    4. Beta Test js-controller 3.0.x auf GitHub
      Kueppert @apollon77 last edited by
      @apollon77 Update unauffällig - was auffällt, dass viel weniger Einträge im Log sind
        A Former User @apollon77 last edited by
        @apollon77 Die einzigen Warnings kommen jetzt nur noch von broadlink, admin, mihome-vacuum. Ansonsten sehr ruhig.
        Dankeschön!
        Löschen des Adapters Onvif brachte folgendes:
        readFile	2020-04-17 19:50:35.081	warn	will not read this file (openuv.png) in future versions: openuv.admin is not an object of type "meta"
        host.iobroker	2020-04-17 19:50:34.522	info	iobroker exit 0
        host.iobroker	2020-04-17 19:50:33.521	error	iobroker Error deleting adapter onvif from disk: Error: host.iobroker: Cannot uninstall iobroker.onvif: 1You might have to delete it yourself!
        host.iobroker	2020-04-17 19:50:33.492	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-04-17T17_50_33_448Z-debug.log
        host.iobroker	2020-04-17 19:50:33.491	info	iobroker
        host.iobroker	2020-04-17 19:50:33.439	info	iobroker Could not install from "node_modules/iobroker-react-components" as it does not contain a package.json file.
        host.iobroker	2020-04-17 19:50:33.438	info	iobroker npm ERR!
        host.iobroker	2020-04-17 19:50:33.437	info	iobroker ERR! code ENOLOCAL
        host.iobroker	2020-04-17 19:50:33.436	info	iobroker npm
        host.iobroker	2020-04-17 19:50:15.039	info	iobroker WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        host.iobroker	2020-04-17 19:50:15.038	info	iobroker npm
        javascript.0	2020-04-17 19:50:00.006	info	(3369) script.js.common.Message.LebensmittelwarnungTabelle: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/hessen.rss eingelesen
        host.iobroker	2020-04-17 19:49:58.672	info	iobroker npm uninstall iobroker.onvif --error --prefix "/opt/iobroker" (System call)
        host.iobroker	2020-04-17 19:49:58.593	info	object deleted system.adapter.onvif.0
        host.iobroker	2020-04-17 19:49:51.322	error	Cannot write files: /opt/iobroker/iobroker-data/files/onvif.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/onvif.admin/_data.json'
        host.iobroker	2020-04-17 19:49:50.330	info	iobroker host.iobroker Deleting 88 object(s).
        host.iobroker	2020-04-17 19:49:50.329	info	iobroker host.iobroker object onvif.admin deleted
        host.iobroker	2020-04-17 19:49:50.323	info	iobroker host.iobroker file onvif.admin deleted
        readDir	2020-04-17 19:49:50.316	warn	will not read this directory () in future versions: onvif is not an object of type "meta"
        host.iobroker	2020-04-17 19:49:50.209	info	iobroker host.iobroker Counted 14 states of system.adapter.onvif
        host.iobroker	2020-04-17 19:49:50.196	info	iobroker host.iobroker Counted 57 states of onvif
        host.iobroker	2020-04-17 19:49:50.175	info	iobroker host.iobroker Counted 14 devices of onvif
        host.iobroker	2020-04-17 19:49:50.164	info	iobroker host.iobroker Counted 1 adapter for onvif
        host.iobroker	2020-04-17 19:49:50.162	info	iobroker host.iobroker Counted 1 meta of onvif
        host.iobroker	2020-04-17 19:49:50.151	info	iobroker host.iobroker Counted 1 instances of onvif
        host.iobroker	2020-04-17 19:49:50.132	info	iobroker Delete adapter "onvif"
        host.iobroker	2020-04-17 19:49:49.118	info	iobroker del onvif
        Ansicht in Admin (Refresh gemacht):
        Verzeichnis in iobroker-data/files ist weg.
