    4. Material Design Widgets: List Widget
      darkiop Most Active @Scrounger last edited by
      @Scrounger Danke.
          "text": "testtext1",
          "subText": "subtext1",
          "rightText": "rightext1",
          "rightSubText": "rightsubtext1",
          "image": "death-star",
          "imageColor": "#44739e",
          "imageActive": "",
          "imageActiveColor": "#44739e",
          "header": "",
          "showDivider": "true",
          "objectId": "",
          "buttonStateValue": "",
          "buttonNavView": "",
          "buttonLink": ""
          "text": "testtext2",
          "subText": "subtext2",
          "rightText": "rightext2",
          "rightSubText": "rightsubtext2",
          "imageActive": "",
          "header": "",
          "objectId": "",
          "buttonLink": ""
        darkiop Most Active last edited by
        @Scrounger
        Wenn man im list-widget über das JSON-Objekt einen Schalter / eine Checkbox darstellt, wird der Zustand nur Korrekt im EDIT angezeigt. Beim rendern im Browser wird der Status nicht angezeigt (siehe Timer 1 auf den Screens).
            "text": "Timer 1 - {robonect.0.timer.0.start_time} - {robonect.0.timer.0.end_time}",
            "subText": "{a:robonect.0.timer.0.weekdays.monday;a=='true'?'Mo ':''}{a:robonect.0.timer.0.weekdays.tuesday;a=='true'?'Di ':''}{a:robonect.0.timer.0.weekdays.wednesday;a=='true'?'Mi ':''}{a:robonect.0.timer.0.weekdays.thursday;a=='true'?'Do ':''}{a:robonect.0.timer.0.weekdays.friday;a=='true'?'Fr ':''}{a:robonect.0.timer.0.weekdays.saturday;a=='true'?'Sa ':''}{a:robonect.0.timer.0.weekdays.sunday;a=='true'?'So ':''}",
            "rightText": "",
            "rightSubText": "",
            "image": "timer",
            "imageColor": "#fff",
            "imageActive": "",
            "imageActiveColor": "#fff",
            "header": "",
            "showDivider": "",
            "objectId": "robonect.0.timer.0.enabled",
            "buttonLink": ""
            "text": "Timer 2 - {robonect.0.timer.0.start_time} - {robonect.0.timer.0.end_time}",
            "subText": "{a:robonect.0.timer.1.weekdays.monday;a=='true'?'Mo ':''}{a:robonect.0.timer.1.weekdays.tuesday;a=='true'?'Di ':''}{a:robonect.0.timer.1.weekdays.wednesday;a=='true'?'Mi ':''}{a:robonect.0.timer.1.weekdays.thursday;a=='true'?'Do ':''}{a:robonect.0.timer.1.weekdays.friday;a=='true'?'Fr ':''}{a:robonect.0.timer.1.weekdays.saturday;a=='true'?'Sa ':''}{a:robonect.0.timer.1.weekdays.sunday;a=='true'?'So ':''}",
            "rightText": "",
            "rightSubText": "",
            "image": "timer",
            "imageActive": "",
            "header": "",
            "showDivider": "",
            "objectId": "robonect.0.timer.1.enabled",
            "buttonLink": ""
        • Scrounger
          Scrounger Developer @darkiop last edited by
          @darkiop sagte in Material Design Widgets: List Widget:
          @Scrounger
          Ich kann das nicht reproduzieren.
          Was steht im log der console?
          Art der Liste ist korrekt gesetzt?
          Mach mal die ganzen Bindings raus und schau ob es dann geht.
          Versuch die Daten mal ohne verwendung des json direkt im widget einzugeben.
          • 0
            0018 last edited by
            @Scrounger Gibt es eine Möglichkeit die Rahmenfarbe der Checkboxen anzupassen? Schwarz geht leider aufgrund meines Hintergrundes unter und man erkennt die checkbox nicht.
