    4. Test Adapter fb-checkpresence v1.0.x
      e-s @afuerhoff last edited by
      @afuerhoff
      Das mit den Gruppen klingt super. Besonders wenn du sowieso diese jeweils in einen Ordner packen wolltest.
        mameier1234 last edited by
        mal wieder was neues...
        meine Tochter hat ein neues Handy, ich habe das Gerät ausgewählt und jetzt kommt im Log..:
        020-04-16 11:09:40.858	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Vxxxxr 88:A4:79:DD:40:5B
        fb-checkpresence.0	2020-04-16 11:09:40.858	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Vxxxxx 40:9C:28:03:F2:6C
        fb-checkpresence.0	2020-04-16 11:09:40.857	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:C2:67:CF
        fb-checkpresence.0	2020-04-16 11:09:40.857	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP B8:E9:37:44:A6:B6
        fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:77:D4:9A
        fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:72:3B:B8
        fb-checkpresence.0	2020-04-16 11:09:40.856	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:70:5D:16
        fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:90:51:46
        fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 78:28:CA:BB:DC:56
        fb-checkpresence.0	2020-04-16 11:09:40.855	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 78:28:CA:91:26:06
        fb-checkpresence.0	2020-04-16 11:09:40.854	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> SonosZP 94:9F:3E:70:61:B4
        fb-checkpresence.0	2020-04-16 11:09:40.850	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Galaxy-S8 44:91:60:7D:72:06
        fb-checkpresence.0	2020-04-16 11:09:40.850	warn	(856) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> Galaxy-S8 30:07:4D:94:24:97
        afuerhoff 2 Replies Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @mameier1234 last edited by
          @mameier1234
          Das ist eine Warnung, dass es in der Fritzbox doppelte Devicenamen für unterschiedliche Mac-Adressen gibt. Damit können die Fb-devices nicht korrekt als Objekt angelegt werden, da dafür der Name benutzt wird.
          • afuerhoff
            afuerhoff Developer last edited by
            Hallo, die Version 1.0.1 ist jetzt im Latest Repository verfügbar.
            Homer.J. 1 Reply Last reply Reply Quote 0
            • Homer.J.
              Homer.J. @afuerhoff last edited by Homer.J.
              @afuerhoff Morgen seid dem Update kann ich keine Änderungen mehr Speichern, ich wollte die Familienliste neu anlegen ist nicht möglich.
              Eigentlich nur wegen dieser Warnung.
              Steht ja schon 2 post drüber.
              fb-checkpresence.0	2020-04-18 07:49:49.755	warn	(15244) dublicate fritzbox device item. Please correct the hostname in the fritzbox settings for the device -> iobroker
              afuerhoff 1 Reply Last reply Reply Quote 0
              • afuerhoff
                afuerhoff Developer @Homer.J. last edited by afuerhoff
                @Homer-J
                Die Warnung sagt ja nur wie oben beschrieben, dass es doppelte Devicenamen in der Fritzbox gibt. Damit können die Fb-Devices nicht eindeutig adressiert werden. Kannst du den Fehler mit dem Speichern detaillierter beschreiben. Die Warnmeldung hat damit gar nichts zu tun.
                Homer.J. ? 2 Replies Last reply Reply Quote 0
                • Homer.J.
                  @afuerhoff wenn ich z.B jemanden Lösche und das Speichern möchte geht nicht. der Speicherbutton reagiert nicht, bei anderen Adaptern habe ich mal probehalber probiert dort geht es.
                  Ist mir deshalb aufgefallen weil ich durch die warnmeldung die Benutzer neu anlegen wollte.
                    A Former User @afuerhoff last edited by
                    @afuerhoff Hi, in der 1.0.1 geht das speichern nicht mehr, ich kann zwar Hinzufügen oder löschen, aber nicht mehr speichern.
                    Adapter FB Presence 1.0.1 (gerade von Git geladen), iobroker js-controller 3.0.13, und Node 12.6.
                    • afuerhoff
                      afuerhoff Developer @Guest last edited by afuerhoff
                      @ilovegym
                      Kannst Du mal direkt über Admin installieren. Ist das Verhalten dann genauso? Bei mir funktioniert das Löschen und Speichern ohne Probleme.
