    4. [Gelöst] Fehlermeldungen in Log-Datei
    • wendy2702
      wendy2702 last edited by
      Kannst du das log bzw. den teil mit dem Error mal als TXT hier in Code Tags Posten.
      Im Bild fehlt scheinbar die rechte Seite abgeschnitten.
        megaron last edited by megaron
        Hallo wendy2702,
        anbei der Log Auszug.
        host.raspberrypi
        2020-04-08 07:45:44.563
        info
        Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        host.raspberrypi
        2020-04-08 07:45:42.973
        info
        Restart adapter system.adapter.info.0 because enabled
        host.raspberrypi
        info
        instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
        host.raspberrypi
        error
        Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        host.raspberrypi
        error
        Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
        host.raspberrypi
        error
        Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
        host.raspberrypi
        error
        Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
        host.raspberrypi
        error
        Caught by controller[0]: at Array.forEach (<anonymous>)
        host.raspberrypi
        2020-04-08 07:45:42.972
        error
        Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
        host.raspberrypi
        error
        host.raspberrypi
        error
        Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
        host.raspberrypi
        error
        Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
        host.raspberrypi
        error
        Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
        host.raspberrypi
        2020-04-08 07:45:42.971
        error
        Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
        info.0
        2020-04-08 07:45:42.453
        info
        (21262) Terminated (NO_ERROR): Without reason
        info.0
        2020-04-08 07:45:42.452
        info
        (21262) terminating
        info.0
        2020-04-08 07:45:42.441
        info
        (21262) Reading process data every 120 seconds.
        info.0
        2020-04-08 07:45:42.414
        info
        (21262) cleaned everything up...
        info.0
        2020-04-08 07:45:42.413
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        info.0
        error
        (21262) TypeError: Cannot read property 'split' of undefined
        info.0
        2020-04-08 07:45:42.412
        error
        (21262) uncaught exception: Cannot read property 'split' of undefined
        info.0
        2020-04-08 07:45:42.302
        info
        (21262) Popup news was read...
        info.0
        2020-04-08 07:45:42.165
        info
        (21262) Reading CPU temp data every 60 seconds.
        info.0
        2020-04-08 07:45:42.162
        info
        (21262) Reading battery data every 120 seconds.
        info.0
        2020-04-08 07:45:42.061
        info
        (21262) Reading user data every 120 seconds.
        info.0
        2020-04-08 07:45:41.889
        info
        (21262) Reading memory data every 60 seconds.
        info.0
        2020-04-08 07:45:41.785
        info
        (21262) Reading disk data every 120 seconds.
        info.0
        2020-04-08 07:45:41.642
        info
        (21262) Reading CPU data every 60 seconds.
        info.0
        2020-04-08 07:45:41.619
        info
        (21262) Reading CPU current speed every 60 seconds.
        info.0
        2020-04-08 07:45:40.990
        info
        (21262) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.19.0
        • wendy2702
          @megaron sagte in Fehlermeldungen in Log-Datei:
          Bedeutet wenn du den Info deaktivierst kommt der Fehler nicht mehr ?
          Welche Version Info Adapter, JS-Controller hast du installiert?
            Richtig. Fehler tritt nur im aktivierten Zustand auf. (Ampel ist zudem auf rot)
            Node.js: v10.19.0
            Info.: 1.5.6 (aktuell)
            • wendy2702
              Der JS Controller ist zu alt denke ich.
                megaron @wendy2702 last edited by
                @wendy2702
                Ich hab das aktuelle Image auf der Homepage von IoBroker Zur Installation benutzt. Waren keinerlei Hinweise die Node.js zu aktualisieren. Hab mal ein bisschen gegoogelt und eine Version 2.2.9 gefunden (passt von der Logik nicht ganz zu der installierten 10.19.0). https://www.npmjs.com/package/iobroker.js-controller.
                Was wäre deine Empfehlung.
                Viele Grüße
                • wendy2702
                  Du verwechselst da etwas.
                  Node/Node Js
                  Ist etwas anderes als der JS Controller.
                  Node/NodeJS ist in Version 10.x ok.
                  JS Controller kann upgedatet werden.
