    4. [Vorstellung] Meine zweite Visualisierung
    • Glasfaser
      Glasfaser @cTech last edited by
      @cTech sagte in [Vorstellung] Meine zweite Visualisierung:
      Was kann ich hier noch machen?
      Das Log davon hier posten !
        cTech @Glasfaser last edited by
        @Glasfaser
        javascript.0	2020-04-10 16:20:04.151	info	(32676) received all objects
        javascript.0	2020-04-10 16:20:02.829	info	(32676) received all states
        host.ioBroker	2020-04-10 16:20:01.872	info	instance system.adapter.dwd.0 started with pid 626
        javascript.0	2020-04-10 16:19:58.028	info	(32676) requesting all objects
        javascript.0	2020-04-10 16:19:58.024	info	(32676) requesting all states
        javascript.0	2020-04-10 16:19:57.952	error	(32676) Cannot install npm packet: Simple-ssh
        javascript.0	2020-04-10 16:19:57.951	error	(32676) Cannot install Simple-ssh: 1
        javascript.0	2020-04-10 16:19:57.935	error	(32676) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-04-10T14_19_57_533Z-debug.log
        javascript.0	2020-04-10 16:19:57.933	error	(32676)
        javascript.0	2020-04-10 16:19:57.530	error	(32676) 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
        javascript.0	2020-04-10 16:19:57.528	error	(32676) npm ERR! 404 Your package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR!
        javascript.0	2020-04-10 16:19:57.526	error	(32676) 404 Not Found - GET https://registry.npmjs.org/Simple-ssh - Not found npm ERR! 404 npm ERR! 404 'Simple-ssh@latest' is not in the npm registry.
        javascript.0	2020-04-10 16:19:57.524	error	(32676) npm ERR!
        javascript.0	2020-04-10 16:19:57.516	error	(32676) ERR! code E404
        javascript.0	2020-04-10 16:19:57.514	error	(32676) npm
        javascript.0	2020-04-10 16:19:54.780	info	(32676) npm install Simple-ssh --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
        javascript.0	2020-04-10 16:19:54.780	error	(32676) Cannot install Simple-ssh: 1
        javascript.0	2020-04-10 16:19:54.770	error	(32676) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-04-10T14_19_54_381Z-debug.log
        javascript.0	2020-04-10 16:19:54.378	error	(32676) Your package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, fol
        javascript.0	2020-04-10 16:19:54.375	error	(32676) Not Found - GET https://registry.npmjs.org/Simple-ssh - Not found npm ERR! 404 npm ERR! 404 'Simple-ssh@latest' is not in the npm registry. npm ERR! 404
        javascript.0	2020-04-10 16:19:54.373	error	(32676) npm ERR! 404
        javascript.0	2020-04-10 16:19:54.367	error	(32676) ERR! code E404
        javascript.0	2020-04-10 16:19:54.365	error	(32676) npm
        javascript.0	2020-04-10 16:19:49.391	info	(32676) npm install Simple-ssh --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
        javascript.0	2020-04-10 16:19:49.390	error	(32676) Cannot install Simple-ssh: 1
        javascript.0	2020-04-10 16:19:49.381	error	(32676) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-04-10T14_19_49_369Z-debug.log
        javascript.0	2020-04-10 16:19:49.379	error	(32676)
        javascript.0	2020-04-10 16:19:49.367	error	(32676) 404 Your package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball,
        javascript.0	2020-04-10 16:19:49.366	error	(32676) ERR! 404 Not Found - GET https://registry.npmjs.org/Simple-ssh - Not found npm ERR! 404 npm ERR! 404 'Simple-ssh@latest' is not in the npm registry. npm ERR!
        javascript.0	2020-04-10 16:19:49.364	error	(32676) npm
        javascript.0	2020-04-10 16:19:49.362	error	(32676) npm ERR! code E404
        host.ioBroker	2020-04-10 16:19:38.680	info	instance system.adapter.javascript.0 started with pid 32676
        host.ioBroker	2020-04-10 16:19:36.793	info	instance system.adapter.javascript.0 terminated with code 156 (156)
        • Glasfaser
          Glasfaser @cTech last edited by Glasfaser
          @cTech
          Laut Log erreicht er die URL nicht ( error 404 )!!!
          Gehen sonst alle Update´s ??
          Text Edit:
          Error bezog sich auf URL https://registry.npmjs.org ....
            @Glasfaser jetzt geht es. Habe neu gestartet und nochmal ein paar sachen probiert.
