    4. Beta Test js-controller 3.0.x auf GitHub
    • Homer.J.
      Homer.J. @apollon77 last edited by Homer.J.
      @apollon77 Morgen bin hier auch schon fleißig am Testen bei mir ist bei der 3.0.6 er Version der TR-064 Adapter rot, hat bei der 3.0.5 noch funktioniert hier mal der Auszug.
      tr-064.0 2020-04-12 07:58:13.397 error at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31)
      tr-064.0 2020-04-12 07:58:13.397 error at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
      tr-064.0 2020-04-12 07:58:13.397 error at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
      tr-064.0 2020-04-12 07:58:13.397 error at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
      tr-064.0 2020-04-12 07:58:13.397 error at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
      tr-064.0 2020-04-12 07:58:13.397 error at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26)
      tr-064.0 2020-04-12 07:58:13.397 error at Parser.emit (events.js:198:13)
      tr-064.0 2020-04-12 07:58:13.397 error at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18)
      tr-064.0 2020-04-12 07:58:13.397 error at xmlParser.parseString (/opt/iobroker/node_modules/iobroker.tr-064/lib/calllist.js:53:67)
      tr-064.0 2020-04-12 07:58:13.397 error at getHttpData (/opt/iobroker/node_modules/iobroker.tr-064/lib/calllist.js:272:20)
      tr-064.0 2020-04-12 07:58:13.397 error (22626) TypeError: systemData.save is not a function
      tr-064.0 2020-04-12 07:58:13.396 error (22626) uncaught exception: systemData.save is not a function
      tr-064.0 2020-04-12 08:00:27.002 error (25387) TypeError: systemData.save is not a function at getHttpData (/opt/iobroker/node_modules/iobroker.tr-064/lib/calllist.js:272:20) at xmlParser.parseString (/opt/iobroker/node_modules/iob
      tr-064.0 2020-04-12 08:00:27.001 error (25387) uncaught exception: systemData.save is not a function
      K H 2 Replies Last reply Reply Quote 0
        Kueppert @Homer.J. last edited by
        @Homer-J Hinweis von mir an der Stelle: den Adapter nutze ich auch, läuft bei mir unauffällig auch nach dem Update weiter.
        Homer.J. 1 Reply Last reply Reply Quote 0
        • Homer.J.
          Homer.J. @Kueppert last edited by
          @Kueppert Morgen läuft bei mir auf der selben Hartware wie bei dir. Fixer hab ich auch schon drüber laufen lassen.
            @Homer-J ich hab die Version 3.1.4 drauf. Welche nutzt du?
            • Homer.J.
              Homer.J. @Kueppert last edited by Homer.J.
              @Kueppert hab ich auch am laufen.
              Pushover ist zwar grün geht aber auch nicht mehr.
                @Homer-J komisch...ohne Apollon vorgreifen zu wollen, würde ich versuchen - da Testing - den Adapter einfach neu zu installieren (vorher komplett löschen). Oder du wartest einfach 😉 wirst bestimmt vorher nen Backup deiner Prod gemacht haben?! 😄
                • Homer.J.
                  @Kueppert jab wird jeden Tag gemacht. 😊
                    @Homer-J dann teste doch einfach mal, das Teil neu zu installieren. Wenn schon dabei bist, mach doch vorher direkt ein Update von NPM - und die neue JS-Controller Version 3.0.6 drauf (Vielleicht vorher, um Seiteneffekte auszuschließen, mal den TR-064 neu installieren und testen.)
                    Ich habe es in folgender Reihenfolge gemacht:
                    jsController:
                    cd /opt/iobroker
                    iobroker stop
                    npm install ioBroker/ioBroker.js-controller
                    NPM-Update:
                    npm install -g npm
                    node Update:
                    curl -sL https://deb.nodesource.com/setup_13.x | bash -
                    apt-get install -y nodejs
                    • Homer.J.
                      @Kueppert Adapter komplett gelöscht und neu installiert trotzdem bleibt er rot.
