    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • Dutchman
      Dutchman Developer Most Active Administrators @Sunshinemaker last edited by
      @Sören sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
      @Dutchman
      Danke 🙂 haben sich wohl gerade überschnitten unsere Posts.
      😲 😊 alles gut 🙂
      • Sunshinemaker
        Sunshinemaker @Dutchman last edited by
        @Dutchman
        Wenn du mir sagst wie ich das mache kein Problem. 😕
        • Dutchman
          Dutchman Developer Most Active Administrators @Sunshinemaker last edited by Dutchman
          @Dutchman
          gehe mal bitte auf den state den du analysiert, dan den Bleistift und tabblad "raw daten"
          dan mal alles copy/paste hier rein (hm Seriennummer eventuell abändern)
          Sunshinemaker 1 Reply Last reply Reply Quote 0
          • Sunshinemaker
            @Dutchman
            Das sind die vom Xiaomi Mi power plug ZigBee EU, Model: ZNCZ04LM
              "type": "state",
              "common": {
                "name": "Steckdose Load power",
                "type": "number",
                "unit": "W",
                "read": true,
                "write": false,
                "role": "value.power",
                "custom": {
                  "sourceanalytix.0": {
                    "enabled": true,
                    "alias": "",
                    "state_type": "kWh_consumption",
                    "state_unit": "w",
                    "costs": false,
                    "consumption": true,
                    "meter_values": false,
                    "start_day": 2.1522543344583314,
                    "start_week": 0.010404209858333333,
                    "start_month": 0,
                    "start_quarter": 0,
                    "start_year": 0,
                    "previousReadingWatt": null,
                    "previousReadingWattTs": null
              "from": "system.adapter.sourceanalytix.0",
              "user": "system.user.admin",
              "ts": 1587160800019,
              "_id": "zigbee.0.04cf8cdf3c75a1bf.load_power",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
              "native": {}
            Und das die Daten vom HMIP PSM
              "type": "state",
              "common": {
                "def": 0,
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 838859.1,
                "unit": "Wh",
                "name": "Stckd_Fernseher:6.ENERGY_COUNTER",
                "custom": {
                    "enabled": true,
                    "alias": "",
                    "state_unit": "wh",
                    "costs": false,
                    "start_day": 164.3275,
                    "start_week": 164.3275,
                    "start_month": 164.3275,
                    "start_quarter": 164.3275,
                    "start_year": 164.3275,
                    "currentValuekWh": null
              "native": {
                "MIN": 0,
                "UNIT": "Wh",
                "OPERATIONS": 5,
                "MAX": 838859.1,
                "FLAGS": 1,
                "ID": "ENERGY_COUNTER",
                "TYPE": "FLOAT",
                "DEFAULT": 0,
                "CONTROL": "POWERMETER_PSM.ENERGY_COUNTER"
              "ts": 1587160800020,
              "_id": "hm-rpc.1.0001D3XXXXXXXX.6.ENERGY_COUNTER",
              "acl": {
                "object": 1636,
                "state": 1636,
              "type": "state",
              "common": {
                "def": 0,
                "type": "number",
                "read": true,
                "write": false,
                "min": 0,
                "max": 163830,
                "unit": "W",
                "name": "Stckd_Fernseher:6.POWER",
                "custom": {
                    "enabled": true,
                    "alias": "",
                    "state_unit": "w",
                    "costs": false,
                    "start_day": 0,
                    "start_week": 0,
                    "start_month": 0,
                    "start_quarter": 0,
                    "start_year": 0,
                    "previousReadingWattTs": null,
                    "valueAtDeviceReset": 0.7450009218833333
              "native": {
                "MIN": 0,
                "UNIT": "W",
                "OPERATIONS": 5,
                "MAX": 163830,
                "FLAGS": 1,
                "ID": "POWER",
                "TYPE": "FLOAT",
                "DEFAULT": 0,
                "CONTROL": "POWERMETER_PSM.POWER"
              "ts": 1587160800018,
              "_id": "hm-rpc.1.0001D3XXXXXXXX.6.POWER",
              "acl": {
                "object": 1636,
                "state": 1636,
            • Dutchman
              Super ich danke dir, schaue mir das alles mal in ruhe an
              • AtomicIX
                AtomicIX @Dutchman last edited by
                @Dutchman Cool , klasse. Jetzt habe ich auch nach der neu Installation und dem Xten Neustart, die Einstellungen.
