controll-own.0.AAATEST.TestZahlPx
              vis.js:3167 Create inner vis object javascript.0.logik.gästebadLicht.bewegungGästebad
              vis.js:3167 Create inner vis object javascript.2.WLANUnifi.Wifi_Vouchers_Anzahl
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_RX
              vis.js:3167 Create inner vis object javascript.2.WLANUnifiHelp.Midnight_Uplink_TX
              vis.js:3167 Create inner vis object system.adapter.tr-064.1.connected
              vis.js:3167 Create inner vis object system.adapter.tr-064.0.connected
              vis.js:3167 Create inner vis object snmp.1.info.connection
              vis.js:3167 Create inner vis object system.adapter.snmp.1.alive
              vis.js:3167 Create inner vis object snmp.0.info.connection
              vis.js:3167 Create inner vis object system.adapter.rpi2.0.connected
              vis.js:3167 Create inner vis object system.adapter.radar.0.connected
              vis.js:3167 Create inner vis object system.adapter.pushover.0.connected
              vis.js:3167 Create inner vis object system.adapter.paw.0.connected
              vis.js:3167 Create inner vis object system.adapter.paw.0.alive
              vis.js:3167 Create inner vis object mihome-vacuum.0.info.connection
              vis.js:3167 Create inner vis object mihome.0.devices.gateway_7c49eb88c200.connected
              vis.js:3167 Create inner vis object system.adapter.pushbullet.1.alive
              vis.js:3167 Create inner vis object fritzbox.0.system.deltaTimeOK
              vis.js:3167 Create inner vis object javascript.0.Log-Script.logProtokol.logJSON
              vis.js:3167 Create inner vis object javascript.0.Log-Script.logAlexaueberwachung.clearJSON
              vis.js:3167 Create inner vis object javascript.1.mylog.logAllJSON
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.volume
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1072270E5V.Player.currentArtist
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.volume
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.ALLradioALL
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.7dbdc61535fd4214b45ee26d40f00370.Player.currentArtist
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.1cddc50c95b244728175d6427e0fe4a8.Player.currentArtist
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.volume
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioKueche
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090VC09917519BE.Player.currentArtist
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioEchoPlus
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.volume
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentArtist
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.providerId
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090NV03742503T0.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF1071860WED.Player.currentTitle
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.volume
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.RadioFlur
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090LF11742316CP.Player.currentArtist
              vis.js:3167 Create inner vis object controll-own.0.RADIOs.EchoShow5Radio
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.volume
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentArtist
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentState
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G0911B0592830RM7.Player.currentTitle
              vis.js:3167 Create inner vis object alexa2.0.Echo-Devices.G090SU0275070FD6.Player.providerId
              vis.js:3167 Create inner vis object trashschedule.0.type.KrankSchreibung.daysleft
              vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT
              vis.js:3167 Create inner vis object controll-own.0.MOTION.StandortALT2
              vis.js:3167 Create inner vis object ping.0.iobroker59.www_google_com
              vis.js:3167 Create inner vis object ping.0.raspberry3.www_google_com
              vis.js:3167 Create inner vis object controll-own.0.mount.CPUTemp
              vis.js:3167 Create inner vis object javascript.0.CountdownPapierTonne.Termin.Rest.Tage
              vis.js:3167 Create inner vis object javascript.0.Speed-Test.data.speeds.download
              vis.js:3167 Create inner vis object tcontroll-own.0.Banane
              vis.js:3167 Create inner vis object trashschedule.1.type.Gelber Sack.daysleft
              vis.js:3167 Create inner vis object trashschedule.1.type.Biomüll.daysleft
              vis.js:3167 Create inner vis object trashschedule.1.type.Restmüll.daysleft
              vis.js:3167 Create inner vis object trashschedule.1.type.Papiertonne.daysleft
              vis.js:3167 Create inner vis object javascript.0.Log-Script.Loganzeige
              vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.download_Mb
              vis.js:3167 Create inner vis object web-speedy.0.Results.speeds.upload_Mb
              vis.js:3167 Create inner vis object trashschedule.0.type.json
              vis.js:3167 Create inner vis object javascript.0.wled.farbe
              vis.js:3167 Create inner vis object javascript.0.wled.effekt
              vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.sx
              vis.js:3167 Create inner vis object wled.0.a020a61bbd2c.seg.0.ix
              vis.js:3167 Create inner vis object javascript.0.wled.brightness
              vis.js:3167 Create inner vis object javascript.0.wled.toggle
              vis.js:3167 Create inner vis object javascript.0.wled.palette
              vis.js:3167 Create inner vis object javascript.0.wled.preset
              vis.js:3167 Create inner vis object javascript.0.RSS-Feed.Bild.Alarm
              vis.js:3167 Create inner vis object calendar.0.YXJtaW4uc2xpdmluc2t5QGdtYWlsLm
              vis.js:3167 Create inner vis object calendar.0.YWRkcmVzc2Jvb2sjY29udGFjdHNAZ3
              vis.js:3167 Create inner vis object calendar.0.ZGUuZ2VybWFuI2hvbGlkYXlAZ3JvdX
              vis.js:3167 Create inner vis object calendar.0.cCN3ZWF0aGVyQGdyb3VwLnYuY2FsZW
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.DeleteALL
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anzahl
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDelete
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteWerte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.AuswahlDeleteTexte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.Anlegen
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.Einkauf.ALEXAEinkauf
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.targettemp
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.targettemp
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.targettemp
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950281871.actualtemp
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950280789.actualtemp
              vis.js:3167 Create inner vis object fritzdect.2.Comet_099950284772.actualtemp
              vis.js:3167 Create inner vis object controll-own.0.HILDE.SQLHilde
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.ALEXAToDo
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anlegen
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDelete
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteWerte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.AuswahlDeleteTexte
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.DeleteALL
              vis.js:3167 Create inner vis object javascript.0.Alexa_Listen.Hilde.ALEXALists.ToDo.Anzahl
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Mail
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Fax
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Telefon
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Adresse
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Lieferant.Name
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Datum
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Änderung zum Vortag
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Allgemein.Trend zum Vortag
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettopreis Gesamt
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Nettozuschlag Gesamt
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.MwSt Gesamt
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Gesamt.Bruttopreis Gesamt
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettopreis 100l
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.Nettozuschlag 100l
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Heizölpreis.Wohnort.Je 100L.MwSt 100l
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Entladestellen
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Heizölsorte ID
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Zahlungsart ID
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Lieferort
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Bestelldaten.Liefermenge
              vis.js:3167 Create inner vis object javascript.0.Heizoel.Skriptstart
              :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://www.zeitverschiebung.net/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
              :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://zeitverschiebung.net/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
              DevTools failed to parse SourceMap: chrome-extension://iemadiahhbebdklepanmkjenfdebfpfe/static/js/main.6e6198ed.js.map
              hqwidgets.js:902 Version vis-hqwidgets: 1.1.4
              bars.js:55 Version vis-bars:0.1.4
              undefined:1 GET http://192.168.178.59:8072/vis/undefined 404 (Not Found)
              Image (async)
              l @ can.custom.min.js:20
              e.buildFragment @ can.custom.min.js:20
              n.frag @ can.custom.min.js:14
              fragment @ can.custom.min.js:58
              frag @ can.custom.min.js:58
              r @ can.custom.min.js:58
              renderTo @ can.custom.min.js:58
              renderAs @ can.custom.min.js:58
              e.view.e.template @ can.custom.min.js:58
              renderWidget @ vis.js:1610
              (anonymous) @ vis.js:887
              (anonymous) @ vis.js:2742
              (anonymous) @ conn.js:730
              r.onack @ index.js:83
              r.onpacket @ index.js:83
              (anonymous) @ index.js:83
              r.emit @ index.js:83
              r.ondecoded @ index.js:83
              a.add @ index.js:83
              r.ondata @ index.js:83
              r.onPacket @ index.js:83
              r.onData @ index.js:83
              ws.onmessage @ index.js:83
              VM19719:1 Uncaught SyntaxError: Unexpected token u in JSON at position 0
                 at JSON.parse (<anonymous>)
                 at Object.redraw (trashschedule.js:170)
                 at Object.createWidget (trashschedule.js:36)
                 at trashschedule.js:31
              redraw @ trashschedule.js:170
              createWidget @ trashschedule.js:36
              (anonymous) @ trashschedule.js:31
              setTimeout (async)
              createWidget @ trashschedule.js:30
              eval @ tplTrashscheduleHelper.js:24
              n.render @ can.custom.min.js:76
              t.template.fn @ can.custom.min.js:76
              subscribeStates @ vis.js:2745
              renderView @ vis.js:799
              renderViews @ vis.js:761
              (anonymous) @ vis.js:917
              a.add @ index.js:83
              Show 6 more frames
              widgets.min.js:3 [Line History Chart w02261] widget setting: {"_data":{"wid":"w02261","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"0","visibility-groups-action":"hide","dataCount":"0","aggregate":"average","timeIntervalToShow":"8 hours","refreshMethod":"realtime","refreshTimeInterval":"5 minutes","pointStyle":"line","showLegend":true,"legendPosition":"right","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"true","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.0","oid0":"sonoff.0.Sonoff15.AM2301_Temperature","visibility-oid":"controll-own.0.TV","legendFontColor":"#13f138","dataColor0":"#13f138","xAxisValueLabelColor":"#13f138","yAxisValueLabelColor":"#7bf990","xAxisMaxLabel":"5","yAxisMinValue0":"0","yAxisMaxValue0":"30","yAxisValueMinDigits0":"0","yAxisMaxLabel0":"","lineTension0":"0","lineThikness0":"1","xAxisTitleFontSize":"8","xAxisOffsetGridLines":false,"pointSize":"20","yAxisStep0":"5","yAxisZeroLineWidth0":"","chartPaddingBottom":"10","mdwDebug":true},"_cid":".map9063","_computedAttrs":{},"wid":"w02261","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"0","visibility-groups-action":"hide","dataCount":"0","aggregate":"average","timeIntervalToShow":"8 hours","refreshMethod":"realtime","refreshTimeInterval":"5 minutes","pointStyle":"line","showLegend":true,"legendPosition":"right","legendPointStyle":"true","showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":true,"xAxisMinRotation":"0","xAxisMaxRotation":"0","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"end","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":"true","valuesPositionAnchor1":"end","valuesPositionAlign1":"top","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"sql.0","oid0":"sonoff.0.Sonoff15.AM2301_Temperature","visibility-oid":"controll-own.0.TV","legendFontColor":"#13f138","dataColor0":"#13f138","xAxisValueLabelColor":"#13f138","yAxisValueLabelColor":"#7bf990","xAxisMaxLabel":"5","yAxisMinValue0":"0","yAxisMaxValue0":"30","yAxisValueMinDigits0":"0","yAxisMaxLabel0":"","lineTension0":"0","lineThikness0":"1","xAxisTitleFontSize":"8","xAxisOffsetGridLines":false,"pointSize":"20","yAxisStep0":"5","yAxisZeroLineWidth0":"","chartPaddingBottom":"10","mdwDebug":true,"_bubbleBindings":{},"__bindEvents":{"class":[{"name":"class"}],"backgroundColor":[{"name":"backgroundColor"}],"wid":[{"name":"wid"}]},"_bindings":3}
              widgets.min.js:4 [getTaskForHistoryData w02261] history options for 'sonoff.0.Sonoff15.AM2301_Temperature': {"instance":"sql.0","count":100,"aggregate":"average","start":1586062096052,"end":1586090896053,"timeout":2000}
              widgets.min.js:4 [getTaskForHistoryData w02261] history data result 'sonoff.0.Sonoff15.AM2301_Temperature' length: 69
              widgets.min.js:4 [getTaskForHistoryData w02261] history data result 'sonoff.0.Sonoff15.AM2301_Temperature': [{"ts":1586062096052,"val":null},{"ts":1586068576052,"val":null},{"ts":1586071168052,"val":9.1},{"ts":1586071456052,"val":9.15},{"ts":1586071744052,"val":9.27},{"ts":1586072032052,"val":9.45},{"ts":1586072320052,"val":9.55},{"ts":1586072608052,"val":9.65},{"ts":1586072896052,"val":9.75},{"ts":1586073184052,"val":9.9},{"ts":1586073472052,"val":10.05},{"ts":1586073760052,"val":10.2},{"ts":1586074048052,"val":10.3},{"ts":1586074336052,"val":10.43},{"ts":1586074624052,"val":10.57},{"ts":1586074912052,"val":10.75},{"ts":1586075200052,"val":10.9},{"ts":1586075488052,"val":11},{"ts":1586075776052,"val":11.25},{"ts":1586076064052,"val":11.63},{"ts":1586076352052,"val":11.93},{"ts":1586076640053,"val":12.13},{"ts":1586076928053,"val":12.3},{"ts":1586077216053,"val":12.45},{"ts":1586077504053,"val":12.5},{"ts":1586077792053,"val":12.65},{"ts":1586078080053,"val":12.85},{"ts":1586078368053,"val":13.2},{"ts":1586078656053,"val":13.17},{"ts":1586078944053,"val":13.05},{"ts":1586079232053,"val":13.13},{"ts":1586079520053,"val":13.4},{"ts":1586079808053,"val":13.63},{"ts":1586080096053,"val":13.83},{"ts":1586080384053,"val":13.9},{"ts":1586080672053,"val":13.97},{"ts":1586080960053,"val":14.1},{"ts":1586081248053,"val":14.23},{"ts":1586081536053,"val":14.3},{"ts":1586081824053,"val":14.43},{"ts":1586082112053,"val":14.55},{"ts":1586082400053,"val":14.6},{"ts":1586082688053,"val":14.7},{"ts":1586082976053,"val":14.8},{"ts":1586083264053,"val":14.85},{"ts":1586083840053,"val":14.97},{"ts":1586084128053,"val":15.13},{"ts":1586084416053,"val":15.13},{"ts":1586084704053,"val":null},{"ts":1586084992053,"val":null},{"ts":1586085280053,"val":14.97},{"ts":1586085568053,"val":14.97},{"ts":1586085856053,"val":15.13},{"ts":1586086144053,"val":15.23},{"ts":1586086432053,"val":15.23},{"ts":1586086720053,"val":null},{"ts":1586087008053,"val":null},{"ts":1586087296053,"val":15.65},{"ts":1586087584053,"val":15.8},{"ts":1586087872053,"val":15.67},{"ts":1586088160053,"val":15.65},{"ts":1586088448053,"val":15.75},{"ts":1586088736053,"val":15.87},{"ts":1586089024053,"val":16},{"ts":1586089312053,"val":16.2},{"ts":1586089600053,"val":16.3},{"ts":1586089888053,"val":16.37},{"ts":1586090464053,"val":16.35},{"ts":1586090752053,"val":16.5}]
              widgets.min.js:3 [Line History Chart w02261] promise all datasets - count: 1
              widgets.min.js:4 [getPreparedData w02261] prepare data for 'sonoff.0.Sonoff15.AM2301_Temperature' length: 69
              widgets.min.js:3 [Line History Chart w02261] prepare dataset for 'sonoff.0.Sonoff15.AM2301_Temperature'
              widgets.min.js:3 [Line History Chart w02261] prepare yAxis for 'sonoff.0.Sonoff15.AM2301_Temperature'
              widgets.min.js:3 [Line History Chart w02261] prepare chart options
              widgets.min.js:3 [Line History Chart w02261] chart creating...
              widgets.min.js:3 [Line History Chart w02261] chart successful created
              :8072/vis/index.html?galaxy#99Whatsapp:1 A cookie associated with a cross-site resource at http://www.tagesschau.de/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032.
                sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
                @Scrounger sagte in Test Adapter Material Design Widgets v0.2.x:
                Also das log sieht gut aus. Was hast du denn noch für fehler?
                Jetzt keine mehr! 👍
                • Scrounger
                  Scrounger Developer @liv-in-sky last edited by
                  @liv-in-sky sagte in Test Adapter Material Design Widgets v0.2.x:
                  und noch ein log - mit funktionierendem widget
                  @sigi234 sagte in Test Adapter Material Design Widgets v0.2.x:
                  Jetzt keine mehr! 👍
                  Perfekt, obwohl ich echt verwundert bin, dann war der meiner Meinung nach Schönheitsfehler im Code wohl die Ursache.
                  Dann lad ich es heute abend mal ins latest.
                    liv-in-sky @Scrounger last edited by
                    @Scrounger wenn du gerne fehler suchst, probier mal den brave browser aus, ob es bei dir funktioniert 🙂 weder runtime noch editor zeigen es unter brave bei mir an (vielleicht stört auch irgendeine erweiterung?)
                    firefox und opera zeigen es bei mir an - auch fully browser auf android und auch - verwunderung - brave mit android funktioniert
                    • Scrounger
                      ne eigentlich nicht, aber druck wurde zu groß den Fehler endlich mal für euch zu beheben 😁
                      • Chris Tailor
                        Chris Tailor @Scrounger last edited by Chris Tailor
                        @Scrounger Besten Dank
                        Hier das Console Log:
                        [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
                        index.html?smarthub:3408 Version vis-canvas-gauges: 0.1.5
                        index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
                        index.html?smarthub:5374 Version vis-history: 1.0.0
                        info.js:9 Version Info-Adapter-Widget: 0.0.8
                        keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
                        index.html?smarthub:8340 Version vis-map: 1.0.3
                        DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
                        materialdesign.js:25 Version vis-materialdesign: 0.2.77
                        lib.min.js:22 Download the Vue Devtools extension for a better development experience:
                        https://github.com/vuejs/vue-devtools
                        lib.min.js:22 You are running Vue in development mode.
                        Make sure to turn on production mode when deploying for production.
