    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • Glasfaser
      Glasfaser @peterbaumert last edited by
      @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
      @Glasfaser Hey, nein ich sehe keine Signatur von dir.
      Synology 918+ 16GB - ioBroker in Docker v4.1.0
      Könntest du den log mal auf silly stellen und schicken?
      Kenne kein silly !
      Der Debug Log ist oben im Spoiler ....
      Aber hier nochmal :
      host.iobrokerv4	2020-04-20 19:32:14.167	info	Do not restart adapter system.adapter.vodafone-speedtest.0 because disabled or deleted
      host.iobrokerv4	2020-04-20 19:32:14.166	error	instance system.adapter.vodafone-speedtest.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      vodafone-speedtest.0	2020-04-20 19:32:13.626	warn	(7868) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      vodafone-speedtest.0	2020-04-20 19:32:13.547	error	(7868) adapter disabled
      host.iobrokerv4	2020-04-20 19:31:52.621	info	"system.adapter.vodafone-speedtest.0" disabled
      web.0	2020-04-20 19:31:51.559	info	(507) ==>Connected system.user.admin from ::ffff:192.168.178.28
      host.iobrokerv4	2020-04-20 19:31:41.657	info	Restart adapter system.adapter.vodafone-speedtest.0 because enabled
      host.iobrokerv4	2020-04-20 19:31:41.653	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
      host.iobrokerv4	2020-04-20 19:31:41.652	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
      web.0	2020-04-20 19:31:41.321	info	(507) <==Disconnect system.user.admin from ::ffff:192.168.178.28 vis.0
      vodafone-speedtest.0	2020-04-20 19:31:34.819	debug	(7359) interval: #2 @Mon Apr 20 2020 19:31:34 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:34.066	debug	(7359) interval: #3 @Mon Apr 20 2020 19:31:34 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:33.314	debug	(7359) interval: #4 @Mon Apr 20 2020 19:31:33 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:32.560	debug	(7359) interval: #5 @Mon Apr 20 2020 19:31:32 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:31.808	debug	(7359) interval: #6 @Mon Apr 20 2020 19:31:31 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:31.057	debug	(7359) interval: #7 @Mon Apr 20 2020 19:31:31 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:30.305	debug	(7359) interval: #8 @Mon Apr 20 2020 19:31:30 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:29.554	debug	(7359) interval: #9 @Mon Apr 20 2020 19:31:29 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:28.805	debug	(7359) interval: #10 @Mon Apr 20 2020 19:31:28 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:28.054	debug	(7359) interval: #11 @Mon Apr 20 2020 19:31:28 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:27.304	debug	(7359) interval: #12 @Mon Apr 20 2020 19:31:27 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:26.555	debug	(7359) interval: #13 @Mon Apr 20 2020 19:31:26 GMT+0200 (GMT+02:00)
      vodafone-speedtest.0	2020-04-20 19:31:21.833	debug	(7359) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"
      vodafone-speedtest.0	2020-04-20 19:31:21.832	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.832	debug	(7359) Create_state called for : upstreamBooked with value : 50
      vodafone-speedtest.0	2020-04-20 19:31:21.831	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.831	debug	(7359) Create_state called for : downstreamBooked with value : 1000
      vodafone-speedtest.0	2020-04-20 19:31:21.830	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.830	debug	(7359) Create_state called for : upstreamSpeed with value : 54784
      vodafone-speedtest.0	2020-04-20 19:31:21.829	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.828	debug	(7359) Create_state called for : downstreamSpeed with value : 1095680
      vodafone-speedtest.0	2020-04-20 19:31:21.828	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.827	debug	(7359) Create_state called for : ipCountry with value : DE
      vodafone-speedtest.0	2020-04-20 19:31:21.827	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.826	debug	(7359) Create_state called for : ip with value : xxxxxxxxxxxxxxxxx
      vodafone-speedtest.0	2020-04-20 19:31:21.826	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.825	debug	(7359) Create_state called for : isp with value : Vodafone GmbH
      vodafone-speedtest.0	2020-04-20 19:31:21.825	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.824	debug	(7359) Create_state called for : isCustomer with value : true
      vodafone-speedtest.0	2020-04-20 19:31:21.824	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.823	debug	(7359) Create_state called for : modem.text with value : AVM
      vodafone-speedtest.0	2020-04-20 19:31:21.823	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.822	debug	(7359) Create_state called for : modem.name with value : AVM Fritz!Box 6591
      vodafone-speedtest.0	2020-04-20 19:31:21.822	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.821	debug	(7359) Create_state called for : modem.code with value : 6591
