    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер HomeMatic RPC (1.0.1)
    • Bluefox
      Bluefox last edited by
      @Alex1808:
      Порт сменил командой
      iobroker set hm-rpc.0 --port 2000
      На bin-rpc oшибки не ушли.. 😞
      ` > host-raspberrypi3 2016-03-21 23:58:06 info Restart adapter system.adapter.hm-rpc.0 because enabled
      host-raspberrypi3 2016-03-21 23:58:06 error instance system.adapter.hm-rpc.0 terminated with code 6 (uncaught exception)
      hm-rpc-0 2016-03-21 23:58:06 info binrpc -> 192.168.2.104:2001 init ["xmlrpc_bin://192.168.2.46:2000",""]
      TypeError: 2016-03-21 23:58:06 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError: 2016-03-21 23:58:06 error at Socket. (/opt/iobroker/node_modules/iobroker.hm-rpc/hm-rpc.js:377:17)
      TypeError: 2016-03-21 23:58:06 error at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:104:13
      TypeError: 2016-03-21 23:58:06 error at /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/server.js:85:45
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeResponse (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:44:25)
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeData (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:81:32)
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeArray (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:151:44)
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeData (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:86:36)
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeStruct (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:108:83)
      TypeError: 2016-03-21 23:58:06 error at Object.Protocol.encodeData (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/binrpc/lib/protocol.js:61:60)
      TypeError: 2016-03-21 23:58:06 error argument 'obj' must be type number, string, boolean or object
      uncaught 2016-03-21 23:58:06 error exception: argument 'obj' must be type number, string, boolean or object
      hm-rpc-0 2016-03-21 23:58:06 info binrpc -> 319 devices
      hm-rpc-0 2016-03-21 23:58:06 info binrpc <- listDevices ["hm-rpc.0"]
      hm-rpc-0 2016-03-21 23:58:06 info binrpc -> 192.168.2.104:2001 init ["xmlrpc_bin://192.168.2.46:2000","hm-rpc.0"] `
      На XML-RPC тоже без изменений
      > hm-rpc.0 2016-03-22 00:16:14 error hm-rpc.0 Error: XML-RPC fault: type error `
      на гите лежит версия, где обрабатываются ошибки.
      Можешь её попробовать (в случае ошибки должен появится файл: /opt/iobroker/node_modules/iobroker.hm-rpc/problem.json) ?
      У меня ошибка не воспроизводится.
      • Alex1808
        Alex1808 last edited by
        @Bluefox:
        У меня ошибка не воспроизводится. `
        Я был успел уже откатится на 0.5.2 и ошибка осталась. Тогда я полностью снёс адаптер и установил нормально через админку 0.5.2 (она сейчас последняя доступная) и всё заработало нормально без ошибок, был выбран xml-rpc.
        Накатил на верх с гита 1.0.4 >> работает нормально, без ошибок (в настройках остались xml-rpc и адрес самого распберри 192.168.2.46)
        В настройках адаптера попробовал выбрать bin-rpc, нажал на сохранить и пошел смотреть лог.. адаптер не запустился, в инстанциях горит жёлтый индикатор, в настройках адаптера стоит только локалхост 127.0.0.1 и 0.0.0.0
        reboot не помогает, адаптер так и не хочет запускаться и не выдаёт никаких ошибок.
