    4. Beta Test js-controller 3.0.x auf GitHub
      deta Most Active last edited by
      hab gerade auch das Update auf 3.0 gemacht, funktioniert zwar alles, habe dennoch ein paar Fehler bei der Install gehabt, vielleicht könnt Ihr mir da bitte mal helfen, diese zu beseitigen.
      Hier das Install..
      root@rock:/opt/iobroker# npm install ioBroker/ioBroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      > iobroker.js-controller@3.0.6 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.4
      > sharp@0.24.1 install /opt/iobroker/node_modules/sharp
      > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
      ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.0
      info sharp Attempting to build from source via node-gyp but this may fail due to the above error
      info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
      make: Entering directory '/opt/iobroker/node_modules/sharp/build'
        TOUCH Release/obj.target/libvips-cpp.stamp
        CXX(target) Release/obj.target/sharp/src/common.o
      In file included from ../src/common.cc:25:0:
      /usr/include/vips/vips8:35:25: fatal error: glib-object.h: No such file or directory
       #include <glib-object.h>
      compilation terminated.
      sharp.target.mk:127: recipe for target 'Release/obj.target/sharp/src/common.o' failed
      make: *** [Release/obj.target/sharp/src/common.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/sharp/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.4.192-rockchip64
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/sharp
      gyp ERR! node -v v10.20.0
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      > iobroker.js-controller@3.0.6 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      object system.certificates updated
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/@abandonware/.noble.DELETE/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/unix-dgram/package.json'
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.24.1 (node_modules/sharp):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.24.1 install: `(node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      + iobroker.js-controller@3.0.6
      updated 1 package and audited 31342 packages in 145.011s
      16 packages are looking for funding
        run `npm fund` for details
      found 171 vulnerabilities (167 low, 1 moderate, 3 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      Das bekomme ich nicht in Griff..
      Danke schon mal
      cu Deta
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      • Dr. Bakterius
        Dr. Bakterius Most Active @foxriver76 last edited by
        @foxriver76 sagte in Beta Test js-controller 3.0.x auf GitHub:
        @Dr-Bakterius pushover brauchst du die Version von GitHub 1.2.4
        Danke, schon gemerkt. 😊
        • Homer.J.
          Homer.J. @foxriver76 last edited by
          @foxriver76 👍 läuft wieder.
          • foxriver76
            tr064 schaue ich dann an ob Controller was kaputt gemacht hat oder tr-064 was net passt.
            • AlCalzone
              AlCalzone Developer @deta last edited by
              @deta sagte in Beta Test js-controller 3.0.x auf GitHub:
              updated 1 package
              Alles gut!
              • BBTown
                BBTown last edited by BBTown
                Sodele, ich habe die v3.0.6 auch einmal zusammen mit node.js v12.16.2 installiert.
                Die Installation verlief fehlerfrei, alle Adapter sind grün! 👍
                In den Logs habe ich zum Einen die hier bereits erwähnte Warnung
                adapter.objects.getObjectView is deprecated ...
                Bei mir kommen diese wiederkehrend vom iot.0 und vom web.0 Adapter sowie einmalig vom admin.0
                Vom broadlink2.0 Adapter erhalte ich wiederholt die Warnung:
                State value to set is invalid for broadlink2.0.RMproWohnzimmer.Temperature: The state contains the forbidden properties user!
                Beim Start des iot.0 Adapter kommen dann noch diese Meldungen:
                iot.0	2020-04-12 12:29:17.324	warn	(2413) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                iot.0	2020-04-12 12:29:17.281	warn	(2413) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                iot.0	2020-04-12 12:29:17.143	warn	(2413) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                iot.0	2020-04-12 12:29:16.779	warn	(2413) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                iot.0	2020-04-12 12:29:16.771	warn	the module (for instance, using `npm rebuild` or `npm install`).
                iot.0	2020-04-12 12:29:16.771	warn	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                iot.0	2020-04-12 12:29:16.771	warn	NODE_MODULE_VERSION 64. This version of Node.js requires
                iot.0	2020-04-12 12:29:16.771	warn	was compiled against a different Node.js version using
                iot.0	2020-04-12 12:29:16.771	warn	(2413) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                Ach ja, schöne Ostern an alle 😉
                apollon77 Dr. Bakterius 2 Replies Last reply Reply Quote 0
                  deta Most Active @AlCalzone last edited by
                  @AlCalzone Und die Fehler? mit dem RR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.0
                  Bekomme ich nicht in Griff...