        Verzeichnis in node_modules ist noch komplett da:
        ilovegym@iobroker /opt/iobroker $ ls node_modules/iobroker.onvif
        admin        iob_npm.done     lib      main.js       package.json       README.md  tsconfig.json
        gulpfile.js  io-package.json  LICENSE  main.test.js  package-lock.json  test
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
          apollon77 @Kueppert last edited by
          @Kueppert Wie weiteroben schon gesagt: Das kommt wenn davon das Ihr ggf weitere Adapter aus Latest aktualisiert ... ich gehe gerade die am meisten verwendeten durch.
            apollon77 @Guest last edited by
            @ilovegym sagte in Beta Test js-controller 3.0.x auf GitHub:
            Da liegt der "Hase im Pfeffer begraben" 🙂 Dieses node-js modul kann er nicht sauber bearbeiten und daher kommt ein npm fehler und daher bleibt der Adater Code da.
            Dieses Modul kommt vom ble adapter. Am besten lösch das genannte Verzeichnis (/opt/iobroker/node_modules/iobroker-react-components) und installier ble nochmal neu.
            Hat nichts mit dem Controller zu tun.
              Kueppert last edited by Kueppert
              Hm,
              hab jetzt doch relativ viele neue Fehlermeldungen, die vorher nicht da waren die letzten Tage. Bin mir aber nicht sicher, ob die wirklich vom Update kommen 😕
              javascript.0	2020-04-17 20:31:12.957	error	(26164) at processTicksAndRejections (internal/process/task_queues.js:97:5)
              javascript.0	2020-04-17 20:31:12.956	error	(26164) at runMicrotasks (<anonymous>:null:null)
              javascript.0	2020-04-17 20:31:12.956	error	(26164) at script.js.common.Sonstiges.UnifiAdapterErsatz-Skript:514:27
              javascript.0	2020-04-17 20:31:12.956	error	(26164) at Array.sort (<anonymous>:null:null)
              javascript.0	2020-04-17 20:31:12.955	error	(26164) at script.js.common.Sonstiges.UnifiAdapterErsatz-Skript:515:23
              javascript.0	2020-04-17 20:31:12.954	error	(26164) script.js.common.Sonstiges.UnifiAdapterErsatz-Skript: TypeError: Cannot read property 'toLowerCase' of undefined
              host.ioBroker2	2020-04-17 20:30:09.312	error	Caught by controller[0]: (node:27881) PromiseRejectionHandledWarning: Promise rejection was handled asynchronously (rejection id: 1)
              zigbee.0	2020-04-17 20:30:08.505	error	(27881) Error: Timeout - 102 - 11 - 9 - 0 - 1 after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at list
              zigbee.0	2020-04-17 20:30:08.504	error	(27881) uncaught exception: Timeout - 102 - 11 - 9 - 0 - 1 after 10000ms
              zigbee.0	2020-04-17 20:24:14.211	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
              zigbee.0	2020-04-17 20:24:14.211	error	at Generator.throw (<anonymous>)
              zigbee.0	2020-04-17 20:24:14.211	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:349:23)
              zigbee.0	2020-04-17 20:24:14.211	error	(22374) Error on send command to 0x8418260000000712. Error: Error: Command 0x8418260000000712/3 genLevelCtrl.moveToLevelWithOnOff({"level":38,"transtime":0}, {"timeout":10000,"manufacturerCode":null,
              zigbee.0	2020-04-17 20:24:13.959	error	at processTimers (internal/timers.js:492:7)
              zigbee.0	2020-04-17 20:24:13.959	error	at listOnTimeout (internal/timers.js:549:17)
              zigbee.0	2020-04-17 20:24:13.959	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
              zigbee.0	2020-04-17 20:24:13.959	error	(22374) Error: Timeout - 1681 - 3 - 8 - 8 - 11 after 10000ms
              zigbee.0	2020-04-17 20:24:13.958	error	(22374) uncaught exception: Timeout - 1681 - 3 - 8 - 8 - 11 after 10000ms
              zigbee.0	2020-04-17 20:19:32.438	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
              zigbee.0	2020-04-17 20:19:32.438	error	at Generator.throw (<anonymous>)
              zigbee.0	2020-04-17 20:19:32.438	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:349:23)