            • Scrounger
              Scrounger Developer @0018 last edited by
              @0018 sagte in Material Design Widgets: List Widget:
              Geht nur per css klasse überschreiben.
              0 1 Reply Last reply Reply Quote 0
              • 0
                0018 @Scrounger last edited by
                @Scrounger sagte in Material Design Widgets: List Widget:
                Wie muss der Code aussehen? Habe leider keine Ahnung wie das mir dem css funktioniert, sorry.
                Kann man die Rahmenfarbe mit in das nächste Release aufnehmen?
                  darkiop Most Active @Scrounger last edited by darkiop
                  Sorry hat leider etwas gedauert. Im Log steht leider nichts relevantes.
                  checkbox_readonly und checkbox
                  Bindins entfernt, keine Besserung. Aber ... das ganz wird jetzt etwas seltsam ... sobald ich ein weiteres Widget einfüge und die DPs in diesem direkt eingebe, funktioniert es bei diesem Widget und bei dem mit JSON-Input ...
                    "settings": {
                      "style": {
                        "background_class": "",
                        "background-repeat": ""
                      "theme": "redmond",
                      "sizex": "",
                      "sizey": "",
                      "gridSize": "10",
                      "snapType": 2,
                      "useBackground": false
                    "widgets": {
                      "e00001": {
                        "tpl": "tplJquiRadioList",
                        "data": {
                          "oid": "robonect.0.status.mode",
                          "g_fixed": true,
                          "g_visibility": false,
                          "g_css_font_text": false,
                          "g_css_background": false,
                          "g_css_shadow_padding": false,
                          "g_css_border": false,
                          "g_gestures": false,
                          "g_signals": false,
                          "g_last_change": false,
                          "visibility-cond": "==",
                          "visibility-val": 1,
                          "visibility-groups-action": "hide",
                          "values": "0;98;2;1;99",
                          "texts": "Auto;Feierabend;Home;Manuell;Job",
                          "signals-cond-0": "==",
                          "signals-val-0": true,
                          "signals-icon-0": "/vis/signals/lowbattery.png",
                          "signals-icon-size-0": 0,
                          "signals-blink-0": false,
                          "signals-horz-0": 0,
                          "signals-vert-0": 0,
                          "signals-hide-edit-0": false,
                          "signals-cond-1": "==",
                          "signals-val-1": true,
                          "signals-icon-1": "/vis/signals/lowbattery.png",
                          "signals-icon-size-1": 0,
                          "signals-blink-1": false,
                          "signals-horz-1": 0,
                          "signals-vert-1": 0,
                          "signals-hide-edit-1": false,
                          "signals-cond-2": "==",
                          "signals-val-2": true,
                          "signals-icon-2": "/vis/signals/lowbattery.png",
                          "signals-icon-size-2": 0,
                          "signals-blink-2": false,
                          "signals-horz-2": 0,
                          "signals-vert-2": 0,
                          "signals-hide-edit-2": false,
                          "lc-type": "last-change",
                          "lc-is-interval": true,
                          "lc-is-moment": false,
                          "lc-format": "",
                          "lc-position-vert": "top",
                          "lc-position-horz": "right",
                          "lc-offset-vert": 0,
                          "lc-offset-horz": 0,
                          "lc-font-size": "12px",
                          "lc-font-family": "",
                          "lc-font-style": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-border-width": "0",
                          "lc-border-style": "",
                          "lc-border-color": "",
                          "lc-border-radius": 10,
                          "lc-zindex": 0,
                          "class": "mdui-radio"
                        "style": {
                          "left": "10px",
                          "top": "60px",
                          "font-family": "Jura-Light",
                          "width": "400px"
                        "widgetSet": "jqui"
                      "e00002": {
                        "tpl": "tplHtml",
                        "data": {
                          "g_fixed": true,
                          "g_css_font_text": true,