        Через какое-то время в настройках адаптера всё-токи появился IP192.168.2.46 и я его смог выбрать и сохранить, но адаптер так и не запускается
        Вот что в логе (включен фильтр на hm-rpc-0, в общем логе ошибок нет)
        ` > hm-rpc-0 2016-03-23 11:29:46 info xmlrpc -> 192.168.2.104:2001 init ["http://192.168.2.46:2001","hm-rpc.0"]
        hm-rpc-0 2016-03-23 11:29:46 info xmlrpc server is trying to listen on 192.168.2.46:2001
        hm-rpc-0 2016-03-23 11:29:46 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.hm-rpc
        hm-rpc-0 2016-03-23 11:23:36 info xmlrpc -> 192.168.2.104:2001 init ["http://192.168.2.46:2002","hm-rpc.0"]
        hm-rpc-0 2016-03-23 11:23:36 info xmlrpc server is trying to listen on 192.168.2.46:2002
        hm-rpc-0 2016-03-23 11:23:36 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.hm-rpc
        hm-rpc-0 2016-03-23 11:22:36 info xmlrpc -> 192.168.2.104:2001 init ["http://0.0.0.0:2001",""]
        hm-rpc-0 2016-03-23 11:13:38 info xmlrpc -> 192.168.2.104:2001 init ["http://0.0.0.0:2001","hm-rpc.0"]
        hm-rpc-0 2016-03-23 11:13:38 info xmlrpc server is trying to listen on 0.0.0.0:2001
        hm-rpc-0 2016-03-23 11:13:37 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.hm-rpc
        hm-rpc-0 2016-03-23 11:10:32 info xmlrpc -> 192.168.2.104:2001 init ["http://127.0.0.1:2002",""]
        hm-rpc-0 2016-03-23 11:09:17 info xmlrpc -> 192.168.2.104:2001 init ["http://127.0.0.1:2002","hm-rpc.0"]
        hm-rpc-0 2016-03-23 11:09:17 info xmlrpc server is trying to listen on 127.0.0.1:2002
        hm-rpc-0 2016-03-23 11:09:17 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.hm-rpc
        hm-rpc-0 2016-03-23 11:07:22 info binrpc -> 192.168.2.104:2001 init ["xmlrpc_bin://0.0.0.0:2001",""]
        hm-rpc-0 2016-03-23 11:06:39 info binrpc -> 192.168.2.104:2001 init ["xmlrpc_bin://0.0.0.0:2001","hm-rpc.0"]
        hm-rpc-0 2016-03-23 11:06:39 info binrpc server is trying to listen on 0.0.0.0:2001
        hm-rpc-0 2016-03-23 11:06:39 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.hm-rpc `
        Порт сам кстати переписывается, то на 2001 то 2002 при переустановки адаптера
        • Alex1808
          Хотел по второму разу воспроизвести но фокус не прошел, теперь не в какую не переключает акторы.
          Заметил ещё такую особенность, если устанавливать сразу версию 1.0.4 без предварительной установки 0.5.2 то адаптер hm-rpc не появляется в инстанциях.
          • Alex1808
            Заметил что вышла новая версия RPC драйвера >(1.0.5), попробовал установить её на чистую систему.
            (актуальная прошивка, чистая установка ioBroker с минимальным набором драйверов)
            RPC драйвер ставил через вебморду, сразу заметил что после установки в настройках не появляется IP eth0
            ~~![](</s><URL url=)http://i.imgur.com/CrDsjX9.png" />
            ~~![](</s><URL url=)http://i.imgur.com/4N7IUxk.png" />
            В объектах драйвера не появились устройства
            (светофор на драйверах RPC зелёный, в логе всё чистенько, без ошибок)
            ~~![](</s><URL url=)http://i.imgur.com/3YG3mFr.png" />
            Перезапустил ioBroker и в логе появились ошибки
            ~~![](</s><URL url=)http://i.imgur.com/wW0iNIt.png" />
            В объектах драйвера появилась часть устройств (все так и не появились, ребут делал ещё пару раз), в описании к устройствам чистые поля, светофор переодически переходит на красный.
            ~~![](</s><URL url=)http://i.imgur.com/phGzTSQ.png" />
            Пару ребутов самого распберри причесали таки лог, ошибок пока не видно. но половина устройств так и не появились.~~~~~~~~~~
            • Bluefox
              @Alex1808:
              но половина устройств так и не появились. `
              Помогло?
              • Alex1808
                Нет, делал так уже несколько раз.