      vodafone-speedtest.0	2020-04-20 19:31:21.820	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.820	debug	(7359) Create_state called for : modem.vendor with value : AVM
      vodafone-speedtest.0	2020-04-20 19:31:21.818	debug	(7359) Write value : false
      vodafone-speedtest.0	2020-04-20 19:31:21.817	debug	(7359) Create_state called for : modem with value : undefined
      vodafone-speedtest.0	2020-04-20 19:31:20.727	info	(7359) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v10.20.1
      vodafone-speedtest.0	2020-04-20 19:31:19.830	debug	(7359) statesDB connected
      vodafone-speedtest.0	2020-04-20 19:31:19.829	debug	(7359) States connected to redis: 127.0.0.1:9000
      vodafone-speedtest.0	2020-04-20 19:31:19.805	debug	(7359) States create System PubSub Client
      vodafone-speedtest.0	2020-04-20 19:31:19.803	debug	(7359) States create User PubSub Client
      vodafone-speedtest.0	2020-04-20 19:31:19.791	debug	(7359) Redis States: Use Redis connection: 127.0.0.1:9000
      vodafone-speedtest.0	2020-04-20 19:31:19.789	debug	(7359) objectDB connected
      vodafone-speedtest.0	2020-04-20 19:31:19.782	debug	(7359) Objects connected to redis: 127.0.0.1:9001
      vodafone-speedtest.0	2020-04-20 19:31:19.743	debug	(7359) Objects client initialize lua scripts
      vodafone-speedtest.0	2020-04-20 19:31:19.742	debug	(7359) Objects create User PubSub Client
      vodafone-speedtest.0	2020-04-20 19:31:19.741	debug	(7359) Objects create System PubSub Client
      vodafone-speedtest.0	2020-04-20 19:31:19.670	debug	(7359) Objects client ready ... initialize now
      vodafone-speedtest.0	2020-04-20 19:31:19.047	debug	(7359) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iobrokerv4	2020-04-20 19:31:18.198	info	instance system.adapter.vodafone-speedtest.0 started with pid 7359
      host.iobrokerv4	2020-04-20 19:31:18.148	info	"system.adapter.vodafone-speedtest.0" enabled
      • Dr. Bakterius
        Dr. Bakterius Most Active @peterbaumert last edited by Dr. Bakterius
        @peterbaumert Danke für deinen Adapter. Ich bin zwar kein vodafone-Kunde, habe den Adapter trotzdem getestet und mit den Werten im Browser verglichen.
        Meist wird bei mir die Instanz auch gelb angezeigt. Einmal war sie bis zum nächsten Test grün, dann wieder gelb. Im Log dazu aber keine Auffälligkeiten (auf debug gestellt).
        Ich habe eine 250/50 Mbit/s Verbindung und im Browser wird mir 162-268/32-54 Mbit/s (mehrere Test hintereinander) vom Vodafon-Test getestet. Speedtest.net misst zum Vodafon-Server in Frankfurt so zwischen 85-124/23-41 Mbit/s. Zu Servern in näheren Umfeld entsprechen die Werte meinem Produkt - also 250/50 Mbit/s. Der Adapter misst immer so um die 260-265/55-68 Mbit/s.
        Der Adapter misst also ziemlich optimistisch. 😏
        • peterbaumert
          peterbaumert Developer last edited by
          Danke @Dr-Bakterius für das Feedback,
          ja der Adapter und auch Vodafone speedtest Seite haben sehr interessante Messverhalten 😉
          Es werden x Werte genommen und dann an Vodafone Server gesendet, welcher dir dann deinen Speed ausrechnet und zurückschickt. Ich habe extra nicht selbst ausgerechnet, weil ich das Messverfahren so nah wie möglich am original lassen wollte.
          Das mit dem Geld und Grün kommt in einer neueren Version dann 🙂
          Pete
          peterbaumert 1 Reply Last reply Reply Quote 0
          • AlCalzone
            AlCalzone Developer @peterbaumert last edited by
            Hast du curl installiert? Ich habe das vergessen zu erwähnen, dass das Voraussetzung ist.
            Ohne genauer hingeschaut zu haben, was du damit treibst:
            Es gibt aber genügend Möglichkeiten in Node.js, Web-Requests zu machen (ich bevorzuge https://www.npmjs.com/package/axios), dass man dafür nicht auf Bordmittel ausweichen muss, die nur auf manchen Systemen zur Verfügung stehen.
            • peterbaumert
              Hi @AlCalzone ja da hast du recht, leider funktioniert das dort aber mit dem Upload nicht. Da Vodafone bei ihrer Seite zwei mal "Content-Length" zurückliefert und node direkt ein error schmeißt. Egal ob axios,https oder sonstige "Board-Mittel" ich hatte das erst so versucht, da ich eigentlich auch keine sonder-locken will, leider ist dies hier aber nicht möglich 😞
              AlCalzone 1 Reply Last reply Reply Quote 1
              • AlCalzone
                AlCalzone Developer @peterbaumert last edited by AlCalzone
                @peterbaumert Alles klar. Dann trag curl am besten in io-package.json in den osDependencies ein, so wie hier:
                https://github.com/ioBroker/ioBroker.zwave/blob/e3056eeb2f95524256dee73b7cf17b5402196c7d/io-package.json#L99-L101
                Da der Adapter wohl auf Windows nicht läuft, solltest du ihn wohl auch auf Linux und ggf. OSX beschränken:
                https://github.com/iobroker-community-adapters/ioBroker.rpi2/blob/f48dd198c0710560a255184b6319bee29c5c7bcb/io-package.json#L130-L132
                OSX heißt "darwin", dafür musst du entsprechend auch die osDependencies angeben.
