    4. Beta Test js-controller 3.0.x auf GitHub
      Kueppert last edited by
      Version 14 war leider nix:
      Ich mach dann mal die 12er drauf.
        Kueppert last edited by Kueppert
        Sooo,
        node 12 ist nun drauf:
        ioBroker hab ich jetzt einfach mal direkt gestartet. Worauf muss ich jetzt im LOG wegen Rebuild achten?
        EDIT: Ah auf Fehler ^^ :
        host.ioBroker2	2020-04-09 11:39:53.468	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBroker2	2020-04-09 11:39:53.467	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.ioBroker2	2020-04-09 11:39:53.466	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
        host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: ^
        host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        host.ioBroker2	2020-04-09 11:39:53.465	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
        EDIT2: SQL- sowie mein Zigbee-Adapter bleiben rot
        Errors nach Restart SQL-Adapter:
        host.ioBroker2	2020-04-09 11:43:49.928	info	Restart adapter system.adapter.sql.0 because enabled
        host.ioBroker2	2020-04-09 11:43:49.928	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.ioBroker2	2020-04-09 11:43:49.928	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker2	2020-04-09 11:43:49.927	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
        host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: ^
        host.ioBroker2	2020-04-09 11:43:49.926	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        host.ioBroker2	2020-04-09 11:43:49.925	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
        host.ioBroker2	2020-04-09 11:43:49.450	info	instance system.adapter.sql.0 started with pid 25250
        host.ioBroker2	2020-04-09 11:43:49.246	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.ioBroker2	2020-04-09 11:43:49.246	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.ioBroker2	2020-04-09 11:43:49.246	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:43:49.245	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
        host.ioBroker2	2020-04-09 11:43:49.244	error	Caught by controller[0]: ^
        host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: throw e;
        host.ioBroker2	2020-04-09 11:43:49.243	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
        host.ioBroker2	2020-04-09 11:43:48.971	info	instance system.adapter.zigbee.0 started with pid 25243
        Errors nach Zigbee-Restart:
        host.ioBroker2	2020-04-09 11:44:59.454	info	Restart adapter system.adapter.zigbee.0 because enabled
        host.ioBroker2	2020-04-09 11:44:59.454	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
        host.ioBroker2	2020-04-09 11:44:59.454	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker2	2020-04-09 11:44:59.453	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
        host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: ^
        host.ioBroker2	2020-04-09 11:44:59.452	error	Caught by controller[0]: throw e;
        host.ioBroker2	2020-04-09 11:44:59.451	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
        host.ioBroker2	2020-04-09 11:44:59.161	info	instance system.adapter.zigbee.0 started with pid 26632
        Danke und vG, Thorsten
        J apollon77 2 Replies Last reply Reply Quote 0
          Jan1 @Kueppert last edited by Jan1
          @Kueppert
          Da hat wohl das automatische re-compiling nicht hin gehauen. Der Zigbee läuft bei mir mit Node 12 und JS-Controller 3.0.4 jedenfalls ohne Probleme. Hatte aber auch vorher schon Node 12 drauf.
            Kueppert @Jan1 last edited by
            @Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
            @Kueppert
            Jo...wollte nur wissen, ob ich nmoch etwas testen soll ... aber dann mache ich das Rebuild nun manuell hinterher...ich melde mich ^^
              @Kueppert
              Warte doch mal was @apollon77 dazu sagt, da es ja ne neue Funktion des Controller ist, die bei Dir wohl nicht so ganz geklappt hat.
                Kueppert @Jan1 last edited by Kueppert
                @Kueppert
                to late ^^ ist schon am rebuilden...ich kann das ganze ja auch nochmal machen und testen wenn gewünscht
                Fehler beim Rebuild:
                ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
                   void init(v8::Handle<v8::Object> target) {
                ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
                ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
                ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
                ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                                    tzset
                In file included from ../../nan/nan.h:54,
                                 from ../src/./serialport.h:6,
                                 from ../src/serialport.cpp:1:
                ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
                 NODE_MODULE(serialport, init);
                /root/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                       (node::addon_register_func) (regfunc),                          \
                ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
                ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
                make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
                make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird verlassen
                gyp ERR! build error
                gyp ERR! stack Error: `make` failed with exit code: 2
                gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                gyp ERR! System Linux 4.19.0-5-amd64
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! cwd /opt/iobroker/node_modules/serialport
                gyp ERR! node -v v12.16.2
                gyp ERR! node-gyp -v v5.1.0
                gyp ERR! not ok
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the serialport@6.2.2 install script.
                npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                npm ERR!     /root/.npm/_logs/2020-04-09T10_30_03_438Z-debug.log
                Hm...SQL sowie Zigbee sind im Admin auf grün. Mit dem Zigbee-Adapter lassen sich meine Lampen auch noch schalten...kann aber gern wenn gewünscht weiter testen 🙂
                • Jey Cee
                  Jey Cee Developer @apollon77 last edited by
                  @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                  Kannst Du bitte mal "iobroker upload socketio" und "iobroker upload simple-api" versuchen
                  Würde das nicht vorraussetzen das die Adapter installiert sind?
