Beta Test js-controller 3.0.x auf GitHub
@ilovegym sagte in Beta Test js-controller 3.0.x auf GitHub:
Virtualpowermeter
ble: Ja interessant
virtualpowermeter ist auch interessant. muss beides gefixt werden -
Hi @apollon77 ich habe das neuen Rebuild-Kommando mal für Zigbee ausgeführt. Habe folgenden Output erhalten. Gehört das hier her oder zum Adapter?
root@ioBroker2:/opt/iobroker# iobroker stop root@ioBroker2:/opt/iobroker# iobroker rebuild zigbee npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.zigbee" In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1: ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~ ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’: ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~ ../src/serialport.cpp: At global scope: ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^ ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^ In file included from ../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1: /home/iobroker/.cache/node-gyp/13.12.0/include/node/node.h:618:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/13.12.0/include/node/node.h:652:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~ In file included from ../src/serialport.h:6, from ../src/serialport_unix.cpp:2: ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’: ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~ ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’: ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~ ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In file included from ../src/poller.cpp:1: ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^Ich erkenne aus den Meldungen nur, dass irgendwas nicht funbktioniert hat?
Danke dir und vG, ThorstenPS: der Vollständigkeit halber auch Befehl Nr. 2:
root@ioBroker2:/opt/iobroker# iobroker rebuild zigbee --install npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.zigbee" Rebuild zigbee doneDer sah besser aus
@Kueppert Das andere waren auch nur warnungen. Aber mit dem --install scheint es teilweise besser zu tun. Wir hatten schon Fälle wo das eine besser war und manchmal das andere. Die gründe aufzuführen wäre recht technisch
Daher haben wir einfach beides gebaut -
Nach zwei Sentry Crash Reports habe ich hier die 3.0.9 Aka Latest RC2 für Euch auf Github:
3.0.9 (2020-04-15) Release Elena
- (Apollon77) fix reported crash on obsolete object deletion (Sentry IOBROKER-JS-CONTROLLER-8)
- (Apollon77) fix reported crash when a new process can not be started because of ENOMEM (Sentry IOBROKER-JS-CONTROLLER-7)
- (foxriver76) make sure errors are return the same in two places
@apollon77 Update lief problemlos durch - mit folgenden Befehlszeilen (auch für alle, die sich mit dem Verzeichnis schwer tun nochmal zur Erinnerung):
cd /opt/iobroker iobroker stop npm install ioBroker/ioBroker.js-controller(ggf. sudo nutzen, wenn man nicht mit root-Rechten unterwegs ist)
@apollon77 Hi,
die 3.09 wirft recht häufig das hier raus, die Adapter stehen dann auf rot:host.iobroker 2020-04-15 10:24:00.018 error instance system.adapter.freifunk.0 could not be started: Error: spawn ENOMEM
host.iobroker 2020-04-15 10:23:58.590 error instance system.adapter.enigma2.0 could not be started: Error: spawn ENOMEMBetrifft auch Socketio, mihome-vacuum Adapter...
@ilovegym hm...ich habe nur den MiHome-Vacuum, der läuft bei mir. Hab nur ein zwei warns gehabt:
mihome-vacuum.0 2020-04-15 10:26:14.963 info (24740) create state for carpet_mode mihome-vacuum.0 2020-04-15 10:26:13.437 info (24740) set nächster Timer: Nicht verfügbar mihome-vacuum.0 2020-04-15 10:26:13.007 info (24740) Connected mihome-vacuum.0 2020-04-15 10:26:12.968 info (24740) connecting, this can take up to 10 minutes ... mihome-vacuum.0 2020-04-15 10:26:12.967 warn (24740) Time difference between Mihome Vacuum and ioBroker: 1 sec mihome-vacuum.0 2020-04-15 10:26:12.955 info (24740) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean mihome-vacuum.0 2020-04-15 10:26:12.912 info (24740) Create state clean_home for controlling by cloud adapter mihome-vacuum.0 2020-04-15 10:26:12.910 info (24740) Expert mode disabled, states deleted mihome-vacuum.0 2020-04-15 10:26:12.860 info (24740) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v13.12.0, js-controller: 3.0.9 mihome-vacuum.0 2020-04-15 10:26:12.121 warn (24740) This object will not be created in future versions. Please report this to the developer. mihome-vacuum.0 2020-04-15 10:26:12.119 warn (24740) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, jsonsocketio läuft ohne Auffälligkeiten bei mir.
