    4. Zigbee Adapter Failed to start
    UNSOLVED Zigbee Adapter Failed to start
    • hg6806
      hg6806 Most Active last edited by
      ich hänge mich mal hier dran, denn mein Zigbee läuft an einem USB-Hub auch nur ganz selten.
      Hier das Debug-Log.
      Vielleicht kann ja jemand ein paar Tipps geben.
      zigbee.0	2020-04-07 20:32:06.553	error	(8457) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
      zigbee.0	2020-04-07 20:32:06.552	error	(8457) Failed to start Zigbee
      zigbee.0	2020-04-07 20:32:06.360	debug	(8457) Starting zigbee-herdsman...
      zigbee.0	2020-04-07 20:32:06.360	info	(8457) Starting Zigbee...
      zigbee.0	2020-04-07 20:32:06.359	info	(8457) Try to reconnect. 1 attempts left
      zigbee.0	2020-04-07 20:31:56.356	error	(8457) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
      zigbee.0	2020-04-07 20:31:56.355	error	(8457) Failed to start Zigbee
      zigbee.0	2020-04-07 20:31:49.037	debug	(8457) Starting zigbee-herdsman...
      zigbee.0	2020-04-07 20:31:49.036	info	(8457) Starting Zigbee...
      zigbee.0	2020-04-07 20:31:48.999	info	(8457) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
      zigbee.0	2020-04-07 20:31:42.743	info	(7714) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      zigbee.0	2020-04-07 20:31:42.741	info	(7714) terminating
      zigbee.0	2020-04-07 20:31:42.740	error	at process._tickCallback (internal/process/next_tick.js:68:7))
      zigbee.0	2020-04-07 20:31:42.740	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
      zigbee.0	2020-04-07 20:31:42.740	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
      zigbee.0	2020-04-07 20:31:42.740	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
      zigbee.0	2020-04-07 20:31:42.740	error	at new Promise (<anonymous>)
      zigbee.0	2020-04-07 20:31:42.740	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
      zigbee.0	2020-04-07 20:31:42.740	error	at Generator.next (<anonymous>)
      zigbee.0	2020-04-07 20:31:42.740	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
      zigbee.0	2020-04-07 20:31:42.740	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
      zigbee.0	2020-04-07 20:31:42.740	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
      zigbee.0	2020-04-07 20:31:42.740	error	(7714) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2020-04-07 20:31:42.730	info	(7714) Zigbee: disabling joining new devices.
      zigbee.0	2020-04-07 20:31:42.724	info	(7714) cleaned everything up...
      zigbee.0	2020-04-07 20:31:42.721	info	(7714) Got terminate signal TERMINATE_YOURSELF
        arteck Developer Most Active @hg6806 last edited by
        @hg6806 sagte in Zigbee Adapter Failed to start:
        • hg6806
          OK, was heißt das? Er kann den Stick nicht finden?
            @hg6806 der seriall port ist besetzt.. starte mal die kiste neu .. was läuft da sonst noch druff?
            • hg6806
              hg6806 Most Active @arteck last edited by
              @arteck
              COM Ports? Ich kenne das unter Windows, diese sind oft blockiert, kann man aber irgdndwie "freischaufeln".
              Habe den Pi4 mal neu gestartet, wirft aber den gleichen Fehler aus.
              An dem Pi hängen 2 IR-Smartmeter, eine USB3-SSD und ein 4-fach-USB-Hub woran dann ein BLE5.0 Stick und der CC2531 Zigbee Stick dran ist.
              arteck 1 Reply Last reply Reply Quote 1
                arteck Developer Most Active @hg6806 last edited by arteck
                BLE5.0 Stick
                der blockiert den
                aber zeigmal
                ls -l /dev/serial/by-id
                • hg6806
                  Here it is:
                  root@raspberrypi:~# ls -l /dev/serial/by-id
                  insgesamt 0
                  lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
                  lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridg            e_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
                  lrwxrwxrwx 1 root root 13 Apr  9 10:53 usb-Texas_Instruments_TI_CC2531_USB_CDC__            _0X00124B00194AD7E3-if00 -> ../../ttyACM0
                  root@raspberrypi:~#
                    @hg6806 wo ist der BLE??
