    4. Kann keine IP Adresse für hm-rpc auswählen(Jessie)
    • Bluefox
      Bluefox last edited by
      Rainer kannst du gleich nach der Restart (Fehlerzustand ) mir das Objekt system.host.deinHost zeigen. Da drin unter native sollten die Ip Adressen sein (oder nicht sein). Dann kann ich testen.
        Raspi Reboot (Meine uptime 😢 😢 )
        iobroker admin nach autostart - Objects system.host (native hardware):
        "cpus": [
        "model": "ARMv7 Processor rev 4 (v7l)",
        "speed": 1200,
        "times": {
        "user": 22700,
        "nice": 0,
        "sys": 18400,
        "idle": 27500,
        "irq": 0
        "speed": 1200,
        "times": {
        "user": 21300,
        "nice": 0,
        "sys": 15300,
        "idle": 43100,
        "irq": 0
        "speed": 1200,
        "times": {
        "user": 16900,
        "nice": 0,
        "sys": 17600,
        "idle": 37400,
        "irq": 0
        "speed": 1200,
        "times": {
        "user": 18600,
        "nice": 0,
        "sys": 12300,
        "idle": 56400,
        "irq": 0
        "totalmem": 970764288,
        "networkInterfaces": {
        "lo": [
        "address": "127.0.0.1",
        "netmask": "255.0.0.0",
        "family": "IPv4",
        "mac": "00:00:00:00:00:00",
        "internal": true
        "address": "::1",
        "netmask": "ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff",
        "family": "IPv6",
        "scopeid": 0,
        "internal": true
        "eth0": [
        "address": "fe80::6ddf:a7fe:63ab:3a58",
        "netmask": "ffff:ffff:ffff:ffff::",
        "family": "IPv6",
        "mac": "b8:27:eb:32:78:32",
        "scopeid": 2,
        "internal": false
        Rainer
        • Bluefox
          @Homoran:
          "cpus": [
          "speed": 1200,
          "times": {
          "user": 22700,
          "nice": 0,
          "sys": 18400,
          "idle": 27500,
          "irq": 0
          "speed": 1200,
          "times": {
          "user": 21300,
          "nice": 0,
          "sys": 15300,
          "idle": 43100,
          "irq": 0
          "speed": 1200,
          "times": {
          "user": 16900,
          "nice": 0,
          "sys": 17600,
          "idle": 37400,
          "irq": 0
          "speed": 1200,
          "times": {
          "user": 18600,
          "nice": 0,
          "sys": 12300,
          "idle": 56400,
          "irq": 0
          "lo": [
          "family": "IPv4",
          "internal": true
          "address": "::1",
          "family": "IPv6",
          "scopeid": 0,
          "internal": true
          "eth0": [
          "family": "IPv6",
          "scopeid": 2,
          "internal": false
          Rainer `
          Kann es sein, dass du HDCp hast? eth0 ist schon da nur ohne IPv4 Adresse.
          Und vielen Dank Rainer, weil mit deinem Post habe ich verstanden, dass mein WorkArounf nicht greift und ich muss umdenken.
            @Bluefox:
            Kann es sein, dass du HDCp hast? `
            Ja!
            @Bluefox:
            eth0 ist schon da nur ohne IPv4 Adresse. `
            So ist es:
            @homoran:
            Bluefox hat geschrieben:
            jessie gibt keine ip Adressen
            Wieso?
            Es gibt doch eine v6 Adresse - und die stimmt sogar!
            :mrgreen: :mrgreen: :mrgreen: `
            http://forum.iobroker.net/viewtopic.php … =60#p23569
            @Bluefox:
            dass mein WorkArounf nicht greift `
            Mist - wenn ich noch helfen kann immer gerne.
            Rainer
            Darf ich jetzt wieder ./iobroker restart machen? 😉
            • Bluefox
              @Homoran:
              @Bluefox:
              Ja!
              @Bluefox:
              So ist es:
              @homoran:
              Wieso?
              @Bluefox:
              Rainer
              Darf ich jetzt wieder ./iobroker restart machen? 😉 `
              Danke. Ich habe jetzt alles.
              • Bluefox
                Kann jemand js-controller vom git ausprobieren?
                  ich habe doch schon den 0.8.8.
                  oder gibt es schon wieder eine neue Version?