                • peterbaumert
                  Ah okay, danke für die Tips @AlCalzone, aber auf Windows gibt es auch curl und sollte laufen. Zumindest bei den Travis builds kamen keine Fehler, getestet hab ich es natürlich nicht 😄
                  • J.A.R.V.I.S.
                    J.A.R.V.I.S. Developer last edited by J.A.R.V.I.S.
                    Windows 10
                    Node 10
                    js-controller 2.28
                    Bei mir funktioniert der Test unter Windows obgleich mit Curl oder ohne auch nicht.
                    Mit Curl:
                    2020-04-21 17:13:48.230 - info: vodafone-speedtest.0 (12840) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
                    2020-04-21 17:13:48.746 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem with value : undefined
                    2020-04-21 17:13:48.747 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.vendor with value :
                    2020-04-21 17:13:48.753 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.code with value : null
                    2020-04-21 17:13:48.754 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.name with value : null
                    2020-04-21 17:13:48.755 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Create_state called for : modem.text with value : null
                    2020-04-21 17:13:48.756 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Create_state called for : isCustomer with value : false
                    2020-04-21 17:13:48.757 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.758 - debug: vodafone-speedtest.0 (12840) Create_state called for : isp with value : Vodafone GmbH
                    2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.759 - debug: vodafone-speedtest.0 (12840) Create_state called for : ip with value : xxx.xxx.xxx.xxx
                    2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Create_state called for : ipCountry with value : DE
                    2020-04-21 17:13:48.760 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamSpeed with value : 0
                    2020-04-21 17:13:48.761 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamSpeed with value : 0
                    2020-04-21 17:13:48.762 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Create_state called for : downstreamBooked with value : null
                    2020-04-21 17:13:48.763 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Create_state called for : upstreamBooked with value : null
                    2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) Write value : false
                    2020-04-21 17:13:48.764 - debug: vodafone-speedtest.0 (12840) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
                    2020-04-21 17:13:54.010 - debug: vodafone-speedtest.0 (12840) interval: #13 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:54.758 - debug: vodafone-speedtest.0 (12840) interval: #12 @Tue Apr 21 2020 17:13:54 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:55.508 - debug: vodafone-speedtest.0 (12840) interval: #11 @Tue Apr 21 2020 17:13:55 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:56.259 - debug: vodafone-speedtest.0 (12840) interval: #10 @Tue Apr 21 2020 17:13:56 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:57.009 - debug: vodafone-speedtest.0 (12840) interval: #9 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:57.760 - debug: vodafone-speedtest.0 (12840) interval: #8 @Tue Apr 21 2020 17:13:57 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:58.508 - debug: vodafone-speedtest.0 (12840) interval: #7 @Tue Apr 21 2020 17:13:58 GMT+0200 (GMT+02:00)
                    2020-04-21 17:13:59.259 - debug: vodafone-speedtest.0 (12840) interval: #6 @Tue Apr 21 2020 17:13:59 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:00.009 - debug: vodafone-speedtest.0 (12840) interval: #5 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:00.760 - debug: vodafone-speedtest.0 (12840) interval: #4 @Tue Apr 21 2020 17:14:00 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:01.510 - debug: vodafone-speedtest.0 (12840) interval: #3 @Tue Apr 21 2020 17:14:01 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:02.261 - debug: vodafone-speedtest.0 (12840) interval: #2 @Tue Apr 21 2020 17:14:02 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:03.011 - debug: vodafone-speedtest.0 (12840) interval: #1 @Tue Apr 21 2020 17:14:03 GMT+0200 (GMT+02:00)
                    2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) uncaught exception: Curl handle is closed.
                    2020-04-21 17:14:03.257 - error: vodafone-speedtest.0 (12840) Error: Curl handle is closed.
                    at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
                    at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
                    at ontimeout (timers.js:436:11)
                    at tryOnTimeout (timers.js:300:5)
                    at listOnTimeout (timers.js:263:5)
                    at Timer.processTimers (timers.js:223:10)
                    2020-04-21 17:14:03.257 - info: vodafone-speedtest.0 (12840) cleaned everything up...
                    2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) terminating
                    2020-04-21 17:14:03.259 - info: vodafone-speedtest.0 (12840) Terminated (NO_ERROR): Without reason
                    2020-04-21 17:14:03.792 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: Error: Curl handle is closed.