                          "g_signals": false,
                          "refreshInterval": "0",
                          "signals-icon-0": "/vis.0/main-2020/lowbattery.png",
                          "signals-icon-1": "/vis.0/main-2020/lowbattery.png",
                          "signals-icon-2": "/vis.0/main-2020/lowbattery.png",
                          "html": "",
                          "class": "mdui-abar mdui-bluegrey-bg",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "comment": "",
                          "name": "app-bar"
                        "style": {
                          "left": "0px",
                          "top": "0px",
                          "width": "100%",
                          "height": "50px",
                          "z-index": "0",
                          "color": "#ffffff",
                          "text-align": "center",
                        "widgetSet": "basic"
                      "e00003": {
                        "tpl": "tplHtml",
                        "data": {
                          "g_fixed": true,
                          "g_signals": false,
                          "html": "Robonect",
                          "class": "mdui-title",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0
                        "style": {
                          "left": "calc(0% + 50px)",
                          "top": "15px",
                          "width": "195px",
                          "height": "23px",
                          "z-index": 1,
                      "e00004": {
                        "tpl": "tplImage",
                        "data": {
                          "g_fixed": false,
                          "g_signals": false,
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "src": "/icons-mfd-png/scene_robo_lawnmower.png"
                        "style": {
                          "left": "0",
                          "top": "0px",
                          "width": "50px",
                          "height": "50px",
                      "e00005": {
                        "tpl": "tplValueLastchange",
                        "data": {
                          "oid": "robonect.0.last_sync",
                          "g_fixed": true,
                          "g_visibility": true,
                          "g_signals": false,
                          "visibility-val": "true",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "format_date": "DD.MM.YYYY hh:mm:ss",
                          "html_append": " Uhr",
                          "class": "mdui-blue",
                          "html_prepend": "Letzer Sync: ",
                          "visibility-oid": "javascript.0.VIS.show_last_change"
                        "style": {
                          "left": "20px",
                          "top": "105px",
                          "width": "220px",
                          "font-size": "small",
                          "color": "",
                          "height": "auto"
                      "e00006": {
                        "tpl": "tplJquiButtonLinkBlank",
                        "data": {
                          "g_fixed": true,
                          "g_signals": false,
                          "buttontext": "EDIT",
                          "padding": "0",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "href": "http://iobroker-master.birkenweg.walk-steinweiler.de:8082/vis/edit.html?main-2020#{view}",
                          "no_style": false,
                          "class": "mdui-flatbutton",
                          "visibility-oid": "javascript.0.VIS.Edit_Mode"
                        "style": {
                          "left": "calc(100% - 140px)",
                          "top": "10px",
                          "width": "auto",
                          "height": "30px"
                        "widgetSet": "jqui"
                      "e00007": {
                        "tpl": "tplValueListHtml8",
                        "data": {
                          "oid": "system.adapter.robonect.0.alive",
                          "count": "1",
                          "value0": "Offline",
                          "value1": "Online",
                          "style0": "background-color: {javascript.0.VIS.Farben.Rot}; padding-top:2px;",
                          "style1": "background-color: {javascript.0.VIS.Farben.Gruen}; padding-top:2px;",
                          "test_list": "1",
                          "style2": "",
                          "value2": "",
                          "value3": "Boost",
                          "style3": "background-color: blue; padding-top:3px;",
                          "name": "Robby",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0
                        "style": {
                          "left": "calc(100% - 70px)",
                          "top": "10px",
                          "z-index": "3",
