    5. Anwesenheit an die CCU senden
      Torxplacid @Torxplacid last edited by
      @Torxplacid sagte in Anwesenheit an die CCU senden:
      @ticaki
        <block type="comment" id="*}PfflVC1kr.[TsnBfZ[" x="-613" y="-38">
          <field name="COMMENT">Nachtabschaltung</field>
            <block type="on_ext" id="L/A!iA~ukT09,V+(,BrL">
              <value name="OID0">
                <shadow type="field_oid" id="scR3|/GYcQncq:g0d}-R">
                  <field name="oid">hm-rega.0.950</field>
                <block type="controls_if" id="GeU_@`o@n@mC{BLZ,]zB">
                    <block type="logic_operation" id="LEvrvQ.26#Jj+)MA!{pL">
                      <field name="OP">AND</field>
                        <block type="time_compare" id="`=/;i^tc!#k#PEREN7M(">
                          <mutation end_time="true"></mutation>
                          <field name="START_TIME">23:00</field>
                          <field name="END_TIME">05:29</field>
                        <block type="on_source" id="0OUpJ}k]O_-:4G5r|ywQ">
                    <block type="control" id="3or|@[AT=VyPv!2Cfsn*">
                      <field name="OID">hm-rega.0.950</field>
                        <block type="logic_boolean" id="0BF;Kws_c*NfEif|@b?X">
                <block type="comment" id="h+))*?gdqH#Wbb+QnmqM">
                  <field name="COMMENT">Schaltung nach Anwesenheit</field>
                    <block type="on_ext" id="C}%?$1}OXaPX/w74Xfv#">
                      <value name="OID0">
                        <shadow type="field_oid" id="!DzM_wsq0y`@,I}F]WU,">
                          <field name="oid">radar2.0.Gritt._here</field>
                      <value name="OID1">
                        <shadow type="field_oid" id=")N([ZT`sFCV5?%U5:tYA">
                          <field name="oid">radar2.0.Tim._here</field>
                        <block type="controls_if" id="?GNx8Rf^531E=)Po`mJA">
                            <block type="logic_operation" id="O530HP7;sl^~.BsO?-]V">
                                <block type="time_compare" id="?YfQXhoP]CWy=gN,Qj9x">
                                  <field name="START_TIME">05:30</field>
                                  <field name="END_TIME">22:59</field>
                                <block type="logic_operation" id="593nZ6RruMT!HR?FxS?P">
                                  <field name="OP">OR</field>
                                    <block type="logic_compare" id="=gQkaV2wOyU]9c0H,/Fd">
                                      <field name="OP">EQ</field>
                                        <block type="get_value" id="S59qn/I8L*+Q--8w+Nz9">
                                          <field name="OID">radar2.0.Gritt._here</field>
                                        <block type="logic_boolean" id="pKy-umeq,7T6a8TY~KIP">
                                    <block type="logic_compare" id="VYt%Q,BmI.TpYwvJ^Ran">
                                        <block type="get_value" id="_,yq^HcaizW^Ix:hohCo">
                                          <field name="OID">radar2.0.Tim._here</field>
                                        <block type="logic_boolean" id="M_fSJC,kyHlV6E#=O!3s">
                            <block type="control" id=":W3zXQb!SHZH`ERD*Eie">
                                <block type="logic_boolean" id="P.G#%sRFeCiw(9i=7RQ-">
                          <statement name="ELSE">
                            <block type="control" id="LdeV92BdwT!pk#?=/ZWm">
                                <block type="logic_boolean" id=";Y.VIopXwr!X$hw//k6L">
      so?
      • BBTown
        BBTown @Homoran last edited by
        @Homoran sagte in Anwesenheit an die CCU senden:
        time=exact time...
        alles klar, innerhalb des Zeitplanes auf CRON gehen:
         <variables>
           <variable type="" id="%M2}!8m+(Y^W0[Zp$?!%">AlarmScharf</variable>
         </variables>
         <block type="schedule" id="a`Nk7({3;ME)09g|bV$Y" x="-312" y="-162">
           <field name="SCHEDULE">0 23 * * *</field>
             <block type="variables_set" id="j^A+9@l`Kr4JcS/nyVp}">
               <field name="VAR" id="%M2}!8m+(Y^W0[Zp$?!%" variabletype="">AlarmScharf</field>
                 <block type="logic_boolean" id="d8zvT!{Q%DwP[~rGd7wM">
                 <block type="procedures_callnoreturn" id="MK5iBj0)Hxp|8]0Gltg0">
                   <mutation name="FunktionAusführen"></mutation>
             <block type="schedule" id="@qjy:~J}:NA;/_~](!AD">
               <field name="SCHEDULE">30 5 * * *</field>
                 <block type="variables_set" id="S9(6.~+R0fqaw{Wquo^K">
                     <block type="logic_boolean" id="QuTl2GwZJ(a7;sh6^A)n">
                     <block type="procedures_callnoreturn" id="ZA^2p2^B`p6lf5X(4X(F">
                 <block type="on_ext" id="xF==bnm27l:6rr/~Jm.P">
                   <value name="OID0">
                     <shadow type="field_oid" id="k5}k8oh(yU2a3^g`b1p^">
                       <field name="oid">Test.0.Person1</field>
                   <value name="OID1">
                     <shadow type="field_oid" id="F=?m)):-2H@aN=q!%-QK">
                       <field name="oid">Test.0.Person2</field>
                     <block type="procedures_callnoreturn" id="%QtOgY2dET:JuaF_^P?}">
         <block type="procedures_defnoreturn" id="/1h+FUyDaR{iOsFU3].`" x="13" y="-162">
           <field name="NAME">FunktionAusführen</field>
           <statement name="STACK">
             <block type="controls_if" id="Y-;z~b!~~(PL6MU(UvWy">
               <mutation elseif="1" else="1"></mutation>
                 <block type="variables_get" id="sV|bn$(c8K%whLAo|n{p">
                 <block type="control" id="%C9W8o@KSVqjjubPCL2O">
                   <field name="OID">Test.0.Anwesenheit</field>
                     <block type="logic_boolean" id="}:zR-Av.#K@w]79s~4wR">