                    @wendy2702
                    Hab gerade ein IoBroker Update/Upgrade gemacht. Js.controller ist aktuell (2.2.9). Problem ist weiterhin vorhanden. Hier auch noch das Protokoll.
                    Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Wed Apr  8 10:50:38 2020 from 192.168.178.34
                    pi@raspberrypi:~ $ cd /opt/iobroker
                    pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
                    pi@raspberrypi:/opt/iobroker $ sudo iobroker update
                    Used repository: default
                    hash unchanged, use cached sources
                    update done
                    Adapter    "admin"         : 3.7.8    , installed 3.7.8
                    Adapter    "alexa2"        : 3.0.5
                    Adapter    "alpha2"        : 1.0.0
                    Adapter    "amazon-dash"   : 1.1.0
                    Adapter    "artnet"        : 1.0.0
                    Adapter    "asterisk"      : 1.0.6
                    Adapter    "asuswrt"       : 1.0.1
                    Adapter    "b-control-em"  : 0.2.1
                    Adapter    "backitup"      : 1.4.5    , installed 1.4.5
                    Adapter    "beckhoff"      : 1.2.0
                    Adapter    "benq"          : 0.2.0
                    Adapter    "ble"           : 0.10.1
                    Adapter    "bmw"           : 1.3.3    , installed 1.3.3
                    Adapter    "bosesoundtouch": 0.2.4
                    Adapter    "botvac"        : 1.0.0
                    Adapter    "bring"         : 1.7.1
                    Adapter    "broadlink2"    : 2.0.2
                    Adapter    "bsblan"        : 0.0.6
                    Adapter    "bshb"          : 0.1.8
                    Adapter    "chromecast"    : 2.3.1
                    Adapter    "cloud"         : 3.0.2    , installed 3.0.2
                    Adapter    "comfoair"      : 0.3.2
                    Adapter    "contactid"     : 1.0.0
                    Adapter    "coronavirus-statistics": 0.5.5
                    Adapter    "countdown"     : 1.1.0
                    Adapter    "cul"           : 1.2.1
                    Adapter    "daikin"        : 1.0.5
                    Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
                    Adapter    "deconz"        : 1.2.6
                    Adapter    "denon"         : 1.7.2    , installed 1.7.2
                    Adapter    "digitalstrom"  : 0.5.5
                    Adapter    "discovergy"    : 0.5.0
                    Adapter    "discovery"     : 2.2.2    , installed 2.2.2
                    Adapter    "ds18b20"       : 1.1.4
                    Adapter    "dwd"           : 2.4.6
                    Adapter    "ebus"          : 1.0.0
                    Adapter    "egigeozone"    : 0.1.2
                    Adapter    "ekey"          : 1.1.0
                    Adapter    "email"         : 1.0.6
                    Adapter    "emby"          : 1.0.2
                    Adapter    "energymanager" : 1.2.2
                    Adapter    "enet"          : 1.0.1
                    Adapter    "epson_stylus_px830": 0.2.1
                    Adapter    "fakeroku"      : 0.2.1
                    Adapter    "fb-checkpresence": 0.3.0   , installed 0.3.0
                    Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
                    Adapter    "fhem"          : 1.3.0
                    Adapter    "find-my-iphone": 0.2.15
                    Adapter    "firetv"        : 0.0.27
                    Adapter    "flot"          : 1.9.2    , installed 1.9.2
                    Adapter    "foobar2000"    : 1.0.0
                    Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                    Adapter    "fritzdect"     : 0.2.4    , installed 0.2.4
                    Adapter    "fronius"       : 1.0.5
                    Adapter    "fullcalendar"  : 1.1.0
                    Adapter    "fullybrowser"  : 1.0.0
                    Adapter    "g-homa"        : 0.5.1
                    Adapter    "geofency"      : 0.3.2
                    Adapter    "gruenbeck"     : 0.0.18
                    Adapter    "habpanel"      : 0.3.4
                    Adapter    "haier"         : 1.0.2
                    Adapter    "ham"           : 1.1.2
                    Adapter    "ham-wemo"      : 1.0.1
