    4. [Vorstellung] Meine dritte VIS
      Kuddel last edited by
      @hofmannha
      CPU: info.0.sysinfo.cpu.currentLoad.currentload
      RAM: javascript.0.ressourcen.iobroker.iobroker_ram_usage
      Skript zum umrechen:
       <variables>
         <variable type="" id="O.j^v!]+^bg2::gZwGtK">ram_total</variable>
         <variable type="" id="7pyA@#Kp~LlnIk[brWNK">ram_usage</variable>
       </variables>
       <block type="comment" id="?B=ttbjkwQuxKt39J3FR" x="-562" y="-487">
         <field name="COMMENT">Iobroker RAM Nutzung</field>
           <block type="variables_set" id="MR[RP)5PGL(?D3{_J^ZV">
             <field name="VAR" id="O.j^v!]+^bg2::gZwGtK" variabletype="">ram_total</field>
               <block type="get_value" id="(~k.kk2Ym/]k1wlVUzfL">
                 <field name="OID">info.0.sysinfo.memory.info.total</field>
               <block type="on_ext" id="D){=B{N1D:@hKDX8IEE)" collapsed="true">
                 <value name="OID0">
                   <shadow type="field_oid" id="!F8cVi!af9@O4ndgQ2Dy">
                     <field name="oid">info.0.sysinfo.memory.info.active</field>
                   <block type="variables_set" id="DqE?8a)v}]p](dvT5LJE">
                     <field name="VAR" id="7pyA@#Kp~LlnIk[brWNK" variabletype="">ram_usage</field>
                       <block type="math_arithmetic" id="dGE8$h_)T%@95z=EgK$|">
                           <shadow type="math_number" id="@rLNGf@%a[-Nb5%qo]VI">
                             <field name="NUM">100</field>
                           <shadow type="math_number" id="bmfleZldj$g`/dmoU6me">
                           <block type="math_arithmetic" id="D:0$i;Dk,i-7-t$upkmR" inline="false">
                             <field name="OP">DIVIDE</field>
                               <shadow type="math_number" id="6qH+TvdFHfOos4m:IAD/">
                               <block type="get_value" id="l*m$n38G[LfM^|G1+~L_">
                                 <field name="OID">info.0.sysinfo.memory.info.used</field>
                               <shadow type="math_number" id="4;sclejA}gIFJ,gBkbnB">
                               <block type="variables_get" id="dvctta$?gNNV#!?9N2S,">
                       <block type="control" id="OPCg|}Ap[_^8V@2v2{NI">
                         <field name="OID">javascript.0.ressourcen.iobroker.iobroker_ram_usage</field>
                           <block type="variables_get" id="Se~R9^}TMu=:F7~kbL7J">
        hofmannha @Kuddel last edited by
        @Kuddel
        Hallo Kuddel,
        vielen Dank für deine Antwort. Wie wird das Script aufgerufen. Irgendwie blicke ich da nicht durch.
        Ich kriege eine Ram Auslastung von 168%. Was muß ich da machen?
        Eine Linie sehe ich auch nicht im Diagramm.
          Kuddel @hofmannha last edited by
          @hofmannha das aufzeichnen der werte mit dem History Adapter hast du aktiviert ?
          Das Skript wird jedes mal gestartet, wenn sich der Wert "Memory Active" vom Info Adapter ändert
            @Kuddel
            Die Aufzeichnung hatte ich aktiviert.
              @Kuddel
              Ich habe mal die Daten in den Objekten angehängt.
                hofmannha @hofmannha last edited by
                @hofmannha sagte in [Vorstellung] Meine dritte VIS:
                @Kuddel
                Bei mir werden nur Werte aufgezeichnet, wenn der Wert sich ändert. Aber die Werte ändern sich nicht, das ist das Problem.
                  @hofmannha wenn sie die Werte nicht ändern, dann läuft dein Info Adapter nicht korrekt
                    @Kuddel
                    Guten Morgen Kuddel,
                    könntest Du meine Einstellungen im Flot-Editor mal mit deinen vergleichen.
