    4. Beta Test js-controller 3.0.x auf GitHub
    • Chaot
      Chaot last edited by
      Ich habe mehrere Warnmeldungen:
      Bei ODL:
      odl.0	2020-04-13 09:19:51.377	warn	(25330) Got no data for DEZ3192
      odl.0	2020-04-13 09:19:51.376	warn	(25330) SyntaxError: Unexpected token < in JSON at position 0
      odl.0	2020-04-13 09:19:51.376	warn	(25330) Error parsing response from server!
      Bei sourceanalytics:
      sourceanalytix.0	2020-04-13 09:19:50.716	warn	(25736) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-04-13 09:19:50.715	warn	(25736) Object sonoff__0__Stecker3__ENERGY_Power.2020.costs.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-04-13 09:19:50.654	warn	(25736) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-04-13 09:19:50.654	warn	(25736) Object sonoff__0__Stecker3__ENERGY_Power.2020.meterReadings.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-04-13 09:19:50.565	warn	(25736) This object will not be created in future versions. Please report this to the developer.
      sourceanalytix.0	2020-04-13 09:19:50.565	warn	(25736) Object sonoff__0__Stecker3__ENERGY_Power.2020.consumed.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      sourceanalytix.0	2020-04-13 09:19:50.487	warn	(25736) This object will not be created in future versions. Please report this to the developer.
      ...gekürzt ...
      Bei WLED:
      wled.0	2020-04-13 09:22:17.401	warn	(25893) This value will not be set in future versions. Please report this to the developer.
      wled.0	2020-04-13 09:22:17.401	warn	(25893) State value to set is invalid for wled.0.cc50e304f753.seg.0.col.0: The state is missing the required property val!
      wled.0	2020-04-13 09:22:17.394	warn	(25893) This value will not be set in future versions. Please report this to the developer.
      wled.0	2020-04-13 09:22:17.392	warn	(25893) State value to set is invalid for wled.0.cc50e304f753.seg.0.ix: The state is missing the required property val!
      Alle Adapter sind auf grün und alles scheint zu laufen.
        Kueppert @apollon77 last edited by
        @apollon77 erledigt 😉
        https://github.com/iobroker-community-adapters/ioBroker.yeelight-2/issues/57
        kueppert created this issue in iobroker-community-adapters/ioBroker.yeelight-2
        closed Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed #57
        • foxriver76
          foxriver76 Developer @Chaot last edited by
          @Chaot ersteres scheint API kaputtes JSON zu liefern, bei anderen beiden bitte Adapter Issues wenn noch nicht geschehen.
            apollon77 @BBTown last edited by
            @BBTown Solche Fehler mag ich am liebsten (wenn Sie dann weg bleiben) 😉
            Homer.J. 1 Reply Last reply Reply Quote 0
              A Former User @apollon77 last edited by
              @apollon77
              übrigens, wer Octoprint und Adapter nutzt, der Fork von @reloxx13 funktioniert mit Node 12 und js-controller 3.0.x einwandfrei 🙂
              ist von letztem Jahr März ..
              https://github.com/reloxx13/ioBroker.octoprint
              • Homer.J.
                Homer.J. @apollon77 last edited by
                Hi @apollon77 hab seid dem ich auf die 3.0.7 bin bei manchen scripten Fehler.
                Ich hab keine Ahnung ob es hiervon kommt deshalb hier meine Frage.
                2020-04-13 11:29:28.435  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:29.437  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:30.437  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:31.437  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:32.436  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:33.437  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:34.436  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:35.437  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:36.438  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:37.439  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:38.439  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:39.440  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:40.440  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:41.442  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:42.442  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:43.442  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:44.441  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:45.442  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:46.443  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:47.443  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:48.444  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:49.444  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:50.444  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:51.445  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:52.445  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:53.447  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:54.448  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:55.449  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:56.450  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:57.451  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:58.452  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                2020-04-13 11:29:59.453  - error: javascript.0 (31801) script.js.common.Steuerung.02_Geschirrspüler: setForeignState: undefined is not a valid state value
                  apollon77 @Homer.J. last edited by
                  @Homer-J Dann schau doch mal was Du hier in Deinem Skript an Wert setzen willst ... scheinbar willst Du "undefined" setzen was formal seit jeher ein nicht erlaubter wert ist! Sonst zeig doch mal das genannte Skript
                  • Homer.J.
                    Homer.J. @apollon77 last edited by Homer.J.
