    4. js-controller 3.0/3.1 jetzt im Latest!
      peer69 Forum Testing last edited by
      Kann man die Meldungen zum invalid object type deaktivieren? Ich hab es den devs gemeldet, hätte jetzt aber gern wieder ein sauberes logfile.
      deconz.0	2020-04-21 16:44:54.251	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:44:54.251	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
      deconz.0	2020-04-21 16:44:53.241	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:44:53.240	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
      deconz.0	2020-04-21 16:44:38.212	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:44:38.212	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
      netatmo.0	2020-04-21 16:44:10.582	warn	(27317) This object will not be created in future versions. Please report this to the developer.
      netatmo.0	2020-04-21 16:44:10.579	warn	(27317) Object netatmo.0.My-Home.Events.5e9f06b99asdfasdfasddfasdfabb09.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
      deconz.0	2020-04-21 16:44:08.259	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:44:08.258	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
      netatmo.0	2020-04-21 16:43:59.394	warn	(27317) This object will not be created in future versions. Please report this to the developer.
      netatmo.0	2020-04-21 16:43:59.393	warn	(27317) Object netatmo.0.My-Home.Events.5e9fasdffdsafasd3fb06d.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
      netatmo.0	2020-04-21 16:43:19.367	warn	(27317) This object will not be created in future versions. Please report this to the developer.
      netatmo.0	2020-04-21 16:43:19.366	warn	(27317) Object netatmo.0.My-Home.Events.231067c231219694e4f1389.time is invalid: obj.common.type has an invalid value (date) but has to be one of number, string, boolean, array, object, mixed, file,
      deconz.0	2020-04-21 16:42:49.430	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:42:49.429	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
      deconz.0	2020-04-21 16:42:38.297	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:42:38.296	warn	(25582) State value to set is invalid for deconz.0.Groups.1.bri: The state is missing the required property val!
      deconz.0	2020-04-21 16:42:37.298	warn	(25582) This value will not be set in future versions. Please report this to the developer.
      deconz.0	2020-04-21 16:42:37.297	warn	(25582) State value to set is invalid for deconz.0.Groups.1.on: The state is missing the required property val!
      harrym apollon77 2 Replies Last reply Reply Quote 0
      • harrym
        harrym @peer69 last edited by
        @peer69 stell den loglevel auf error
          apollon77 @peer69 last edited by
          @peer69 Und Issues bei den Adaptern anlegen nicht vergessen bevor Du auf "Ignore" schaltest
            dtp last edited by dtp
            Hab gerade das Update auf den js-controller 3.0.14 und admin 4.0.9 für mein Docker-Image V4 auf der Synology DiskStation gemacht. Lief alles problemlos durch. Auch alle meine Adapter starteten ohne Fehlermeldungen.
            • ostseereiter
              ostseereiter last edited by ostseereiter
              Das Update des js-controller 3.0.14 und admin 4.0.9 lief durch. Im Moment keine Auffälligkeiten.
              • wendy2702
                Update von 3.0.13 nach 3.0.14.
                @apollon77 : Sayit upload hatte ich vorher gemacht. Jetzt kommt das:
                2020-04-21 20:58:15.785  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
                2020-04-21 20:58:15.809  - warn: readFile will not read this file (tts.userfiles/scifi.mp3) in future versions: sayit.1 is not an object of type "meta"
                2020-04-21 20:58:15.812  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
                2020-04-21 20:58:15.813  - warn: readFile will not read this file (tts.userfiles/gong.mp3) in future versions: sayit.1 is not an object of type "meta"
                Und das hier beim Yamaha Adapter: (Sorry falls es schon erwähnt wurde)
                2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeUp is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
                2020-04-21 20:59:08.020  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
                2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) Object yamaha.0.Commands.volumeDown is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
                2020-04-21 20:59:08.022  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
                2020-04-21 20:59:08.023  - warn: yamaha.0 (32612) Object yamaha.0.Commands.adjustVolume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
                2020-04-21 20:59:08.024  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
                2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) Object yamaha.0.volume is invalid: obj.common.type has an invalid value (integer) but has to be one of number, string, boolean, array, object, mixed, file, json
                2020-04-21 20:59:08.027  - warn: yamaha.0 (32612) This object will not be created in future versions. Please report this to the developer.