              zigbee.0	2020-04-17 20:19:32.438	error	(21232) Error on send command to 0x0017880102b1973c. Error: Error: Command 0x0017880102b1973c/11 genLevelCtrl.moveToLevelWithOnOff({"level":76,"transtime":0}, {"timeout":10000,"manufacturerCode":null
              zigbee.0	2020-04-17 20:19:32.190	error	at processTimers (internal/timers.js:492:7)
              zigbee.0	2020-04-17 20:19:32.190	error	at listOnTimeout (internal/timers.js:549:17)
              zigbee.0	2020-04-17 20:19:32.190	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
              zigbee.0	2020-04-17 20:19:32.190	error	(21232) Error: Timeout - 102 - 11 - 2 - 8 - 11 after 10000ms
              zigbee.0	2020-04-17 20:19:32.189	error	(21232) uncaught exception: Timeout - 102 - 11 - 2 - 8 - 11 after 10000ms
              zigbee.0	2020-04-17 20:18:28.748	error	at processTimers (internal/timers.js:492:7)
              zigbee.0	2020-04-17 20:18:28.748	error	at listOnTimeout (internal/timers.js:549:17)
              zigbee.0	2020-04-17 20:18:28.748	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
              zigbee.0	2020-04-17 20:18:28.748	error	(14838) Error: Timeout - 23637 - 1 - 4 - 0 - 1 after 10000ms
              zigbee.0	2020-04-17 20:18:28.747	error	(14838) uncaught exception: Timeout - 23637 - 1 - 4 - 0 - 1 after 10000ms
              zigbee.0	2020-04-17 20:12:36.378	error	at processTimers (internal/timers.js:492:7)
              zigbee.0	2020-04-17 20:12:36.378	error	at listOnTimeout (internal/timers.js:549:17)
              zigbee.0	2020-04-17 20:12:36.378	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
              zigbee.0	2020-04-17 20:12:36.378	error	(29864) Error: Timeout - 1681 - 3 - 20 - 0 - 1 after 10000ms
              zigbee.0	2020-04-17 20:12:36.377	error	(29864) uncaught exception: Timeout - 1681 - 3 - 20 - 0 - 1 after 10000ms
              Ich werd die ganze Kiste (inkl. Proxmox) mal neu booten...
              Chaot apollon77 2 Replies Last reply Reply Quote 0
              • Chaot
                Chaot @Kueppert last edited by
                @Kueppert Die Fehlermeldungen im Unifi Script habe ich auch seit V. 3.0.9 soweit ich mich erinnere
                  Mist,
                  rebuild vom Zigbee hat auch nix geholfen 😞
                  zigbee.0	2020-04-17 20:47:11.658	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
                  zigbee.0	2020-04-17 20:47:11.658	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
                  zigbee.0	2020-04-17 20:47:11.658	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                  zigbee.0	2020-04-17 20:47:11.658	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                  zigbee.0	2020-04-17 20:47:11.658	error	at new Promise (<anonymous>)
                  zigbee.0	2020-04-17 20:47:11.658	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                  zigbee.0	2020-04-17 20:47:11.658	error	at Generator.next (<anonymous>)
                  zigbee.0	2020-04-17 20:47:11.658	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                  zigbee.0	2020-04-17 20:47:11.658	error	(9723) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-her
                  zigbee.0	2020-04-17 20:47:11.657	error	(9723) Failed to start Zigbee
                  zigbee.0	2020-04-17 20:47:11.422	info	(9723) Starting Zigbee...
                  zigbee.0	2020-04-17 20:47:11.421	info	(9723) Try to reconnect. 1 attempts left
                  zigbee.0	2020-04-17 20:47:01.419	error	(9723) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/ad
                  zigbee.0	2020-04-17 20:47:01.418	error	(9723) Failed to start Zigbee
                  Vielleicht hat @arteck hier ja auch ne Idee?? 😥
                  Den Fehler im Unifi-Skript hab ich erst jetzt (gesehen)
                  Hm, hab den Stick gezogen und mal wieder in nen anderen Port gedrückt...läuft gerade wieder...