                    2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Curl.close (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\node_modules\node-libcurl\dist\Curl.js:284:21)
                    2020-04-21 17:14:03.793 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timeout.stopDownloadTest (E:\Program Files\iobroker\SmartHome\node_modules\iobroker.vodafone-speedtest\main.js:475:29)
                    2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at ontimeout (timers.js:436:11)
                    2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
                    2020-04-21 17:14:03.794 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at listOnTimeout (timers.js:263:5)
                    2020-04-21 17:14:03.795 - error: host.DESKTOP-GG5M5BF Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
                    2020-04-21 17:14:03.795 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 0 (NO_ERROR)
                    Ohne Curl:
                    2020-04-21 17:10:43.716 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 started with pid 16092
                    2020-04-21 17:10:44.198 - debug: vodafone-speedtest.0 (16092) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2020-04-21 17:10:44.212 - debug: vodafone-speedtest.0 (16092) Objects client ready ... initialize now
                    2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create System PubSub Client
                    2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects create User PubSub Client
                    2020-04-21 17:10:44.214 - debug: vodafone-speedtest.0 (16092) Objects client initialize lua scripts
                    2020-04-21 17:10:44.219 - debug: vodafone-speedtest.0 (16092) Objects connected to redis: 127.0.0.1:9001
                    2020-04-21 17:10:44.222 - debug: vodafone-speedtest.0 (16092) objectDB connected
                    2020-04-21 17:10:44.223 - debug: vodafone-speedtest.0 (16092) Redis States: Use Redis connection: 127.0.0.1:6379
                    2020-04-21 17:10:44.227 - debug: vodafone-speedtest.0 (16092) States create User PubSub Client
                    2020-04-21 17:10:44.230 - debug: vodafone-speedtest.0 (16092) States create System PubSub Client
                    2020-04-21 17:10:44.232 - debug: vodafone-speedtest.0 (16092) States connected to redis: 127.0.0.1:6379
                    2020-04-21 17:10:44.233 - debug: vodafone-speedtest.0 (16092) statesDB connected
                    2020-04-21 17:10:44.256 - info: vodafone-speedtest.0 (16092) starting. Version 0.0.2 in E:/Program Files/iobroker/SmartHome/node_modules/iobroker.vodafone-speedtest, node: v10.16.3
                    2020-04-21 17:10:44.783 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem with value : undefined
                    2020-04-21 17:10:44.784 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.vendor with value :
                    2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.787 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.code with value : null
                    2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.name with value : null
                    2020-04-21 17:10:44.788 - debug: vodafone-speedtest.0 (16092) Create_state called for : modem.text with value : null
                    2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isCustomer with value : false
                    2020-04-21 17:10:44.789 - debug: vodafone-speedtest.0 (16092) Create_state called for : isp with value : Vodafone GmbH
                    2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ip with value : xxx.xxx.xxx.xxx
                    2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.790 - debug: vodafone-speedtest.0 (16092) Create_state called for : ipCountry with value : DE
                    2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamSpeed with value : 0
                    2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.791 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamSpeed with value : 0
                    2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : downstreamBooked with value : null
                    2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Write value : false
                    2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) Create_state called for : upstreamBooked with value : null
                    2020-04-21 17:10:44.792 - debug: vodafone-speedtest.0 (16092) SBC-Init (Success):{"downstreamSpeed":0,"upstreamSpeed":0,"downstreamBooked":null,"upstreamBooked":null,"speedtestId":"xxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"xxx.xxx.xxx.xxx","isCustomer":false,"vendor":"","modemType":null,"plannedImprovement":null,"isO2Customer":false,"swapScenario":null,"swapLink":null}
                    2020-04-21 17:10:50.036 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:50.788 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:10:50 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:51.536 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:10:51 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:52.286 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:10:52 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:53.036 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:53.786 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:10:53 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:54.538 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:10:54 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:55.287 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:10:55 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:56.036 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:56.786 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:10:56 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:57.536 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:10:57 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:58.286 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:10:58 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:59.036 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
                    2020-04-21 17:10:59.287 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
                    2020-04-21 17:10:59.288 - warn: vodafone-speedtest.0 (16092) startDownload abort: undefined
                    2020-04-21 17:10:59.379 - debug: vodafone-speedtest.0 (16092) result:{"type":"download","value":940000}
                    2020-04-21 17:10:59.786 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:10:59 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:02.379 - debug: vodafone-speedtest.0 (16092) interval: #16 @Tue Apr 21 2020 17:11:02 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:03.129 - debug: vodafone-speedtest.0 (16092) interval: #15 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:03.878 - debug: vodafone-speedtest.0 (16092) interval: #14 @Tue Apr 21 2020 17:11:03 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:04.628 - debug: vodafone-speedtest.0 (16092) interval: #13 @Tue Apr 21 2020 17:11:04 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:05.378 - debug: vodafone-speedtest.0 (16092) interval: #12 @Tue Apr 21 2020 17:11:05 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:06.130 - debug: vodafone-speedtest.0 (16092) interval: #11 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:06.880 - debug: vodafone-speedtest.0 (16092) interval: #10 @Tue Apr 21 2020 17:11:06 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:07.630 - debug: vodafone-speedtest.0 (16092) interval: #9 @Tue Apr 21 2020 17:11:07 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:08.379 - debug: vodafone-speedtest.0 (16092) interval: #8 @Tue Apr 21 2020 17:11:08 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:09.130 - debug: vodafone-speedtest.0 (16092) interval: #7 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:09.879 - debug: vodafone-speedtest.0 (16092) interval: #6 @Tue Apr 21 2020 17:11:09 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:10.630 - debug: vodafone-speedtest.0 (16092) interval: #5 @Tue Apr 21 2020 17:11:10 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:11.380 - debug: vodafone-speedtest.0 (16092) interval: #4 @Tue Apr 21 2020 17:11:11 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:12.130 - debug: vodafone-speedtest.0 (16092) interval: #3 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:12.880 - debug: vodafone-speedtest.0 (16092) interval: #2 @Tue Apr 21 2020 17:11:12 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:13.631 - debug: vodafone-speedtest.0 (16092) interval: #1 @Tue Apr 21 2020 17:11:13 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:13.717 - error: vodafone-speedtest.0 (16092) result: Unknown Error 500
                    2020-04-21 17:11:14.381 - debug: vodafone-speedtest.0 (16092) interval: #0 @Tue Apr 21 2020 17:11:14 GMT+0200 (GMT+02:00)
                    2020-04-21 17:11:26.626 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 (force=false, process=true)
                    2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) Got terminate signal TERMINATE_YOURSELF
                    2020-04-21 17:11:26.627 - info: vodafone-speedtest.0 (16092) cleaned everything up...