                    Ich bin kein Flot-Spezialist.
                    Gruß und Danke für die bisherige Info
                      @Kuddel
                      hier ist standardmäßig ein Haken gesetzt.
                      Der muß doch sicherlich entfernt werden?
                      • V
                        vsa last edited by
                        Hallo alle zusammen hier,
                        auch ich lerne hier almählich hinzu, jedoch mit der VIS habe ich mich leider nur minimal bisher beschäftigt. Vielleicht kann mir jemand von Euch auf die Sprünge helfen (voll Anfänger diesbezüglich, sorry.) Ganz am Anfang (vielleicht hilft das weiteren Beginnern dann auch...)
                        VIS_v3 vom 24.02.2020: VIS_V3.zip
                        Icons: Meine_Icons.rar
                        1. Meine_Icons.rar entpacken
                        2. VIS_v3.zip entpacken
                        3. Die beiden VIS-Datein und die den Icons Ordner zu einem neuen Zip Archiv >zusammefügen
                        4. Das neue Zip archiv importieren
                        5. Wie gewohnt im VIS Editor importieren
                        Punkt 3: Mein Zip ist gepackt. Sind die zwei Files von VIS_v3 innerhalb von "Meine Icons" Ordner oder außerhalb (oder ist das völlig egal?)
                        Punkt 4: Das neue Zip-Archiv dann via Dateibrowser importieren geht (so war es wohl gemeint, oder?). -> In welchem Verzeichnis soll es dann liegen? vis.0?
                        Punkt5: Ich denke, es ist schon unter Punkt 4 via Dateibrwoser importiert worden... wie ist das hier gemeint? Es muss ja irgendwie wohl entpackt werden?
                        Wäre toll, wenn jmd von Euch diese völligen Anfängerfragen beantworten könnte (mit den Javascipts/Blockys komme ich deutlich besser zurecht...)
                        Danke, vsa
                          Kuddel @vsa last edited by
                          @vsa mach mal einen Screenshot von deinem Archiv, ob die Struktur so richtig ist.
                          Du sollst das Archiv im VIS Editor importieren. Habe ich vllt. ein wenig unglücklich formuliert;
                          • V
                            vsa last edited by
                            Hallo Kuddel,
                            danke schon mal. So sieht bei mir das zusammengefügte ZIP aus.
                              @Kuddel
                              Hallo Kuddel,
                              ich hoffe, dass ich diesmal eine Antwort von Dir bekomme.
                              In welchem Script befindet sich diese Berrechnung ccu.ccu_cpu_usage.
                              Bei mir läuft Homematic auf einem anderen Raspberry.
                                @Kuddel
                                ja genau, ich habe den haken auch nicht gesetzt
                                  @vsa bei mir sieht der Export so aus:
                                    @hofmannha remote_abfragen heißt das Skript:
                                      Corallus last edited by Corallus
                                      Hallo Kuddel
                                      zuerst mal vielen dank das du deine Arbeit Online stellst, du hilfst mir damit sehr.
                                      Ich habe dein Projekt Importiert das einzige was ich momentan nicht finde ist der Speedtest.
                                      Ich habe hier keine Objekte mit den Namen Speedtest drin
                                      Kannst du mir bitte weiterhelfen
                                      javascript.0.Speed-Test.data.speeds.upload
                                      Vielen dank
                                      Glasfaser K 2 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        Glasfaser @Corallus last edited by
                                        @Corallus
                                        Du mußt das Skript Speedtest einmal starten , dann werden auch die Datenpunkte erzeugt !
                                          @Kuddel
                                          vielen vielen Dank für deine Info.
                                          Hast Du ioBroker auf zwei unterschiedlichen Systemen laufen?
                                            Kuddel @Corallus last edited by
                                            @Corallus dir fehlt der speed-test Adapter
                                            vis vis projekte
                                            83
                                            640
                                            172283
