    4. Test: Adapter Log Parser v0.x.x GitHub
    • Glasfaser
      Glasfaser @Beliar_666 last edited by Glasfaser
      @Beliar_666
      Hier auch ein fertiges View von Mic Link Text , muss nur auf die neuen Datenpunkte geändert werden.
      oder nimm mein eingestelles Widget materialdesign-Table
      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"logparser.0.filters.Error.json","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"countCols":"3","tableLayout":"standard","showHeader":true,"headerTextSize":"small","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"left","showColumn3":"true","colType3":"text","textAlign3":"left","label0":"Datum","label2":"Quelle","label1":"Meldung","padding_left0":"10","label3":"Einträge","dataJson":"","padding_left2":"","class":"mdui-table mdui-table-ascard-r250-l mdui-table-striped noSwipe","textSize3":"small","textColor2":"#8f8f8f","textSize2":"small","padding_right3":"","rowHeight":"","textSize0":"small","textSize1":"small","padding_left1":"","textColor0":"#8f8f8f","textColor1":"#8f8f8f","textColor3":"#8f8f8f","imageSize1":"","prefix3":"<span style=\"display: inline-block; word-wrap:break-word;\"></span>","suffix3":"","colorHeaderRowText":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","colorHeaderRowBackground":"#202020","colorRowBackground":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","colorRowText":"#8f8f8f","dividers":"","colorBackground":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","prefix2":"<span style=\"display: inline-block; word-wrap:break-word;\">","prefix1":"<span style=\"display: inline-block; word-wrap:break-word;\">","suffix2":"</span>","suffix1":"</span>","columnWidth0":"70","columnWidth1":"40","columnWidth3":"400","columnWidth2":"80","fontFamily3":"Jura-DemiBold","fontFamily2":"Jura-DemiBold","fontFamily1":"Jura-DemiBold","fontFamily0":"Jura-DemiBold","showColumn4":"true","colType4":"text","textAlign4":"center","name":"Tab_Error","colNoWrap0":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"8px","top":"71px","width":"970px","height":"650px","z-index":"3","background":"linear-gradient(0deg, #2c2a3f, #4f344c, #2c2a3f)","background-color":"#2e2e2e","color":"","overflow-y":"auto","border-radius":"10px","font-family":"Jura-DemiBold"},"widgetSet":"materialdesign"}]
      • Negalein
        Negalein Global Moderator @Glasfaser last edited by
        @Glasfaser sagte in Test: Adapter Log Parser v0.3.x GitHub:
        wie schaltest du zwischen den einzelnen Logstufen um?
        Derzeit verwende ich beim Script den View von Mic.
        • Glasfaser
          Glasfaser @Negalein last edited by Glasfaser
          @Negalein
          Ich nutze das umschalten mit einem Widget nicht !
          Habe einzelne Widget´s mit Sichtbarkeit geschaltet , da bin ich mit den Spalteneinstellungen pro Widget variabler .....
          Kann dir gerade da nicht helfen , da ich es nicht aktiviert habe !
          Bin selber noch am Testen .
          Zusammenfassen ist nicht aktiviert ... und die +++ soll er auch enfernen was noch nicht klappt.
          ...suche selber noch ...vielleicht ein Einstellungsfehler von mir 😞
          Negalein 2 Replies Last reply Reply Quote 0
          • Negalein
            So wie hier, dass Widgets bei true eines DP sichtbar werden?
            • Mic
              Mic Developer @Dutchman last edited by Mic
              @Dutchman
              Cool, vielen Dank für dein Feedback und Ideen, die Issues und den PR 😎 👍
              Auf die Issues habe ich entsprechend schon auf Github geantwortet, bei Issue 4 habe ich noch eine Frage an dich.
              Auf die Punkte, für die du Issues eröffnet hast, bin ich dort auf Github bereits eingegangen.
              Hier die weiteren:
              Der interface überschlaget mich mit langen texten, da verliert man sehr schnell de faden
              Der Aufbau gefällt mir auch noch nicht sonderlich. Mit den "langen Texten" dachte ich eigentlich, ich mach was gutes, d.h. ich erkläre die Felder hier direkt, damit z.B. nicht nur die Option "Remove PID" da steht, und keiner checkt, was damit gemeint ist.
              Klar muss das dann in der Doku erklärt sein, aber so sieht man halt die Erklärung direkt.
