    4. Material Design Widgets: Buttons Widget
    • Scrounger
      Scrounger Developer @skokarl last edited by
      @skokarl
      Was hat denn binding mit html / css zu tun?
      @thomas-heyn
      geht ganz einfach nur mit dem Widget und ohne binding:
      anbei Widget zum importieren:
      [{"tpl":"tplVis-materialdesign-Button-Toggle-vertical","data":{"oid":"0_userdata.0.BadFenster","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","toggleType":"boolean","stateIfNotTrueValue":"on","vibrateOnMobilDevices":"50","iconPosition":"top","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"image":"/vis.0/main/window_closed.png","imageTrue":"/vis.0/main/window_open.png","iconHeight":"80","buttontext":"Bad<br>geschlossen","labelTrue":"Bad<br>offen","readOnly":true},"style":{"left":"421px","top":"263px","width":"146px","height":"150px"},"widgetSet":"materialdesign"}]
        sigi234 Forum Testing Most Active @Scrounger last edited by
        @Scrounger sagte in Material Design Widgets: Buttons Widget:
        Von wo hast du die Bilder?
        Scrounger 2 Replies Last reply Reply Quote 0
        • Scrounger
          Scrounger Developer @sigi234 last edited by
          @sigi234
          Internet 😉 und hab die offene variante bissle modifiziert. Kann ich heute Abend zur Verfügung stellen
          • Scrounger
            Scrounger Developer @sigi234 last edited by Scrounger
            @sigi234
            D 1 Reply Last reply Reply Quote 2
            • Bostil
              Bostil last edited by
              @Scrounger Vielleicht kannst du hier auch helfen: Ich möchte eine Aufgabenliste in meiner VIS hinterlegen, wo man erstmal über dein Materialdesign-Input eine Aufgabe in einen Datenpunkt schreiben kann. Das klappt erstmal problemlos.
              Allerdings würde ich auch nach Wochentagen drei mögliche Stati definieren wollen:
              1. Ausgangswert: blank / nicht selektiert bzw. eben ohne Symbol, da inaktiv
              2. Status: Vorgemerkt (Icon: bell) als Todo für einen bestimmten Wochentag
              3. Status: Erledigt (Icon: check-bold)
              Aktuell kann man nur mit true / false entsprechend zwei Stati anwählen. Hast du eine Idee, ob / wie man dies mit deinem schönen Widget hinbekommen könnte ?
              • Scrounger
                Scrounger Developer @Bostil last edited by Scrounger
                @Bostil
                Erstell einen Datenpunkt in den du per Skript den Pfad zum Bild hinterlegst. Beim Button als Image den Datenpunkt als Binding eintragen -> z.B. {meinDP.Bild}
                Alternativ könntest du das auch mit IconList Widget realisieren, da kann man per json-string quasi allles dynamisch gestalten.
                • Bostil
                  IconList Widget
                  IconListWidget war definitiv DIE Idee - vielen Dank dir!
                    dos1973 @Scrounger last edited by
                    @Scrounger
                    Gibt es die ggfs. Auch als gekippte Fenster?
                    • Bostil
                      Hallo @Scrounger, du siehst deine Widgets werden bei mir für Allerlei "misbraucht" 🙂
                      Der Button-Switch im Datum soll dafür dienen, um eine Objekt-ID zu steuern, über die dann die Sichtbarkeit eines Kalender auf dem Homescreen gesteuert werden soll. Leider verändert sich der Button nach dem Betätigen etwas, wo ich dich gerne fragen würde, ob du eine Idee hast, wie der Button einfach so bleiben kann, wie er auch im "ungedrückten" Zustand erscheint - siehe Beispiele unterhalb:
                      Vor Betätigen der Schaltfläche:
                      Nach Betätigen der Schaltfläche:
                      Konfiguration Button:
                      Scrounger 1 Reply Last reply Reply Quote 1
                      • Scrounger
                        @Bostil
                        Bei Farbe alle drei gleiche eintragen
                        • Bostil
                          Oh man ... also manchmal ...
                          Vielen Dank (mal wieder) @Scrounger !!!
                          • Scrounger
                            @Bostil
                            Kein Problem helfe gerne. Und genau dafur hab ich die ganzen Themen erstellt
                            • Negalein
                              @Scrounger
                              Ich habe ein Problem mit dem Button State Widget.
                              Über Binding stelle ich die Farbe des aktiven Button dar.
                              Bei 2 geht es, bei den restlichen nicht.
                              Binding hab ich überprüft. Müsste passen.
                              Kannst du bitte mal drüberschaun?