                          "color": "#000",
                          "width": "60px",
                          "height": "15px",
                          "border-radius": "4px",
                          "padding-top": "",
                          "line-height": "",
                          "font-size": "x-small",
                          "background-color": "#FFFFFF",
                          "opacity": "0.5",
                      "e00008": {
                        "tpl": "tplVis-materialdesign-List",
                        "data": {
                          "g_fixed": false,
                          "g_signals": false,
                          "listType": "checkbox",
                          "listItemDividerStyle": "standard",
                          "listLayout": "standard",
                          "vibrateOnMobilDevices": "50",
                          "listItemDataMethod": "jsonStringObject",
                          "countListItems": "1",
                          "listItemAlignment": "left",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "jsonStringObject": "[\n  {\n    \"text\": \"Timer 1\",\n    \"subText\": \"\",\n    \"rightText\": \"\",\n    \"rightSubText\": \"\",\n    \"image\": \"timer\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"robonect.0.timer.0.enabled\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  },\n  {\n    \"text\": \"Timer 2\",\n    \"subText\": \"\",\n    \"rightText\": \"\",\n    \"rightSubText\": \"\",\n    \"image\": \"timer\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"robonect.0.timer.1.enabled\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  }\n]",
                          "oid0": "",
                          "listItemBackground": "transparent",
                          "colorListItemText": "#fff",
                          "colorListItemTextRight": "#fff",
                          "rightTextWidth": "220",
                          "colorListItemTextSecondary": "#1e88e5",
                          "colorSwitchTrue": "{javascript.0.VIS.Farben.Bedienelemente}",
                          "colorSwitchTrack": "",
                          "colorSwitchThumb": "",
                          "colorCheckBox": "{javascript.0.VIS.Farben.Bedienelemente}",
                          "listItemTextRightSize": "16px",
                          "colorListItemTextSecondaryRight": "#fff"
                        "style": {
                          "left": "50%",
                          "top": "140px",
                          "width": "calc(50% - 20px)",
                          "height": "auto"
                        "widgetSet": "materialdesign"
                      "e00009": {
                        "data": {
                          "g_fixed": false,
                          "g_signals": false,
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "jsonStringObject": "[\n  {\n    \"text\": \"Telegram Status\",\n    \"subText\": \"\",\n    \"rightText\": \"\",\n    \"rightSubText\": \"\",\n    \"image\": \"message\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"javascript.0.scriptEnabled.PRODUKTIV.Telegram.Telegram_wenn_Rasenmaehroboter\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  },\n  {\n    \"text\": \"Telegram Error\",\n    \"subText\": \"\",\n    \"rightText\": \"\",\n    \"rightSubText\": \"\",\n    \"image\": \"message\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"javascript.0.scriptEnabled.PRODUKTIV.Telegram.Telegram_wenn_Rasenmaehroboter_Fehler\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  }\n]",
                          "oid0": "",
                        "style": {
                          "left": "50%",
                          "top": "240px",
                          "height": "auto"
                      "e00010": {
                        "data": {
                          "g_fixed": false,
                          "g_signals": false,
                          "listType": "text",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "jsonStringObject": "[\n  {\n    \"text\": \"Ladezustand\",\n    \"subText\": \"{robonect.0.batteries.0.charge.lc;date(DD.MM.YYYY hh:mm:ss)} Uhr\",\n    \"rightText\": \"{robonect.0.batteries.0.charge} %\",\n    \"rightSubText\": \"{robonect.0.batteries.0.capacity.remaining} / {robonect.0.batteries.0.capacity.full} mAh\",\n    \"image\": \"battery-charging\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  },\n  {\n    \"text\": \"Klingen-Qualität\",\n    \"subText\": \"{robonect.0.blades.quality.lc;date(DD.MM.YYYY hh:mm:ss)} Uhr\",\n    \"rightText\": \"{robonect.0.blades.quality} %\",\n    \"rightSubText\": \"\",\n    \"image\": \"saw-blade\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  },\n  {\n    \"text\": \"Status\",\n    \"subText\": \"{javascript.0.Garten.Rasenmaehroboter.Status.lc;date(DD.MM.YYYY hh:mm:ss)} Uhr\",\n    \"rightText\": \"{javascript.0.Garten.Rasenmaehroboter.Status}\",\n    \"rightSubText\": \"\",\n    \"image\": \"robot-mower\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  },\n  {\n    \"text\": \"Feuchtigkeit im Mäher\",\n    \"subText\": \"{robonect.0.health.humidity.lc;date(DD.MM.YYYY hh:mm:ss)} Uhr\",\n    \"rightText\": \"{robonect.0.health.humidity} %\",\n    \"rightSubText\": \"\",\n    \"image\": \"water\",\n    \"imageColor\": \"#fff\",\n    \"imageActive\": \"\",\n    \"imageActiveColor\": \"#fff\",\n    \"header\": \"\",\n    \"showDivider\": \"\",\n    \"objectId\": \"\",\n    \"buttonStateValue\": \"\",\n    \"buttonNavView\": \"\",\n    \"buttonLink\": \"\"\n  }\n]",