                    • hg6806
                      Das frage ich mich auch. Zumindest ist der BLE Adapter grün und zwei BLE Sensoren liefern aktuelle Daten.
                      • hg6806
                        Bin leider noch nicht weitergekommen.
                        Folgendes habe ich probiert:
                        root@raspberrypi:~# hciconfig
                        hci1:   Type: Primary  Bus: UART
                                BD Address: DC:A6:32:0A:73:B3  ACL MTU: 1021:8  SCO MTU: 64:1
                                UP RUNNING
                                RX bytes:8525625 acl:0 sco:0 events:234932 errors:0
                                TX bytes:1374 acl:0 sco:0 commands:59 errors:0
                        hci0:   Type: Primary  Bus: USB
                                BD Address: 00:1A:7D:DA:71:11  ACL MTU: 679:9  SCO MTU: 48:16
                                DOWN
                                RX bytes:1148 acl:0 sco:0 events:60 errors:0
                                TX bytes:736 acl:0 sco:0 commands:60 errors:0
                        root@raspberrypi:~# lsusb
                        Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s bridge
                        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                        Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                        Bus 001 Device 004: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
                        Bus 001 Device 007: ID 0451:16a8 Texas Instruments, Inc.
                        Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
                        Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. Hub
                        Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                        root@raspberrypi:~# bluetoothctl
                        Agent registered
                        [bluetooth]# scan on
                        Discovery started
                        [CHG] Controller DC:A6:32:0A:73:B3 Discovering: yes
                        [NEW] Device E7:2E:00:D3:20:42 LYWSD02
                        Dann den BLE Stick entfernt, BLE Adapter gestoppt und den Pi neu gestartet.
                        Zigbee bleibt gelb, Debug-Log:
                        zigbee.0	2020-04-12 10:12:53.178	error	(2063) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/zn
                        zigbee.0	2020-04-12 10:12:53.176	error	(2063) Failed to start Zigbee
                        zigbee.0	2020-04-12 10:12:52.979	debug	(2063) Starting zigbee-herdsman...
                        zigbee.0	2020-04-12 10:12:52.979	info	(2063) Starting Zigbee...
                        zigbee.0	2020-04-12 10:12:52.978	info	(2063) Try to reconnect. 1 attempts left
                        zigbee.0	2020-04-12 10:12:42.977	error	(2063) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackA
                        zigbee.0	2020-04-12 10:12:42.974	error	(2063) Failed to start Zigbee
                        zigbee.0	2020-04-12 10:12:35.663	debug	(2063) Starting zigbee-herdsman...
                        zigbee.0	2020-04-12 10:12:35.661	info	(2063) Starting Zigbee...
                        zigbee.0	2020-04-12 10:12:35.627	info	(2063) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
                        zigbee.0	2020-04-12 10:12:13.440	info	(1823) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        zigbee.0	2020-04-12 10:12:13.439	info	(1823) terminating
                        zigbee.0	2020-04-12 10:12:13.438	error	at process._tickCallback (internal/process/next_tick.js:68:7))
                        zigbee.0	2020-04-12 10:12:13.438	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:297:33)
                        zigbee.0	2020-04-12 10:12:13.438	error	at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:169:16)
                        zigbee.0	2020-04-12 10:12:13.438	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:4:12)
                        zigbee.0	2020-04-12 10:12:13.438	error	at new Promise (<anonymous>)
                        zigbee.0	2020-04-12 10:12:13.438	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:8:71
                        zigbee.0	2020-04-12 10:12:13.438	error	at Generator.next (<anonymous>)
                        zigbee.0	2020-04-12 10:12:13.438	error	at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:173:49)
                        zigbee.0	2020-04-12 10:12:13.438	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:15)
                        zigbee.0	2020-04-12 10:12:13.438	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:64:55)
                        zigbee.0	2020-04-12 10:12:13.438	error	(1823) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                        zigbee.0	2020-04-12 10:12:13.434	info	(1823) Zigbee: disabling joining new devices.