                        See more tips at https://vuejs.org/guide/deployment.html
                        players.js:58 Version players: 0.1.0
                        conn.js:273 2020-04-06T04:26:34.511Z Connected => authenticate
                        conn.js:293 2020-04-06T04:26:35.096Z Authenticated: true
                        vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
                        vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
                        vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
                        vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
                        widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
                        2widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                        (anonymous) @ widgets.min.js:4
                        (anonymous) @ conn.js:1299
                        setTimeout (async)
                        getHistory @ conn.js:1297
                        getHistory @ vis.js:2613
                        getTaskForHistoryData @ widgets.min.js:4
                        (anonymous) @ widgets.min.js:3
                        setTimeout (async)
                        lineHistory @ widgets.min.js:3
                        eval @ tplVis-materialdesign-Chart-Line-History.js:31
                        (anonymous) @ can.custom.min.js:64
                        a.each @ can.custom.min.js:24
                        (anonymous) @ can.custom.min.js:58
                        hookup @ can.custom.min.js:58
                        a.add @ index.js:83
                        Show 11 more frames
                        widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 206
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585887997544,"val":18.78092805428227},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893179325,"val":197},{"ts":1585893184213,"val":196},{"ts":1585893204300,"val":193},{"ts":1585895684283,"val":501},{"ts":1585895769586,"val":470},{"ts":1585895774610,"val":480},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898364970,"val":628},{"ts":1585898369993,"val":625},{"ts":1585899575029,"val":530},{"ts":1585900945395,"val":987},{"ts":1585900960455,"val":983},{"ts":1585900965472,"val":981},{"ts":1585903529618,"val":2184},{"ts":1585903544678,"val":2184},{"ts":1585903549706,"val":2183},{"ts":1585903554752,"val":2180},{"ts":1585906116541,"val":3555},{"ts":1585906136652,"val":3515},{"ts":1585906141680,"val":3540},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908728849,"val":4926},{"ts":1585908733864,"val":4919},{"ts":1585908759022,"val":4910},{"ts":1585911325479,"val":5853},{"ts":1585911330492,"val":5854},{"ts":1585913902754,"val":6600},{"ts":1585913912811,"val":6594},{"ts":1585913917834,"val":6598},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916504542,"val":6936},{"ts":1585916509571,"val":6935},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919096685,"val":7003},{"ts":1585919101696,"val":7009},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921693478,"val":7030},{"ts":1585921698473,"val":7042},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924285138,"val":6735},{"ts":1585924290151,"val":6729},{"ts":1585926786616,"val":1903},{"ts":1585926877036,"val":6047},{"ts":1585926882051,"val":6151},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929469104,"val":5025},{"ts":1585929474125,"val":5006},{"ts":1585932061362,"val":3015},{"ts":1585932066391,"val":2988},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978717233,"val":108},{"ts":1585978722256,"val":115},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981308947,"val":372},{"ts":1585981313960,"val":371},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983895732,"val":524},{"ts":1585983905765,"val":517},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986496435,"val":716},{"ts":1585987214177,"val":0},{"ts":1585989081857,"val":1792},{"ts":1585989086736,"val":1795},{"ts":1585989192086,"val":1778},{"ts":1585991677443,"val":3044},{"ts":1585991682461,"val":3048},{"ts":1585992038901,"val":2880},{"ts":1585994168050,"val":4469},{"ts":1585994268477,"val":4409},{"ts":1585994273492,"val":4456},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996860023,"val":5554},{"ts":1585996865046,"val":5538},{"ts":1585996875086,"val":5534},{"ts":1585999380974,"val":6507},{"ts":1585999451346,"val":6472},{"ts":1585999456354,"val":6473},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002043171,"val":6943},{"ts":1586002048187,"val":6945},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004634898,"val":6903},{"ts":1586004639938,"val":6915},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007226658,"val":7050},{"ts":1586007231700,"val":7044},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014992383,"val":5230},{"ts":1586015002414,"val":5237},{"ts":1586015007423,"val":5240},{"ts":1586017407825,"val":3634},{"ts":1586017588648,"val":3764},{"ts":1586017598695,"val":3752},{"ts":1586020169540,"val":2077},{"ts":1586020184597,"val":2080},{"ts":1586020189630,"val":2083},{"ts":1586022746179,"val":79},{"ts":1586022781371,"val":92},{"ts":1586022786410,"val":73},{"ts":1586022796454,"val":82},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064248282,"val":70},{"ts":1586064263341,"val":75},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066853766,"val":270},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069434376,"val":426},{"ts":1586069439382,"val":419},{"ts":1586071758748,"val":563},{"ts":1586071834103,"val":217},{"ts":1586072024984,"val":529},{"ts":1586072029999,"val":535},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077213157,"val":2592},{"ts":1586077218168,"val":2617},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079803897,"val":4013},{"ts":1586079813939,"val":4001},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082394850,"val":5307},{"ts":1586082399863,"val":5284},{"ts":1586082414917,"val":5281},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092763104,"val":7006},{"ts":1586092768120,"val":7000},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103128895,"val":4612},{"ts":1586103133838,"val":4604},{"ts":1586105724162,"val":3028},{"ts":1586105729185,"val":3041},{"ts":1586108073752,"val":1070},{"ts":1586108314620,"val":1101},{"ts":1586108319639,"val":1093},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147197607,"val":0}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 400
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585887997544,"val":993.6004784688995},{"ts":1585887998966,"val":1052},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890588960,"val":1880},{"ts":1585890593982,"val":1100},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893179325,"val":5325},{"ts":1585893184213,"val":5261},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895769586,"val":1444},{"ts":1585895774610,"val":1215},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898364970,"val":1484},{"ts":1585898369994,"val":1404},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900955432,"val":927},{"ts":1585900960455,"val":2207},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903544678,"val":629},{"ts":1585903549706,"val":714},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906136652,"val":1138},{"ts":1585906141684,"val":1360},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908728849,"val":1621},{"ts":1585908733864,"val":2118},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911325479,"val":1476},{"ts":1585911330492,"val":1477},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913912811,"val":1586},{"ts":1585913917834,"val":1579},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916504542,"val":1860},{"ts":1585916509571,"val":1722},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919096685,"val":1601},{"ts":1585919101696,"val":1659},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921693480,"val":1549},{"ts":1585921698473,"val":1578},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924285139,"val":1187},{"ts":1585924290152,"val":1151},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926877036,"val":2139},{"ts":1585926882051,"val":1020},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929464105,"val":883},{"ts":1585929474128,"val":879},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932061362,"val":6360},{"ts":1585932066391,"val":6159},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939834459,"val":3982},{"ts":1585939839473,"val":3983},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947609823,"val":1346},{"ts":1585947614761,"val":1849},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950202718,"val":2590},{"ts":1585950207734,"val":1615},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963164598,"val":447},{"ts":1585963169613,"val":445},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968345560,"val":450},{"ts":1585968350578,"val":445},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970941015,"val":387},{"ts":1585970945780,"val":386},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973531270,"val":994},{"ts":1585973541299,"val":988},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976121590,"val":974},{"ts":1585976126607,"val":978},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978717233,"val":964},{"ts":1585978722256,"val":958},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981308947,"val":381},{"ts":1585981313960,"val":378},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983900745,"val":1609},{"ts":1585983905765,"val":470},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986491415,"val":1012},{"ts":1585986496435,"val":999},{"ts":1585986511507,"val":935},{"ts":158598896
                        widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                        widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 day
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586060815542,"val":19.947579455043893},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063364835,"val":36},{"ts":1586063389936,"val":36},{"ts":1586063425053,"val":34},{"ts":1586063997372,"val":84},{"ts":1586064268379,"val":79},{"ts":1586064273399,"val":74},{"ts":1586064393948,"val":59},{"ts":1586065131806,"val":145},{"ts":1586065136832,"val":146},{"ts":1586065217180,"val":102},{"ts":1586065925107,"val":196},{"ts":1586065995424,"val":191},{"ts":1586066000439,"val":192},{"ts":1586066035563,"val":185},{"ts":1586066843732,"val":276},{"ts":1586066858788,"val":274},{"ts":1586066863801,"val":268},{"ts":1586067637051,"val":386},{"ts":1586067727427,"val":375},{"ts":1586067732438,"val":359},{"ts":1586068209595,"val":155},{"ts":1586068540859,"val":411},{"ts":1586068591055,"val":389},{"ts":1586068596077,"val":390},{"ts":1586068917655,"val":373},{"ts":1586069384063,"val":433},{"ts":1586069454442,"val":425},{"ts":1586069459493,"val":419},{"ts":1586070197508,"val":390},{"ts":1586070222599,"val":479},{"ts":1586070312906,"val":443},{"ts":1586070322938,"val":450},{"ts":1586070338001,"val":414},{"ts":1586070920499,"val":548},{"ts":1586071181476,"val":478},{"ts":1586071186498,"val":510},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072045080,"val":520},{"ts":1586072050089,"val":563},{"ts":1586072245821,"val":475},{"ts":1586072532026,"val":654},{"ts":1586072908547,"val":584},{"ts":1586072913577,"val":583},{"ts":1586073069196,"val":559},{"ts":1586073757247,"val":920},{"ts":1586073772341,"val":887},{"ts":1586073777354,"val":927},{"ts":1586073787388,"val":904},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586076364579,"val":1965},{"ts":1586076369615,"val":2020},{"ts":1586076856750,"val":1835},{"ts":1586077203046,"val":2650},{"ts":1586077228206,"val":2629},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586078091881,"val":3081},{"ts":1586078101962,"val":3084},{"ts":1586078116969,"val":3062},{"ts":1586078945609,"val":3555},{"ts":1586078955641,"val":3554},{"ts":1586078960682,"val":3566},{"ts":1586078985780,"val":3543},{"ts":1586079738665,"val":4032},{"ts":1586079818990,"val":3981},{"ts":1586079824022,"val":4019},{"ts":1586079839106,"val":3956},{"ts":1586080672557,"val":4572},{"ts":1586080682581,"val":4547},{"ts":1586080687605,"val":4565},{"ts":1586080787954,"val":4544},{"ts":1586081546248,"val":5004},{"ts":1586081551945,"val":4996},{"ts":1586081566310,"val":4981},{"ts":1586082339629,"val":5323},{"ts":1586082414917,"val":5281},{"ts":1586082419935,"val":5300},{"ts":1586082450037,"val":5298},{"ts":1586083243231,"val":5693},{"ts":1586083278362,"val":5692},{"ts":1586083283382,"val":5695},{"ts":1586083358669,"val":5637},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088460725,"val":6857},{"ts":1586088465726,"val":6845},{"ts":1586088521072,"val":6910},{"ts":1586088757078,"val":6820},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586092637546,"val":7053},{"ts":1586092738000,"val":6989},{"ts":1586092783176,"val":7000},{"ts":1586092788193,"val":7001},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093646660,"val":7038},{"ts":1586093651731,"val":7015},{"ts":1586093681791,"val":7043},{"ts":1586093932788,"val":6972},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096238576,"val":6786},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098549248,"val":6306},{"ts":1586098830323,"val":6332},{"ts":1586098835342,"val":6314},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586103971920,"val":4118},{"ts":1586104007062,"val":4122},{"ts":1586104017114,"val":4126},{"ts":1586104032183,"val":4133},{"ts":1586104448936,"val":3519},{"ts":1586104875565,"val":3600},{"ts":1586104880592,"val":3594},{"ts":1586105739215,"val":3020},{"ts":1586105744232,"val":3023},{"ts":1586105749245,"val":3028},{"ts":1586106597564,"val":2470},{"ts":1586106607606,"val":2468},{"ts":1586107471103,"val":1809},{"ts":1586107476199,"val":1796},{"ts":1586107481131,"val":1802},{"ts":1586108334704,"val":1067},{"ts":1586108339732,"val":1062},{"ts":1586109198118,"val":169},{"ts":1586109203206,"val":162},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147215543,"val":0}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586060815542,"val":322.84586241276173},{"ts":1586060819569,"val":579},{"ts":1586060859739,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586061678004,"val":583},{"ts":1586061683019,"val":415},{"ts":1586061748667,"val":0},{"ts":1586062104842,"val":1622},{"ts":1586062541545,"val":294},{"ts":1586062546668,"val":0},{"ts":1586062998234,"val":2038},{"ts":1586063405000,"val":135},{"ts":1586063410005,"val":286},{"ts":1586063470272,"val":0},{"ts":1586063967244,"val":2081},{"ts":1586064268379,"val":386},{"ts":1586064273399,"val":1191},{"ts":1586064383908,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065131807,"val":690},{"ts":1586065136832,"val":452},{"ts":1586065583541,"val":0},{"ts":1586065618661,"val":2177},{"ts":1586065995425,"val":886},{"ts":1586066000439,"val":235},{"ts":1586066070684,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066858790,"val":482},{"ts":1586066863801,"val":592},{"ts":1586066883914,"val":0},{"ts":1586067406105,"val":1935},{"ts":1586067727427,"val":468},{"ts":1586067732438,"val":601},{"ts":1586067742470,"val":0},{"ts":1586067812769,"val":1761},{"ts":1586068591055,"val":0},{"ts":1586068596077,"val":170},{"ts":1586068626232,"val":0},{"ts":1586069273632,"val":2032},{"ts":1586069454443,"val":625},{"ts":1586069459493,"val":917},{"ts":1586070242670,"val":2701},{"ts":1586070302873,"val":208},{"ts":1586070317923,"val":899},{"ts":1586070322939,"val":1367},{"ts":1586070624105,"val":207},{"ts":1586071025845,"val":2602},{"ts":1586071181476,"val":846},{"ts":1586071186498,"val":1101},{"ts":1586071628219,"val":2592},{"ts":1586071703481,"val":226},{"ts":1586072045082,"val":845},{"ts":1586072050089,"val":1317},{"ts":1586072230757,"val":413},{"ts":1586072762980,"val":2978},{"ts":1586072908548,"val":975},{"ts":1586072913578,"val":701},{"ts":1586073666896,"val":2709},{"ts":1586073767288,"val":444},{"ts":1586073772347,"val":924},{"ts":1586073777355,"val":1152},{"ts":1586074013295,"val":307},{"ts":1586074093629,"val":2544},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586076289173,"val":1207},{"ts":1586076364579,"val":1265},{"ts":1586076369615,"val":1296},{"ts":1586076610668,"val":1068},{"ts":1586077017357,"val":3198},{"ts":1586077228206,"val":1289},{"ts":1586077233228,"val":1278},{"ts":1586077238248,"val":0},{"ts":1586077685215,"val":1942},{"ts":1586078091881,"val":1158},{"ts":1586078096910,"val":1207},{"ts":1586078106940,"val":1166},{"ts":1586078352967,"val":3369},{"ts":1586078955641,"val":3196},{"ts":1586078960682,"val":3213},{"ts":1586078980763,"val":3257},{"ts":1586079186687,"val":1134},{"ts":1586079818990,"val":1571},{"ts":1586079824022,"val":1507},{"ts":1586080225786,"val":1926},{"ts":1586080486842,"val":1202},{"ts":1586080682581,"val":1333},{"ts":1586080687605,"val":1344},{"ts":1586081455867,"val":1416},{"ts":1586081516117,"val":1298},{"ts":1586081546248,"val":1338},{"ts":1586081551945,"val":1326},{"ts":1586081566310,"val":1308},{"ts":1586081722115,"val":3243},{"ts":1586082414918,"val":3051},{"ts":1586082419935,"val":3098},{"ts":1586082545523,"val":3320},{"ts":1586083223140,"val":1293},{"ts":1586083278363,"val":1324},{"ts":1586083283382,"val":1342},{"ts":1586083398807,"val":1288},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586085732930,"val":1369},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088465726,"val":2059},{"ts":1586088470825,"val":2076},{"ts":1586088561240,"val":2000},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090600065,"val":1956},{"ts":1586090630195,"val":778},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586092627510,"val":2070},{"ts":1586092732971,"val":868},{"ts":1586092783176,"val":888},{"ts":1586092788193,"val":894},{"ts":1586092868521,"val":2080},{"ts":1586093300238,"val":807},{"ts":1586093646660,"val":1057},{"ts":1586093651731,"val":822},{"ts":1586093661724,"val":815},{"ts":1586093787227,"val":2030},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095816995,"val":1322},{"ts":1586095857154,"val":2851},{"ts":1586096238576,"val":1371},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586098800198,"val":2478},{"ts":1586098830323,"val":1316},{"ts":1586098835342,"val":1301},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586103113778,"val":1315},{"ts":1586103148902,"val":1593},{"ts":1586103153929,"val":1261},{"ts":1586103159184,"val":2398},{"ts":1586103981944,"val":687},{"ts":1586104012091,"val":687},{"ts":1586104017115,"val":702},{"ts":1586104474012,"val":1934},{"ts":1586104870548,"val":664},{"ts":1586104875565,"val":693},{"ts":1586104880592,"val":692},{"ts":1586104930783,"val":1839},{"ts":1586105699084,"val":383},{"ts":1586105739216,"val":403},{"ts":1586105744232,"val":588},{"ts":1586105759281,"val":388},{"ts":1586106336553,"val":1621},{"ts":1586106602593,"val":445},{"ts":1586106607606,"val":438},{"ts":1586107144860,"val":431},{"ts":1586107325556,"val":2002},{"ts":1586107471103,"val":514},{"ts":1586107476199,"val":830},{"ts":1586107491177,"val":1670},{"ts":1586108164066,"val":110},{"ts":1586108334704,"val":674},{"ts":1586108339732,"val":357},{"ts":1586109082505,"val":35},{"ts":1586109188056,"val":2119},{"ts":1586109198118,"val":508},{"ts":1586109203206,"val":450},{"ts":1586109218231,"val":0},{"ts":1586109850709,"val":2206},{"ts":1586110061406,"val":232},{"ts":1586110066424,"val":888},{"ts":1586110141653,"val":126},{"ts":1586110252079,"val":2542},{"ts":1586110924465,"val":868},{"ts":1586110929486,"val":857},{"ts":1586111004750,"val":510},{"ts":1586111280685,"val":2601},{"ts":1586111787428,"val":1708},{"ts":1586111792442,"val":1660},{"ts":1586112354474,"val":1076},{"ts":1586112550182,"val":3304},{"ts":1586112655527,"val":1748},{"ts":1586112660537,"val":1783},{"ts":1586112871240,"val":1684},{"ts":1586113513452,"val":3736},{"ts":1586113518453,"val":3723},{"ts":1586113523475,"val":3733},{"ts":1586113628798,"val":3563},{"ts":1586114381222,"val":3680},{"ts":1586114386250,"val":3686},{"ts":1586114792624,"val":3769},{"ts":1586114862881,"val":1929},{"ts":1586115244235,"val":2042},{"ts":1586115249250,"val":2056},{"ts":1586115550299,"val":1166},{"ts":1586116087149,"val":3146},{"ts":1586116107211,"val":3130},{"ts":1586116112226,"val":3132},{"ts":1586116428259,"val":4117},{"ts":1586116779539,"val":1092},{"ts":1586116975168,"val":1093},{"ts":1586116980200,"val":1117},{"ts":1586117769027,"val":1188},{"ts":1586117839517,"val":1042},{"ts":1586117844536,"val":1053},{"ts":1586118065490,"val":983},{"ts":1586118672995,"val":2060},{"ts":1586118703098,"val":1250},{"ts":1586118708114,"val":1239},{"ts":1586118999493,"val":1460},{"ts":1586119561868,"val":1066},{"ts":1586119566886,"val":1072},{"ts":1586119571931,"val":1070},{"ts":1586119617135,"val":994},{"ts":1586120235271,"val":1286},{"ts":1586120430949,"val":1069},{"ts":1586120435977,"val":1068},{"ts":1586120471125,"val":1484},{"ts":1586121294876,"val":1196},{"ts":1586121299896,"val":1197},{"ts":1586121470673,"val":1481},{"ts":1586122012898,"val":876},{"ts":1586122158648,"val":890},{"ts":1586122163668,"val":894},{"ts":1586122399822,"val":1066},{"ts":1586123002470,"val":744},{"ts":1586123022552,"val":856},{"ts":1586123027566,"val":779},{"ts":1586123635474,"val":957},{"ts":1586123846241,"val":733},{"ts":1586123886377,"val":756},{"ts":1586123891397,"val":755},{"ts":1586124057031,"val":740},{"ts":1586124358522,"val":1079},{"ts":1586124750423,"val":822},{"ts":1586124755564,"val":823},{"ts":1586124896001,"val":805},{"ts":1586125483391,"val":978},{"ts":1586125614109,"val":843},{"ts":1586125619128,"val":845},{"ts":1586125694599,"val":851},{"ts":1586126016471,"val":743},{"ts":1586126473161,"val":760},{"ts":1586126483197,"val":753},{"ts":1586126548458,"val":750},{"ts":1586127206643,"val":1195},{"ts":1586127342251,"val":853},{"ts":1586127357302,"val":852},{"ts":1586127563231,"val":817},{"ts":1586127794593,"val":1617},{"ts":1586128201532,"val":900},{"ts":1586128211514,"val":905},{"ts":1586128472584,"val":911},{"ts":1586128608291,"val":819},{"ts":1586129070615,"val":834},{"ts":1586129075630,"val":841},{"ts":1586129136032,"val":846},{"ts":1586129502477,"val":817},{"ts":1586129934382,"val":820},{"ts":1586129939400,"val":829},{"ts":1586130085156,"val":821},{"ts":1586130456695,"val":1010},{"ts":1586130793195,"val":893},{"ts":1586130803232,"val":887},{"ts":1586130904252,"val":909},{"ts":1586131647319,"val":762},{"ts":1586131657353,"val":775},{"ts":1586131667477,"val":774},{"ts":1586131707555,"val":764},{"ts":1586132320385,"val":879},{"ts":1586132526173,"val":869},{"ts":1586132531213,"val":863},{"ts":1586132546279,"val":875},{"ts":1586132712049,"val":768},{"ts":1586133390253,"val":782},{"ts":1586133395276,"val":796},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586134254366,"val":852},{"ts":1586134259404,"val":842},{"ts":1586134284519,"val":858},{"ts":1586134405104,"val":778},{"ts":1586135118594,"val":811},{"ts":1586135123624,"val":820},{"ts":1586135194019,"val":800},{"ts":1586135630884,"val":1070},{"ts":1586135982464,"val":855},{"ts":1586135987482,"val":853},{"ts":1586136333985,"val":787},{"ts":1586136685546,"val":1050},{"ts":1586136846282,"val":878},{"ts":1586136851300,"val":874},{"ts":1586137011970,"val":862},{"ts":1586137288246,"val":1083},{"ts":1586137710306,"val":935},{"ts":1586137715336,"val":929},{"ts":1586137735449,"val":947},{"ts":1586138363143,"val":856},{"ts":1586138574110,"val":866},{"ts":1586138579123,"val":885},{"ts":1586138749901,"val":895},{"ts":1586139287234,"val":805},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141263684,"val":889},{"ts":1586141665342,"val":804},{"ts":1586142026837,"val":827},{"ts":1586142031851,"val":833},{"ts":1586142383576,"val":805},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586144671112,"val":967},{"ts":1586144866935,"val":878},{"ts":1586145484896,"val":892},{"ts":1586145489911,"val":888},{"ts":1586145715999,"val":877},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147215542,"val":963}]
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 328
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                        widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585888021338,"val":18.80886217247979},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893204300,"val":193},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585895684283,"val":501},{"ts":1585895794672,"val":480},{"ts":1585895799700,"val":473},{"ts":1585897185165,"val":0},{"ts":1585898159180,"val":659},{"ts":1585898385040,"val":617},{"ts":1585898390058,"val":628},{"ts":1585899575029,"val":530},{"ts":1585900980520,"val":994},{"ts":1585900985534,"val":1005},{"ts":1585901015644,"val":1003},{"ts":1585903569795,"val":2200},{"ts":1585903574811,"val":2196},{"ts":1585903645071,"val":2181},{"ts":1585906161769,"val":3571},{"ts":1585906166784,"val":3570},{"ts":1585906839996,"val":3192},{"ts":1585908723833,"val":4928},{"ts":1585908754000,"val":4924},{"ts":1585908759022,"val":4910},{"ts":1585911345563,"val":5898},{"ts":1585911350603,"val":5908},{"ts":1585912410550,"val":5877},{"ts":1585913922850,"val":6616},{"ts":1585913932895,"val":6599},{"ts":1585913942936,"val":6605},{"ts":1585914163920,"val":6467},{"ts":1585916384007,"val":6985},{"ts":1585916529650,"val":6944},{"ts":1585916534675,"val":6960},{"ts":1585917263083,"val":6529},{"ts":1585917584464,"val":7089},{"ts":1585919116745,"val":6997},{"ts":1585919126800,"val":7020},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921713534,"val":7025},{"ts":1585921723734,"val":7029},{"ts":1585922783485,"val":7092},{"ts":1585923817824,"val":6552},{"ts":1585924305287,"val":6682},{"ts":1585924310307,"val":6698},{"ts":1585926786616,"val":1903},{"ts":1585926897099,"val":5636},{"ts":1585926902112,"val":5320},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585929489238,"val":4971},{"ts":1585929494237,"val":4964},{"ts":1585929509309,"val":4983},{"ts":1585932066391,"val":2988},{"ts":1585932081439,"val":3016},{"ts":1585932086459,"val":3017},{"ts":1585932242172,"val":3059},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978687121,"val":119},{"ts":1585978737447,"val":112},{"ts":1585978742326,"val":117},{"ts":1585978747342,"val":99},{"ts":1585981303931,"val":374},{"ts":1585981318976,"val":369},{"ts":1585981334020,"val":376},{"ts":1585983418325,"val":259},{"ts":1585983820346,"val":543},{"ts":1585983920820,"val":515},{"ts":1585983925837,"val":521},{"ts":1585984789725,"val":22},{"ts":1585986491415,"val":734},{"ts":1585986516521,"val":711},{"ts":1585986521539,"val":742},{"ts":1585987214177,"val":0},{"ts":1585989086736,"val":1795},{"ts":1585989106800,"val":1779},{"ts":1585989111816,"val":1812},{"ts":1585989192086,"val":1778},{"ts":1585991682461,"val":3048},{"ts":1585991697540,"val":3026},{"ts":1585991702556,"val":3042},{"ts":1585992038901,"val":2880},{"ts":1585994288543,"val":4521},{"ts":1585994293558,"val":4515},{"ts":1585994529574,"val":4425},{"ts":1585996844900,"val":5554},{"ts":1585996885114,"val":5553},{"ts":1585996895147,"val":5562},{"ts":1585999380974,"val":6507},{"ts":1585999476411,"val":6458},{"ts":1585999481423,"val":6465},{"ts":1585999496486,"val":6420},{"ts":1586002028065,"val":6951},{"ts":1586002068265,"val":6928},{"ts":1586002073289,"val":6909},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004660013,"val":6868},{"ts":1586004665028,"val":6897},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586007251982,"val":7062},{"ts":1586007256978,"val":7056},{"ts":1586007277183,"val":7074},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586015012435,"val":5222},{"ts":1586015027508,"val":5225},{"ts":1586015032523,"val":5206},{"ts":1586015037535,"val":5220},{"ts":1586017407825,"val":3634},{"ts":1586017618787,"val":3733},{"ts":1586017628822,"val":3739},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020224747,"val":2051},{"ts":1586022801468,"val":69},{"ts":1586022806483,"val":79},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063997372,"val":84},{"ts":1586064273399,"val":74},{"ts":1586064283425,"val":70},{"ts":1586064393948,"val":59},{"ts":1586066843732,"val":276},{"ts":1586066868851,"val":273},{"ts":1586066873847,"val":279},{"ts":1586068209595,"val":155},{"ts":1586069384063,"val":433},{"ts":1586069459493,"val":419},{"ts":1586069464488,"val":421},{"ts":1586071834103,"val":217},{"ts":1586072040042,"val":586},{"ts":1586072050089,"val":563},{"ts":1586072055104,"val":537},{"ts":1586072245821,"val":475},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077203046,"val":2650},{"ts":1586077233227,"val":2636},{"ts":1586077238247,"val":0},{"ts":1586079738665,"val":4032},{"ts":1586079824022,"val":4019},{"ts":1586079834067,"val":4026},{"ts":1586079839106,"val":3956},{"ts":1586082339629,"val":5323},{"ts":1586082419935,"val":5300},{"ts":1586082424953,"val":5307},{"ts":1586082450037,"val":5298},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586092637546,"val":7053},{"ts":1586092788193,"val":7001},{"ts":1586092793207,"val":6983},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103143897,"val":4596},{"ts":1586103148901,"val":4602},{"ts":1586103159184,"val":4593},{"ts":1586103173990,"val":4603},{"ts":1586105739215,"val":3020},{"ts":1586105749245,"val":3028},{"ts":1586105754258,"val":3024},{"ts":1586108339732,"val":1062},{"ts":1586108344752,"val":1052},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147221338,"val":0}]