                    2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) terminating
                    2020-04-21 17:11:26.628 - info: vodafone-speedtest.0 (16092) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    2020-04-21 17:11:26.627 - info: host.DESKTOP-GG5M5BF stopInstance system.adapter.vodafone-speedtest.0 send kill signal
                    2020-04-21 17:11:27.190 - info: host.DESKTOP-GG5M5BF instance system.adapter.vodafone-speedtest.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                    • peterbaumert
                      @J-A-R-V-I-S
                      Die Einstellung "Use Curl" ist nur dafür da ob er auch für den Download curl nutzen soll, das muss ich noch besser beschreieben. Es geht darum ob du Curl installiert hast. Der Download ohne den Curl haken sieht gut aus und du scheinst 940mbit hinbekommen zu haben 🙂
                      Hier https://curl.haxx.se/windows/ solltest du curl installieren können, oder wenn du den Windows Package Manager Chocolatey nutz: https://chocolatey.org/packages/curl
                      VG
                      Pete
                      J.A.R.V.I.S. 1 Reply Last reply Reply Quote 0
                      • J.A.R.V.I.S.
                        J.A.R.V.I.S. Developer @peterbaumert last edited by
                        @peterbaumert Curl ist schon von Windows vorhanden, oder benötigt man eine andere Version?
                        • peterbaumert
                          @J-A-R-V-I-S dann hab ich nichts gesagt 😄 und teste es die tage selbst mal um genau zu sehen was das problem ist.
                          Danke für deine Rückmeldungen.
                          Pete
                          • peterbaumert
                            peterbaumert Developer @J.A.R.V.I.S. last edited by
                            @J-A-R-V-I-S kannst du dir mal die aktuelle master ausm github installieren und testen ob es damit geht?
                            • J.A.R.V.I.S.
                              @peterbaumert mit Curl funktioniert es jetzt, ohne auch, aber dann kommen immer noch die ganze Zeit die Warn-Meldungen.
                              Und ich glaube der Test ist ein bisschen unrealistisch, der zeigt beim Download immer 940 an.
                              • peterbaumert
                                @J-A-R-V-I-S ok das schonmal gut, was hast du denn für eine Leitung? Die meldungen nehm ich noch raus bzw ändere sie in silly
                                J.A.R.V.I.S. Glasfaser 2 Replies Last reply Reply Quote 0
                                • J.A.R.V.I.S.
                                  @peterbaumert 1Gbit Leitung, aber ich hatte bei anderen Tests noch nie konstant 940Mbit.