                              [{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Error","buttontext":" Error ({v:logparser.0.filters.Error.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Error\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnError","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"237px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Error\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Homematic","buttontext":" Homematic ({v:logparser.0.filters.Homematic.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Homematic\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnHomematic","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"279px","z-index":"50","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Eingangstuerhuawei\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Laura-Volume","buttontext":" Laura-Volume ({v:logparser.0.filters.Laura-Volume.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Laura-Volume\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"365px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Info\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Alexa","buttontext":" Alexa ({v:logparser.0.filters.Alexa.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Alexa\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"322px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Info\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Debug","buttontext":" Debug ({v:logparser.0.filters.Debug.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Debug\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"151px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Info\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Warn","buttontext":" Warn ({v:logparser.0.filters.Warn.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Warn\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnWarn","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"194px","z-index":"50","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Warn\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"}]
                              Bostil Scrounger 3 Replies Last reply Reply Quote 0
                              • Bostil
                                Bostil @Negalein last edited by
                                @Negalein Dein Widget sieht interessant aus. Interessehalber: Wie sieht die Programmierung dahinter aus? Kann mir auch gut vorstellen Infos kategorisiert auszugeben. Wäre wirklich mal interessant, wie du es gelöst hast 🙂
                                  sigi234 Forum Testing Most Active @Bostil last edited by
                                  @Bostil
                                  @Negalein
                                  Ich habe es kombiniert mit Button und Icon List Widgets.
                                  • Negalein
                                    Negalein Global Moderator @sigi234 last edited by
                                    @sigi234 sagte in Material Design Widgets: Buttons Widget:
                                    das Icon-List-Widget ist nicht so mein Fall.
                                    Die Buttons alleine passen zu meinem Layout.
                                    @Bostil sagte in Material Design Widgets: Buttons Widget:
                                    die Daten kommen vom Log-Parser Adapter von Mic.
                                    • Scrounger
                                      Scrounger Developer @Negalein last edited by
                                      @Negalein
                                      Also auf dem Screenshot sieht es doch genau so aus, wie du es beschreibst? Versteh nicht wo der Fehler ist.
                                      • Negalein
                                        Negalein Global Moderator @Scrounger last edited by
                                        Die Buttons Warn und Error werden grau, wenn sie aktiv sind.
                                        Die anderen bleiben schwarz.
                                        • Glasfaser
                                          Glasfaser @Negalein last edited by Glasfaser
                                          @Negalein
                                          Widget habe ich angepasst :
                                          [{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Warn","buttontext":" Warn ({v:logparser.0.filters.Warn.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Warn\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnWarn","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"194px","z-index":"50","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Warn\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Debug","buttontext":" Debug ({v:logparser.0.filters.Debug.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Debug\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"151px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Debug\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Alexa","buttontext":" Alexa ({v:logparser.0.filters.Alexa.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Alexa\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"322px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Alexa\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Laura-Volume","buttontext":" Laura-Volume ({v:logparser.0.filters.Laura-Volume.jsonCount;v})","image":"alert-circle-outline","labelWidth":"","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Laura-Volume\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnInfo","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"365px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Laura-Volume\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Homematic","buttontext":" Homematic ({v:logparser.0.filters.Homematic.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Homematic\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnHomematic","autoLockAfter":"10","lockFilterGrayscale":"30","lockIconSize":"-4"},"style":{"left":"26px","top":"279px","z-index":"50","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Homematic\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"},{"tpl":"tplVis-materialdesign-Button-State","data":{"oid":"logparser.0.visualization.table0.selection","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"text","vibrateOnMobilDevices":"50","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/Log-Mic-2/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"Error","buttontext":" Error ({v:logparser.0.filters.Error.jsonCount;v})","image":"alert-circle-outline","labelWidth":"0","colorPress":"{b:logparser.0.visualization.table0.selection;b==\"Error\" ? \"#ffd71a\" : \"#8f8f8f\"}","class":"leftBarBtn","name":"btnError","autoLockAfter":"10","lockFilterGrayscale":"30"},"style":{"left":"26px","top":"237px","z-index":"49","width":"180px","height":"32px","background-color":"{b:logparser.0.visualization.table0.selection;b==\"Error\" ? \"#4d4d4d\" : \"#2e2e2e\"}"},"widgetSet":"materialdesign"}]
                                          • Negalein
                                            Negalein Global Moderator @Glasfaser last edited by
                                            @Glasfaser sagte in Material Design Widgets: Buttons Widget:
                                            1000x hingeschaut, aber CSS Background nie aufgemacht! 😖
                                            Glasfaser Mic 2 Replies Last reply Reply Quote 1
                                            vis
                                            38
                                            157
                                            25243