                Issue für Yamaha: https://github.com/iobroker-community-adapters/ioBroker.yamaha-community/issues/14
                wendy2702 created this issue in iobroker-community-adapters/ioBroker.yamaha-community
                closed Warnings with JS-Controller 3.0.14 #14
                • JB_Sullivan
                  JB_Sullivan last edited by JB_Sullivan
                  Nach dem Update auf 3.0.14 und Admin 4.0.9 habe ich jetzt einen bunten Strauß an Warn und Fehlermeldungen von verschiedenen Adaptern (vorher NULL Fehlermeldungen)
                  tr-064.0	2020-04-21 21:35:37.299	error	(10884) Password error: Please re-enter the password in Admin. Stopping
                  fritzbox.0	2020-04-21 21:35:41.038	warn	(6452) restartConnection: 10.IP.IP.
                  fritzbox.0	2020-04-21 21:35:41.035	info	(6452) adapter connected to fritzbox: 10.IP.IP.
                  innogy-smarthome.0	2020-04-21 21:37:02.227	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
                  innogy-smarthome.0	2020-04-21 21:37:02.202	info	(8720) Terminated (NO_ERROR): Without reason
                  innogy-smarthome.0	2020-04-21 21:37:02.200	info	(8720) terminating
                  innogy-smarthome.0	2020-04-21 21:37:02.192	debug	(8720) SOCKET CONNECTION TO THE INNOGY API WAS CLOSED
                  innogy-smarthome.0	2020-04-21 21:37:02.188	error	at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                  innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) Error: read ECONNRESET
                  innogy-smarthome.0	2020-04-21 21:37:02.188	error	(8720) uncaught exception: read ECONNRESET
                  Irgendwie hat man das Gefühl, das alles was mit FritzBox zu tun hat gerade kollabiert.
                  tr-064.0	2020-04-21 21:49:03.583	warn	at process.topLevelDomainCallback (domain.js:126:23)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at processImmediate (timers.js:658:5)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at tryOnImmediate (timers.js:676:5)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at runCallback (timers.js:705:18)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at Immediate.setImmediate (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:234:41)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at change (C:\iobroker\GLT\node_modules\iobroker.js-controller\lib\adapter.js:5228:34)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.EventEmitter.emit (domain.js:448:20)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.emit (events.js:198:13)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at Adapter.adapter.on.obj (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:92:41)
                  tr-064.0	2020-04-21 21:49:03.583	warn	at onMessage (C:\iobroker\GLT\node_modules\iobroker.tr-064\main.js:255:25)
                  tr-064.0	2020-04-21 21:49:03.583	warn	(3316) TypeError: Cannot read property 'forEachHostEntry' of undefined
                  tr-064.0	2020-04-21 21:49:03.561	warn	(3316) States system pmessage io.messagebox.system.adapter.tr-064.0 {"command":"discovery","message":{"onlyActive":true,"reread":false},"from":"system.adapter.admin.0","callback":{"message":{"onlyAct
                  tr-064.0	2020-04-21 21:48:58.819	error	(3316) Password error: Please re-enter the password in Admin. Stopping
                  tr-064.0	2020-04-21 21:48:58.798	info	(3316) starting. Version 4.0.0 in C:/iobroker/GLT/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.0.14
                  host.GLT	2020-04-21 21:48:56.999	info	instance system.adapter.tr-064.0 started with pid 3316
                  host.GLT	2020-04-21 21:48:56.978	info	"system.adapter.tr-064.0" enabled
                  wendy2702 apollon77 2 Replies Last reply Reply Quote 0
                    Flugschüler last edited by wendy2702
                    Hallo!
                    bin noch neu hier im Forum
                    bei mir kommt immer das und dann startet mein js adapter neu.