                    Adapter    "harmony"       : 1.2.2    , installed 1.2.2
                    Adapter    "heatingcontrol": 0.3.19
                    Adapter    "heytech"       : 0.2.0
                    Adapter    "hid"           : 0.1.17
                    Adapter    "history"       : 1.8.7    , installed 1.8.7
                    Adapter    "hm-rega"       : 2.5.5    , installed 2.5.5
                    Adapter    "hm-rpc"        : 1.12.10  , installed 1.12.10
                    Adapter    "hmip"          : 0.0.11
                    Adapter    "homeconnect"   : 0.0.26
                    Adapter    "homee"         : 0.3.1
                    Adapter    "homepilot"     : 1.0.3
                    Adapter    "hp-ilo"        : 1.0.5
                    Adapter    "hs100"         : 1.0.10
                    Adapter    "hue"           : 3.2.3
                    Adapter    "hue-extended"  : 1.2.3
                    Adapter    "ical"          : 1.7.0    , installed 1.7.0
                    Adapter    "icons-addictive-flavour-png": 0.1.0
                    Adapter    "icons-fatcow-hosting": 0.1.0
                    Adapter    "icons-icons8"  : 0.0.1
                    Adapter    "icons-material-png": 0.1.0
                    Adapter    "icons-material-svg": 0.1.0
                    Adapter    "icons-mfd-png" : 1.0.2
                    Adapter    "icons-mfd-svg" : 1.0.2
                    Adapter    "icons-open-icon-library-png": 0.1.2
                    Adapter    "icons-ultimate-png": 1.0.1
                    Adapter    "influxdb"      : 1.7.0
                    Adapter    "info"          : 1.5.6    , installed 1.5.6
                    Adapter    "innogy-smarthome": 0.3.3
                    Adapter    "iogo"          : 0.5.7
                    Adapter    "iot"           : 1.1.8
                    Adapter    "iqontrol"      : 0.2.16
                    Adapter    "javascript"    : 4.3.4    , installed 4.3.4
                    Adapter    "jeelink"       : 0.1.0
                    Controller "js-controller" : 2.2.9    , installed 2.2.9
                    Adapter    "kecontact"     : 0.1.0
                    Adapter    "klf200"        : 0.9.5
                    Adapter    "km200"         : 1.1.6
                    Adapter    "knmi-weather"  : 0.2.0
                    Adapter    "knx"           : 1.0.39   , installed 1.0.39
                    Adapter    "kodi"          : 1.0.0
                    Adapter    "kress"         : 2.5.5
                    Adapter    "lametric"      : 0.0.7
                    Adapter    "landroid"      : 1.0.3
                    Adapter    "lcn"           : 0.3.2
                    Adapter    "lgtv"          : 1.1.5
                    Adapter    "lgtv-rs"       : 0.0.4
                    Adapter    "lgtv11"        : 1.0.5
                    Adapter    "lifx"          : 0.1.0
                    Adapter    "lightify"      : 0.2.16
                    Adapter    "link"          : 0.5.9
                    Adapter    "linkeddevices" : 1.1.1
                    Adapter    "lovelace"      : 0.2.3
                    Adapter    "loxone"        : 1.0.0
                    Adapter    "luftdaten"     : 0.0.11
                    Adapter    "lupusec"       : 1.2.3
                    Adapter    "luxtronik1"    : 0.2.2
                    Adapter    "material"      : 0.12.1
                    Adapter    "maxcube"       : 0.1.2
                    Adapter    "maxcul"        : 1.1.2
                    Adapter    "mbus"          : 2.1.4
                    Adapter    "megad"         : 1.2.1
                    Adapter    "megadd"        : 0.2.0
                    Adapter    "megaesp"       : 0.1.0
                    Adapter    "mercedesme"    : 0.0.21
                    Adapter    "mercury"       : 0.1.0
                    Adapter    "meross"        : 1.3.11
                    Adapter    "meteoalarm"    : 1.0.9
                    Adapter    "miele"         : 0.1.5
                    Adapter    "mielecloudservice": 1.1.0
                    Adapter    "mihome"        : 1.3.0    , installed 1.3.0
                    Adapter    "mihome-lamp"   : 1.1.0
                    Adapter    "mihome-plug"   : 0.2.0
                    Adapter    "mihome-vacuum" : 1.1.5    , installed 1.1.5
                    Adapter    "mikrotik"      : 1.0.11
                    Adapter    "milight"       : 0.3.6
