    4. Beta Test js-controller 3.0.x auf GitHub
    • crycode
      crycode Developer @apollon77 last edited by
      @apollon77 Upgrade meiner Testumgebung (Debian 10) von 2.2.9 auf 3.0.8 klappte ohne Probleme.
      Ich habe zugleich die Node.js Version von 10.x auf 12.16.2 angehoben. Der automatische Rebuild der Adapter (getestet an ioBroker.radiohead) klappte einwandfrei. 🙂
      • BBTown
        BBTown @apollon77 last edited by BBTown
        @apollon77 bei der v3.0.8 erhalte ich beim iot-Adapter folgende Meldungen
        iot.0	2020-04-14 12:08:25.927	warn	(12587) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        iot.0	2020-04-14 12:08:25.852	warn	(12587) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        iot.0	2020-04-14 12:08:25.627	warn	(12587) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        iot.0	2020-04-14 12:08:25.017	warn	(12587) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        iot.0	2020-04-14 12:08:25.016	warn	(12587) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
        iot.0	2020-04-14 12:08:25.008	warn	the module (for instance, using `npm rebuild` or `npm install`).
        iot.0	2020-04-14 12:08:25.008	warn	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        iot.0	2020-04-14 12:08:25.008	warn	NODE_MODULE_VERSION 64. This version of Node.js requires
        iot.0	2020-04-14 12:08:25.008	warn	was compiled against a different Node.js version using
        iot.0	2020-04-14 12:08:25.008	warn	(12587) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        Dies wiederholt sich beim Restart des Adapters und nach einem Upload und anschließendem Restart des Adapters
        K apollon77 2 Replies Last reply Reply Quote 0
          Kueppert @BBTown last edited by
          @BBTown das hatte ich auch - allerdings hatte ich da gem. HOST im ioBroker keine 3.0.8 drauf, sondern immer noch die 2.x.x. Ich hatte den falschen Ordner für das Update ausgewählt (war bei der JS-Controller-Installation nicht im Ordner /opt/iobroker).
          • BBTown
            BBTown @Kueppert last edited by BBTown
            @Kueppert sagte in Beta Test js-controller 3.0.x auf GitHub:
            Interessant, da auch ich eben zunächst im falschen Ordner den aktuellen js-controller installiert habe (mir ist aufgefallen, dass die Version auf v3.0.7 geblieben war)
            Danach habe ich dann erneut den js-copntroller in /opt/iobroker installiert und sehe nun auch die v3.0.8.
            Kann/muss man dennoch ein uninstall der falschen js-controller Installation durchführen?
            Wenn ja, wie? 😎
              @BBTown ich hab die 2. Installation auch noch nicht entfernt, weil ich auch nicht weiß, wie das geht ^^
                apollon77 @BBTown last edited by
                @BBTown in dem Falschen verzeichnis sollte an sich maximal ein Verzeichnis "node_modules" entstanden sein. vllt eine package.json und/oder package-lock.json. DIe einfach löschen das sollte es gewesen sein
                  @BBTown Alles klar, wie weiter oben schon gesagt tut hier der Auto rebuild nicht weil der Adapter den Fehler fängt und ggf einzelne Funktionen nicht zur verfügung stehen.
                  Aber auch dafür haben wir etwas neues 🙂
                  Führe mal "iobroker rebuild iot" aus.
                  Falls der Fehler danach noch bleibt mach ein
                  "iobroker rebuild iot --install"
                  Danach sollte es spätestens weg sein
                  BBTown 1 Reply Last reply Reply Quote 1
                  • BBTown
                    @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                    dann erhalte ich ein Rebuild iot done zurück - ich denke mal, so soll es sein 🙂
                    [EDIT]
                    ... allerdings sind die WARN-Hinwiese des iot-Adapters nach einem Neustat von ioBroker noch immer da. Dann versuche ich nun mal mit der zweiten Option iobroker rebuild iot --install
                    Erneut kommt die Rüclmeldung Rebuild iot done
                    Nach einem Neustrat von ioBroker kommen jetzt nur noch die bekannten:
                    iot.0	2020-04-14 15:54:04.891	warn	(1304) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
                    Meldungen.
                      @BBTown 🙂 Hat also geklappt wie es soll
                        Am Ende ist das Auto-Rebuild und die neuen "rebuild" Kommandos der ersatz für resinstall.sh das globale rebuild kommando was immer wieder komische effekte hat
                          e-i-k-e last edited by e-i-k-e
                          ein Beta Test! Da bin ich wieder mit dabei. 😉
                          Master/Slave System läuft auf 2.2.9, node 10.20.0, npm 6.14.4
                          Master: Intel Nuc mit Proxmox
                          Slave: 6x Raspberry mit Rasbian
                          Vor dem Update der Slave auf 3.0.8, habe ich jeweils den fixer laufen lassen.
                          Update über npm install ioBroker/ioBroker.js-controller lief zwar durch, aber unter Host wurde keine neue Version angezeigt.
