    4. Kamera + Bewegungsmelder kombinieren für Gartenüberwachung
    • wendy2702
      wendy2702 @smarthome2020 last edited by
      @smarthome2020 sagte in Kamera + Bewegungsmelder kombinieren für Gartenüberwachung:
      Mittagessen
      Wahrscheinlich!
      Essen wird eh überbewertet. 😉
        smarthome2020 @wendy2702 last edited by
        @wendy2702
        Also die Kamera lief den ganzen Tag nebenher... keine Abbrüche.
        Abends hab ich dem PC etwas Auszeit gegeben und da ist die Kamera wieder abgeschmiert.
        Nachfolgend ist der Übergang aus dem Log (war im Übrigen >1GB :D):
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('Date: Fri, 17 Apr 2020 18:35:18 GMT')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_check_content_length: Content-Length -1
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('Content-Type: image/jpeg')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_check_content_type: Content-type image/jpeg
        [1:nc2:Garten_hint] [NTC] [NET] netcam_read_first_header: Non-streaming camera (keep-alive not set)
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('Content-Length: 480224')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_check_content_length: Content-Length 480224
        [1:nc2:Garten_hint] [NTC] [NET] netcam_read_first_header: Content-length present
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('Connection: keep-alive')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('X-Frame-Options: SAMEORIGIN')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('Strict-Transport-Security: max-age=63072000; includeSubdomains; preload')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('X-XSS-Protection: 1; mode=block')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('X-Content-Type-Options: nosniff')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('')
        [1:nc2:Garten_hint] [NTC] [NET] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
        [1:ml1:Garten_hint] [DBG] [NET] netcam_init_jpeg: ***new pic delay successful***
        [1:nc2:Garten_hint] [INF] [NET] netcam_connect: disconnecting netcam since keep-alive not set.
        [1:nc2:Garten_hint] [INF] [NET] netcam_connect: with no keepalive, new socket created fd 8
        [1:nc2:Garten_hint] [INF] [NET] netcam_connect: re-using socket 8 since keepalive is set.
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: Received first header ('HTTP/1.1 502 Bad Gateway')
        [1:nc2:Garten_hint] [DBG] [NET] netcam_read_first_header: HTTP Result code 502
        [1:nc2:Garten_hint] [ERR] [NET] netcam_handler_loop: Unrecognized image header (502)
        • wendy2702
          Vielleicht mal in der Motion.conf mit diesem Wert spielen:
          # The setting for keep-alive of network socket, should improve performance on compatible net cameras.
          # 1.0:         The historical implementation using HTTP/1.0, closing the socket after each http request.
          # keep_alive:  Use HTTP/1.0 requests with keep alive header to reuse the same connection.
          # 1.1:         Use HTTP/1.1 requests that support keep alive as default.
          # Default: 1.0
          # CHANGED
          netcam_http 1.1
            @wendy2702
            OK. Probiere das nachher. Ist aber interessant, dass sie abschmiert, wenn man den Stream nicht auf nem Monitor laufen hat.
              smarthome2020 @smarthome2020 last edited by smarthome2020
              @wendy2702
              Ich finde in keiner motion.conf diese Einstellungsmöglichkeiten. Oder wo hast du die her?
              Glaube auch nciht, dass es daran liegt. Kann wieder nicht auf die Kamera zugreifen per Browser. "Bad Gateway". Kann die Kamera nicht bei motionEye einrichten "Bad Gateway".
              WLAN-Steckdose habe ich beim Switch installiert. Die Kamera hierüber aus und angeschaltet und dann gehts wieder mit der Einrichtung.
              • wendy2702
                https://linuxwiki.de/motion
                  @wendy2702
                  Danke. Schau mal im Post von mir drüber. Hatte da noch was geändert. Siehst du es auch so?
                  • wendy2702
                    Möglich das die ne Macke hat.
                    Hast du nur die eine?
                      @wendy2702
                      Ja, hab nur die eine. Kann noch ne Alternative bestellen. Oder gleich ne Hikvision.
                      • wendy2702
                        Tja....
                        Da ist guter Rat teuer.
                        Ich würde die zurück geben und direkt ne HikVision kaufen.
                          smarthome2020 @wendy2702 last edited by smarthome2020
                          @wendy2702
                          Morgen setze ich ne neue SD Karte mal mit einem neuen System auf und schaue, obs stabiler läuft.
                          Gehe ich aber nicht von aus. Sonst nehme ich ne Hikvision. Die kosten nur doppelt so viel 😄
                          Und ich hab nur nen RPi 4
                            el_malto @smarthome2020 last edited by
                            @smarthome2020 kannst es immer noch mit ner App aufn Tablet oder Phone testen. Kann mir wirklich nicht vorstellen das es am System liegt Die Kamera ist ja nicht mehr erreichbar und stürzt ab.
                              Also scheinbar kann ich bei "Connection lost" einfach Strom von der Kamera nehmen und wieder anschalten. Dann geht alles. Wie kann ich das automatisieren?
                              Also die Befehle:
                              http://192.168.xxx.xxx:7999/1/detection/connection
                              http://192.168.xxx.xxx:7999/1/detection/status
                              Wie kann ich die im ioBroker auswerten?
                              • wendy2702
                                Sorry... aber das ist doch keine Lösung.
