    4. Test Adapter mihome-vacuum v2.0.x
      dirkhe Developer last edited by
      Geh mal in die xiaomi App und verbinde dich mit dem robbi. Manchmal hilft das.
        DarkDevil last edited by
        Die Installation (bzw. das Update) haben schonmal geklappt. Danke dafür.
        Jetzt habe ich aber anscheinend den gleichen Fehler wie BamBam89
        mihome-vacuum.0	2020-04-11 07:47:03.668	info	(28242) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-04-11 07:47:03.668	warn	(28242) Time difference between Mihome Vacuum and ioBroker: 1 sec
        mihome-vacuum.0	2020-04-11 07:47:03.667	debug	(28242) Receive <<< Helo <<< 21310020000000000706b6555e9159d8ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-04-11 07:46:58.788	debug	(28242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-04-11 07:46:58.787	debug	(28242) no answer for undefined(id:1) received, giving up
        mihome-vacuum.0	2020-04-11 07:46:55.373	debug	(28242) system.adapter.admin.0: logging true
        mihome-vacuum.0	2020-04-11 07:46:53.786	debug	(28242) sendMsg[3] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 07:46:48.785	debug	(28242) sendMsg[2] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 07:46:46.064	debug	(28242) Xiaomi Cloud: Login successful
        mihome-vacuum.0	2020-04-11 07:46:45.241	debug	(28242) system.adapter.admin.0: logging false
        mihome-vacuum.0	2020-04-11 07:46:44.177	info	(28242) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-04-11 07:46:43.784	debug	(28242) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-04-11 07:46:43.755	debug	(28242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        • haselchen
          haselchen Most Active @DarkDevil last edited by
          @DarkDevil
          Hast du, wie vorher schonmal geraten, die MiHome App geöffnet ?
            BamBam89 last edited by
            Morgen zusammen,
            also ich hab das schon gemacht, allerdings ohne besondere Verbesserung:
            mihome-vacuum.0	2020-04-11 09:33:39.352	debug	(5753) sendMsg[1] >>> {"id":478,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:33:39.349	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:33:39.348	info	(5753) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-04-11 09:33:39.348	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172d3ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-04-11 09:33:34.353	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:33:34.353	debug	(5753) no answer for undefined(id:477) received, giving up
            mihome-vacuum.0	2020-04-11 09:33:29.353	debug	(5753) sendMsg[3] >>> {"id":477,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:33:24.352	debug	(5753) sendMsg[2] >>> {"id":477,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:33:19.351	debug	(5753) sendMsg[1] >>> {"id":477,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:33:19.346	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:33:19.346	info	(5753) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-04-11 09:33:19.346	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172bfffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-04-11 09:33:14.351	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:33:14.350	debug	(5753) no answer for undefined(id:476) received, giving up
            mihome-vacuum.0	2020-04-11 09:33:09.349	debug	(5753) sendMsg[3] >>> {"id":476,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:33:04.349	debug	(5753) sendMsg[2] >>> {"id":476,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:32:59.347	debug	(5753) sendMsg[1] >>> {"id":476,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:32:59.346	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:32:59.346	info	(5753) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-04-11 09:32:59.346	debug	(5753) Receive <<< Helo <<< 21310020000000000f9b48a15e9172abffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-04-11 09:32:54.354	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:32:54.354	debug	(5753) no answer for undefined(id:475) received, giving up
            mihome-vacuum.0	2020-04-11 09:32:49.353	debug	(5753) sendMsg[3] >>> {"id":475,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:32:44.352	debug	(5753) sendMsg[2] >>> {"id":475,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:32:39.351	debug	(5753) sendMsg[1] >>> {"id":475,"method":"get_status"}
            mihome-vacuum.0	2020-04-11 09:32:39.348	debug	(5753) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-04-11 09:32:39.347	info	(5753) connecting, this can take up to 10 minutes ...~~~~
            • haselchen
              haselchen Most Active @BamBam89 last edited by
              @BamBam89
              Welcher Sauger welche Firmware Version?
                BamBam89 @haselchen last edited by
                @haselchen
                Es handelt sich um einen S502-00
                Firmware 3.5.7_002008
                • haselchen
                  @BamBam89
                  Habe ich auch beides.
                  Welche Adapter Version hast du drauf?
                  Mit RC Nummer wenn du hast.
                    @haselchen
                    Version 2.0.9. Mit RC Nummer kann ich aber nichts anfangen 🙂
                    • haselchen
                      haselchen Most Active @BamBam89 last edited by haselchen
                      @BamBam89
                      Auf debug stellen über den Experten Modus und dann den Adapter neu starten. Im Log steht dann die RC Nummer hinter 2.0.9
                        @haselchen
                        Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                        • haselchen
                          @BamBam89
                          Ist aktuell.
                          Und das Problem ist, dass er sich nicht verbindet?
                          Oder habe ich da was überlesen?
                            ltsalvatore @Diginix last edited by
                            @Diginix sagte in Test Adapter mihome-vacuum v2.0.x:
                            @iphone333 Dann passt was nicht. Sollte eigentlich so im RAW von fan_power aussehen:
                            Welche Adapter Version nutzt du?
                            Hi Dginix,
                            ich wollte mal fragen, ob es mittlerweile ein lösung zu dem problem gibt.
                            ich habe auch das problem wie @iphone333, dass trotz aktuellen adapter v2.0.7 über den wert von fan_power* keine änderungen vorgenommen werden können.
                            auch bei mir sind die alten werte noch drin gewesen, habe diese um die von dir genannten ergänzt.. hilft aber leider nichts..
                            kuriose ist dabei, wenn ich einen wert über vis eintrage, dann funktioniert es einwandfrei..
                            nur über blockly script (sowohl text als auch zahl) nicht.
                            haselchen L 2 Replies Last reply Reply Quote 0
                              @haselchen
                              also wenn ich das richtig verstehe, müsste ich ja über die Buttons die entsprechenden Befehle ausgeben können:
                              Da tut sich aber nichts. Er wird auch in den Instanzen nicht grün
                              • haselchen
                                @BamBam89
                                Zeig mal bitte deine Adpatereinstellungen
                                • haselchen
                                  haselchen Most Active @ltsalvatore last edited by haselchen
                                  @ltsalvatore
                                  Aktuell wäre 2.0.9 RC7
                                  Habe das Blockly aus dem Forum.
                                  Es wird anscheinend von 100% ausgegangen für die einzelnen Stufen.
                                    DarkDevil @haselchen last edited by
                                    @haselchen jo, das habe ich. Allerdings ohne Veränderung. Der Adapter bleibt gelb
                                      @haselchen
                                      • haselchen
                                        @BamBam89
                                        Hast du Valetudo drauf?
                                        Ob ja oder nein, deaktiviere den Punkt und starte den Adapter mal neu.
                                        Meinetwegen öffne nach ein paar Sekunden nach Adapterstart auch die App nochmal.
                                        Edit:
                                        Hast du 2 verschiedene Token?
                                        Dann passt es ja auch nicht.
                                        Der Token von oben, muss unten in manuelle Einstellungen
                                        B 2 Replies Last reply Reply Quote 1
                                          @haselchen
                                          Nein habe ich eigentlich nicht. Die beiden Token schreibt er da ja automatisch rein....
                                          Ich versuche das mal.
                                          • haselchen
                                            @BamBam89
                                            Also Valetudo weg und beide Token gleich (den von oben >GetDevices)
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            494285
