    4. [How-to] Node.js für ioBroker richtig updaten
      Thomas Braun Most Active @Sneak-L8 last edited by
      @Sneak-L8
      nodejs -v
      node -v
      npm -v
      sudo apt update
      apt policy nodejs
      sudo apt upgrade
        Hab ich gerade durchgeführt und anschließend einen npm rebuild versucht. Immer noch der gleiche Fehler.
        epoll.target.mk:103: die Regel für Ziel „Release/obj.target/epoll/src/epoll.o“ scheiterte
        make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 4.14.34-v7+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
        gyp ERR! node -v v10.20.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! epoll@0.1.22 install: `node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the epoll@0.1.22 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR!     /home/iobroker/.npm/_logs/2020-04-13T20_33_28_983Z-debug.log
          apollon77 @Sneak-L8 last edited by
          @Sneak-L8 Und bricht er das rebuild dort ab oder was ist die Ausgabe am Ende?
            Sneak-L8 last edited by Sneak-L8
            Ja, der Build wird an dieser Stelle mit Fehler beendet.
            Hier mal etwas mehr Log-Output:
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp WARN Using request for node-pre-gyp https download
            [sqlite3] Success: "/opt/iobroker/node_modules/sqlite3/lib/binding/node-v64-linux-arm/node_sqlite3.node" already installed
            Pass --update-binary to reinstall or --build-from-source to recompile
            > epoll@2.0.9 install /opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll/build“ wird betreten
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.rpi2/node_modules/epoll/build“ wird verlassen
            > node-gyp rebuild
            > epoll@0.1.22 install /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird betreten
            In file included from ../../nan/nan.h:192:0,
                             from ../src/epoll.cc:15:
            ../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8: :Value>, v8::PropertyAttribute)’:
            ../../nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
               return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
            In file included from ../src/epoll.cc:15:0:
            ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local< v8::Value>*)’:
            ../../nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Functio n>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                     v8::Isolate::GetCurrent(), target, func, argc, argv);
            In file included from ../src/epoll.cc:12:0:
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:177:50: note: declared here
                             NODE_EXTERN v8::Local<v8::Value> MakeCallback(
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
                 __attribute__((deprecated(message))) declarator
            ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8 ::Value>*)’:
            ../../nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String> , int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                     v8::Isolate::GetCurrent(), target, symbol, argc, argv);
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:170:50: note: declared here
            ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*  ’:
            ../../nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8: :Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
                     v8::Isolate::GetCurrent(), target, method, argc, argv);
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/node.h:163:50: note: declared here
            ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v 8::Value>*) const’:
            ../../nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Functio n>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
            ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Add(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/epoll.cc:210:44: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declaration  ]
               int err = epoll->Add(info[0]->Int32Value(), info[1]->Int32Value());
            In file included from /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:26:0,
                             from ../src/epoll.cc:11:
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8.h:2478:46: note: declared here
               V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
            /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
               declarator __attribute__((deprecated(message)))
            ../src/epoll.cc:210:67: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declaration  ]
            ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Modify(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/epoll.cc:230:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declaration  ]
               int err = epoll->Modify(info[0]->Int32Value(), info[1]->Int32Value());
            ../src/epoll.cc:230:70: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declaration  ]
            ../src/epoll.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Epoll::Remove(Nan::NAN_METHOD_ARGS_TYPE)’:
            ../src/epoll.cc:247:47: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declaration  ]
               int err = epoll->Remove(info[0]->Int32Value());
            gyp ERR! not ok
            npm ERR! errno 1
            npm ERR!
            npm ERR!     /home/iobroker/.npm/_logs/2020-04-14T06_54_15_971Z-debug.log
            pi@ioBroker-RasPi:/opt/iobroker $
              @Sneak-L8 Welche Version von rpi2 adapter hast Du installiert? Dein "epoll" ist asbach uralt und nicht mit nodejs 10 kompatibel ... update mal rpi2 Adapter
                Sneak-L8 @apollon77 last edited by Sneak-L8
                @apollon77 Der Adapter RPI2 hat die Version 1.1.1. Laut Änderungsprotokoll gibt es nur eine neuere Version 1.2.0, die die automatische Adapter-Prüfung aber nicht vorschlägt.
