    4. Test: Adapter Log Parser v0.x.x GitHub
    • Scrounger
      Scrounger Developer @Mic last edited by
      @Mic
      Hab heut schon den ganzen Tag mitgelesen und mich drauf gefreut heute noch den Adapter auszuprobieren. Installiert, läuft, perfekt - vielen Dank super Adapter!
      Vorallem die Struktur finde ich sehr durchdacht. Speziell die Datenpunkte für Visualisierung und den selection Datenpunkt, bin begeistert 🙂
      Hab gleich mal nen MDW Select Wigdet gebastelt für den selection Datenpunkt:
      [{"tpl":"tplVis-materialdesign-Select","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","inputType":"text","inputLayout":"regular","showInputMessageAlways":"true","showInputCounter":"true","clearIconShow":"true","listDataMethod":"jsonStringObject","countSelectItems":"1","listPosition":"auto","showSelectedIcon":"prepend-inner","showValue":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"jsonStringObject":"[\n\t{\n\t\t\"text\": \"Info\",\n\t\t\"value\": \"Info\"\n\t},\n\t{\n\t\t\"text\": \"Warn\",\n\t\t\"value\": \"Warn\"\n\t},\n\t{\n\t\t\"text\": \"Error\",\n\t\t\"value\": \"Error\"\n\t},\n\t{\n\t\t\"text\": \"WarnAndError\",\n\t\t\"value\": \"WarnAndError\"\n\t},\n\t{\n\t\t\"text\": \"Homematic\",\n\t\t\"value\": \"Homematic\"\n\t}\n]"},"style":{"left":"34px","top":"230px","width":"353px","height":"38px"},"widgetSet":"materialdesign"}]
      Jetzt hab ich endlich nen grund gefunden dem Select Widget noch beizubringen mit multistates umgehen zu können.
      Scrounger Mic 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @Mic last edited by sigi234
        @Mic
        Hallo, Super Adapter ! 👍
        Habe mal eine View gebastelt, irgendwo habe ich einen Fehler, die Logs springen wieder zurück.
        Kannst du die View mal testen?
        VIEW_Log_Mic3_sigi234.txt
        Mic Feuersturm 2 Replies Last reply Reply Quote 1
          Kuddel last edited by
          ich habe das gleiche problem wie @Glasfaser
          Ich will alle Logeinträge die +++ enthalten in einer Ansicht zusammenfassen.
          Im Log selber sollen die +++ aber nicht auftauchen:
          Whitelist: +++
          Entferne: /script.js.[^:]*: /, "+++"
          Ergebnis:
          Mic 1 Reply Last reply Reply Quote 0
            Mir ist noch etwas aufgefallen:
            Gestern ist eingestellt und im Log steht yesterday
            • Scrounger
              Scrounger Developer @Scrounger last edited by
              @Scrounger sagte in Test: Adapter Log Parser v0.x.x GitHub:
              Zur Info mt der neuen Material Design Widgets Version 0.3.0 geht das jetzt (demnächst im latest).
              D.h. beim Select Widget einfach den Datenpunkt selection eintragen
              und bei Eingabemethode Objekt hat Werteliste auswählen:
              So funktioniert die Auswahl dann out of the box.
              Knallochse Mic 2 Replies Last reply Reply Quote 1
              • Knallochse
                Knallochse @Scrounger last edited by
                @Scrounger Ich habe heute mal eine Testview mit dem Select Widget erstellt. Hat super funktioniert.
                Wegen Platzmangel habe ich dann in meiner normalen View in einem Popup Fenster zu arbeiten (Widget - jqui -container - icon - view in Dialog).
                Da wird das Auswahlmenü nicht angezeit. Als ich dann das Popup Fenster geschlossen hatte war das Auswahlfenster da (lag dahinter). Das spielen mit dem Z-Index brachte leider auch keinen Erfolg.
                • Knallochse
                  Knallochse @Mic last edited by
                  @Mic Echt geile Sache dein Adapter. Funktioniert so weit ich das bis jetzt überblicken kann - Hervorragend .
                  Wie @Dutchman schon schrieb, wären mehr Adapter zur Auswahl (Parser-Regeln) bestimmt nicht schlecht.
                  Was man nicht braucht kann man ja deaktivieren / oder löschen.
                  Bei löschen vielleicht noch einen Button für "Werkszustand 😀 "
                  Die Bedienung ist für mich sehr schlüssig und finde ich toll.
                  • Mic
                    Mic Developer @Kuddel last edited by
                    @Kuddel sagte in Test: Adapter Log Parser v0.x.x GitHub:
                    Whitelist: +++
                    Ergebnis:
                    Danke, damit konnte ich es reproduzieren. War ein Fehler im Adapter. Aber bitte die Strings ohne Anführungszeichen, also /script\.js\.[^:]*: /, "+++" ändern in /script\.js\.[^:]*: /, +++.