                        setTimeout (async)
                        o @ widgets.min.js:3
                        t.dispatch @ can.custom.min.js:18
                        stop @ can.custom.min.js:44
                        _setAttrs @ can.custom.min.js:48
                        attr @ can.custom.min.js:48
                        (anonymous) @ vis.js:311
                        a.add @ index.js:83
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 208
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585888021338,"val":978.7388789148215},{"ts":1585888024034,"val":954},{"ts":1585888189680,"val":147},{"ts":1585889665174,"val":2601},{"ts":1585890609036,"val":1003},{"ts":1585890614058,"val":947},{"ts":1585891688301,"val":370},{"ts":1585893128983,"val":6513},{"ts":1585893204300,"val":5228},{"ts":1585893209725,"val":5304},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585895794674,"val":1409},{"ts":1585895799700,"val":766},{"ts":1585896286641,"val":472},{"ts":1585897873089,"val":3202},{"ts":1585898385040,"val":1490},{"ts":1585898390058,"val":1463},{"ts":1585899856172,"val":3180},{"ts":1585900824952,"val":783},{"ts":1585900980520,"val":1525},{"ts":1585900985534,"val":1361},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903569795,"val":709},{"ts":1585903574811,"val":352},{"ts":1585904800420,"val":2535},{"ts":1585905036614,"val":109},{"ts":1585906161770,"val":1314},{"ts":1585906166784,"val":1319},{"ts":1585906196884,"val":620},{"ts":1585906789757,"val":7580},{"ts":1585908754000,"val":1853},{"ts":1585908759022,"val":2107},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585911345563,"val":1475},{"ts":1585911350603,"val":1800},{"ts":1585911375779,"val":1454},{"ts":1585912782456,"val":3479},{"ts":1585913937908,"val":1581},{"ts":1585913942936,"val":1610},{"ts":1585914163920,"val":1438},{"ts":1585916414148,"val":2888},{"ts":1585916529650,"val":1698},{"ts":1585916534675,"val":1736},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585919121783,"val":1582},{"ts":1585919126800,"val":1788},{"ts":1585920578494,"val":1454},{"ts":1585920714057,"val":3022},{"ts":1585921713534,"val":1572},{"ts":1585921718548,"val":1993},{"ts":1585922015043,"val":2670},{"ts":1585922220919,"val":979},{"ts":1585924305287,"val":1318},{"ts":1585924310307,"val":1138},{"ts":1585926344500,"val":2383},{"ts":1585926791643,"val":824},{"ts":1585926897099,"val":1016},{"ts":1585926902112,"val":1021},{"ts":1585927389541,"val":2238},{"ts":1585927645698,"val":578},{"ts":1585929489239,"val":866},{"ts":1585929494237,"val":1222},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932081440,"val":6083},{"ts":1585932086459,"val":6253},{"ts":1585932186912,"val":6805},{"ts":1585932839608,"val":1735},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585935483710,"val":3882},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939859554,"val":3969},{"ts":1585939864583,"val":3943},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585947634845,"val":1339},{"ts":1585947639854,"val":1342},{"ts":1585948061642,"val":930},{"ts":1585950137489,"val":2922},{"ts":1585950227803,"val":1559},{"ts":1585950232824,"val":1956},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585953647922,"val":1088},{"ts":1585954190090,"val":1137},{"ts":1585956039145,"val":1013},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585958744944,"val":1015},{"ts":1585958815259,"val":995},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963074269,"val":815},{"ts":1585963184681,"val":449},{"ts":1585963189696,"val":448},{"ts":1585963767030,"val":368},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585968365640,"val":449},{"ts":1585968375693,"val":450},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585970960846,"val":383},{"ts":1585970965865,"val":378},{"ts":1585970990956,"val":376},{"ts":1585973415728,"val":1007},{"ts":1585973556359,"val":996},{"ts":1585973561377,"val":993},{"ts":1585973656679,"val":903},{"ts":1585975162738,"val":1677},{"ts":1585976146690,"val":984},{"ts":1585976151706,"val":972},{"ts":1585976432703,"val":1087},{"ts":1585978737447,"val":895},{"ts":1585978742326,"val":892},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585981329005,"val":381},{"ts":1585981334020,"val":390},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983920820,"val":597},{"ts":1585983925837,"val":551},{"ts":1585983981076,"val":424},{"ts":1585984217203,"val":2734},{"ts":1585986516521,"val":988},{"ts":1585986521540,"val":1439},{"ts":1585986702219,"val":949},{"ts":1585988961236,"val":2760},{"ts":1585989106
                        widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
                        widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
                        setTimeout (async)
                        r.onack @ index.js:83
                        r.onpacket @ index.js:83
                        (anonymous) @ index.js:83
                        r.emit @ index.js:83
                        r.ondecoded @ index.js:83
                        a.add @ index.js:83
                        r.ondata @ index.js:83
                        r.onPacket @ index.js:83
                        r.onData @ index.js:83
                        ws.onmessage @ index.js:83
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 106
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427421,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905297714,"val":2895},{"ts":1585905307760,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911350603,"val":5908},{"ts":1585911355617,"val":5917},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917398670,"val":6958},{"ts":1585917403697,"val":6960},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020214708,"val":2045},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227422,"val":0}]
                        setTimeout (async)
                        setInterval (async)
                        setTimeout (async)
                        frag @ can.custom.min.js:58
                        r @ can.custom.min.js:58
                        renderTo @ can.custom.min.js:58
                        renderAs @ can.custom.min.js:58
                        e.view.e.template @ can.custom.min.js:58
                        renderWidget @ vis.js:1610
                        (anonymous) @ vis.js:887
                        (anonymous) @ vis.js:2742
                        (anonymous) @ conn.js:730
                        a.add @ index.js:83
                        Show 13 more frames
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 105
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542427891,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893209725,"val":199},{"ts":1585893214336,"val":197},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899258798,"val":655},{"ts":1585899263819,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905292697,"val":2903},{"ts":1585905307760,"val":2896},{"ts":1585905312772,"val":2882},{"ts":1585905674398,"val":2619},{"ts":1585911355617,"val":5917},{"ts":1585911360684,"val":5923},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917403697,"val":6960},{"ts":1585917408732,"val":6957},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923451340,"val":6947},{"ts":1585923456353,"val":6960},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929499251,"val":4965},{"ts":1585929504280,"val":4977},{"ts":1585929509309,"val":4983},{"ts":1585935513849,"val":153},{"ts":1585935543974,"val":158},{"ts":1585935549000,"val":160},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977878561,"val":62},{"ts":1585977888595,"val":66},{"ts":1585977898644,"val":59},{"ts":1585983820346,"val":543},{"ts":1585983930849,"val":517},{"ts":1585983935863,"val":522},{"ts":1585987214177,"val":0},{"ts":1585989970447,"val":2198},{"ts":1585989975437,"val":2185},{"ts":1585989980468,"val":2187},{"ts":1585995991077,"val":5337},{"ts":1585996026186,"val":5316},{"ts":1585996031210,"val":5338},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002073289,"val":6909},{"ts":1586002078320,"val":6922},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014168676,"val":5463},{"ts":1586014173704,"val":5469},{"ts":1586014178718,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020219725,"val":2048},{"ts":1586020224747,"val":2051},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068601120,"val":382},{"ts":1586068606155,"val":387},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080672557,"val":4572},{"ts":1586080697652,"val":4564},{"ts":1586080702679,"val":4551},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092793207,"val":6983},{"ts":1586092798226,"val":6996},{"ts":1586093596415,"val":7097},{"ts":1586098840356,"val":6296},{"ts":1586098855415,"val":6290},{"ts":1586104448936,"val":3519},{"ts":1586104890630,"val":3594},{"ts":1586104895646,"val":3588},{"ts":1586104900666,"val":3593},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147227892,"val":0}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 192
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427421,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905302744,"val":543},{"ts":1585905307760,"val":936},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911350603,"val":1800},{"ts":1585911355618,"val":1458},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917398670,"val":1511},{"ts":1585917403698,"val":1498},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977878561,"val":997},{"ts":1585977883583,"val":1000},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020214708,"val":622},{"ts":1586020219725,"val":706},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026262452,"val":218},{"ts":1586026267476,"val":1036},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110934505,"val":849},{"ts":1586110939527,"val":841},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227422,"val":963}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542427891,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875066695,"val":990},{"ts":1585875071710,"val":957},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881112719,"val":408},{"ts":1585881117733,"val":328},{"ts":1585881127769,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887160647,"val":814},{"ts":1585887165659,"val":715},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893209725,"val":5304},{"ts":1585893214336,"val":5505},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899258798,"val":1554},{"ts":1585899263819,"val":1807},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905307760,"val":936},{"ts":1585905312772,"val":1337},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911355618,"val":1458},{"ts":1585911360684,"val":1565},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917403698,"val":1498},{"ts":1585917408732,"val":2677},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923451340,"val":1211},{"ts":1585923456353,"val":1076},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929499251,"val":863},{"ts":1585929504280,"val":1266},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935543974,"val":2298},{"ts":1585935549000,"val":2222},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941591810,"val":1457},{"ts":1585941596824,"val":1677},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947639854,"val":1342},{"ts":1585947644870,"val":1345},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953688242,"val":1128},{"ts":1585953693097,"val":1129},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971834208,"val":382},{"ts":1585971844242,"val":384},{"ts":1585975162738,"val":1677},{"ts":1585977883583,"val":1000},{"ts":1585977888595,"val":1003},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983930849,"val":753},{"ts":1585983935863,"val":1631},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585989975438,"val":1416},{"ts":1585989980469,"val":1778},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996026187,"val":1579},{"ts":1585996031210,"val":1244},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002073290,"val":1403},{"ts":1586002078320,"val":1397},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014168676,"val":1277},{"ts":1586014173704,"val":1301},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020219725,"val":706},{"ts":1586020224747,"val":626},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026267476,"val":1036},{"ts":1586026272518,"val":667},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032310896,"val":652},{"ts":1586032315939,"val":964},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038359695,"val":670},{"ts":1586038364724,"val":1562},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044409399,"val":694},{"ts":1586044414434,"val":484},{"ts":1586044439569,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050458808,"val":608},{"ts":1586050463823,"val":946},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056507278,"val":1202},{"ts":1586056512293,"val":1065},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062551579,"val":119},{"ts":1586062556594,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068601120,"val":331},{"ts":1586068606155,"val":377},{"ts":1586068626232,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080697652,"val":1359},{"ts":1586080702680,"val":1344},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092793207,"val":881},{"ts":1586092798226,"val":1065},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098840357,"val":1329},{"ts":1586098845375,"val":1287},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104890630,"val":704},{"ts":1586104895646,"val":691},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110939527,"val":841},{"ts":1586110944541,"val":525},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586116985215,"val":1107},{"ts":1586116990225,"val":1118},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123032579,"val":749},{"ts":1586123037592,"val":752},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129080642,"val":832},{"ts":1586129085656,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135128646,"val":821},{"ts":1586135133700,"val":825},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147227891,"val":963}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585542457581,"val":0},{"ts":1585857922009,"val":0},{"ts":1585862511601,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585893239448,"val":204},{"ts":1585893244471,"val":203},{"ts":1585897185165,"val":0},{"ts":1585899123304,"val":684},{"ts":1585899288946,"val":642},{"ts":1585899293958,"val":662},{"ts":1585899575029,"val":530},{"ts":1585905332891,"val":2904},{"ts":1585905337924,"val":2896},{"ts":1585905674398,"val":2619},{"ts":1585911365768,"val":5936},{"ts":1585911380802,"val":5916},{"ts":1585911385822,"val":5926},{"ts":1585912410550,"val":5877},{"ts":1585916725590,"val":7006},{"ts":1585917428858,"val":6996},{"ts":1585917433849,"val":7003},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585923481449,"val":6954},{"ts":1585923486473,"val":6952},{"ts":1585923541698,"val":6989},{"ts":1585927444855,"val":1193},{"ts":1585929529383,"val":4954},{"ts":1585929539440,"val":4956},{"ts":1585929594711,"val":4969},{"ts":1585935559025,"val":142},{"ts":1585935574080,"val":147},{"ts":1585935589139,"val":143},{"ts":1585935594162,"val":147},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585977793218,"val":70},{"ts":1585977908692,"val":63},{"ts":1585977913712,"val":64},{"ts":1585977918743,"val":62},{"ts":1585983820346,"val":543},{"ts":1585983955926,"val":520},{"ts":1585983965996,"val":524},{"ts":1585987214177,"val":0},{"ts":1585989995523,"val":2210},{"ts":1585990005577,"val":2210},{"ts":1585990010587,"val":2211},{"ts":1585990020611,"val":2205},{"ts":1585996031210,"val":5338},{"ts":1585996056364,"val":5329},{"ts":1585996061386,"val":5334},{"ts":1585996347883,"val":5107},{"ts":1586002028065,"val":6951},{"ts":1586002098413,"val":6840},{"ts":1586002108453,"val":6837},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586014158640,"val":5451},{"ts":1586014198840,"val":5466},{"ts":1586014209331,"val":5460},{"ts":1586014264186,"val":5475},{"ts":1586020209705,"val":2037},{"ts":1586020239796,"val":2045},{"ts":1586020249832,"val":2041},{"ts":1586020259865,"val":2042},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586068540859,"val":411},{"ts":1586068631241,"val":394},{"ts":1586068636256,"val":396},{"ts":1586071834103,"val":217},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586080717735,"val":4585},{"ts":1586080727764,"val":4565},{"ts":1586080732785,"val":4603},{"ts":1586080787954,"val":4544},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586092637546,"val":7053},{"ts":1586092823340,"val":7027},{"ts":1586092828356,"val":7033},{"ts":1586093596415,"val":7097},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586104448936,"val":3519},{"ts":1586104920743,"val":3575},{"ts":1586104925757,"val":3576},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586147257587,"val":0}]
                        widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                        (anonymous) @ widgets.min.js:4
                        (anonymous) @ conn.js:1299
                        setTimeout (async)
                        getHistory @ conn.js:1297
                        getHistory @ vis.js:2613
                        getTaskForHistoryData @ widgets.min.js:4
                        (anonymous) @ widgets.min.js:3
                        setInterval (async)
                        setTimeout (async)
                        lineHistory @ widgets.min.js:3
                        eval @ tplVis-materialdesign-Chart-Line-History.js:31
                        (anonymous) @ can.custom.min.js:64
                        a.each @ can.custom.min.js:24
                        (anonymous) @ can.custom.min.js:58
                        hookup @ can.custom.min.js:58
                        a.add @ index.js:83
                        Show 13 more frames
                        widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                        widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 107
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 194
                        widgets.min.js:4 [getTaskForHistoryData w00477] history data 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585542457581,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585862511615,"val":1361},{"ts":1585863070872,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585868189555,"val":611},{"ts":1585870007176,"val":886},{"ts":1585871728785,"val":2806},{"ts":1585873802006,"val":135},{"ts":1585875096810,"val":902},{"ts":1585875101837,"val":964},{"ts":1585875468113,"val":0},{"ts":1585876816170,"val":2299},{"ts":1585881142844,"val":1083},{"ts":1585881147858,"val":781},{"ts":1585881182990,"val":0},{"ts":1585886252436,"val":2250},{"ts":1585887190756,"val":1317},{"ts":1585887195774,"val":1228},{"ts":1585888189680,"val":147},{"ts":1585893128983,"val":6513},{"ts":1585893239448,"val":5409},{"ts":1585893244472,"val":5317},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585899288946,"val":2198},{"ts":1585899293958,"val":1491},{"ts":1585901110985,"val":3204},{"ts":1585905036614,"val":109},{"ts":1585905332891,"val":756},{"ts":1585905337925,"val":769},{"ts":1585905890372,"val":290},{"ts":1585906789757,"val":7580},{"ts":1585911380802,"val":1477},{"ts":1585911385823,"val":1469},{"ts":1585912782456,"val":3479},{"ts":1585914163920,"val":1438},{"ts":1585917428858,"val":1509},{"ts":1585917433849,"val":1518},{"ts":1585917710085,"val":4053},{"ts":1585922220919,"val":979},{"ts":1585923481449,"val":1069},{"ts":1585923486473,"val":1220},{"ts":1585926344500,"val":2383},{"ts":1585927645698,"val":578},{"ts":1585929529383,"val":866},{"ts":1585929534444,"val":2029},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585935574081,"val":1616},{"ts":1585935579102,"val":1641},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585941621951,"val":1832},{"ts":1585941626967,"val":1563},{"ts":1585943791038,"val":4658},{"ts":1585945872198,"val":604},{"ts":1585947669968,"val":1567},{"ts":1585947675005,"val":1404},{"ts":1585948061642,"val":930},{"ts":1585950694493,"val":3047},{"ts":1585953718193,"val":1133},{"ts":1585953723211,"val":1122},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585958865542,"val":1010},{"ts":1585960714730,"val":515},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585964258956,"val":376},{"ts":1585966076650,"val":385},{"ts":1585966297472,"val":369},{"ts":1585970197879,"val":1802},{"ts":1585971864331,"val":437},{"ts":1585971869365,"val":424},{"ts":1585971879417,"val":422},{"ts":1585975162738,"val":1677},{"ts":1585977908693,"val":999},{"ts":1585977913712,"val":1007},{"ts":1585982343403,"val":339},{"ts":1585983870589,"val":1763},{"ts":1585983960967,"val":615},{"ts":1585983965996,"val":695},{"ts":1585983981076,"val":424},{"ts":1585989161988,"val":3025},{"ts":1585990005577,"val":1765},{"ts":1585990010588,"val":1418},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585996056365,"val":1423},{"ts":1585996061386,"val":1496},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586002103434,"val":1762},{"ts":1586002108453,"val":1384},{"ts":1586003238503,"val":6525},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010523424,"val":2534},{"ts":1586012972700,"val":334},{"ts":1586014198840,"val":1278},{"ts":1586014204096,"val":1280},{"ts":1586017402800,"val":2539},{"ts":1586020159515,"val":611},{"ts":1586020244827,"val":632},{"ts":1586020249832,"val":627},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586026292628,"val":401},{"ts":1586026297651,"val":748},{"ts":1586026342890,"val":0},{"ts":1586032245602,"val":2701},{"ts":1586032341034,"val":1149},{"ts":1586032346148,"val":1487},{"ts":1586033536704,"val":2855},{"ts":1586038309460,"val":0},{"ts":1586038389857,"val":962},{"ts":1586038394868,"val":1096},{"ts":1586038636203,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586044439569,"val":0},{"ts":1586044444598,"val":103},{"ts":1586044474730,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050488905,"val":1017},{"ts":1586050493929,"val":1689},{"ts":1586053129518,"val":209},{"ts":1586055488482,"val":2686},{"ts":1586056537411,"val":1105},{"ts":1586056542425,"val":617},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586062581675,"val":669},{"ts":1586062586691,"val":441},{"ts":1586062621791,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068631241,"val":871},{"ts":1586068636257,"val":285},{"ts":1586068691451,"val":0},{"ts":1586072762980,"val":2978},{"ts":1586074319661,"val":996},{"ts":1586076168683,"val":5584},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586080727764,"val":1332},{"ts":1586080732785,"val":1341},{"ts":1586082545523,"val":3320},{"ts":1586083398807,"val":1288},{"ts":1586085788126,"val":1380},{"ts":1586087637496,"val":800},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586092823340,"val":892},{"ts":1586092828356,"val":917},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586104870548,"val":664},{"ts":1586104920744,"val":676},{"ts":1586104925757,"val":693},{"ts":1586109218231,"val":0},{"ts":1586110252079,"val":2542},{"ts":1586110964619,"val":855},{"ts":1586110969633,"val":836},{"ts":1586111004750,"val":510},{"ts":1586116428259,"val":4117},{"ts":1586117015295,"val":1126},{"ts":1586117020309,"val":1125},{"ts":1586118672995,"val":2060},{"ts":1586123002470,"val":744},{"ts":1586123062707,"val":754},{"ts":1586123067726,"val":749},{"ts":1586123846241,"val":733},{"ts":1586127794593,"val":1617},{"ts":1586129110768,"val":830},{"ts":1586129115798,"val":845},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586135158842,"val":813},{"ts":1586135163912,"val":815},{"ts":1586136333985,"val":787},{"ts":1586137288246,"val":1083},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141665342,"val":804},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147257581,"val":963}]
                        • Scrounger
                          Scrounger Developer @Chris Tailor last edited by
                          @Chris-Tailor
                          Bitte die aktuelle version von git testen -> v0.2.78
                          liv-in-sky Chris Tailor 2 Replies Last reply Reply Quote 0
                            liv-in-sky @Scrounger last edited by
                            @Scrounger
                            ich habe ein seltsames problem - hast du dazu eine idee
                            wenn ich widgets von anderen '"herstellern" (inventwo) in den editor ziehe, bekomme ich dich in den eigenschaften
                            • Scrounger
                              Scrounger Developer @liv-in-sky last edited by
                              @liv-in-sky
                              Versteht ich nicht du ziehst erst nen MDW Line Chart Widget, dann nen MDW Button Widget rein - beide haben unter Allgemein die Punkte Anleitung, etc.