                  Welches ist eigentlich jetzt die aktuelle richtige lauffähige Version vom tr-064 Adapter? Link?
                  Der Spinnt bei mir noch.
                  Und Radar2 bringt im Log Fehler jetzt.
                  AlCalzone apollon77 2 Replies Last reply Reply Quote 0
                  • AlCalzone
                    Für welchen Adapter wird das denn benötigt? Der Controller braucht die nicht, deshalb auch die Erfolgsmeldung am Ende. Hat also mit JS-Controller 3.x nichts zu tun.
                      @AlCalzone Weis ich leider nicht, der Fehler kommt fast bei jeden Update von Adaptern.
                      • AlCalzone
                        @deta Einen Hinweis könnte folgender Befehl bieten:
                        cd /opt/iobroker
                        npm ls sharp
                          ok das kommt
                          iobroker.inst@2.0.2 /opt/iobroker
                          └─┬ iobroker.iot@1.4.2
                            └── UNMET OPTIONAL DEPENDENCY sharp@~0.24.1
                          Wohl vom iot Adapter Mal da fragen danke oder hast du ne Idee?
                          • AlCalzone
                            @deta Ne frag ruhig mal in dem Kontext nach.
                              apollon77 @Kueppert last edited by
                              @Kueppert dann müssten die Verzeichnis rechte Schuld sein. Aber support für root Systeme ist so ne Sache 😉
                                apollon77 @Dr. Bakterius last edited by
                                @Dr-Bakterius sagte in Beta Test js-controller 3.0.x auf GitHub:
                                Der rflink-Adapter konnte keinen Serial-Port finden. Auch eine Neuinstallation des Adapters hat nicht geholfen. Dieses Problem konnte ich dann durch folgenden Befehl im iobroker-Verzeichnis lösen (hat halt dann rund 15 Minuten gedauert alle Adapter neu zu installieren):
                                Ja ich fürchte hier greif das Auto-Rebuild nicht weil das nicht verfügbare Serialport im ersten schritt für Admin abgefangen wird und somit keine Exception fliegt. Was hat das Log genau gesagt?
                                  apollon77 @BBTown last edited by
                                  @BBTown Und tut bewi iot was nicht trotz der meldung? Wenn Du den Adapter beendest sollte er versuchen zu rebuilden. mach mal ... Bzw mehr log bitte 🙂
                                    apollon77 @deta last edited by
                                    libvips
                                    Wir AlCalzone schon sagt nix vom Controller ... Aber die Meldungbesagt das Du ein Linux Paket in einer minimalen Version brauchst ... versuch mal "apt install libvips-dev" ... kommt da eine >=8.9.0 ?
                                      apollon77 last edited by apollon77
                                      Hey All,
                                      habe gerade mal alles gecheckt was seit heute früh auf kam.
                                      Am Ende ist es:
                                      • tr-064 wo @foxriver76 gerade schaut
                                      • serialport bei rflink wo ggf. die Rebuild-Exception nicht fliegt und daher kein Auto Rebuild passiert
                                      • iot mit auch nem Warn wegen nicht rebuild Paketen ... da sollte man mal einen Neustart des Adapters versuchen ob er das dann erkennt und rebuildet.
                                      • pushover 1.2.4 muss noch ins Latest 🙂
                                      Hab ich alles erwischt?
                                        deta Most Active @apollon77 last edited by deta
                                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                        libvips
                                        Hab ich schon, ist installiert.
                                        root@rock:~# apt install libvips-dev
                                        Reading package lists... Done
                                        Building dependency tree
                                        libvips-dev is already the newest version (8.4.5-1+deb9u1).
