    4. Nach Update Fehler beim Start und Putty II
    • I
      IwaKim last edited by Negalein
      ludino 16 Oct 2019, 19:37 hatte bereits das gleiche Problem nach einen Update. Seinen Beitrag konnte ich aber nicht kommentieren.
      Bei ihm hat sich das Problem von selber erledigt. Bei mir leider nicht. Was kann ich machen?
      root@iobroker:/opt/iobroker# iobroker start
      module.js:478
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:476:15)
          at Function.Module._load (module.js:424:25)
          at Module.runMain (module.js:611:10)
          at run (bootstrap_node.js:394:7)
          at startup (bootstrap_node.js:160:9)
          at bootstrap_node.js:507:3
      Den Ordner '/opt/iobroker/node_modules/iobroker.js-controller' gibt es bei mir nicht.
      Es war ein Update in der Konsole
      iobroker stop
      iobroker backup
      iobroker stop
      iobroker update
      iobroker upgrade self
      Viele Grüße
      Mod-Edit: Thema von Forum nach Error/Bug verschoben!
      • wendy2702
        wendy2702 last edited by
        Probiere mal:
        cd /opt/iobroker
        iobroker stop
        npm install iobroker.js-controller
        iobroker start
        • I
          IwaKim last edited by wendy2702
          das schaut so aus:
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          npm WARN lifecycle iobroker.js-controller@2.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@2.2.9 node lib/preinstallCheck.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
          > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
          > node-gyp rebuild
          make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
            CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
            SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
            COPY Release/unix_dgram.node
          make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
          > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
          > node rebuild.js
          > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
          > node-gyp rebuild
          make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
            CXX(target) Release/obj.target/diskusage/src/main.o
            CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          ../src/diskusage_posix.cpp: In function 'DiskUsage GetDiskUsage(const char*)':
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_bsize' [-Wmissing-field-initializers]
               struct statvfs info = {};
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_frsize' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_blocks' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_bfree' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_bavail' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_files' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_ffree' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_favail' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_fsid' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_flag' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::f_namemax' [-Wmissing-field-initializers]
          ../src/diskusage_posix.cpp:10:28: warning: missing initializer for member 'statvfs::__f_spare' [-Wmissing-field-initializers]
            SOLINK_MODULE(target) Release/obj.target/diskusage.node
            COPY Release/diskusage.node
          make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
          > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:242
                                  const createInitialInstances = async () => {
          SyntaxError: Unexpected token (
              at createScript (vm.js:56:10)
              at Object.runInThisContext (vm.js:97:10)
              at Module._compile (module.js:549:28)
              at Object.Module._extensions..js (module.js:586:10)
              at Module.load (module.js:494:32)
              at tryModuleLoad (module.js:453:12)
              at Function.Module._load (module.js:445:3)
              at Module.require (module.js:504:17)
              at require (internal/module.js:20:19)
              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:63)
          iobroker@1.0.0 /opt/iobroker
          `-- (empty)
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm ERR! Linux 3.14-1-amd64
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller"
          npm ERR! node v6.17.1
          npm ERR! npm  v3.10.10
          npm ERR! code ELIFECYCLE
          npm ERR! iobroker.js-controller@2.2.9 install: `node iobroker.js setup first`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the iobroker.js-controller@2.2.9 install script 'node iobroker.js setup first'.
          npm ERR! Make sure you have the latest version of node.js and npm installed.
          npm ERR! If you do, this is most likely a problem with the iobroker.js-controller package,
          npm ERR! not with npm itself.
          npm ERR! Tell the author that this fails on your system:
          npm ERR!     node iobroker.js setup first
          npm ERR! You can get information on how to open an issue for this project with:
          npm ERR!     npm bugs iobroker.js-controller
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls iobroker.js-controller
          npm ERR! There is likely additional logging output above.
          npm ERR! Please include the following file with any support request:
          npm ERR!     /opt/iobroker/npm-debug.log
          npm ERR! code 1
          root@jessie:/opt/iobroker
          EDIT:LOG in CODE TAGS
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          • wendy2702
            Was kommt bei
            node -v
            npm -v
            • I
              @wendy2702 said in Nach Update Fehler beim Start und Putty II:
              root@jessie:/opt/iobroker# node -v
              v6.17.1
              root@jessie:/opt/iobroker# npm -v
              3.10.10
              • wendy2702
                Die Versionen sind zu alt.