                                S Glasfaser 2 Replies Last reply Reply Quote 1
                                  @wendy2702
                                  Ne, hast ja recht 😞 Schade.
                                  • Glasfaser
                                    Glasfaser @smarthome2020 last edited by Glasfaser
                                    @smarthome2020
                                    Versuche mal damit , ob du ein Auswertung bekommst
                                    <block xmlns="http://www.w3.org/1999/xhtml" type="exec" id="!%H2f7Y`8OFd.~gFDvX#" x="188" y="64">
                                     <mutation with_statement="true"></mutation>
                                     <field name="WITH_STATEMENT">TRUE</field>
                                     <field name="LOG"></field>
                                     <value name="COMMAND">
                                       <shadow type="text" id="D7}!}?AKU*cClHlv+9y4">
                                         <field name="TEXT">curl http://192.168.178.51/streaming/channels/1/picture</field>
                                       <block type="debug" id="!N5up[B{T/LTTi-_ecn9">
                                         <value name="TEXT">
                                           <shadow type="text" id="J`/`lk[1@05UD[2~T+TL">
                                           <block type="variables_get" id="Hh~k_N+@YbO%UvlA/@bU">
                                             <field name="VAR" id="%3Mff6CD,)5FpTyqT-?!" variabletype="">result</field>
                                           <block type="debug" id="?da:0)J$|KrxbYk`B}(B">
                                             <value name="TEXT">
                                               <block type="variables_get" id="+W;=rb#yQo|PE}[-2UtT">
                                                 <field name="VAR" id="k/Bs#bIB:Ff8L9lv4^-d" variabletype="">stdout</field>
                                               <block type="debug" id="RXN$G!=O`P9nhNpVu#(N">
                                                 <value name="TEXT">
                                                   <shadow type="text" id="Lbpbr1oEFz|ETX~l$^Cs">
                                                   <block type="variables_get" id=",4pl9#rI2/9w19HTHk~o">
                                                     <field name="VAR" id="Cjr.[GB6284iu*rOZxn}" variabletype="">stderr</field>
                                                   <block type="debug" id=";K*88rm67)kSl|OR`?4:">
                                                     <value name="TEXT">
                                                       <shadow type="text" id="y:/8xVy;=1lXAoSk~x)4">
                                                       <block type="variables_get" id="@Rs4BpAt%r]mmn4Aj_::">
                                                         <field name="VAR" id="_qJ[C$+4||[A|G%Qg~xD" variabletype="">error</field>
                                    • Glasfaser
                                      Glasfaser @wendy2702 last edited by
                                      @wendy2702 sagte in Kamera + Bewegungsmelder kombinieren für Gartenüberwachung:
                                      @smarthome2020
                                      Stimmt ...
                                      bei 188 Beiträgen sollte mal Schluss sein ...
                                      Kauf dir eine vernüftige Cam
                                        el_malto @Glasfaser last edited by
                                        @Glasfaser sagte in Kamera + Bewegungsmelder kombinieren für Gartenüberwachung:
                                        @smarthome2020
                                        Stimmt ...
                                        Sorry, aber @Glasfaser hat einfach recht. Macht keinen Sinn mehr und du @smarthome2020 steckst nur unnötig Energie und Zeit rein.
                                          Schaue nun nach neuen Kameras.
                                          Mir reicht eine Full-HD-Auflösung locker aus. Preislich wäre so um die 100 Euro max. schon ganz nett, da es wahrscheinlich 3-4 werden sollen. Als Hardware reicht dann ein RPi 4 auch nicht mehr aus, nehme ich mal an.
                                          Anforderungen:
                                          1. PoE
                                          2. Outdoor
                                          3. erprobte Kamera mit !!!stabilem!!! Stream
                                          Ich bin ja doch hartnäckig, aber hab die RLC nun zurück geschickt.
                                          Knallochse J 2 Replies Last reply Reply Quote 0
                                          • Knallochse
                                            Knallochse @smarthome2020 last edited by
                                            @smarthome2020
                                            Ich habe diese hier:
                                            Ctronics Überwachungskamera Aussen WLAN, IP Kamera Outdoor wifi HD 1080P mit 110 ° Weitwinkel, Zwei-Wege-Audio, 30m IR-Nachtsicht, Bewegungserkennung, IP65 Wasserdicht,Fernzugriff https://www.amazon.de/dp/B07HRB3MJ4/ref=cm_sw_r_cp_tai_mgWNEb4RNCG5N
                                            Und die hat sogar einen mjpeg-Stream (so sparst du dir das umwandeln)
                                            Bin ganz zufrieden damit. Und die gab es schon im Angebot für 45,-€
                                            Ich fand den Weitwinkel toll. So hat man viel im Bild (aber halt auch verzerrt Thema Fischauge - stört mich aber nich)
                                            Gibt es auch als POE:
                                            Ctronics PoE Überwachungskamera Super HD 5MP IP Kamera 2,8mm 110 ° Linse Fixieren H.265 Videokompression Nachtsicht Bewegungserkennung IP66 Wasserdicht Kompatibel mit Synology Kein WLAN CTIPO-300C https://www.amazon.de/dp/B07QRW42K6/ref=cm_sw_r_cp_tai_tkWNEbND2PSGH
                                            Ob diese aber auch mjpeg liefert kann ich dir nicht sagen.
                                            bewegungsmelder kamera überwachung
                                            11
                                            197
                                            16793
