    4. Beta Test js-controller 3.0.x auf GitHub
      apollon77 @Homer.J. last edited by
      @Homer-J Yahka 0.11.0 muss auch mit nodejs12 tun!
      Homer.J. 1 Reply Last reply Reply Quote 0
        apollon77 @Guest last edited by apollon77
        @ilovegym sagte in Beta Test js-controller 3.0.x auf GitHub:
        Virtualpowermeter
        ble: Ja interessant
        virtualpowermeter ist auch interessant. muss beides gefixt werden
          Kueppert last edited by Kueppert
          Hi @apollon77 ich habe das neuen Rebuild-Kommando mal für Zigbee ausgeführt. Habe folgenden Output erhalten. Gehört das hier her oder zum Adapter?
          root@ioBroker2:/opt/iobroker# iobroker stop
          root@ioBroker2:/opt/iobroker# iobroker rebuild zigbee
          npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
          In file included from ../src/./serialport.h:6,
                           from ../src/serialport.cpp:1:
          ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
          ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
          ../src/serialport.cpp: At global scope:
          ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
           SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
          ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
           SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
          In file included from ../../../nan/nan.h:54,
          /home/iobroker/.cache/node-gyp/13.12.0/include/node/node.h:618:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                 (node::addon_register_func) (regfunc),                          \
          /home/iobroker/.cache/node-gyp/13.12.0/include/node/node.h:652:3: note: in expansion of macro ‘NODE_MODULE_X’
             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(serialport, init);
          In file included from ../src/serialport.h:6,
                           from ../src/serialport_unix.cpp:2:
          ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
          ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
               snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
          ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
          ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
          ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
               snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
          ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
          In file included from ../src/poller.cpp:1:
          Ich erkenne aus den Meldungen nur, dass irgendwas nicht funbktioniert hat?
          Danke dir und vG, Thorsten
          PS: der Vollständigkeit halber auch Befehl Nr. 2:
          root@ioBroker2:/opt/iobroker# iobroker rebuild zigbee --install
          npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
          Rebuild zigbee done
          Der sah besser aus 🙂
            apollon77 @Kueppert last edited by
            @Kueppert Das andere waren auch nur warnungen. Aber mit dem --install scheint es teilweise besser zu tun. Wir hatten schon Fälle wo das eine besser war und manchmal das andere. Die gründe aufzuführen wäre recht technisch 😉 Daher haben wir einfach beides gebaut
              apollon77 last edited by
              Nach zwei Sentry Crash Reports habe ich hier die 3.0.9 Aka Latest RC2 für Euch auf Github:
              3.0.9 (2020-04-15) Release Elena
              • (Apollon77) fix reported crash on obsolete object deletion (Sentry IOBROKER-JS-CONTROLLER-8)
              • (Apollon77) fix reported crash when a new process can not be started because of ENOMEM (Sentry IOBROKER-JS-CONTROLLER-7)
              • (foxriver76) make sure errors are return the same in two places
              K ? 2 Replies Last reply Reply Quote 1
                Kueppert @apollon77 last edited by
                @apollon77 Update lief problemlos durch - mit folgenden Befehlszeilen (auch für alle, die sich mit dem Verzeichnis schwer tun nochmal zur Erinnerung):
                cd /opt/iobroker
                iobroker stop
                npm install ioBroker/ioBroker.js-controller
                (ggf. sudo nutzen, wenn man nicht mit root-Rechten unterwegs ist)
                  A Former User @apollon77 last edited by
                  @apollon77 Hi,
                  die 3.09 wirft recht häufig das hier raus, die Adapter stehen dann auf rot:
                  host.iobroker 2020-04-15 10:24:00.018 error instance system.adapter.freifunk.0 could not be started: Error: spawn ENOMEM
                  host.iobroker 2020-04-15 10:23:58.590 error instance system.adapter.enigma2.0 could not be started: Error: spawn ENOMEM
                  Betrifft auch Socketio, mihome-vacuum Adapter...