                        zigbee.0	2020-04-12 10:12:13.417	info	(1823) cleaned everything up...
                        zigbee.0	2020-04-12 10:12:13.415	info	(1823) Got terminate signal TERMINATE_YOURSELF
                        Hier noch weitere Konsolenbefehle:
                        insgesamt 0
                        lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAA-if00-port0 -> ../../ttyUSB1
                        lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01304FAE-if00-port0 -> ../../ttyUSB0
                        lrwxrwxrwx 1 root root 13 Apr 12 10:08 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194AD7E3-if00 -> ../../ttyACM0
                        Bus 001 Device 005: ID 0451:16a8 Texas Instruments, Inc.
                        root@raspberrypi:~#
                        Was kann ich noch tun?
                        • mickym
                          mickym Most Active last edited by mickym
                          Ich glaube - dass wir das gleiche Problem haben: https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled
                          Allerdings passiert es nicht immer, wenn auch mit der neuen Version gefühlt häufiger.
                          Bei mir läuft der Adapter jedoch IMMER, wenn ich den Stick im laufenden Betrieb einfach abziehe, dann wieder anstecke und NUR den Adapter neu starte.
                            toki1973 last edited by
                            @mickym Danke für deine Rückmeldung im anderen Thread. Inzwischen ist der Status wieder grün. Allerdings bekomme ich keine Werte mehr von den Sensoren.
                            • mickym
                              mickym Most Active @toki1973 last edited by mickym
                              @toki1973 Hmm - bei mir funktionieren die Sensoren, es ist alles Bestens. Ist denn bei Dir der Adapter alleine auf grün gegangen oder hast Du wie ich mal den Stick abgezogen und wieder angesteckt und dann den Adapter neu gestartet?
                              • hg6806
                                @mickym So läuft es! Danke!
                                Also immer erst Stick neu anstecken und Adapter neu starten. Dann wird es grün.
                                Auch zusammen mit dem BLE.
                                Wenn man aber den Pi neu startet bleibt Zigbee gelb.
                                Ich habe das mit BLE mal ausprobiert, der BRAUCHT unbedingt ein Pi Neustart.
                                Die Frage ist wie kann man das fixen?
                                Kann man den Zigbee Stick oder den ganzen USB Bus resetten?
                                • hg6806
                                  hg6806 Most Active last edited by hg6806
                                  Hier gibt es wohl die Möglichkeit:
                                  Eine Datei usbreset erstellen und dann aufrufen
                                  Link Text
                                  Hab's noch nicht ausprobiert und hoffe es heute Abend mal zu schaffen.
                                  • mickym
                                    mickym Most Active @hg6806 last edited by mickym
                                    @hg6806 said in Zigbee Adapter Failed to start:
                                    Meines Erachtens wird der Zigbee-Stick ja beim Adapterstart resettet und das ist aber das Problem. Wenn ich die Maschine neu boote wird der Stick resettet und die LED leuchtet. Startet der Adapter geht die LED auf dem Stick aus und dann scheint es bei mir Glücksache zu sein, ob der Adapter den wieder findet oder einen Time-Out bekommt. Jedenfalls geht die LED im Fehlerfall nicht mehr an, bis ich den Adapter physisch neu verbinde.
                                    • hg6806
                                      Ja, so ist es wohl.
                                      Habe mal usbreset nach der Anleitung erstellt und ausgeführt.
                                      Bus 002 Device 002: ID 174c:5136 ASMedia Technology Inc. ASM1053 SATA 3Gb/s brid        ge
                                      Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (        HCI mode)
                                      root@raspberrypi:~# usbreset /dev/bus/usb/001/007
                                      Resetting USB device /dev/bus/usb/001/007
                                      Reset successful
                                      Stick wurde resettet aber zeigt nach Adapter-Neustart doch noch immer gelb an.