                              Dann ziehst nen html Widget rein und da findet man unter allgemein keine Angaben zum MDW Widget.
                                @Scrounger oh - man - ich sollte heute kein iobroker machen - habe nochmal gecheckt
                                habe deine widgets mit anderen verwechselt - ich dachte das MDW Button Widget ist ein anderes - die, die ich suchte, sind viel weiter unten zur auswahl
                                somit alles gut
                                war wohl etwas verwirrt, weil ich andere fehlermeldungen im browser habe, die aber nix mit deinen sachen zu tun haben
                                • Chris Tailor
                                  Chris Tailor @Scrounger last edited by
                                  @Scrounger ok, eingespielt und getestet. Gefühlt funktionieren die Charts etwas besser und die Linien tauchen häufiger auf. Hier die Log Daten:
                                  [Deprecation] Application Cache was previously restricted to secure origins only from M70 on but now secure origin use is deprecated and will be removed in M82.  Please shift your use case over to Service Workers.
                                  index.html?smarthub:3408 Version vis-canvas-gauges: 0.1.5
                                  index.html?smarthub:3948 Version vis-colorpicker: 1.0.1
                                  index.html?smarthub:5374 Version vis-history: 1.0.0
                                  info.js:9 Version Info-Adapter-Widget: 0.0.8
                                  keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
                                  index.html?smarthub:8340 Version vis-map: 1.0.3
                                  materialdesign.js:25 Version vis-materialdesign: 0.2.78
                                  lib.min.js:22 Download the Vue Devtools extension for a better development experience:
                                  https://github.com/vuejs/vue-devtools
                                  lib.min.js:22 You are running Vue in development mode.
                                  Make sure to turn on production mode when deploying for production.
                                  See more tips at https://vuejs.org/guide/deployment.html
                                  players.js:58 Version players: 0.1.0
                                  conn.js:273 2020-04-06T19:02:17.119Z Connected => authenticate
                                  conn.js:293 2020-04-06T19:02:17.488Z Authenticated: true
                                  vis.js:3167 Create inner vis object 0_userdata.0.vis.Timeinterval_iSpeed
                                  vis.js:3167 Create inner vis object 0_userdata.0.vis.ChartAktualisieren
                                  vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40083_Batterie_SOC
                                  vis.js:3167 Create inner vis object javascript.0.adapterdatenpunkte.modbus.Autarkie
                                  vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40068_PV_Leistung
                                  vis.js:3167 Create inner vis object modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung
                                  widgets.min.js:3 [Line History Chart w00477] widget setting: {"_data":{"wid":"w00477","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","dataCount":"1","aggregate":"minmax","timeIntervalToShow":"2 hours","refreshMethod":"timeInterval","refreshTimeInterval":"30 seconds","pointStyle":"circle","showLegend":true,"legendPosition":"bottom","legendPointStyle":true,"showTooltip":"true","tooltipTimeFormats":"{\"millisecond\":\"lll:ss\",\"second\":\"lll:ss\",\"minute\":\"lll\",\"hour\":\"lll\",\"day\":\"lll\",\"week\":\"lll\",\"month\":\"lll\",\"quarter\":\"lll\",\"year\":\"lll\"}","tooltipShowColorBox":"true","lineSpanGaps0":true,"lineSpanGaps1":"true","xAxisPosition":"bottom","xAxisBounds":"dataSet","xAxisTimeFormats":"{\"millisecond\":\"H:mm:ss.SSS\",\"second\":\"H:mm:ss\",\"minute\":\"H:mm\",\"hour\":\"H\",\"day\":\"ddd DD.\",\"week\":\"ll\",\"month\":\"MMM YYYY\",\"quarter\":\"[Q]Q - YYYY\",\"year\":\"YYYY\"}","xAxisValueDistanceToAxis":"0","xAxisShowAxis":"true","xAxisShowAxisLabels":"true","xAxisShowGridLines":"true","xAxisShowTicks":"true","yAxisValueDistanceToAxis":"10","showYAxis0":true,"yAxisPosition0":"left","yAxisShowGridLines0":"true","yAxisShowTicks0":"true","yAxisShowAxisBorder0":"true","showYAxis1":"true","yAxisPosition1":"left","yAxisShowGridLines1":"true","yAxisShowTicks1":"true","yAxisShowAxisBorder1":"true","showValues0":false,"valuesPositionAnchor0":"center","valuesPositionAlign0":"top","valuesTextAlign0":"center","showValues1":false,"valuesPositionAnchor1":"end","valuesPositionAlign1":"bottom","valuesTextAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"historyAdapterInstance":"influxdb.0","oid0":"modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung","oid1":"modbus.0.holdingRegisters.40068_PV_Leistung","lineSpanGaps2":"true","showYAxis2":"true","yAxisPosition2":"left","yAxisShowGridLines2":"true","yAxisShowTicks2":"true","yAxisShowAxisBorder2":"true","showValues2":"true","valuesPositionAnchor2":"end","valuesPositionAlign2":"top","valuesTextAlign2":"center","lineSpanGaps3":"true","showYAxis3":"true","yAxisPosition3":"left","yAxisShowGridLines3":"true","yAxisShowTicks3":"true","yAxisShowAxisBorder3":"true","showValues3":"true","valuesPositionAnchor3":"end","valuesPositionAlign3":"top","valuesTextAlign3":"center","lineSpanGaps4":"true","showYAxis4":"true","yAxisPosition4":"left","yAxisShowGridLines4":"true","yAxisShowTicks4":"true","yAxisShowAxisBorder4":"true","showValues4":"true","valuesPositionAnchor4":"end","valuesPositionAlign4":"top","valuesTextAlign4":"center","legendText0":"Hausverbrauch W","legendText1":"PV Leistung W","dataColor1":"#F3FFBD","dataColor0":"#B2DBBF","useFillColor0":true,"useFillColor1":true,"fillColor1":"","fillColor0":"","yAxisGridLinesColor1":"","yAxisValueColor1":"","yAxisGridLinesColor0":"white","yAxisValueColor0":"white","yAxisValueLabelColor":"#ffffff","yAxisTitleColor":"#ffffff","xAxisTitleColor":"","xAxisValueLabelColor":"#ffffff","time_interval_oid":"0_userdata.0.vis.Timeinterval_iSpeed","legendFontColor":"white","maxDataPoints":"100","commonYAxis0":"1","commonYAxis1":"1","colorScheme":"scrounger.pie","legendFontSize":"20","legendFontFamily":"Jura-Light","legendBoxWidth":"8","legendPadding":"","lineTension0":"","valuesMaxDecimals0":"0","valuesFontFamily0":"Jura-DemiBold","valuesFontSize0":"20","valuesFontFamily1":"Jura-DemiBold","valuesFontSize1":"20","valuesMaxDecimals1":"0","yAxisTitleFontFamily":"Jura-Light","yAxisTitleFontSize":"","yAxisValueFontFamily":"Jura-Light","yAxisValueFontSize":"15","xAxisValueFontFamily":"Jura-Light","xAxisValueFontSize":"15","chartPaddingRight":"20","chartPaddingTop":"22","manualRefreshTrigger":"0_userdata.0.vis.ChartAktualisieren","pointSize":"0","minTimeInterval":"","xAxisMinRotation":"0","xAxisMaxRotation":"0","valuesMinDecimals1":"15","mdwDebug":true},"_cid":".map17","_computedAttrs":{},"wid":"w00477",
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586113338503,"end":1586199738515,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586113338503,"end":1586199738518,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 326
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586113338503,"val":1723.9014955134596},{"ts":1586113342731,"val":1718},{"ts":1586113513452,"val":3736},{"ts":1586114200643,"val":3644},{"ts":1586114205657,"val":3650},{"ts":1586114792624,"val":3769},{"ts":1586114862881,"val":1929},{"ts":1586115063696,"val":2006},{"ts":1586115068709,"val":2011},{"ts":1586115550299,"val":1166},{"ts":1586115926612,"val":3144},{"ts":1586115931628,"val":3131},{"ts":1586116428259,"val":4117},{"ts":1586116779539,"val":1092},{"ts":1586116789568,"val":1125},{"ts":1586116794584,"val":1118},{"ts":1586117346778,"val":1148},{"ts":1586117542684,"val":1086},{"ts":1586117658265,"val":1113},{"ts":1586117663287,"val":1142},{"ts":1586118065490,"val":983},{"ts":1586118346638,"val":1673},{"ts":1586118517257,"val":1064},{"ts":1586118527297,"val":1071},{"ts":1586118537332,"val":1057},{"ts":1586118672995,"val":2060},{"ts":1586119386223,"val":1146},{"ts":1586119391253,"val":1143},{"ts":1586119617135,"val":994},{"ts":1586120235271,"val":1286},{"ts":1586120250234,"val":1078},{"ts":1586120255317,"val":1073},{"ts":1586120275350,"val":1065},{"ts":1586120471125,"val":1484},{"ts":1586121103849,"val":1288},{"ts":1586121118893,"val":1293},{"ts":1586121470673,"val":1481},{"ts":1586121716647,"val":881},{"ts":1586121977720,"val":889},{"ts":1586121982744,"val":884},{"ts":1586122399822,"val":1066},{"ts":1586122721276,"val":747},{"ts":1586122841782,"val":752},{"ts":1586122846814,"val":757},{"ts":1586123148085,"val":736},{"ts":1586123635474,"val":957},{"ts":1586123700753,"val":755},{"ts":1586123706531,"val":764},{"ts":1586123846241,"val":733},{"ts":1586124358522,"val":1079},{"ts":1586124569659,"val":828},{"ts":1586124574685,"val":836},{"ts":1586124675068,"val":804},{"ts":1586125433185,"val":813},{"ts":1586125438198,"val":815},{"ts":1586125483391,"val":978},{"ts":1586126016471,"val":743},{"ts":1586126297445,"val":766},{"ts":1586126302467,"val":756},{"ts":1586126402869,"val":779},{"ts":1586126548458,"val":750},{"ts":1586127161490,"val":767},{"ts":1586127166510,"val":764},{"ts":1586127171717,"val":761},{"ts":1586127794593,"val":1617},{"ts":1586128025626,"val":905},{"ts":1586128030654,"val":899},{"ts":1586128472584,"val":911},{"ts":1586128608291,"val":819},{"ts":1586128889780,"val":836},{"ts":1586128894822,"val":834},{"ts":1586129060578,"val":847},{"ts":1586129502477,"val":817},{"ts":1586129753556,"val":825},{"ts":1586129758573,"val":835},{"ts":1586129889197,"val":820},{"ts":1586130456695,"val":1010},{"ts":1586130617400,"val":979},{"ts":1586130622414,"val":968},{"ts":1586130692729,"val":999},{"ts":1586131039502,"val":764},{"ts":1586131481564,"val":775},{"ts":1586131486592,"val":773},{"ts":1586131647319,"val":762},{"ts":1586132320385,"val":879},{"ts":1586132345478,"val":872},{"ts":1586132350512,"val":871},{"ts":1586132465939,"val":875},{"ts":1586132712049,"val":768},{"ts":1586133209401,"val":785},{"ts":1586133214435,"val":784},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586134068484,"val":857},{"ts":1586134078520,"val":859},{"ts":1586134234292,"val":865},{"ts":1586134405104,"val":778},{"ts":1586134937634,"val":821},{"ts":1586134947677,"val":820},{"ts":1586135194019,"val":800},{"ts":1586135630884,"val":1070},{"ts":1586135801563,"val":911},{"ts":1586135806673,"val":909},{"ts":1586135856872,"val":978},{"ts":1586136333985,"val":787},{"ts":1586136665476,"val":817},{"ts":1586136670491,"val":807},{"ts":1586137288246,"val":1083},{"ts":1586137529545,"val":1031},{"ts":1586137534575,"val":1024},{"ts":1586137594815,"val":1039},{"ts":1586138363143,"val":856},{"ts":1586138393336,"val":876},{"ts":1586138398351,"val":872},{"ts":1586138523913,"val":898},{"ts":1586139141467,"val":808},{"ts":1586139256924,"val":817},{"ts":1586139261931,"val":820},{"ts":1586139287234,"val":805},{"ts":1586139337603,"val":824},{"ts":1586139372657,"val":822},{"ts":1586141223452,"val":875},{"ts":1586141263684,"val":889},{"ts":1586141665342,"val":804},{"ts":1586141846088,"val":822},{"ts":1586141851102,"val":815},{"ts":1586142383576,"val":805},{"ts":1586142634874,"val":1082},{"ts":1586142710282,"val":904},{"ts":1586142715298,"val":902},{"ts":1586142735355,"val":900},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586144671112,"val":967},{"ts":1586144866935,"val":878},{"ts":1586145303921,"val":892},{"ts":1586145308942,"val":887},{"ts":1586145715999,"val":877},{"ts":1586145891564,"val":1844},{"ts":1586145926705,"val":963},{"ts":1586147744499,"val":887},{"ts":1586147754537,"val":897},{"ts":1586147779652,"val":888},{"ts":1586149597983,"val":2232},{"ts":1586149602974,"val":2255},{"ts":1586149623100,"val":2236},{"ts":1586149628164,"val":2235},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151865176,"val":517},{"ts":1586151990748,"val":2834},{"ts":1586152216757,"val":1344},{"ts":1586152221803,"val":1581},{"ts":15861522719
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 165
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586113338503,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149618166,"val":31},{"ts":1586149623100,"val":27},{"ts":1586149628164,"val":26},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586152171544,"val":178},{"ts":1586152216757,"val":176},{"ts":1586152221803,"val":179},{"ts":1586152231836,"val":174},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157300246,"val":529},{"ts":1586157400714,"val":479},{"ts":1586157405735,"val":486},{"ts":1586157701981,"val":554},{"ts":1586158214217,"val":431},{"ts":1586158264446,"val":529},{"ts":1586158269465,"val":539},{"ts":1586158274478,"val":484},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160849462,"val":1302},{"ts":1586160854436,"val":1295},{"ts":1586160859472,"val":1311},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163201203,"val":2013},{"ts":1586163432167,"val":2555},{"ts":1586163447246,"val":2505},{"ts":1586163457301,"val":2535},{"ts":1586163492471,"val":2428},{"ts":1586164296369,"val":2949},{"ts":1586164311434,"val":2944},{"ts":1586164316483,"val":2959},{"ts":1586164326546,"val":2944},{"ts":1586165125068,"val":3417},{"ts":1586165175311,"val":3403},{"ts":1586165180333,"val":3422},{"ts":1586165185350,"val":3414},{"ts":1586166023986,"val":3881},{"ts":1586166039028,"val":3875},{"ts":1586166044050,"val":3869},{"ts":1586166069136,"val":3739},{"ts":1586166802237,"val":4301},{"ts":1586166902691,"val":4293},{"ts":1586166907709,"val":4306},{"ts":1586167269338,"val":0},{"ts":1586167736383,"val":4810},{"ts":1586167761481,"val":4799},{"ts":1586167771521,"val":4808},{"ts":1586167776534,"val":4797},{"ts":1586168625287,"val":5207},{"ts":1586168630305,"val":5192},{"ts":1586168635337,"val":5233},{"ts":1586168700563,"val":5197},{"ts":1586169363735,"val":5466},{"ts":1586169494193,"val":5442},{"ts":1586169499209,"val":5445},{"ts":1586169504228,"val":5433},{"ts":1586170327789,"val":5738},{"ts":1586170357902,"val":5688},{"ts":1586170362962,"val":5682},{"ts":1586170383054,"val":5631},{"ts":1586171070939,"val":6003},{"ts":1586171221762,"val":5935},{"ts":1586171226816,"val":5923},{"ts":1586171231815,"val":5902},{"ts":1586172005168,"val":6252},{"ts":1586172085590,"val":6220},{"ts":1586172090633,"val":6228},{"ts":1586172130792,"val":6196},{"ts":1586172949375,"val":6512},{"ts":1586172954397,"val":6506},{"ts":1586172959414,"val":6539},{"ts":1586173486746,"val":6438},{"ts":1586173707772,"val":6618},{"ts":1586173818204,"val":6576},{"ts":1586173823220,"val":6575},{"ts":1586173853322,"val":6555},{"ts":1586174470952,"val":6771},{"ts":1586174681755,"val":6739},{"ts":1586174686775,"val":6695},{"ts":1586174762088,"val":6657},{"ts":1586174817321,"val":6748},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586176878355,"val":6839},{"ts":1586177013882,"val":6751},{"ts":1586177264908,"val":6792},{"ts":1586177274960,"val":6809},{"ts":1586177631651,"val":6903},{"ts":1586178108667,"val":6732},{"ts":1586178133751,"val":6774},{"ts":1586178138772,"val":6762},{"ts":1586178294421,"val":6687},{"ts":1586178927140,"val":6891},{"ts":1586179002448,"val":6874},{"ts":1586179007467,"val":6850},{"ts":1586179052674,"val":6903},{"ts":1586179624982,"val":6728},{"ts":1586179866122,"val":6850},{"ts":1586179871175,"val":6873},{"ts":1586179926359,"val":6915},{"ts":1586180222795,"val":6761},{"ts":1586180729883,"val":6855},{"ts":1586180739936,"val":6862},{"ts":1586180749981,"val":6879},{"ts":1586181588966,"val":6612},{"ts":1586181598931,"val":6617},{"ts":1586181629064,"val":6682},{"ts":1586182427579,"val":6451},{"ts":1586182457710,"val":6503},{"ts":1586182467740,"val":6531},{"ts":1586182482790,"val":6543},{"ts":1586183196081,"val":6296},{"ts":1586183321688,"val":6324},{"ts":1586183326700,"val":6307},{"ts":1586183366863,"val":6328},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586185814664,"val":5688},{"ts":1586185909992,"val":5700},{"ts":1586185915013,"val":5712},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586188440899,"val":4708},{"ts":1586188505968,"val":4726},{"ts":1586188510998,"val":4720},{"ts":1586188516024,"val":4736},{"ts":1586189360264,"val":4243},{"ts":1586189375155,"val":4247},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586191956637,"val":2618},{"ts":1586191961669,"val":2633},{"ts":1586191966693,"val":2622},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586194545428,"val":732},{"ts":1586194550613,"val":733},{"ts":1586194555503,"val":732},{"ts":1586195414466,"val":350},{"ts":1586195419488,"val":349},{"ts":1586195424513,"val":352},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199738518,"val":0}]
                                  widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 326
                                  widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                                  widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung'
                                  widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 165
                                  widgets.min.js:3 [Line History Chart w00477] prepare dataset for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                                  widgets.min.js:3 [Line History Chart w00477] prepare yAxis for 'modbus.0.holdingRegisters.40068_PV_Leistung'
                                  widgets.min.js:3 [Line History Chart w00477] prepare chart options
                                  widgets.min.js:3 [Line History Chart w00477] chart creating...