            Beim Script für die Abfragen geht es auch alles soweit aber ich bekomme jetzt diese Fehler...
            javascript.0	2020-04-11 14:41:46.605	warn	(2639) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-04-11 14:41:46.605	warn	(2639) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-04-11 14:41:46.604	warn	(2639) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-04-11 14:41:46.604	warn	(2639) at ontimeout (timers.js:438:13)
            javascript.0	2020-04-11 14:41:46.603	warn	(2639) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1460:29)
            javascript.0	2020-04-11 14:41:46.603	warn	(2639) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
            javascript.0	2020-04-11 14:41:46.601	warn	(2639) You are assigning a object to the state "javascript.0.Adapter.Adapter1.Connected" which expects a number. Please fix your code to use a number or change the state type to object. This warning m
            javascript.0	2020-04-11 14:41:46.589	warn	(2639) at Timer.processTimers (timers.js:223:10)
            javascript.0	2020-04-11 14:41:46.589	warn	(2639) at listOnTimeout (timers.js:263:5)
            javascript.0	2020-04-11 14:41:46.589	warn	(2639) at tryOnTimeout (timers.js:300:5)
            javascript.0	2020-04-11 14:41:46.588	warn	(2639) at ontimeout (timers.js:438:13)
            javascript.0	2020-04-11 14:41:46.588	warn	(2639) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1460:29)
            javascript.0	2020-04-11 14:41:46.588	warn	(2639) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
            javascript.0	2020-04-11 14:41:46.579	warn	(2639) You are assigning a object to the state "javascript.0.Adapter.Adapter1.Uptime" which expects a string. Please fix your code to use a string or change the state type to object. This warning migh
            javascript.0	2020-04-11 14:41:38.136	info	(2639) script.js.java.abfragen.adapter_infos: registered 2 subscriptions and 0 schedules
            • Glasfaser
              @cTech
              Steht doch alles drin ... was du machen sollst !!
                @Glasfaser
                Ich werde aber nicht schlau draus was ich machen soll. Ich finde im Code nichts mit Adapter1. Daher die Frage 😉 Hast du noch einen Tip? 😉
                • Glasfaser
                  Nee .. nicht im Skript ... der Datenpunkt selber ist gemeint ...z.b . javascript.0.Adapter.Adapter1.Connected, den sollst du umstellen ..
                  hier dieser Punkt ist gemeint..
                  Beispiel :
                    @Glasfaser
                    Das ist es nicht gewesen. Die sind so eingestellt wie die anderen Adapter Ordner. Dann kann wohl nur Kuddel als Skriptersteller weiterhelfen. Bei mir klappt das zumindest nicht.
                    • Glasfaser
                      @cTech
                      Die beiden Datenpunkt sind aber nicht von Kuddel , die dort als warn erscheinen !!!
                      Das Script selber ist im Ordner "abfragen" und das Script heißt : adapter_infos und das ist von Kuddel und das stellt fest ... das die Datenpunkte geändert werden sollen
                      Hast du es jetzt die beiden Datenpunkten geändert/angepasst , laut dem Log !?
                        cTech @Glasfaser last edited by cTech
                        @Glasfaser
                        Ja auf object. Funktioniert nicht.
                        Zeichenkette habe ich auch probiert.
                          Kuddel @cTech last edited by
                          @cTech am besten mal alle objekte unter javascript.0.Adapter löschen, Skrippt stoppen, Javascript-Instanz stoppen und neustarten und das Skript auch wieder starten
                            cTech @Kuddel last edited by
                            Hmm ich geb es auf 😉
                            Ih versuche die Adapter anderweitig zu überwachen.
                            Eine andere Frage...
                            Ich bekomme die DWD Warnungen in so einer komischen Uhrzeit; 1505156151855
                            Was kann man dagegen machen?
                            Auch bekomme ich öfters mal folgende Fehlermeldung:
                            no connection to objects DB
                            no connection to states DB
                            Kommt immer mal von unterschiedlichen Adaptern
                              für die VIs einfach das Widget "TimeValue" nehmen und entsprechend Konvertieren
                              habe ich auch ab und zu. kümmere ich mich nicht weiter drum
                                @Kuddel
                                so habe ich es auch gelöst. Das Widget funktioniert. Ich bekomme zudem noch eine Message per Telegram. Da habe ich den Code etwas verändert. Läuft.
                                  ToniMahoni @cTech last edited by
                                  @cTech
                                  Und was genau hast du im Script geändert? Habe das gleiche Problem.