                                        Nach entfernen des USB Sticks und Neustart der VM auf dem NUC habe ich zumindest wieder die Instanz grün. Aber die Aktualität der Sensoren wurde nur beim Neustart aktualisiert.
                                        @arteck Wie kann ich denn den Fehler eingrenzen?
                                        Ein direktes ansprechen der Adapter über die Erweiterten Einstellungen hat auch keine Antwort von einem Sensor gebracht.
                                        • mickym
                                          @toki1973
                                          Nicht die VM neu starten. Nur Stick rausziehen und wieder rein und die Adapterinstanz Neustarten, nicht die ganze Maschine
                                          • nerd68
                                            nerd68 last edited by nerd68
                                            ich stoß mal ins gleiche Horn.
                                            • ich habe meinen cc2531 auf die aktuelle Firmware geflasht.
                                            • Neustart, Adapter gelb.
                                            • Adapter auf 1.1.0 geupdated.
                                            • selber Fehler, Adpater bleibt gelb.
                                            • Adapter neu installiert, selber Fehler Adapter bleibt gelb.
                                            Z-Stack ist sauber geflasht, wir und Serial Belegung zeigt:
                                            drwxr-xr-x 2 root root 60 Apr 13 19:05 .
                                            drwxr-xr-x 4 root root 80 Apr 13 19:05 ..
                                            lrwxrwxrwx 1 root root 13 Apr 13 19:05 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019387353-if00 -> ../../ttyACM0
                                            • keine weiteren USB Geräte angeschlossen, kann also kein Konflikt sein, dass der Port nicht frei ist.
                                            Fehlercode:
                                            zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                                            zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                                            zigbee.0	2020-04-13 19:05:48.110	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                                            zigbee.0	2020-04-13 19:05:48.110	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                                            zigbee.0	2020-04-13 19:05:48.110	error	at new Promise (<anonymous>)
                                            zigbee.0	2020-04-13 19:05:48.110	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                                            zigbee.0	2020-04-13 19:05:48.110	error	at Generator.next (<anonymous>)
                                            zigbee.0	2020-04-13 19:05:48.110	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                                            zigbee.0	2020-04-13 19:05:48.110	error	(2581) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                            zigbee.0	2020-04-13 19:05:48.109	error	(2581) Failed to start Zigbee
                                            zigbee.0	2020-04-13 19:05:47.714	info	(2581) Starting Zigbee...
                                            zigbee.0	2020-04-13 19:05:47.711	info	(2581) Try to reconnect. 1 attempts left
                                            zigbee.0	2020-04-13 19:05:37.707	error	at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:5:58)
                                            zigbee.0	2020-04-13 19:05:37.707	error	at Generator.next (<anonymous>)
                                            zigbee.0	2020-04-13 19:05:37.707	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:246:27)
                                            zigbee.0	2020-04-13 19:05:37.707	error	(2581) Error: SREQ '--> SYS - osalNvRead - {"id":3840,"offset":0,"len":1,"value":{"type":"Buffer","data":[85]}}' failed with status '2' (expected '0')
                                            zigbee.0	2020-04-13 19:05:37.705	error	(2581) Failed to start Zigbee
                                            zigbee.0	2020-04-13 19:05:35.981	info	(2581) Starting Zigbee...
                                            zigbee.0	2020-04-13 19:05:35.941	info	(2581) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.2
                                            BTW lief vorher komplett und reibungslos.
                                            Das mit dem rein raus und Instanz Neustart hat nichts gebracht.
                                            Vielleicht hat jemand noch einen Tipp.
                                            VG,
                                            Didier
                                            Ubuntu 18.04 LTS
                                            NUC Celeron 8GB, 500GB SSD
                                            Node.js v12.16.2
                                            NPM v6.14.4
                                            zigbee adapter cc2531
                                            10
                                            48
                                            4537