                                  widgets.min.js:3 [Line History Chart w00477] chart successful created
                                  DevTools failed to parse SourceMap: http://192.168.86.90:8082/vis/widgets/materialdesign/lib/fonts/material-design-icons/materialdesignicons.css.map
                                  widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                                  widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 3 days
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585940557341,"end":1586199757342,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585940557341,"end":1586199757375,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 207
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585940557341,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585979410331,"val":160},{"ts":1585979425396,"val":160},{"ts":1585979445501,"val":163},{"ts":1585979500832,"val":130},{"ts":1585981580233,"val":416},{"ts":1585982027065,"val":415},{"ts":1585982032097,"val":412},{"ts":1585983418325,"val":259},{"ts":1585984202129,"val":602},{"ts":1585984618801,"val":486},{"ts":1585984623824,"val":542},{"ts":1585984789725,"val":22},{"ts":1585987204134,"val":904},{"ts":1585987209157,"val":903},{"ts":1585987214177,"val":0},{"ts":1585989488310,"val":1986},{"ts":1585989804619,"val":1895},{"ts":1585989809643,"val":1908},{"ts":1585992345235,"val":3430},{"ts":1585992395514,"val":3429},{"ts":1585992400564,"val":3448},{"ts":1585992611497,"val":3229},{"ts":1585994961493,"val":4834},{"ts":1585994986646,"val":4820},{"ts":1585994991617,"val":4829},{"ts":1585995011768,"val":4771},{"ts":1585997573034,"val":5780},{"ts":1585997578049,"val":5768},{"ts":1585997583064,"val":5771},{"ts":1585997658414,"val":5754},{"ts":1586000169320,"val":6703},{"ts":1586000174352,"val":6683},{"ts":1586001113661,"val":6654},{"ts":1586002028065,"val":6951},{"ts":1586002761211,"val":6890},{"ts":1586002766229,"val":6897},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586005353417,"val":7042},{"ts":1586005358433,"val":7047},{"ts":1586005780202,"val":7162},{"ts":1586006664079,"val":6851},{"ts":1586007945317,"val":7021},{"ts":1586007950335,"val":7044},{"ts":1586007965401,"val":7050},{"ts":1586010237076,"val":6617},{"ts":1586010533473,"val":6630},{"ts":1586010543508,"val":6605},{"ts":1586010548528,"val":6618},{"ts":1586013068196,"val":5894},{"ts":1586013128435,"val":5932},{"ts":1586013133457,"val":5934},{"ts":1586015720687,"val":4947},{"ts":1586015725716,"val":4951},{"ts":1586015730742,"val":4959},{"ts":1586018306656,"val":3283},{"ts":1586018316705,"val":3283},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586020902675,"val":1569},{"ts":1586020907697,"val":1579},{"ts":1586020912737,"val":1557},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586064956168,"val":133},{"ts":1586064971234,"val":125},{"ts":1586064976257,"val":108},{"ts":1586064981268,"val":102},{"ts":1586067446285,"val":364},{"ts":1586067561788,"val":357},{"ts":1586067581866,"val":358},{"ts":1586068209595,"val":155},{"ts":1586070142281,"val":469},{"ts":1586070157356,"val":460},{"ts":1586070162372,"val":452},{"ts":1586071834103,"val":217},{"ts":1586072532026,"val":654},{"ts":1586072747921,"val":578},{"ts":1586072752947,"val":610},{"ts":1586072838255,"val":557},{"ts":1586074319661,"val":1163},{"ts":1586076168682,"val":1785},{"ts":1586077238247,"val":0},{"ts":1586077926193,"val":2957},{"ts":1586077931233,"val":2946},{"ts":1586077936285,"val":2950},{"ts":1586077941281,"val":2947},{"ts":1586080521962,"val":4460},{"ts":1586080526978,"val":4466},{"ts":1586080537014,"val":4460},{"ts":1586083082597,"val":5622},{"ts":1586083112710,"val":5559},{"ts":1586083117723,"val":5597},{"ts":1586083127753,"val":5580},{"ts":1586085702830,"val":6392},{"ts":1586085707844,"val":6367},{"ts":1586085712863,"val":6336},{"ts":1586085763023,"val":6326},{"ts":1586088300106,"val":6946},{"ts":1586088305124,"val":6947},{"ts":1586088757078,"val":6820},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586092863505,"val":7061},{"ts":1586093300238,"val":6972},{"ts":1586093480888,"val":7021},{"ts":1586093485903,"val":7042},{"ts":1586093596415,"val":7097},{"ts":1586095897296,"val":6757},{"ts":1586096072966,"val":6802},{"ts":1586096078005,"val":6803},{"ts":1586098549248,"val":6306},{"ts":1586098664679,"val":6366},{"ts":1586098669704,"val":6372},{"ts":1586098689771,"val":6376},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586103831452,"val":4215},{"ts":1586103851517,"val":4228},{"ts":1586103856531,"val":4234},{"ts":1586103896694,"val":4243},{"ts":1586106431949,"val":2610},{"ts":1586106441980,"val":2613},{"ts":1586106446995,"val":2612},{"ts":1586109032347,"val":342},{"ts":1586109037359,"val":347},{"ts":1586109042375,"val":336},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157701981,"val":554},{"ts":1586158284528,"val":494},{"ts":1586158289593,"val":515},{"ts":1586158294569,"val":486},{"ts":1586160874540,"val":1323},{"ts":1586160879573,"val":1330},{"ts":1586160889593,"val":1320},{"ts":1586163467336,"val":2581},{"ts":1586163472352,"val":2575},{"ts":1586163492471,"val":2428},{"ts":1586166023986,"val":3881},{"ts":1586166059103,"val":3875},{"ts":1586166069136,"val":3739},{"ts":1586167269338,"val":0},{"ts":1586168635337,"val":5233},{"ts":1586168650393,"val":5223},{"ts":1586168660426,"val":5221},{"ts":1586168700563,"val":5197},{"ts":1586171070939,"val":6003},{"ts":1586171241844,"val":5963},{"ts":1586171246863,"val":5986},{"ts":1586171322201,"val":5958},{"ts":1586173707772,"val":6618},{"ts":1586173833259,"val":6562},{"ts":1586173838275,"val":6568},{"ts":1586173853322,"val":6555},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586177631651,"val":6903},{"ts":1586178294421,"val":6687},{"ts":1586179017513,"val":6839},{"ts":1586179022544,"val":6850},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181608974,"val":6647},{"ts":1586181613979,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586189385203,"val":4233},{"ts":1586189390219,"val":4236},{"ts":1586191976725,"val":2617},{"ts":1586191981746,"val":2614},{"ts":1586191986769,"val":2617},{"ts":1586194570862,"val":725},{"ts":1586194575555,"val":723},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199757375,"val":0}]
                                  setTimeout (async)
                                  o @ widgets.min.js:3
                                  t.dispatch @ can.custom.min.js:18
                                  stop @ can.custom.min.js:44
                                  _setAttrs @ can.custom.min.js:48
                                  attr @ can.custom.min.js:48
                                  (anonymous) @ vis.js:311
                                  a.add @ index.js:83
                                  widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 207
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 397
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585940557341,"val":1493.966487133453},{"ts":1585940557509,"val":1494},{"ts":1585941119725,"val":4620},{"ts":1585941556689,"val":816},{"ts":1585941958208,"val":1429},{"ts":1585943776013,"val":3400},{"ts":1585943781004,"val":3394},{"ts":1585943791038,"val":4658},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585948217175,"val":1651},{"ts":1585950067209,"val":1609},{"ts":1585950513825,"val":959},{"ts":1585950694493,"val":3047},{"ts":1585950920474,"val":1458},{"ts":1585950925489,"val":1441},{"ts":1585951005790,"val":2281},{"ts":1585951030887,"val":1036},{"ts":1585953512452,"val":1128},{"ts":1585953517472,"val":1125},{"ts":1585954144921,"val":1145},{"ts":1585956084287,"val":918},{"ts":1585956104350,"val":922},{"ts":1585956109368,"val":927},{"ts":1585956164595,"val":918},{"ts":1585956209779,"val":1009},{"ts":1585958699755,"val":1001},{"ts":1585958704778,"val":997},{"ts":1585958744944,"val":1015},{"ts":1585961256928,"val":374},{"ts":1585961292052,"val":375},{"ts":1585961297064,"val":387},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963882496,"val":591},{"ts":1585963887522,"val":585},{"ts":1585963892538,"val":591},{"ts":1585966297472,"val":369},{"ts":1585966473174,"val":384},{"ts":1585966478204,"val":388},{"ts":1585966483209,"val":384},{"ts":1585966598601,"val":768},{"ts":1585969068361,"val":447},{"ts":1585969073380,"val":443},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585971658569,"val":388},{"ts":1585971663581,"val":390},{"ts":1585971763990,"val":377},{"ts":1585973827422,"val":1271},{"ts":1585974249062,"val":978},{"ts":1585974254074,"val":972},{"ts":1585975162738,"val":1677},{"ts":1585976834267,"val":953},{"ts":1585976844306,"val":961},{"ts":1585976849318,"val":965},{"ts":1585977411665,"val":1070},{"ts":1585979345075,"val":872},{"ts":1585979435460,"val":891},{"ts":1585979440480,"val":890},{"ts":1585980003100,"val":912},{"ts":1585980148705,"val":348},{"ts":1585982027065,"val":389},{"ts":1585982032097,"val":380},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585984618801,"val":641},{"ts":1585984623824,"val":983},{"ts":1585985718318,"val":879},{"ts":1585987194094,"val":2630},{"ts":1585987209157,"val":1471},{"ts":1585987214177,"val":1428},{"ts":1585987244266,"val":1332},{"ts":1585989161988,"val":3025},{"ts":1585989804620,"val":1735},{"ts":1585989809643,"val":2760},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992395514,"val":1674},{"ts":1585992400564,"val":1330},{"ts":1585992661663,"val":917},{"ts":1585994248405,"val":3707},{"ts":1585994986646,"val":1593},{"ts":1585994991618,"val":1562},{"ts":1585995252796,"val":2874},{"ts":1585996704240,"val":1231},{"ts":1585997578049,"val":1275},{"ts":1585997583064,"val":1309},{"ts":1585997663448,"val":1258},{"ts":1585998266153,"val":2610},{"ts":1586000169320,"val":1314},{"ts":1586000174353,"val":1308},{"ts":1586001113661,"val":1185},{"ts":1586002610627,"val":2655},{"ts":1586002761211,"val":1532},{"ts":1586002766231,"val":1533},{"ts":1586003238503,"val":6525},{"ts":1586005338344,"val":1427},{"ts":1586005353417,"val":2541},{"ts":1586005358434,"val":1430},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586007945317,"val":1407},{"ts":1586007950335,"val":1432},{"ts":1586007995500,"val":2551},{"ts":1586010262197,"val":1360},{"ts":1586010538490,"val":1390},{"ts":1586010543509,"val":1370},{"ts":1586012500505,"val":2479},{"ts":1586012972700,"val":334},{"ts":1586013128435,"val":2425},{"ts":1586013133457,"val":1550},{"ts":1586014048013,"val":1255},{"ts":1586014384795,"val":2524},{"ts":1586015720687,"val":1261},{"ts":1586015725735,"val":1274},{"ts":1586015881337,"val":1170},{"ts":1586017402800,"val":2539},{"ts":1586018316705,"val":1475},{"ts":1586018321812,"val":1188},{"ts":1586018447204,"val":2311},{"ts":1586020882757,"val":607},{"ts":1586020907697,"val":622},{"ts":1586020912755,"val":620},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586023499221,"val":357},{"ts":1586023504304,"val":327},{"ts":1586023514357,"val":0},{"ts":1586024840244,"val":2290},{"ts":1586026091762,"val":1026},{"ts":1586026096785,"val":510},{"ts":1586026111837,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586028683486,"val":702},{"ts":1586028688500,"val":0},{"ts":1586031230910,"val":2558},{"ts":1586031276229,"val":809},{"ts":1586031281181,"val":918},{"ts":1586032536892,"val":150},{"ts":1586033536704,"val":2855},{"ts":1586033868131,"val":1139},{"ts":1586033873142,"val":1577},{"ts":1586034682203,"val":291},{"ts":1586036078983,"val":2692},{"ts":1586036460721,"val":853},{"ts":1586036465735,"val":1001},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586039053191,"val":1032},{"ts":1586039058211,"val":590},{"ts":1586039113413,"val":0},{"ts":1586040704830,"val"
                                  widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 7 days
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594965660,"end":1586199765664,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594965660,"end":1586199765672,"timeout":2000}
                                  2widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                                  setTimeout (async)
                                  r.onack @ index.js:83
                                  r.onpacket @ index.js:83
                                  (anonymous) @ index.js:83
                                  r.emit @ index.js:83
                                  r.ondecoded @ index.js:83
                                  a.add @ index.js:83
                                  r.ondata @ index.js:83
                                  r.onPacket @ index.js:83
                                  r.onData @ index.js:83
                                  ws.onmessage @ index.js:83
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 133
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585594965660,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585891306695,"val":46},{"ts":1585891316733,"val":43},{"ts":1585891321759,"val":53},{"ts":1585897185165,"val":0},{"ts":1585897305676,"val":596},{"ts":1585897361130,"val":575},{"ts":1585897365959,"val":584},{"ts":1585897747504,"val":269},{"ts":1585903394072,"val":2106},{"ts":1585903409019,"val":2106},{"ts":1585903414039,"val":2116},{"ts":1585903419055,"val":2093},{"ts":1585909457181,"val":5275},{"ts":1585909462256,"val":5273},{"ts":1585909532468,"val":5220},{"ts":1585915334368,"val":6874},{"ts":1585915505122,"val":6855},{"ts":1585915510143,"val":6857},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921552767,"val":7068},{"ts":1585921557800,"val":7070},{"ts":1585921628137,"val":7093},{"ts":1585927444855,"val":1193},{"ts":1585927600539,"val":1279},{"ts":1585927605707,"val":1271},{"ts":1585927926879,"val":6109},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585981580233,"val":416},{"ts":1585982037109,"val":411},{"ts":1585982042123,"val":414},{"ts":1585987214177,"val":0},{"ts":1585988067501,"val":1294},{"ts":1585988082563,"val":1281},{"ts":1585988087572,"val":1293},{"ts":1585988092587,"val":1291},{"ts":1585994117847,"val":4449},{"ts":1585994132909,"val":4376},{"ts":1585994137923,"val":4362},{"ts":1585994248405,"val":4116},{"ts":1586000179374,"val":6704},{"ts":1586000184399,"val":6718},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586006227106,"val":7039},{"ts":1586006232205,"val":7057},{"ts":1586007086047,"val":7110},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586066698141,"val":255},{"ts":1586066708178,"val":253},{"ts":1586066713192,"val":254},{"ts":1586068209595,"val":155},{"ts":1586072532026,"val":654},{"ts":1586072752947,"val":610},{"ts":1586072757965,"val":566},{"ts":1586077238247,"val":0},{"ts":1586078784835,"val":3492},{"ts":1586078804939,"val":3458},{"ts":1586078810042,"val":3456},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093596415,"val":7097},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586102993321,"val":4694},{"ts":1586102998338,"val":4683},{"ts":1586109042375,"val":336},{"ts":1586109047386,"val":329},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586157300246,"val":529},{"ts":1586157425812,"val":518},{"ts":1586157430842,"val":498},{"ts":1586158214217,"val":431},{"ts":1586163467336,"val":2581},{"ts":1586163477369,"val":2581},{"ts":1586163487412,"val":2566},{"ts":1586167269338,"val":0},{"ts":1586169363735,"val":5466},{"ts":1586169524305,"val":5448},{"ts":1586169529329,"val":5469},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181619171,"val":6664},{"ts":1586181624020,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199765672,"val":0}]
                                  widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - TimeInterval by Editor **************************************************************
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594968557,"end":1586199768562,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585594968557,"end":1586199768567,"timeout":2000}
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 230
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585594965660,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585860971999,"val":1361},{"ts":1585861809586,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585867125428,"val":608},{"ts":1585867130446,"val":807},{"ts":1585871728785,"val":2806},{"ts":1585872582450,"val":259},{"ts":1585873169522,"val":956},{"ts":1585873174535,"val":390},{"ts":1585873425472,"val":2692},{"ts":1585875468113,"val":0},{"ts":1585879220150,"val":216},{"ts":1585879225212,"val":219},{"ts":1585879300521,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585885263599,"val":282},{"ts":1585885273627,"val":327},{"ts":1585885368978,"val":0},{"ts":1585891211257,"val":2620},{"ts":1585891316733,"val":1650},{"ts":1585891321769,"val":1277},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585897361130,"val":1548},{"ts":1585897365959,"val":1455},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903409020,"val":712},{"ts":1585903414039,"val":872},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585909457181,"val":2250},{"ts":1585909462258,"val":2204},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585915505124,"val":1641},{"ts":1585915510143,"val":1637},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585921552767,"val":1540},{"ts":1585921557800,"val":1536},{"ts":1585921663313,"val":2673},{"ts":1585927419689,"val":696},{"ts":1585927600539,"val":1376},{"ts":1585927605707,"val":868},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939698950,"val":1980},{"ts":1585939703970,"val":1825},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963892538,"val":591},{"ts":1585963897559,"val":588},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585969936897,"val":380},{"ts":1585969941912,"val":377},{"ts":1585970172785,"val":376},{"ts":1585970197879,"val":1802},{"ts":1585975981062,"val":976},{"ts":1585975991103,"val":983},{"ts":1585976432703,"val":1087},{"ts":1585980148705,"val":348},{"ts":1585982037109,"val":391},{"ts":1585982042123,"val":390},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585988082563,"val":1564},{"ts":1585988087572,"val":1563},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585994132910,"val":2150},{"ts":1585994137923,"val":2553},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1586000179374,"val":1686},{"ts":1586000184399,"val":1310},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586006222093,"val":1436},{"ts":1586006232206,"val":1442},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017402800,"val":2539},{"ts":1586018321812,"val":1188},{"ts":1586018326728,"val":2304},{"ts":1586018447204,"val":2311},{"ts":1586022484981,"val":0},{"ts":1586024373037,"val":612},{"ts":1586024378059,"val":574},{"ts":1586024508643,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586030416942,"val":296},{"ts":1586030423081,"val":228},{"ts":1586030522456,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586036465735,"val":1001},{"ts":1586036470755,"val":973},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586042516828,"val":410},{"ts":1586042521838,"val":283},{"ts":1586042526870,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586048561350,"val":553},{"ts":1586048566369,"val":326},{"ts":1586048611524,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586054610113,"val":871},{"ts":1586054615138,"val":838},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586060658896,"val":400},{"ts":1586060663945,"val":354},{"ts":1586060673971,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066708178,"val":553},{"ts":1586066713192,"val":443},{"ts":1586066738312,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586072752947,"val":1278},{"ts":1586072757965,"val":1122},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586078804939,"val":3104},{"ts":1586078810043,"val":3049},{"ts":1586079186687,"val":1134},{"ts":1586082545523,"val":3320},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586102621756,"val":6094},{"ts":1586102993321,"val":1357},{"ts":1586102998338,"val":1352},{"ts":1586103083636,"val":2490},{"ts":1586108164066,"val":110},{"ts":1586109042375,"val":735},{"ts":1586109047387,"val":837},{"ts":1586109218231,"val":0},{"ts":1586114792624,"val":3769},{"ts":1586115088771,"val":2002},{"ts":1586115093790,"val":2011},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586121138991,"val":1289},{"ts":1586121144012,"val":1291},{"ts":1586121470673,"val":1481},{"ts":1586123846241,"val":733},{"ts":1586127186563,"val":775},{"ts":1586127191579,"val":766},{"ts":1586127201621,"val":762},{"ts":1586127794593,"val":1617},{"ts":1586133234497,"val":784},{"ts":1586133239574,"val":786},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586139282099,"val":820},{"ts":1586139287234,"val":805},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586145329017,"val":891},{"ts":1586145334099,"val":890},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586152271986,"val":459},{"ts":1586157059190,"val":2999},{"ts":1586157425813,"val":815},{"ts":1586157430842,"val":988},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586163477370,"val":1600},{"ts":1586163482397,"val":1589},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586169524306,"val":5683},{"ts":1586169529329,"val":1743},{"ts":1586169634764,"val":5949},{"ts":1586169770472,"val":1072},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586181619171,"val":1147},{"ts":1586181624020,"val":1253},{"ts":1586182377307,"val":2336},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586199761872,"val":1223},{"ts":1586199765664,"val":1223}]
