    4. Windanzeige mit Ventus W132 & Wemos D1 Mini
      claus1993 last edited by claus1993
      Hier mal noch die komplette Fehlermeldung
      Arduino: 1.8.8 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
      C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\claus\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\claus\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\claus\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10808 -build-path C:\Users\claus\AppData\Local\Temp\arduino_build_156623 -warnings=none -build-cache C:\Users\claus\AppData\Local\Temp\arduino_cache_901311 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\claus\Documents\Arduino\Windmesser\Windmesser.ino
      C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\claus\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\claus\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\claus\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10808 -build-path C:\Users\claus\AppData\Local\Temp\arduino_build_156623 -warnings=none -build-cache C:\Users\claus\AppData\Local\Temp\arduino_cache_901311 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -verbose C:\Users\claus\Documents\Arduino\Windmesser\Windmesser.ino
      Using board 'd1_mini' from platform in folder: C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
      Using core 'esp8266' from platform in folder: C:\Users\claus\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
      Build-Optionen wurden verändert, alles wird neu kompiliert
      Detecting libraries used...
      "C:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/include" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/lwip2/include" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\claus\\AppData\\Local\\Temp\\arduino_build_156623/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\cores\\esp8266" "-IC:\\Users\\claus\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.5.0\\variants\\d1_mini" "C:\\Users\\claus\\AppData\\Local\\Temp\\arduino_build_156623\\sketch\\Windmesser.ino.cpp" -o nul
      Windmesser:30:25: error: common_wifi.h: No such file or directory
       #include <common_wifi.h>
      compilation terminated.
      exit status 1
      WIFI und MQTT Namen sowie Passwörter habe ich bewusst noch nicht eingetragen 🙂
        Dann gebe ich mir mal selber eine Antwort 🙂
        Da ich die Befehle direkt in den Sketch kopiert habe, benötige ich die externen Libraries nicht. Externe Libraries werden in den gleichen Ordner abgelegt wie der Sketch und im Sketch mit include eingebunden.
        Habe die #include für <common_wifi.h>, <Common_mqtt.h>, <esp_pins.h> und <private_wifi.h> mit einen // davor als Kommentar gesetzt. Den Sketch auf meinen ESP geflasht und jetzt habe ich die Values in meinem ioBroker 🙂
        Weiterhin habe ich meine Zugriffsdaten für mein WLAN und MQTT im Sketch eingetragen.
          mwyraz last edited by mwyraz
          Top 😉
          Please enter a longer post. Posts should contain at least 8 character(s).
          Freu mich, dass es geht. Ja, die Libs entfallen, wenn du deren Inhalt reinkopierst kannst die Zeilen rauslöschen.
          Edit: ich versuche mal, meinen Blogpost incl. "Schaltplan" zeitnah fertig zu machen und poste dann den Link hier.
            feli1 last edited by feli1
            ...habe in dem Sketch von @claus1993 vom 9.Okt die includes "common_wifi.h, common_mqtt.h, private_wifi.h und esp_pins.h" auskommentiert, die Wlan und MQTT Login Daten eingetragen und den Sketch erfolgreich geflasht.
            Der Wemos meldet sich erfolgreich in der Fritzbox an, alles scheint ok. Leider wird mein MQTT Adapter im IO Broker nicht grün. Mit dem MQTT Beispiel- Sketch aus dem Arduino IDE wird er dagegen sofort grün.
            Habe im Moment keine Idee wie ich weitermachen könnte.
            Hat jemand einen Vorschlag?
              Wayne1983 @claus1993 last edited by
              @claus1993 Hallo. Vielleicht könntest du mir helfen. Habe alle lt. deiner Beschreibung erledigt.
              Bekomme aber immer folgende Fehlermeldung.
              Danke.
                hugo1215 last edited by
                habe auch das Script von @claus1993 genommen und auch die #include für <common_wifi.h>, <Common_mqtt.h>, <esp_pins.h> und <private_wifi.h> mit einen // auskommentiert.
                Habe meine Wlan daten und MQTT daten eingeben. Im Wlan habe ich diesen auch gefunden nur leider sehe ich diese noch nicht im MQTT im Iobroker.
                Habe ich was übersehen? Sensor ist auch angeschlossen.
                  Sorry das tut mir leid das es nicht funktioniert...bin leider kein Profi was das programmieren betrifft und wurschtele mich auch immer so durch. meist ist es ein Trial and Error...
                  @Wayne1983
                  du hast die Meldung zu dem D2 Pin gesehen? Hast du deine Data Leitung dort angesetzt?
                  Hatte in einem anderen Sketch auch ein Problem und habe dann D2 durch den GPIO Pin ersetzt. Vielleicht hilft das.