                                  ostseereiter 1 Reply Last reply Reply Quote 0
                                  • Glasfaser
                                    Glasfaser @peterbaumert last edited by Glasfaser
                                    @peterbaumert
                                    Passt auch nicht mehr .... neu von Git
                                    ohne "Use curl for download too"
                                    host.iobrokerv4	2020-04-23 15:49:10.198	info	"system.adapter.vodafone-speedtest.0" disabled
                                    vodafone-speedtest.0	2020-04-23 15:48:51.082	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:51 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:50.409	debug	(9795) result:{"type":"upload","value":51730}
                                    vodafone-speedtest.0	2020-04-23 15:48:50.408	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:50.407	debug	(9795) Create_state called for : Results.upload_Mb with value : 51.73
                                    vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:50.406	debug	(9795) Create_state called for : Results.upload_MB with value : 6.46625
                                    vodafone-speedtest.0	2020-04-23 15:48:50.405	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Create_state called for : Results.download_Mb with value : 940
                                    vodafone-speedtest.0	2020-04-23 15:48:50.404	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:50.403	debug	(9795) Create_state called for : Results.download_MB with value : 117.5
                                    vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:50.401	debug	(9795) Create_state called for : Results.Last_Run with value : Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:50.332	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:50 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:49.582	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:49 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:48.832	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:48.082	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:48 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:47.332	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:47 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:46.581	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:46 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:45.832	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:45.081	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:45 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:44.330	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:44 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:43.580	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:43 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:42.820	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:42.070	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:42 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:41.316	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:41 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:40.565	debug	(9795) interval: #14 @Thu Apr 23 2020 15:48:40 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:39.815	debug	(9795) interval: #15 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:39.069	debug	(9795) interval: #16 @Thu Apr 23 2020 15:48:39 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:34.086	debug	(9795) interval: #0 @Thu Apr 23 2020 15:48:34 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:33.604	debug	(9795) result:{"type":"download","value":940000}
                                    vodafone-speedtest.0	2020-04-23 15:48:33.524	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.523	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.522	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.521	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.520	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.519	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.518	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.517	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.516	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.515	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.513	warn	(9795) startDownload abort: undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:33.337	debug	(9795) interval: #1 @Thu Apr 23 2020 15:48:33 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:32.591	debug	(9795) interval: #2 @Thu Apr 23 2020 15:48:32 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:31.846	debug	(9795) interval: #3 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:31.084	debug	(9795) interval: #4 @Thu Apr 23 2020 15:48:31 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:30.330	debug	(9795) interval: #5 @Thu Apr 23 2020 15:48:30 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:29.576	debug	(9795) interval: #6 @Thu Apr 23 2020 15:48:29 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:28.825	debug	(9795) interval: #7 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:28.077	debug	(9795) interval: #8 @Thu Apr 23 2020 15:48:28 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:27.315	debug	(9795) interval: #9 @Thu Apr 23 2020 15:48:27 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:26.560	debug	(9795) interval: #10 @Thu Apr 23 2020 15:48:26 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:25.809	debug	(9795) interval: #11 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:25.065	debug	(9795) interval: #12 @Thu Apr 23 2020 15:48:25 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:24.271	debug	(9795) interval: #13 @Thu Apr 23 2020 15:48:24 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:48:23.429	debug	(9795) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":"
                                    vodafone-speedtest.0	2020-04-23 15:48:23.428	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.426	debug	(9795) Create_state called for : upstreamBooked with value : 50
                                    vodafone-speedtest.0	2020-04-23 15:48:23.425	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Create_state called for : downstreamBooked with value : 1000
                                    vodafone-speedtest.0	2020-04-23 15:48:23.424	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Create_state called for : upstreamSpeed with value : 54784
                                    vodafone-speedtest.0	2020-04-23 15:48:23.423	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Create_state called for : downstreamSpeed with value : 1095680
                                    vodafone-speedtest.0	2020-04-23 15:48:23.422	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.421	debug	(9795) Create_state called for : ipCountry with value : DE
                                    vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.420	debug	(9795) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                                    vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.419	debug	(9795) Create_state called for : isp with value : Vodafone GmbH
                                    vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.418	debug	(9795) Create_state called for : isCustomer with value : true
                                    vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.417	debug	(9795) Create_state called for : modem.text with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.416	debug	(9795) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                    vodafone-speedtest.0	2020-04-23 15:48:23.415	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Create_state called for : modem.code with value : 6591
