    5. [gelöst] blockly musikplayer - VIS
      patrick039212 @sigi234 last edited by
      sigi234 P 2 Replies Last reply Reply Quote 0
        sigi234 Forum Testing Most Active @patrick039212 last edited by sigi234
        @patrick039212
        Ich habe es so:
        Hab es mal bei mir getestet mit diesen Widget:
        [{"tpl":"tplHqCheckbox","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"alexa2.0.Echo-Devices.GxxxxxxxxxxDKU.Player.TuneIn-Station","val_false":"s8007","val_true":"s8007","checkboxSize":"small","checkboxColor":"grey","checkboxColorOn":"blue","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"readOnly":false},"style":{"left":"396px","top":"479px","z-index":"5"},"widgetSet":"hqwidgets"}]
          patrick039212 @patrick039212 last edited by patrick039212
          @patrick039212 said in blockly musikplayer - VIS:
          Danke für deine Mühe, leider funktioniert es nicht ...
          Regler ein = Ö3
          Regler aus = keine Funktion
          oder mach ich etwas falsch ... habe versucht den Wert leer zulassen bzw. auf 0 gesetzt beides ohne Ergebnis
          ed:
          Das Problem wird sein das die Musik nur über den Datenpunkt controlPause gestoppt werden kann ...
            @patrick039212 sagte in blockly musikplayer - VIS:
            Was willst du bei Regler aus?
              @sigi234
              Das die Musik angehalten wird,
              "Alexa Spiele Krone Hit" - Regler soll auf An gehen
              Regler aus in Vis - Musik aus
              Regler An in Vis - Musik an
              Alexa Stop - Regler aus Musik aus
              sigi234 dslraser 2 Replies Last reply Reply Quote 0
                @patrick039212
                Ok, dafür ist der Regler nicht gemacht. Das sollte man mit Blockly lösen (können). Ist was für @dslraser ?
                  @sigi234
                  trotzdem vielen dank für deine Hilfe 🙂
                    @sigi234
                    Habe dslraser mal angeschrieben, vielleicht meldet er sich.
                    • dslraser
                      dslraser Forum Testing Most Active @patrick039212 last edited by
                      @sigi234
                      Was geht denn nicht ?
                      Bei mir wird im Bad über einen Bewegungsmelder ein Sender abgespielt und auch wieder ausgeschaltet, ist dieses Prinzip gemeint ?
                        patrick039212 @dslraser last edited by
                        @dslraser
                        Ich möchte gerne über die Vis die Musikwiedergabe von Alexa steuern also wenn ich sage
                        "Alexa spiele Musik x" soll der Regler in der Übersicht auf True geändert werden
                        wenn ich den Regler in der Vis auf false setze, soll die Musik abgeschalten werden.
                        Das ganze halt anders herum auch...
                        Regler True = spiele meinen Lieblings sender
                        Regler False = Musik aus
                        hoffe ich konnte es verständlich erklären ^^
                        • dslraser
                          @patrick039212
                          ich habe kein VIS, aber, das müsste doch über Deinen selbst erstellten Schalter gehen. Hast Du ein aktuelles Probeblockly als Export ? Stell mal hier rein, dann schau ich mal...
                          • dslraser
                            dslraser Forum Testing Most Active @patrick039212 last edited by dslraser
                            @patrick039212
                            Damit müsstest Du es schon an und ausschalten können, probiere mal...Um die Alexa Befehle können wir uns ja gleich kümmern. Meinst Du sowas. (im Trigger Deinen Schalter einfügen)
                             <block type="comment" id="Y)^OQX=4qN@eo%N_SI(_" x="-288" y="87">
                               <field name="COMMENT">Trigger auswählen</field>
                                 <block type="on_ext" id="n[L!|Z3-!2M2`/YI1VLc">
                                   <value name="OID0">
                                     <shadow type="field_oid" id="[;8D5{yn~A$[uJ)r,M5U">
                                     <block type="controls_if" id="r4;C-s:gJHryisv4KGb`">
                                         <block type="on_source" id="~DD%(.c_8OctNk;?4tW,">
                                         <block type="comment" id="g}TuHbtrA6O!-t0!C#q;">
                                           <field name="COMMENT">NDR2</field>
                                             <block type="control" id="pdP4]j.R]sG|Kbv{UAOu">
                                               <field name="OID">alexa2.0.Echo-Devices.xxx.Player.TuneIn-Station</field>
                                                 <block type="text" id="s,iZ/qZ?P?P|Z_$-J}W[">
                                                   <field name="TEXT">NDR 2</field>
                                       <statement name="ELSE">
                                         <block type="control" id="ngh%mwu(d(S#=ec1Wvlx">
                                           <field name="OID">alexa2.0.Echo-Devices.xxx.Player.controlPause</field>
                                             <block type="logic_boolean" id="8,X?-H,Dzv1G,]3ZVC5q">
                              patrick039212 @dslraser last edited by patrick039212
                              Ich habe einen neuen Datenpunkt "echoshow" angelegt ...