                                  setTimeout (async)
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585594968557,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585891306695,"val":46},{"ts":1585891316733,"val":43},{"ts":1585891321759,"val":53},{"ts":1585897185165,"val":0},{"ts":1585897305676,"val":596},{"ts":1585897365959,"val":584},{"ts":1585897370985,"val":576},{"ts":1585897747504,"val":269},{"ts":1585903414039,"val":2116},{"ts":1585903419055,"val":2093},{"ts":1585909457181,"val":5275},{"ts":1585909462256,"val":5273},{"ts":1585909467217,"val":5281},{"ts":1585909532468,"val":5220},{"ts":1585915334368,"val":6874},{"ts":1585915510143,"val":6857},{"ts":1585915515159,"val":6867},{"ts":1585920005966,"val":7206},{"ts":1585920578493,"val":4454},{"ts":1585921557800,"val":7070},{"ts":1585921562829,"val":7068},{"ts":1585921628137,"val":7093},{"ts":1585927444855,"val":1193},{"ts":1585927605707,"val":1271},{"ts":1585927610569,"val":1270},{"ts":1585927926879,"val":6109},{"ts":1585933060519,"val":740},{"ts":1585933221231,"val":2329},{"ts":1585935071724,"val":246},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585981580233,"val":416},{"ts":1585982037109,"val":411},{"ts":1585982042123,"val":414},{"ts":1585987214177,"val":0},{"ts":1585988067501,"val":1294},{"ts":1585988087572,"val":1293},{"ts":1585988092587,"val":1291},{"ts":1585994117847,"val":4449},{"ts":1585994132909,"val":4376},{"ts":1585994137923,"val":4362},{"ts":1585994248405,"val":4116},{"ts":1586000184399,"val":6718},{"ts":1586000189417,"val":6719},{"ts":1586003695567,"val":6098},{"ts":1586005780202,"val":7162},{"ts":1586006232205,"val":7057},{"ts":1586006237201,"val":7051},{"ts":1586007086047,"val":7110},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586018321812,"val":3267},{"ts":1586018326728,"val":3282},{"ts":1586018331752,"val":3261},{"ts":1586018341800,"val":3265},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586066698141,"val":255},{"ts":1586066708178,"val":253},{"ts":1586066713192,"val":254},{"ts":1586068209595,"val":155},{"ts":1586072532026,"val":654},{"ts":1586072757965,"val":566},{"ts":1586072762980,"val":581},{"ts":1586077238247,"val":0},{"ts":1586078784835,"val":3492},{"ts":1586078804939,"val":3458},{"ts":1586078810042,"val":3456},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093596415,"val":7097},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586102998338,"val":4683},{"ts":1586103003361,"val":4677},{"ts":1586103008412,"val":4681},{"ts":1586109047386,"val":329},{"ts":1586109052403,"val":325},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586157300246,"val":529},{"ts":1586157430842,"val":498},{"ts":1586157435871,"val":489},{"ts":1586158214217,"val":431},{"ts":1586163467336,"val":2581},{"ts":1586163477369,"val":2581},{"ts":1586163487412,"val":2566},{"ts":1586167269338,"val":0},{"ts":1586169363735,"val":5466},{"ts":1586169524305,"val":5448},{"ts":1586169529329,"val":5469},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586179926359,"val":6915},{"ts":1586181588966,"val":6612},{"ts":1586181624020,"val":6653},{"ts":1586181629064,"val":6682},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586199768567,"val":0}]
                                  widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585594968557,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585860971999,"val":1361},{"ts":1585861809586,"val":1361},{"ts":1585865022126,"val":2729},{"ts":1585865468975,"val":251},{"ts":1585867125428,"val":608},{"ts":1585867130446,"val":807},{"ts":1585871728785,"val":2806},{"ts":1585872582450,"val":259},{"ts":1585873174535,"val":390},{"ts":1585873179557,"val":914},{"ts":1585873425472,"val":2692},{"ts":1585875468113,"val":0},{"ts":1585879220150,"val":216},{"ts":1585879225212,"val":219},{"ts":1585879300521,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585885263599,"val":282},{"ts":1585885273627,"val":327},{"ts":1585885368978,"val":0},{"ts":1585891211257,"val":2620},{"ts":1585891316733,"val":1650},{"ts":1585891321769,"val":1277},{"ts":1585893505542,"val":6581},{"ts":1585895006597,"val":354},{"ts":1585897365959,"val":1455},{"ts":1585897370985,"val":1462},{"ts":1585901110985,"val":3204},{"ts":1585903378770,"val":148},{"ts":1585903414039,"val":872},{"ts":1585903419055,"val":637},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585909462258,"val":2204},{"ts":1585909467218,"val":2375},{"ts":1585909748464,"val":4180},{"ts":1585910547158,"val":1413},{"ts":1585915510143,"val":1637},{"ts":1585915515159,"val":1652},{"ts":1585917263083,"val":1452},{"ts":1585917710085,"val":4053},{"ts":1585921557800,"val":1536},{"ts":1585921562829,"val":1553},{"ts":1585921663313,"val":2673},{"ts":1585927419689,"val":696},{"ts":1585927605707,"val":868},{"ts":1585927610570,"val":924},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585933221231,"val":3544},{"ts":1585935071759,"val":2316},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585939703970,"val":1825},{"ts":1585939708998,"val":3971},{"ts":1585940045484,"val":5141},{"ts":1585941556689,"val":816},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585951200119,"val":1433},{"ts":1585952920056,"val":1176},{"ts":1585953181158,"val":1290},{"ts":1585956084287,"val":918},{"ts":1585956882607,"val":989},{"ts":1585958699755,"val":1001},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585963892538,"val":591},{"ts":1585963897559,"val":588},{"ts":1585966297472,"val":369},{"ts":1585966598601,"val":768},{"ts":1585969941912,"val":377},{"ts":1585969946930,"val":379},{"ts":1585970172785,"val":376},{"ts":1585970197879,"val":1802},{"ts":1585975991103,"val":983},{"ts":1585975996118,"val":988},{"ts":1585976432703,"val":1087},{"ts":1585980148705,"val":348},{"ts":1585982037109,"val":391},{"ts":1585982042123,"val":390},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585988087572,"val":1563},{"ts":1585988092588,"val":2034},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585994132910,"val":2150},{"ts":1585994137923,"val":2553},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1586000184399,"val":1310},{"ts":1586000189417,"val":1311},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586006232206,"val":1442},{"ts":1586006237202,"val":1429},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017402800,"val":2539},{"ts":1586018326728,"val":2304},{"ts":1586018331753,"val":1199},{"ts":1586018447204,"val":2311},{"ts":1586022484981,"val":0},{"ts":1586024373037,"val":612},{"ts":1586024378059,"val":574},{"ts":1586024508643,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586030423081,"val":228},{"ts":1586030426972,"val":389},{"ts":1586030522456,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586036470755,"val":973},{"ts":1586036475773,"val":995},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586042516828,"val":410},{"ts":1586042521838,"val":283},{"ts":1586042526870,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586048566369,"val":326},{"ts":1586048571383,"val":1088},{"ts":1586048611524,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586054615138,"val":838},{"ts":1586054620170,"val":397},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586060663945,"val":354},{"ts":1586060668943,"val":304},{"ts":1586060673971,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586066708178,"val":553},{"ts":1586066713192,"val":443},{"ts":1586066738312,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586072757965,"val":1122},{"ts":1586072762980,"val":2978},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586078804939,"val":3104},{"ts":1586078810043,"val":3049},{"ts":1586079186687,"val":1134},{"ts":1586082545523,"val":3320},{"ts":1586083805273,"val":1322},{"ts":1586085622533,"val":1459},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586090750716,"val":809},{"ts":1586092567284,"val":923},{"ts":1586093300238,"val":807},{"ts":1586095857154,"val":2851},{"ts":1586096243592,"val":1370},{"ts":1586098092533,"val":1285},{"ts":1586098177848,"val":1267},{"ts":1586102621756,"val":6094},{"ts":1586102998338,"val":1352},{"ts":1586103003361,"val":1350},{"ts":1586103083636,"val":2490},{"ts":1586108164066,"val":110},{"ts":1586109047387,"val":837},{"ts":1586109052404,"val":306},{"ts":1586109218231,"val":0},{"ts":1586114792624,"val":3769},{"ts":1586115093790,"val":2011},{"ts":1586115098809,"val":2006},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586121144012,"val":1291},{"ts":1586121149035,"val":1295},{"ts":1586121470673,"val":1481},{"ts":1586123846241,"val":733},{"ts":1586127191579,"val":766},{"ts":1586127196605,"val":772},{"ts":1586127201621,"val":762},{"ts":1586127794593,"val":1617},{"ts":1586133239574,"val":786},{"ts":1586133244601,"val":791},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586139287234,"val":805},{"ts":1586139292143,"val":813},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586145334099,"val":890},{"ts":1586145339142,"val":892},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586152271986,"val":459},{"ts":1586157059190,"val":2999},{"ts":1586157430842,"val":988},{"ts":1586157435871,"val":734},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586163477370,"val":1600},{"ts":1586163482397,"val":1589},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586169524306,"val":5683},{"ts":1586169529329,"val":1743},{"ts":1586169634764,"val":5949},{"ts":1586169770472,"val":1072},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586181624020,"val":1253},{"ts":1586181629064,"val":1202},{"ts":1586182377307,"val":2336},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586199761872,"val":1223},{"ts":1586199768562,"val":1223}]
                                  Vielen Dank!
                                  • Scrounger
                                    @Chris-Tailor
                                    Also laut log werden die Daten modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung nicht korrekt geladen, bekomst einen timeout - werden diese trotzdem angezeit?
                                    Ich hab den timeout jetzt mal erhöht und noch eine kleine Optimierung eingebaut.
                                    Bitte teste die aktuelle git version 0.2.79 und stell dann wieder das consolen log zur verfügung
                                    Chris Tailor 1 Reply Last reply Reply Quote 0
                                    • Chris Tailor
                                      Chris Tailor @Scrounger last edited by Chris Tailor
                                      @Scrounger Super, mit der neusten Version hatte ich nur beim ersten Test ein Timeout. Nach einem Refresh der Seite konnte ich dann den Fehler nicht mehr reproduzieren (PV Daten für 1 Tag, 3 tage, 7 Tage, 1 Monat und 7 Monate). Nachfolgend findest du noch die Log Daten vom ersten Versuch mit einem einmaligen Timeout. Das Timeout wird nun auf direkt in der Grafik rot dargestellt, verschwindet dann aber auch bei erfolgreicher Aktualisierung nicht mehr. Evtl. ist das noch ein kleiner Bug oder ist so gewollt.
                                      Vielen Dank für die super Widgets!
                                      materialdesign.js:25 Version vis-materialdesign: 0.2.79
                                      conn.js:273 2020-04-07T04:46:12.512Z Connected => authenticate
                                      conn.js:293 2020-04-07T04:46:12.777Z Authenticated: true
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774189,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1586148374187,"end":1586234774196,"timeout":5000}
                                      widgets.min.js:1 version: "0.2.79"
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1586148374187,"val":1327.4442156021098},{"ts":1586149597983,"val":2232},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151835018,"val":1543},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586152397495,"val":1130},{"ts":1586154246636,"val":796},{"ts":1586154352009,"val":2636},{"ts":1586154417313,"val":634},{"ts":1586154422357,"val":955},{"ts":1586154663511,"val":2283},{"ts":1586154723886,"val":583},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586156823024,"val":487},{"ts":1586156948480,"val":2873},{"ts":1586157013929,"val":1085},{"ts":1586157019290,"val":1299},{"ts":1586157059190,"val":2999},{"ts":1586157501173,"val":456},{"ts":1586157877787,"val":1058},{"ts":1586157882817,"val":1094},{"ts":1586158133821,"val":2445},{"ts":1586158173998,"val":241},{"ts":1586158299582,"val":1174},{"ts":1586160116497,"val":1260},{"ts":1586160141561,"val":699},{"ts":1586160352393,"val":2481},{"ts":1586160467840,"val":1229},{"ts":1586160472858,"val":1048},{"ts":1586160668587,"val":692},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586162915020,"val":842},{"ts":1586163025417,"val":2587},{"ts":1586163060542,"val":2114},{"ts":1586163065583,"val":1685},{"ts":1586163859139,"val":608},{"ts":1586163894422,"val":3020},{"ts":1586163924599,"val":1270},{"ts":1586163929732,"val":1557},{"ts":1586164326546,"val":343},{"ts":1586164547538,"val":2657},{"ts":1586164788528,"val":619},{"ts":1586164793558,"val":839},{"ts":1586164803603,"val":179},{"ts":1586164833735,"val":2418},{"ts":1586165652422,"val":1180},{"ts":1586165657413,"val":1042},{"ts":1586165833241,"val":2857},{"ts":1586165843277,"val":518},{"ts":1586166516032,"val":1036},{"ts":1586166521148,"val":1032},{"ts":1586167264278,"val":0},{"ts":1586167304445,"val":3352},{"ts":1586167379784,"val":1133},{"ts":1586167384773,"val":1116},{"ts":1586167580686,"val":6177},{"ts":1586168223534,"val":1011},{"ts":1586168243644,"val":1195},{"ts":1586168248660,"val":1193},{"ts":1586168660426,"val":969},{"ts":1586169006924,"val":5908},{"ts":1586169107536,"val":2328},{"ts":1586169112558,"val":4193},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586169971411,"val":1122},{"ts":1586169976352,"val":1885},{"ts":1586169981368,"val":1101},{"ts":1586170784666,"val":3550},{"ts":1586170834915,"val":2165},{"ts":1586170839942,"val":2184},{"ts":1586171608485,"val":3424},{"ts":1586171683774,"val":1561},{"ts":1586171698823,"val":1740},{"ts":1586171703843,"val":1591},{"ts":1586171874540,"val":1483},{"ts":1586171959900,"val":3358},{"ts":1586172562761,"val":1589},{"ts":1586172567779,"val":1584},{"ts":1586172587859,"val":2730},{"ts":1586172733478,"val":1364},{"ts":1586173426515,"val":1396},{"ts":1586173431530,"val":1403},{"ts":1586173582135,"val":2597},{"ts":1586174204747,"val":1274},{"ts":1586174290075,"val":1319},{"ts":1586174295089,"val":1302},{"ts":1586174315178,"val":2468},{"ts":1586174832405,"val":1173},{"ts":1586176682560,"val":1412},{"ts":1586176737808,"val":1169},{"ts":1586176813130,"val":2340},{"ts":1586176883374,"val":1182},{"ts":1586176888399,"val":1257},{"ts":1586177059091,"val":1173},{"ts":1586177174546,"val":2474},{"ts":1586177747129,"val":1785},{"ts":1586177752151,"val":1205},{"ts":1586178083588,"val":2360},{"ts":1586178309483,"val":1067},{"ts":1586178610816,"val":1102},{"ts":1586178615809,"val":1121},{"ts":1586179112913,"val":2420},{"ts":1586179429232,"val":1008},{"ts":1586179474399,"val":1104},{"ts":1586179479418,"val":1113},{"ts":1586179680252,"val":1066},{"ts":1586180298136,"val":2347},{"ts":1586180338299,"val":1240},{"ts":1586180343322,"val":1536},{"ts":1586180493947,"val":2418},{"ts":1586181151867,"val":1137},{"ts":1586181202061,"val":1166},{"ts":1586181207076,"val":2261},{"ts":1586181488430,"val":1103},{"ts":1586181850020,"val":2312},{"ts":1586182065925,"val":1178},{"ts":1586182070988,"val":1166},{"ts":1586182377307,"val":2336},{"ts":1586182427580,"val":1108},{"ts":1586182929855,"val":2113},{"ts":1586182934864,"val":1112},{"ts":1586182969994,"val":2313},{"ts":1586183743608,"val":1052},{"ts":1586183793806,"val":1070},{"ts":1586183798847,"val":1084},{"ts":1586183879231,"val":2297},{"ts":1586183919347,"val":589},{"ts":1586185769496,"val":858},{"ts":1586185809646,"val":1722},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586188104226,"val":525},{"ts":1586188114254,"val":533},{"ts":1586188119270,"val":524},{"ts":1586188264864,"val":1683},{"ts":1586188591383,"val":482},{"ts":1586188978417,"val":494},{"ts":1586188983441,"val":1004},{"ts":1586189360267,"val":464},{"ts":1586189515728,"val":1656},{"ts":1586189761817,"val":960},{"ts":1586191579896,"val":1463},{"ts":1586191670467,"val":649},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194048203,"val":861},{"ts":1586194123540,"val":2252},{"ts":1586194163696,"val":1231},{"ts":1586194168712,"val":698},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586195027708,"val":2012},{"ts":1586195032801,"val":1232},{"ts":1586195113268,"val":2421},{"ts":1586195595240,"val":341},{"ts":1586195891661,"val":1067},{"ts":1586195896677,"val":1048},{"ts":1586196052372,"val":1061},{"ts":1586196107619,"val":1008},{"ts":1586196152901,"val":1046},{"ts":1586198002185,"val":1024},{"ts":1586198227952,"val":1009},{"ts":1586198423669,"val":1050},{"ts":1586198483865,"val":1035},{"ts":1586198488881,"val":1043},{"ts":1586198644430,"val":1533},{"ts":1586198860059,"val":986},{"ts":1586199349454,"val":1184},{"ts":1586199354483,"val":1173},{"ts":1586199445083,"val":1156},{"ts":1586199475251,"val":1385},{"ts":1586200209314,"val":1214},{"ts":1586200214344,"val":1201},{"ts":1586200962577,"val":891},{"ts":1586200977621,"val":1396},{"ts":1586201078091,"val":1363},{"ts":1586201083300,"val":1372},{"ts":1586201228710,"val":1401},{"ts":1586201851444,"val":1206},{"ts":1586201941764,"val":1224},{"ts":1586201946777,"val":1216},{"ts":1586202107409,"val":1711},{"ts":1586202373415,"val":1210},{"ts":1586202805391,"val":1235},{"ts":1586202810411,"val":1239},{"ts":1586202815428,"val":1249},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586205393574,"val":750},{"ts":1586205398606,"val":749},{"ts":1586206096897,"val":613},{"ts":1586206257486,"val":645},{"ts":1586206262504,"val":652},{"ts":1586206302655,"val":612},{"ts":1586206403066,"val":644},{"ts":1586208252581,"val":690},{"ts":1586208342895,"val":0},{"ts":1586208362985,"val":779},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586210321912,"val":545},{"ts":1586210403395,"val":564},{"ts":1586210577994,"val":554},{"ts":1586210583013,"val":548},{"ts":1586210613137,"val":544},{"ts":1586210753758,"val":678},{"ts":1586211341349,"val":547},{"ts":1586213190303,"val":298},{"ts":1586213260773,"val":309},{"ts":1586213406398,"val":287},{"ts":1586213436537,"val":301},{"ts":1586215291547,"val":882},{"ts":1586215296559,"val":886},{"ts":1586215605005,"val":747},{"ts":1586215765662,"val":795},{"ts":1586215770697,"val":800},{"ts":1586215896315,"val":784},{"ts":1586216061985,"val":811},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218188358,"val":925},{"ts":1586218348946,"val":1032},{"ts":1586218353962,"val":1029},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586219217540,"val":866},{"ts":1586219227581,"val":869},{"ts":1586219232600,"val":864},{"ts":1586219272768,"val":896},{"ts":1586219438425,"val":877},{"ts":1586221288103,"val":876},{"ts":1586221303149,"val":872},{"ts":1586221313182,"val":885},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223262888,"val":268},{"ts":1586223539019,"val":1082},{"ts":1586223544144,"val":463},{"ts":1586223800107,"val":333},{"ts":1586224402596,"val":363},{"ts":1586224407611,"val":361},{"ts":1586224613434,"val":366},{"ts":1586225020230,"val":262},{"ts":1586225266226,"val":263},{"ts":1586225271240,"val":270},{"ts":1586225642729,"val":300},{"ts":1586225768246,"val":259},{"ts":1586225923884,"val":279},{"ts":1586227741595,"val":418},{"ts":1586227862087,"val":336},{"ts":1586227867114,"val":335},{"ts":1586228173435,"val":324},{"ts":1586228509926,"val":444},{"ts":1586228725822,"val":381},{"ts":1586228730838,"val":350},{"ts":1586229343264,"val":327},{"ts":1586229544046,"val":354},{"ts":1586229589180,"val":335},{"ts":1586229594214,"val":330},{"ts":1586229614279,"val":329},{"ts":1586229634350,"val":484},{"ts":1586230452867,"val":351},{"ts":1586230457902,"val":352},{"ts":1586230593504,"val":357},{"ts":1586231045444,"val":274},{"ts":1586231170977,"val":276},{"ts":1586233021191,"val":1662},{"ts":1586233026198,"val":1666},{"ts":1586233031215,"val":1656},{"ts":1586233041249,"val":1660},{"ts":1586233046265,"val":1663},{"ts":1586233051280,"val":1661},{"ts":1586234311418,"val":1661},{"ts":1586234317314,"val":1661},{"ts":1586234774189,"val":1661}]