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        Aber bei kommt
                                        root@rock:~# vips -v
                                        Could not find the database of available applications, run update-command-not-found as root to fix this
                                        vips: command not found
                                        root@rock:~# sudo update-command-not-found
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_contrib_Contents-arm64.lz4 ... . done
                                        I: Writing data for dl.yarnpkg.com_debian_dists_stable_main_Contents-armhf.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_stretch-utils_Contents-armhf.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_main_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_contrib_Contents-armhf.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_main_Contents-armhf.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_stretch-desktop_Contents-armhf.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_non-free_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_contrib_Contents-armhf.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_main_Contents-armhf.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-updates_main_Contents-arm64.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_stretch-utils_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_non-free_Contents-arm64.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_main_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_non-free_Contents-armhf.lz4 ... . done
                                        I: Writing data for mirrors.dotsrc.org_armbian-apt_dists_stretch_stretch-desktop_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-updates_main_Contents-armhf.lz4 ... . done
                                        I: Writing data for dl.yarnpkg.com_debian_dists_stable_main_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_non-free_Contents-armhf.lz4 ... . done
                                        I: Writing data for dl.yarnpkg.com_debian_dists_stable_main_Contents-all.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_main_Contents-arm64.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch-backports_main_Contents-armhf.lz4 ... . done
                                        I: Writing data for httpredir.debian.org_debian_dists_stretch_contrib_Contents-arm64.lz4 ... . done
                                        The program 'vips' is currently not installed.  You can install it by typing:
                                        apt install libvips-tools
                                        root@rock:~# apt install libvips-tools
                                        Recommended packages:
                                          nip2 libvips-doc
                                        The following NEW packages will be installed:
                                          libvips-tools
                                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 92,3 kB of archives.
                                        After this operation, 198 kB of additional disk space will be used.
                                        Get:1 http://httpredir.debian.org/debian stretch/main arm64 libvips-tools arm64 8.4.5-1+deb9u1 [92,3 kB]
                                        Fetched 92,3 kB in 0s (391 kB/s)
                                        Selecting previously unselected package libvips-tools.
                                        (Reading database ... 53112 files and directories currently installed.)
                                        Preparing to unpack .../libvips-tools_8.4.5-1+deb9u1_arm64.deb ...
                                        Unpacking libvips-tools (8.4.5-1+deb9u1) ...
                                        Setting up libvips-tools (8.4.5-1+deb9u1) ...
                                        Processing triggers for man-db (2.7.6.1-2) ...
                                        vips-8.4.5-Fri Jan 18 18:15:36 UTC 2019
                                        root@rock:~#
                                        gelöst, mal sehen beim nächsten Update
                                          Der TR-064 Adapter macht bei mir dieses Problem.
                                          tr-064-community.0	2020-04-12 15:00:22.767	info	(29197) Terminated (NO_ERROR): Without reason
                                          tr-064-community.0	2020-04-12 15:00:22.763	info	(29197) terminating
                                          tr-064-community.0	2020-04-12 15:00:22.678	error	(29197) TypeError: Cannot read property 'getState' of undefined at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1006:20) at Object.options.ready (/opt/iobro
                                          tr-064-community.0	2020-04-12 15:00:22.671	error	(29197) uncaught exception: Cannot read property 'getState' of undefined
                                          tr-064-community.0	2020-04-12 15:00:22.597	info	(29197) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.20.0, js-controller: 3.0.6
                                          tr-064-community.0	2020-04-12 14:59:35.065	info	(27910) Terminated (NO_ERROR): Without reason
                                          tr-064-community.0	2020-04-12 14:59:35.061	info	(27910) terminating
                                          tr-064-community.0	2020-04-12 14:59:34.989	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                          tr-064-community.0	2020-04-12 14:59:34.989	error	at Promise.all.then (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7986:76)
                                          tr-064-community.0	2020-04-12 14:59:34.989	error	at Object.options.ready (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1120:13)
                                          tr-064-community.0	2020-04-12 14:59:34.989	error	at checkIfUpdated (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1006:20)
                                          tr-064-community.0	2020-04-12 14:59:34.989	error	(27910) TypeError: Cannot read property 'getState' of undefined
                                          tr-064-community.0	2020-04-12 14:59:34.983	error	(27910) uncaught exception: Cannot read property 'getState' of undefined
                                          tr-064-community.0	2020-04-12 14:59:34.925	info	(27910) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.20.0, js-controller: 3.0.6
                                            @deta naja. Community Version wird nicht weiter gepflegt. Bitte auf originalen wechseln mit 3.1.4
                                            js-controller
                                            39
                                            416
                                            68542