                          "oid0": "",
                        "style": {
                          "left": "10px",
                          "top": "140px",
                          "height": "auto"
                      "e00011": {
                        "data": {
                          "g_fixed": false,
                          "g_signals": false,
                          "listItemDataMethod": "inputPerEditor",
                          "lc-format": "",
                          "lc-bkg-color": "",
                          "lc-color": "",
                          "lc-zindex": 0,
                          "jsonStringObject": "",
                          "oid0": "robonect.0.timer.0.enabled",
                          "colorSwitchTrue": "",
                          "colorCheckBox": "",
                          "colorListItemTextSecondaryRight": "#fff",
                          "oid1": "robonect.0.timer.1.enabled"
                        "style": {
                          "left": "40px",
                          "top": "370px",
                          "height": "auto"
                    "name": "3_card_Geraete_und_Medien_Haus_und_Garten_Robonect",
                    "filterList": []
                  Scrounger 1 Reply Last reply Reply Quote 1
                  • Scrounger
                    @darkiop
                    Perfekt, danke.
                    Dann weiß ich jetzt woran es liegt. Problem ist, das wenn DPs nur per json übergeben werden, dann werden diese nicht automatisch regstriert, d.h. runtime weiß nicht das er auf diese hören soll. Gleiches Problem hatte ich bereits beim IconList Widget und dort gelöst.
                    Da ich die ganzen Funktionen vom IconList Widget eh auf das List Widget übertragen werden, werd ich das in diesem Zuge fixen. Dauert aber sicher nen bissle, weil das nicht ganz so trivial ist 😉
                      @Scrounger Perfekt 🙂 Bei der JSON Option wäre es noch klasse wenn man grundsätzlich die Wahl hätte zwischen DP oder Textfeld im EDIT, denn nicht alle JSON werden generiert - aber ein JSON ist schneller angepasst/erstellt als die Optionen im EDIT durchzuklicken 😉
                        Svenson6 last edited by
                        Moin zusammen!
                        Vielleicht eine Anfängerfrage, und vielleicht schon 26 mal beantwortet - sagt, wenn ich nerve. Trotzdem:
                        Ich habe ein Material-Design-List-Widget in VIS eingefügt. Das soll testweise mal drei Bool-Werte anzeigen. Folgendes JSON habe ich eingebaut:
                        		"background": "red",
                        		"text": "Feiertag",
                        		"subText": "",
                        		"image": "",
                        		"imageColor": "#ec0909",
                        		"imageActive": "",
                        		"imageActiveColor": "#5ad902",
                        		"buttonBackgroundColor": "",
                        		"buttonBackgroundActiveColor": "",
                        		"listType": "",
                        		"objectId": "feiertage.0.today.boolean",
                        		"buttonLink": "",
                        		"buttonToggleValueTrue": "",
                        		"buttonToggleValueFalse": "",
                        		"valueAppendix": "",
                        		"showValueLabel": "true",
                        		"statusBarColor": "green",
                        		"lockEnabled": "false"
                        		"text": "Ferien",
                        		"subText": "",
                        		"image": "",
                        		"imageActive": "",
                        		"listType": "",
                        		"objectId": "schoolfree.0.info.today",
                        		"buttonLink": "",
                        		"background": "green",
                        		"text": "Freier Tag",
                        		"subText": "",
                        		"image": "",
                        		"imageActive": "",
                        		"buttonBackgroundActiveColor": "#a0f628",
                        		"listType": "",
                        		"objectId": "0_userdata.0.freier_Tag",
                        		"buttonLink": "",
                        		"showValueLabel": "false",
                        		"statusBarColor": "",
                        "Art der Liste" steht auf Checkbox.