                  K ? apollon77 3 Replies Last reply Reply Quote 0
                    Kueppert @Guest last edited by Kueppert
                    @ilovegym hm...ich habe nur den MiHome-Vacuum, der läuft bei mir. Hab nur ein zwei warns gehabt:
                    mihome-vacuum.0	2020-04-15 10:26:14.963	info	(24740) create state for carpet_mode
                    mihome-vacuum.0	2020-04-15 10:26:13.437	info	(24740) set nächster Timer: Nicht verfügbar
                    mihome-vacuum.0	2020-04-15 10:26:13.007	info	(24740) Connected
                    mihome-vacuum.0	2020-04-15 10:26:12.968	info	(24740) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-04-15 10:26:12.967	warn	(24740) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2020-04-15 10:26:12.955	info	(24740) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                    mihome-vacuum.0	2020-04-15 10:26:12.912	info	(24740) Create state clean_home for controlling by cloud adapter
                    mihome-vacuum.0	2020-04-15 10:26:12.910	info	(24740) Expert mode disabled, states deleted
                    mihome-vacuum.0	2020-04-15 10:26:12.860	info	(24740) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v13.12.0, js-controller: 3.0.9
                    mihome-vacuum.0	2020-04-15 10:26:12.121	warn	(24740) This object will not be created in future versions. Please report this to the developer.
                    mihome-vacuum.0	2020-04-15 10:26:12.119	warn	(24740) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                    socketio läuft ohne Auffälligkeiten bei mir.
                      A Former User @Guest last edited by
                      @apollon77 Hi,
                      Reboot tat gut... danach war ruhe.. bis auf jede Menge warnings vom Socketio.. und web Adapter:
                      web.0 2020-04-15 10:49:56.703 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
                      web.0 2020-04-15 10:49:54.612 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
                      web.0 2020-04-15 10:49:46.704 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
                      web.0 2020-04-15 10:49:44.372 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
                      • Homer.J.
                        Homer.J. @apollon77 last edited by Homer.J.
                        @apollon77 läuft zwar ich kann aber nichts schalten es reagiert nichts. Bin auch erstmal wieder zurück auf die 10.20.1 Version.
                        Hab mal auf die 3.0.9 hochgezogen und die node.js 12... Installiert jetzt läuft es warum auch immer.
                        apollon77 2 Replies Last reply Reply Quote 0
                          e-i-k-e @apollon77 last edited by e-i-k-e
                          @apollon77
                          Gut möglich, jetzt läuft die 3.0.8er.
                          Anbei ein Auszug aus dem log, nachdem ich versucht habe diesen neu zu starten..
                          Slave:
                          2020-04-15 11:26:18.431  - info: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 (force=false, process=true)
                          2020-04-15 11:26:18.436  - info: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 send kill signal
                          2020-04-15 11:26:19.440  - info: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 killing pid 27154
                          2020-04-15 11:26:21.611  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7635
                          2020-04-15 11:26:27.195  - error: javascript.2 (7635) javascript.2 already running
                          2020-04-15 11:26:27.201  - warn: javascript.2 (7635) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2020-04-15 11:26:28.455  - error: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2020-04-15 11:26:28.456  - info: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled
                          2020-04-15 11:26:58.472  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7696
                          2020-04-15 11:27:02.372  - info: javascript.2 (27154) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          2020-04-15 11:27:03.439  - error: javascript.2 (7696) javascript.2 already running
                          2020-04-15 11:27:03.446  - warn: javascript.2 (7696) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2020-04-15 11:27:04.718  - error: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2020-04-15 11:27:04.719  - info: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled
                          2020-04-15 11:27:34.735  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7769
                          2020-04-15 11:27:39.805  - info: javascript.2 (7769) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8
                          2020-04-15 11:27:40.039  - info: javascript.2 (7769) requesting all states
                          2020-04-15 11:27:40.044  - info: javascript.2 (7769) requesting all objects
                          2020-04-15 11:27:40.045  - warn: javascript.2 (7769) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                          2020-04-15 11:27:43.854  - info: javascript.2 (7769) received all objects
                          2020-04-15 11:27:46.488  - info: javascript.2 (7769) received all states
                          2020-04-15 11:27:47.519  - info: javascript.2 (7769) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          2020-04-15 11:27:47.690  - info: javascript.2 (7769) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules
                          2020-04-15 11:28:01.522  - info: javascript.2 (27154) Got terminate signal TERMINATE_YOURSELF
                          2020-04-15 11:28:01.523  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          2020-04-15 11:28:01.524  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 7635 vs own PID 27154
                          2020-04-15 11:28:01.525  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          2020-04-15 11:28:01.526  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 7696 vs own PID 27154
                          2020-04-15 11:29:05.133  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          2020-04-15 11:29:05.135  - warn: javascript.2 (27154) Got terminate signal. Checking desired PID: 7769 vs own PID 27154
                          2020-04-15 11:29:05.153  - info: javascript.2 (27154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-04-15 11:30:07.086  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                          2020-04-15 11:30:07.088  - info: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled
                          2020-04-15 11:30:08.121  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 8043
                          2020-04-15 11:30:10.498  - warn: javascript.2 (7769) Got terminate signal. Checking desired PID: 0 vs own PID 7769
