    5. Anwesenheit an die CCU senden
    • BBTown
      BBTown @Torxplacid last edited by
      @Torxplacid
      Ich würde es womöglich über eine Funktione lösen
       <variables>
         <variable type="" id="%M2}!8m+(Y^W0[Zp$?!%">AlarmScharf</variable>
       </variables>
       <block type="schedule" id="0+LeML?/XzKmnHRio7[~" x="-324" y="-151">
         <field name="SCHEDULE">{"time":{"exactTime":true,"start":"23:00"},"period":{"days":1}}</field>
           <block type="variables_set" id="j^A+9@l`Kr4JcS/nyVp}">
             <field name="VAR" id="%M2}!8m+(Y^W0[Zp$?!%" variabletype="">AlarmScharf</field>
               <block type="logic_boolean" id="d8zvT!{Q%DwP[~rGd7wM">
               <block type="procedures_callnoreturn" id="MK5iBj0)Hxp|8]0Gltg0">
                 <mutation name="FunktionAusführen"></mutation>
           <block type="schedule" id="?[a3|95j(].pHOA?:Nic">
             <field name="SCHEDULE">{"time":{"exactTime":true,"start":"05:30"},"period":{"days":1}}</field>
               <block type="variables_set" id="S9(6.~+R0fqaw{Wquo^K">
                   <block type="logic_boolean" id="QuTl2GwZJ(a7;sh6^A)n">
                   <block type="procedures_callnoreturn" id="ZA^2p2^B`p6lf5X(4X(F">
               <block type="on_ext" id="xF==bnm27l:6rr/~Jm.P">
                 <value name="OID0">
                   <shadow type="field_oid" id="k5}k8oh(yU2a3^g`b1p^">
                     <field name="oid">Test.0.Person1</field>
                 <value name="OID1">
                   <shadow type="field_oid" id="F=?m)):-2H@aN=q!%-QK">
                     <field name="oid">Test.0.Person2</field>
                   <block type="procedures_callnoreturn" id="%QtOgY2dET:JuaF_^P?}">
       <block type="procedures_defnoreturn" id="/1h+FUyDaR{iOsFU3].`" x="38" y="-137">
         <field name="NAME">FunktionAusführen</field>
         <statement name="STACK">
           <block type="controls_if" id="Y-;z~b!~~(PL6MU(UvWy">
             <mutation elseif="1" else="1"></mutation>
               <block type="variables_get" id="sV|bn$(c8K%whLAo|n{p">
               <block type="control" id="%C9W8o@KSVqjjubPCL2O">
                 <field name="OID">Test.0.Anwesenheit</field>
                   <block type="logic_boolean" id="}:zR-Av.#K@w]79s~4wR">
             <value name="IF1">
               <block type="logic_operation" id="$KbE8#n$C%+vY*Y~x?tA" inline="false">
                 <field name="OP">AND</field>
                   <block type="logic_negate" id=";Hy{XCj=#25:?PHCkAGf">
                     <value name="BOOL">
                       <block type="get_value" id="z6^Mx5w~^3iZ1F[8gY9j">
                         <field name="OID">Test.0.Person1</field>
                   <block type="logic_negate" id="wL4HZ|Hg/|#;p:48N:*v">
                     <value name="BOOL">
                       <block type="get_value" id="HEWmOM6m#^EH9Y(S#H8;">
                         <field name="OID">Test.0.Person2</field>
             <statement name="DO1">
               <block type="control" id=")DwCKgxyLL.QN7So|2I]">
                   <block type="logic_boolean" id="jmq)b=kwpTt?t=m]YW:i">
             <statement name="ELSE">
               <block type="control" id="u0YA]1VJGNFO:_5{Dxf:">
                   <block type="logic_boolean" id="dt]AZR~M!CZ)y+(@vct;">
        Homoran Global Moderator Administrators @BBTown last edited by
        @BBTown Nimm bitte die normalen CRON-Blöcke.
