    4. Beta Test js-controller 3.0.x auf GitHub
    • foxriver76
      foxriver76 Developer @Guest last edited by
      @ilovegym der ist leider noch 1 zu 1 der gleiche wie der von soef glaube ich
        A Former User @apollon77 last edited by A Former User
        @apollon77
        hier mal die Fehler vom wifilight (soef) mit Node12 ( ein npm install soef half nicht!)
        2020-04-09 10:21:04.113  - info: host.ioB-D10 iobroker host.ioB-D10 install adapter wifilight
        2020-04-09 10:21:04.238  - info: host.ioB-D10 iobroker upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
        2020-04-09 10:21:04.311  - info: host.ioB-D10 iobroker upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
        2020-04-09 10:21:04.379  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight created/updated
        2020-04-09 10:21:04.446  - info: host.ioB-D10 iobroker host.ioB-D10 create instance wifilight
        2020-04-09 10:21:04.455  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.sigKill created
        2020-04-09 10:21:04.492  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.eventLoopLag created
        2020-04-09 10:21:04.522  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.outputCount created
        2020-04-09 10:21:04.551  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.inputCount created
        2020-04-09 10:21:04.579  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.uptime created
        2020-04-09 10:21:04.608  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.memRss created
        2020-04-09 10:21:04.638  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.memHeapTotal created
        2020-04-09 10:21:04.667  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.memHeapUsed created
        2020-04-09 10:21:04.694  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.cputime created
        2020-04-09 10:21:04.724  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.cpu created
        2020-04-09 10:21:04.754  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.compactMode created
        2020-04-09 10:21:04.783  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.connected created
        2020-04-09 10:21:04.812  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0.alive created
        2020-04-09 10:21:04.846  - info: host.ioB-D10 iobroker host.ioB-D10 object system.adapter.wifilight.0 created
        2020-04-09 10:21:07.354  - info: host.ioB-D10 instance system.adapter.wifilight.0 started with pid 5687
        2020-04-09 10:21:08.241  - info: wifilight.0 (5687) starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v12.16.1, js-controller: 3.0.4
        2020-04-09 10:21:08.260  - warn: wifilight.0 (5687) adapter.states.getState is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        2020-04-09 10:21:08.282  - error: wifilight.0 (5687) uncaught exception: adapter.objects.getObject is not a function
        2020-04-09 10:21:08.282  - error: wifilight.0 (5687) TypeError: adapter.objects.getObject is not a function
            at savePrevVersion (/opt/iobroker/node_modules/iobroker.wifilight/node_modules/soef/soef.js:986:21)
            at /opt/iobroker/node_modules/iobroker.wifilight/node_modules/soef/soef.js:1018:17
        2020-04-09 10:21:08.293  - info: wifilight.0 (5687) terminating
        2020-04-09 10:21:08.293  - info: wifilight.0 (5687) Terminated (NO_ERROR): Without reason
        2020-04-09 10:21:08.811  - info: host.ioB-D10 instance system.adapter.wifilight.0 terminated with code 0 (NO_ERROR)
        2020-04-09 10:21:08.811  - info: host.ioB-D10 Restart adapter system.adapter.wifilight.0 because enabled
          A Former User @foxriver76 last edited by
          @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
          da haben schon n paar dran gefummelt, aber besser geworden ist es leider nicht.. 😞
          foxriver76 2 Replies Last reply Reply Quote 0
          • Jey Cee
            Hier noch einen Meldung, kam als ich den LGTV Adapter installiert und gestartet hab. Keine Ahnung ob das Zusammenh hängt.
