    4. Wifilight 1.1.0 testing
      sigi234 Forum Testing Most Active @Guest last edited by
      @ilovegym
      Danke , läuft auf Windows mit node: v10.16.3, js-controller: 3.0.4
      • CKMartens
        CKMartens @foxriver76 last edited by
        @foxriver76
        bei mir ist beim Update ein Fehler aufgetretten:
        $ ./iobroker upgrade wifilight
        Update wifilight from @0.2.0 to @1.1.0
        NPM version: 6.13.4
        npm install iobroker.wifilight@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR!
         code EACCESnpm ERR! syscall accessnpm ERR! path /opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-extnpm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-ext'npm ERR!  { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-ext']npm ERR!   stack:npm ERR!    'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-ext\'',npm ERR!   errno: -13,npm
        ERR!   code: 'EACCES',npm ERR!   syscall: 'access',npm ERR!   path:npm ERR!    '/opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-ext' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR!
         It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-04-10T16_50_08_799Z-debug.log
        ERROR: host.iob01 Cannot install iobroker.wifilight@1.1.0: 243
        ERROR: process exited with code 25
        Das Verzeichnis /opt/iobroker/node_modules/iobroker.wifilight/node_modules/array-ext hat die Rechte 755 und gehört root:root
        • foxriver76
          foxriver76 Developer @CKMartens last edited by
          @CKMartens führe doch mal den Fixer aus mittels iob fix
          CKMartens 1 Reply Last reply Reply Quote 0
          • CKMartens
            @foxriver76
            Hab mit
            curl -sL https://iobroker.net/fix.sh | bash -
            den Fixer drüberlaufen lassen. Das hat geholfen. Danke!
            • foxriver76
              Bitte auch mal nicht js-c 3 Tester testen ob es tut 😉
              ? CKMartens 2 Replies Last reply Reply Quote 0
                frankyboy73 last edited by
                Hi, habe versucht den Adapter zu installieren. Unter Adapter wird er mir auch als installiert angezeigt, aber es gibt keine Instanz. Ein paar meiner Adapter wurden nach der Insatllation komischerweise neu gestartet, z.B Node Red.
                RasperyPi 4 mit 4 GB
                Js-Controller 2.2.9
                Node.JS 10.19.0
                NPM 6.13.4
                host.raspberrypi	2020-04-12 22:38:34.189	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                host.raspberrypi	2020-04-12 22:38:33.982	info	iobroker exit 0
                host.raspberrypi	2020-04-12 22:38:32.871	info	iobroker upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/de/translations.json i18n/de/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.809	info	iobroker upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/en/translations.json i18n/en/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.747	info	iobroker upload [2] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/es/translations.json i18n/es/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.688	info	iobroker upload [3] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.628	info	iobroker upload [4] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/it/translations.json i18n/it/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.572	info	iobroker upload [5] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.508	info	iobroker upload [6] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.453	info	iobroker upload [7] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.397	info	iobroker upload [8] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.341	info	iobroker upload [9] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                host.raspberrypi	2020-04-12 22:38:32.284	info	iobroker upload [10] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
                host.raspberrypi	2020-04-12 22:38:32.227	info	iobroker upload [11] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
                host.raspberrypi	2020-04-12 22:38:32.120	info	iobroker upload [12] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/words.js words.js application/javascript
                host.raspberrypi	2020-04-12 22:38:13.903	info	iobroker npm install https://github.com/iobroker-community-adapters/ioBroker.wifilight/tarball/3b408fefaca79abe9bb404216791b5408d3d6d52 --loglevel error --prefix "/opt/iobroker" (System call)
                host.raspberrypi	2020-04-12 22:38:13.901	info	iobroker NPM version: 6.13.4
                host.raspberrypi	2020-04-12 22:38:13.257	info	iobroker install https://github.com/iobroker-community-adapters/ioBroker.wifilight/tarball/3b408fefaca79abe9bb404216791b5408d3d6d52
                host.raspberrypi	2020-04-12 22:38:11.103	info	iobroker url "https://github.com/iobroker-community-adapters/ioBroker.wifilight.git"
                • foxriver76
                  foxriver76 Developer @frankyboy73 last edited by
                  @frankyboy73 dann leg doch eine Instanz an 😉
                    frankyboy73 @foxriver76 last edited by frankyboy73
                    @foxriver76
                    Ok, hab ich jetzt gemacht. Allerdings wurde das sonst automatisch gemacht wenn ich nen Adapter installiert habe. Liegt das daran das ich das jetzt direkt über die Github URL gemacht habe?