                Bitte updaten:
                https://www.iobroker.net/#de/documentation/install/linux.md
                • I
                  das habe ich bis "Installation ioBroker" gemacht.
                  Jetzt schau das so aus
                  root@jessie:~# nodejs -v
                  v10.20.1
                  v10.20.1
                  root@jessie:~# iobroker start
                  internal/modules/cjs/loader.js:638
                      throw err;
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                      at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                      at startup (internal/bootstrap/node.js:283:19)
                      at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  root@jessie:~#
                  Soll ich dem Link auch noch weiter folgen (ab Installation ioBroker). Mache ich da nicht meine gesamte Installation kaputt?
                  EDIT: LOG in CODE TAGS
                  • wendy2702
                    Nach update von NPM und Node musst du den JS-Controller neu installieren. Also das was du zuvor probiert hast.
                    Welche NPM Version ist jetzt installiert?
                    • I
                      NPM
                      root@jessie:~# npm -v
                      6.14.4
                      root@jessie:~#
                      • wendy2702
                        wendy2702 @wendy2702 last edited by
                        @wendy2702 sagte in Nach Update Fehler beim Start und Putty II:
                        Probiere mal:
                        cd /opt/iobroker
                        iobroker stop
                        iobroker start
                        Dann das erneut
                        • I
                          egal was ich hinter iobroker schreibe, ich bekomme immer das:
                          root@jessie:~# iobroker [stop|start|update|...]
                              throw err;
                          root@jessie:~#
                          • wendy2702
                            wendy2702 @IwaKim last edited by wendy2702
                            @IwaKim BITTE BENUTZE CODE TAGS ZUM POSTEN VON LOGS
                            cd /opt/iobroker
                            iobroker start
                            Stop ist überflüssig weil er ja eh nicht läuft. Von update habe ich nichts geschrieben.
                            • I
                              Du meinst "npm install iobroker.js-controller"?
                              • wendy2702
                                Ja.
                                Aber bitte im richtigen Ordner!
                                • I
                                  dieser hier?
                                  root@jessie:/opt/iobroker# ls
                                  backups install.sh iobroker-data log npm-debug.log package.json
                                  etc iobroker killall.sh node_modules package-lock.json reinstall.sh
                                  • wendy2702
                                    Ja.
                                    Wie bereits geschrieben.
                                    • I
                                      Sorry, das hatte ich oberlesen!
                                      1. es geht Suuuper!
                                        root@jessie:/opt/iobroker# iobroker start
                                        Starting iobroker controller daemon...
                                        iobroker controller daemon started. PID: 4484
                                      2. bei "npm install iobroker.js-controller" kam u.a. das
                                        | New major version of npm available! 5.3.0 -> 6.4.1 │
                                        │ Changelog: https://github.com/npm/cli/releases/tag/v6.4.1 │
                                        │ Run npm install -g npm to update!
                                        Ist das eine gute Idee?
                                      • wendy2702
                                        wendy2702 @wendy2702 last edited by wendy2702
                                        Bitte updaten:
                                        Hättest du das hier gelesen 👆
                                        Wäre dir dieser Teil aufgefallen:
                                        Als letzte Überprüfung bitte noch die Version von npm mittels npm -v überprüfen.
                                        Ergibt dies eine Version < 6, bitte noch mit sudo -H npm install -g npm@6 ein npm-Update durchführen
                                        Also lautet die Antwort: JA... machen, es ist eine gute Idee
                                        • I
                                          alles super1
                                          ein gutes Voting hast Du Dir mehr als verdient. Aber wie geht das?
                                          Recht unter was was wie "got it". Da habe ich drauf geklickt.
                                          • wendy2702
                                            @IwaKim
                                            Kannst gerne Hier in den Beiträgen die geholfen haben auf den Pfeil nach oben drücken
                                            Schön das es wieder läuft.
                                            Schönen Sonntag
                                            update fehler
                                            781