                          2020-04-15 11:30:10.503  - info: javascript.2 (7769) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          2020-04-15 11:30:10.506  - warn: javascript.2 (7769) Got terminate signal. Checking desired PID: 8043 vs own PID 7769
                          2020-04-15 11:30:10.521  - info: javascript.2 (7769) terminating
                          2020-04-15 11:30:10.522  - info: javascript.2 (7769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2020-04-15 11:30:13.072  - error: javascript.2 (8043) javascript.2 already running
                          2020-04-15 11:30:13.078  - warn: javascript.2 (8043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          2020-04-15 11:30:14.213  - error: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                          2020-04-15 11:30:14.214  - info: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled
                          2020-04-15 11:30:44.227  - info: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 8116
                          2020-04-15 11:30:49.289  - info: javascript.2 (8116) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8
                          2020-04-15 11:30:49.447  - info: javascript.2 (8116) requesting all states
                          2020-04-15 11:30:49.451  - info: javascript.2 (8116) requesting all objects
                          2020-04-15 11:30:49.453  - warn: javascript.2 (8116) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                          2020-04-15 11:30:53.281  - info: javascript.2 (8116) received all objects
                          2020-04-15 11:30:55.801  - info: javascript.2 (8116) received all states
                          2020-04-15 11:30:56.851  - info: javascript.2 (8116) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          2020-04-15 11:30:57.000  - info: javascript.2 (8116) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules
                          2020-04-15 11:31:04.118  - error: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated by request of the instance itself and will not be restarted, before user restarts it.
                          2020-04-15 11:31:04.119  - info: host.raspberrypi-display1 Do not restart adapter system.adapter.javascript.2 because desired by instance
                          Master:
                          javascript.2	2020-04-15 11:30:57.000	info	(8116) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules
                          javascript.2	2020-04-15 11:30:56.851	info	(8116) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          javascript.2	2020-04-15 11:30:55.801	info	(8116) received all states
                          javascript.2	2020-04-15 11:30:53.281	info	(8116) received all objects
                          javascript.2	2020-04-15 11:30:49.453	warn	(8116) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                          javascript.2	2020-04-15 11:30:49.451	info	(8116) requesting all objects
                          javascript.2	2020-04-15 11:30:49.447	info	(8116) requesting all states
                          javascript.2	2020-04-15 11:30:49.289	info	(8116) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8
                          javascript.2	2020-04-15 11:30:13.078	warn	(8043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          javascript.2	2020-04-15 11:30:13.072	error	(8043) javascript.2 already running
                          javascript.2	2020-04-15 11:30:10.522	info	(7769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          javascript.2	2020-04-15 11:30:10.521	info	(7769) terminating
                          javascript.2	2020-04-15 11:30:10.506	warn	(7769) Got terminate signal. Checking desired PID: 8043 vs own PID 7769
                          javascript.2	2020-04-15 11:30:10.503	info	(7769) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          javascript.2	2020-04-15 11:30:10.498	warn	(7769) Got terminate signal. Checking desired PID: 0 vs own PID 7769
                          javascript.2	2020-04-15 11:29:05.153	info	(27154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          javascript.2	2020-04-15 11:29:05.135	warn	(27154) Got terminate signal. Checking desired PID: 7769 vs own PID 27154
                          javascript.2	2020-04-15 11:29:05.133	warn	(27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          javascript.2	2020-04-15 11:28:01.526	warn	(27154) Got terminate signal. Checking desired PID: 7696 vs own PID 27154
                          javascript.2	2020-04-15 11:28:01.525	warn	(27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          javascript.2	2020-04-15 11:28:01.524	warn	(27154) Got terminate signal. Checking desired PID: 7635 vs own PID 27154
                          javascript.2	2020-04-15 11:28:01.523	warn	(27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154
                          javascript.2	2020-04-15 11:28:01.522	info	(27154) Got terminate signal TERMINATE_YOURSELF
                          javascript.2	2020-04-15 11:27:47.690	info	(7769) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules
                          javascript.2	2020-04-15 11:27:47.519	info	(7769) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          javascript.2	2020-04-15 11:27:46.488	info	(7769) received all states
                          javascript.2	2020-04-15 11:27:43.854	info	(7769) received all objects
                          javascript.2	2020-04-15 11:27:40.045	warn	(7769) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                          javascript.2	2020-04-15 11:27:40.044	info	(7769) requesting all objects
                          javascript.2	2020-04-15 11:27:40.039	info	(7769) requesting all states
                          javascript.2	2020-04-15 11:27:39.805	info	(7769) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8
                          javascript.2	2020-04-15 11:27:03.446	warn	(7696) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          javascript.2	2020-04-15 11:27:03.439	error	(7696) javascript.2 already running
                          javascript.2	2020-04-15 11:27:02.372	info	(27154) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten
                          javascript.2	2020-04-15 11:26:27.201	warn	(7635) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                          javascript.2	2020-04-15 11:26:27.195	error	(7635) javascript.2 already running
                            @apollon77 said in Beta Test js-controller 3.0.x auf GitHub:
                            @e-i-k-e Welche js-controller Version ist im Einsatz? Laut Log kam das vor als es noch die 2.2.9 war. Dann ab 17:47:49.463 war es der 3.0.8er controller und da gabs das nimmer. oder sehe ich was falsch?