              Ich gebe ein anderes Beispiel:
              Das ist ein Screenshot vom Parser-Adapter. Was bedeutet da denn nun "Num", "Rolle", "Alt", "Ersatz", etc.? Klar, steht in der Doku, aber wäre es nicht besser, man sieht die Erklärung gleich im User Interface?
              Ich werfe diese Frage mal so in den Raum, mir ist es egal, die Pflege für mich ist sogar leichter und einfacher in der Adapter-Readme als in der admin/index_m.html, aber ich dachte ich tue den Usern was gutes damit.
              Die Tabellen sind leider sehr unuebersichtlich, auf nem 4k schirm hat man platz aber normaler PC/tabblet fast nicht mit zu arbeiten
              Da bin ich auch nicht glücklich damit. Außer kürzen (wie Term "Logs zusammenfassen") und Spaltenbreiten begrenzen fällt mir da aber nichts zu ein. Evtl. hat ein HTML/CSS Experte hier noch Tipps. Eigentlich bräuchte ich die Konfig dreidimensional 😁
              Hab dir n PR geschickt fuer issue/enhancement templates auf git
              Nice, danke dafür.
              • Glasfaser
                @Negalein
                Jipp ..
                @Mic
                Ich kann einsetzen was ich will und ich bekomme es nicht Editiert das +++
                Das ist doch das gleiche wie im Script ...oder ist etwas anderes zu beachten und der Log wird immer zusammengefasst !?
                LOG siehe oben ...
                Mic 2 Replies Last reply Reply Quote 0
                • Mic
                  Mic Developer @Glasfaser last edited by Mic
                  @Glasfaser
                  @Alle
                  Hier mal eine Übersicht für die Log-Script-Umsteiger, wie sich die Datenpunkte geändert haben. Exemplarisch für den Filter "Info". Im Log-Script wurde da immer noch "log..." vorangestellt.
                  Im VIS am besten die Widgets oder die View exportieren, im Texteditor suchen/ersetzen, und dann wieder importieren.
                  Hilft das?
                  Log-Script Adapter Log Parser
                  0_userdata.0.Log-Script.logInfo.logJSON logparser.0.filters.Info.json
                  0_userdata.0.Log-Script.logInfo.logJSONcount logparser.0.filters.Info.jsonCount
                  0_userdata.0.Log-Script.logInfo.clearJSON logparser.0.filters.Info.emptyJson
                  0_userdata.0.Log-Script.All.clearAllJSON logparser.0.emptyAllJson
                  0_userdata.0.Log-Script.All.lastTimeUpdated logparser.0.lastTimeUpdated
                  0_userdata.0.Log-Script.All.visView1.clearJSON logparser.0.visualization.table0.emptyJson
                  0_userdata.0.Log-Script.All.visView1.outputJSON logparser.0.visualization.table0.json
                  0_userdata.0.Log-Script.All.visView1.outputJSONcount logparser.0.visualization.table0.jsonCount
                  0_userdata.0.Log-Script.All.visView1.whichFilter logparser.0.visualization.table0.selection
                  • Mic
                    @Glasfaser
                    Was ist denn das für ein Datenpunkt "Loganzeige" aus deinem Screenshot? Denn kenne ich nicht.
                    Negalein Glasfaser 2 Replies Last reply Reply Quote 0
                    • Negalein
                      Negalein Global Moderator @Mic last edited by
                      @Mic sagte in Test: Adapter Log Parser v0.3.x GitHub:
                      ein selbsterstellter DP um die einzelnen Logs über Sichtbarkeit anzuzeigen! 🙂
                      Glasfaser Mic 2 Replies Last reply Reply Quote 1
                      • Glasfaser
                        @Negalein
                        Richtig .... 🙂
                        • Glasfaser
                          Glasfaser @Mic last edited by Glasfaser
                          @Mic
                          Hast du vielleicht ein Tip !!
                          siehe meine Anfrage oben Beitrag 18 ! ( Editieren +++ und Zusammenfassung )
                          Mic 1 Reply Last reply Reply Quote 0
                          • Mic
                            @Glasfaser sagte in Test: Adapter Log Parser v0.x.x GitHub:
                            Bitte poste den Link des Beitrags, den du meinst, direkt, ich sehe leider weder die Beitragsnummern, noch funktioniert die Beitragssuche nach diesem Text. Der Link ist in der Datumsangabe, neben dem Usernamen...
