    4. FireTv 1.0.0 testen
    FireTv 1.0.0 testen
      sigi234 Forum Testing Most Active @foxriver76 last edited by
      @foxriver76
      firetv.0	2020-04-09 16:48:50.917	info	(16056) 192.168.178.57: ADB version: 39, Android Version: , API Level:
      firetv.0	2020-04-09 16:48:50.915	error	Otherwise check for a confirmation dialog on your device.'
      firetv.0	2020-04-09 16:48:50.915	error	Try 'adb kill-server' if that seems wrong.
      firetv.0	2020-04-09 16:48:50.915	error	This adb server's $ADB_VENDOR_KEYS is not set
      firetv.0	2020-04-09 16:48:50.915	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
      firetv.0	2020-04-09 16:48:50.913	error	Otherwise check for a confirmation dialog on your device.'
      firetv.0	2020-04-09 16:48:50.913	error	Try 'adb kill-server' if that seems wrong.
      firetv.0	2020-04-09 16:48:50.913	error	This adb server's $ADB_VENDOR_KEYS is not set
      firetv.0	2020-04-09 16:48:50.913	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
      firetv.0	2020-04-09 16:48:50.911	error	Otherwise check for a confirmation dialog on your device.'
      firetv.0	2020-04-09 16:48:50.911	error	Try 'adb kill-server' if that seems wrong.
      firetv.0	2020-04-09 16:48:50.911	error	This adb server's $ADB_VENDOR_KEYS is not set
      firetv.0	2020-04-09 16:48:50.911	error	(16056) ID: 192.168.178.57 Error=Failure: 'device unauthorized.
      firetv.0	2020-04-09 16:48:50.910	debug	(16056) Connected to 192.168.178.57 id=192.168.178.57:5555
      firetv.0	2020-04-09 16:48:50.865	debug	(16056) Device 192.168.178.57:5555 + type=unauthorized was plugged in
      firetv.0	2020-04-09 16:48:50.796	debug	(16056) FireTV: 192.168.178.57
      • foxriver76
        foxriver76 Developer @sigi234 last edited by foxriver76
        @sigi234 hm und das ist mit alter Adapter Version nicht? Konfig Seite passt?
        An der ganzen Geschichte sollte sich nix geändert haben..
          darkiop Most Active last edited by darkiop
          Wollte dem 1.0.0 auch mal wieder ne Chance geben 🙂
          adb liegt unter /usr/bin - somit also auch in $PATH. Installiert über android-tools-adb (Debian).
          Der FireTV-Stick ist per ping erreichbar.
          In den Einstellungen des Adapters hatte ich trotzdem mal manuell den Pfad von ADB geändert - das wird beim speichern aber nicht übernommen.
          Mir ist es bisher nicht gelungen den Stick zu verbinden. Auch im mit Log = debug ist der Adapter nicht gerade gesprächig:
          error: firetv.0 (2364) adb executable not found. undefined
          Jemand ne Idee was ich noch versuchen könnte? Oder stelle ich mich gerade etwas blöd dran und verstehe die Logik des etwas angestaubten Admins nicht? 🙂
          Interessanterweise ist der Adapter die ganze Zeit 'grün' 🙂
            @foxriver76 sagte in FireTv 1.0.0 testen:
            Alter hatte mal funktioniert, in letzter Zeit aber nicht mehr.
              sigi234 Forum Testing Most Active @darkiop last edited by
              @darkiop sagte in FireTv 1.0.0 testen:
              Bei mir auch.
              • foxriver76
                foxriver76 Developer last edited by foxriver76
                Puh für den ‘kreativen’ Code übernehme ich allgemein keine Verantwortung. Es gibt kein info.connection State, somit immer grün solange der Adapter nicht crashed oder aus ist.
                D Neuschwansteini 2 Replies Last reply Reply Quote 0
                  darkiop Most Active @foxriver76 last edited by
                  Passt schon 😉
                  @sigi234 Läuft der Rest bei dir? Kannst du eine IP eintragen und über adb verbinden?
                  • Neuschwansteini
                    Neuschwansteini Banned @foxriver76 last edited by
                    @foxriver76 ich glaub der Adapter mag noch ausführlich getestet werden, die nächsten Tage-Wochen....
                    hier zickt er auch gerade mal rum. von wegen device offline..
                    Was er nicht macht:
                    adb server starten
                    adb connect device
                    das mach ich vorher mit nem script, wenn ich iobroker starte...
                    übrigens war in meiner prod. Installation da immer ein sudo adb notwendig!
                      sigi234 Forum Testing Most Active @darkiop last edited by sigi234
                      (9800) can not connect to 192.168.178.41 Error=unable to connect to 192.168.178.41:5555: cannot connect to 192.168.178.41:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
                      Hm, es hatte ja schon mal funktioniert. Ich weis noch das ich viel experimentiert habe, denke es liegt an der Abrage zum TV. Normalerweise solle da eine Verbindunsmeldung vom TV kommen ob ich den Zugriff erlaube.
                      • foxriver76
                        foxriver76 Developer @Neuschwansteini last edited by
                        @ilovegym hm ja insbesondere geht es mir darum, dass er mindestens so läuft wie vorher und js-c 3 kompatibel ist, alles was schon immer im Adapter schief lief, sollte sich mal einer annehmen der einen FireTV selbst hat.
                        Also wenn ich jetzt irgendwas kaputt gemacht habe was mit der vorherigen Version ging bitte hervorheben, sonst Issue damit sich möglichst bald mal jemand darum kümmert.
                          Nein, er ging schon einige Wochen bei mir nicht mehr.
                            Alternativ könnte ja auch "alles" über ein Skript und exec adb machen ...