                            @apollon77
                            Slave:
                            Master:
                              @ilovegym Aah dann bist Du das 🙂 bisher ist da immer der controller gecrasht. ENOMEM heisst das der Prozess nicht gestartet werden konnte weil kein RAM mehr frei ist ...
                              Schau Dir mal dein system genau an bzw reboote mal.
                                apollon77 @e-i-k-e last edited by
                                @e-i-k-e sagte in Beta Test js-controller 3.0.x auf GitHub:
                                Also bei mir sieht es so aus als ob die Instanz hier ein Problem beim stoppen hat. Hängt vllt irgendeins der Skripte oder so? In jedem Fall verhält sich das System laut Log korrekt.
                                Beim Slave sehe ich in dem Log Auszug:
                                • 11:26:19.440 controller sagt prozess 27154 er solle sich beenden
                                • 11:26:19.440 adapter hat nicht reagiert, controller sendet dem prozess ein kill signal 27154
                                • 11:26:21.611 controller startet neuen prozess (7635)
                                • 11:27:02.372 prozess 27154 meldet das er das erste Skript gestoppt hat
                                • 11:27:03.439 prozess 7635 beendet sich weil noch ein anderer läuft
                                • 11:27:34.735 controller startet neuen prozess (7769) ... der startet weil der andere Prozess ewig sein alive nicht mehr aktualisiert hat
                                  *11:28:01.522 prozess 27154 läuft immer noch und bekommt JETZT erst die Info über state changes vom 7635 start (1:40 Minuten später!!) und dnan alle
                                • 11:29:05.153 ENDLICH beendet sich 27154 (2:46 Minuten nachdem er den Kill befehl erhalten hat)
                                Alles in Allem schau ich mal was ich optimieren kann, aber fakt ist das irgendein Skript deine Instanz mega blockiert und damit alles durcheinander bringt ... Finde das Skript und fixe es 🙂
                                Um das Thema zu ohne Skript Fix zu beheben musst Du schauen das du stop drückst, wartest bis der alte prozess wirklich weg ist und dann neu startest.
                                  @ilovegym Versuch mal rauszufinden wann genau das kommt. Also welchen Visu adapter du aufrufen musst damit das im Log kommt. und dann bei dem ein "iobroker upload NAME" ausführen .
                                    @Homer-J sagte in Beta Test js-controller 3.0.x auf GitHub:
                                    Bitte Issue beim Adapter öffnen
                                      Log?
                                      • Homer.J.
                                        Hi @apollon77 Hab heut morgen die 3.0.9 Version installiert im Anschluss die Node.js auf die 12.. Version angehoben nochmal zur Sicherheit den Fixer drüber laufen lassen und seitdem läuft er.
                                          Jan1 last edited by
                                          Bei mir gibts zwar keine Fehler im Log und alle Adapter sind grün, aber einige Scripte haben gesponnen und der TR-064 findet keine Geräte mehr.
                                          Bin gerade dabei ein Backup zurück zuspielen um zu testen, ob es tatsächlich am JS liegt, oder sich einfach das System was eingefangen hat.
                                            @Homer-J Und Yahka tut?
                                            js-controller
                                            39
                                            416
                                            68555