                Evtl. manuell drüber installieren? aber wie genau?
                Ich habe jetzt mal gesagt, bestimmte RPI2-Version installieren und die 1.1.1 gewählt. Danach habe ich erneut einen npm rebuild gemacht. Gleicher Fehler. Hab aber gesehen, dass der rebuild mit einem epoll 3.0.0 startet. Also irgendwie will er wohl auch noch die alte Version umwandeln. Aber warum?
                npm uninstall epoll@0.1.22 hatte ich schon mal versucht.
                  @Sneak-L8 Dann mach mal npm ls im Verzeichnis node_modules/iobroker.rpi2 und Zeig mal die Ausgabe
                    @apollon77 Bitte schön:
                    pi@ioBroker-RasPi:/opt/iobroker/node_modules/iobroker.rpi2 $ npm ls
                    iobroker.rpi2@1.1.1 /opt/iobroker/node_modules/iobroker.rpi2
                    ├── UNMET DEPENDENCY @iobroker/adapter-core@^1.0.3
                    ├─┬ rpi-gpio@2.1.5
                    │ ├── UNMET DEPENDENCY async-retry@^1.2.1
                    │ ├─┬ debug@3.2.6
                    │ │ └── ms@2.1.2
                    │ └─┬ epoll@2.0.10
                    │   ├── UNMET DEPENDENCY bindings@^1.5.0
                    │   └── UNMET DEPENDENCY nan@^2.14.0
                    └── UNMET DEPENDENCY sync-exec@^0.6.2
                    npm ERR! missing: @iobroker/adapter-core@^1.0.3, required by iobroker.rpi2@1.1.1
                    npm ERR! missing: sync-exec@^0.6.2, required by iobroker.rpi2@1.1.1
                    npm ERR! missing: async-retry@^1.2.1, required by rpi-gpio@2.1.5
                    npm ERR! missing: bindings@^1.5.0, required by epoll@2.0.10
                    npm ERR! missing: nan@^2.14.0, required by epoll@2.0.10
                    • Steff
                      Steff last edited by
                      ich habe da auch mal eine Frage bzgl. dem richtigen Node updaten. Ich habe bei mir Node V10.17.0 am Laufen und mir wird ein mögliches Update auf die V10.20.1 angezeigt. Muss bei solch einem Update ebenfalls ein npm rebuild durchgeführt werden?
                      Gruß Steffen
                        Thomas Braun Most Active @Steff last edited by
                        @Steff Ich würde es machen. Steht auch wohl nicht ganz ohne Grund so in der Anleitung drin.
                          Jan1 @Thomas Braun last edited by Jan1
                          @Thomas-Braun
                          Dann zeig mir mal die Anleitung wo das drin steht, dass wenn man innerhalb der Grundversion ein Update durchführt, ein rebuild durchführen muss 😉
                            Thomas Braun Most Active @Jan1 last edited by
                            @Jan1 Bei minor-upgrades nicht unbedingt erforderlich, aber es schadet auch nicht. Und wenn man es gewohnheitsmäßig macht vergisst man es auch nicht bei major updates.
                            • cvidal
                              Ich habe das selbe Problem wie @Sneak-L8, bei npm rebuild bekomme ich folgendes raus:
                              root@IoBroker:/home/christian# cd /opt/iobroker
                              root@IoBroker:/opt/iobroker# npm rebuild
                              iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                              node lib/preinstallCheck.js
                              NPM version: 6.14.4
                              iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                              node iobroker.js setup first
                              acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                              node scripts/postinstall
                              Greenlock and ACME.js v3 are on the way!