                  @hugo1215
                  hast du die Daten korrekt eingegeben? Funktionieren andere MQTT Exports? Hast du auch deine IP und Port Nummer verwendet und nicht die die im Skript steht?
                  Aufgrund eines Rechner Crashs habe ich den Sketch leider nicht mehr sonst würde ich ihn hier posten 😞
                    hugo1215 last edited by hugo1215
                    Hallo @claus1993,
                    also normal funktionieren die Exports. Habe 4 Wemos laufen wo ESP EASY läuft mit meinem Einstellungen.
                    Hatte einen Kleine Fehler gefunden. hehe. Wass aber passiert ist das es sich immer wieder mit meinem WLAN verbinden will das hat er auch macht immer ein Reconnect und somit kommt er nicht zum verbinden mit dem MQTT server und kann dann im weiteren Verlauf nicht die Daten vom Windmesser weiterleiten.
                      @hugo1215
                      sorry dann kann ich leider nicht weiterhelfen. Sollte mir etwas einfallen würde ich mich melden.
                      • premo
                        premo last edited by premo
                        Falls Interesse besteht dann könnte ich mal ein einfaches Ansteuern der Markise anbieten.
                        Bei mir ist ein Eltako WS Windsensor mit Wemos D1 mini im Einsatz.
                        Mit dem Skript wird über MQTT die Windstärke in km/h in IOBroker
                        angezeigt.
                        Der Eltako WS erzeugt pro Umdrehung 2 Impulse, beim W132 wird nur 1 Impuls erzeugt.
                        Dieses muss im Skript noch eingestellt werden.
                        Anbei die Beschreibung mit Skript
                        esp8266-anemometer-master.zip Beschreibung.zip
                        Gerade noch was Intressantes gefunden.
                        https://gist.github.com/micw/098709efc83a9d9ebf16d14cea4ca38e
                          hallo @premo
                          danke das du dein Script zur verfügung stellst. Werde es mal ausprobieren. WO stelle ich die Impulse in deinem Script ein. Ein bisschen erfahrung habe ich aber nicht genug.
                          Denn Link von Github kenne ich schon leider klappt es damit nicht.
                          premo 1 Reply Last reply Reply Quote 0
                            hugo1215 @claus1993 last edited by
                            @claus1993 sagte in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                            @hugo1215
                            Hallo @claus1993,
                            habe den Fehler gefunden. Bei den Board Verwaltung im Arduino Programm muss die Version 2.4.1 installiert sein. Dann klappt es.
                            Bekomme jetzt auch die Daten in Iobroker. Soweit so gut. Kann man die Daten auch schneller Abrufen und nicht nur alle 30 sek??
                            C ? 2 Replies Last reply Reply Quote 0
                              claus1993 @hugo1215 last edited by
                              @hugo1215 freut mich das es jetzt läuft. Was eine Verkürzung der Abfragezeit betrifft meine ich gelesen zu haben das der Skript Vergleichswerte zur Berechnung benötigt. Wenn dem so ist müsste man den Skript und die Berechnung anpassen.
                                @claus1993 hast du einen Tip wo ich schauen kann??
                                • premo
                                  premo @hugo1215 last edited by
                                  @hugo1215 sagte in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                                  In der "myconfig_samples.h"
                                  In der Zeile 16
                                  const float number_reed = 1
                                    Meldb @claus1993 last edited by
                                    @claus1993 Hallo ich habe auch dein Skipt verwendet. Super danke erstmal das du es hier zu verfügung gestellt hat. Jetzt habe ich noch eine Frage weiter oben habt ihr über den Regensensor W174 geschrieben habt ihr das auch an dem Wemo mit dem Skript? Oder wie habt ihr das gemacht?
                                      claus1993 @Meldb last edited by
                                      @Meldb
                                      Jepp der läuft mit einem Wemos D1 Mini.
                                        @claus1993 Hallo ich habe heute mein Sensor W132 bekommen ich bekomme immer den gleichen Temperatur u. Luftfeuchte Wert ist das bei dir auch so?
                                          claus1993 @Meldb last edited by claus1993
                                          @Meldb
                                          Habe den Sensor mal angeklemmt und sehe das sich nur die Werte für den Wind ändern. Bei Temperatur und Humity ist schon weit längeren unverändert und wird bei einem Update auch nicht kurz grün. Kann die leider nicht sagen woran das liegt. Vielleicht gibt es den ein oder anderen Experten der den Code lesen kann und dort einen Fehler findet.
                                            A Former User @hugo1215 last edited by A Former User
                                            @hugo1215 said in Windanzeige mit Ventus W132 & Wemos D1 Mini:
                                            @mwyraz
                                            Vielleicht könnte man den Punkt mit der Version 2.4.1 auf GitHub hinzufügen?
                                            45
                                            9713