            lgtv.0	2020-04-09 08:55:34.176	info	(16860) Ready. Configured WebOS TV IP: 192.168.0.241
            lgtv.0	2020-04-09 08:55:34.155	info	(16860) starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.lgtv, node: v10.18.1, js-controller: 3.0.4
            host.iobroker-testing	2020-04-09 08:55:33.475	info	instance system.adapter.lgtv.0 started with pid 16860
            host.iobroker-testing	2020-04-09 08:55:33.459	info	"system.adapter.lgtv.0" enabled
            readFile	2020-04-09 08:50:55.670	warn	will not read this file (socketio.png) in future versions: socketio.admin is not an object of type "meta"
            readFile	2020-04-09 08:50:55.669	warn	will not read this file (simple-api.png) in future versions: simple-api.admin is not an object of type "meta"
            host.iobroker-testing	2020-04-09 08:50:55.080	info	iobroker exit 0
            host.iobroker-testing	2020-04-09 08:50:54.074	info	iobroker host.iobroker-testing object system.adapter.lgtv.0 created
            host.iobroker-testing	2020-04-09 08:50:54.024	info	iobroker host.iobroker-testing Set default value of lgtv.0.info.connection: false
            host.iobroker-testing	2020-04-09 08:50:53.991	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.alive created
            host.iobroker-testing	2020-04-09 08:50:53.958	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.connected created
            host.iobroker-testing	2020-04-09 08:50:53.930	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.compactMode created
            host.iobroker-testing	2020-04-09 08:50:53.903	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.cpu created
            host.iobroker-testing	2020-04-09 08:50:53.874	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.cputime created
            host.iobroker-testing	2020-04-09 08:50:53.841	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.memHeapUsed created
            host.iobroker-testing	2020-04-09 08:50:53.808	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.memHeapTotal created
            host.iobroker-testing	2020-04-09 08:50:53.773	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.memRss created
            host.iobroker-testing	2020-04-09 08:50:53.741	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.uptime created
            host.iobroker-testing	2020-04-09 08:50:53.708	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.inputCount created
            host.iobroker-testing	2020-04-09 08:50:53.673	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.outputCount created
            host.iobroker-testing	2020-04-09 08:50:53.639	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.eventLoopLag created
            host.iobroker-testing	2020-04-09 08:50:53.606	info	iobroker host.iobroker-testing object system.adapter.lgtv.0.sigKill created
            host.iobroker-testing	2020-04-09 08:50:53.571	info	iobroker host.iobroker-testing object lgtv.0.info.connection created
            host.iobroker-testing	2020-04-09 08:50:53.540	info	iobroker host.iobroker-testing object lgtv.0.states created
            host.iobroker-testing	2020-04-09 08:50:53.509	info	iobroker host.iobroker-testing object lgtv.0.states.on created
            host.iobroker-testing	2020-04-09 08:50:53.481	info	iobroker host.iobroker-testing object lgtv.0.states.popup created
            host.iobroker-testing	2020-04-09 08:50:53.448	info	iobroker host.iobroker-testing object lgtv.0.states.turnOff created
            host.iobroker-testing	2020-04-09 08:50:53.417	info	iobroker host.iobroker-testing object lgtv.0.states.power created
            host.iobroker-testing	2020-04-09 08:50:53.387	info	iobroker host.iobroker-testing object lgtv.0.states.mute created
            host.iobroker-testing	2020-04-09 08:50:53.356	info	iobroker host.iobroker-testing object lgtv.0.states.volumeUp created
            host.iobroker-testing	2020-04-09 08:50:53.326	info	iobroker host.iobroker-testing object lgtv.0.states.volumeDown created
            host.iobroker-testing	2020-04-09 08:50:53.295	info	iobroker host.iobroker-testing object lgtv.0.states.3Dmode created
            host.iobroker-testing	2020-04-09 08:50:53.264	info	iobroker host.iobroker-testing object lgtv.0.states.channel created
            host.iobroker-testing	2020-04-09 08:50:53.233	info	iobroker host.iobroker-testing object lgtv.0.states.channelId created
            host.iobroker-testing	2020-04-09 08:50:53.203	info	iobroker host.iobroker-testing object lgtv.0.states.channelUp created