                      Auf die 13 Version kann ich noch nicht gehen dann laufen andere Adapter bei mir nicht mehr wie z.B. Yahka.
                      Ich kann sie ja nochmal Testweise installieren und schauen ober er dann tut.
                      So hab mal die 13 Version installiert jetzt läuft komischerweise der Yahka mit der 3.0.6 Version aber der TR-064 bleibt der gleiche Fehler und ist rot.
                        HelmutS @Homer.J. last edited by
                        @Homer-J
                        Das Problem mit dem TR-064 habe ich jetzt auch, nach ausschalten der Anruflisten läuft er wieder.
                        @apollon77
                        SONOS läuft
                        • Homer.J.
                          Homer.J. @HelmutS last edited by
                          @HelmutS kann ich bestätigen hab sie jetzt auch mal raus genommen und er läuft wieder.
                            Hm,
                            ich hab beim TR-064 die Anruflisten drin - ohne Fehlermeldung 🙂
                            • Dr. Bakterius
                              Dr. Bakterius Most Active last edited by
                              Ich habe den 3.0.6 installiert und dabei auch gleich node.js auf v12.16.2 hochgezogen. Danach hatte ich zwei Probleme:
                              • Der rflink-Adapter konnte keinen Serial-Port finden. Auch eine Neuinstallation des Adapters hat nicht geholfen. Dieses Problem konnte ich dann durch folgenden Befehl im iobroker-Verzeichnis lösen (hat halt dann rund 15 Minuten gedauert alle Adapter neu zu installieren):
                              node reinstall.js
                              • Pushover v1.2.3 funktioniert nicht. Die alte v.1.1.1 hingegen schon. Folgender Fehler im Log beim Versenden einer Nachricht (nicht beim Adapterstart):
                              2020-04-12 11:32:47.320 - error: pushover.0 (9266) uncaught exception: application token is invalid
                              2020-04-12 11:32:47.322 - error: pushover.0 (9266) Error: application token is invalid
                              at Pushover.errors (/opt/iobroker/node_modules/pushover-notifications/lib/pushover.js:146:13)
                              at IncomingMessage. (/opt/iobroker/node_modules/pushover-notifications/lib/pushover.js:250:12)
                              at IncomingMessage.emit (events.js:322:22)
                              at endReadableNT (_stream_readable.js:1187:12)
                              at processTicksAndRejections (internal/process/task_queues.js:84:21)
                              2020-04-12 11:32:47.829 - info: pushover.0 (9266) terminating
                              2020-04-12 11:32:47.830 - info: pushover.0 (9266) Terminated (NO_ERROR): Without reason
                              Ob es am Controller oder an node.js liegt? Vermutlich an node.js (in Verbindung mit den Adaptern).
                              foxriver76 apollon77 2 Replies Last reply Reply Quote 0
                                sigi234 Forum Testing Most Active @apollon77 last edited by sigi234
                                @apollon77
                                @Homer-J
                                Ok, ist bei mir auch beim tr-064 und der Adapter springt von Rot auf Grün und zurück.