        Es gibt hier im Forum immer wieder User, bei denen die von dir gewählten zu Problemen führen.
        • BBTown
          BBTown @Homoran last edited by
          @Homoran welchen meinst Du?
            @BBTown sagte in Anwesenheit an die CCU senden:
            time=exact time...
              Torxplacid @ticaki last edited by
              @ticaki
                <block type="comment" id="*}PfflVC1kr.[TsnBfZ[" x="-613" y="-38">
                  <field name="COMMENT">Nachtabschaltung</field>
                    <block type="on_ext" id="L/A!iA~ukT09,V+(,BrL">
                      <value name="OID0">
                        <shadow type="field_oid" id="scR3|/GYcQncq:g0d}-R">
                          <field name="oid">hm-rega.0.950</field>
                        <block type="controls_if" id="GeU_@`o@n@mC{BLZ,]zB">
                            <block type="logic_operation" id="LEvrvQ.26#Jj+)MA!{pL">
                                <block type="time_compare" id="`=/;i^tc!#k#PEREN7M(">
                                  <mutation end_time="true"></mutation>
                                  <field name="START_TIME">23:00</field>
                                  <field name="END_TIME">05:29</field>
                                <block type="on_source" id="0OUpJ}k]O_-:4G5r|ywQ">
                            <block type="control" id="3or|@[AT=VyPv!2Cfsn*">
                              <field name="OID">hm-rega.0.950</field>
                                <block type="logic_boolean" id="0BF;Kws_c*NfEif|@b?X">
                        <block type="comment" id="h+))*?gdqH#Wbb+QnmqM">
                          <field name="COMMENT">Schaltung nach Anwesenheit</field>
                            <block type="on_ext" id="C}%?$1}OXaPX/w74Xfv#">
                              <value name="OID0">
                                <shadow type="field_oid" id="!DzM_wsq0y`@,I}F]WU,">
                                  <field name="oid">radar2.0.Gritt._here</field>
                              <value name="OID1">
                                <shadow type="field_oid" id=")N([ZT`sFCV5?%U5:tYA">
                                  <field name="oid">radar2.0.Tim._here</field>
                                <block type="controls_if" id="?GNx8Rf^531E=)Po`mJA">
                                    <block type="logic_operation" id="O530HP7;sl^~.BsO?-]V">
                                        <block type="time_compare" id="?YfQXhoP]CWy=gN,Qj9x">
                                          <field name="START_TIME">05:30</field>
                                          <field name="END_TIME">22:59</field>
                                        <block type="logic_operation" id="593nZ6RruMT!HR?FxS?P">
                                          <field name="OP">OR</field>
                                            <block type="logic_compare" id="=gQkaV2wOyU]9c0H,/Fd">
                                              <field name="OP">EQ</field>
                                                <block type="get_value" id="S59qn/I8L*+Q--8w+Nz9">
                                                  <field name="OID">radar2.0.Gritt._here</field>
                                                <block type="logic_boolean" id="pKy-umeq,7T6a8TY~KIP">
                                            <block type="logic_compare" id="VYt%Q,BmI.TpYwvJ^Ran">
                                                <block type="get_value" id="_,yq^HcaizW^Ix:hohCo">
                                                  <field name="OID">radar2.0.Tim._here</field>
                                                <block type="logic_boolean" id="M_fSJC,kyHlV6E#=O!3s">
                                    <block type="control" id=":W3zXQb!SHZH`ERD*Eie">
                                        <block type="logic_boolean" id="P.G#%sRFeCiw(9i=7RQ-">
                                    <block type="control" id="LdeV92BdwT!pk#?=/ZWm">
                                        <block type="logic_boolean" id=";Y.VIopXwr!X$hw//k6L">
                Torxplacid @Torxplacid last edited by
                @Torxplacid sagte in Anwesenheit an die CCU senden:
                @ticaki
                        <value name="OID0">
                                <value name="OID0">
                                <value name="OID1">
                so?