                    --> Sollte behoben sein in aktueller Github-Version 0.4.1
                    Bitte um dein Test-Feedback 🙂
                    Über folgendes Issue werde ich es später ermöglichen, dass man auch Anführungszeichen (") benutzen kann wenn man will: https://github.com/Mic-M/ioBroker.logparser/issues/11
                    Mic-M created this issue in Mic-M/ioBroker.logparser
                    closed Enhancement: allow quotation marks for specifying strings vs. regex #11
                    • Mic
                      War ein Bug. --> Sollte behoben sein in aktueller Github-Version 0.4.1
                      • Mic
                        Mic Developer @Dutchman last edited by
                        @Dutchman sagte in Test: Adapter Log Parser v0.x.x GitHub:
                        Die Tabellen sind leider sehr unuebersichtlich, auf nem 4k schirm hat man platz aber normaler PC/tabblet fast nicht mit zu arbeiten
                        Habe jetzt in Version in aktueller Github-Version 0.4.1 zumindest die Spaltenbreiten optimiert (zumindest für Chrome Browser).
                        • Mic
                          Mic Developer @Scrounger last edited by
                          @Mic
                          Vielen Dank für dein Feedback, schätze ich sehr 👍 Ebenso, dass du das direkt aufgegriffen hast für deinen Adapter 😎
                          Ich bin noch an meinem Adapter beschäftigt (Debugging etc.), daher dauert es noch etwas, bis ich deine Implementierungen testen und Feedback geben kann.
                          • Mic
                            Mic Developer @sigi234 last edited by
                            @sigi234 sagte in Test: Adapter Log Parser v0.x.x GitHub:
                            @Mic
                            Danke für dein Feedback Sigi, schöne View hast du da 🙂
                            Was meinst du mit "springen wieder zurück"? Ich komme nicht gleich dazu, mir das anzusehen, evtl. erst in ein paar Tagen, also nicht wundern 😉
                            Stephan Schleich 1 Reply Last reply Reply Quote 0
                            • Mic
                              Mic Developer @Knallochse last edited by
                              @Knallochse sagte in Test: Adapter Log Parser v0.x.x GitHub:
                              Danke auch für deine Rückmeldung 😎
                              Das mit Adapter-Auswahl ist schon per Issue adressiert, werde das aber wohl erst angehen, sobald ansonsten alles passt, will ihn erstmal zügig "latest" und dann "stable" hin bekommen 🙂 Da hab ich noch ein paar Sachen zu tun (u.a. gute Dokumentation, Übersetzungen, etc.).
                              Meine Idee ist aktuell diese: Now regarding issue #2 - probably it would be better to let the user choose which adapters to add to the filter (so multiple selection by using the ctrl key)....
                              • Glasfaser
                                Glasfaser @Mic last edited by Glasfaser
                                @Mic
                                Für was ist diese Einstellung .... ?
                                Mic Glasfaser 2 Replies Last reply Reply Quote 0
                                  Kuddel @Mic last edited by Kuddel
                                  @Mic sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                  Whitelist: +++
                                  Ergebnis:
                                  jetzt werden die Einträge nicht mehr aufgelistet 😞
                                  javascript.0	2020-04-09 08:44:39.257	info	(63817) script.js.smarthome.z_test.test_2: +++ test +++
                                  Letzter Eintrag:
                                  Konfig:
                                  EDIT:
                                  Die Einträge werden jetzt doch aufgelistet:
                                  Wie entferne ich jetzt noch die +++ am Ende?
                                  EDIT 2:
                                  Habe jetzt folgenden Workaround:
                                  Bereinige Log Message*: /script.js.[^:]*: /,+++ , +++
                                  • Stephan Schleich
                                    Stephan Schleich @Mic last edited by Stephan Schleich
                                    @Mic
                                    Er meint damit, dass wen du Warn,Error etc. anklickst und ein Info Log kommt er sofort wieder auf Info springt
                                    • Mic
                                      Mic Developer @Stephan Schleich last edited by
                                      @sigi234
                                      @Stephan-Schleich sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                      Ok, danke euch. Sollte nun behoben sein mit Version 0.4.2.
                                        Ja behoben, Danke.👍
                                        • Mic
                                          EDIT 2:
                                          Dein Feedback zeigt, wie wichtig eure Tests sind 👍
                                          Es gab noch einen Fehler bezüglich "multiple regex/string config values separated by comma". Habe ich nun mit 0.4.3 behoben.
                                          Dadurch solltest du auch deinen Workaround nicht mehr benötigen.
                                          • Mic
                                            Mic Developer @Glasfaser last edited by
                                            @Glasfaser sagte in Test: Adapter Log Parser v0.x.x GitHub:
                                            @Mic
                                            Keine Ahnung 🤔 Scheint bei mehreren Adaptern so zu sein, dass die angezeigt werden, u.a. auch RSS Parser. Was stellt man denn da normalerweise ein? Wird evtl. durch den "Adapter Creator" so hinzugefügt...
                                            adapter log logging logparser parser vis
                                            21
                                            213
                                            32551