                Kannst du ungefähr absehen, wann du es schaffst, das Pulsen einzunbauen?
                • Dutchman
                  Dutchman Developer Most Active Administrators @AtomicIX last edited by
                  @AtomicIX sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                  bin gerade am reset problem dran denke mal so 1-2 Wochen
                  AtomicIX 1 Reply Last reply Reply Quote 0
                  • AtomicIX
                    @Dutchman cool, danke
                    • Dutchman
                      Dutchman Developer Most Active Administrators @lobomau last edited by
                      @lobomau sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      Also: Schuld war Kombination Discovergy mit Sourceanalytix
                      Hey, könntest du mal bitte die neuer Version von discovergy testen ob damit diese problem gelöst ist ?
                      lobomau 1 Reply Last reply Reply Quote 1
                      • lobomau
                        lobomau @Dutchman last edited by
                        @Dutchman ich habe auf 0.5.2 geupdatet. Mehrbelastung ist weg 👍
                        Hier ist der Verlauf. Erster Anstieg ist beim Update, dann habe ich Discovergy in SA dazugenommen mit 5s Aktualisierung, zweiter Anstieg ist Discovergy-Adapter Neustart. Ich hab noch was zum Thema Discovergy-Adapter, das ich im anderen thread antworte...
                        • Dutchman
                          Super ! Problem solved wie erwartet wegen den unnötigen object sets das andere klareren wir im discovergy thread
                            lexiz52 last edited by
                            Erst mal vielen Dank für die Arbeit an diesem Adapter! Ich habe dieses Wochenende mein System neu aufgesetzt (Raspi4). In meiner alten vis nutze ich die Daten aus "this week (Montag-Sonntag)". Mir ist aufgefallen das in der neuen Version zwar ein neues Verzeichnis 2020 erstellt wird, was grundsätzlich gut ist um Daten aus den Jahren vergleichen zu können, aber natürlich in 2021 einiges an Arbeit in vis verursachen wird da ich meine Datenpunkte aktualisieren muss. In 2020 gibt es keinen Datenpunkt "this week" mehr und das alte wird nicht mehr aktualisiert. Ist das richtig oder habe etwas übersehen oder falsch angeklickt? Ist es geplant das der Datenpunkt "this week" wieder eingepflegt wird, ich halte diesen für sehr wichtig?
                            Danke !
                            Lexiz52
                            • Dutchman
                              Dutchman Developer Most Active Administrators @lexiz52 last edited by
                              @lexiz52 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                              working on it : https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/135
                              skvarel created this issue in iobroker-community-adapters/ioBroker.sourceanalytix
                              closed THIS WEEK #135
                                Berchemer @Dutchman last edited by Berchemer
                                @Dutchman sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                @Homer-J sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                Morgen @Dutchman irgendetwas stimmt noch nicht ganz, jetzt wird der Tageswert zwar zurück gesetzt aber auch die restlichen Werte auf Null. Starte ich den Adapter einmal neu schreibt er die Werte wieder.
                                ich erwarte dafuer heute ein update das scheint zu passieren wen nach denn tagesreset sich der wert nicht aktualisiert.
                                Danke fürs melden
                                Da ich kein issue zum Thema auf github gefunden habe, möchte ich nur kurz mitteilen, dass auch ich das Problem habe und ggf. gerne Daten sende, um den Fehler besser zu lokalisieren 🙂
                                • O
                                  osser @Berchemer last edited by
                                  @Berchemer sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                  Danke fürs melden
                                  Dieses Verhalten kann ich auch bestätigen.
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @osser last edited by
                                    @osser sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                    bin noch dran is diesmal n hartnäckiger 😕
                                      Glück auf 😉
                                      • lobomau
                                        ich habe bei dem Adapter ein "Neu starten" kurz nach Tagesbeginn eingestellt und habe damit keine Einschränkungen. Oder übersehe ich etwas?
                                        • Dutchman
                                          sollte so klappen, ist aber nicht wie ich es gerne hätte 😞
                                          Mit definieren bitte "kurz nach", ich wuerde es nicht innerhalb einer Sekunden mache den bei vielen werte ist er dan noch am rechnen 🙂
                                            crunchip Forum Testing Most Active @Dutchman last edited by
                                            @Dutchman ich lass nach 10min neustarten, sollte reichen
                                            1.0k
                                            81.1k
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            351764