@apollon77 Hi,
Reboot tat gut... danach war ruhe.. bis auf jede Menge warnings vom Socketio.. und web Adapter:
web.0 2020-04-15 10:49:56.703 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
web.0 2020-04-15 10:49:54.612 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
web.0 2020-04-15 10:49:46.704 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta"
web.0 2020-04-15 10:49:44.372 warn readFile will not read this file (index.html) in future versions: socket.io is not an object of type "meta" -
@apollon77 läuft zwar ich kann aber nichts schalten es reagiert nichts. Bin auch erstmal wieder zurück auf die 10.20.1 Version.
Hab mal auf die 3.0.9 hochgezogen und die node.js 12... Installiert jetzt läuft es warum auch immer. -
@apollon77
Gut möglich, jetzt läuft die 3.0.8er.
Anbei ein Auszug aus dem log, nachdem ich versucht habe diesen neu zu starten..
Slave:
2020-04-15 11:26:18.431 - [32minfo[39m: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 (force=false, process=true) 2020-04-15 11:26:18.436 - [32minfo[39m: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 send kill signal 2020-04-15 11:26:19.440 - [32minfo[39m: host.raspberrypi-display1 stopInstance system.adapter.javascript.2 killing pid 27154 2020-04-15 11:26:21.611 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7635 2020-04-15 11:26:27.195 - [31merror[39m: javascript.2 (7635) javascript.2 already running 2020-04-15 11:26:27.201 - [33mwarn[39m: javascript.2 (7635) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2020-04-15 11:26:28.455 - [31merror[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2020-04-15 11:26:28.456 - [32minfo[39m: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled 2020-04-15 11:26:58.472 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7696 2020-04-15 11:27:02.372 - [32minfo[39m: javascript.2 (27154) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten 2020-04-15 11:27:03.439 - [31merror[39m: javascript.2 (7696) javascript.2 already running 2020-04-15 11:27:03.446 - [33mwarn[39m: javascript.2 (7696) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2020-04-15 11:27:04.718 - [31merror[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2020-04-15 11:27:04.719 - [32minfo[39m: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled 2020-04-15 11:27:34.735 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 7769 2020-04-15 11:27:39.805 - [32minfo[39m: javascript.2 (7769) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8 2020-04-15 11:27:40.039 - [32minfo[39m: javascript.2 (7769) requesting all states 2020-04-15 11:27:40.044 - [32minfo[39m: javascript.2 (7769) requesting all objects 2020-04-15 11:27:40.045 - [33mwarn[39m: javascript.2 (7769) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer! 2020-04-15 11:27:43.854 - [32minfo[39m: javascript.2 (7769) received all objects 2020-04-15 11:27:46.488 - [32minfo[39m: javascript.2 (7769) received all states 2020-04-15 11:27:47.519 - [32minfo[39m: javascript.2 (7769) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten 2020-04-15 11:27:47.690 - [32minfo[39m: javascript.2 (7769) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules 2020-04-15 11:28:01.522 - [32minfo[39m: javascript.2 (27154) Got terminate signal TERMINATE_YOURSELF 2020-04-15 11:28:01.523 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 2020-04-15 11:28:01.524 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 7635 vs own PID 27154 2020-04-15 11:28:01.525 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 2020-04-15 11:28:01.526 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 7696 vs own PID 27154 2020-04-15 11:29:05.133 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 2020-04-15 11:29:05.135 - [33mwarn[39m: javascript.2 (27154) Got terminate signal. Checking desired PID: 7769 vs own PID 27154 2020-04-15 11:29:05.153 - [32minfo[39m: javascript.2 (27154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason 2020-04-15 11:30:07.086 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP) 2020-04-15 11:30:07.088 - [32minfo[39m: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled 2020-04-15 11:30:08.121 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 8043 