                    Aber egal.
                    Mein Lightstrip wurde gefunden, allerdings wird mir in Objekten nur ein Datenpunkt Device angezeigt, sonst nichts.
                    Edit:
                    Ich hatte vor ca. 2 Jahren mal die Version 0.2.0 getestet. Da konnte ich meinen Lightstrip schalten, Helligkeit ging nicht und auch keine Farben, deshalb habe ich mich dann auch nicht weiter mit dem Adapter beschäftig.
                    • foxriver76
                      @frankyboy73 Jop bei GitHub Install kommt nicht automatisch eine Instanz dazu. Evtl mal bei Admin oben auf aktualisieren evtl wird dann das device erweitert. Ich selbst weiß gerade nicht was der Adapter für States anlegt. Müssten die anderen Nutzer aushelfen.
                        @foxriver76
                        Hi, aktualisiert hatte ich schon mehrmals. Hatte aber nicht geholfen. Nach einiger Zeit sind die Objekte dann doch aufgetaucht, ca. 10 Minuten. Schalten geht, aber ich bekomme keine Rückmeldung über den Status, wenn ich über die App schalte. Auch kann ich die Helligkeit und die Farben usw. nicht steuern, bzw. ändert sich nichts am Lightstrip oder in der App.
                        Das Polling Intervall in den Einstellungen ist in Sekunden oder?
                        Edit: ist es normal das der Adapter immer mal wieder neu startet?
                        wifilight.0	2020-04-13 00:00:50.889	info	(7274) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v10.19.0
                        host.raspberrypi	2020-04-13 00:00:49.282	info	instance system.adapter.wifilight.0 started with pid 7274
                        host.raspberrypi	2020-04-13 00:00:47.303	info	instance system.adapter.wifilight.0 terminated with code 156 (156)
                        wifilight.0	2020-04-13 00:00:46.775	info	(7198) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        wifilight.0	2020-04-13 00:00:46.774	info	(7198) terminating
                        wifilight.0	2020-04-13 00:00:46.772	info	(7198) Got terminate signal TERMINATE_YOURSELF
                        wifilight.0	2020-04-13 00:00:46.770	info	(7198) soef.changeAdapterConfig: changed
                        host.raspberrypi	2020-04-13 00:00:46.768	info	stopInstance system.adapter.wifilight.0 send kill signal
                        host.raspberrypi	2020-04-13 00:00:46.767	info	stopInstance system.adapter.wifilight.0 (force=false, process=true)
                        wifilight.0	2020-04-13 00:00:46.594	info	(7198) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.wifilight, node: v10.19.0
                        host.raspberrypi	2020-04-13 00:00:45.029	info	instance system.adapter.wifilight.0 started with pid 7198
                        host.raspberrypi	2020-04-13 00:00:43.056	info	instance system.adapter.wifilight.0 terminated with code 156 (156)
                        wifilight.0	2020-04-13 00:00:42.541	info	(2445) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        wifilight.0	2020-04-13 00:00:42.538	info	(2445) terminating
                        wifilight.0	2020-04-13 00:00:42.521	info	(2445) Got terminate signal TERMINATE_YOURSELF
                        host.raspberrypi	2020-04-13 00:00:42.516	info	stopInstance system.adapter.wifilight.0 send kill signal
                        ? 2 Replies Last reply Reply Quote 0
                          A Former User @foxriver76 last edited by
                          @foxriver76 sagte in Wifilight 1.1.0 testing:
                          Hi, läuft bei mir auch auf dem prod. System unter js-c 2.29 ohne Probleme.
                          • foxriver76
                            foxriver76 Developer @Guest last edited by
                            @ilovegym top, könntest du evtl die Fragen von @frankyboy73 beantworten. Ich weiß nicht wie sich der Adapter zu verhalten hat, habe ja nur Kompatibilität hergestellt, nutze ihn selbst nicht. Wäre nett 😉
                            • CKMartens
                              Unter 2.2.10 lüft der Adapter ohne Probleme. Danke
                                A Former User @frankyboy73 last edited by
                                @frankyboy73 Hi,
                                ich kenn mich mit den zicken des Adapters ganz gut aus, hab jetzt nach 2 Jahren 18 Controller, die ich damit steuere.
                                Zum ersten muss man sagen, dass die Devices kein response melden, d.h. du schickst da was hin, und es gibt keine Rückmeldung, ob die Funktion geklappt hat.
