    4. Zigbee Adapter Failed to start
    UNSOLVED Zigbee Adapter Failed to start
      @skylike sagte in Zigbee Adapter Failed to start:
      instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      • hg6806
        hg6806 Most Active last edited by
        ich hänge mich mal hier dran, denn mein Zigbee läuft an einem USB-Hub auch nur ganz selten.
        Hier das Debug-Log.
        Vielleicht kann ja jemand ein paar Tipps geben.
        zigbee.0	2020-04-07 20:32:06.553	error	(8457) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
        zigbee.0	2020-04-07 20:32:06.552	error	(8457) Failed to start Zigbee
        zigbee.0	2020-04-07 20:32:06.360	debug	(8457) Starting zigbee-herdsman...
        zigbee.0	2020-04-07 20:32:06.360	info	(8457) Starting Zigbee...
        zigbee.0	2020-04-07 20:32:06.359	info	(8457) Try to reconnect. 1 attempts left
        zigbee.0	2020-04-07 20:31:56.356	error	(8457) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
        zigbee.0	2020-04-07 20:31:56.355	error	(8457) Failed to start Zigbee
        zigbee.0	2020-04-07 20:31:49.037	debug	(8457) Starting zigbee-herdsman...
        zigbee.0	2020-04-07 20:31:49.036	info	(8457) Starting Zigbee...
        zigbee.0	2020-04-07 20:31:48.999	info	(8457) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
        zigbee.0	2020-04-07 20:31:42.743	info	(7714) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        zigbee.0	2020-04-07 20:31:42.741	info	(7714) terminating
        zigbee.0	2020-04-07 20:31:42.740	error	at process._tickCallback (internal/process/next_tick.js:68:7))
        zigbee.0	2020-04-07 20:31:42.740	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
        zigbee.0	2020-04-07 20:31:42.740	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
        zigbee.0	2020-04-07 20:31:42.740	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
        zigbee.0	2020-04-07 20:31:42.740	error	at new Promise (<anonymous>)
        zigbee.0	2020-04-07 20:31:42.740	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
        zigbee.0	2020-04-07 20:31:42.740	error	at Generator.next (<anonymous>)
        zigbee.0	2020-04-07 20:31:42.740	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
        zigbee.0	2020-04-07 20:31:42.740	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
        zigbee.0	2020-04-07 20:31:42.740	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
        zigbee.0	2020-04-07 20:31:42.740	error	(7714) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
        zigbee.0	2020-04-07 20:31:42.730	info	(7714) Zigbee: disabling joining new devices.
        zigbee.0	2020-04-07 20:31:42.724	info	(7714) cleaned everything up...
        zigbee.0	2020-04-07 20:31:42.721	info	(7714) Got terminate signal TERMINATE_YOURSELF
          arteck Developer Most Active @hg6806 last edited by
          @hg6806 sagte in Zigbee Adapter Failed to start:
          • hg6806
            OK, was heißt das? Er kann den Stick nicht finden?
              @hg6806 der seriall port ist besetzt.. starte mal die kiste neu .. was läuft da sonst noch druff?
              • hg6806
                hg6806 Most Active @arteck last edited by
                @arteck
                COM Ports? Ich kenne das unter Windows, diese sind oft blockiert, kann man aber irgdndwie "freischaufeln".
                Habe den Pi4 mal neu gestartet, wirft aber den gleichen Fehler aus.
                An dem Pi hängen 2 IR-Smartmeter, eine USB3-SSD und ein 4-fach-USB-Hub woran dann ein BLE5.0 Stick und der CC2531 Zigbee Stick dran ist.
                arteck 1 Reply Last reply Reply Quote 1
                  arteck Developer Most Active @hg6806 last edited by arteck
                  BLE5.0 Stick
                  der blockiert den
                  aber zeigmal
                  ls -l /dev/serial/by-id
                  • hg6806
                    Here it is:
                    root@raspberrypi:~# ls -l /dev/serial/by-id
                    insgesamt 0
                    lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
                    lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
                    lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Texas_Instruments_TI_CC2531_USB_CDC__            _0X00124B00194AD7E3-if00 -> ../../ttyACM0
                    root@raspberrypi:~#
                      @hg6806 wo ist der BLE??