                                    cTech @ToniMahoni last edited by
                                    @ToniMahoni
                                    function convertTimestamp(timestamp) { // Unix in Milliseconds!
                                      var d = new Date(timestamp),
                                    		yyyy = d.getFullYear(),
                                    		mm = ('0' + (d.getMonth() + 1)).slice(-2),	// Months are zero based. Add leading 0.
                                    		dd = ('0' + d.getDate()).slice(-2),			// Add leading 0
                                    		hh = ('0' + d.getHours()).slice(-2),        // Add leading 0
                                    		min = ('0' + d.getMinutes()).slice(-2),		// Add leading 0
                                    		sec = ('0' + d.getSeconds()).slice(-2),     // Add leading 0
                                    		day = d.getDay(),                           // Wochentag
                                    		days = ['Sonntag', 'Montag', 'Dienstag', 'Mittwoch', 'Donnerstag', 'Freitag', 'Samstag'],
                                    		time;
                                    	time = days[d.getDay()] + ' ' + dd + '.' + mm + '.' + yyyy + ' ' + hh + ':' + min;
                                    	return time;
                                    function SendDWDWarning()
                                      //var Begin = getState("dwd.0.warning.begin").val;
                                      //var End = getState("dwd.0.warning.end").val;
                                      var Begin = convertTimestamp(getState("dwd.0.warning.begin").val);
                                      var End = convertTimestamp(getState("dwd.0.warning.end").val);
                                      var text = getState("dwd.0.warning.text").val;
                                      var Headline = getState("dwd.0.warning.headline").val;
                                      var Description = getState("dwd.0.warning.description").val;
                                      var DWD_telegramm = "Achtung Wetterwarnungen: " + Headline + " gültig vom " + Begin + "Uhr bis " + End + "Uhr: " + Description ;
                                      sendTo ("telegram.0", DWD_telegramm);
                                    on("dwd.0.warning.severity", function (obj)
                                      if (obj.newState.val !==0)
                                        setTimeout(SendDWDWarning, 30 * 1000);
                                      if (obj.newState.val === 0)
                                        sendTo ("telegram.0", "Alle Wetterwarnungen des Deutschen Wetterdienstes wurden aufgehoben.") ;
                                    • nils50122
                                      nils50122 last edited by
                                      das VIS gefällt mir echt sehr gut.
                                      Ich habe das gesamte Projekt importiert. Die Views sind vorhanden, allerdings sind sämtliche Icons nicht vorhanden, obwohl diese im Datei-Manager angezeigt werden.
                                      • Passt hier eventuell die Ordnerstruktur nicht?
                                      Am Beispiel der View "101_Navi". Hinterlegt sind die Pfade: "/icons-mfd-png/xxxpng".
                                      Ich finde allerdings nur "/icons-mfd-png.admin/" und hier ist leider auch nur ein einziges .png drin.
                                      Installiert habe ich den Adapter von "https://github.com/ioBroker/ioBroker.icons-mfd-png" und auch eine Instanz hiervon angelegt. Dabei gab es keine Fehler.
                                      Hat jemand eine Idee?
                                        Kuddel @nils50122 last edited by
                                        @nils50122 sieht so aus, als wenn der Icon-Adapter nicht korrekt installiert wurde.
                                        Einfach mal löschen und neu installieren
                                        nils50122 2 Replies Last reply Reply Quote 1
                                        • nils50122
                                          nils50122 @Kuddel last edited by
                                          @Kuddel
                                          Das habe ich auch schon vermutet.
                                          Der Adapter wurde bereits komplett gelöscht und neuinstalliert.
                                          Vielleicht ist der aktuelle Release fehlerhaft.
                                          • nils50122
                                            @Kuddel
                                            Läuft nun, habe den kompletten IOBroker neu aufgesetzt.
                                            Eine Anfängerfrage:
                                            Ich habe nun dein Projekt importiert und sehe die Icons. Logischerweise stehen z.B. alle Temperaturen und Co. auf NaN xx.
                                            Wie verlinke ich diese nun mit meinen Theromstaten aus dem HomeMatic? Ich hatte mir vorgestellt, dass ich doppelt auf z.B. NaN °C klicke und dort dann unter Eigenschaften das Objekt verlinke. Leider öffnet sich z.B. bei Heizung nur "121_Heizung".
                                            Inwiefern werden die Skripts benötigt?
                                            Wie integriere ich die IP-Kameras und die Müllabholung?
                                            template vis
                                            148
                                            1324
                                            495000
