    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Onkyo
    Onkyo
    • Bluefox
      Bluefox last edited by
      Hello Installator,
      i am on vacation till next week, so only then I can help you.
      greetings,
      bluefox
      • I
        instalator last edited by
        @Eisbaeeer:
        ` > All objects in IoB work with VIS.
        I looked at your driver and understand your idea. . `
        OK, can you shortly explain, wich button do you use to power on/off and the corrosponding objekt?
        I don't get running it with only one button.
        Eisbaeeer `
        You wrote a little wrong code.
        I have made changes that allow you to automatically create objects, but check when BlueFox will return from vacation.
        https://github.com/GermanBluefox/node-e … 9fac6dca4d
        https://github.com/ioBroker/ioBroker.on ... 1532dd5799
        https://github.com/ioBroker/ioBroker.on ... ca6105cb19
        Change at these files, delete all the objects in Onkio driver and restart the IOB.
        • I
          @Eisbaeeer:
          Eisbaeeer `
          I changed the driver. Objects are created automatically. Replace folder with the drivers, and delete all the objects in Onkio driver and restart the IOB.
          266_iobroker.onkyo.rar
          • I
            @instalator:
            filename="iobroker.onkyo.rar" index="0">~~ `
            What result?
            • Eisbaeeer
              Eisbaeeer Developer last edited by
              @instalator:
              @instalator:
              filename="iobroker.onkyo.rar" index="0">~~ What result?
              I tested with the main power button. Result is, that the button doesn´t change the colour, because the status in iobroker is NOT "true" or "false" or "1" or "0". And this can not be working. Only this 4 states are allowed in iobroker. The object get´s the state (value) "standby".
              I have attached a screenshot of my test. The buttons left of the marked are my working buttons who changes the logo by selecting a picture for the value "false" and an other for the value "true".
              I tested the "Mute" button, too. This is working how it should !!!
              So it seems, that only the feedback of power button is wrong. Can you change that from "standby" to "false" and if the receiver is on to "true"?
              At the moment we get:
              Receiver off = "standby"
              Receiver on = "1"
              Correct feedbacks will be:
              Receiver off = "false"
              Receiver on = "true"
              Eisbaeeer
              • Eisbaeeer
                Hi
                I changed my vis to test further. In zone 1 there is no "radio preset" available. The radio preset in zone2 doesn´t working. If I try to set the preset to "2" for preset memory 2, the receiver doesn´t recognize that. It doesn´t matter, what you type in, no reaction.
                The other "net-usb" things are not tested at the moment.
                Greetings Eisbaeeer
                • I
                  @Eisbaeeer:
                  Hi
                  Greetings Eisbaeeer `
                  Hallo!
                  Zuletzt hatte ich den Hörer nachließ. Ich nahm es für eine kostenlose Ersatzkarte hdmi zur Reparatur. Ich kann den Fahrer nur 2 Wochen überprüfen.
                  • Eisbaeeer
                    Hi Installator
                    The translation does not make sense. I think it´s better to write in english.
                    I changed the "eiscp-commands.json" to get the status working in onkyo adapter. I changed the both "standby" to "false" states in zone1 and zone2.
                    You can compare the file with yours:
                    Now I get the correct feedback and my power buttons are working. Can you change this in your code?
                    My opinion is, that the adapter has too much overhead for the target function. It is not clear, why we need so much alias for the commands?
                    Who needs this and for wich function?
                    My main feature is to control the onkyo through VIS.
                    Can someone explain how do you use the adapter and the other functions?
                    My first adapter was created without an extra "node_module" for eiscp. I realized all in RAW mode wihtout too much overhead.
                    The other issue is, that I get now zone3, zone4 …., but I don´t have this zones!
                    For me the adapter now doing that what he should. So all is fine and I am happy. I can use it as it is.
                    Eisbaeeer
                    139_eiscp-commands.json.txt
                    • I
                      @Eisbaeeer:
                      Hi Installator
                      Eisbaeeer `
                      Hello! I can not yet test the driver. I gave my ressiver in the replacement motherboard repair hdmi
                      • Eisbaeeer
                        Ahh, OK! No problem.
                        Gesendet von meinem SM-G920F mit Tapatalk
                        • I
                          @Eisbaeeer:
                          @instalator:
                          @instalator:
                          filename="iobroker.onkyo.rar" index="2">~~ What result?
                          Receiver on = "1"
                          filename="Screenshot.png" index="2">~~
                          Eisbaeeer `
                          I changed the code to standby to False.
                          What do you do before prevented as in the picture?
                          • I
                            Eisbaeeer
                            [{"tpl":"tplHqButton","data":{"visibility-cond":"==","visibility-val":1,"oid":"onkyo.0.system-power","min":"standby","max":"true","iconName":"/vis/img/dashui/avSony.png","btIconWidth":"47","offsetAuto":false,"leftOffset":"4","topOffset":"7","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","usejQueryStyle":false,"changeEffect":"waves","testActive":false,"waveColor":"#FFFFFF","oid-working":"","filterkey":"media","pushButton":false,"gestures-offsetX":0,"gestures-offsetY":0},"style":{"left":"26px","top":"171px","z-index":"3","border-radius":"50px","width":"50px","height":"50px"},"widgetSet":"hqwidgets"}]
                            • I
                              Это объекты которые созданы автоматически, на основе файла команд.
                              These are objects that are created automatically based on the file command.
                              • Eisbaeeer
                                That's strange because I don't have a zone 3 and 4! Anyway, I'm happy now with my solution. I will not spend more time to debug. My buttons are working and I don't need more. Thanks.
                                • I
                                  @Eisbaeeer:
                                  Gesendet von meinem SM-G920F mit Tapatalk `
                                  Which model is your AV receiver?
                                  • Eisbaeeer
                                    TX-NR626
                                    • I
                                      @Eisbaeeer:
                                      TX-NR626
                                      )) Your receiver is not in the command file. https://github.com/GermanBluefox/node-e … mands.json
                                      Now I'll add it for you.
                                      • I
                                        @instalator:
                                        @Eisbaeeer:
                                        TX-NR626
                                        Now I'll add it for you. `
                                        266_eiscp-commands.rar
                                        • I
                                          @Eisbaeeer:
                                          TX-NR626
                                          Now the driver work? any comments?
                                          • Eisbaeeer
                                            Don't have time to test now.
                                            21938
