    4. Beta Test js-controller 3.0.x auf GitHub
      guergen last edited by
      Ich kann machen was ich will, der tr064-Adapter spielt nicht mit:
      tr-064.0	2020-04-20 17:55:23.460	error	(2058) Password error: Please re-enter the password in Admin. Stopping
      tr-064.0	2020-04-20 17:55:23.425	info	(2058) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.20.1, js-controller: 3.0.13
      Ich habe 2 Adapter, wo ich das Fritzbox-Passwort eingeben muss, einmal den TR064 und FB-Presence.
      Beim Ersten kann ich machen was ich will, er nimmt das neue Passwort nicht.
      FB-Presence nimmt das selbe Passwort ohne Murren.
      JS 3.0.13
      Admin 4.0.9
      TR064 4.0.0
      Auch diverse Adapter geben mir folgendes im Log aus:
      2020-04-20 16:42:54.438 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      2020-04-20 16:42:54.464 - warn: maxcul.0 (9240) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.FRITZ!Box_7590_(UI).fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
      2020-04-20 16:37:14.377 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
      2020-04-20 16:27:05.260 - warn: upnp.0 (11152) State value to set is invalid for upnp.0.Repeater310.fritzbox.Alive: The state property "expire" has the wrong type "string" (should be "number")!
      2020-04-20 16:27:05.261 - warn: upnp.0 (11152) This value will not be set in future versions. Please report this to the developer.
      wendy2702 Michael Sauer 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @guergen last edited by
        @guergen sagte in Beta Test js-controller 3.0.x auf GitHub:
        TR064 4.0.0
        Tipp mal was "falsches" ein, speichern und schließen und dann das richtige.
          guergen @wendy2702 last edited by
          @wendy2702 Ich habe mir schon die Finger wund getippt.
          Bin grade schon auf Admin 4.0.5 runter nix...
            Versuche grade ein Rollback auf die 2.2.9 oder 2.2.10....
            Wie heisst denn der korrekte Befehl?
            npm install iobroker.js-controller@version
            Was muss ich anstelle von "@Version" eingeben?
            2.2.9, 2.2.10, 2.2.x.... alles schon versucht
            • wendy2702
              Logfile?
              So gemacht!?
              npm install iobroker.js-controller@2.2.9
                @wendy2702
                Hier mit 2.2.9:
                 npm install ioBroker.js-controller@2.2.9                           npm ERR! code E404
                npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller -                     Not found
                npm ERR! 404
                npm ERR! 404  'ioBroker.js-controller@2.2.9' is not in the npm registry.
                npm ERR! 404 Your package name is not valid, because
                npm ERR! 404  1. name can no longer contain capital letters
                npm ERR! 404
                npm ERR! 404 Note that you can also install from a
                npm ERR! 404 tarball, folder, http url, or git url.
                Das Selbe mit 2.2.10:
                iobroker@iobroker:/opt/iobroker$ npm install ioBroker.js-controller@2.2.10
                npm ERR! code E404
                npm ERR! 404
                npm ERR! 404  'ioBroker.js-controller@2.2.10' is not in the npm registry.
                npm ERR! 404
                Hier ein Log:
                0 info it worked if it ends with ok
                1 verbose cli [ '/usr/bin/node',
                1 verbose cli   '/usr/bin/npm',
                1 verbose cli   'install',
                1 verbose cli   'ioBroker.js-controller@2.2.9' ]
                2 info using npm@6.14.4
                3 info using node@v10.20.1
                4 verbose npm-session b1d2b8998bed8472
                5 silly install loadCurrentTree
                6 silly install readLocalPackageData
                7 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 1058ms
                8 http fetch GET 404 https://registry.npmjs.org/ioBroker.js-controller 778ms
                9 silly fetchPackageMetaData error for ioBroker.js-controller@2.2.9 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                10 timing stage:rollbackFailedOptional Completed in 1ms
                11 timing stage:runTopLevelLifecycles Completed in 4482ms
                12 verbose stack Error: 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                12 verbose stack     at res.buffer.catch.then.body (/usr/lib/node_modules/npm/node_modules/npm-registry-fetch/check-response.js:104:15)
                12 verbose stack     at process._tickCallback (internal/process/next_tick.js:68:7)
                13 verbose statusCode 404
                14 verbose pkgid ioBroker.js-controller@2.2.9
                15 verbose cwd /opt/iobroker
                16 verbose Linux 4.19.0-6-amd64
                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "ioBroker.js-controller@2.2.9"
                18 verbose node v10.20.1
                19 verbose npm  v6.14.4
                20 error code E404
                21 error 404 Not Found - GET https://registry.npmjs.org/ioBroker.js-controller - Not found
                22 error 404
                23 error 404 'ioBroker.js-controller@2.2.9' is not in the npm registry.