                                tr-064.0	2020-04-12 11:44:04.779	error	at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:323:31)
                                tr-064.0	2020-04-12 11:44:04.779	error	at SAXParser.write (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\sax\lib\sax.js:1436:13)
                                tr-064.0	2020-04-12 11:44:04.779	error	at closeTag (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\sax\lib\sax.js:889:7)
                                tr-064.0	2020-04-12 11:44:04.779	error	at emitNode (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\sax\lib\sax.js:629:5)
                                tr-064.0	2020-04-12 11:44:04.779	error	at emit (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\sax\lib\sax.js:624:35)
                                tr-064.0	2020-04-12 11:44:04.779	error	at SAXParser.onclosetag (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:262:26)
                                tr-064.0	2020-04-12 11:44:04.779	error	at Parser.emit (events.js:198:13)
                                tr-064.0	2020-04-12 11:44:04.779	error	at Parser.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\node_modules\xml2js\lib\parser.js:304:18)
                                tr-064.0	2020-04-12 11:44:04.779	error	at xmlParser.parseString (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\lib\calllist.js:53:67)
                                tr-064.0	2020-04-12 11:44:04.779	error	at getHttpData (C:\Program Files\iobroker\Test\node_modules\iobroker.tr-064\lib\calllist.js:272:20)
                                tr-064.0	2020-04-12 11:44:04.779	error	(4280) TypeError: systemData.save is not a function
                                tr-064.0	2020-04-12 11:44:04.778	error	(4280) uncaught exception: systemData.save is not a function
                                • foxriver76
                                  foxriver76 Developer @Dr. Bakterius last edited by
                                  @Dr-Bakterius pushover brauchst du die Version von GitHub 1.2.4
                                  Dr. Bakterius Homer.J. 2 Replies Last reply Reply Quote 0
                                    deta Most Active last edited by
                                    hab gerade auch das Update auf 3.0 gemacht, funktioniert zwar alles, habe dennoch ein paar Fehler bei der Install gehabt, vielleicht könnt Ihr mir da bitte mal helfen, diese zu beseitigen.
                                    Hier das Install..
                                    root@rock:/opt/iobroker# npm install ioBroker/ioBroker.js-controller
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    > iobroker.js-controller@3.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                    > node lib/preinstallCheck.js
                                    NPM version: 6.14.4
                                    > sharp@0.24.1 install /opt/iobroker/node_modules/sharp
                                    > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                                    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.0
                                    info sharp Attempting to build from source via node-gyp but this may fail due to the above error
                                    info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                                    make: Entering directory '/opt/iobroker/node_modules/sharp/build'
                                      TOUCH Release/obj.target/libvips-cpp.stamp
                                      CXX(target) Release/obj.target/sharp/src/common.o
                                    In file included from ../src/common.cc:25:0:
                                    /usr/include/vips/vips8:35:25: fatal error: glib-object.h: No such file or directory
                                     #include <glib-object.h>
                                    compilation terminated.
                                    sharp.target.mk:127: recipe for target 'Release/obj.target/sharp/src/common.o' failed
                                    make: *** [Release/obj.target/sharp/src/common.o] Error 1
                                    make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2
                                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                    gyp ERR! System Linux 4.4.192-rockchip64
                                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /opt/iobroker/node_modules/sharp
                                    gyp ERR! node -v v10.20.0
                                    gyp ERR! node-gyp -v v5.1.0
                                    gyp ERR! not ok
                                    > iobroker.js-controller@3.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                    > node iobroker.js setup first
                                    object system.certificates updated
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@abandonware/.noble.DELETE/package.json'
                                    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unix-dgram/package.json'
                                    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.24.1 (node_modules/sharp):
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.24.1 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)`
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                    + iobroker.js-controller@3.0.6
                                    updated 1 package and audited 31342 packages in 145.011s
                                    16 packages are looking for funding
                                      run `npm fund` for details
                                    found 171 vulnerabilities (167 low, 1 moderate, 3 high)
                                      run `npm audit fix` to fix them, or `npm audit` for details
                                    Das bekomme ich nicht in Griff..
                                    Danke schon mal
                                    cu Deta
                                    mikeal created this issue in request/request
                                    open Request’s Past, Present and Future #3142
                                    • Dr. Bakterius
                                      Dr. Bakterius Most Active @foxriver76 last edited by
                                      @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                      Danke, schon gemerkt. 😊
                                      • Homer.J.
                                        Homer.J. @foxriver76 last edited by
                                        @foxriver76 👍 läuft wieder.
                                        • foxriver76
                                          tr064 schaue ich dann an ob Controller was kaputt gemacht hat oder tr-064 was net passt.
                                          • AlCalzone
                                            AlCalzone Developer @deta last edited by
                                            @deta sagte in Beta Test js-controller 3.0.x auf GitHub:
                                            updated 1 package
                                            Alles gut!
                                            js-controller
                                            39
                                            416
                                            68569
