    4. [How-to] Node.js für ioBroker richtig updaten
      Thomas Braun Most Active @Jan1 last edited by
      @Jan1 Bei minor-upgrades nicht unbedingt erforderlich, aber es schadet auch nicht. Und wenn man es gewohnheitsmäßig macht vergisst man es auch nicht bei major updates.
      • cvidal
        Ich habe das selbe Problem wie @Sneak-L8, bei npm rebuild bekomme ich folgendes raus:
        root@IoBroker:/home/christian# cd /opt/iobroker
        root@IoBroker:/opt/iobroker# npm rebuild
        iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        node lib/preinstallCheck.js
        NPM version: 6.14.4
        iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
        node iobroker.js setup first
        acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
        node scripts/postinstall
        Greenlock and ACME.js v3 are on the way!
        Watch for updates at https://indiegogo.com/at/greenlock
        authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
        node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
        CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
        ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
        ../authenticate_pam.cc:107:87: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
        keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
        In file included from ../authenticate_pam.cc:23:0:
        ../../nan/nan.h:1024:46: note: declared here
        NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
        ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../authenticate_pam.cc:147:83: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
        al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
        In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14:0,
        from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27,
        from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67,
        from ../../nan/nan.h:54,
        /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:3553:51: note: declared here
        V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
        declarator attribute((deprecated(message)))
        ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
        In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67:0,
        /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
        int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
        /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
        ../authenticate_pam.cc:152:69: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
        res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
        ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
        ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
        username->WriteUtf8(m->username, sizeof(m->username) - 1);
        ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
        password->WriteUtf8(m->password, sizeof(m->password) - 1);
        ../authenticate_pam.cc: At global scope:
        ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
        void init(Handle<Object> exports) {
        ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
        ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
        ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
        In file included from ../../nan/nan.h:54:0,
        ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
        NODE_MODULE(authenticate_pam, init);
        /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
        (node::addon_register_func) (regfunc),
        ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
        authenticate_pam.target.mk:111: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
        make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: make failed with exit code: 2
        gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.9.0-11-amd64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        gyp ERR! node -v v12.16.2
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! authenticate-pam@1.0.2 install: node-gyp rebuild
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the authenticate-pam@1.0.2 install script.
        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! /home/iobroker/.npm/_logs/2020-04-14T20_27_54_800Z-debug.log
        Alles läuft soweit ohne Errors bei mir ist der VW Connect Adapter das Problem. Bekomme fehler im Log und der Adapter Startet nicht.
        host.IoBroker 2020-04-14 22:30:58.371 info Restart adapter system.adapter.vw-connect.0 because enabled
        host.IoBroker 2020-04-14 22:30:58.371 error instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.IoBroker 2020-04-14 22:30:58.371 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
        host.IoBroker 2020-04-14 22:30:58.370 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: was compiled against a different Node.js version using
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: ^
        host.IoBroker 2020-04-14 22:30:58.369 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
        host.IoBroker 2020-04-14 22:30:58.368 error Caught by controller[0]: internal/modules/cjs/loader.js:1206
        host.IoBroker 2020-04-14 22:30:57.978 info instance system.adapter.vw-connect.0 started with pid 28748
        Hier komme ich nicht weiter.
        Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @cvidal last edited by Thomas Braun
          @cvidal Welche Version von node ist installiert?
          node -v
          nodejs -v
          Also root würde ich mich auch nicht anmelden.
          cvidal 1 Reply Last reply Reply Quote 0
            wie komme ich am dümmsten von v10.19 auf die 10.20, ohne den apt update && apt upgrade Befehl?
            Hintergrund,
            Bluetooth bekomme ich nicht mehr zum laufen, wenn ich die übliche Variante wähle. Daher bin ich erstmal wieder zurück via backup.
            • cvidal
              cvidal Forum Testing @Thomas Braun last edited by
              @Thomas-Braun Ich nutze 12.16.2, ich weiß wird noch nicht empfohlen aber das sollte dem Adapter nichts ausmachen.
                Thomas Braun Most Active @crunchip last edited by Thomas Braun
                @crunchip
                sudo apt install nodejs
                Ich würde aber schauen, dass die 10.20.1 angeboten wird. Die 10.20.0 hat einen Fehler.
                Bluetooth würde ich allerdings auch aktuell halten. Das Update kommt aus Security, das hat wohl einen Grund...
                crunchip 1 Reply Last reply Reply Quote 1
                  @cvidal Dann bin ich raus.
