    4. Beta Test js-controller 3.0.x auf GitHub
    • foxriver76
      foxriver76 Developer @harrym last edited by
      @harrym Danke, konnten den Fehler identifizieren.
        Einstein67 last edited by Einstein67
        Da nun Iobroker mit JS-Controller (3.0.5) den dritten Tag läuft, wollte ich die Log-Archive testen. Dabei stürzt der Admin aber komplett ab und Iobroker ist eine halbe Minute nicht erreichbar.
        admin.0	2020-04-11 07:23:57.210	info	(32229) Use link "http://localhost:8081" to configure.
        admin.0	2020-04-11 07:23:57.210	info	(32229) http server listening on port 8081
        admin.0	2020-04-11 07:23:57.175	info	(32229) received all objects
        admin.0	2020-04-11 07:23:56.955	info	(32229) requesting all objects
        admin.0	2020-04-11 07:23:56.955	info	(32229) requesting all states
        admin.0	2020-04-11 07:23:56.945	info	(32229) starting. Version 4.0.5 in /opt/iobroker/node_modules/iobroker.admin, node: v12.16.2, js-controller: 3.0.5
        host.iob12b	2020-04-11 07:23:56.380	info	instance system.adapter.admin.0 started with pid 32229
        host.iob12b	2020-04-11 07:23:26.366	info	Restart adapter system.adapter.admin.0 because enabled
        host.iob12b	2020-04-11 07:23:26.364	info	instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        admin.0	2020-04-11 07:23:25.854	info	(31873) Terminated (NO_ERROR): Without reason
        admin.0	2020-04-11 07:23:25.854	info	(31873) terminating
        admin.0	2020-04-11 07:23:25.851	info	(31873) terminating http server on port 8081
        admin.0	2020-04-11 07:23:25.851	error	at Unzip.emit (/opt/iobroker/node_modules/minipass/index.js:409:25)
        admin.0	2020-04-11 07:23:25.851	error	at Unzip.emit (events.js:322:22)
        admin.0	2020-04-11 07:23:25.851	error	at Unzip.<anonymous> (/opt/iobroker/node_modules/tar/lib/parse.js:352:29)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.[consumeChunk] (/opt/iobroker/node_modules/tar/lib/parse.js:434:21)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.[maybeEnd] (/opt/iobroker/node_modules/tar/lib/parse.js:402:17)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.[emit] (/opt/iobroker/node_modules/tar/lib/parse.js:286:12)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.emit (events.js:322:22)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.<anonymous> (/opt/iobroker/node_modules/tar/lib/parse.js:82:14)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.warn (/opt/iobroker/node_modules/tar/lib/unpack.js:188:18)
        admin.0	2020-04-11 07:23:25.851	error	at Unpack.warn (/opt/iobroker/node_modules/tar/lib/warn-mixin.js:19:40)
        admin.0	2020-04-11 07:23:25.851	error	(31873) Error: TAR_BAD_ARCHIVE: Unrecognized archive format
        admin.0	2020-04-11 07:23:25.848	error	(31873) uncaught exception: TAR_BAD_ARCHIVE: Unrecognized archive format
        Sonst bisher noch keine Fehler aufgetreten!!
          Kueppert @apollon77 last edited by Kueppert
          @apollon77 so, habe heute wohl alles korrekt gemacht - vermutlich. Folgendes vorgehen:
          cd /opt/iobroker
          iobroker stop
          npm install ioBroker/ioBroker.js-controller
          danach direkt das
          npm install -g npm
          gefolgt vom neuen node 13:
          curl -sL https://deb.nodesource.com/setup_13.x | bash -
          apt-get install -y nodejs
          alles als ROOT.
          Ergebnis:
          vorher:
          nachher:
          Der einzige Adapter, der tot bleibt, ist Lightyfi.
          lightify.0	2020-04-11 08:29:02.113	error	(8438) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/soef/soef.js:1239:20) at Object.options.ready (/opt/iobroker/node_modules/soef/soef
          lightify.0	2020-04-11 08:29:02.110	error	(8438) uncaught exception: Cannot read property 'getState' of undefined
          Auch wundert mich, dass ich als root gebeten werde:
          Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
          2020-04-11 08:11:50.544 - error: host.ioBroker2 Please consider running the installation fixer when on Linux.
          2020-04-11 08:12:19.568 - info: host.ioBroker2 instance system.adapter.lightify.0 started with pid 22036
          2020-04-11 08:12:20.571 - error: host.ioBroker2 could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Please also check left over processes when stopping ioBroker!
