    4. Beta Test js-controller 3.0.x auf GitHub
      sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
      @apollon77
      KURZ-Bericht folgt:
      Folgende Adapter bleiben Rot:
      • firetv.0
      • wifilight.0
      Warnmeldungen:
      coronavirus-statistics.0	2020-04-08 21:00:05.549	warn	(21724) This object will not be created in future versions. Please report this to the developer.
      coronavirus-statistics.0	2020-04-08 21:00:05.549	warn	(21724) Object countryTranslator is invalid: obj.type has to exist
      admin.0	2020-04-08 21:04:03.839	warn	(13820) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      web.0	2020-04-08 21:15:27.595	warn	(19708) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      Hinweis:
      Die warn kommen im 10 Minuten Takt auch für andere Adapter. Stelle diese jetzt nicht alle rein.
      • foxriver76
        foxriver76 Developer @sigi234 last edited by foxriver76
        @sigi234 Was steht denn im Log, bei denen, die rot bleiben?
          sigi234 Forum Testing Most Active @foxriver76 last edited by
          @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
          wifilight.0	2020-04-08 21:05:58.853	error	at process._tickCallback (internal/process/next_tick.js:68:7)
          wifilight.0	2020-04-08 21:05:58.853	error	at Promise.all.then (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:7926:76)
          wifilight.0	2020-04-08 21:05:58.853	error	at Object.options.ready (C:\Program Files\iobroker\Test\node_modules\iobroker.wifilight\node_modules\soef\soef.js:1131:13)
          wifilight.0	2020-04-08 21:05:58.853	error	at checkIfUpdated (C:\Program Files\iobroker\Test\node_modules\iobroker.wifilight\node_modules\soef\soef.js:1006:20)
          wifilight.0	2020-04-08 21:05:58.853	error	(19316) TypeError: Cannot read property 'getState' of undefined
          wifilight.0	2020-04-08 21:05:58.851	error	(19316) uncaught exception: Cannot read property 'getState' of undefined
          • foxriver76
            @sigi234 Ich nehme an firetv dasselbe? Ist ja auch soef..
              Ja
                darkiop Most Active last edited by
                Was hat es denn mit soef auf sich? Liest man immer wieder mal hier im Forum. Ehemaliger Entwickler der eine lib bereitgestellt die aktuell nicht mehr gepflegt wird?
                • foxriver76
                  foxriver76 Developer @darkiop last edited by
                  @darkiop Ja + kein Kontakt zu dem Entwickler. Einige Adapter haben wir mittlerweile erfolgreich zu uns umziehen können, wie tr-064. Allerdings selbst nach Umzug, muss alles was in seiner eigenen Lib gebaut wurde umgeschrieben werden. Leider nutzt die Lib nun Methoden die wir nicht mehr bereitstellen wollten, da Sie dem von uns gedachten Konzept widersprechen.
                  • Basti97
                    Basti97 Most Active last edited by
                    Super gute Arbeit von euch und Danke das ihr so ein geiles System erfunden habt bzw immer auf den neuesten Stand haltet.
                    Ich werde es auch mal auf meinen Test System ausprobieren und berichten.
                    Ich würde auch mich auch mal mit den Thema Adapter Programmierung auseinander setzen aber leider weiß ich noch nicht richtig wie es funktioniert.
                    Ich wünsche euch noch einen schönen Abend und bleibt gesund.
                      apollon77 last edited by apollon77
                      Hi All,
                      GitHub hat nach erstem Feedback jetzt die 3.0.4:
                      • (Apollon77) Add "lc" property to list of allowed properties to set (prevent false positive errors with hm-rpc adapter)
                      • (Apollon77) Add mock for adapter.states.getState to prevent crashed with Soef Adapters
                      • (Apollon77) Make sure extendObject is checking object parts differently, prevent false positive loggings
                      Ebenso ist bekannt das Pushover in Version 1.1.x noch tut, Wer Version 1.2.x drauf hat könnte Probleme bekommen und sollte bitte 1.2.4 vom GitHub versuchen ob die Probleme damit behoben werden.
                        Einstein67 last edited by
                        Hab gerade den neuen JS-Controller getestet (saubere Iobroker Installation, Update auf Admin-4.0.5 und JS-3.0.4 und danach Restore meiner bestehenden Installation).
                        Hat alles problemlos funktioniert und läuft alles wie vorher. Auch das löschen von Adaptern geht ohne Probleme aus der Admin-Oberfläche!
                        Das einzige das anders ist als vorher: Beim Restore wird nachdem ein Adapter/eine Instanz wiederhergestellt wurde, die Konfigurationsseite der Instanz geöffnet die geschlossen werden muss.
                        Sonst läuft alles bisher problemlos!!
                          apollon77 @Einstein67 last edited by
                          @Einstein67 sagte in Beta Test js-controller 3.0.x auf GitHub:
                          Du meinst wenn Admin dabei geöffnet ist? Ja das kann sein. Admin reagiert auf ein bestimmtes Objekt update und macht dann dinge. Da fehlte bisher ein Objekt Update ... Wenn es stört dann bitte mal Admin issue anlegen. Wenn ok dann lassen 🙂
                            e-s @apollon77 last edited by
                            @apollon77
                            Irgendwie hat mich das in der Art schon immer genervt. Habe meistens im Browser 4 tabs vom Admin offen(Objekte, Instanzen, logs, Javascript).
                            Wenn ich dann ein Adapter neu installiere, dann springen alle tabs in die Einstellungen der Instanz.
                            Wäre schön wenn entweder nur das aktive tab dahin springt oder keins davon. Mir ist ja bewußt das man da was einstellen muss.
                              apollon77 @e-s last edited by
                              @e-s Admin Issue bitte 🙂
                                Jan1 last edited by
                                So Update ist durch und läuft.
                                Alles was mit Warnungen im Log steht, hat @sigi234 ja schon auf Github ein Issues angelegt, zumindest mal bei allen Adaptern bei denen ich auch die Warnung hatte 😉
                                  apollon77 @Jan1 last edited by
                                  @Jan1 Danke Euch beiden dafür!! Und den anderen natürlich auch ... bitte hier nicht nachlassen mit GitHub Issues anlegen!
                                  • foxriver76
                                    @sigi234 interessant wäre ob firetv und wifilight mit 3.0.4 laufen. Ich tippe mal auf nein.
                                    J apollon77 sigi234 3 Replies Last reply Reply Quote 0
                                      Jan1 @foxriver76 last edited by
                                      @foxriver76
                                      Da wirst wohl schlechte Karten haben, aber den wifilight Adapter hatte ich auch und habe die damit verbundenen Geräte auf Tasmota geflasht. Die laufen jetzt schön im Sonoff Adapter und lassen sich wesentlich besser steuern als vorher.
                                      Den FireTV Adapter hatte ich bei mir eh noch nie zum Laufen bekommen, deshalb stört mich der weniger 🙂
                                        apollon77 @foxriver76 last edited by
                                        @foxriver76 sollten sie ... sie werden zwar denke ich einiges loggen an warnungen aber das war eine der 3.0.3 -> 30.0.4 änderungen
                                          Richtig getippt!
                                          apollon77 ? 2 Replies Last reply Reply Quote 0
                                            apollon77 @sigi234 last edited by
                                            @sigi234 Welcher Fehler kommt jetzt?
                                            js-controller
                                            39
                                            416
                                            68297