                                    vodafone-speedtest.0	2020-04-23 15:48:23.414	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.413	debug	(9795) Create_state called for : modem.vendor with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:48:23.411	debug	(9795) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:48:23.410	debug	(9795) Create_state called for : modem with value : undefined
                                    vodafone-speedtest.0	2020-04-23 15:48:22.392	info	(9795) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                    vodafone-speedtest.0	2020-04-23 15:48:21.674	debug	(9795) statesDB connected
                                    vodafone-speedtest.0	2020-04-23 15:48:21.673	debug	(9795) States connected to redis: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:48:21.654	debug	(9795) States create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:48:21.652	debug	(9795) States create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:48:21.640	debug	(9795) Redis States: Use Redis connection: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:48:21.638	debug	(9795) objectDB connected
                                    vodafone-speedtest.0	2020-04-23 15:48:21.633	debug	(9795) Objects connected to redis: 127.0.0.1:9001
                                    vodafone-speedtest.0	2020-04-23 15:48:21.591	debug	(9795) Objects client initialize lua scripts
                                    vodafone-speedtest.0	2020-04-23 15:48:21.587	debug	(9795) Objects create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:48:21.585	debug	(9795) Objects create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:48:21.581	debug	(9795) Objects client ready ... initialize now
                                    vodafone-speedtest.0	2020-04-23 15:48:21.528	debug	(9795) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    host.iobrokerv4	2020-04-23 15:48:20.916	info	instance system.adapter.vodafone-speedtest.0 started with pid 9795
                                    mit "Use curl for download too"
                                    host.iobrokerv4	2020-04-23 15:52:37.906	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                                    host.iobrokerv4	2020-04-23 15:52:37.904	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                                    vodafone-speedtest.0	2020-04-23 15:52:35.372	debug	(12159) interval: #2 @Thu Apr 23 2020 15:52:35 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:34.621	debug	(12159) interval: #3 @Thu Apr 23 2020 15:52:34 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:33.867	debug	(12159) interval: #4 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:33.117	debug	(12159) interval: #5 @Thu Apr 23 2020 15:52:33 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:32.366	debug	(12159) interval: #6 @Thu Apr 23 2020 15:52:32 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:31.618	debug	(12159) interval: #7 @Thu Apr 23 2020 15:52:31 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:30.857	debug	(12159) interval: #8 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:30.109	debug	(12159) interval: #9 @Thu Apr 23 2020 15:52:30 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:29.346	debug	(12159) interval: #10 @Thu Apr 23 2020 15:52:29 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:28.596	debug	(12159) interval: #11 @Thu Apr 23 2020 15:52:28 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:27.846	debug	(12159) interval: #12 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:27.099	debug	(12159) interval: #13 @Thu Apr 23 2020 15:52:27 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:52:25.367	debug	(12159) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                                    vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.365	debug	(12159) Create_state called for : upstreamBooked with value : 50
                                    vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.364	debug	(12159) Create_state called for : downstreamBooked with value : 1000
                                    vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.363	debug	(12159) Create_state called for : upstreamSpeed with value : 54784
                                    vodafone-speedtest.0	2020-04-23 15:52:25.362	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.361	debug	(12159) Create_state called for : downstreamSpeed with value : 1095680
                                    vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.360	debug	(12159) Create_state called for : ipCountry with value : DE
                                    vodafone-speedtest.0	2020-04-23 15:52:25.359	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.358	debug	(12159) Create_state called for : ip with value : xxxxxxxxxxxxxxxxxxx
                                    vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.357	debug	(12159) Create_state called for : isp with value : Vodafone GmbH
                                    vodafone-speedtest.0	2020-04-23 15:52:25.356	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.355	debug	(12159) Create_state called for : isCustomer with value : true
                                    vodafone-speedtest.0	2020-04-23 15:52:25.354	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.353	debug	(12159) Create_state called for : modem.text with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:52:25.352	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.351	debug	(12159) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                    vodafone-speedtest.0	2020-04-23 15:52:25.346	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.345	debug	(12159) Create_state called for : modem.code with value : 6591
                                    vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.344	debug	(12159) Create_state called for : modem.vendor with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:52:25.341	debug	(12159) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:52:25.340	debug	(12159) Create_state called for : modem with value : undefined
                                    vodafone-speedtest.0	2020-04-23 15:52:24.278	info	(12159) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                    vodafone-speedtest.0	2020-04-23 15:52:23.522	debug	(12159) statesDB connected
                                    vodafone-speedtest.0	2020-04-23 15:52:23.521	debug	(12159) States connected to redis: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:52:23.500	debug	(12159) States create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:52:23.498	debug	(12159) States create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:52:23.486	debug	(12159) Redis States: Use Redis connection: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:52:23.484	debug	(12159) objectDB connected
                                    vodafone-speedtest.0	2020-04-23 15:52:23.479	debug	(12159) Objects connected to redis: 127.0.0.1:9001
                                    vodafone-speedtest.0	2020-04-23 15:52:23.443	debug	(12159) Objects client initialize lua scripts
                                    vodafone-speedtest.0	2020-04-23 15:52:23.442	debug	(12159) Objects create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:52:23.441	debug	(12159) Objects create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:52:23.438	debug	(12159) Objects client ready ... initialize now
                                    vodafone-speedtest.0	2020-04-23 15:52:23.392	debug	(12159) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    host.iobrokerv4	2020-04-23 15:52:22.618	info	instance system.adapter.vodafone-speedtest.0 started with pid 12159
                                    host.iobrokerv4	2020-04-23 15:51:52.536	info	Restart adapter system.adapter.vodafone-speedtest.0 because enabled