                          Der Versuch über sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller brachte einige Fehler.
                          pi@raspberrypi-display3:~ $ iobroker stop
                          pi@raspberrypi-display3:~ $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
                          npm WARN checkPermissions Missing write access to /home/pi/node_modules/iobroker.js-controller
                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                          npm WARN pi No description
                          npm WARN pi No repository field.
                          npm WARN pi No README data
                          npm WARN pi No license field.
                          npm ERR! code EACCES
                          npm ERR! syscall access
                          npm ERR! path /home/pi/node_modules/iobroker.js-controller
                          npm ERR! errno -13
                          npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller'
                          npm ERR!  { [Error: EACCES: permission denied, access '/home/pi/node_modules/iobroker.js-controller']
                          npm ERR!   stack:
                          npm ERR!    'Error: EACCES: permission denied, access \'/home/pi/node_modules/iobroker.js-controller\'',
                          npm ERR!   errno: -13,
                          npm ERR!   code: 'EACCES',
                          npm ERR!   syscall: 'access',
                          npm ERR!   path: '/home/pi/node_modules/iobroker.js-controller' }
                          npm ERR!
                          npm ERR! The operation was rejected by your operating system.
                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                          npm ERR!
                          npm ERR! If you believe this might be a permissions issue, please double-check the
                          npm ERR! permissions of the file and its containing directories, or try running
                          npm ERR! the command again as root/Administrator.
                          npm ERR!     /home/iobroker/.npm/_logs/2020-04-14T15_14_45_176Z-debug.log
                          Anbei die log-Datei.
                          Edit: Wie dumm! War im falschen Ordner. 🙄
                          3.0.8 lauft jetzt auf einem Slave.
                            Kueppert @e-i-k-e last edited by
                            @e-i-k-e HAHAHA, passiert den Besten 😉 ist nicht nur dir passiert ^^
                              Komplette System läuft jetzt auf 3.0.8. Alle Adapter sind aktuell grün.
                              Im Log kommen unzählige Warnungen von sourceanalytix.
                              Anbei ein Auszug davon.
                              sourceanalytix.0	2020-04-14 18:01:04.142	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.142	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.31 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.138	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.138	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.31 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.133	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.133	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.31 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.123	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.123	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.30 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.114	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.113	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.30 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.108	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.107	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.30 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.102	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.102	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.098	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.097	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.093	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.093	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.087	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.084	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.082	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.081	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.079	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.078	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.075	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.075	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.27 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.073	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.072	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.27 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.068	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.068	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.27 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.062	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.062	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.26 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.057	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.057	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.26 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.052	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.052	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.26 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.048	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.048	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.25 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.044	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.044	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.25 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.040	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.039	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.25 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.032	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.032	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.24 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.028	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.028	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.24 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.023	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.023	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.24 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.016	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.016	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.23 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.011	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:04.009	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.23 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:04.001	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.998	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.23 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.992	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.992	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.22 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.987	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.987	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.22 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.983	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.983	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.22 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.978	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.978	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.21 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.973	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.972	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.21 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.969	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.969	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.21 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.966	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.966	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.20 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.961	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.961	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.20 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.956	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.956	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.20 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.950	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.950	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.19 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.946	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.946	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.19 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.943	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.943	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.19 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.940	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.940	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.18 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.937	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.937	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.18 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.933	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.933	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.18 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.925	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.925	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.17 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.913	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.913	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.17 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.904	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.904	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.17 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.896	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.895	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.16 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.890	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.890	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.16 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.881	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.881	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.16 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.874	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.874	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.15 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.865	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.864	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.15 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.860	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.859	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.15 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.856	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.856	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.853	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.853	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.850	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.850	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.14 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.846	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.846	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.842	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.842	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.837	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.836	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.13 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.831	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.831	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.12 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.827	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.826	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.12 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.821	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.821	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.12 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.816	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.816	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.11 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.812	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.812	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.11 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.807	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.806	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.11 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.801	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.801	warn	(15468) Object discovergy__0__61234183__energy.2020.costs.weeks.10 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.797	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.796	warn	(15468) Object discovergy__0__61234183__energy.2020.meterReadings.weeks.10 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.792	warn	(15468) This object will not be created in future versions. Please report this to the developer.