            host.iobroker-testing	2020-04-09 08:50:53.173	info	iobroker host.iobroker-testing object lgtv.0.states.channelDown created
            host.iobroker-testing	2020-04-09 08:50:53.141	info	iobroker host.iobroker-testing object lgtv.0.states.mediaPlay created
            host.iobroker-testing	2020-04-09 08:50:53.110	info	iobroker host.iobroker-testing object lgtv.0.states.mediaPause created
            host.iobroker-testing	2020-04-09 08:50:53.080	info	iobroker host.iobroker-testing object lgtv.0.states.mediaStop created
            host.iobroker-testing	2020-04-09 08:50:53.048	info	iobroker host.iobroker-testing object lgtv.0.states.mediaFastForward created
            host.iobroker-testing	2020-04-09 08:50:53.016	info	iobroker host.iobroker-testing object lgtv.0.states.mediaRewind created
            host.iobroker-testing	2020-04-09 08:50:52.984	info	iobroker host.iobroker-testing object lgtv.0.states.volume created
            host.iobroker-testing	2020-04-09 08:50:52.954	info	iobroker host.iobroker-testing object lgtv.0.states.input created
            host.iobroker-testing	2020-04-09 08:50:52.923	info	iobroker host.iobroker-testing object lgtv.0.states.currentApp created
            host.iobroker-testing	2020-04-09 08:50:52.889	info	iobroker host.iobroker-testing object lgtv.0.states.launch created
            host.iobroker-testing	2020-04-09 08:50:52.858	info	iobroker host.iobroker-testing object lgtv.0.states.openURL created
            host.iobroker-testing	2020-04-09 08:50:52.827	info	iobroker host.iobroker-testing object lgtv.0.states.youtube created
            host.iobroker-testing	2020-04-09 08:50:52.796	info	iobroker host.iobroker-testing object lgtv.0.states.drag created
            host.iobroker-testing	2020-04-09 08:50:52.767	info	iobroker host.iobroker-testing object lgtv.0.states.scroll created
            host.iobroker-testing	2020-04-09 08:50:52.726	info	iobroker host.iobroker-testing object lgtv.0.states.click created
            host.iobroker-testing	2020-04-09 08:50:52.695	info	iobroker host.iobroker-testing object lgtv.0.states.soundOutput created
            host.iobroker-testing	2020-04-09 08:50:52.665	info	iobroker host.iobroker-testing object lgtv.0.states.raw created
            host.iobroker-testing	2020-04-09 08:50:52.633	info	iobroker host.iobroker-testing object lgtv.0.remote.power created
            host.iobroker-testing	2020-04-09 08:50:52.603	info	iobroker host.iobroker-testing object lgtv.0.remote.red created
            host.iobroker-testing	2020-04-09 08:50:52.572	info	iobroker host.iobroker-testing object lgtv.0.remote.green created
            host.iobroker-testing	2020-04-09 08:50:52.542	info	iobroker host.iobroker-testing object lgtv.0.remote.yellow created
            host.iobroker-testing	2020-04-09 08:50:52.513	info	iobroker host.iobroker-testing object lgtv.0.remote.blue created
            host.iobroker-testing	2020-04-09 08:50:52.481	info	iobroker host.iobroker-testing object lgtv.0.remote.home created
            host.iobroker-testing	2020-04-09 08:50:52.450	info	iobroker host.iobroker-testing object lgtv.0.remote.menu created
            host.iobroker-testing	2020-04-09 08:50:52.419	info	iobroker host.iobroker-testing object lgtv.0.remote.cc created
            host.iobroker-testing	2020-04-09 08:50:52.387	info	iobroker host.iobroker-testing object lgtv.0.remote.back created
            host.iobroker-testing	2020-04-09 08:50:52.357	info	iobroker host.iobroker-testing object lgtv.0.remote.up created
            host.iobroker-testing	2020-04-09 08:50:52.326	info	iobroker host.iobroker-testing object lgtv.0.remote.down created
            host.iobroker-testing	2020-04-09 08:50:52.296	info	iobroker host.iobroker-testing object lgtv.0.remote.left created
            host.iobroker-testing	2020-04-09 08:50:52.266	info	iobroker host.iobroker-testing object lgtv.0.remote.right created
            host.iobroker-testing	2020-04-09 08:50:52.240	info	iobroker host.iobroker-testing object lgtv.0.remote.enter created
            host.iobroker-testing	2020-04-09 08:50:52.213	info	iobroker host.iobroker-testing object lgtv.0.remote.dash created
            host.iobroker-testing	2020-04-09 08:50:52.185	info	iobroker host.iobroker-testing object lgtv.0.remote.exit created
            host.iobroker-testing	2020-04-09 08:50:52.159	info	iobroker host.iobroker-testing object lgtv.0.remote.0 created
            host.iobroker-testing	2020-04-09 08:50:52.125	info	iobroker host.iobroker-testing object lgtv.0.remote.1 created
