    4. Test Coronavirus Statistics for ioBroker
      Hicki @crunchip last edited by
      @crunchip sagte in Test Coronavirus Statistics for ioBroker:
      für die, die es verwenden, habe die Ansicht Tageswerte für Deutschland und Global angepasst
      für Deutschland
       "datasource": "InfluxDB-corona",
       "aliasColors": {
         "Genesen": "dark-green",
         "Kritisch": "dark-purple",
         "Sterbefälle": "dark-red",
         "aktiv": "dark-orange",
         "infiziert": "dark-blue"
       "bars": true,
       "dashLength": 10,
       "dashes": false,
       "fill": 1,
       "fillGradient": 0,
       "gridPos": {
         "h": 6,
         "w": 12,
         "x": 0,
         "y": 13
       "hiddenSeries": false,
       "id": 26,
       "legend": {
         "avg": false,
         "current": true,
         "hideEmpty": false,
         "hideZero": false,
         "max": false,
         "min": false,
         "show": true,
         "total": false,
         "values": true
       "lines": false,
       "linewidth": 1,
       "nullPointMode": "null",
       "options": {
         "dataLinks": []
       "percentage": false,
       "pointradius": 2,
       "points": false,
       "renderer": "flot",
       "seriesOverrides": [
           "alias": "Sterbefälle"
           "alias": "Kritisch"
           "alias": "aktiv"
           "alias": "infiziert"
           "alias": "Genesen"
       "spaceLength": 10,
       "stack": true,
       "steppedLine": false,
       "targets": [
           "alias": "Kritisch",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "orderByTime": "ASC",
           "policy": "default",
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "D",
           "resultFormat": "time_series",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "infiziert",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "A",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "aktiv",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "B",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "Sterbefälle",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "C",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "Genesen",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "E",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
       "thresholds": [],
       "timeFrom": "7d",
       "timeRegions": [],
       "timeShift": null,
       "title": "Tageswerte Deutschland",
       "tooltip": {
         "shared": true,
         "sort": 0,
         "value_type": "individual"
       "transparent": true,
       "type": "graph",
       "xaxis": {
         "buckets": null,
         "mode": "time",
         "name": null,
         "show": true,
         "values": []
       "yaxes": [
           "format": "short",
           "label": null,
           "logBase": 1,
           "max": null,
           "min": null,
           "show": true
           "format": "short",
           "label": null,
           "logBase": 1,
           "max": null,
           "min": null,
           "show": true
       "yaxis": {
         "align": false,
         "alignLevel": null
      für Global
       "aliasColors": {
       "bars": true,
       "dashLength": 10,
       "dashes": false,
       "fill": 1,
       "fillGradient": 0,
       "gridPos": {
         "h": 6,
         "w": 12,
         "x": 0,
         "y": 19
       "id": 27,
       "legend": {
         "avg": false,
         "current": true,
         "hideEmpty": false,
         "hideZero": false,
         "max": false,
         "min": false,
         "show": true,
         "total": false,
         "values": true,
         "alignAsTable": false
       "lines": false,
       "linewidth": 1,
       "options": {
         "dataLinks": []
       "pointradius": 2,
       "points": false,
       "renderer": "flot",
           "alias": "Kritisch"
           "alias": "aktiv"
           "alias": "Genesen"
       "spaceLength": 10,
       "stack": true,
       "targets": [
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "D",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "A",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "aktiv",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "B",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "C",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "Genesen",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "E",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
       "thresholds": [],
       "timeFrom": "7d",
       "timeRegions": [],
       "timeShift": null,
       "title": "Tageswerte Global",
       "tooltip": {
         "shared": true,
         "sort": 0,
       "type": "graph",
       "xaxis": {
         "buckets": null,
         "mode": "time",
         "name": null,
         "show": true,
         "values": []
       "yaxes": [
           "format": "short",
           "label": null,
           "logBase": 1,
           "max": null,
           "min": null,
           "show": true
           "format": "short",
           "label": null,
           "logBase": 1,
           "max": null,
           "min": null,
           "show": true
       "yaxis": {
         "align": false,
         "alignLevel": null
      Bei mir ist alles schwarz.