                        Im Prinzip funktioniert das auch, es zeigt korrekte Häkchen an, und die Werte lassen sich ggf. auch ändern. Das funktioniert aber nur, wenn ich auf der selben View drei Felder vom Typ String einfüge, die den jeweilgen Wert anzeigen. Lösche ich diese String-Felder, funktioniert das List-Widget nicht mehr.
                        Soll das so, muss das so? Oder mache ich was falsch?
                        Viele Grüße von
                        Sven
                        • Scrounger
                          Scrounger Developer @Svenson6 last edited by
                          @Svenson6
                          Das ist ein bug, ist genau dieser fehler:
                          Übergangsweise kannst lösen genauso wie du es machst z.B. String Widget mit den ObjektIds verwenden und diese halt einfach verstecken.
                            Alles klar, vielen Dank!
                              schmid_no1 last edited by
                              @Scrounger guten morgen und frohe Ostern
                              Ich habe eine kurze Frage bezüglich der Einstellmöglichkeiten beim list widget.
                              Wenn ich in meiner Liste die checkbox oder den Schalter verwende plus ein icon habe ich folgendes Phänomen. Ich schalten an der checkbox... mein icon switch. Ich schalte am knx meine checkbox schaltet, mein icon nicht.
                              Die checkbox oder der Schalter geben true/false aus und erkennen das auch mein knx gibt 1/0 aus.
                              Gibt es die Möglichkeit die Ausgabe und das erkennen der checkbox und des Schalters auf 1/0 umzustellen?
                              • Scrounger
                                Scrounger Developer @schmid_no1 last edited by
                                @schmid_no1 sagte in Material Design Widgets: List Widget:
                                schau mal hier, war das gleiche Thema:
                                https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/63
                                Und dann entsprechend 1 / 0 eintragen.
                                Gompman created this issue in Scrounger/ioBroker.vis-materialdesign
                                closed Icon List / List Symbol und Zustand aktualisiert nicht nach Datenpunktänderung Button Toggle #63
                                  schmid_no1 @Scrounger last edited by
                                  @Scrounger danke für deine schnelle Antwort
                                  Habe den knx Adapter auf die neueste Version geupdatet und die Gas mit true und false verwenden eingelesen und es funktioniert😁
                                  Danke nochmal für deine Denkanstöße
                                    @Scrounger
                                    Kann man das listen wideget scrollbar machen?
                                    • Scrounger
                                      @schmid_no1
                                      Du kannst jedes Widget scrollbar machen über overflow einstellungen:
                                        @Scrounger Danke
                                          Conquest last edited by
                                          @Scrounger
                                          Hallo gibt es eine Möglichkeit die Farbe der Checkbox im List-Widget zu ändern? Und wo kann ich eine andere Schriftart auswählen?
                                          Vielen Dank schon mal für deine Hilfe und dem tollen Adapter.
                                          • Scrounger
                                            Scrounger Developer @Conquest last edited by
                                            @Conquest
                                            rahmenfarbe:
                                            .mdc-checkbox__background {
                                            border-color: red !important;
                                            select farbe:
                                            Schriftart:
                                            font tag verwenden:
                                            https://www.w3schools.com/css/css_font.asp
                                            C 1 Reply Last reply Reply Quote 1
                                            vis
                                            31
                                            103
                                            14147