                    Adapter    "milight-smart-light": 0.2.7
                    Adapter    "mobile"        : 0.5.0    , installed 0.5.0
                    Adapter    "modbus"        : 3.0.0
                    Adapter    "moma"          : 1.2.3
                    Adapter    "mpd"           : 1.0.0
                    Adapter    "mqtt"          : 2.1.1
                    Adapter    "mqtt-client"   : 1.3.1
                    Adapter    "musiccast"     : 0.1.3
                    Adapter    "mysensors"     : 2.0.0
                    Adapter    "nanoleaf-lightpanels": 0.8.1
                    Adapter    "nello"         : 2.0.6
                    Adapter    "netatmo"       : 1.3.1    , installed 1.3.1
                    Adapter    "nibeuplink"    : 0.3.0
                    Adapter    "nina"          : 0.0.22
                    Adapter    "node-red"      : 1.13.0
                    Adapter    "nuki"          : 1.2.0
                    Adapter    "nuki-extended" : 2.2.5
                    Adapter    "nut"           : 1.1.3
                    Adapter    "odl"           : 1.0.5
                    Adapter    "oilfox"        : 0.0.5
                    Adapter    "onkyo"         : 2.0.3
                    Adapter    "onvif"         : 0.0.2
                    Adapter    "openhab"       : 1.1.0
                    Adapter    "openligadb"    : 1.0.0
                    Adapter    "openweathermap": 0.1.0
                    Adapter    "opi"           : 0.1.1
                    Adapter    "oppoplayer"    : 0.2.1
                    Adapter    "owfs"          : 0.6.4
                    Adapter    "owntracks"     : 0.6.2
                    Adapter    "panasonic-viera": 1.0.2
                    Adapter    "parser"        : 1.0.7
                    Adapter    "paw"           : 0.0.7
                    Adapter    "phantomjs"     : 1.0.1
                    Adapter    "pi-hole"       : 1.2.3
                    Adapter    "piface"        : 1.0.0
                    Adapter    "pimatic"       : 0.1.5
                    Adapter    "ping"          : 1.3.2    , installed 1.3.2
                    Adapter    "places"        : 0.7.0
                    Adapter    "plex"          : 0.8.9
                    Adapter    "plexconnect"   : 0.0.7
                    Adapter    "pollenflug"    : 1.0.4
                    Adapter    "proxmox"       : 1.0.1
                    Adapter    "proxy"         : 1.1.1
                    Adapter    "pushbullet"    : 0.0.11
                    Adapter    "pushover"      : 1.2.3
                    Adapter    "pushsafer"     : 0.1.8
                    Adapter    "radar2"        : 1.0.9
                    Adapter    "radiohead"     : 1.0.4
                    Adapter    "rflink"        : 2.0.0
                    Adapter    "rickshaw"      : 1.0.0
                    Adapter    "ring"          : 1.0.5
                    Adapter    "robonect"      : 0.0.12
                    Adapter    "roomba"        : 1.1.1
                    Adapter    "rpi2"          : 1.1.1
                    Adapter    "s7"            : 1.1.7
                    Adapter    "samsung"       : 0.2.9
                    Adapter    "sayit"         : 1.8.2
                    Adapter    "sbfspot"       : 2.4.0
                    Adapter    "scenes"        : 1.1.0
                    Adapter    "schoolfree"    : 0.5.0
                    Adapter    "shelly"        : 3.1.6
                    Adapter    "shuttercontrol": 0.4.3
                    Adapter    "sia"           : 1.0.3
                    Adapter    "siegenia"      : 1.0.0
                    Adapter    "simple-api"    : 2.3.2    , installed 2.3.2
                    Adapter    "smappee"       : 0.2.2
                    Adapter    "smartmeter"    : 3.0.10
                    Adapter    "snips"         : 1.5.0
                    Adapter    "snmp"          : 0.5.0
                    Adapter    "socketio"      : 2.1.2    , installed 3.0.1
                    Adapter    "solarlog"      : 1.2.4
                    Adapter    "solarwetter"   : 1.0.0
                    Adapter    "sonnen"        : 1.3.0
                    Adapter    "sonoff"        : 2.3.3
                    Adapter    "sonos"         : 2.0.1
                    Adapter    "sony-bravia"   : 1.0.1
                    Adapter    "spotify-premium": 1.0.0
                    Adapter    "sql"           : 1.9.5