                            Mir geht es eigentlich nur um starten/beenden von Apps und ggf. reboot des Sticks.
                              Ok, ich werde das ganze wirklich über ein Skript aufbauen.
                              Hier eine Liste mit den intents zum starten/stoppen diverser Apps:
                              https://gist.github.com/mcfrojd/9e6875e1db5c089b1e3ddeb7dba0f304
                              Das funktioniert von der Shell auch ohne Probleme.
                              Hier noch ein paar weitere Befehle aus meinen Notizen:
                              apt-get install android-tools-adb
                              adb start-server
                              adb kill-server
                              adb connect
                              adb disconnect
                              adb reboot
                              adb shell pm list packages -f
                              adb shell am start -a android.intent.action.VIEW -d -n com.spotify.tv.android/.SpotifyTVActivity
                              adb shell am start -a android.intent.action.VIEW -d -n org.xbmc.kodi/.Splash
                              adb am force-stop org.xbmc.kodi
                                Erster Test erfolgreich - also als Alternative eine Option:
                                • harrym
                                  harrym last edited by
                                  hmmmm .seltsam .... ich kann apps direkt via Objekt vom Adapter starten, stoppen und auch alles andere auch. Ich habe den alten Adapter gelöscht und den neuen via Git installiert. ADB Pfad eingetragen, FireTV 4K hinzugefügt und alles war ok.
                                    sigi234 Forum Testing Most Active @harrym last edited by
                                    @harrym
                                    Wie schaut der Pfad aus? Hast du Windows?
                                    harrym 2 Replies Last reply Reply Quote 0
                                    • harrym
                                      harrym @sigi234 last edited by
                                      @sigi234 ne. ich hab linux am laufen.
                                      /usr/lib/android-sdk/platform-tools/adb
                                      • harrym
                                        @sigi234 eventuell den FireTV mal resetten/updaten und die Entwicklereinstellungen vom Stick checken ?
                                        • foxriver76
                                          Bitte auch mal nicht js-c 3 Tester testen ob es tut. 😉
                                          Neuschwansteini 1 Reply Last reply Reply Quote 0
                                            sigi234 Forum Testing Most Active @harrym last edited by sigi234
                                            @harrym sagte in FireTv 1.0.0 testen:
                                            firetv.0	2020-04-12 20:21:42.027	debug	(12848) system.adapter.admin.0: logging true
                                            firetv.0	2020-04-12 20:19:42.661	debug	(12848) system.adapter.admin.0: logging false
                                            firetv.0	2020-04-12 20:18:04.882	error	(12848) can not connect to 192.168.178.54 Error=unable to connect to 192.168.178.54:5555: cannot connect to 192.168.178.54:5555: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die
                                            firetv.0	2020-04-12 20:18:02.864	info	(12848) 192.168.178.57: ADB version: 39, Android Version: , API Level:
                                            firetv.0	2020-04-12 20:18:02.863	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                            firetv.0	2020-04-12 20:18:02.860	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                            firetv.0	2020-04-12 20:18:02.858	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                            firetv.0	2020-04-12 20:18:02.855	error	(12848) ID: 192.168.178.57 Error=Failure: 'device '192.168.178.57:5555' not found'
                                            firetv.0	2020-04-12 20:18:02.854	debug	(12848) Connected to 192.168.178.57 id=192.168.178.57:5555
                                            firetv.0	2020-04-12 20:18:02.848	debug	(12848) Device 192.168.178.57:5555 was unplugged
                                            firetv.0	2020-04-12 20:18:02.839	debug	(12848) Device 192.168.178.57:5555 + type=offline was plugged in
                                            firetv.0	2020-04-12 20:18:02.799	debug	(12848) FireTV: 192.168.178.57
                                            firetv.0	2020-04-12 20:18:02.798	debug	(12848) FireTV: 192.168.178.54
                                            firetv.0	2020-04-12 20:18:02.724	info	(12848) starting. Version 1.0.0 in C:/Program Files/iobroker/Test/node_modules/iobroker.firetv, node: v10.16.3, js-controller: 3.0.7
                                            firetv.0	2020-04-12 20:18:02.590	debug	(12848) statesDB connected
                                            firetv.0	2020-04-12 20:18:02.590	debug	(12848) States connected to redis: 127.0.0.1:9000
                                            firetv.0	2020-04-12 20:18:02.580	debug	(12848) States create System PubSub Client
                                            firetv.0	2020-04-12 20:18:02.579	debug	(12848) States create User PubSub Client
                                            firetv.0	2020-04-12 20:18:02.575	debug	(12848) Redis States: Use Redis connection: 127.0.0.1:9000
                                            firetv.0	2020-04-12 20:18:02.574	debug	(12848) objectDB connected
                                            firetv.0	2020-04-12 20:18:02.572	debug	(12848) Objects connected to redis: 127.0.0.1:9013
                                            firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects client initialize lua scripts
                                            firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create User PubSub Client
                                            firetv.0	2020-04-12 20:18:02.562	debug	(12848) Objects create System PubSub Client
                                            firetv.0	2020-04-12 20:18:02.561	debug	(12848) Objects client ready ... initialize now
                                            firetv.0	2020-04-12 20:18:02.543	debug	(12848) Redis Objects: Use Redis connection: 127.0.0.1:9013
                                            firetv.0	2020-04-12 20:17:59.210	info	(2544) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            firetv.0	2020-04-12 20:17:59.209	info	(2544) terminating
                                            firetv.0	2020-04-12 20:17:59.208	info	(2544) Got terminate signal TERMINATE_YOURSELF
                                            amazon firetv test
                                            21
                                            82
                                            7155