                      • hg6806
                        Das frage ich mich auch. Zumindest ist der BLE Adapter grün und zwei BLE Sensoren liefern aktuelle Daten.
                        • hg6806
                          Bin leider noch nicht weitergekommen.
                          Folgendes habe ich probiert:
                          root@raspberrypi:~# hciconfig
                          hci1:   Type: Primary  Bus: UART
                                  BD Address: DC:A6:32:0A:73:B3  ACL MTU: 1021:8  SCO MTU: 64:1
                                  UP RUNNING
                                  RX bytes:8525625 acl:0 sco:0 events:234932 errors:0
                                  TX bytes:1374 acl:0 sco:0 commands:59 errors:0
                          hci0:   Type: Primary  Bus: USB
                                  BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
                                  DOWN
                                  RX bytes:1148 acl:0 sco:0 events:60 errors:0
                                  TX bytes:736 acl:0 sco:0 commands:60 errors:0
                          root@raspberrypi:~# lsusb
                          Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s bridge
                          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                          Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                          Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                          Bus 001 Device 007: ID 0451:16a8 Texas Instruments, Inc.
                          Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
                          Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
                          Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                          root@raspberrypi:~# bluetoothctl
                          Agent registered
                          [bluetooth]# scan on
                          Discovery started
                          [CHG] Controller DC:A6:32:0A:73:B3 Discovering: yes
                          [NEW] Device E7:2E:00:D3:20:42 LYWSD02
                          Dann den BLE Stick entfernt, BLE Adapter gestoppt und den Pi neu gestartet.
                          Zigbee bleibt gelb, Debug-Log:
                          zigbee.0	2020-04-12 10:12:53.178	error	(2063) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
                          zigbee.0	2020-04-12 10:12:53.176	error	(2063) Failed to start Zigbee
                          zigbee.0	2020-04-12 10:12:52.979	debug	(2063) Starting zigbee-herdsman...
                          zigbee.0	2020-04-12 10:12:52.979	info	(2063) Starting Zigbee...
                          zigbee.0	2020-04-12 10:12:52.978	info	(2063) Try to reconnect. 1 attempts left
                          zigbee.0	2020-04-12 10:12:42.977	error	(2063) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
                          zigbee.0	2020-04-12 10:12:42.974	error	(2063) Failed to start Zigbee
                          zigbee.0	2020-04-12 10:12:35.663	debug	(2063) Starting zigbee-herdsman...
                          zigbee.0	2020-04-12 10:12:35.661	info	(2063) Starting Zigbee...
                          zigbee.0	2020-04-12 10:12:35.627	info	(2063) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
                          zigbee.0	2020-04-12 10:12:13.440	info	(1823) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          zigbee.0	2020-04-12 10:12:13.439	info	(1823) terminating
                          zigbee.0	2020-04-12 10:12:13.438	error	at process._tickCallback (internal/process/next_tick.js:68:7))
                          zigbee.0	2020-04-12 10:12:13.438	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
                          zigbee.0	2020-04-12 10:12:13.438	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
                          zigbee.0	2020-04-12 10:12:13.438	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                          zigbee.0	2020-04-12 10:12:13.438	error	at new Promise (<anonymous>)
                          zigbee.0	2020-04-12 10:12:13.438	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                          zigbee.0	2020-04-12 10:12:13.438	error	at Generator.next (<anonymous>)
                          zigbee.0	2020-04-12 10:12:13.438	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
                          zigbee.0	2020-04-12 10:12:13.438	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                          zigbee.0	2020-04-12 10:12:13.438	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                          zigbee.0	2020-04-12 10:12:13.438	error	(1823) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                          zigbee.0	2020-04-12 10:12:13.434	info	(1823) Zigbee: disabling joining new devices.
                          zigbee.0	2020-04-12 10:12:13.417	info	(1823) cleaned everything up...