                    @apollon77 hier mal das Script für den Spüler. Beim Waschmaschine ist es genau so. Hat sich Erledigt hab die Datenpunkte neu angelegt.
                    var Meldetext, AUS_Zaehler, Intervall, Waschdauer, Sekunde, timeout, Minute, timeout2;
                     * Beschreibe diese Funktion …
                    function etwas_tun(Meldetext) {
                      sendTo("pushover", "send", {
                         message: Meldetext,
                         sound: "",
                         title: '+++ Geschirrspüler +++'
                    createState("Vis.Geschirrspüler.Aktiv", function () {
                      createState("Vis.Geschirrspüler.Aktiv.Zeit_Minuten", function () {
                        createState("Vis.Geschirrspüler.Aktiv.Zeit_Sekunden", function () {
                    // Geschirrspüler_Script
                    setState("javascript.0.Vis.Geschirrspüler.Aktiv"/*Vis.Geschirrspüler.Aktiv*/, false);
                    on({id: 'hm-rpc.2.0001D3C99CB161.6.POWER', change: "any"}, function (obj) {
                      var value = obj.state.val;
                      if (getState("javascript.0.Vis.Geschirrspüler.Aktiv").val == false && getState("hm-rpc.2.0001D3C99CB161.6.POWER").val > 10) {
                        setState("javascript.0.Vis.Geschirrspüler.Aktiv.Zeit_Minuten"/*Vis.Geschirrspüler.Aktiv.Zeit_Minuten*/, 0);
                        (function () {if (Intervall) {clearInterval(Intervall); Intervall = null;}})();
                        Intervall = setInterval(function () {
                          Sekunde = (typeof Sekunde == 'number' ? Sekunde : 0) + 1;
                          if (Sekunde > 59) {
                            Minute = (typeof Minute == 'number' ? Minute : 0) + 1;
                            Sekunde = 0;
                          setState("javascript.0.Vis.Geschirrspüler.Aktiv.Zeit_Minuten"/*Vis.Geschirrspüler.Aktiv.Zeit_Minuten*/, Minute);
                          setState("javascript.0.Vis.Geschirrspüler.Aktiv.Zeit_Sekunden"/*Vis.Geschirrspüler.Aktiv.Zeit_Sekunden*/, Sekunde);
                        }, 1000);
                        setState("javascript.0.Vis.Geschirrspüler.Aktiv"/*Vis.Geschirrspüler.Aktiv*/, true);
                        setState("javascript.0.Vis.Geschirrspüler.Aktiv_State"/*Vis.Geschirrspüler.Aktiv_State*/, 1);
                        Waschdauer = (new Date().getHours() * 3600 + new Date().getMinutes() * 60 + new Date().getSeconds());
                        etwas_tun('Der Geschirrspüler wurde angeschalten');
                        setState("alexa2.0.Echo-Devices.G000RA07841712N1.Commands.speak-volume"/*Volume to use for speak commands*/, 35);
                        setStateDelayed("javascript.0.Alexa.Sprachausgabe"/*Alexa.Sprachausgabe*/, 'Der Geschirrspüler wurde angeschalten', 1000, false);
                        setStateDelayed("alexa2.0.Echo-Devices.G000RA07841712N1.Commands.speak-volume"/*Volume to use for speak commands*/, 40, 10000, false);
                      } else if (getState("hm-rpc.2.0001D3C99CB161.6.POWER").val > 10 && getState("javascript.0.Vis.Geschirrspüler.Aktiv").val == true && AUS_Zaehler > 0) {
                        AUS_Zaehler = AUS_Zaehler - 1;
                      } else if (getState("hm-rpc.2.0001D3C99CB161.6.POWER").val < 1 && getState("javascript.0.Vis.Geschirrspüler.Aktiv").val == true) {
                        AUS_Zaehler = (typeof AUS_Zaehler == 'number' ? AUS_Zaehler : 0) + 1;
                      if (AUS_Zaehler == 7) {
                        etwas_tun('Der Geschirrspüler ist fertig');
                        Waschdauer = (new Date().getHours() * 3600 + new Date().getMinutes() * 60 + new Date().getSeconds()) - Waschdauer;
                        (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
                        timeout = setTimeout(function () {
                          (function () {if (timeout2) {clearTimeout(timeout2); timeout2 = null;}})();
                          timeout2 = setTimeout(function () {
                            etwas_tun(['Der Spülvorgang dauerte *',Math.round(Waschdauer / 60),' Minuten* und hat *',getState("sourceanalytix.0.hm-rpc__2__0001D3C99CB161__6__ENERGY_COUNTER.2020.consumed.01_current_day").val,' kWh* Energie für (*',getState("sourceanalytix.0.hm-rpc__2__0001D3C99CB161__6__ENERGY_COUNTER.2020.costs.01_current_day").val,' €*) verbraucht.'].join(''));
                          }, 240000);
                          AUS_Zaehler = 0;
                          setStateDelayed("javascript.0.Alexa.Sprachausgabe"/*Alexa.Sprachausgabe*/, 'Der Geschirrspüler ist fertig.', 1000, false);
                          setStateDelayed("hm-rpc.2.0001D3C99CB161.3.STATE"/*Steckdose Geschirrspüler.STATE*/, false, 300000, false);