                  • Jey Cee
                    (bitte vorher schauen das ein admin öffnen den auslöst - wäre meine Annahme). Danke!
                    Die Annahme scheint richtig zu sein. Nach upload ist die Meldung weg.
                    • foxriver76
                      foxriver76 Developer @Neuschwansteini last edited by foxriver76
                      @ilovegym Also folgendes, der wifilight Adapter wird jetzt über Community-Adapters gepflegt, heißt aber nun wieder wifilight ohne den community Zusatz. Gerne von Github installieren über https://github.com/iobroker-community-adapters/ioBroker.wifilight. Wenn das passt kann man die anderen Adapter auch so fixen - zumindest js-c 3 kompatibel machen.
                      Test Thread: https://forum.iobroker.net/topic/32062/wifilight-1-1-0-testing
                      • foxriver76
                        foxriver76 Developer last edited by foxriver76
                        @sigi234 selbiges gilt für firetv https://github.com/iobroker-community-adapters/ioBroker.firetv, wobei ich da sagen muss, wenn ich die ersten 5 Zeilen sehe, wundert es mich, dass das Ding überhaupt läuft.. 😉
                        Test Thread: https://forum.iobroker.net/topic/32063/firetv-1-0-0-testen
                        In beiden Fällen nach GitHub Install bitte unbedingt Upload ausführen. iob u firetv oder eben für wifilight
                        • harrym
                          harrym last edited by
                          just4info: bekomm jetzt diese Warnings nach dem Upgrade ....
                          • foxriver76
                            foxriver76 Developer @harrym last edited by
                            @harrym das passt, muss in den Adaptern gefixt werden, bzw ist es glaube in den neusten Versionen.
                              apollon77 @Kueppert last edited by apollon77
                              @Kueppert Für die nodejs 14 bist Du ca 12 Tage zu früh oder so (as I know)
                                @Kueppert Und du bist ganz sicher das die 3.0.4 drauf ist. ich hab gestern getestet und lieff super mit sql. Ich vermisse im Log das er sagt "hey rebuild erkannt" und sowas
                                Mein log war so:
                                2020-04-08 17:37:32.555  - ESC[32minfoESC[39m: host.io-test instance system.adapter.sql.0 started with pid 32387
                                2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: internal/modules/cjs/loader.js:1197
                                2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:                  ^
                                2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: was compiled against a different Node.js version using
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 79. Please try re-compiling or re-installing
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1197:18)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1036:19)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                                2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1147:30)
                                2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
                                2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                                2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                                2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2020-04-08 17:37:33.003  - ESC[32minfoESC[39m: host.io-test Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
                                2020-04-08 17:37:33.004  - ESC[34mdebugESC[39m: Incoming Host message rebuildAdapter
                                2020-04-08 17:37:33.004  - ESC[32minfoESC[39m: host.io-test system.adapter.sql.0 will be rebuilt
                                2020-04-08 17:37:33.005  - ESC[33mwarnESC[39m: host.io-test adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2020-04-08 17:37:33.005  - ESC[32minfoESC[39m: host.io-test iobroker rebuild sql
                                2020-04-08 17:37:33.154  - ESC[32minfoESC[39m: host.io-test iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.sql"
                                Das sehe ich bei dir nicht. Und er sucht nach "NODE_MODULE_VERSION" was bei dir drin ist. Oder Log zu früh beim kopieren abgeschnitten? schau mal bitte rein
                                  @Kueppert Hast Du jetzt manuell rebuilded?
                                    apollon77 @Jey Cee last edited by
                                    @Jey-Cee Es gab mal frrüüüüher js.controller Versionen die beim adapter löschen ggff Objekte zurückgelassen haben. Die versucht Admin jetzt zu lesen und da meckern dann Dinge 😞
                                    • Jey Cee
                                      @apollon77 Hm das war aber eine Nackte test Installation lediglich mit einer älteren js-controller Version die ich geupdatet habe und dann die Adapter installiert.
                                        @Jey-Cee schau mal. Du hast bestimmt system.adapter.xy Objekte rumliegende von Objekt Typ Adapter. Korrekt? Wo die her sind wäre dann die interessante Frage.
                                        • Jey Cee
                                          Korrekt?
                                          Nein, hab sogar extra nochmal die VM mit dem Testsystem gestartet um ganz sicher zu sein.
                                            Kueppert @apollon77 last edited by
                                            @apollon77 jo, hab manuell nen Rebuild gemacht und nur die eine Fehlermeldung gehabt wegen Serialdings...hat aber nix mit dem neuen JS zu tun. Rebuild hat der nicht gemacht...hab ca. 1h gewartet - kamen immer nur die hier gemeldeten Fehlermeldungen...
                                            31.7k
                                            79.9k
                                            js-controller
                                            39
                                            416
                                            54309
