    4. Beta Test js-controller 3.0.x auf GitHub
      Kueppert @Jan1 last edited by Kueppert
      @Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
      @Kueppert
      Warte doch mal was @apollon77 dazu sagt, da es ja ne neue Funktion des Controller ist, die bei Dir wohl nicht so ganz geklappt hat.
      to late ^^ ist schon am rebuilden...ich kann das ganze ja auch nochmal machen und testen wenn gewünscht
      Fehler beim Rebuild:
      ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
         void init(v8::Handle<v8::Object> target) {
      ../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’
      ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
      ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
      ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’
                                          tzset
      In file included from ../../nan/nan.h:54,
                       from ../src/./serialport.h:6,
                       from ../src/serialport.cpp:1:
      ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
       NODE_MODULE(serialport, init);
      /root/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
             (node::addon_register_func) (regfunc),                          \
      ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
      ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’
      make: *** [serialport.target.mk:114: Release/obj.target/serialport/src/serialport.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/serialport/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.19.0-5-amd64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/serialport
      gyp ERR! node -v v12.16.2
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the serialport@6.2.2 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2020-04-09T10_30_03_438Z-debug.log
      Hm...SQL sowie Zigbee sind im Admin auf grün. Mit dem Zigbee-Adapter lassen sich meine Lampen auch noch schalten...kann aber gern wenn gewünscht weiter testen 🙂
      • Jey Cee
        Jey Cee Developer @apollon77 last edited by
        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
        Kannst Du bitte mal "iobroker upload socketio" und "iobroker upload simple-api" versuchen
        Würde das nicht vorraussetzen das die Adapter installiert sind?
        • Jey Cee
          (bitte vorher schauen das ein admin öffnen den auslöst - wäre meine Annahme). Danke!
          Die Annahme scheint richtig zu sein. Nach upload ist die Meldung weg.
          • foxriver76
            foxriver76 Developer @Guest last edited by foxriver76
            @ilovegym Also folgendes, der wifilight Adapter wird jetzt über Community-Adapters gepflegt, heißt aber nun wieder wifilight ohne den community Zusatz. Gerne von Github installieren über https://github.com/iobroker-community-adapters/ioBroker.wifilight. Wenn das passt kann man die anderen Adapter auch so fixen - zumindest js-c 3 kompatibel machen.
            Test Thread: https://forum.iobroker.net/topic/32062/wifilight-1-1-0-testing
            • foxriver76
              foxriver76 Developer last edited by foxriver76
              @sigi234 selbiges gilt für firetv https://github.com/iobroker-community-adapters/ioBroker.firetv, wobei ich da sagen muss, wenn ich die ersten 5 Zeilen sehe, wundert es mich, dass das Ding überhaupt läuft.. 😉
              Test Thread: https://forum.iobroker.net/topic/32063/firetv-1-0-0-testen
              In beiden Fällen nach GitHub Install bitte unbedingt Upload ausführen. iob u firetv oder eben für wifilight
              • harrym
                harrym last edited by
                just4info: bekomm jetzt diese Warnings nach dem Upgrade ....
                • foxriver76
                  foxriver76 Developer @harrym last edited by
                  @harrym das passt, muss in den Adaptern gefixt werden, bzw ist es glaube in den neusten Versionen.
                    apollon77 @Kueppert last edited by apollon77
                    @Kueppert Für die nodejs 14 bist Du ca 12 Tage zu früh oder so (as I know)
                      @Kueppert Und du bist ganz sicher das die 3.0.4 drauf ist. ich hab gestern getestet und lieff super mit sql. Ich vermisse im Log das er sagt "hey rebuild erkannt" und sowas
                      Mein log war so:
                      2020-04-08 17:37:32.555  - ESC[32minfoESC[39m: host.io-test instance system.adapter.sql.0 started with pid 32387
                      2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: internal/modules/cjs/loader.js:1197
                      2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                      2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:                  ^
                      2020-04-08 17:37:33.001  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: was compiled against a different Node.js version using
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: NODE_MODULE_VERSION 79. Please try re-compiling or re-installing
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1197:18)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1036:19)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:72:18)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                      2020-04-08 17:37:33.002  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1147:30)
                      2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1167:10)
                      2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:996:32)
                      2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:896:14)
                      2020-04-08 17:37:33.003  - ESC[31merrorESC[39m: host.io-test instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2020-04-08 17:37:33.003  - ESC[32minfoESC[39m: host.io-test Adapter system.adapter.sql.0 needs rebuild and will be restarted afterwards.