                                Das ist auch der Grund, warum der Adapter erst irgendwann später mit bekommt, wenn du etwas in der App schaltest.
                                Das Polling ist in Sekunden, leider haben bei mir andere Werte als 30 mehr zu gar keiner Funktion geführt, als irgendeine Verbesserung. Also 30sek. warten, entweder stimmen dann die States in iobroker oder es dauert nochmal 30sek...
                                Bei mir sieht das so im Setup aus, zu beachten ist, dass wenn man einen anderen Namen als AK001-xxx einträgt, es nicht immer funktioniert.. scheint irgendwas mit den Pfaden/Objekten nicht zu stimmen..
                                Also am besten die Geräte erkennen lassen und dann per klick übernehmen. ( dauert bei mir so 2-5min, dann sind aber auch alle 18 da).
                                Normal ist es nicht, dass er neu startet, aber oft hilft es, dann funktioniert er wieder richtig 🙂
                                Die Version 0.2.0 hatte ich stündlich automatisch neu starten lassen, da er sich irgendwann mal verzettelt hat und nix mehr ging.. so kam ich bis zur 1.x über die Runden..
                                Irgendwann wird alles gut.. 🙂
                                  @frankyboy73 wenn du noch fragen hast, meld dich
                                    frankyboy73 @Guest last edited by frankyboy73
                                    @ilovegym
                                    Ok, vielen Dank für die Infos. Dann stelle ich mal auf 30 Sekunden zurück und schaue mir das mal an. Ich hatte es jetzt mit 10 Sekunden getestet und zeitnah nichts mehr zurück bekommen. Habe ich dann nach ein paar Minuten noch mal geschaut, war der Status richtig. Aber Helligkeit und Farben kann ich bei meinem Stripe nicht über den Adapter steuern, nur An und Aus, klappt das denn bei dir?
                                    Das sah vor 2 Jahren mit dem Adapter ähnlich bei mir aus, deshalb habe ich mir auch keine weiteren dieser Stripes zugelegt, da ich sie so nicht vernüftig mit dem Iobroker nutzen kann. Ich hatte mir jetzt erst mal mit dem Umweg über Alexa Skill und Alexa2 Adapter geholfen, aber da gibts auch keinen Response und der Umweg über die Cloud gefällt mir nicht, falls das Internet oder Alexa offline ist, ist nix mehr mit schalten.
                                    Log Meldungen über Neustart des Adapters hatte ich jetzt übrigens keine mehr.
                                      @frankyboy73 Hi, notfalls komplette Instanz mal löschen, schauen dass alle Objekte auch wirklich gelöscht sind, und dann nochmal neu installieren, alles mit dem Adapter suchen lassen, und genau so übernehmen.
                                        @ilovegym
                                        Hi, Instanz geöscht, Objekte wurden alle entfernt. Instanz hinzugefügt, suchen lassen, Gerät sofort gefunden, hinzugefügt, nicht verändert. Adapter Ausgabe auf Debug.
                                        Es werden nach Adapter Start alle 30 Sekunden Werte geholt, Bri ist allerdings nicht dabei. Ich kann Ein und Ausschalten. Setzte ich die Helligkeit im Objekt auf einen anderen Wert, gibts haufenweise Schreibbefehle. Helligkeit am Stripe ändert sich aber nicht. Versuche ich dann zu schalten, geht das nicht mehr. Danach kommen auch keine Daten mehr an. Es wird nur noch versucht zu schreiben.
                                        Das gleiche habe ich auch wenn ich per App schalte (brauche ich eigentlich nicht, aber mal zum Test). Erst werden alle 30 Sekunden Daten angezeigt und nach dem Schalten per App ist das vorbei, es wird wohl alle 30 Sekunden versucht, aber es werden keine Daten mehr angezeigt.
                                        Log nach Helligkeit ändern und Schalten:
                                        wifilight.0	2020-04-13 12:21:57.170	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:21:27.169	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:20:57.167	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:20:27.166	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:19:57.165	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:19:27.164	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:19:08.160	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:19:08.159	debug	(7462) [192.168.1.67] sending refresh...
                                        wifilight.0	2020-04-13 12:19:08.149	debug	(7462) [192.168.1.67] write: 71 24 0f a4
                                        wifilight.0	2020-04-13 12:18:57.162	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:18:36.723	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:18:36.722	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:36.722	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:36.721	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:18:27.164	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:18:27.164	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:27.163	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:27.163	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:18:27.157	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:18:06.723	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:18:06.723	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:06.723	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:18:06.722	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:17:57.260	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:17:57.259	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:57.258	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:57.257	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:17:57.156	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:17:40.341	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:17:40.340	debug	(7462) [192.168.1.67] sending refresh...