                    Kann mir vieleicht irgend wer helfen?
                    host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
                    host.raspberrypi	2020-04-21 20:49:09.462	error	Caught by controller[1]: Error: connect EHOSTUNREACH 192.168.1.140:22
                    host.raspberrypi	2020-04-21 20:49:09.461	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
                    • wendy2702
                      wendy2702 @JB_Sullivan last edited by
                      @JB_Sullivan bei tr064 password neu eingegeben ?
                      Bei Fritzbox die IP mal kontrollieren bzw. Eingeben.
                      • wendy2702
                        wendy2702 @Flugschüler last edited by
                        @Flugschüler was hast du denn gemacht?
                        Welche Version vom Controller?
                          Version 3.0.14 ich habe keine Fritzbox.
                          • wendy2702
                            @Flugschüler Fritzbox war nicht für dich gedacht.
                            Wohl aber die Frage was du gemacht hast.
                            • JB_Sullivan
                              JB_Sullivan @wendy2702 last edited by JB_Sullivan
                              @wendy2702 Na klar, alles kontrolliert und auch nochmal eingegeben - no way.
                              FritzDect Adapter genau das gleiche - immer Passwort Fehler, aber das PW ist 100%ig richtig
                              fritzdect.0	2020-04-21 21:56:02.467	error	(11792) Did not get session id- invalid username or password?
                              fritzdect.0	2020-04-21 21:56:02.467	error	(11792) fritzbox returned this "0000000000000000"
                              fritzdect.0	2020-04-21 21:56:00.477	info	(11792) SWITCH ID: 087610244490 identified for command (state) : true
                              fritzdect.0	2020-04-21 21:55:46.252	error	(11792) Did not get session id- invalid username or password?
                              fritzdect.0	2020-04-21 21:55:46.251	error	(11792) fritzbox returned this "0000000000000000"
                              Das interessante daran ist, das alle Instanzen grün sind.
                                Flugschüler last edited by Flugschüler
                                cd /opt/iobroker
                                sudo iobroker stop
                                sudo iobroker update
                                sudo iobroker upgrade self
                                sudo iobroker start
                                Das hab ich gemacht hab jetzt js controller 3.0.14 und der startet andauernd neu.
                                Ich glaube ich hab den Fehler gefunden.
                                Habe ein Blockly das einen ssh Befehl sendet, wenn das ausgeführt wird startet der js controller neu, aber warum?
                                Beim der Version 2.2.9 hats noch funktioniert.
                                • wendy2702
                                  @Flugschüler eventuell was das „sudo“ der Fehler.
                                  Ich spreche aus Erfahrung, auch wenn ich andere Probleme hatte.
                                  Ich würde als erstes mal den Fixer laufen lassen.
                                  sudo curl -sL https://iobroker.net/fix.sh | bash -
                                    Flugschüler @wendy2702 last edited by
                                    @wendy2702 Nein das Blockly mit dem ssh befehl ist schuld, wenn ich das deaktiviere ist der Fehler weg.
                                    • wendy2702
                                      @JB_Sullivan werden denn die Objecte aktualisiert?
                                      Vielleicht hat die FB den User wegen zu vielen Fehlversuchen für eine gewisse Zeit gesperrt. Ähnlich dem WEB Admin login der Fritte.
                                      Darüber gibt es hier auch Berichte.
                                      Instanzen stoppen. Fritte neu starten, 15 Minuten warten und dann erneut probieren hat in den fällen geholfen.
                                      Admin hast du 4.0.9 ?
                                      • wendy2702
                                        @Flugschüler Na dann...
                                        Perfekt.
                                          @wendy2702 Nicht ganz, ich brauche das Blockly um einen anderen Raspberry herunter zu fahren. Hat beim alten js ja funktioniert.
                                          • Iccube
                                            Iccube last edited by
                                            nach dem update auf 3.0.14 und Admin 4.0.9 habe ich folgende Warnmeldung
                                            2020-04-21 22:22:10.934 - warn: writeFile will not write this file (/htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                                            2020-04-21 22:22:10.939 - warn: writeFile will not write this file (htmlinfo.html) in future versions: iqontrol.meta is not an object of type "meta"
                                            Kann mir einer sagen was das heißt habe den iqontrol adapter nicht installiert
                                            js-controller
                                            127
                                            1340
                                            443225