2020-04-15 11:30:10.498 - [33mwarn[39m: javascript.2 (7769) Got terminate signal. Checking desired PID: 0 vs own PID 7769 2020-04-15 11:30:10.503 - [32minfo[39m: javascript.2 (7769) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten 2020-04-15 11:30:10.506 - [33mwarn[39m: javascript.2 (7769) Got terminate signal. Checking desired PID: 8043 vs own PID 7769 2020-04-15 11:30:10.521 - [32minfo[39m: javascript.2 (7769) terminating 2020-04-15 11:30:10.522 - [32minfo[39m: javascript.2 (7769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2020-04-15 11:30:13.072 - [31merror[39m: javascript.2 (8043) javascript.2 already running 2020-04-15 11:30:13.078 - [33mwarn[39m: javascript.2 (8043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2020-04-15 11:30:14.213 - [31merror[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2020-04-15 11:30:14.214 - [32minfo[39m: host.raspberrypi-display1 Restart adapter system.adapter.javascript.2 because enabled 2020-04-15 11:30:44.227 - [32minfo[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 started with pid 8116 2020-04-15 11:30:49.289 - [32minfo[39m: javascript.2 (8116) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8 2020-04-15 11:30:49.447 - [32minfo[39m: javascript.2 (8116) requesting all states 2020-04-15 11:30:49.451 - [32minfo[39m: javascript.2 (8116) requesting all objects 2020-04-15 11:30:49.453 - [33mwarn[39m: javascript.2 (8116) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer! 2020-04-15 11:30:53.281 - [32minfo[39m: javascript.2 (8116) received all objects 2020-04-15 11:30:55.801 - [32minfo[39m: javascript.2 (8116) received all states 2020-04-15 11:30:56.851 - [32minfo[39m: javascript.2 (8116) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten 2020-04-15 11:30:57.000 - [32minfo[39m: javascript.2 (8116) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules 2020-04-15 11:31:04.118 - [31merror[39m: host.raspberrypi-display1 instance system.adapter.javascript.2 terminated by request of the instance itself and will not be restarted, before user restarts it. 2020-04-15 11:31:04.119 - [32minfo[39m: host.raspberrypi-display1 Do not restart adapter system.adapter.javascript.2 because desired by instanceMaster:
javascript.2 2020-04-15 11:30:57.000 info (8116) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules javascript.2 2020-04-15 11:30:56.851 info (8116) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten javascript.2 2020-04-15 11:30:55.801 info (8116) received all states javascript.2 2020-04-15 11:30:53.281 info (8116) received all objects javascript.2 2020-04-15 11:30:49.453 warn (8116) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer! javascript.2 2020-04-15 11:30:49.451 info (8116) requesting all objects javascript.2 2020-04-15 11:30:49.447 info (8116) requesting all states javascript.2 2020-04-15 11:30:49.289 info (8116) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8 javascript.2 2020-04-15 11:30:13.078 warn (8043) Terminated (ADAPTER_ALREADY_RUNNING): Without reason javascript.2 2020-04-15 11:30:13.072 error (8043) javascript.2 already running javascript.2 2020-04-15 11:30:10.522 info (7769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason javascript.2 2020-04-15 11:30:10.521 info (7769) terminating javascript.2 2020-04-15 11:30:10.506 warn (7769) Got terminate signal. Checking desired PID: 8043 vs own PID 7769 javascript.2 2020-04-15 11:30:10.503 info (7769) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten javascript.2 2020-04-15 11:30:10.498 warn (7769) Got terminate signal. Checking desired PID: 0 vs own PID 7769 javascript.2 2020-04-15 11:29:05.153 info (27154) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason javascript.2 2020-04-15 11:29:05.135 warn (27154) Got terminate signal. Checking desired PID: 7769 vs own PID 27154 javascript.2 2020-04-15 11:29:05.133 warn (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 javascript.2 2020-04-15 11:28:01.526 warn (27154) Got terminate signal. Checking desired PID: 7696 vs own PID 27154 javascript.2 2020-04-15 11:28:01.525 warn (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 javascript.2 2020-04-15 11:28:01.524 warn (27154) Got terminate signal. Checking