                    @Kueppert unify: hatten wir nicht das Thema oben schonmal? Zeigt die Code stelle und wir sehen weiter. Ich tippe darauf das einfach das JavaScript ohne viel Fehlerbehandlung geschrieben wurde. Und irgendwo Ein Fall passiert der unerwartet ist. Ob es am Controller liegt bezweifle ich ziemlich. Aber muss man sehen.
                      @Kueppert zigbee ist ein Fehler vom Adapter. Der Controller kann nicht schuldig sein.
                        Ritter last edited by Ritter
                        hab beim DWD Adapter unter Windows 10 seit dem update diese Fehler im log:
                        dwd.0 2020-04-17 21:48:34.064 info (2336) Terminated (NO_ERROR): Without reason
                        dwd.0 2020-04-17 21:48:34.064 info (2336) terminating
                        dwd.0 2020-04-17 21:48:33.559 error (2336) ReferenceError: lat is not defined at adapter.getForeignObjectAsync.then.sys_conf (C:\iobroker\node_modules\iobroker.dwd\main.js:260:114) at process._tickCallback (internal/process/next
                        dwd.0 2020-04-17 21:48:33.558 error (2336) uncaught exception: lat is not defined
                        dwd.0 2020-04-17 21:48:33.539 info (2336) starting. Version 2.4.6 in C:/iobroker/node_modules/iobroker.dwd, node: v10.16.0, js-controller: 3.0.12
                        foxriver76 apollon77 2 Replies Last reply Reply Quote 0
                        • foxriver76
                          foxriver76 Developer @Ritter last edited by
                          @Ritter liegt daran dass rejections jetzt als Fehler fliegen. Muss im Adapter gefixt werden.
                            OK, Danke
                              apollon77 @Ritter last edited by
                              @Ritter exakt. Issue Im Adapter anlegen.
                                Die 3.0.13 mit noch ein paar Fixes ist auf GitHub
                                3.0.13 (2020-04-18) Release Elena
                                • (Apollon77) fix in objects lib when db connection closes while loading view results
                                • (bluefox) fixes and optimizations
                                  Und neben ein paar anderen Adaptern hat Admin eine 4.0.7 bekommen die das obige ZIP-Log-Download Problem fixen sollte und auch sonst js-controller Features unterstützt.
                                    sigi234 Forum Testing Most Active @apollon77 last edited by
                                    @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                    Derzeit keine Warn Meldungen mehr. 👍
                                      Einstein67 @apollon77 last edited by
                                      @apollon77 said in Beta Test js-controller 3.0.x auf GitHub:
                                      Zip-Logs funktionieren nun wieder wie gewünscht. Hab mein GitHub-Issue "geclosed"!!
                                        Perfekt, Danke!
                                        Ich will heute noch was an History&Co machen und danach geht es heute Abend oder morgen dann ins Latest denke ich. Danke in jedem Fall bisher an Eure Super Mitarbeit!
                                          @apollon77 wir haben zu danken!
                                          3.0.13 mit den ganzen Updates Admin, IOT, etc. läuft sehr ruhig.
                                          Von iogo gabs die 0.5.8, die wollte auch mit iobroker rebuild neu gemacht werden, ebenso der iot Adapter mal wieder.
                                          Das Verzeichnis und BLE hab ich komplett gelöscht, musste die restlichen Ordner halt mit der Hand löschen.
                                          Das Kapitel beobachte ich mal weiter.
                                            msauer last edited by
                                            Hi..ich habe ein seltsames Phänomen im Pushover Adapter seit dem ich die 3.0.13 installiert habe. Ich kann Änderungen im Admin nicht mehr speichern. Die beiden Buttons sind ohne Funktion. Nur Abbrechen geht. Bei der Version 3.0.11 und natürlich mit der älteren Admin Version, ging das noch. Wenn gleich der API Key da leider trotzdem invalid war.
                                            js-controller
                                            39
                                            416
                                            68572