                              Watch for updates at https://indiegogo.com/at/greenlock
                              authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                              node-gyp rebuild
                              make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                              CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                              ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                              ../authenticate_pam.cc:107:87: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
                              keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
                              In file included from ../authenticate_pam.cc:23:0:
                              ../../nan/nan.h:1024:46: note: declared here
                              NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
                              ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                              ../authenticate_pam.cc:147:83: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
                              al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
                              In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14:0,
                              from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27,
                              from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67,
                              from ../../nan/nan.h:54,
                              /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:3553:51: note: declared here
                              V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
                              /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
                              declarator attribute((deprecated(message)))
                              ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                              serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
                              In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67:0,
                              /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
                              int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                              /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                              ../authenticate_pam.cc:152:69: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
                              res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
                              ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                              remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
                              ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                              username->WriteUtf8(m->username, sizeof(m->username) - 1);
                              ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                              password->WriteUtf8(m->password, sizeof(m->password) - 1);
                              ../authenticate_pam.cc: At global scope:
                              ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
                              void init(Handle<Object> exports) {
                              ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                              ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
                              ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
                              In file included from ../../nan/nan.h:54:0,
                              ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
                              NODE_MODULE(authenticate_pam, init);
                              /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                              (node::addon_register_func) (regfunc),
                              ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
                              authenticate_pam.target.mk:111: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
                              make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                              make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                              gyp ERR! stack Error: make failed with exit code: 2
                              gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                              gyp ERR! stack at ChildProcess.emit (events.js:310:20)
                              gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                              gyp ERR! System Linux 4.9.0-11-amd64
                              gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                              gyp ERR! node -v v12.16.2
                              gyp ERR! not ok
                              npm ERR! errno 1
                              npm ERR! authenticate-pam@1.0.2 install: node-gyp rebuild
                              npm ERR!
                              npm ERR! Failed at the authenticate-pam@1.0.2 install script.
                              npm ERR! /home/iobroker/.npm/_logs/2020-04-14T20_27_54_800Z-debug.log
                              Alles läuft soweit ohne Errors bei mir ist der VW Connect Adapter das Problem. Bekomme fehler im Log und der Adapter Startet nicht.
                              host.IoBroker 2020-04-14 22:30:58.371 info Restart adapter system.adapter.vw-connect.0 because enabled
                              host.IoBroker 2020-04-14 22:30:58.371 error instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.IoBroker 2020-04-14 22:30:58.371 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                              host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: was compiled against a different Node.js version using
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: ^
                              host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                              host.IoBroker 2020-04-14 22:30:58.368 error Caught by controller[0]: internal/modules/cjs/loader.js:1206
                              host.IoBroker 2020-04-14 22:30:57.978 info instance system.adapter.vw-connect.0 started with pid 28748
                              Hier komme ich nicht weiter.
                              Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @cvidal last edited by Thomas Braun
                                @cvidal Welche Version von node ist installiert?
                                node -v
                                nodejs -v
                                Also root würde ich mich auch nicht anmelden.
                                cvidal 1 Reply Last reply Reply Quote 0
                                  wie komme ich am dümmsten von v10.19 auf die 10.20, ohne den apt update && apt upgrade Befehl?
                                  Hintergrund,
                                  Bluetooth bekomme ich nicht mehr zum laufen, wenn ich die übliche Variante wähle. Daher bin ich erstmal wieder zurück via backup.
                                  • cvidal
                                    cvidal Forum Testing @Thomas Braun last edited by
                                    @Thomas-Braun Ich nutze 12.16.2, ich weiß wird noch nicht empfohlen aber das sollte dem Adapter nichts ausmachen.
                                      Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                      @crunchip
                                      sudo apt install nodejs
                                      Ich würde aber schauen, dass die 10.20.1 angeboten wird. Die 10.20.0 hat einen Fehler.
                                      Bluetooth würde ich allerdings auch aktuell halten. Das Update kommt aus Security, das hat wohl einen Grund...
                                      crunchip 1 Reply Last reply Reply Quote 1
                                        @cvidal Dann bin ich raus.
                                        Permanent als root angemeldet und dann eine noch nicht vorgesehene Version macht Hilfe schwer.
                                          @Sneak-L8 Sehr interessant, da ist von der epoll 0.x nix zu sehen ... Dann halt der Harte weg:
                                          Lösche mal /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll komplett. Dann gehst Du in /opt/iobroker/node_modules/rpi-gpio und sagst "npm install --production".
                                          Dann versuch nochmal
                                            apollon77 @cvidal last edited by
                                            @cvidal sagte in [How-to] Node.js für ioBroker richtig updaten:
                                            authenticate_pam
                                            Versuch mal "apt install libpam0g-dev" und danach nochmal
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            736995