                          zigbee.0	2020-04-12 10:12:13.415	info	(1823) Got terminate signal TERMINATE_YOURSELF
                          Hier noch weitere Konsolenbefehle:
                          insgesamt 0
                          lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
                          lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
                          lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194AD7E3-if00 -> ../../ttyACM0
                          Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc.
                          root@raspberrypi:~#
                          Was kann ich noch tun?
                          • mickym
                            mickym Most Active last edited by mickym
                            Ich glaube - dass wir das gleiche Problem haben: https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled
                            Allerdings passiert es nicht immer, wenn auch mit der neuen Version gefühlt häufiger.
                            Bei mir läuft der Adapter jedoch IMMER, wenn ich den Stick im laufenden Betrieb einfach abziehe, dann wieder anstecke und NUR den Adapter neu starte.
                              toki1973 last edited by
                              @mickym Danke für deine Rückmeldung im anderen Thread. Inzwischen ist der Status wieder grün. Allerdings bekomme ich keine Werte mehr von den Sensoren.
                              • mickym
                                mickym Most Active @toki1973 last edited by mickym
                                @toki1973 Hmm - bei mir funktionieren die Sensoren, es ist alles Bestens. Ist denn bei Dir der Adapter alleine auf grün gegangen oder hast Du wie ich mal den Stick abgezogen und wieder angesteckt und dann den Adapter neu gestartet?
                                • hg6806
                                  @mickym So läuft es! Danke!
                                  Also immer erst Stick neu anstecken und Adapter neu starten. Dann wird es grün.
                                  Auch zusammen mit dem BLE.
                                  Wenn man aber den Pi neu startet bleibt Zigbee gelb.
                                  Ich habe das mit BLE mal ausprobiert, der BRAUCHT unbedingt ein Pi Neustart.
                                  Die Frage ist wie kann man das fixen?
                                  Kann man den Zigbee Stick oder den ganzen USB Bus resetten?
                                  • hg6806
                                    hg6806 Most Active last edited by hg6806
                                    Hier gibt es wohl die Möglichkeit:
                                    Eine Datei usbreset erstellen und dann aufrufen
                                    Link Text
                                    Hab's noch nicht ausprobiert und hoffe es heute Abend mal zu schaffen.
                                    • mickym
                                      mickym Most Active @hg6806 last edited by mickym
                                      @hg6806 said in Zigbee Adapter Failed to start:
                                      Meines Erachtens wird der Zigbee-Stick ja beim Adapterstart resettet und das ist aber das Problem. Wenn ich die Maschine neu boote wird der Stick resettet und die LED leuchtet. Startet der Adapter geht die LED auf dem Stick aus und dann scheint es bei mir Glücksache zu sein, ob der Adapter den wieder findet oder einen Time-Out bekommt. Jedenfalls geht die LED im Fehlerfall nicht mehr an, bis ich den Adapter physisch neu verbinde.
                                      • hg6806
                                        Ja, so ist es wohl.
                                        Habe mal usbreset nach der Anleitung erstellt und ausgeführt.
                                        Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s brid        ge
                                        Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (        HCI mode)
                                        root@raspberrypi:~# usbreset /dev/bus/usb/001/007
                                        Resetting USB device /dev/bus/usb/001/007
                                        Reset successful
                                        Stick wurde resettet aber zeigt nach Adapter-Neustart doch noch immer gelb an.
                                          Nach entfernen des USB Sticks und Neustart der VM auf dem NUC habe ich zumindest wieder die Instanz grün. Aber die Aktualität der Sensoren wurde nur beim Neustart aktualisiert.
                                          @arteck Wie kann ich denn den Fehler eingrenzen?
                                          Ein direktes ansprechen der Adapter über die Erweiterten Einstellungen hat auch keine Antwort von einem Sensor gebracht.
                                          • mickym
                                            @toki1973
                                            Nicht die VM neu starten. Nur Stick rausziehen und wieder rein und die Adapterinstanz Neustarten, nicht die ganze Maschine
                                            zigbee adapter cc2531
                                            10
                                            48
                                            4537