      Habe ich was falsch gemacht?
        crunchip Forum Testing Most Active @Hicki last edited by crunchip
        @Hicki das kann ich dir nicht beantworten 😊
        Weiss ja nicht, was du gemacht hast😉
        Wenn da das Gesamt Dashboard laufen hast, musst du für die jeweilige Abfrage die json ersetzen.
          Ich habe in Grafana unter Create, Import - paste JSON eingefügt. Ist doch richtig, oder?
            @Hicki das wäre richtig, wenn du das Gesamte Dashboard importieren würdest. Das sind aber zwei einzelne innerhalb eines Dashboard.
            Hast du das Gesamte Dashboard laufen?
              Ja
                @Hicki dann kannst du doch bei Tageswert Deutschland das Menü aufmachen, dort die json öffnen und die aktuell reinkopieren.
                Bin leider nicht am Rechner, hab Nachtschicht.
                  Ok, ich melde mich Morgen noch einmal.
                  Danke erst einmal.
                      Vielen Dank. Passt.
                      Ein Problem doch noch. Im Bild rot eingerahmt stehen zum Teil keine Werte. Was kann das sein?
                        @Hicki da erscheinen nur die Werte, die aktuell übertragen wurden und die Berechnung ist 24Std Zyklus um 0:00
                        aktuell wäre es bei mir im Moment
                          Hicki @crunchip last edited by Hicki
                          Was und wo muss ich jetzt da ändern?
                            @Hicki wieso was ändern?, wen Daten kommen, werden die automatisch aktualisiert. Siehst du doch zum Vergleich auf deinem Dashboard rechts daneben.
                              Alles gut
                                es fehlt der Landkreis Aschersleben-Staßfurt
                                  wie kann ich den Zyklus ändern?
                                  Gruß Hicki
                                    @Hicki was meinst du, die Anzeigezeit?(last 14 days)
                                    oder meinst du im Query selbst (WHERE $timeFilter GROUP BY time(1d))
                                      Die (last 14 days) meine ich nicht.
                                      Bei Dir steht neben dem Datum keine Aktualisierungszeit. Wo ändere ich das? Das ich mal den aktuellen Wert habe und nicht 00.00 Uhr.
                                        @Hicki Natürlich steht da 0:00, da ab 0:00 bis aktuelle Zeit berechnet wird, sofern Daten in der Zwischenzeit gesendet wurden.Das was du meinst, siehst du doch im rechten Panel daneben
                                          Alexander Späth @stimezo last edited by
                                          @stimezo: Klasse Visu und coole Icons!👏
                                          Würdest du die Icons oder die Vis zur Verfügung stellen?
                                          Gruß aus dem Schwarzwald
                                            @Dutchman es hat sich seit heute scheinbar wieder etwas an der api geändert
                                            coronavirus-statistics.0	2020-04-17 02:00:39.354	error	(960) [loadCountries] error: values is not iterable, stack: TypeError: values is not iterable at loadCountries (/opt/iobroker/node_modules/iobroker.coronavirus-statistics/main.js:85:28) at pro
                                            coronavirus-statistics.0	2020-04-17 02:00:38.492	warn	(960) State attribute definition missing for + message
                                            coronavirus-statistics.0	2020-04-17 01:30:25.604	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                            coronavirus-statistics.0	2020-04-17 01:30:25.604	error	at loadCountries (/opt/iobroker/node_modules/iobroker.coronavirus-statistics/main.js:85:28)
                                            coronavirus-statistics.0	2020-04-17 01:30:25.604	error	(23387) [loadCountries] error: values is not iterable, stack: TypeError: values is not iterable
                                            coronavirus-statistics.0	2020-04-17 01:30:25.402	warn	(23387) State attribute definition missing for + message
                                            81.1k
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            330519