                                        wifilight.0	2020-04-13 12:17:40.280	debug	(7462) [192.168.1.67] write: 31 18 cc 00 00 00 ff 0f 23
                                        wifilight.0	2020-04-13 12:17:40.220	debug	(7462) [192.168.1.67] write: 31 18 cd 00 00 00 ff 0f 24
                                        wifilight.0	2020-04-13 12:17:40.160	debug	(7462) [192.168.1.67] write: 31 18 ce 00 00 00 ff 0f 25
                                        wifilight.0	2020-04-13 12:17:40.099	debug	(7462) [192.168.1.67] write: 31 18 cf 00 00 00 ff 0f 26
                                        wifilight.0	2020-04-13 12:17:40.039	debug	(7462) [192.168.1.67] write: 31 18 d0 00 00 00 ff 0f 27
                                        wifilight.0	2020-04-13 12:17:39.979	debug	(7462) [192.168.1.67] write: 31 18 d1 00 00 00 ff 0f 28
                                        wifilight.0	2020-04-13 12:17:39.919	debug	(7462) [192.168.1.67] write: 31 19 d2 00 00 00 ff 0f 2a
                                        wifilight.0	2020-04-13 12:17:39.859	debug	(7462) [192.168.1.67] write: 31 19 d3 00 00 00 ff 0f 2b
                                        wifilight.0	2020-04-13 12:17:39.799	debug	(7462) [192.168.1.67] write: 31 19 d4 00 00 00 ff 0f 2c
                                        wifilight.0	2020-04-13 12:17:39.739	debug	(7462) [192.168.1.67] write: 31 19 d5 00 00 00 ff 0f 2d
                                        wifilight.0	2020-04-13 12:17:39.679	debug	(7462) [192.168.1.67] write: 31 19 d6 00 00 00 ff 0f 2e
                                        wifilight.0	2020-04-13 12:17:39.619	debug	(7462) [192.168.1.67] write: 31 19 d7 00 00 00 ff 0f 2f
                                        wifilight.0	2020-04-13 12:17:39.558	debug	(7462) [192.168.1.67] write: 31 19 d8 00 00 00 ff 0f 30
                                        wifilight.0	2020-04-13 12:17:39.498	debug	(7462) [192.168.1.67] write: 31 19 d9 00 00 00 ff 0f 31
                                        wifilight.0	2020-04-13 12:17:39.438	debug	(7462) [192.168.1.67] write: 31 19 da 00 00 00 ff 0f 32
                                        wifilight.0	2020-04-13 12:17:39.378	debug	(7462) [192.168.1.67] write: 31 19 db 00 00 00 ff 0f 33
                                        wifilight.0	2020-04-13 12:17:39.320	debug	(7462) [192.168.1.67] write: 31 1a dc 00 00 00 ff 0f 35
                                        wifilight.0	2020-04-13 12:17:39.261	debug	(7462) [192.168.1.67] write: 31 1a dd 00 00 00 ff 0f 36
                                        wifilight.0	2020-04-13 12:17:39.201	debug	(7462) [192.168.1.67] write: 31 1a de 00 00 00 ff 0f 37
                                        wifilight.0	2020-04-13 12:17:39.141	debug	(7462) [192.168.1.67] write: 31 1a df 00 00 00 ff 0f 38
                                        wifilight.0	2020-04-13 12:17:39.080	debug	(7462) [192.168.1.67] write: 31 1a e0 00 00 00 ff 0f 39
                                        wifilight.0	2020-04-13 12:17:39.020	debug	(7462) [192.168.1.67] write: 31 1a e1 00 00 00 ff 0f 3a
                                        wifilight.0	2020-04-13 12:17:38.960	debug	(7462) [192.168.1.67] write: 31 1a e2 00 00 00 ff 0f 3b
                                        wifilight.0	2020-04-13 12:17:38.901	debug	(7462) [192.168.1.67] write: 31 1a e3 00 00 00 ff 0f 3c
                                        wifilight.0	2020-04-13 12:17:38.842	debug	(7462) [192.168.1.67] write: 31 1a e4 00 00 00 ff 0f 3d
                                        wifilight.0	2020-04-13 12:17:38.782	debug	(7462) [192.168.1.67] write: 31 1a e5 00 00 00 ff 0f 3e
                                        wifilight.0	2020-04-13 12:17:38.724	debug	(7462) [192.168.1.67] write: 31 1b e6 00 00 00 ff 0f 40
                                        wifilight.0	2020-04-13 12:17:38.665	debug	(7462) [192.168.1.67] write: 31 1b e7 00 00 00 ff 0f 41
                                        wifilight.0	2020-04-13 12:17:38.606	debug	(7462) [192.168.1.67] write: 31 1b e8 00 00 00 ff 0f 42
                                        wifilight.0	2020-04-13 12:17:38.547	debug	(7462) [192.168.1.67] write: 31 1b e9 00 00 00 ff 0f 43
                                        wifilight.0	2020-04-13 12:17:38.488	debug	(7462) [192.168.1.67] write: 31 1b ea 00 00 00 ff 0f 44