                      2020-04-08 17:37:33.004  - ESC[34mdebugESC[39m: Incoming Host message rebuildAdapter
                      2020-04-08 17:37:33.004  - ESC[32minfoESC[39m: host.io-test system.adapter.sql.0 will be rebuilt
                      2020-04-08 17:37:33.005  - ESC[33mwarnESC[39m: host.io-test adapter "sql" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                      2020-04-08 17:37:33.005  - ESC[32minfoESC[39m: host.io-test iobroker rebuild sql
                      2020-04-08 17:37:33.154  - ESC[32minfoESC[39m: host.io-test iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.sql"
                      Das sehe ich bei dir nicht. Und er sucht nach "NODE_MODULE_VERSION" was bei dir drin ist. Oder Log zu früh beim kopieren abgeschnitten? schau mal bitte rein
                        @Kueppert Hast Du jetzt manuell rebuilded?
                          apollon77 @Jey Cee last edited by
                          @Jey-Cee Es gab mal frrüüüüher js.controller Versionen die beim adapter löschen ggff Objekte zurückgelassen haben. Die versucht Admin jetzt zu lesen und da meckern dann Dinge 😞
                          • Jey Cee
                            @apollon77 Hm das war aber eine Nackte test Installation lediglich mit einer älteren js-controller Version die ich geupdatet habe und dann die Adapter installiert.
                              @Jey-Cee schau mal. Du hast bestimmt system.adapter.xy Objekte rumliegende von Objekt Typ Adapter. Korrekt? Wo die her sind wäre dann die interessante Frage.
                              • Jey Cee
                                Korrekt?
                                Nein, hab sogar extra nochmal die VM mit dem Testsystem gestartet um ganz sicher zu sein.
                                  Kueppert @apollon77 last edited by
                                  @apollon77 jo, hab manuell nen Rebuild gemacht und nur die eine Fehlermeldung gehabt wegen Serialdings...hat aber nix mit dem neuen JS zu tun. Rebuild hat der nicht gemacht...hab ca. 1h gewartet - kamen immer nur die hier gemeldeten Fehlermeldungen...
                                    @Kueppert Und du bist 100% sicher das der controller 3.x drauf war? Hm ... das volle log wäre cool. Mindestens mehr.
                                      @Jey-Cee Schau mal bei den einzelnen Objekten weiter unten
                                        Ich habe gerade noch die 3.0.5 auf GitHub veröffentlicht mit noch kleinere Fixes:
                                        3.0.5 (2020-04-09) Release Elena
                                        • (foxriver76) Remove mock for adapter.states.getState again, fixed two adapters
                                        • (foxriver76) fix crash of redis setState when undefined is passed and refuse undefined as value in general
                                        • (Apollon77) Make sure objects update from/ts/user when extending objects in all cases
                                        • harrym
                                          host.iobroker	2020-04-09 23:52:48.373	error	iobroker Cannot find io-package.json in "null": Error: ENOENT: no such file or directory, open 'null/io-package.json'
                                          wollte gerade nen adapter auf den letzten stand bringen.
                                          foxriver76 apollon77 2 Replies Last reply Reply Quote 0
                                          • foxriver76
                                            @harrym Mal Fixer ausgeführt? Auf der Konsole iob fix, falls Installation nicht zu alt oder schon mal gefixt. Schaut so aus als konnte das Adapter Vezeichnis vom js-c nicht korrekt festgemacht werden, könnte z. B. aufgrund von Rechten der Fall sein.
                                            harrym 1 Reply Last reply Reply Quote 0
                                            js-controller
                                            39
                                            416
                                            68471