          Habe nen ganzen Haufen Fehlermeldungen...stelle gern mein ganzes LOG (als Datei) bereit, allerdings nicht hier als Upload 😉
          LOG zeigt er mir immer im Browser an...schöner wäre vermutlich, das LOG als Datei direkt bereitzustellen, damit nix umformatiert wird beim Herauskopieren aus dem Browser?!
          VG Thorsten
          apollon77 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
            @apollon77
            Bekomme beim Updaten von Adaptern immer diese Meldung: JS controller 3.0.5
            iobroker Cannot find io-package.json in "null": Error: ENOENT: no such file or directory, open 'null/io-package.json'
            Manuel via Github geht es dann.
            Dauert aber sehr lange mit einigen Fehlermeldungen!
            $ ./iobroker url "https://github.com/inventwo/ioBroker.vis-inventwo.git"
            install https://github.com/inventwo/ioBroker.vis-inventwo/tarball/853a829dd03b8c2e95d634286d9ade6b91c20fb7
            NPM version: 6.9.0
            npm install https://github.com/inventwo/ioBroker.vis-inventwo/tarball/853a829dd03b8c2e95d634286d9ade6b91c20fb7 --loglevel error (System call)
            gyp
            ERR! build error
            gyp ERR!
            stack
            Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR!
            stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp ERR!
            stack
                at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
            gyp
            ERR! System
            Windows_NT 10.0.18363
            gyp
            ERR!
            command
            "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\authenticate-pamgyp ERR! node -v v10.16.3gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
            gyp
            ERR! build error
            gyp
            ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
            gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\bufferutilgyp ERR! node -v v10.16.3gyp ERR! node-gyp -v v3.8.0gyp ERR!
            not ok
            gyp
            ERR!
            build error
            gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
            gyp
            ERR! stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\unix-dgramgyp
            ERR! not ok
            gyp ERR! build error
            gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR!
            ERR! cwd C:\Program Files\iobroker\Test\node_modules\utf-8-validategyp ERR! node -v
            v10.16.3
            gyp
            upload [20] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/tsconfig.json tsconfig.json application/json
            upload [19] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/style.css style.css text/css
            upload [18] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/spende.png spende.png image/png
            upload [17] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Set.png Set.png image/png
            upload [16] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Preview4.png Preview4.png image/png
            upload [15] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Preview3.png Preview3.png image/png
            upload [14] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Preview2.png Preview2.png image/png
            upload [13] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Preview.png Preview.png image/png
            upload [12] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Muster.png Muster.png image/png
            upload [11] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/i_DEV_150.png i_DEV_150.png image/png
            upload [10] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/i_300.png i_300.png image/png
            upload [9] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/i_150.png i_150.png image/png
            upload [8] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/index_m.html index_m.html text/html
            upload [7] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/icons.png icons.png image/png
            upload [6] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Data.png Data.png image/png
            upload [5] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/CSS-text.png CSS-text.png image/png
            upload [4] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Config.png Config.png image/png
            upload [3] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Button_CSS.png Button_CSS.png image/png
            upload [2] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/Blockly.png Blockly.png image/png
            upload [1] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/BackgroundUrl.png BackgroundUrl.png image/png
            upload [0] vis-inventwo.admin C:/Program Files/iobroker/Test/node_modules/iobroker.vis-inventwo/admin/admin.d.ts admin.d.ts video/mp2t
            Adapter "system.adapter.vis.0" restarted.
            Update "system.adapter.vis-inventwo.0"
            process exited with code 0
            Betroffene Adapter:
            VIS-INVENTWO
            rssfeed
              HelmutS last edited by
              Der SONOS-Adapter schreibt unter dem js-controller 3 keine Stati mehr, steuern funktioniert noch.
              Ursache scheint die Art des Zugriffes zu sein:
              adapter.setState({device: 'root', channel: ip, state: 'state_simple'}, {val: ps.playing, ack: true});
              nach ändern in
              adapter.setState('root.'+ip+'.state_simple',  ps.playing, true);
              funktioniert es.
              Ist das eine beabsichtigte Änderung?
              • foxriver76
                foxriver76 Developer @sigi234 last edited by
                @sigi234 wird in nächster Version behoben sein.
                  sigi234 Forum Testing Most Active @foxriver76 last edited by
                  @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
                  Super, Danke.