                                    host.iobrokerv4	2020-04-23 15:51:52.536	info	instance system.adapter.vodafone-speedtest.0 terminated with code NaN ()
                                    host.iobrokerv4	2020-04-23 15:51:52.535	warn	instance system.adapter.vodafone-speedtest.0 terminated due to SIGKILL
                                    vodafone-speedtest.0	2020-04-23 15:51:50.104	debug	(11688) interval: #3 @Thu Apr 23 2020 15:51:50 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:49.361	debug	(11688) interval: #4 @Thu Apr 23 2020 15:51:49 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:48.269	debug	(11688) interval: #5 @Thu Apr 23 2020 15:51:48 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:47.516	debug	(11688) interval: #6 @Thu Apr 23 2020 15:51:47 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:46.764	debug	(11688) interval: #7 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:46.015	debug	(11688) interval: #8 @Thu Apr 23 2020 15:51:46 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:45.263	debug	(11688) interval: #9 @Thu Apr 23 2020 15:51:45 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:44.510	debug	(11688) interval: #10 @Thu Apr 23 2020 15:51:44 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:43.761	debug	(11688) interval: #11 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:43.009	debug	(11688) interval: #12 @Thu Apr 23 2020 15:51:43 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:42.262	debug	(11688) interval: #13 @Thu Apr 23 2020 15:51:42 GMT+0200 (GMT+02:00)
                                    vodafone-speedtest.0	2020-04-23 15:51:40.597	debug	(11688) SBC-Init (Success):{"downstreamSpeed":1095680,"upstreamSpeed":54784,"downstreamBooked":1000,"upstreamBooked":50,"speedtestId":"xxxxxxxxxxxxxxx","isp":"Vodafone GmbH","ipCountry":"DE","clientIp":
                                    vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.596	debug	(11688) Create_state called for : upstreamBooked with value : 50
                                    vodafone-speedtest.0	2020-04-23 15:51:40.595	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Create_state called for : downstreamBooked with value : 1000
                                    vodafone-speedtest.0	2020-04-23 15:51:40.594	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.593	debug	(11688) Create_state called for : upstreamSpeed with value : 54784
                                    vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.592	debug	(11688) Create_state called for : downstreamSpeed with value : 1095680
                                    vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.591	debug	(11688) Create_state called for : ipCountry with value : DE
                                    vodafone-speedtest.0	2020-04-23 15:51:40.590	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Create_state called for : ip with value : xxxxxxxxxxxxxxxx
                                    vodafone-speedtest.0	2020-04-23 15:51:40.589	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Create_state called for : isp with value : Vodafone GmbH
                                    vodafone-speedtest.0	2020-04-23 15:51:40.588	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.587	debug	(11688) Create_state called for : isCustomer with value : true
                                    vodafone-speedtest.0	2020-04-23 15:51:40.586	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Create_state called for : modem.text with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:51:40.585	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.584	debug	(11688) Create_state called for : modem.name with value : AVM Fritz!Box 6591
                                    vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.583	debug	(11688) Create_state called for : modem.code with value : 6591
                                    vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.582	debug	(11688) Create_state called for : modem.vendor with value : AVM
                                    vodafone-speedtest.0	2020-04-23 15:51:40.579	debug	(11688) Write value : false
                                    vodafone-speedtest.0	2020-04-23 15:51:40.578	debug	(11688) Create_state called for : modem with value : undefined
                                    vodafone-speedtest.0	2020-04-23 15:51:39.442	info	(11688) starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.vodafone-speedtest, node: v12.16.2
                                    vodafone-speedtest.0	2020-04-23 15:51:38.814	debug	(11688) statesDB connected
                                    vodafone-speedtest.0	2020-04-23 15:51:38.813	debug	(11688) States connected to redis: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:51:38.794	debug	(11688) States create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:51:38.791	debug	(11688) States create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:51:38.779	debug	(11688) Redis States: Use Redis connection: 127.0.0.1:9000
                                    vodafone-speedtest.0	2020-04-23 15:51:38.777	debug	(11688) objectDB connected
                                    vodafone-speedtest.0	2020-04-23 15:51:38.772	debug	(11688) Objects connected to redis: 127.0.0.1:9001
                                    vodafone-speedtest.0	2020-04-23 15:51:38.737	debug	(11688) Objects client initialize lua scripts
                                    vodafone-speedtest.0	2020-04-23 15:51:38.736	debug	(11688) Objects create User PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:51:38.735	debug	(11688) Objects create System PubSub Client
                                    vodafone-speedtest.0	2020-04-23 15:51:38.732	debug	(11688) Objects client ready ... initialize now
                                    vodafone-speedtest.0	2020-04-23 15:51:38.691	debug	(11688) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    host.iobrokerv4	2020-04-23 15:51:38.093	info	instance system.adapter.vodafone-speedtest.0 started with pid 11688
                                    • peterbaumert
                                      peterbaumert Developer @Glasfaser last edited by
                                      @Glasfaser Ich schau mir das an, versuche es bei mir zu debugen. Wenn du auf der Instanz Seite den expert Modus aktiviert hast kannst du die log Option umstellen. Wenn du das auf silly stellen könntest und mir dann den log posten, würde mir das dabei sehr helfen. Danke schonmal.
                                      Pete
                                      • Dr. Bakterius
                                        Dr. Bakterius Most Active last edited by
                                        Mir ist aufgefallen, dass sich der Adapter unheimlich viel RAM krallt. Startet so bei 400MB und steigert sich mit der Zeit. Bei 850MB habe ich das System mal neu gestartet doch dann eben 400MB.
                                        Während des Tests lasse ich mir das ja einreden, doch danach sollte der RAM wieder freigegeben werden. Auf keinen Fall sollte der Bedarf immer weiter ansteigen.
                                        Oder ist das nur bei mir so?
                                        arteck RK62 2 Replies Last reply Reply Quote 0
                                          arteck Developer Most Active @Dr. Bakterius last edited by
                                          @Dr-Bakterius hier ditto
                                          • RK62
                                            RK62 @Dr. Bakterius last edited by RK62
                                            @Dr-Bakterius Bei mir auch. Ich habe die Version 0.0.3 mit ioBroker unter Docker probiert, da hat er sich während / nach der ersten Messung gleich 1085.6 MB geschnappt.
                                            Ansonsten problemlos und sie Werte scheinen plausibel.
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25287