                  Permanent als root angemeldet und dann eine noch nicht vorgesehene Version macht Hilfe schwer.
                    apollon77 @Sneak-L8 last edited by
                    @Sneak-L8 Sehr interessant, da ist von der epoll 0.x nix zu sehen ... Dann halt der Harte weg:
                    Lösche mal /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll komplett. Dann gehst Du in /opt/iobroker/node_modules/rpi-gpio und sagst "npm install --production".
                    Dann versuch nochmal
                      apollon77 @cvidal last edited by
                      @cvidal sagte in [How-to] Node.js für ioBroker richtig updaten:
                      authenticate_pam
                      Versuch mal "apt install libpam0g-dev" und danach nochmal
                      • cvidal
                        cvidal Forum Testing @apollon77 last edited by cvidal
                        @apollon77 sagte in [How-to] Node.js für ioBroker richtig updaten:
                        authenticate_pam
                        Sollte ich das unter cd /opt/iobroker machen?
                        Edit: ich habe jetzt erstmal auf NodeJS 10.20.1 am laufen, das geht erst mal ohne Probleme. Node 12 werde ich erstmal die finger von lassen.
                        • cvidal
                          @Thomas-Braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                          Ist mein Testsystem, da versuche ich irgendwie alles mal, normal bin ich nicht dauerhaft als Root angemeldet.
                            Sneak-L8 @apollon77 last edited by Sneak-L8
                            @apollon77 Guten Morgen, hab ich gemacht. Das Löschen wir nur mit root-User möglich (also sudo rm -rf ...).
                            Aber schon der
                            schlägt wieder mit demselben Befehl fehl:
                            pi@ioBroker-RasPi:/opt/iobroker/node_modules/rpi-gpio $ npm install --production
                            npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                            npm WARN deprecated mkdirp@0.3.5: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                            npm WARN deprecated istanbul@0.2.7: This module is no longer maintained, try this instead:
                            npm WARN deprecated   npm i nyc
                            npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
                            npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                            npm WARN deprecated mkdirp@0.3.0: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                            npm WARN deprecated formatio@1.0.2: This package is unmaintained. Use @sinonjs/formatio instead
                            npm WARN deprecated graceful-fs@2.0.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                            npm WARN deprecated minimatch@0.4.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                            npm WARN deprecated samsam@1.1.3: This package has been deprecated in favour of @sinonjs/samsam
                            npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                            > epoll@0.1.22 install /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
                            > node-gyp rebuild
                            make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird betreten
                              CXX(target) Release/obj.target/epoll/src/epoll.o
                            In file included from ../../nan/nan.h:192:0,
                                             from ../src/epoll.cc:15:
                            /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
                               declarator __attribute__((deprecated(message)))
                            epoll.target.mk:103: die Regel für Ziel „Release/obj.target/epoll/src/epoll.o“ scheiterte
                            make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
                            make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird verlassen
                            gyp ERR! stack Error: `make` failed with exit code: 2
                            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                            gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                            gyp ERR! System Linux 4.14.34-v7+
                            gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
                            gyp ERR! node -v v10.20.1
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR! epoll@0.1.22 install: `node-gyp rebuild`
                            npm ERR!
                            npm ERR! Failed at the epoll@0.1.22 install script.
                            npm ERR!     /home/iobroker/.npm/_logs/2020-04-15T07_59_33_981Z-debug.log
                            Er will erneut epoll 0.1.22 installieren...
                              @Sneak-L8 Ok, dann noch härter:
                              Lösche /opt/iobroker/node_modules/rpi-gpio
                              gehe in /opt/iobroker/node_modules/iobroker.rpi2 und mache dort
                                Super, jetzt hat's geklappt! Vielen Dank!!
                                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                                  @Thomas-Braun das klappt so aber nicht
                                  • Glasfaser
                                    Glasfaser @crunchip last edited by
                                    @crunchip
                                    vorher eine .. machen , zur Paketenaktualisierung
                                    sudo apt update
                                      crunchip Forum Testing Most Active @Glasfaser last edited by
                                      @Glasfaser danke, hatte ich nicht dran gedacht
                                      • Glasfaser
                                        Glasfaser @crunchip last edited by Glasfaser
                                        @crunchip
                                          SolarGuido last edited by SolarGuido
                                          vertan... falscher Beitrag
                                            Jetzt wird es richtig wuschelig mit der js8 Version. Ich überlege auch upgrade auf js12 zu machen, wie sieht es damit aus? Gibt es dazu auch eine Anleitung? Gibt es für NPM auch dann eine Notwendigkeit diese upzugraden?
                                            Danke für jeden Hinweis!
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            736768