                  @all
                  Gibt es eigentlich eine Möglichkeit schon gemeldete Fehler in eine Liste zu schreiben. (Als Spoiler im 1 .Beitrag ?)
                  Bei einen kleinen Beitrag ist das ja übersichtlich. Aber bei einen so wichtigen und großen wäre es hilfreich.
                  Anders gefragt: kann man das abfangen wenn ich einen Beitrag schreibe, so in der Art : Fehler schon bekannt!
                  Ich hoffe Ihr wisst was ich meine.
                    apollon77 @Kueppert last edited by apollon77
                    @Kueppert lightily ist wieder so ein soef scheiss. Mal schauen. Bzw. Wann schalten die die Server ab? Das ist doch schon gekillt. Noch relevant??
                    Log nehm ich gern als email iobroker@fischer-ka.de. Danke.
                    Und logfile gibts auf deinem iobroker Host im iobroker dir unterverzeichnis log auch als datei
                    K sigi234 2 Replies Last reply Reply Quote 0
                      apollon77 @HelmutS last edited by
                      @HelmutS fixen wir. Danke!! Denke heute Abend haben wir eine 3.0.6
                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                        LOG-file hab ich dir gerade geschickt...hab nix rausgelöscht, sondern es komplett gelassen. Denke, das ist am sinnvollsten.
                        Lightify-Anbindung ist kommendes Jahr zu Ende. Vermutlich lohnt daher ein Update des Adapters nicht mehr. Hab meine Lampe wieder am Zigbee vom Artek angelernt.
                        Wenn noch was zu testen ist - bitte gern melden. Lasse das System jetzt erst mal genau so weiter laufen.
                        Viele Grüße, Thorsten
                          Ja der geht mir auch schon auf den Wecker!
                            apollon77 @Einstein67 last edited by
                            @Einstein67 Bitte Admin Issue.
                              @Kueppert sagte in Beta Test js-controller 3.0.x auf GitHub:
                              Das sollte als Root nicht auftreten. musst mal schauen was es da an Rechten zerballert hat.
                                apollon77 @sigi234 last edited by
                                @sigi234 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                Ja, aktuell eher schwierig weil wir gerade zu dritte am fixen arbeiten und am Ende nur ich den Artikel bearbeiten kann ... auf dem Handy ist das aber alles andere als schön teilweise. (Family und so).
                                Aktuell ist es faktisch so: Hochscrollen bis zu meinem letzten "neue version" post weil bisher haben wir immer alles was davor gemeldet war mit einem update gefixt 🙂
                                Aktuell arbeiten wir an der 3.0.6 (tippe grob heute abend) die dann alles bisherige fixen sollte.
                                  @Kueppert Ok, dann würde ich notieren das wir lightify adapter nicht fixen. Umstellung auf Zigbee wird empfohlen
                                    Guten Abend an die fleissigen Tester 🙂
                                    Heute habe ich in enger Zusammenarbeit wieder mit @foxriver76 und @AlCalzone die 3.0.6 des js-controller für Euch. Alle bisher gemeldeten Probleme sind behoben. Sonos sollte wieder Daten schreiben und updates einiger bestimmter Adapter (zB hm-rega und VIS-INVENTWO) sollten auch wieder tun, Falls da jemand Updates offen hat versucht bitte mal.
                                    Changelog:
                                    3.0.6 (2020-04-11) Release Elena
                                    • (bluefox) Fixed vis debug
                                    • (foxriver76/Apollon77) optimize and fix dependeny checks to consider all dependencies correctly on install, upgrade and adapter start
                                    • (AlCalzone) add iobroker extend object command
                                    • (AlCalzone) optimize performance when objects are duplicated and checked internally
                                    • (AlCalzone) Add command iobroker debug adapter to start Node.js debug sessions for an adapter
                                    • (foxriver76) validate id also has to allow objects with correct properties (device, channel ...)
                                    • (Apollon77) prevent crash if udp membership can not be added (Sentry fix)
                                    • (Apollon77) change object type for compact groups to "folder"
                                    • (Apollon77) add adapter flag ALIAS_SEPARATE_READ_WRITE_ID
                                    • harrym
                                      DANKE für eure Arbeit! ich werd gleich mal es Update machen 😉
                                      • harrym
                                        • harrym
                                          harrym last edited by harrym
                                          Das "Warn" kommt noch ...
                                          aber ist eben nur ein warning.
                                          • harrym
                                            worauf soll ich achten? updates oder so? wo könnten fehler kommen?
                                            js-controller
                                            39
                                            416
                                            68445