                                        wifilight.0	2020-04-13 12:17:38.429	debug	(7462) [192.168.1.67] write: 31 1b eb 00 00 00 ff 0f 45
                                        wifilight.0	2020-04-13 12:17:38.369	debug	(7462) [192.168.1.67] write: 31 1b ec 00 00 00 ff 0f 46
                                        wifilight.0	2020-04-13 12:17:38.310	debug	(7462) [192.168.1.67] write: 31 1b ed 00 00 00 ff 0f 47
                                        wifilight.0	2020-04-13 12:17:38.252	debug	(7462) [192.168.1.67] write: 31 1b ee 00 00 00 ff 0f 48
                                        wifilight.0	2020-04-13 12:17:38.193	debug	(7462) [192.168.1.67] write: 31 1b ef 00 00 00 ff 0f 49
                                        wifilight.0	2020-04-13 12:17:38.134	debug	(7462) [192.168.1.67] write: 31 1c f0 00 00 00 ff 0f 4b
                                        wifilight.0	2020-04-13 12:17:38.075	debug	(7462) [192.168.1.67] write: 31 1c f1 00 00 00 ff 0f 4c
                                        wifilight.0	2020-04-13 12:17:38.015	debug	(7462) [192.168.1.67] write: 31 1c f2 00 00 00 ff 0f 4d
                                        wifilight.0	2020-04-13 12:17:37.955	debug	(7462) [192.168.1.67] write: 31 1c f3 00 00 00 ff 0f 4e
                                        wifilight.0	2020-04-13 12:17:37.895	debug	(7462) [192.168.1.67] write: 31 1c f4 00 00 00 ff 0f 4f
                                        wifilight.0	2020-04-13 12:17:37.835	debug	(7462) [192.168.1.67] write: 31 1c f5 00 00 00 ff 0f 50
                                        wifilight.0	2020-04-13 12:17:37.776	debug	(7462) [192.168.1.67] write: 31 1c f6 00 00 00 ff 0f 51
                                        wifilight.0	2020-04-13 12:17:37.717	debug	(7462) [192.168.1.67] write: 31 1c f7 00 00 00 ff 0f 52
                                        wifilight.0	2020-04-13 12:17:37.658	debug	(7462) [192.168.1.67] write: 31 1c f8 00 00 00 ff 0f 53
                                        wifilight.0	2020-04-13 12:17:37.599	debug	(7462) [192.168.1.67] write: 31 1c f9 00 00 00 ff 0f 54
                                        wifilight.0	2020-04-13 12:17:37.540	debug	(7462) [192.168.1.67] write: 31 1d fa 00 00 00 ff 0f 56
                                        wifilight.0	2020-04-13 12:17:37.481	debug	(7462) [192.168.1.67] write: 31 1d fb 00 00 00 ff 0f 57
                                        wifilight.0	2020-04-13 12:17:37.423	debug	(7462) [192.168.1.67] write: 31 1d fc 00 00 00 ff 0f 58
                                        wifilight.0	2020-04-13 12:17:37.364	debug	(7462) [192.168.1.67] write: 31 1d fd 00 00 00 ff 0f 59
                                        wifilight.0	2020-04-13 12:17:37.304	debug	(7462) [192.168.1.67] write: 31 1d fe 00 00 00 ff 0f 5a
                                        wifilight.0	2020-04-13 12:17:36.726	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:17:36.725	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:36.724	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:36.723	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:17:27.259	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:17:27.259	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:27.258	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:27.257	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:17:27.154	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:17:06.724	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:17:06.724	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:06.723	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:17:06.722	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:16:58.369	debug	(7462) system.adapter.admin.0: logging true
                                        wifilight.0	2020-04-13 12:16:57.162	debug	(7462) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:16:57.162	debug	(7462) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:16:57.161	debug	(7462) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:16:57.160	debug	(7462) raw data length: 14
                                        wifilight.0	2020-04-13 12:16:57.153	debug	(7462) self.client.connect: connected
                                        wifilight.0	2020-04-13 12:16:57.153	debug	(7462) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:16:57.145	debug	(7462) [192.168.1.67] 192.168.1.67 connected