desired PID: 7635 vs own PID 27154 javascript.2 2020-04-15 11:28:01.523 warn (27154) Got terminate signal. Checking desired PID: 0 vs own PID 27154 javascript.2 2020-04-15 11:28:01.522 info (27154) Got terminate signal TERMINATE_YOURSELF javascript.2 2020-04-15 11:27:47.690 info (7769) script.js.Raspberry.Bildschirm_über_BWM_Flur_unten: registered 3 subscriptions and 0 schedules javascript.2 2020-04-15 11:27:47.519 info (7769) Start javascript script.js.Raspberry.Bildschirm_über_BWM_Flur_unten javascript.2 2020-04-15 11:27:46.488 info (7769) received all states javascript.2 2020-04-15 11:27:43.854 info (7769) received all objects javascript.2 2020-04-15 11:27:40.045 warn (7769) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer! javascript.2 2020-04-15 11:27:40.044 info (7769) requesting all objects javascript.2 2020-04-15 11:27:40.039 info (7769) requesting all states javascript.2 2020-04-15 11:27:39.805 info (7769) starting. Version 4.4.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v10.20.0, js-controller: 3.0.8 javascript.2 2020-04-15 11:27:03.446 warn (7696) Terminated (ADAPTER_ALREADY_RUNNING): Without reason javascript.2 2020-04-15 11:27:03.439 error (7696) javascript.2 already running javascript.2 2020-04-15 11:27:02.372 info (27154) Stop script script.js.Raspberry.Bildschirm_über_BWM_Flur_unten javascript.2 2020-04-15 11:26:27.201 warn (7635) Terminated (ADAPTER_ALREADY_RUNNING): Without reason javascript.2 2020-04-15 11:26:27.195 error (7635) javascript.2 already running -
@apollon77 said in Beta Test js-controller 3.0.x auf GitHub:
@e-i-k-e Welche js-controller Version ist im Einsatz? Laut Log kam das vor als es noch die 2.2.9 war. Dann ab 17:47:49.463 war es der 3.0.8er controller und da gabs das nimmer. oder sehe ich was falsch?
@apollon77
Slave:
@ilovegym Aah dann bist Du das
bisher ist da immer der controller gecrasht. ENOMEM heisst das der Prozess nicht gestartet werden konnte weil kein RAM mehr frei ist ...Schau Dir mal dein system genau an bzw reboote mal.
@e-i-k-e sagte in Beta Test js-controller 3.0.x auf GitHub:
Also bei mir sieht es so aus als ob die Instanz hier ein Problem beim stoppen hat. Hängt vllt irgendeins der Skripte oder so? In jedem Fall verhält sich das System laut Log korrekt.
Beim Slave sehe ich in dem Log Auszug:- 11:26:19.440 controller sagt prozess 27154 er solle sich beenden
- 11:26:19.440 adapter hat nicht reagiert, controller sendet dem prozess ein kill signal 27154
- 11:26:21.611 controller startet neuen prozess (7635)
- 11:27:02.372 prozess 27154 meldet das er das erste Skript gestoppt hat
- 11:27:03.439 prozess 7635 beendet sich weil noch ein anderer läuft
- 11:27:34.735 controller startet neuen prozess (7769) ... der startet weil der andere Prozess ewig sein alive nicht mehr aktualisiert hat
*11:28:01.522 prozess 27154 läuft immer noch und bekommt JETZT erst die Info über state changes vom 7635 start (1:40 Minuten später!!) und dnan alle - 11:29:05.153 ENDLICH beendet sich 27154 (2:46 Minuten nachdem er den Kill befehl erhalten hat)
Alles in Allem schau ich mal was ich optimieren kann, aber fakt ist das irgendein Skript deine Instanz mega blockiert und damit alles durcheinander bringt ... Finde das Skript und fixe es
Um das Thema zu ohne Skript Fix zu beheben musst Du schauen das du stop drückst, wartest bis der alte prozess wirklich weg ist und dann neu startest.
@ilovegym Versuch mal rauszufinden wann genau das kommt. Also welchen Visu adapter du aufrufen musst damit das im Log kommt. und dann bei dem ein "iobroker upload NAME" ausführen .
@Homer-J sagte in Beta Test js-controller 3.0.x auf GitHub:
Bitte Issue beim Adapter öffnen
Log?
Hi @apollon77 Hab heut morgen die 3.0.9 Version installiert im Anschluss die Node.js auf die 12.. Version angehoben nochmal zur Sicherheit den Fixer drüber laufen lassen und seitdem läuft er.
Bei mir gibts zwar keine Fehler im Log und alle Adapter sind grün, aber einige Scripte haben gesponnen und der TR-064 findet keine Geräte mehr.
Bin gerade dabei ein Backup zurück zuspielen um zu testen, ob es tatsächlich am JS liegt, oder sich einfach das System was eingefangen hat. -
@Homer-J Und Yahka tut?
@Jan1 Hm ... ohne Details schwierig