            host.iobroker-testing	2020-04-09 08:50:52.091	info	iobroker host.iobroker-testing object lgtv.0.remote.2 created
            host.iobroker-testing	2020-04-09 08:50:52.059	info	iobroker host.iobroker-testing object lgtv.0.remote.3 created
            host.iobroker-testing	2020-04-09 08:50:52.026	info	iobroker host.iobroker-testing object lgtv.0.remote.4 created
            host.iobroker-testing	2020-04-09 08:50:51.994	info	iobroker host.iobroker-testing object lgtv.0.remote.5 created
            host.iobroker-testing	2020-04-09 08:50:51.966	info	iobroker host.iobroker-testing object lgtv.0.remote.6 created
            host.iobroker-testing	2020-04-09 08:50:51.938	info	iobroker host.iobroker-testing object lgtv.0.remote.7 created
            host.iobroker-testing	2020-04-09 08:50:51.911	info	iobroker host.iobroker-testing object lgtv.0.remote.8 created
            host.iobroker-testing	2020-04-09 08:50:51.885	info	iobroker host.iobroker-testing object lgtv.0.remote.9 created
            host.iobroker-testing	2020-04-09 08:50:51.857	info	iobroker host.iobroker-testing object lgtv.0.states.mac created
            host.iobroker-testing	2020-04-09 08:50:51.830	info	iobroker host.iobroker-testing object lgtv.0.states.model created
            host.iobroker-testing	2020-04-09 08:50:51.821	info	iobroker host.iobroker-testing create instance lgtv
            host.iobroker-testing	2020-04-09 08:50:50.963	info	iobroker add lgtv --host iobroker-testing
            readFile	2020-04-09 08:50:45.536	warn	will not read this file (socketio.png) in future versions: socketio.admin is not an object of type "meta"
            readFile	2020-04-09 08:50:45.535	warn	will not read this file (simple-api.png) in future versions: simple-api.admin is not an object of type "meta"
              Kueppert last edited by
              Hallo Gemeinde,
              ich war mutig (?) und hab das Update mal in meine Prod eingespielt. Testsystem hin oder her, testing in Prod ist immer noch am Aussagekräftigsten 😄 (hab vorher nen Backup meiner VM gemacht 😉 )
              Update lief gut durch...kam auch nen Hinweis auf ne aktuelle NPM - die hab ich direkt mitgemacht. Zugriffsprobleme hab ich nie, da ich mit Root unterwegs bin (jaja, ich weiß, aber ich arbeite damit am liebsten - und Server ist nur im Heimnetz erreichbar).
              Sieht bisher alles gut und sauber aus. Alle meine genutzten Adapter sind grün. Nun werde ich mal das node-Update ausprobieren - ohne ein Rebuild und die Funktion des neuen Controllers testen 🙂
              Bis gleich, Thorsten
              • foxriver76
                @ilovegym Ich probiere mal ne 1.1.0 zu bauen für wifilight
                  apollon77 @Jey Cee last edited by
                  @Jey-Cee sagte in Beta Test js-controller 3.0.x auf GitHub:
                  Der ist interessant. Da scheinen die beiden adapter nicht sauber installiert zu sein.
                  Kannst Du bitte mal "iobroker upload socketio" und "iobroker upload simple-api" versuchen und schauen ob der Fehler nochmal kommt wenn Du Admin öffnest ? (bitte vorher schauen das ein admin öffnen den auslöst - wäre meine Annahme). Danke!
                  Jey Cee 2 Replies Last reply Reply Quote 0
                    apollon77 @Kueppert last edited by
                    @Kueppert sagte in Beta Test js-controller 3.0.x auf GitHub:
                    hhhuuuiiii 🙂 gespaaaannt
                      Kueppert @apollon77 last edited by
                      @apollon77 gugug, welche Version soll ich den mal druffkloppen? 🙂 nur die 12 oder direkt die 14?
                      Hab in unserer Doku auf Iobroker.net den link zum Befehl für Linux gefunden - da steht nur die Befehlszeile für 12 (root-User):
                      curl -sL https://deb.nodesource.com/setup_12.x | bash -
                      apt-get install -y nodejs
                      Bitte kurze Vorgabe machen 🙂 Zurück komme ich via Backup immer noch, wenns in die Hose geht ^^
                      VG Thorsten
                        Jan1 @Kueppert last edited by
                        @Kueppert
                        Die 14er, 12 wäre ja langweilig 😉
                          Version 14 war leider nix:
                          Ich mach dann mal die 12er drauf.
                            Kueppert last edited by Kueppert
                            Sooo,
                            node 12 ist nun drauf:
                            ioBroker hab ich jetzt einfach mal direkt gestartet. Worauf muss ich jetzt im LOG wegen Rebuild achten?