                              Das Problem ist das letzte sonst fals, wenn ich jetzt zu Alexa sage spiele z.B Ö3 schaltet er den Schalter auf True dadurch wird oben im Skript der Sender wieder auf Kronehit gewechselt...
                              Es müsste nach dem letzten "sonst fals" das Skript beendet werden ...
                              ED
                              Sry jetzt erst deinen Beitrag gesehen, ja das würde funktionieren.
                              • dslraser
                                @patrick039212
                                ich habe das jetzt mal mit einer Steckdose probiert (das ist quasi Dein eigener Datenpunkt)
                                Funktioniert. Meinst Du es so ?
                                • dslraser
                                  achso..., ja stimmt...dann muss das anders
                                    @dslraser
                                    ja nur wie, komme auf keine Lösung
                                    dslraser 2 Replies Last reply Reply Quote -1
                                    • dslraser
                                      @patrick039212
                                      ich probiere gerade...
                                      • dslraser
                                        @dslraser
                                        so könnte es klappen. Der controlPause braucht eine ganz schöne Verzögerung, sonst ging es bei mir nicht aus.
                                         <block type="on_ext" id="n[L!|Z3-!2M2`/YI1VLc" x="-337" y="62">
                                           <value name="OID0">
                                               <field name="oid">hm-rpc.0.SchalterSTATE</field>
                                                 <block type="on_source" id="X2ey^e9~Ky=hL=ap+Ig7">
                                                 <block type="controls_if" id=")CPaSYFnC1BV=@+uY.4I">
                                                     <block type="logic_compare" id="Da9}Q3WGE1O0_Uh~2WE;">
                                                       <field name="OP">NEQ</field>
                                                         <block type="on_source" id="4R.`#-r4WQ+bCL~c5MO2">
                                                           <field name="ATTR">state.from</field>
                                                         <block type="text" id="ZcgMybnh-RIZZdizL}k$">
                                                           <field name="TEXT">system.adapter.javascript.0</field>
                                                             <block type="debug" id="bNz}RU6F}hM*W+e{,`-e">
                                                               <value name="TEXT">
        <shadow type="text" id="7az6O~^AZ/k@N6uP]u9`">
        <field name="TEXT">sender an</field>
                                                 <block type="controls_if" id="Ly,HUr0QzAT;OsSx(.Us">
                                                     <block type="logic_negate" id="wuJ{VFmKH,ws({pFl^8@">
                                                       <value name="BOOL">
                                                         <block type="on_source" id="}TBG3~qCcgUqPB3Z9t#Q">
                                                     <block type="control" id="0+z[`l2Zz,^W07pFcVwI">
                                                       <mutation delay_input="true"></mutation>
                                                       <field name="DELAY_MS">3000</field>
                                                       <field name="UNIT">ms</field>
                                                         <block type="logic_boolean" id="^IkG(Ro4UR:bdnfAd[tl">
                                                         <block type="debug" id="rEd#F]iKSO+tQ,U:/r)w">
                                                           <value name="TEXT">
                                                             <shadow type="text" id="`/^djKksx}O:nv]qEF[P">
                                                               <field name="TEXT">sender aus</field>
                                             <block type="on_ext" id="/?mYxi#6K*C8f~d*4Z}3">
                                               <value name="OID0">
                                                 <shadow type="field_oid" id="A%x#r]gw28kiogk%rbXz">
                                                   <field name="oid">alexa2.0.Echo-Devices.xxx.Player.currentState</field>
                                                 <block type="controls_if" id="X7W43%DS?aL~;O6`)/{(">
                                                     <block type="on_source" id="*Vex#qEb+mF{LKh@#u|T">
                                                     <block type="control" id="5hI#Zp|oP[=tPMv{1FMb">
                                                       <field name="OID">hm-rpc.0.Schalter.3.STATE</field>
                                                         <block type="logic_boolean" id="dFZ*JU[GbT+,9fR}0~lv">
                                                     <block type="control" id="6a`dv{_S9_whBP:BcUp.">
                                                         <block type="logic_boolean" id="#p|drbt/hX)T-sjS)[oR">
                                          @dslraser
                                          Danke, teste ich sofort eine Frage nur was bedeutet "system.adapter,javascript.0"?
                                          • dslraser
                                            @patrick039212
                                            bei mir läuft das Blockly auf der Instanz javascript.0
                                            Das soll bewirken, wenn der Ursprüngliche Befehl nicht von da kommt (sondern über die Sprache per Alexa2 Adapter umgeschaltet wird) auf einen anderen Sender, das nicht wieder der Schalter aus geht bzw. wieder auf diesen Sender zurück geschaltet wird. Wenn Du über den Schalter einschaltest, dann geht immer der im Blockly genannte Sender an, dann kannst Du den Sender per Sprache wechseln, aber der Schalter bleibt an. Wenn Du dann den Schalter ausschaltest, oder Alexa stop sagst, dann geht auch der Schalter aus. (immer innerhalb von TuneIn, wenn Du auf einen anderen Provider wechselst geht das nicht)
                                            blockly javascript multimedia
                                            3200