                24 error 404 Your package name is not valid, because
                25 error 404 1. name can no longer contain capital letters
                26 error 404 Note that you can also install from a
                27 error 404 tarball, folder, http url, or git url.
                28 verbose exit [ 1, true ]
                • wendy2702
                  Ich schreibe das:
                  du machst das:
                  man beachte das "B" in iobroker 🙂
                    @wendy2702 Wo kommt das denn her.... ich habe copy/paste gemacht.... aber von der ersten Seite ganz oben...
                    egal....
                    Der Fehler sitzt je meistend VOR dem Bildschirm...
                    • afuerhoff
                      afuerhoff Developer last edited by
                      Hallo, hab auf meinem Raspberry Pi 3 Testsystem die 3.0.13 unter Node.js 10.20.0 am Laufen. Installation lief reibungslos. Im Betrieb bis jetzt keine Auffälligkeiten. Bei der Adapter-Entwicklung hat das sofort einen Benefit gebracht, da sich ein Fehler bei der Objektbezeichnung sofort im Log angezeigt wurde.
                      Danke an die Entwickler für die Super Arbeit 🙂
                      • wendy2702
                        Kenne ich.... hier auch 😉
                          @wendy2702 Bin jetzt komplett wieder zurück, läuft...
                            apollon77 @guergen last edited by
                            @guergen und du hast nach einem Admin Update auch im Browser einen richtigen harten reload gemacht? Sonst Hast du nämlich noch
                            Den alten Admin JavaScript Code im Browser und das neue greift nicht!
                              apollon77 @wendy2702 last edited by
                              @wendy2702 Also am Ende hast Du dir einiges davon scheinbar selbst eingebrockt 😉 Ganz oben steht das Du "sudo" genutzt hast für den install. Steht so aber nicht in der Anleitung!! Damit sind alle die Fehler und ggf andere Probleme die dich zu der Fixing-Arie geführt haben wohl darauf basierend! Tja, was so 4 blöde Buchstaben so ausmachen 😉
                              ABer hast es ja dann über 5 Ecken hinbekommen.
                              Und die NPM patch-Info gibt NPM selbst aus, kommt nicht von uns
                                apollon77 @wendy2702 last edited by apollon77
                                @wendy2702 AUch hier wieder ... wo hast Du das sudo her? 😉 Wenn Du mit einem System Arbeitest welches mit dem Installer bzw Fixer erstellt ist das Bitte FINGER WEG VON SUDO! ... BÖÖÖÖÖÖSE 😉
                                Am besten jetzt den Fixer nochmal auf beiden Systemen hinterher um ggf komisches nochmal final geradezubiegen
                                harrym wendy2702 2 Replies Last reply Reply Quote 0
                                • harrym
                                  harrym @apollon77 last edited by
                                  @apollon77 🤣 aber nicht immer is sudo böse
                                    Ansonsten bedanke ich mich nochmals bei allen hier und wir verlagern die weiteren Themen jetzt in den Latest Thread --> https://forum.iobroker.net/topic/32481/js-controller-3-0-jetzt-im-latest
                                      guergen @apollon77 last edited by
                                      @apollon77 ja, hatte ich gemacht.
                                      • wendy2702
                                        wendy2702 @apollon77 last edited by
                                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                        Hm,
                                        so böse kann es nicht sein wenn es am Ende mit den 4 Buchstaben funktioniert hat aber festgelegtem User.
                                        Aber hast recht, das "sudo" beim ersten Versuch steht nicht in der Anleitung. ..... scheiß macht der Gewohnheit bevor der Fixer vor Ewigkeiten gelaufen ist.
                                        • wendy2702
                                          Gerade noch das hier im Upgrade log gefunden:
                                          The following notifications happened during sync:
                                          • Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
                                          • Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
                                          • Ignoring Directory "sayit.1" because officially not created as meta object. Please remove directory!
                                          Das _temp ist von mir erzeugt aber die beiden sayit Ordner habe ich nicht selber erzeugt:
                                            @wendy2702 Falls Du sayit als Adapter noch installiert hast dann mach ein upload sayit, falls nicht kannste löschen.
                                            js-controller
                                            39
                                            416
                                            68298
