    4. [How-to] Node.js für ioBroker richtig updaten
      Sneak-L8 @apollon77 last edited by Sneak-L8
      @apollon77 Guten Morgen, hab ich gemacht. Das Löschen wir nur mit root-User möglich (also sudo rm -rf ...).
      Aber schon der
      npm install --production
      schlägt wieder mit demselben Befehl fehl:
      pi@ioBroker-RasPi:/opt/iobroker/node_modules/rpi-gpio $ npm install --production
      npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
      npm WARN deprecated mkdirp@0.3.5: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
      npm WARN deprecated istanbul@0.2.7: This module is no longer maintained, try this instead:
      npm WARN deprecated   npm i nyc
      npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated mkdirp@0.3.0: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
      npm WARN deprecated formatio@1.0.2: This package is unmaintained. Use @sinonjs/formatio instead
      npm WARN deprecated graceful-fs@2.0.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm WARN deprecated minimatch@0.4.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm WARN deprecated samsam@1.1.3: This package has been deprecated in favour of @sinonjs/samsam
      npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      > epoll@0.1.22 install /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird betreten
        CXX(target) Release/obj.target/epoll/src/epoll.o
      In file included from ../../nan/nan.h:192:0,
                       from ../src/epoll.cc:15:
      /home/iobroker/.cache/node-gyp/10.20.1/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      epoll.target.mk:103: die Regel für Ziel „Release/obj.target/epoll/src/epoll.o“ scheiterte
      make: *** [Release/obj.target/epoll/src/epoll.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/rpi-gpio/node_modules/epoll/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.14.34-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/rpi-gpio/node_modules/epoll
      gyp ERR! node -v v10.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! epoll@0.1.22 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the epoll@0.1.22 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2020-04-15T07_59_33_981Z-debug.log
      Er will erneut epoll 0.1.22 installieren...
        apollon77 @Sneak-L8 last edited by
        @Sneak-L8 Ok, dann noch härter:
        Lösche /opt/iobroker/node_modules/rpi-gpio
        gehe in /opt/iobroker/node_modules/iobroker.rpi2 und mache dort
          Super, jetzt hat's geklappt! Vielen Dank!!
            crunchip Forum Testing Most Active @Thomas Braun last edited by
            @Thomas-Braun das klappt so aber nicht
            • Glasfaser
              Glasfaser @crunchip last edited by
              @crunchip
              vorher eine .. machen , zur Paketenaktualisierung
              sudo apt update
              crunchip 1 Reply Last reply Reply Quote 1
                crunchip Forum Testing Most Active @Glasfaser last edited by
                @Glasfaser danke, hatte ich nicht dran gedacht
                • Glasfaser
                  Glasfaser @crunchip last edited by Glasfaser
                  @crunchip
                    SolarGuido last edited by SolarGuido
                    vertan... falscher Beitrag
                      Jetzt wird es richtig wuschelig mit der js8 Version. Ich überlege auch upgrade auf js12 zu machen, wie sieht es damit aus? Gibt es dazu auch eine Anleitung? Gibt es für NPM auch dann eine Notwendigkeit diese upzugraden?
                      Danke für jeden Hinweis!
                        Thomas Braun Most Active @SolarGuido last edited by Thomas Braun
                        @SolarGuido Hängt vom verwendeten System ab.
                        Grundsätzlich: Siehe den ersten Beitrag in diesem Thread.
                          Homoran Global Moderator Administrators @SolarGuido last edited by
                          @SolarGuido sagte in [How-to] Node.js für ioBroker richtig updaten:
                          Die Anleitung ist identisch, nur dass du die 10.x in dem Befehl gegen eine 12.x austauschen musst.
                          Das wird automatisch mit ugegradet
                            SolarGuido @Thomas Braun last edited by SolarGuido
                            @Thomas-Braun sagte in [How-to] Node.js für ioBroker richtig updaten:
                            Orange Pi (image aus dem Forum) Also Debian
                              @SolarGuido Da läuft ein Linux drauf? Debian?
                                Armbian
                                  SolarGuido @Homoran last edited by
                                  @Homoran sagte in [How-to] Node.js für ioBroker richtig updaten:
                                  Ok, dann vielen Dank!
                                    Armbian
                                    Ja , aber Debian ist glaub ich die Basis dafür , nur das Armbian eingeschränkt ist gegenüber Deban...
                                    Ich werde es probieren mache ne Ordner Sicherung vorher, da werden doch nur Änderungen in opt/iobroker gemacht oder auch andere Verzeichnisse?
                                      Naja, ist ein für ARM Hardware optimiertes Debian.
                                        @Homoran
                                        da werden doch nur Änderungen in opt/iobroker gemacht oder auch andere Verzeichnisse??
                                        Also nur das Verzeichnis sichern, damit wenn es schief läuft ich wieder auf Start komme, richtig?
                                          @SolarGuido Nein, da wird node.js upgedated und danach über npm rebuild die Pakete von ioBroker neu kompiliert
                                          Es betrifft ggf. mehr als ioB
                                          Aber Backup von ioB mit backitup ist immer eine gute Basis für einen neuanfang
                                            ok, danke für die Auskunft
                                            installation linux node node.js nodejs windows
                                            106
                                            1105
                                            679935