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1586148374187,"val":22.852575024652907},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151850123,"val":161},{"ts":1586151870190,"val":154},{"ts":1586152397495,"val":188},{"ts":1586154246635,"val":341},{"ts":1586154326917,"val":352},{"ts":1586154382143,"val":327},{"ts":1586154417313,"val":340},{"ts":1586154422340,"val":311},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586157009004,"val":489},{"ts":1586157013929,"val":475},{"ts":1586157019289,"val":455},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586157877787,"val":528},{"ts":1586157882817,"val":484},{"ts":1586158028351,"val":550},{"ts":1586158214217,"val":431},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160467840,"val":1122},{"ts":1586160472858,"val":1131},{"ts":1586160512990,"val":1121},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163030429,"val":2099},{"ts":1586163060542,"val":2116},{"ts":1586163070600,"val":2126},{"ts":1586163201203,"val":2013},{"ts":1586163919495,"val":2785},{"ts":1586163924598,"val":2783},{"ts":1586163934646,"val":2791},{"ts":1586164100481,"val":2746},{"ts":1586164778599,"val":3246},{"ts":1586164788528,"val":3222},{"ts":1586164793558,"val":3238},{"ts":1586164803603,"val":3200},{"ts":1586165652422,"val":3718},{"ts":1586165657413,"val":3713},{"ts":1586165873391,"val":3676},{"ts":1586166511020,"val":4153},{"ts":1586166516032,"val":4147},{"ts":1586166521148,"val":4134},{"ts":1586167269338,"val":0},{"ts":1586167374687,"val":4561},{"ts":1586167379784,"val":4552},{"ts":1586167384773,"val":4556},{"ts":1586168243644,"val":5082},{"ts":1586168248660,"val":5091},{"ts":1586168308842,"val":5018},{"ts":1586169047220,"val":5333},{"ts":1586169102514,"val":5326},{"ts":1586169112557,"val":5320},{"ts":1586169760442,"val":5592},{"ts":1586169971410,"val":5562},{"ts":1586169976352,"val":5554},{"ts":1586170036595,"val":5533},{"ts":1586170834915,"val":5909},{"ts":1586170839942,"val":5931},{"ts":1586171131274,"val":5882},{"ts":1586171653656,"val":6133},{"ts":1586171698823,"val":6109},{"ts":1586171703843,"val":6128},{"ts":1586171754011,"val":6076},{"ts":1586172422129,"val":6381},{"ts":1586172562761,"val":6378},{"ts":1586172567778,"val":6389},{"ts":1586172633100,"val":6316},{"ts":1586173150581,"val":6570},{"ts":1586173426515,"val":6481},{"ts":1586173431530,"val":6462},{"ts":1586173486746,"val":6438},{"ts":1586174290074,"val":6756},{"ts":1586174295089,"val":6724},{"ts":1586174470952,"val":6771},{"ts":1586174762088,"val":6657},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586176772949,"val":6756},{"ts":1586176878355,"val":6839},{"ts":1586176898433,"val":6833},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177747128,"val":6809},{"ts":1586177762220,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586178575601,"val":6886},{"ts":1586178610816,"val":6839},{"ts":1586178615804,"val":6844},{"ts":1586179052674,"val":6903},{"ts":1586179474399,"val":6750},{"ts":1586179479418,"val":6774},{"ts":1586179624982,"val":6728},{"ts":1586179926359,"val":6915},{"ts":1586180338299,"val":6821},{"ts":1586180343322,"val":6844},{"ts":1586180749981,"val":6879},{"ts":1586181151867,"val":6763},{"ts":1586181202061,"val":6774},{"ts":1586181207075,"val":6780},{"ts":1586181227186,"val":6808},{"ts":1586181714505,"val":6515},{"ts":1586182065924,"val":6584},{"ts":1586182070988,"val":6612},{"ts":1586182849534,"val":6377},{"ts":1586182929854,"val":6389},{"ts":1586182934864,"val":6401},{"ts":1586182949913,"val":6416},{"ts":1586183773727,"val":6220},{"ts":1586183793806,"val":6232},{"ts":1586183798846,"val":6231},{"ts":1586183844189,"val":6251},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188104226,"val":4842},{"ts":1586188114254,"val":4850},{"ts":1586188119270,"val":4839},{"ts":1586188139365,"val":4870},{"ts":1586188978417,"val":4461},{"ts":1586188983441,"val":4457},{"ts":1586188988479,"val":4461},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586194158774,"val":1032},{"ts":1586194163695,"val":1039},{"ts":1586194168712,"val":1038},{"ts":1586195027708,"val":438},{"ts":1586195032801,"val":442},{"ts":1586195093282,"val":450},{"ts":1586195891661,"val":79},{"ts":1586195896677,"val":92},{"ts":1586196107619,"val":0},{"ts":1586196152901,"val":36},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234774196,"val":0}]
                                      widgets.min.js:3 [Line History Chart w00477] promise all datasets - count: 2
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 286
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 155
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795032,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585975595024,"end":1586234795039,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585975595024,"val":968.2274900398406},{"ts":1585975599473,"val":970},{"ts":1585976432703,"val":1087},{"ts":1585977953951,"val":939},{"ts":1585978185139,"val":945},{"ts":1585978189981,"val":953},{"ts":1585978817682,"val":991},{"ts":1585980148705,"val":348},{"ts":1585980771608,"val":435},{"ts":1585980781658,"val":445},{"ts":1585982343403,"val":339},{"ts":1585983312823,"val":1590},{"ts":1585983368074,"val":497},{"ts":1585983373095,"val":492},{"ts":1585983458448,"val":348},{"ts":1585984217203,"val":2734},{"ts":1585985959326,"val":1028},{"ts":1585985964348,"val":2091},{"ts":1585986511507,"val":935},{"ts":1585988504257,"val":2740},{"ts":1585988554474,"val":1588},{"ts":1585988559497,"val":1586},{"ts":1585990352016,"val":1308},{"ts":1585990914291,"val":3516},{"ts":1585991145112,"val":3363},{"ts":1585991150131,"val":2075},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585993736307,"val":2155},{"ts":1585993741353,"val":2375},{"ts":1585994248405,"val":3707},{"ts":1585996031210,"val":1244},{"ts":1585996327815,"val":1909},{"ts":1585996332831,"val":1290},{"ts":1585996704240,"val":1231},{"ts":1585998266153,"val":2610},{"ts":1585998919075,"val":1299},{"ts":1585998924097,"val":1287},{"ts":1586001113661,"val":1185},{"ts":1586001450162,"val":2611},{"ts":1586001510457,"val":1332},{"ts":1586001515478,"val":1460},{"ts":1586001711430,"val":1317},{"ts":1586003238503,"val":6525},{"ts":1586004102681,"val":6288},{"ts":1586004107707,"val":4715},{"ts":1586004147878,"val":5465},{"ts":1586006664079,"val":1370},{"ts":1586006694221,"val":1402},{"ts":1586006699275,"val":1407},{"ts":1586006799673,"val":2558},{"ts":1586007457986,"val":1272},{"ts":1586008000515,"val":1417},{"ts":1586009850382,"val":1469},{"ts":1586010262197,"val":1360},{"ts":1586010523424,"val":2534},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586014384795,"val":2524},{"ts":1586014470188,"val":1346},{"ts":1586014475204,"val":1936},{"ts":1586015881337,"val":1170},{"ts":1586017056341,"val":2532},{"ts":1586017066383,"val":1335},{"ts":1586017071424,"val":1341},{"ts":1586017402800,"val":2539},{"ts":1586019567023,"val":634},{"ts":1586019657432,"val":657},{"ts":1586019662468,"val":656},{"ts":1586022032554,"val":1964},{"ts":1586022213521,"val":170},{"ts":1586022248752,"val":319},{"ts":1586022253765,"val":673},{"ts":1586022484981,"val":0},{"ts":1586023047529,"val":2301},{"ts":1586024840244,"val":2290},{"ts":1586024845260,"val":618},{"ts":1586024850281,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586027432732,"val":335},{"ts":1586027437837,"val":366},{"ts":1586027854628,"val":2254},{"ts":1586027874750,"val":0},{"ts":1586030025219,"val":584},{"ts":1586030030269,"val":2102},{"ts":1586030070486,"val":0},{"ts":1586032391334,"val":2744},{"ts":1586032617389,"val":1120},{"ts":1586032622407,"val":1070},{"ts":1586033536704,"val":2855},{"ts":1586034682203,"val":291},{"ts":1586035209862,"val":896},{"ts":1586035214877,"val":889},{"ts":1586037269627,"val":2751},{"ts":1586037701658,"val":245},{"ts":1586037802128,"val":833},{"ts":1586037807140,"val":1061},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586040393597,"val":501},{"ts":1586040398609,"val":457},{"ts":1586040493959,"val":0},{"ts":1586040704830,"val":2247},{"ts":1586042983665,"val":499},{"ts":1586042988681,"val":112},{"ts":1586043008746,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586045574048,"val":561},{"ts":1586045579062,"val":451},{"ts":1586045604206,"val":0},{"ts":1586047512093,"val":2054},{"ts":1586048169783,"val":0},{"ts":1586048174807,"val":233},{"ts":1586048204933,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586050759988,"val":2457},{"ts":1586050765005,"val":1012},{"ts":1586050845298,"val":2651},{"ts":1586053129518,"val":209},{"ts":1586053350266,"val":923},{"ts":1586053355289,"val":901},{"ts":1586054695420,"val":288},{"ts":1586055488482,"val":2686},{"ts":1586055945279,"val":887},{"ts":1586055950295,"val":538},{"ts":1586057039571,"val":2532},{"ts":1586057380892,"val":0},{"ts":1586058535519,"val":304},{"ts":1586058540535,"val":325},{"ts":1586058590704,"val":0},{"ts":1586059012299,"val":2348},{"ts":1586061130886,"val":123},{"ts":1586061135908,"val":590},{"ts":1586061201161,"val":0},{"ts":1586061401936,"val":2078},{"ts":1586063721185,"val":526},{"ts":1586063726206,"val":1251},{"ts":1586063801693,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586066311611,"val":324},{"ts":1586066316626,"val":390},{"ts":1586066366803,"val":0},{"ts":1586066567660,"val":2296},{"ts":1586068902230,"val":405},{"ts":1586068907250,"val":343},{"ts":1586068912275,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071497690,"val":950},{"ts":1586071502717,"val":895},{"ts":1586071703481,"val":226},{"ts":1586072762980,"val":2978},{"ts":1586074088589,"val":1158},{"ts":1586074093629,"val":2544},{"ts":1586074133748,"val":617},{"ts":1586076203797,"
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585975595024,"val":20.79800990397711},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585978139770,"val":84},{"ts":1585978185139,"val":79},{"ts":1585978194995,"val":83},{"ts":1585978230205,"val":77},{"ts":1585980721437,"val":311},{"ts":1585980771607,"val":306},{"ts":1585980781658,"val":304},{"ts":1585981163296,"val":294},{"ts":1585983312823,"val":518},{"ts":1585983368074,"val":444},{"ts":1585983373093,"val":417},{"ts":1585984789725,"val":22},{"ts":1585985638026,"val":646},{"ts":1585985959326,"val":581},{"ts":1585985964348,"val":598},{"ts":1585987214177,"val":0},{"ts":1585988554474,"val":1570},{"ts":1585988559497,"val":1564},{"ts":1585991130118,"val":2729},{"ts":1585991145112,"val":2707},{"ts":1585991150131,"val":2729},{"ts":1585991175308,"val":2691},{"ts":1585993721236,"val":4193},{"ts":1585993736307,"val":4160},{"ts":1585993741353,"val":4180},{"ts":1585993806645,"val":3923},{"ts":1585996277559,"val":5402},{"ts":1585996327815,"val":5381},{"ts":1585996332831,"val":5368},{"ts":1585996347883,"val":5107},{"ts":1585998914062,"val":6306},{"ts":1585998924097,"val":6300},{"ts":1585999160025,"val":6279},{"ts":1586001495373,"val":6897},{"ts":1586001510457,"val":6891},{"ts":1586001515478,"val":6889},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004102679,"val":6908},{"ts":1586004107706,"val":6909},{"ts":1586005142356,"val":6832},{"ts":1586005780202,"val":7162},{"ts":1586006694220,"val":7057},{"ts":1586006699273,"val":7068},{"ts":1586007086047,"val":7110},{"ts":1586007457986,"val":6991},{"ts":1586007995500,"val":7026},{"ts":1586009850382,"val":6757},{"ts":1586009860419,"val":6769},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586014470188,"val":5411},{"ts":1586014475203,"val":5405},{"ts":1586014490251,"val":5408},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586019652398,"val":2444},{"ts":1586019657432,"val":2452},{"ts":1586019662468,"val":2456},{"ts":1586022248752,"val":462},{"ts":1586022253765,"val":443},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586063706151,"val":46},{"ts":1586063721185,"val":43},{"ts":1586063726205,"val":41},{"ts":1586066211238,"val":210},{"ts":1586066311611,"val":200},{"ts":1586066316626,"val":206},{"ts":1586068209595,"val":155},{"ts":1586068801844,"val":414},{"ts":1586068902229,"val":404},{"ts":1586068907250,"val":405},{"ts":1586068917655,"val":373},{"ts":1586071221625,"val":554},{"ts":1586071497689,"val":551},{"ts":1586071502717,"val":500},{"ts":1586071834103,"val":217},{"ts":1586074078555,"val":1069},{"ts":1586074088589,"val":1066},{"ts":1586074093629,"val":1063},{"ts":1586074098636,"val":1059},{"ts":1586076384660,"val":2046},{"ts":1586076681006,"val":1928},{"ts":1586076686023,"val":1924},{"ts":1586077238247,"val":0},{"ts":1586079251896,"val":3776},{"ts":1586079271955,"val":3758},{"ts":1586079281993,"val":3794},{"ts":1586079287009,"val":3782},{"ts":1586081862870,"val":5104},{"ts":1586081867874,"val":5094},{"ts":1586083800241,"val":5798},{"ts":1586083805273,"val":5790},{"ts":1586085622533,"val":6330},{"ts":1586085637575,"val":6314},{"ts":1586085702830,"val":6392},{"ts":1586085788126,"val":6334},{"ts":1586087637494,"val":6800},{"ts":1586087682723,"val":6757},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586090750715,"val":6990},{"ts":1586092567282,"val":7041},{"ts":1586093300238,"val":6972},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586096193415,"val":6745},{"ts":1586096243592,"val":6774},{"ts":1586098092530,"val":6467},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586102601680,"val":4867},{"ts":1586102606842,"val":4856},{"ts":1586105191869,"val":3375},{"ts":1586105196900,"val":3369},{"ts":1586105201917,"val":3375},{"ts":1586107782298,"val":1524},{"ts":1586107787323,"val":1518},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586151850123,"val":161},{"ts":1586151865175,"val":162},{"ts":1586151870190,"val":154},{"ts":1586154442438,"val":353},{"ts":1586154447450,"val":337},{"ts":1586154628301,"val":333},{"ts":1586157009004,"val":489},{"ts":1586157034004,"val":463},{"ts":1586157039305,"val":492},{"ts":1586157164657,"val":422},{"ts":1586157701981,"val":554},{"ts":1586158299582,"val":538},{"ts":1586160116497,"val":948},{"ts":1586160191749,"val":936},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586163201203,"val":2013},{"ts":1586164808936,"val":3247},{"ts":1586164813646,"val":3216},{"ts":1586167269338,"val":0},{"ts":1586167394824,"val":4574},{"ts":1586167404870,"val":4573},{"ts":1586169760442,"val":5592},{"ts":1586169991401,"val":5573},{"ts":1586169996425,"val":5565},{"ts":1586170036595,"val":5533},{"ts":1586172582835,"val":6410},{"ts":1586172587859,"val":6401},{"ts":1586172633100,"val":6316},{"ts":1586174470952,"val":6771},{"ts":1586174832405,"val":6737},{"ts":1586176682554,"val":6832},{"ts":1586177013882,"val":6751},{"ts":1586177631651,"val":6903},{"ts":1586177767206,"val":6821},{"ts":1586177772229,"val":6808},{"ts":1586178294421,"val":6687},{"ts":1586179926359,"val":6915},{"ts":1586180358377,"val":6797},{"ts":1586180363395,"val":6827},{"ts":1586180749981,"val":6879},{"ts":1586182944896,"val":6369},{"ts":1586182954923,"val":6411},{"ts":1586182959958,"val":6379},{"ts":1586182964977,"val":6415},{"ts":1586183904305,"val":6174},{"ts":1586183919346,"val":6202},{"ts":1586185769467,"val":5725},{"ts":1586188119270,"val":4839},{"ts":1586188134349,"val":4857},{"ts":1586188139365,"val":4870},{"ts":1586189756987,"val":4017},{"ts":1586189761812,"val":4018},{"ts":1586191579896,"val":2853},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586195891661,"val":79},{"ts":1586195906715,"val":79},{"ts":1586195916741,"val":82},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234795039,"val":0}]
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 396
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 203
                                      widgets.min.js:3 [Line History Chart w00477] ************************************************************** onChange - OID TimeInterval **************************************************************
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234802995,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630002994,"end":1586234803002,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804246,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1585630004246,"end":1586234804256,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630002994,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859826500,"val":3279},{"ts":1585859827521,"val":2982},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865870728,"val":1115},{"ts":1585865875737,"val":1025},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896111023,"val":1502},{"ts":1585896115932,"val":1472},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908206385,"val":2846},{"ts":1585908211400,"val":3800},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914254312,"val":1473},{"ts":1585914259334,"val":1683},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920302216,"val":1534},{"ts":1585920307263,"val":1520},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035214877,"val":889},{"ts":1586035219972,"val":1109},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041262025,"val":51},{"ts":1586041267241,"val":907},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047311222,"val":0},{"ts":1586047316235,"val":177},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071502717,"val":895},{"ts":1586071507737,"val":896},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228750899,"val":347},{"ts":1586228755914,"val":344},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234802995,"val":1661}]