                            EDIT: Ah auf Fehler ^^ :
                            host.ioBroker2	2020-04-09 11:39:53.468	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                            host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: ^
                            host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                            host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
                            EDIT2: SQL- sowie mein Zigbee-Adapter bleiben rot
                            Errors nach Restart SQL-Adapter:
                            host.ioBroker2	2020-04-09 11:43:49.928	info	Restart adapter system.adapter.sql.0 because enabled
                            host.ioBroker2	2020-04-09 11:43:49.928	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                            host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                            host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: ^
                            host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                            host.ioBroker2	2020-04-09 11:43:49.925	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
                            host.ioBroker2	2020-04-09 11:43:49.450	info	instance system.adapter.sql.0 started with pid 25250
                            host.ioBroker2	2020-04-09 11:43:49.246	info	Restart adapter system.adapter.zigbee.0 because enabled
                            host.ioBroker2	2020-04-09 11:43:49.246	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                            host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                            host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: ^
                            host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: throw e;
                            host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                            host.ioBroker2	2020-04-09 11:43:48.971	info	instance system.adapter.zigbee.0 started with pid 25243
                            Errors nach Zigbee-Restart:
                            host.ioBroker2	2020-04-09 11:44:59.454	info	Restart adapter system.adapter.zigbee.0 because enabled
                            host.ioBroker2	2020-04-09 11:44:59.454	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                            host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                            host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                            host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                            host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                            host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: ^
                            host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: throw e;
                            host.ioBroker2	2020-04-09 11:44:59.451	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                            host.ioBroker2	2020-04-09 11:44:59.161	info	instance system.adapter.zigbee.0 started with pid 26632
                            Danke und vG, Thorsten
                            J apollon77 2 Replies Last reply Reply Quote 0
                              Jan1 @Kueppert last edited by Jan1
                              @Kueppert
                              Da hat wohl das automatische re-compiling nicht hin gehauen. Der Zigbee läuft bei mir mit Node 12 und JS-Controller 3.0.4 jedenfalls ohne Probleme. Hatte aber auch vorher schon Node 12 drauf.
                                Kueppert @Jan1 last edited by
                                @Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                @Kueppert
                                Jo...wollte nur wissen, ob ich nmoch etwas testen soll ... aber dann mache ich das Rebuild nun manuell hinterher...ich melde mich ^^
                                  @Kueppert
                                  Warte doch mal was @apollon77 dazu sagt, da es ja ne neue Funktion des Controller ist, die bei Dir wohl nicht so ganz geklappt hat.
                                    Kueppert @Jan1 last edited by Kueppert
                                    @Kueppert
                                    to late ^^ ist schon am rebuilden...ich kann das ganze ja auch nochmal machen und testen wenn gewünscht
                                    Fehler beim Rebuild:
                                    ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
                                       void init(v8::Handle<v8::Object> target) {
                                    ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
                                    ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
                                    ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
                                    ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
        tzset
                                    In file included from ../../nan/nan.h:54,
                                                     from ../src/./serialport.h:6,
                                                     from ../src/serialport.cpp:1:
                                    ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
                                     NODE_MODULE(serialport, init);
                                    /root/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                                           (node::addon_register_func) (regfunc),                          \
                                    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
                                    ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
                                    make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
                                    make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird verlassen
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2
                                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                    gyp ERR! System Linux 4.19.0-5-amd64
                                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /opt/iobroker/node_modules/serialport
                                    gyp ERR! node -v v12.16.2
                                    gyp ERR! node-gyp -v v5.1.0
                                    gyp ERR! not ok
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! errno 1
                                    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the serialport@6.2.2 install script.
                                    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                    npm ERR!     /root/.npm/_logs/2020-04-09T10_30_03_438Z-debug.log
                                    Hm...SQL sowie Zigbee sind im Admin auf grün. Mit dem Zigbee-Adapter lassen sich meine Lampen auch noch schalten...kann aber gern wenn gewünscht weiter testen 🙂
                                    • Jey Cee
                                      Jey Cee Developer @apollon77 last edited by
                                      @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                      Würde das nicht vorraussetzen das die Adapter installiert sind?
                                      • Jey Cee
                                        Die Annahme scheint richtig zu sein. Nach upload ist die Meldung weg.
                                        • foxriver76
                                          foxriver76 Developer @Guest last edited by foxriver76
                                          @ilovegym Also folgendes, der wifilight Adapter wird jetzt über Community-Adapters gepflegt, heißt aber nun wieder wifilight ohne den community Zusatz. Gerne von Github installieren über https://github.com/iobroker-community-adapters/ioBroker.wifilight. Wenn das passt kann man die anderen Adapter auch so fixen - zumindest js-c 3 kompatibel machen.
                                          Test Thread: https://forum.iobroker.net/topic/32062/wifilight-1-1-0-testing
                                          • foxriver76
                                            foxriver76 Developer last edited by foxriver76
                                            @sigi234 selbiges gilt für firetv https://github.com/iobroker-community-adapters/ioBroker.firetv, wobei ich da sagen muss, wenn ich die ersten 5 Zeilen sehe, wundert es mich, dass das Ding überhaupt läuft.. 😉
                                            Test Thread: https://forum.iobroker.net/topic/32063/firetv-1-0-0-testen
                                            In beiden Fällen nach GitHub Install bitte unbedingt Upload ausführen. iob u firetv oder eben für wifilight
                                            js-controller
                                            39
                                            416
                                            68362