                  EDIT:
                  npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                  npm WARN deprecated graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible.
                  Hat wieder nur IPv4 0.0.0.0 😞
                  Rainer
                    Solear last edited by
                    Kurzer Minianleitung für Raspi 3 und ich mache es :geek:
                      cd /opt/iobroker
                      npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
                      Rainer
                        Danke, Rainer!
                        @ Bluefox:
                        Bei mir funzt es jetzt. Habe das installiert, danach den Raspi neu gestartet ohne extra danach ./iobroker nochmal neu zu starten und es ist im Adapter die iobroker IP eingetragen, scheint auch zu funktionieren, jedenfalls hat die testweise gedrückte Türklingel eben mir ein iobroker Telegram geschickt 😄
                        Danke!!
                        Dafür erscheint bei mir jetzt ein Starline Adapter mit dem Fehler "Diese Version aus NPM konnte nicht gelesen werden". Geheimes Projekt? :geek:
                        edit: wie kann ich eigentlich die installierte js-controller Version sehen, Rainer? Weil du von 0.8.8 sprichst?
                          @Solear:
                          Dafür erscheint bei mir jetzt ein Starline Adapter mit dem Fehler "Diese Version aus NPM konnte nicht gelesen werden". Geheimes Projekt? :geek: `
                          Ist wohl für den russischen Markt - hatte das mal gegoogelt.
                          @Solear:
                          edit: wie kann ich eigentlich die installierte js-adapter Version sehen? `
                          im Reiter hosts
                          Rainer
                            Danke, Rainer! Auch für die info mit Starline. Klingt spannend. Mir haben sie mein letztes Auto geklaut :evil:
                            Unter hosts steht Verfügbar 0.8.7 und Installiert 0.8.8
                            Klappt jetzt aber wunderbar mit hm-rpc.
                              @Solear:
                              Klappt jetzt aber wunderbar mit hm-rpc. `
                              Bei mir leider nicht 😢
                              Aber vielleicht lag es daran, dass ich die 0.8.8 schon drauf hatte und dann die Datei gar nicht upgedates wurde ????
                              Daher hatte ich den neuen Adapter auch schon früher gesehen 😉 und hatte Zeit zum googlen.
                              Rainer
                                Und wenn du hinten –force an den Befehl hängst?
                                  npm WARN using --force I sure hope you know what you are doing.
                                  Das müsste ich jetzt mit NEIN beantworten :lol:
                                    [emoji28]
                                    In der Dokumentation steht dass es nur mit Gewalt nochmal lädt…
                                    https://docs.npmjs.com/cli/install
                                    Oder? [emoji85]
                                      Danke für den link.
                                      The -f or --force argument will force npm to fetch remote resources even if a local copy exists on disk.
                                      Bin mal gespannt; da kann natürlich der Wurm drin gewesen sein.
                                      EDIT: Negativ 😢
                                      reboot - Instanzen - rpc - konfig: 127.0.0.1 und 0.0.0.0 sonst nichts.
                                      STRG-F5 keine Änderung
                                      Rainer
                                      • Bluefox
                                        @Homoran:
                                        Danke für den link.
                                        EDIT: Negativ 😢
                                        Rainer `
                                        Wie sieht dein system.host.XXX => common.address ?
                                          @Bluefox:
                                          Wie sieht dein system.host.XXX => common.address ? `
                                          Wo finde ich die?
                                          Objects -systemhost-RasPi3-native-network interfaces - eth0 steht sie drin.
                                          Objects - system-adapter.hm-rpc.0 - native stand immer noch 0.0.0.0 und der Port ebenfalls auf 0.
                                          Habe dann schon einiges probiert - rpc.0 gelöscht und neu aufgebaut. - keine Änderung - auch nicht nach iobroker restart!!!
                                          unter systemadapter-hm-rpc.0 die Adresse eingegeben und erschien trotzdem nicht in der Konfig des hm.rpc.0!! auch nicht nach iobroker restart??
                                          Rainer
                                            Und wenn du per Hand von Github das herunterlädst und drüberkopierst? Geht so etwas?
                                            Gesendet von iPad mit Tapatalk
                                            11017