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630002994,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896111023,"val":466},{"ts":1585896115932,"val":484},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908241498,"val":4550},{"ts":1585914254312,"val":6764},{"ts":1585914259334,"val":6782},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920302216,"val":7072},{"ts":1585920307263,"val":7068},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071502717,"val":500},{"ts":1586071507737,"val":503},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234803002,"val":0}]
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 253
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 141
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1585630004246,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585858669660,"val":654},{"ts":1585858746453,"val":4252},{"ts":1585859827521,"val":2982},{"ts":1585859828540,"val":3236},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585865875737,"val":1025},{"ts":1585865880749,"val":1049},{"ts":1585871231935,"val":299},{"ts":1585871728785,"val":2806},{"ts":1585871919569,"val":1735},{"ts":1585871924581,"val":1490},{"ts":1585872195774,"val":2702},{"ts":1585875468113,"val":0},{"ts":1585877970344,"val":343},{"ts":1585877975360,"val":115},{"ts":1585877985395,"val":0},{"ts":1585880891788,"val":2282},{"ts":1585884018872,"val":496},{"ts":1585884023883,"val":1333},{"ts":1585884064025,"val":0},{"ts":1585889665174,"val":2601},{"ts":1585890066872,"val":562},{"ts":1585890071882,"val":995},{"ts":1585890378178,"val":253},{"ts":1585893505542,"val":6581},{"ts":1585896115932,"val":1472},{"ts":1585896120981,"val":1975},{"ts":1585896286641,"val":472},{"ts":1585901110985,"val":3204},{"ts":1585902160322,"val":1446},{"ts":1585902165343,"val":1418},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585908211400,"val":3800},{"ts":1585908216420,"val":4140},{"ts":1585908603295,"val":5922},{"ts":1585910547158,"val":1413},{"ts":1585914259334,"val":1683},{"ts":1585914264352,"val":1468},{"ts":1585914786772,"val":1440},{"ts":1585917710085,"val":4053},{"ts":1585920307263,"val":1520},{"ts":1585920312285,"val":1532},{"ts":1585920714057,"val":3022},{"ts":1585922220919,"val":979},{"ts":1585926354537,"val":1192},{"ts":1585926359563,"val":1179},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585932402808,"val":1878},{"ts":1585932407821,"val":1907},{"ts":1585933095645,"val":5320},{"ts":1585936242242,"val":853},{"ts":1585936643936,"val":1834},{"ts":1585938493930,"val":1713},{"ts":1585938840490,"val":798},{"ts":1585939583515,"val":5152},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585945872198,"val":604},{"ts":1585946826408,"val":3103},{"ts":1585950543925,"val":2052},{"ts":1585950548938,"val":2069},{"ts":1585950694493,"val":3047},{"ts":1585956084287,"val":918},{"ts":1585956591488,"val":982},{"ts":1585956596383,"val":976},{"ts":1585958744944,"val":1015},{"ts":1585961362271,"val":370},{"ts":1585962642564,"val":476},{"ts":1585962647602,"val":466},{"ts":1585963054196,"val":341},{"ts":1585963842325,"val":1075},{"ts":1585968686863,"val":531},{"ts":1585968696903,"val":535},{"ts":1585969419794,"val":373},{"ts":1585970197879,"val":1802},{"ts":1585974731052,"val":979},{"ts":1585974741088,"val":978},{"ts":1585975162738,"val":1677},{"ts":1585980148705,"val":348},{"ts":1585980786682,"val":444},{"ts":1585980791713,"val":432},{"ts":1585982343403,"val":339},{"ts":1585984217203,"val":2734},{"ts":1585986832829,"val":1175},{"ts":1585986837852,"val":1155},{"ts":1585991642299,"val":3828},{"ts":1585992330176,"val":615},{"ts":1585992882588,"val":2074},{"ts":1585992887613,"val":1648},{"ts":1585994248405,"val":3707},{"ts":1585996704240,"val":1231},{"ts":1585998929111,"val":1284},{"ts":1585998934133,"val":1281},{"ts":1586001113661,"val":1185},{"ts":1586003238503,"val":6525},{"ts":1586004976531,"val":2043},{"ts":1586004981635,"val":1549},{"ts":1586005714856,"val":2683},{"ts":1586007457986,"val":1272},{"ts":1586010674085,"val":1378},{"ts":1586012490479,"val":1346},{"ts":1586012972700,"val":334},{"ts":1586017056341,"val":2532},{"ts":1586017071424,"val":1341},{"ts":1586017076460,"val":1327},{"ts":1586017402800,"val":2539},{"ts":1586022484981,"val":0},{"ts":1586023122859,"val":350},{"ts":1586023127882,"val":369},{"ts":1586023253307,"val":0},{"ts":1586026553794,"val":2347},{"ts":1586029170933,"val":405},{"ts":1586029175946,"val":0},{"ts":1586033536704,"val":2855},{"ts":1586035219972,"val":1109},{"ts":1586035224988,"val":1083},{"ts":1586038309460,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586041267241,"val":907},{"ts":1586041272068,"val":409},{"ts":1586041287170,"val":0},{"ts":1586044012853,"val":2155},{"ts":1586047316235,"val":177},{"ts":1586047321262,"val":908},{"ts":1586047346350,"val":0},{"ts":1586049986765,"val":2701},{"ts":1586053360302,"val":842},{"ts":1586053365316,"val":736},{"ts":1586055488482,"val":2686},{"ts":1586057380892,"val":0},{"ts":1586059408863,"val":600},{"ts":1586059413913,"val":470},{"ts":1586059428959,"val":0},{"ts":1586064770405,"val":2207},{"ts":1586065458076,"val":399},{"ts":1586065463096,"val":749},{"ts":1586065583541,"val":0},{"ts":1586070242670,"val":2701},{"ts":1586071507737,"val":896},{"ts":1586071512748,"val":904},{"ts":1586076203797,"val":5655},{"ts":1586077238248,"val":0},{"ts":1586077554539,"val":1161},{"ts":1586077559561,"val":1128},{"ts":1586077780632,"val":1090},{"ts":1586078352967,"val":3369},{"ts":1586083599519,"val":1329},{"ts":1586083604540,"val":1318},{"ts":1586087667657,"val":772},{"ts":1586088460727,"val":2079},{"ts":1586088777181,"val":2031},{"ts":1586090595054,"val":809},{"ts":1586090630195,"val":778},{"ts":1586092868521,"val":2080},{"ts":1586093957873,"val":835},{"ts":1586095806960,"val":1337},{"ts":1586095857154,"val":2851},{"ts":1586098177848,"val":1267},{"ts":1586098855415,"val":1293},{"ts":1586102546497,"val":1471},{"ts":1586102621756,"val":6094},{"ts":1586107646783,"val":342},{"ts":1586107792345,"val":404},{"ts":1586107797363,"val":352},{"ts":1586109218231,"val":0},{"ts":1586113513452,"val":3736},{"ts":1586113839491,"val":3588},{"ts":1586113844698,"val":3591},{"ts":1586116428259,"val":4117},{"ts":1586118065490,"val":983},{"ts":1586119883341,"val":1066},{"ts":1586119893418,"val":1083},{"ts":1586120471125,"val":1484},{"ts":1586123846241,"val":733},{"ts":1586125935887,"val":764},{"ts":1586125940895,"val":758},{"ts":1586126016471,"val":743},{"ts":1586127794593,"val":1617},{"ts":1586131983847,"val":777},{"ts":1586131988867,"val":779},{"ts":1586133842285,"val":2187},{"ts":1586133897547,"val":0},{"ts":1586138031625,"val":880},{"ts":1586138036640,"val":877},{"ts":1586141665342,"val":804},{"ts":1586142634874,"val":1082},{"ts":1586142815675,"val":920},{"ts":1586144666089,"val":955},{"ts":1586149934435,"val":2805},{"ts":1586149944493,"val":434},{"ts":1586149979650,"val":514},{"ts":1586151830000,"val":1260},{"ts":1586151990748,"val":2834},{"ts":1586152271986,"val":459},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586158173998,"val":241},{"ts":1586160759071,"val":3104},{"ts":1586160914662,"val":1295},{"ts":1586162764286,"val":1365},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586168273731,"val":4717},{"ts":1586168278743,"val":1198},{"ts":1586169213035,"val":961},{"ts":1586169634764,"val":5949},{"ts":1586174320192,"val":1322},{"ts":1586174325211,"val":1308},{"ts":1586177174546,"val":2474},{"ts":1586179429232,"val":1008},{"ts":1586180368441,"val":1242},{"ts":1586180373438,"val":1201},{"ts":1586180493947,"val":2418},{"ts":1586186000394,"val":474},{"ts":1586186276678,"val":482},{"ts":1586188094196,"val":528},{"ts":1586189360267,"val":464},{"ts":1586191690404,"val":6163},{"ts":1586192182855,"val":2183},{"ts":1586194033167,"val":989},{"ts":1586194520295,"val":2572},{"ts":1586194660904,"val":278},{"ts":1586198513968,"val":1081},{"ts":1586198519017,"val":1075},{"ts":1586200962577,"val":891},{"ts":1586202107409,"val":1711},{"ts":1586202855579,"val":1185},{"ts":1586204705435,"val":614},{"ts":1586205378506,"val":0},{"ts":1586208362985,"val":779},{"ts":1586210608114,"val":553},{"ts":1586210613137,"val":544},{"ts":1586213406398,"val":287},{"ts":1586215296559,"val":886},{"ts":1586216177469,"val":793},{"ts":1586218027676,"val":938},{"ts":1586218358977,"val":1039},{"ts":1586219132207,"val":857},{"ts":1586221388483,"val":875},{"ts":1586223237811,"val":281},{"ts":1586223539019,"val":1082},{"ts":1586225768246,"val":259},{"ts":1586228755914,"val":344},{"ts":1586228760946,"val":348},{"ts":1586231045444,"val":274},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234804246,"val":1661}]
                                      widgets.min.js:4 [getTaskForHistoryData w00477] result error: timeout
                                      (anonymous) @ widgets.min.js:4
                                      (anonymous) @ conn.js:1299
                                      setTimeout (async)
                                      getHistory @ conn.js:1297
                                      getHistory @ vis.js:2613
                                      getTaskForHistoryData @ widgets.min.js:4
                                      o @ widgets.min.js:3
                                      (anonymous) @ widgets.min.js:3
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 142
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1585630004246,"val":0},{"ts":1585857922009,"val":0},{"ts":1585858640602,"val":0},{"ts":1585861809549,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585890739517,"val":22},{"ts":1585890744542,"val":0},{"ts":1585895950314,"val":526},{"ts":1585896115932,"val":484},{"ts":1585896120980,"val":478},{"ts":1585897185165,"val":0},{"ts":1585902160322,"val":1491},{"ts":1585902165342,"val":1495},{"ts":1585908206385,"val":4677},{"ts":1585908211400,"val":4663},{"ts":1585908216419,"val":4683},{"ts":1585908241498,"val":4550},{"ts":1585914259334,"val":6782},{"ts":1585914264351,"val":6763},{"ts":1585917263083,"val":6529},{"ts":1585920005966,"val":7206},{"ts":1585920307263,"val":7068},{"ts":1585920312285,"val":7102},{"ts":1585920392679,"val":7177},{"ts":1585920578493,"val":4454},{"ts":1585926354537,"val":6259},{"ts":1585926359563,"val":6256},{"ts":1585927228785,"val":6478},{"ts":1585927444855,"val":1193},{"ts":1585932402807,"val":2886},{"ts":1585932407820,"val":2889},{"ts":1585936237215,"val":31},{"ts":1585936638920,"val":31},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585980721437,"val":311},{"ts":1585980786682,"val":306},{"ts":1585980801746,"val":311},{"ts":1585984789725,"val":22},{"ts":1585986802724,"val":806},{"ts":1585986832829,"val":785},{"ts":1585986837852,"val":774},{"ts":1585987214177,"val":0},{"ts":1585992877572,"val":3776},{"ts":1585992882588,"val":3564},{"ts":1585992887613,"val":3585},{"ts":1585993178846,"val":3480},{"ts":1585998914062,"val":6306},{"ts":1585998929111,"val":6281},{"ts":1585998934133,"val":6285},{"ts":1586003032561,"val":7075},{"ts":1586003695567,"val":6098},{"ts":1586004976531,"val":6856},{"ts":1586004981635,"val":6874},{"ts":1586005780202,"val":7162},{"ts":1586010674085,"val":6540},{"ts":1586012490478,"val":6134},{"ts":1586012520622,"val":6156},{"ts":1586017056341,"val":4113},{"ts":1586017066383,"val":4118},{"ts":1586017076460,"val":4099},{"ts":1586017081479,"val":4105},{"ts":1586023012362,"val":23},{"ts":1586023122859,"val":34},{"ts":1586023127882,"val":36},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586065432983,"val":165},{"ts":1586065458076,"val":158},{"ts":1586065463096,"val":157},{"ts":1586065593575,"val":155},{"ts":1586071221625,"val":554},{"ts":1586071507737,"val":503},{"ts":1586071512747,"val":513},{"ts":1586077238247,"val":0},{"ts":1586077514400,"val":2727},{"ts":1586077554539,"val":2702},{"ts":1586077559561,"val":2717},{"ts":1586077700285,"val":2672},{"ts":1586083448954,"val":5755},{"ts":1586083594501,"val":5742},{"ts":1586083609556,"val":5755},{"ts":1586083664769,"val":5751},{"ts":1586088310140,"val":6953},{"ts":1586088777181,"val":6865},{"ts":1586090595053,"val":6927},{"ts":1586090630195,"val":6891},{"ts":1586093596415,"val":7097},{"ts":1586093957873,"val":6991},{"ts":1586095806960,"val":6850},{"ts":1586095827034,"val":6856},{"ts":1586098855415,"val":6290},{"ts":1586102546497,"val":4939},{"ts":1586107792345,"val":1513},{"ts":1586107797363,"val":1507},{"ts":1586109905885,"val":0},{"ts":1586109925978,"val":0},{"ts":1586124000574,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586149949491,"val":39},{"ts":1586149979650,"val":39},{"ts":1586151829999,"val":160},{"ts":1586151870190,"val":154},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586156596884,"val":365},{"ts":1586160914662,"val":1337},{"ts":1586162764281,"val":2231},{"ts":1586167269338,"val":0},{"ts":1586168263702,"val":5093},{"ts":1586168273730,"val":5089},{"ts":1586168278743,"val":5098},{"ts":1586168308842,"val":5018},{"ts":1586174290074,"val":6756},{"ts":1586174320192,"val":6709},{"ts":1586174325211,"val":6711},{"ts":1586174762088,"val":6657},{"ts":1586179926359,"val":6915},{"ts":1586180368441,"val":6809},{"ts":1586180373438,"val":6774},{"ts":1586180749981,"val":6879},{"ts":1586186176193,"val":5578},{"ts":1586186276678,"val":5605},{"ts":1586188094196,"val":4851},{"ts":1586188139365,"val":4870},{"ts":1586192182855,"val":2473},{"ts":1586194033167,"val":1133},{"ts":1586196107619,"val":0},{"ts":1586198002185,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234311405,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234804256,"val":0}]
                                      widgets.min.js:3 [Line History Chart w00477] time interval changed by '0_userdata.0.vis.Timeinterval_iSpeed' to: 1 month
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history options for 'modbus.0.holdingRegisters.40068_PV_Leistung': {"instance":"influxdb.0","count":100,"aggregate":"minmax","start":1583606816475,"end":1586234816475,"timeout":5000}
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40068_PV_Leistung': [{"ts":1583606816475,"val":0},{"ts":1585857922009,"val":0},{"ts":1585863070811,"val":0},{"ts":1585872000139,"val":0},{"ts":1585893164133,"val":197},{"ts":1585893174183,"val":193},{"ts":1585893179325,"val":197},{"ts":1585897185165,"val":0},{"ts":1585917584464,"val":7089},{"ts":1585919453326,"val":7068},{"ts":1585919458361,"val":7056},{"ts":1585920005966,"val":7206},{"ts":1585938493930,"val":0},{"ts":1585951200107,"val":0},{"ts":1585977004892,"val":22},{"ts":1585977014945,"val":0},{"ts":1585998291250,"val":5976},{"ts":1585998296276,"val":5970},{"ts":1585998301336,"val":5980},{"ts":1586005780202,"val":7162},{"ts":1586023388830,"val":0},{"ts":1586023403890,"val":0},{"ts":1586037600180,"val":0},{"ts":1586063204187,"val":22},{"ts":1586063209205,"val":0},{"ts":1586077132776,"val":2587},{"ts":1586077137791,"val":2585},{"ts":1586077238247,"val":0},{"ts":1586093596415,"val":7097},{"ts":1586103414867,"val":4471},{"ts":1586103419882,"val":4459},{"ts":1586103429906,"val":4468},{"ts":1586109905885,"val":0},{"ts":1586124000596,"val":0},{"ts":1586149597982,"val":24},{"ts":1586154683672,"val":370},{"ts":1586154774080,"val":368},{"ts":1586156591855,"val":403},{"ts":1586167269338,"val":0},{"ts":1586179926359,"val":6915},{"ts":1586182251826,"val":6561},{"ts":1586182256996,"val":6572},{"ts":1586182271904,"val":6584},{"ts":1586196107619,"val":0},{"ts":1586199189840,"val":0},{"ts":1586210403396,"val":0},{"ts":1586234317298,"val":0},{"ts":1586234816475,"val":0}]
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                                      widgets.min.js:4 [getTaskForHistoryData w00477] history data result 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung': [{"ts":1583606816475,"val":1152},{"ts":1585858000479,"val":1152},{"ts":1585860026477,"val":4267},{"ts":1585860694489,"val":189},{"ts":1585866894468,"val":1083},{"ts":1585866899491,"val":1590},{"ts":1585875468113,"val":0},{"ts":1585893128983,"val":6513},{"ts":1585893174183,"val":6372},{"ts":1585893179325,"val":5325},{"ts":1585905036614,"val":109},{"ts":1585906789757,"val":7580},{"ts":1585919453326,"val":1636},{"ts":1585919458362,"val":1626},{"ts":1585930870679,"val":555},{"ts":1585931880446,"val":7189},{"ts":1585943936764,"val":3478},{"ts":1585945786867,"val":1366},{"ts":1585946826408,"val":3103},{"ts":1585963054196,"val":341},{"ts":1585972004945,"val":918},{"ts":1585972020004,"val":913},{"ts":1585982343403,"val":339},{"ts":1585991642299,"val":3828},{"ts":1585998296276,"val":1387},{"ts":1585998301336,"val":1832},{"ts":1586003238503,"val":6525},{"ts":1586022484981,"val":0},{"ts":1586024573904,"val":389},{"ts":1586024578917,"val":968},{"ts":1586024619113,"val":0},{"ts":1586038872460,"val":2895},{"ts":1586050855348,"val":675},{"ts":1586050860376,"val":904},{"ts":1586057380892,"val":0},{"ts":1586076203797,"val":5655},{"ts":1586077132776,"val":1181},{"ts":1586077137791,"val":1228},{"ts":1586077238248,"val":0},{"ts":1586102621756,"val":6094},{"ts":1586103414867,"val":1915},{"ts":1586103419882,"val":775},{"ts":1586109218231,"val":0},{"ts":1586116428259,"val":4117},{"ts":1586129693337,"val":830},{"ts":1586129698348,"val":817},{"ts":1586133897547,"val":0},{"ts":1586151990748,"val":2834},{"ts":1586154774080,"val":1110},{"ts":1586156591855,"val":629},{"ts":1586167264278,"val":0},{"ts":1586167580686,"val":6177},{"ts":1586182251826,"val":1128},{"ts":1586182256996,"val":1157},{"ts":1586191690404,"val":6163},{"ts":1586205378506,"val":0},{"ts":1586208378051,"val":754},{"ts":1586210196393,"val":560},{"ts":1586225768246,"val":259},{"ts":1586233026198,"val":1666},{"ts":1586234317314,"val":1661},{"ts":1586234816475,"val":1661}]
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40072_Hausverbrauch_Leistung' length: 62
                                      widgets.min.js:4 [getPreparedData w00477] prepare data for 'modbus.0.holdingRegisters.40068_PV_Leistung' length: 48
                                      EDIT:
                                      zu früh gefreut. Ich habe nun von InfluxDB wieder auf MariaDB als Datenquelle gewechselt. Die Timeouts treten nun wieder deutlich häufiger auf. Auch beim Wechsel zurück auf InfluxDB gab es viele Timeouts....
                                      • Scrounger
                                        Scrounger Developer @Chris Tailor last edited by
                                        @Chris-Tailor
                                        Hab nochmal bissle optimiert, bitte teste die version von git -> v0.2.80.
                                        Hier kannst du jetzt selbst den timeout einstellen (in Sekunden):
                                        Erhöh mal den bis bei dir keine fehlermeldungen mehr auftauchen.
                                        Reduzier auch mal die max. Anzahl der anzuzeigenden Datenpunkte: und den timeout. Müssten direkt zusammenhängen, d.h. um so weniger Datenpunkte um so niedriger kannst den timeout wählen.
                                        Und noch kleiner Tipp: max. Anzahl der anzuzeigenden Datenpunkte: 100 brauchst du sicher nicht in der VIS. Denke das hier 30 völlig ausreichend sind. Bedenke je höher der Wert desto mehr daten müssen geladen werden, was sich auf die preformance auswirkt!
                                        • Scrounger
                                          Scrounger Developer last edited by
                                          Version 0.3.0 veröffentlicht, ab sofort geht es hier weiter:
                                          https://forum.iobroker.net/topic/32018/test-adapter-material-design-widgets-v0-3-x
                                          adapater material vis visualization widget
                                          77
                                          902
                                          204421