                • BBTown
                  @Homoran sagte in Anwesenheit an die CCU senden:
                  time=exact time...
                  alles klar, innerhalb des Zeitplanes auf CRON gehen:
                   <variables>
                   </variables>
                   <block type="schedule" id="a`Nk7({3;ME)09g|bV$Y" x="-312" y="-162">
                     <field name="SCHEDULE">0 23 * * *</field>
                       <block type="schedule" id="@qjy:~J}:NA;/_~](!AD">
                         <field name="SCHEDULE">30 5 * * *</field>
                             <value name="OID0">
                             <value name="OID1">
                   <block type="procedures_defnoreturn" id="/1h+FUyDaR{iOsFU3].`" x="13" y="-162">
                         <value name="IF1">
                                 <value name="BOOL">
                                 <value name="BOOL">
                    Torxplacid @BBTown last edited by
                    time=exact time...
                     <variables>
                     </variables>
                               <value name="OID0">
                               <value name="OID1">
                           <value name="IF1">
                                   <value name="BOOL">
                                   <value name="BOOL">
                    Danke für die Mühe.
                    Ich werde es mal testen.
                    T T 2 Replies Last reply Reply Quote 0
                      time=exact time...
                       <variables>
                       </variables>
                                 <value name="OID0">
                                 <value name="OID1">
                             <value name="IF1">
                                     <value name="BOOL">
                                     <value name="BOOL">
                      Danke für die Mühe.
                      Ich glaube es ist verdreht. Der Wert bezieht sich auf die Anwesenheit. Wenn er wahr ist bin ich anwesend
                        ticaki Developer @Torxplacid last edited by ticaki
                        @Torxplacid
                        Meines sieht auch nicht anders aus 🙂
                        Da ist ein NICHT davor. Die 2. Prüfung geht auf Abwesenheit nicht auf Anwesenheit.
                          @ticaki sagte in Anwesenheit an die CCU senden:
                          @Torxplacid
                          ist so richtig?
                            @Torxplacid
                            Jo, wenn A nicht da ist und b nicht da ist schalte Anwesenheit auf falsch. 🙂
                              @ticaki
                              nur zum verständnis.
                              im ersten Teil steht ja das er um 23 Uhr die anwesenheit auf wahr setzt. dann bin ich ja da??
                                ticaki Developer last edited by
                                Nope er setzt eine Variable auf wahr
                                • BBTown
                                  @Torxplacid
                                  nein, es wird eine Variable Alarm scharf auf wahr gesetzt" und danach die Funktion aufgerufen
                                    Torxplacid last edited by Torxplacid
                                    Ok?
                                    Ich werde mal berichten ob es funktioniert wie gewünscht.
                                    Verstehen kann ich es nicht
                                    Aber Daumen hoch für die tolle Unterstützung.
                                    Ist es denn so richtig?
                                    Sorry für die Größe. Mein Laptop bekommt es nicht hin
                                    T Homoran BBTown 3 Replies Last reply Reply Quote 0
                                      @Torxplacid
                                      Er setzt dort Alarm auf wahr... dann fragt er ab ob alarm scharf ist und setzt wenn ja anwesenheit auf falsch.
                                        Homoran Global Moderator Administrators @Torxplacid last edited by
                                        Dafür gibt es snipping tool (oder jetzt "Ausschneiden un skizzieren")
                                          Torxplacid @Homoran last edited by
                                          @Homoran
                                          Danke für den Hinweis
                                          • BBTown
                                            BBTown @Torxplacid last edited by BBTown
                                            @Torxplacid das ist inhaltlich korrekt, aber benutze einen anderen Begriff für die Variable z.B. "varNachtalarm" um das später auch noch nachvollziehen zu können.
                                            Du verwendest gleichlautende Begriffe für unterschiedliche Situationen/Inhalte
                                            6539