                –Update--
                Ещё несколько раз перегрузил распберри, галочку пару раз поставил для синхрона и наконец появились все устройства 🙂
                ~~![](</s><URL url=)http://i.imgur.com/xPEDeCX.png" />
                Только на старой версии таких танцев не было, сразу всё заводилось с пол пинка, настройки внёс и готово.~~
                • Bluefox
                  @Alex1808:
                  –Update--
                  Только на старой версии таких танцев не было, сразу всё заводилось с пол пинка, настройки внёс и готово.~~ ` ~~Да я не менял в новой практически ничего, кроме версии. :lol:
                  Добавил только настраиваемые порты и всё.~~
                  • Alex1808
                    @Bluefox:
                    Добавил только настраиваемые порты и всё. `
                    Вот это вот и странно.. 😉
                    А можно поставить как-то старую версию? Для чистоты эксперимента хотел попробовать ещё сначала установить старую, а затем проапгрейдить на актуальную.
                    • Bluefox
                      @Alex1808:
                      @Bluefox:
                      А можно поставить как-то старую версию? Для чистоты эксперимента хотел попробовать ещё сначала установить старую, а затем проапгрейдить на актуальную. `
                      cd /opt/iobroker
                      iobroker stop hm-rpc
                      npm install iobroker.hm-rpc@0.5.2
                      iobroker start hm-rpc
                      • Alex1808
                        @Bluefox:
                        cd /opt/iobroker
                        Полностью форматную Mickro-SD и записал последнюю актуальную прошивку, установил иоброкер.
                        установил через терминал RPC и здесь заминка, в драйверах показывает как установленный 0.5.2 с возможностью обновления до 1.0.5, а в инстанциях не появляется 😞
                        root@raspi3:/opt/iobroker# npm install iobroker.hm-rpc@0.5.2
                        iobroker.hm-rpc@0.5.2 node_modules/iobroker.hm-rpc
                        ├── homematic-xmlrpc@1.0.1 (xmlbuilder@0.4.2, sax@0.4.3)
                        └── binrpc@0.1.3 (async@0.9.2, put@0.0.6, binary@0.3.0)
                        root@raspi3:/opt/iobroker# iobroker restart
                        Stopping iobroker controller daemon...
                        iobroker controller daemon stopped.
                        Starting iobroker controller daemon...
                        iobroker controller daemon started. PID: 9834
                        root@raspi3:/opt/iobroker# iobroker start hm-rpc
                        Cannot find any instances of "hm-rpc"
                        root@raspi3:/opt/iobroker# reboot
                        Connection to 192.168.2.46 closed by remote host.
                        Connection to 192.168.2.46 closed.
                        Alexs-Mac-Pro-Alex:~ Alex$ ssh root@192.168.2.46
                        root@192.168.2.46's password:
                        root@raspi3:~# cd /opt/iobroker
                        Пробую через драйверы обновить на 1.0.5
                        Видимо зависимость с HM-Rega, поставил HM-Rega, появилась инстанция RPC.
                        Еду дальше 🙂
                        –-Update---
                        с 0.5.2 всё проходит без ошибок и заводится с первого запуска, светофор зелёный, всё устройства в полном объёме прописаны 😉
                        • Bluefox
                          @Alex1808:
                          @Bluefox:
                          cd /opt/iobroker
                          Еду дальше 🙂
                          –-Update---
                          с 0.5.2 всё проходит без ошибок и заводится с первого запуска, светофор зелёный, всё устройства в полном объёме прописаны 😉 `
                          светофор зелёный потому-что в этой версии ещё не поддерживался.
                          • Alex1808
                            @Bluefox:
                            светофор зелёный потому-что в этой версии ещё не поддерживался. `
                            Но и в логе не одной ошибки нет 😉
                            Обновил 0.5.2 на 1.0.5, всё нормально.. единственно в логе одна ошибочка проскакивает и почему-то обе версии (0.5.2 и 1.0.5) прописываются при старте.
                            ![](</s><URL url=)http://i.imgur.com/AHI51LX.png" />
                            2836