                                        Log nach Ausschalten per App oder Alexa:
                                        wifilight.0	2020-04-13 12:38:29.247	debug	(18782) [192.168.1.67] onData: raw: 04 00 00 61 81 33 24 61 01 07 1d ff 00 00
                                        wifilight.0	2020-04-13 12:38:29.247	debug	(18782) raw data: 81 33 24 61 01 07 1d ff 00 00 04 00 00 61
                                        wifilight.0	2020-04-13 12:38:29.246	debug	(18782) raw data length: 14
                                        wifilight.0	2020-04-13 12:38:29.135	debug	(18782) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:37:59.246	debug	(18782) [192.168.1.67] onData: raw: 04 00 00 61 81 33 24 61 01 07 1d ff 00 00
                                        wifilight.0	2020-04-13 12:37:59.246	debug	(18782) raw data: 81 33 24 61 01 07 1d ff 00 00 04 00 00 61
                                        wifilight.0	2020-04-13 12:37:59.245	debug	(18782) raw data length: 14
                                        wifilight.0	2020-04-13 12:37:59.134	debug	(18782) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:37:29.242	debug	(18782) [192.168.1.67] onData: raw: 04 00 00 61 81 33 24 61 01 07 1d ff 00 00
                                        wifilight.0	2020-04-13 12:37:29.241	debug	(18782) raw data: 81 33 24 61 01 07 1d ff 00 00 04 00 00 61
                                        wifilight.0	2020-04-13 12:37:29.241	debug	(18782) raw data length: 14
                                        wifilight.0	2020-04-13 12:37:29.133	debug	(18782) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:36:59.139	debug	(18782) [192.168.1.67] onData: raw: f0 71 24 85 81 33 24 61 01 07 1d ff 00 00
                                        wifilight.0	2020-04-13 12:36:59.138	debug	(18782) raw data: 81 33 24 61 01 07 1d ff 00 00 04 00 00 61
                                        wifilight.0	2020-04-13 12:36:59.138	debug	(18782) raw data length: 14
                                        wifilight.0	2020-04-13 12:36:59.132	debug	(18782) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:36:35.882	debug	(18782) raw data: f0 71 24 85
                                        wifilight.0	2020-04-13 12:36:35.881	debug	(18782) raw data length: 4
                                        wifilight.0	2020-04-13 12:36:29.236	debug	(18782) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:36:29.236	debug	(18782) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:36:29.235	debug	(18782) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:36:29.234	debug	(18782) raw data length: 14
                                        wifilight.0	2020-04-13 12:36:29.131	debug	(18782) [192.168.1.67] write: 81 8a 8b 96
                                        wifilight.0	2020-04-13 12:35:59.232	debug	(18782) [192.168.1.67] onData: {"on":true,"progNo":97,"progOn":false,"preogSpeed":7,"red":29,"green":255,"blue":0,"white":0}
                                        wifilight.0	2020-04-13 12:35:59.231	debug	(18782) [192.168.1.67] onData: raw: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:35:59.231	debug	(18782) raw data: 81 33 23 61 01 07 1d ff 00 00 04 00 00 60
                                        wifilight.0	2020-04-13 12:35:59.230	debug	(18782) raw data length: 14
                                          @frankyboy73 hmm seltsam, das funktioniert bei mir einwandfrei..
                                          Welche Version haben denn deine Devices?
                                          findest du in der App, oben links auf die Striche, dann Geräte-Manager, da sollten dann die ID und Version stehen.
                                          Ich hab 15 Version 04.v4 und 3 Version 04.v5.
                                          Bei den Version 5 bekomm ich die nicht als lokal angezeigt, ( das Antennenzeichen ist grau, nicht blau), wenn du darauf klickst, kannst du unter Geräteinformation noch mehr sehen.
                                            @ilovegym
                                            Hi, ist die Magic Home App, da sieht das wohl etwas anders aus.
                                            Das steht bei mir unter Geräteinformation.
                                            Antenne und Globus sind blau.
                                            test wifilight
                                            1258