                    Adapter    "squeezebox"    : 1.0.0
                    Adapter    "squeezeboxrpc" : 1.0.0
                    Adapter    "starline"      : 1.0.0
                    Adapter    "statistics"    : 0.2.2
                    Adapter    "stiebel-isg"   : 1.4.11
                    Adapter    "sunnyportal"   : 0.1.3
                    Adapter    "swiss-weather-api": 0.2.0
                    Adapter    "systeminfo"    : 0.3.1
                    Adapter    "tahoma"        : 0.3.2
                    Adapter    "tankerkoenig"  : 2.0.5
                    Adapter    "telegram"      : 1.4.3
                    Adapter    "terminal"      : 0.1.2
                    Adapter    "tesla-motors"  : 0.2.3
                    Adapter    "text2command"  : 1.3.0
                    Adapter    "tr-064"        : 0.4.14   , installed 0.4.14
                    Adapter    "tradfri"       : 2.5.2
                    Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                    Adapter    "tuya"          : 3.2.2
                    Adapter    "tvspielfilm"   : 1.0.4
                    Adapter    "unifi"         : 0.3.1
                    Adapter    "upnp"          : 1.0.11
                    Adapter    "valloxmv"      : 1.0.3
                    Adapter    "vcard"         : 0.0.9
                    Adapter    "velux"         : 0.0.5
                    Adapter    "viessmann"     : 1.2.4
                    Adapter    "virtualpowermeter": 1.0.0
                    Adapter    "vis"           : 1.2.4    , installed 1.2.4
                    Adapter    "vis-bars"      : 0.1.4
                    Adapter    "vis-canvas-gauges": 0.1.5
                    Adapter    "vis-colorpicker": 1.1.1
                    Adapter    "vis-fancyswitch": 1.1.0
                    Adapter    "vis-google-fonts": 0.1.0
                    Adapter    "vis-history"   : 1.0.0
                    Adapter    "vis-hqwidgets" : 1.1.4
                    Adapter    "vis-inventwo"  : 1.0.0
                    Adapter    "vis-jqui-mfd"  : 1.0.12
                    Adapter    "vis-justgage"  : 1.0.2
                    Adapter    "vis-keyboard"  : 0.0.2
                    Adapter    "vis-lcars"     : 1.0.4
                    Adapter    "vis-map"       : 1.0.4
                    Adapter    "vis-metro"     : 1.1.2
                    Adapter    "vis-players"   : 0.1.5
                    Adapter    "vis-plumb"     : 1.0.2
                    Adapter    "vis-rgraph"    : 0.0.2
                    Adapter    "vis-timeandweather": 1.1.7
                    Adapter    "vis-weather"   : 2.5.2
                    Adapter    "vr200"         : 1.0.0
                    Adapter    "weatherunderground": 3.1.6
                    Adapter    "web"           : 2.4.10   , installed 2.4.10
                    Adapter    "weishaupt-wem" : 0.0.8
                    Adapter    "wetty"         : 0.1.1
                    Adapter    "wiffi-wz"      : 2.2.0
                    Adapter    "wifilight"     : 0.2.0
                    Adapter    "wled"          : 0.5.0
                    Adapter    "wm-bus"        : 0.1.12
                    Adapter    "wolf"          : 0.9.2
                    Adapter    "worx"          : 1.0.0
                    Adapter    "xbox"          : 0.6.1
                    Adapter    "xs1"           : 1.0.2
                    Adapter    "yahka"         : 0.9.2
                    Adapter    "yamaha"        : 0.3.19
                    Adapter    "yeelight-2"    : 1.0.3
                    Adapter    "youtube"       : 0.0.6
                    Adapter    "yr"            : 2.0.3
                    Adapter    "zigbee"        : 1.0.3
                    Adapter    "zont"          : 0.5.3
                    Adapter    "zwave"         : 1.7.3
                    pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade self
                    Host    "raspberrypi"    is up to date.
                    pi@raspberrypi:/opt/iobroker $ sudo iobroker start
                    • wendy2702
                      Was kommt bei
                      iobroker -v
                        megaron @megaron last edited by Negalein
                        @megaron
                        Last login: Wed Apr  8 18:29:29 2020 from 192.168.178.37
                        pi@raspberrypi:~ $ Iobroker -v
                        -bash: Iobroker: Kommando nicht gefunden.