                          setStateDelayed("javascript.0.Vis.Geschirrspüler.Aktiv_State"/*Vis.Geschirrspüler.Aktiv_State*/, 0, 300000, false);
                          setState("javascript.0.Vis.Geschirrspüler.Aktiv_State"/*Vis.Geschirrspüler.Aktiv_State*/, 2);
                          Minute = 0;
                          Sekunde = 0;
                          console.log('Der Geschirrspüler ist jetzt fertig schalte Strom ab');
                        }, 300000);
                    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
                      @Homer-J Neee sorry aber Blockly XML les ich net 🙂 Bitte das generierte Javascript posten oder das Bild 🙂 Bin nur handy gerade und auch sonst dauert Blockly import und gedöhns zu lang
                      • Dr. Bakterius
                        Dr. Bakterius Most Active @apollon77 last edited by
                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                        Ja ich fürchte hier greif das Auto-Rebuild nicht weil das nicht verfügbare Serialport im ersten schritt für Admin abgefangen wird und somit keine Exception fliegt. Was hat das Log genau gesagt?
                        Sorry, das ist weg. Hatte vor einem zweiten Versuch einen Snapshot wiederhergestellt und dann gleich das reinstall gefahren.
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @BBTown last edited by
                          @BBTown sagte in Beta Test js-controller 3.0.x auf GitHub:
                          In den Logs habe ich zum Einen die hier bereits erwähnte Warnung
                          adapter.objects.getObjectView is deprecated ...
                          Bei mir kommen diese wiederkehrend vom iot.0 und vom web.0 Adapter sowie einmalig vom admin.0
                          Bei mir noch beim Info-Adapter und beim MaxCube-Adapter. Auf Github gibt es dazu schon entsprechende Issues.
                          • Chaot
                            Chaot @apollon77 last edited by
                            @apollon77
                            Ich habe beieinem Update eine Fehlermeldung:
                            host.ioBroker	2020-04-14 07:38:33.524	info	iobroker exit 0
                            host.ioBroker	2020-04-14 07:38:32.508	error	iobroker Required dependency "hm-rpc" not found.
                            host.ioBroker	2020-04-14 07:38:30.806	info	iobroker upgrade hm-rega
                            host.ioBroker	2020-04-14 07:38:24.475	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                            • foxriver76
                              @Chaot und ist hm-rpc installiert?
                              • Chaot
                                Chaot @foxriver76 last edited by
                                @foxriver76
                                Ja.
                                Deshalb wundert es mich ja so.
                                Ich habe nichts mit Homematic. Deshalb werde ich mal beides deinstallieren. Oder wird der innerhalb vom ioBroker für irgendwas gebraucht? Der war bei mir von Anfang an installiert.
                                  apollon77 @Chaot last edited by
                                  @Chaot naja warte doch mal bitte ... lass doch mal untersuchen ... nicht gleich den Holzhammer!!
                                  Hats Du ein oder mehrere Hosts?
                                  Zeig mal die Instanzliste bitte
                                  • Chaot
                                    @apollon77 Ich habe nur einen Host und kein Homematic System.
                                    Um zu testen habe ich jetzt nach Entfernen der Instanzen beide nochmals hinzugefügt und keine Fehlermeldung mehr erhalten.
                                    Du hats Recht. Ich hätte sinnvollerweise warten sollen. Hilft dir das Log weiter?
                                    apollon77 foxriver76 2 Replies Last reply Reply Quote 0
                                      noch jemand anders hier mit einem hm-rega upgrade ausstehend?
                                        @Chaot Ääähm mal so gefragt: welche Controller Version war es denn? Die 3.0.7? Oder eine frühere?
                                        • Chaot
                                          @apollon77 Die 3.0.7 vom 13.04.
                                          • foxriver76
                                            foxriver76 Developer @Chaot last edited by foxriver76
                                            @Chaot Wie meinst du, du hast kein Homematic System. Laut Log hast du ja hm-rega geupgradet und vemrutlich kein hm-rpc installiert gehabt..
                                            Habe das Seznario gerade problemlos durchgespielt.
                                            js-controller
                                            39
                                            416
                                            68515