                              sourceanalytix.0	2020-04-14 18:01:03.792	warn	(15468) Object discovergy__0__61234183__energy.2020.consumed.weeks.10 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                              sourceanalytix.0	2020-04-14 18:01:03.709	info	(15468) Meter Calculation executed consumed data for javascript.0.variablen.Photovoltaik.Gesamtverbrauch : {"consumedDay":-2954.475,"consumedWeek":-2941.951,"consumedMonth":-2801.436,"consumedQuarter"
                              sourceanalytix.0	2020-04-14 18:01:03.707	info	(15468) Set calculated value 0.0483900082888889 on state : javascript__0__variablen__Photovoltaik__Gesamtverbrauch.Current_Reading}
                              sourceanalytix.0	2020-04-14 18:01:03.707	info	(15468) Calculation for javascript.0.variablen.Photovoltaik.Gesamtverbrauch with value : {"val":612.12,"ack":true,"ts":1586880063702,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admi
                              sourceanalytix.0	2020-04-14 18:01:03.677	info	(15468) Initialising discovergy.0.61234183.energy with configuration {"stateDetails":{"alias":"","consumption":true,"costs":true,"deviceName":"discovergy__0__61234183__energy","financielCathegorie":"c
                              sourceanalytix.0	2020-04-14 18:01:03.677	info	(15468) for state discovergy.0.61234183.energy Previous watt calculated reading used Version > 4 from {"val":2949.776,"ack":true,"ts":1586880060349,"q":0,"from":"system.adapter.sourceanalytix.0","user
                              sourceanalytix.0	2020-04-14 18:01:03.675	info	(15468) Meter Calculation executed consumed data for discovergy.0.61234183.energy : {"consumedDay":5.033,"consumedWeek":17.073,"consumedMonth":165.724,"consumedQuarter":165.724,"consumedYear":1606.206
                              sourceanalytix.0	2020-04-14 18:01:03.672	info	(15468) Set calculated value 2949.7770563 on state : discovergy__0__61234183__energy.Current_Reading}
                              sourceanalytix.0	2020-04-14 18:01:03.670	info	(15468) Calculation for discovergy.0.61234183.energy with value : {"val":2949.7770563,"ack":true,"ts":1586880063659,"q":0,"from":"system.adapter.discovergy.0","user":"system.user.admin","lc":158688006
                              sql.0	2020-04-14 18:01:03.671	info	(15194) enabled logging of discovergy.0.61234183.energy, Alias=false
                              sql.0	2020-04-14 18:01:03.671	info	(15194) enabled logging of discovergy.0.61234183.Power_Consumption, Alias=false
                              sourceanalytix.0	2020-04-14 18:01:03.666	info	(15468) Updated SourceAnalytix configuration for : discovergy.0.61234183.energy
                              sql.0	2020-04-14 18:01:03.661	info	(15194) enabled logging of discovergy.0.61234183.energyOut, Alias=false
                              sourceanalytix.0	2020-04-14 16:01:00.348	info	(15468) Initialization finished for : discovergy.0.61234183.energy
                              sourceanalytix.0	2020-04-14 16:01:00.348	info	(15468) Meter Calculation executed consumed data for discovergy.0.61234183.energy : {"consumedDay":5.033,"consumedWeek":17.072,"consumedMonth":165.723,"consumedQuarter":165.723,"consumedYear":1606.20
                              sourceanalytix.0	2020-04-14 16:01:00.342	info	(15468) Set calculated value 2949.7764479 on state : discovergy__0__61234183__energy.Current_Reading}
                              sourceanalytix.0	2020-04-14 16:01:00.342	info	(15468) Calculation for discovergy.0.61234183.energy with value : {"val":2949.7764479,"ack":true,"ts":1586880058571,"q":0,"from":"system.adapter.discovergy.0","user":"system.user.admin","lc":15868800
                              sourceanalytix.0	2020-04-14 16:01:00.341	info	(15468) First time calc result after initialising
                              Homer.J. apollon77 2 Replies Last reply Reply Quote 0
                              • Homer.J.
                                Homer.J. @e-i-k-e last edited by
                                @e-i-k-e ist bekannt Log auf error umstellen.
                                  apollon77 @Kueppert last edited by
                                  @Kueppert Dabeihab ichs diesmal extra oben dazu geschrieben. Ich machs mal noch fett ... nächster schritt wäre rot blinkend 🙂
                                    apollon77 @e-i-k-e last edited by
                                    @e-i-k-e Dutchmen ist schon dran
                                    Homer.J. 1 Reply Last reply Reply Quote 1
                                    • Homer.J.
                                      Homer.J. @apollon77 last edited by
                                      @apollon77 von mir jedenfalls einen 👍 läuft alles Klasse 3.0.8 mit Node.js
                                      v13.12.0 keine Fehler mehr, und läuft jetzt auf meinem Produktivsystem.
                                        @apollon77
                                        Habe gerade festgestellt, dass sich die Javascript Adapter auf den Slave Geräten, ab und zu neustarten.
                                        Anbei die Log-Datei von einem Slave.
                                          Jan1 @Homer.J. last edited by
                                          @Homer-J
                                          War das nur ein Test mit Node13?
                                          In der Doku steht dick und rot das dazu:
                                          ungerade nodejs-Versionen sind grundsätzlich nicht empfohlen, da es sich um Entwicklerversionen handelt.
                                          • Homer.J.
                                            Homer.J. @Jan1 last edited by
                                            @Jan1 war ein Test von mir da z.B. der Yahka Adapter in der 12 Version nicht tut, in der 13 läuft bei mir alles wunderbar deshalb lass ich es so. 😊
                                            J apollon77 2 Replies Last reply Reply Quote 0
                                            js-controller
                                            39
                                            416
                                            68493