                        pi@raspberrypi:~ $
                        • wendy2702
                          wendy2702 @megaron last edited by
                          @megaron kleines „i“ bei iobroker.
                          Habe es oben korrigiert
                            @wendy2702
                            2.2.9
                            • wendy2702
                              Node.js: v10.19.0
                              Also hast du schon die neueste JS Controller Version.
                              Woher hast du dann die 1.5.6 ?
                                megaron @wendy2702 last edited by megaron
                                @wendy2702
                                1.5.6 ist die Version des Info Adapters (Information tab)
                                • wendy2702
                                  Also dann mal schauen ob hier etwas für doch dabei ist:
                                  Such Ergebnisse
                                  Oder mal auf Version 1.5.7 upgraden (ist im Latest)
                                  Oder Instanz und Adapter löschen und neu installieren.
                                  Wäre das was ich machen würde.
                                    @wendy2702
                                    Hab die Instanz gelöscht. Muss ich den Adapter auch löschen? Und wie komme ich an die latest 1.5.7. ?
                                    Auf IoBroker.info hab ich die 1.6.0 gefunden.
                                    • wendy2702
                                      Mir wird bei einstellen von "Latest" als Verwahrungsort die 1.5.7 angeboten.
                                      1.6.0 kann man wahrscheinlich direkt aus Github installieren.
                                        @wendy2702
                                        Wo kann man denn latest einstellen. Sorry vielleicht für die blöde Frage aber ich hab den IoBroker erst ist seit einer Woche und von Linux habe ich noch weniger Ahnung.
                                        Hab jetzt die 1.6.0 drauf. Gleiche Fehlermeldungen:
                                        host.raspberrypi	2020-04-08 19:24:56.118	info	Restart adapter system.adapter.info.0 because enabled
                                        host.raspberrypi	2020-04-08 19:24:56.118	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
                                        host.raspberrypi	2020-04-08 19:24:56.118	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                        host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:103452)
                                        host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
                                        host.raspberrypi	2020-04-08 19:24:56.117	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
                                        host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at Array.forEach (<anonymous>)
                                        host.raspberrypi	2020-04-08 19:24:56.116	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
                                        host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
                                        host.raspberrypi	2020-04-08 19:24:56.115	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
                                        host.raspberrypi	2020-04-08 19:24:56.114	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
                                        host.raspberrypi	2020-04-08 19:24:56.111	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
                                        info.0	2020-04-08 19:24:55.579	info	(23189) Terminated (NO_ERROR): Without reason
                                        info.0	2020-04-08 19:24:55.578	info	(23189) terminating
                                        info.0	2020-04-08 19:24:55.531	info	(23189) cleaned everything up...
                                        info.0	2020-04-08 19:24:55.530	error	(23189) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
                                        info.0	2020-04-08 19:24:55.529	error	(23189) uncaught exception: Cannot read property 'split' of undefined
                                        info.0	2020-04-08 19:24:55.407	info	(23189) Popup news was read...
                                        info.0	2020-04-08 19:24:53.538	info	(23189) starting. Version 1.6.0 in /opt/iobroker/node
                                        • wendy2702
                                          OK.
                                          Dann hast du wohl auch noch nicht viel eingerichtet, oder?
                                          Wie hast du den PI installiert? Image oder Manuell?
                                          Wenn manuell, welche SW ?
                                          Debian oder was?
                                            @wendy2702
                                            Hallo, die Installation ist über Image erfolgt.
                                            „IoBroker Image für Raspberry Pi2/3/4 Buster 20191127“ Von der IoBroker.net page.
                                            Ca. 10 Adapter eingerichtet.
                                            error error im log error log errorproblem problem
                                            2001