                            • Glasfaser
                              @Mic
                              Genau über dein @all
                              https://forum.iobroker.net/topic/31969/test-adapter-log-parser-v0-x-x-github/18
                              • Dutchman
                                Dutchman Developer Most Active Administrators @Mic last edited by
                                @Mic sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                haste wieder nen PR diesmal n par translations als Beispiel 🙂
                                zu den texten, mja macht auch sinn überschlage ist denke ich eher auf die Möglichkeiten bezogen.
                                Die Tabellen z.b. haben viele spalten (timestamp z.b. format währe doch selbe für alle ?) und die Eingabe Felder sind doch die vielen Optionen halte klein 🙂
                                Black list dahingegen ist übersichtlich meiner Meinung nach
                                die erste Tabelle ist also bissl zu gross, da müsste man vielleicht par Sachen auslagern der usability wegen 😊
                                • Mic
                                  Mic Developer @Negalein last edited by Mic
                                  @Negalein sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                  Die Sichtbarkeit von was?
                                  Die VIS-Tabelle zeigt den Inhalt von logparser.0.visualization.table0.json.
                                  Mit Buttons kann man den Datenpunkt logparser.0.visualization.table0.selection setzen. Also als Wert kann man da dann einen Filter setzen, z.B. also:
                                  Beispiel für Button "Info":
                                  (side note: und gebt btw @Scrounger bitte auch wirklich einen Kaffee aus, er macht hier tolle Arbeit mit seinem Adapter 🙂 )
                                  Drückt man auf den Button "Info", dann wird der State logparser.0.visualization.table0.selection mit "Info" gesetzt und im Datenpunkt logparser.0.visualization.table0.json dann die gefilterten "Info"-Logs angezeigt. Das zeigt dann die JSON-Tabelle auch an.
                                  Diese Buttons legt man dann auch für "Hubschrauberlandeplatz", "Katze-hat-hunger", "warn" oder whatever an 🙂
                                  Durch drücken auf den Button wird dann der Filter in der Tabelle angezeigt.
                                  Daher verstehe ich nicht, warum ihr da einen weiteren Datenpunkt habt...
                                  • Mic
                                    @Dutchman sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                    Cool, vielen Dank hierfür, schaue ich mir an. 🙂
                                    Mein "Problem" hier ist schlichtweg: Ich brauche halt im Adapter pro Filter die Einstellungen als Objekt (JSON).
                                    Dafür ist diese Tabelle gedacht, aber ich komme da an meine Grenzen (der oben zitierte Parser-Adapter wohl auch).
                                    Ausgelagert habe ich eh schon wie verrückt 😀 Also als globale Einstellungen, wie etwa Max. Anzahl Logeinträge, Spalten-Reihenfolge für Tabelle, Sortierung, etc.
                                    Ich habe dabei versucht, abzuwiegen, was wirklich individuell pro Filter konfiguriert werden muss, und wo man ggf. Abstriche machen muss und ggf. weitere Adapter-Instanzen braucht, um individuelle Fälle abzubilden. Manche Spalten, wie "Max. Länge" (also abschneiden nach x Zeichen) sind sicherlich diskussionswürdig, um "global" zu setzen. Ggf. auch "Logs zusammenfassen", wobei ich Use Cases habe, bei denen ich das nicht möchte. Dann bräuchte ich 3-4 Adapter-Instanzen.
                                    Ich persönlich brauche verschiedene. Ausgelagert global bräuchte ich auch da dann mehrere Adapter-Instanzen.
                                    Zusammengefasst:
                                    Hat wer einen besseren Vorschlag, wie man das in einem Adapter gut abgebildet bekommt? Kennt wer Adapter, in denen so was besser umgesetzt wurde? 🙂
                                    Dutchman Glasfaser 2 Replies Last reply Reply Quote 0
                                    • Dutchman
                                      Zusammengefasst:
                                      ehm, nope 🙂 👍
                                      • Negalein
                                        @Mic
                                        So ungefähr gehts mir auch.
                                        Logs zusammenfassen funktioniert nicht überall.
                                        • Negalein
                                          weil ich zB auf dieser View noch andere Sachen anzeigen lasse. zB das Backitup-Log.
                                          • Glasfaser
                                            @Mic
                                            So hier nochmal als Zusammnefassung :
                                            adapter log logging logparser parser vis
                                            21
                                            213
                                            32544