               <value name="IF1">
                 <block type="logic_operation" id="$KbE8#n$C%+vY*Y~x?tA" inline="false">
                     <block type="logic_negate" id=";Hy{XCj=#25:?PHCkAGf">
                       <value name="BOOL">
                         <block type="get_value" id="z6^Mx5w~^3iZ1F[8gY9j">
                           <field name="OID">Test.0.Person1</field>
                     <block type="logic_negate" id="wL4HZ|Hg/|#;p:48N:*v">
                       <value name="BOOL">
                         <block type="get_value" id="HEWmOM6m#^EH9Y(S#H8;">
                           <field name="OID">Test.0.Person2</field>
               <statement name="DO1">
                 <block type="control" id=")DwCKgxyLL.QN7So|2I]">
                     <block type="logic_boolean" id="jmq)b=kwpTt?t=m]YW:i">
                 <block type="control" id="u0YA]1VJGNFO:_5{Dxf:">
                     <block type="logic_boolean" id="dt]AZR~M!CZ)y+(@vct;">
          Torxplacid @BBTown last edited by
          @BBTown sagte in Anwesenheit an die CCU senden:
          time=exact time...
           <variables>
           </variables>
                     <value name="OID0">
                     <value name="OID1">
                 <value name="IF1">
                         <value name="BOOL">
                         <value name="BOOL">
          Danke für die Mühe.
          Ich werde es mal testen.
          T T 2 Replies Last reply Reply Quote 0
            time=exact time...
             <variables>
             </variables>
                       <value name="OID0">
                       <value name="OID1">
                   <value name="IF1">
                           <value name="BOOL">
                           <value name="BOOL">
            Danke für die Mühe.
            Ich glaube es ist verdreht. Der Wert bezieht sich auf die Anwesenheit. Wenn er wahr ist bin ich anwesend
              ticaki Developer @Torxplacid last edited by ticaki
              @Torxplacid
              Meines sieht auch nicht anders aus 🙂
              Da ist ein NICHT davor. Die 2. Prüfung geht auf Abwesenheit nicht auf Anwesenheit.
                Torxplacid @ticaki last edited by
                @ticaki sagte in Anwesenheit an die CCU senden:
                @Torxplacid
                ist so richtig?
                  @Torxplacid
                  Jo, wenn A nicht da ist und b nicht da ist schalte Anwesenheit auf falsch. 🙂
                    @ticaki
                    nur zum verständnis.
                    im ersten Teil steht ja das er um 23 Uhr die anwesenheit auf wahr setzt. dann bin ich ja da??
                      ticaki Developer last edited by
                      Nope er setzt eine Variable auf wahr
                      • BBTown
                        BBTown @Torxplacid last edited by
                        @Torxplacid
                        nein, es wird eine Variable Alarm scharf auf wahr gesetzt" und danach die Funktion aufgerufen
                          Torxplacid last edited by Torxplacid
                          Ok?
                          Ich werde mal berichten ob es funktioniert wie gewünscht.
                          Verstehen kann ich es nicht
                          Aber Daumen hoch für die tolle Unterstützung.
                          Ist es denn so richtig?
                          Sorry für die Größe. Mein Laptop bekommt es nicht hin
                          T Homoran BBTown 3 Replies Last reply Reply Quote 0
                            @Torxplacid
                            Er setzt dort Alarm auf wahr... dann fragt er ab ob alarm scharf ist und setzt wenn ja anwesenheit auf falsch.
                              Homoran Global Moderator Administrators @Torxplacid last edited by
                              Dafür gibt es snipping tool (oder jetzt "Ausschneiden un skizzieren")
                                Torxplacid @Homoran last edited by
                                @Homoran
                                Danke für den Hinweis
                                • BBTown
                                  BBTown @Torxplacid last edited by BBTown
                                  @Torxplacid das ist inhaltlich korrekt, aber benutze einen anderen Begriff für die Variable z.B. "varNachtalarm" um das später auch noch nachvollziehen zu können.
                                  Du verwendest gleichlautende Begriffe für unterschiedliche Situationen/Inhalte
                                    danke nochmal, das klappt Prima.
                                    Gibt es noch die Möglichkeit da ein HTTP befehl für die Kameras einzubinden?
                                    Das heißt:
                                    Anwesend = Kamera aus
                                    nicht Anwesend bzw. Nachts = Kamera an
                                    Ich kann das über einen HTTP befehl im Browser machen.
                                    Lg
                                    • BBTown
                                      @Torxplacid
                                      schau mal hier
                                        Torxplacid @BBTown last edited by Torxplacid
                                        @BBTown
                                        im Textfeld dann den Befehl eintragen?
                                        http://192.168.1.:***/web/cgi-bin/hi3510/param.cgi?cmd=setsche.......
                                        • BBTown
                                          @Torxplacid
                                          trau dich 🙂
                                            @BBTown 🙂
                                            An welche stelle muß das denn rein?
                                            Unter mache??
                                            6539