                        ich habe eine neue Person aus dem Gast-Netz hinzugefügt..
                        Klappt grundsätzlich, aber:
                        fb-checkpresence.0	2020-04-18 15:18:12.124	info	(856) History from Pxxxxx not enabled
                        Der Datenpunkt bleibt leer...
                        • afuerhoff
                          afuerhoff Developer @mameier1234 last edited by afuerhoff
                          @mameier1234
                          Hallo, ich habe auch einen Gast hinzugefügt, der aber nicht online ist. Er ist auch nicht im normalen Netz angemeldet gewesen. Bei mir kommt ein Fehler von der Fritzbox,
                          hier mal ein Auszug:
                          <errorDescription>NoSuchEntryInArray</errorDescription>
                          Das liegt aber daran, dass in der Fritzbox der Eintrag mal angezeigt wird und mal nicht. Wahrscheinlich wurde die Abfrage genau in so einem Moment gestartet.
                          Jedenfalls ist das bei mir so. Kann das Verhalten vielleicht jemand bestätigen?
                          Die History wurde bei mir auch nicht eingeschaltet. Das kann aber mit dem oberen Verhalten zusammenhängen.
                          Edit: Im Datenpunkt wird auch kein Name, Typ und Rolle angezeigt. Unter presence des Familienmitglieds wird aber false angezeigt, was richtig ist.
                          • afuerhoff
                            @mameier1234 sagte in Test Adapter fb-checkpresence v1.0.x:
                            Hallo, hast du die doppelten Namen mal in der Fritzbox umbenannt?
                            • afuerhoff
                              @Homer-J sagte in Test Adapter fb-checkpresence v1.0.x:
                              Welche Versionen vom js-controller und Node.js hast du installiert?
                              • afuerhoff
                                @ilovegym sagte in Test Adapter fb-checkpresence v1.0.x:
                                Lief die Vorgänger Version auch schon mit js-controller 3.x und Node.js 12.x?
                                  @afuerhoff sagte in Test Adapter fb-checkpresence v1.0.x:
                                  @ilovegym
                                  yes, das wars, jetzt gehts wieder! Admin 4.0.8 inzwischen, jetzt läuft das wieder ohne Probleme.
                                  Hab auch duplicate Hostnames in der Fritzbox, ist wohl ein Bug im FritzOs, normalsollte das garnicht vorkommen...
                                  aber das kann man ja ändern...
                                  • Homer.J.
                                    @afuerhoff lag bei mir auch an der Admin Version jetzt mit der 4.0.8 geht es wieder.
                                      mameier1234 @afuerhoff last edited by
                                      @afuerhoff ich habe den alten Namen gelöscht. Das Problem ist weg
                                      • JB_Sullivan
                                        JB_Sullivan last edited by
                                        Ich habe gerade die Update Orgie hier auf ioB hinter mir.
                                        fb-ckpresence meldet im LOG folgenden Fehler:
                                        fb-checkpresence.0	2020-04-19 13:17:48.274	error	(9040) Fb.getDeviceList Error: timeout of 2000ms exceeded
                                        Hatte ich vorher nie - gibt es dazu ggf. schon irgend welche Erkentnisse?
                                        • afuerhoff
                                          afuerhoff Developer @JB_Sullivan last edited by
                                          @JB_Sullivan sagte in Test Adapter fb-checkpresence v1.0.x:
                                          Der Fehler kam bisher, wenn mehrere Instanzen und Adapter auf die Fritzbox zugegriffen haben. Ist das bei dir auch der Fall? Das timeout kommt aus der Fritzbox.
                                          Kommt der Fehler ständig oder einmalige Angelegenheit?
                                          • Garfonso
                                            Garfonso Developer @afuerhoff last edited by
                                            @afuerhoff
                                            Bei mir kommt der Fehler auch hin und wieder. Meine Fritzbox ist aber auch grundsätzlich sehr lahm (ist eine 6390 Cable). Warum machst du den Timeout da so kurz auf 2 Sekunden?
                                            avm fritzbox soap tr-064
                                            23
                                            248
                                            27006
